[U-Boot] [PATCH 5/5] ppc4xx: Big header cleanup part 2, mostly PPC405 related
This cleanup is done by creating header files for all SoC versions and moving the SoC specific defines into these special headers. This way the common header ppc405.h and ppc440.h can be cleaned up finally.
As a part from this cleanup, the GPIO definitions for PPC405EP are corrected. The high and low parts of the registers (for example CONFIG_SYS_GPIO0_OSRL vs. CONFIG_SYS_GPIO0_OSRH) have been defined in the wrong order. This patch now fixes this issue by switching these xxxH and xxxL values. This brings the GPIO 405EP port in sync with all other PPC4xx ports.
Signed-off-by: Stefan Roese sr@denx.de --- arch/powerpc/cpu/ppc4xx/4xx_uart.c | 4 +- arch/powerpc/cpu/ppc4xx/cpu_init.c | 2 +- arch/powerpc/cpu/ppc4xx/gpio.c | 5 + arch/powerpc/cpu/ppc4xx/speed.c | 2 +- arch/powerpc/include/asm/ppc405.h | 799 ++---------------------------- arch/powerpc/include/asm/ppc405cr.h | 74 +++ arch/powerpc/include/asm/ppc405ep.h | 221 ++++++++ arch/powerpc/include/asm/ppc405ex.h | 57 ++- arch/powerpc/include/asm/ppc405ez.h | 69 +++ arch/powerpc/include/asm/ppc405gp.h | 77 +++ arch/powerpc/include/asm/ppc440.h | 64 --- arch/powerpc/include/asm/ppc440ep_gr.h | 2 - arch/powerpc/include/asm/ppc440epx_grx.h | 2 - arch/powerpc/include/asm/ppc440sp.h | 2 - arch/powerpc/include/asm/ppc440spe.h | 2 - arch/powerpc/include/asm/ppc460ex_gt.h | 2 - arch/powerpc/include/asm/ppc460sx.h | 2 - arch/powerpc/include/asm/ppc4xx.h | 69 +++ board/amcc/acadia/pll.c | 28 +- board/mpl/mip405/init.S | 3 +- board/mpl/mip405/mip405.c | 1 + board/mpl/pip405/init.S | 3 +- board/sc3/sc3.c | 10 +- include/configs/ASH405.h | 10 +- include/configs/CATcenter.h | 12 +- include/configs/CMS700.h | 12 +- include/configs/DP405.h | 12 +- include/configs/G2000.h | 10 +- include/configs/HH405.h | 10 +- include/configs/HUB405.h | 10 +- include/configs/PLU405.h | 10 +- include/configs/PPChameleonEVB.h | 12 +- include/configs/VOH405.h | 10 +- include/configs/VOM405.h | 12 +- include/configs/WUH405.h | 10 +- include/configs/bubinga.h | 10 +- include/configs/quad100hd.h | 10 +- include/configs/zeus.h | 10 +- 38 files changed, 712 insertions(+), 948 deletions(-)
diff --git a/arch/powerpc/cpu/ppc4xx/4xx_uart.c b/arch/powerpc/cpu/ppc4xx/4xx_uart.c index 9a11f3b..5eaeefe 100644 --- a/arch/powerpc/cpu/ppc4xx/4xx_uart.c +++ b/arch/powerpc/cpu/ppc4xx/4xx_uart.c @@ -312,10 +312,10 @@ static void serial_divs (int baudrate, unsigned long *pudiv, }
*pudiv = udiv; - mfcpr(CPC0_PERD0, reg); + mfcpr(CPR0_PERD0, reg); reg &= ~0x0000ffff; reg |= ((udiv - 0) << 8) | (udiv - 0); - mtcpr(CPC0_PERD0, reg); + mtcpr(CPR0_PERD0, reg); *pbdiv = div / udiv; } #endif /* defined(CONFIG_440) && !defined(CONFIG_SYS_EXT_SERIAL_CLK) */ diff --git a/arch/powerpc/cpu/ppc4xx/cpu_init.c b/arch/powerpc/cpu/ppc4xx/cpu_init.c index 677a4b5..d54b30e 100644 --- a/arch/powerpc/cpu/ppc4xx/cpu_init.c +++ b/arch/powerpc/cpu/ppc4xx/cpu_init.c @@ -266,7 +266,7 @@ cpu_init_f (void) /* * Set EMAC noise filter bits */ - mtdcr(CPC0_EPCTL, CPC0_EPRCSR_E0NFE | CPC0_EPRCSR_E1NFE); + mtdcr(CPC0_EPCTL, CPC0_EPCTL_E0NFE | CPC0_EPCTL_E1NFE); #endif /* CONFIG_405EP */
