[U-Boot] [PATCH v4] usb: host: Print device name when scanning
Drop the counter, it has no meaning other than being the order in which the interface is found; the name assigned to the USB host controller interface is a better indicator.
Example of the original output:
USB0: USB EHCI 1.10 scanning bus 0 for devices... 2 USB Device(s) found scanning usb for storage devices... 1 Storage Device(s) found
Patched output:
Bus usb@ee080100: USB EHCI 1.10 scanning bus usb@ee080100 for devices... 2 USB Device(s) found scanning usb for storage devices... 1 Storage Device(s) found
Signed-off-by: Ismael Luceno ismael.luceno@silicon-gears.com ---
Notes: Changes since v3: - Replaced dev->seq with dev->name in usb_scan_bus
Changes since v2: - Dropped counter altogether.
Changes since v1: - Improved commit message.
drivers/usb/host/usb-uclass.c | 12 ++++-------- 1 file changed, 4 insertions(+), 8 deletions(-)
diff --git a/drivers/usb/host/usb-uclass.c b/drivers/usb/host/usb-uclass.c index 611ea97a72..6e118b5a8f 100644 --- a/drivers/usb/host/usb-uclass.c +++ b/drivers/usb/host/usb-uclass.c @@ -210,7 +210,7 @@ static void usb_scan_bus(struct udevice *bus, bool recurse)
assert(recurse); /* TODO: Support non-recusive */
- printf("scanning bus %d for devices... ", bus->seq); + printf("scanning bus %s for devices... ", bus->name); debug("\n"); ret = usb_scan_device(bus, 0, USB_SPEED_FULL, &dev); if (ret) @@ -242,7 +242,6 @@ int usb_init(void) struct usb_bus_priv *priv; struct udevice *bus; struct uclass *uc; - int count = 0; int ret;
asynch_allowed = 1; @@ -255,8 +254,7 @@ int usb_init(void)
uclass_foreach_dev(bus, uc) { /* init low_level USB */ - printf("USB%d: ", count); - count++; + printf("Bus %s: ", bus->name);
#ifdef CONFIG_SANDBOX /* @@ -327,10 +325,8 @@ int usb_init(void) remove_inactive_children(uc, bus);
/* if we were not able to find at least one working bus, bail out */ - if (!count) - printf("No controllers found\n"); - else if (controllers_initialized == 0) - printf("USB error: all controllers failed lowlevel init\n"); + if (controllers_initialized == 0) + printf("No working controllers found\n");
return usb_started ? 0 : -1; }
base-commit: 9ba5e5bc261a16f51662490da0cf620dc7f29013 prerequisite-patch-id: 8ebbc14087da985e5db35ef02335fbfdb4add60a
Patched output:
Changes since v2: - Dropped counter altogether. Changes since v1: - Improved commit message.
- printf("scanning bus %s for devices... ", bus->name); debug("\n"); ret = usb_scan_device(bus, 0, USB_SPEED_FULL, &dev); if (ret)
asynch_allowed = 1;
count++;
- if (!count)
Applied, thanks.
I wonder if this might break on non-DM/DT platforms though.