#if defined(CONFIG_SYS_4xx_GPIO_TABLE) diff --git a/arch/powerpc/cpu/ppc4xx/gpio.c b/arch/powerpc/cpu/ppc4xx/gpio.c index 1f9f93a..20f0572 100644 --- a/arch/powerpc/cpu/ppc4xx/gpio.c +++ b/arch/powerpc/cpu/ppc4xx/gpio.c @@ -26,6 +26,9 @@ #include <asm/io.h> #include <asm/ppc4xx-gpio.h>
+/* Only compile this file for boards with GPIO support */ +#if defined(GPIO0_BASE) + #if defined(CONFIG_SYS_4xx_GPIO_TABLE) gpio_param_s const gpio_tab[GPIO_GROUP_MAX][GPIO_MAX] = CONFIG_SYS_4xx_GPIO_TABLE; #endif @@ -252,4 +255,6 @@ void gpio_set_chip_configuration(void) } } } + +#endif /* GPIO0_BASE */ #endif /* CONFIG_SYS_4xx_GPIO_TABLE */ diff --git a/arch/powerpc/cpu/ppc4xx/speed.c b/arch/powerpc/cpu/ppc4xx/speed.c index 4d7eb29..abd4e91 100644 --- a/arch/powerpc/cpu/ppc4xx/speed.c +++ b/arch/powerpc/cpu/ppc4xx/speed.c @@ -902,7 +902,7 @@ void get_sys_info (PPC4xx_SYS_INFO * sysInfo) /* * Read CPR_PRIMAD register */ - mfcpr(CPC0_PRIMAD, cpr_primad); + mfcpr(CPR0_PRIMAD, cpr_primad);
/* * Determine PLB_DIV. diff --git a/arch/powerpc/include/asm/ppc405.h b/arch/powerpc/include/asm/ppc405.h index e0d165e..14a7a37 100644 --- a/arch/powerpc/include/asm/ppc405.h +++ b/arch/powerpc/include/asm/ppc405.h @@ -37,773 +37,44 @@ /* DCR registers */ #define PLB0_ACR 0x0087
-/****************************************************************************** - * Special for PPC405GP - ******************************************************************************/ - -/****************************************************************************** - * DMA - ******************************************************************************/ -#define DMA_DCR_BASE 0x100 -#define DMACR0 (DMA_DCR_BASE+0x00) /* DMA channel control register 0 */ -#define DMACT0 (DMA_DCR_BASE+0x01) /* DMA count register 0 */ -#define DMADA0 (DMA_DCR_BASE+0x02) /* DMA destination address register 0 */ -#define DMASA0 (DMA_DCR_BASE+0x03) /* DMA source address register 0 */ -#define DMASB0 (DMA_DCR_BASE+0x04) /* DMA scatter/gather descriptor addr 0 */ -#define DMACR1 (DMA_DCR_BASE+0x08) /* DMA channel control register 1 */ -#define DMACT1 (DMA_DCR_BASE+0x09) /* DMA count register 1 */ -#define DMADA1 (DMA_DCR_BASE+0x0a) /* DMA destination address register 1 */ -#define DMASA1 (DMA_DCR_BASE+0x0b) /* DMA source address register 1 */ -#define DMASB1 (DMA_DCR_BASE+0x0c) /* DMA scatter/gather descriptor addr 1 */ -#define DMACR2 (DMA_DCR_BASE+0x10) /* DMA channel control register 2 */ -#define DMACT2 (DMA_DCR_BASE+0x11) /* DMA count register 2 */ -#define DMADA2 (DMA_DCR_BASE+0x12) /* DMA destination address register 2 */ -#define DMASA2 (DMA_DCR_BASE+0x13) /* DMA source address register 2 */ -#define DMASB2 (DMA_DCR_BASE+0x14) /* DMA scatter/gather descriptor addr 2 */ -#define DMACR3 (DMA_DCR_BASE+0x18) /* DMA channel control register 3 */ -#define DMACT3 (DMA_DCR_BASE+0x19) /* DMA count register 3 */ -#define DMADA3 (DMA_DCR_BASE+0x1a) /* DMA destination address register 3 */ -#define DMASA3 (DMA_DCR_BASE+0x1b) /* DMA source address register 3 */ -#define DMASB3 (DMA_DCR_BASE+0x1c) /* DMA scatter/gather descriptor addr 3 */ -#define DMASR (DMA_DCR_BASE+0x20) /* DMA status register */ -#define DMASGC (DMA_DCR_BASE+0x23) /* DMA scatter/gather command register */ -#define DMAADR (DMA_DCR_BASE+0x24) /* DMA address decode register */ - -#ifndef CONFIG_405EP -/****************************************************************************** - * Decompression Controller - ******************************************************************************/ -#define DECOMP_DCR_BASE 0x14 -#define KIAR (DECOMP_DCR_BASE+0x0) /* Decompression controller addr reg */ -#define KIDR (DECOMP_DCR_BASE+0x1) /* Decompression controller data reg */ -/* values for kiar register - indirect addressing of these regs */ -#define KCONF 0x40 /* decompression core config register */ -#endif - -/****************************************************************************** - * Power Management - ******************************************************************************/ -#ifdef CONFIG_405EX -#define POWERMAN_DCR_BASE 0xb0 -#else -#define POWERMAN_DCR_BASE 0xb8 -#endif -#define CPMSR (POWERMAN_DCR_BASE+0x0) /* Power management status */ -#define CPMER (POWERMAN_DCR_BASE+0x1) /* Power management enable */ -#define CPMFR (POWERMAN_DCR_BASE+0x2) /* Power management force */ - -/****************************************************************************** - * Extrnal Bus Controller - ******************************************************************************/ - /* values for EBC0_CFGADDR register - indirect addressing of these regs */ - #define PB0CR 0x00 /* periph bank 0 config reg */ - #define PB1CR 0x01 /* periph bank 1 config reg */ - #define PB2CR 0x02 /* periph bank 2 config reg */ - #define PB3CR 0x03 /* periph bank 3 config reg */ - #define PB4CR 0x04 /* periph bank 4 config reg */ -#ifndef CONFIG_405EP - #define PB5CR 0x05 /* periph bank 5 config reg */ - #define PB6CR 0x06 /* periph bank 6 config reg */ - #define PB7CR 0x07 /* periph bank 7 config reg */ -#endif - #define PB0AP 0x10 /* periph bank 0 access parameters */ - #define PB1AP 0x11 /* periph bank 1 access parameters */ - #define PB2AP 0x12 /* periph bank 2 access parameters */ - #define PB3AP 0x13 /* periph bank 3 access parameters */ - #define PB4AP 0x14 /* periph bank 4 access parameters */ -#ifndef CONFIG_405EP - #define PB5AP 0x15 /* periph bank 5 access parameters */ - #define PB6AP 0x16 /* periph bank 6 access parameters */ - #define PB7AP 0x17 /* periph bank 7 access parameters */ -#endif - #define PBEAR 0x20 /* periph bus error addr reg */ - #define PBESR0 0x21 /* periph bus error status reg 0 */ - #define PBESR1 0x22 /* periph bus error status reg 1 */ -#define EBC0_CFG 0x23 /* external bus configuration reg */ - -#ifdef CONFIG_405EP -/****************************************************************************** - * Control - ******************************************************************************/ -#define CNTRL_DCR_BASE 0x0f0 -#define CPC0_PLLMR0 (CNTRL_DCR_BASE+0x0) /* PLL mode register 0 */ -#define CPC0_BOOT (CNTRL_DCR_BASE+0x1) /* Clock status register */ -#define CPC0_EPCTL (CNTRL_DCR_BASE+0x3) /* EMAC to PHY control register */ -#define CPC0_PLLMR1 (CNTRL_DCR_BASE+0x4) /* PLL mode register 1 */ -#define CPC0_UCR (CNTRL_DCR_BASE+0x5) /* UART control register */ -#define CPC0_PCI (CNTRL_DCR_BASE+0x9) /* PCI control register */ - -#define CPC0_PLLMR0 (CNTRL_DCR_BASE+0x0) /* PLL mode 0 register */ -#define CPC0_BOOT (CNTRL_DCR_BASE+0x1) /* Chip Clock Status register */ -#define CPC0_CR1 (CNTRL_DCR_BASE+0x2) /* Chip Control 1 register */ -#define CPC0_EPRCSR (CNTRL_DCR_BASE+0x3) /* EMAC PHY Rcv Clk Src register */ -#define CPC0_PLLMR1 (CNTRL_DCR_BASE+0x4) /* PLL mode 1 register */ -#define CPC0_UCR (CNTRL_DCR_BASE+0x5) /* UART Control register */ -#define CPC0_SRR (CNTRL_DCR_BASE+0x6) /* Soft Reset register */ -#define CPC0_JTAGID (CNTRL_DCR_BASE+0x7) /* JTAG ID register */ -#define CPC0_SPARE (CNTRL_DCR_BASE+0x8) /* Spare DCR */ -#define CPC0_PCI (CNTRL_DCR_BASE+0x9) /* PCI Control register */ - -/* Bit definitions */ -#define PLLMR0_CPU_DIV_MASK 0x00300000 /* CPU clock divider */ -#define PLLMR0_CPU_DIV_BYPASS 0x00000000 -#define PLLMR0_CPU_DIV_2 0x00100000 -#define PLLMR0_CPU_DIV_3 0x00200000 -#define PLLMR0_CPU_DIV_4 0x00300000 - -#define PLLMR0_CPU_TO_PLB_MASK 0x00030000 /* CPU:PLB Frequency Divisor */ -#define PLLMR0_CPU_PLB_DIV_1 0x00000000 -#define PLLMR0_CPU_PLB_DIV_2 0x00010000 -#define PLLMR0_CPU_PLB_DIV_3 0x00020000 -#define PLLMR0_CPU_PLB_DIV_4 0x00030000 - -#define PLLMR0_OPB_TO_PLB_MASK 0x00003000 /* OPB:PLB Frequency Divisor */ -#define PLLMR0_OPB_PLB_DIV_1 0x00000000 -#define PLLMR0_OPB_PLB_DIV_2 0x00001000 -#define PLLMR0_OPB_PLB_DIV_3 0x00002000 -#define PLLMR0_OPB_PLB_DIV_4 0x00003000 - -#define PLLMR0_EXB_TO_PLB_MASK 0x00000300 /* External Bus:PLB Divisor */ -#define PLLMR0_EXB_PLB_DIV_2 0x00000000 -#define PLLMR0_EXB_PLB_DIV_3 0x00000100 -#define PLLMR0_EXB_PLB_DIV_4 0x00000200 -#define PLLMR0_EXB_PLB_DIV_5 0x00000300 - -#define PLLMR0_MAL_TO_PLB_MASK 0x00000030 /* MAL:PLB Divisor */ -#define PLLMR0_MAL_PLB_DIV_1 0x00000000 -#define PLLMR0_MAL_PLB_DIV_2 0x00000010 -#define PLLMR0_MAL_PLB_DIV_3 0x00000020 -#define PLLMR0_MAL_PLB_DIV_4 0x00000030 - -#define PLLMR0_PCI_TO_PLB_MASK 0x00000003 /* PCI:PLB Frequency Divisor */ -#define PLLMR0_PCI_PLB_DIV_1 0x00000000 -#define PLLMR0_PCI_PLB_DIV_2 0x00000001 -#define PLLMR0_PCI_PLB_DIV_3 0x00000002 -#define PLLMR0_PCI_PLB_DIV_4 0x00000003 - -#define PLLMR1_SSCS_MASK 0x80000000 /* Select system clock source */ -#define PLLMR1_PLLR_MASK 0x40000000 /* PLL reset */ -#define PLLMR1_FBMUL_MASK 0x00F00000 /* PLL feedback multiplier value */ -#define PLLMR1_FBMUL_DIV_16 0x00000000 -#define PLLMR1_FBMUL_DIV_1 0x00100000 -#define PLLMR1_FBMUL_DIV_2 0x00200000 -#define PLLMR1_FBMUL_DIV_3 0x00300000 -#define PLLMR1_FBMUL_DIV_4 0x00400000 -#define PLLMR1_FBMUL_DIV_5 0x00500000 -#define PLLMR1_FBMUL_DIV_6 0x00600000 -#define PLLMR1_FBMUL_DIV_7 0x00700000 -#define PLLMR1_FBMUL_DIV_8 0x00800000 -#define PLLMR1_FBMUL_DIV_9 0x00900000 -#define PLLMR1_FBMUL_DIV_10 0x00A00000 -#define PLLMR1_FBMUL_DIV_11 0x00B00000 -#define PLLMR1_FBMUL_DIV_12 0x00C00000 -#define PLLMR1_FBMUL_DIV_13 0x00D00000 -#define PLLMR1_FBMUL_DIV_14 0x00E00000 -#define PLLMR1_FBMUL_DIV_15 0x00F00000 - -#define PLLMR1_FWDVA_MASK 0x00070000 /* PLL forward divider A value */ -#define PLLMR1_FWDVA_DIV_8 0x00000000 -#define PLLMR1_FWDVA_DIV_7 0x00010000 -#define PLLMR1_FWDVA_DIV_6 0x00020000 -#define PLLMR1_FWDVA_DIV_5 0x00030000 -#define PLLMR1_FWDVA_DIV_4 0x00040000 -#define PLLMR1_FWDVA_DIV_3 0x00050000 -#define PLLMR1_FWDVA_DIV_2 0x00060000 -#define PLLMR1_FWDVA_DIV_1 0x00070000 -#define PLLMR1_FWDVB_MASK 0x00007000 /* PLL forward divider B value */ -#define PLLMR1_TUNING_MASK 0x000003FF /* PLL tune bits */ - -/* Defines for CPC0_EPRCSR register */ -#define CPC0_EPRCSR_E0NFE 0x80000000 -#define CPC0_EPRCSR_E1NFE 0x40000000 -#define CPC0_EPRCSR_E1RPP 0x00000080 -#define CPC0_EPRCSR_E0RPP 0x00000040 -#define CPC0_EPRCSR_E1ERP 0x00000020 -#define CPC0_EPRCSR_E0ERP 0x00000010 -#define CPC0_EPRCSR_E1PCI 0x00000002 -#define CPC0_EPRCSR_E0PCI 0x00000001 - -/* Defines for CPC0_PCI Register */ -#define CPC0_PCI_SPE 0x00000010 /* PCIINT/WE select */ -#define CPC0_PCI_HOST_CFG_EN 0x00000008 /* PCI host config Enable */ -#define CPC0_PCI_ARBIT_EN 0x00000001 /* PCI Internal Arb Enabled */ - -/* Defines for CPC0_BOOR Register */ -#define CPC0_BOOT_SEP 0x00000002 /* serial EEPROM present */ - -/* Defines for CPC0_PLLMR1 Register fields */ -#define PLL_ACTIVE 0x80000000 -#define CPC0_PLLMR1_SSCS 0x80000000 -#define PLL_RESET 0x40000000 -#define CPC0_PLLMR1_PLLR 0x40000000 - /* Feedback multiplier */ -#define PLL_FBKDIV 0x00F00000 -#define CPC0_PLLMR1_FBDV 0x00F00000 -#define PLL_FBKDIV_16 0x00000000 -#define PLL_FBKDIV_1 0x00100000 -#define PLL_FBKDIV_2 0x00200000 -#define PLL_FBKDIV_3 0x00300000 -#define PLL_FBKDIV_4 0x00400000 -#define PLL_FBKDIV_5 0x00500000 -#define PLL_FBKDIV_6 0x00600000 -#define PLL_FBKDIV_7 0x00700000 -#define PLL_FBKDIV_8 0x00800000 -#define PLL_FBKDIV_9 0x00900000 -#define PLL_FBKDIV_10 0x00A00000 -#define PLL_FBKDIV_11 0x00B00000 -#define PLL_FBKDIV_12 0x00C00000 -#define PLL_FBKDIV_13 0x00D00000 -#define PLL_FBKDIV_14 0x00E00000 -#define PLL_FBKDIV_15 0x00F00000 - /* Forward A divisor */ -#define PLL_FWDDIVA 0x00070000 -#define CPC0_PLLMR1_FWDVA 0x00070000 -#define PLL_FWDDIVA_8 0x00000000 -#define PLL_FWDDIVA_7 0x00010000 -#define PLL_FWDDIVA_6 0x00020000 -#define PLL_FWDDIVA_5 0x00030000 -#define PLL_FWDDIVA_4 0x00040000 -#define PLL_FWDDIVA_3 0x00050000 -#define PLL_FWDDIVA_2 0x00060000 -#define PLL_FWDDIVA_1 0x00070000 - /* Forward B divisor */ -#define PLL_FWDDIVB 0x00007000 -#define CPC0_PLLMR1_FWDVB 0x00007000 -#define PLL_FWDDIVB_8 0x00000000 -#define PLL_FWDDIVB_7 0x00001000 -#define PLL_FWDDIVB_6 0x00002000 -#define PLL_FWDDIVB_5 0x00003000 -#define PLL_FWDDIVB_4 0x00004000 -#define PLL_FWDDIVB_3 0x00005000 -#define PLL_FWDDIVB_2 0x00006000 -#define PLL_FWDDIVB_1 0x00007000 - /* PLL tune bits */ -#define PLL_TUNE_MASK 0x000003FF -#define PLL_TUNE_2_M_3 0x00000133 /* 2 <= M <= 3 */ -#define PLL_TUNE_4_M_6 0x00000134 /* 3 < M <= 6 */ -#define PLL_TUNE_7_M_10 0x00000138 /* 6 < M <= 10 */ -#define PLL_TUNE_11_M_14 0x0000013C /* 10 < M <= 14 */ -#define PLL_TUNE_15_M_40 0x0000023E /* 14 < M <= 40 */ -#define PLL_TUNE_VCO_LOW 0x00000000 /* 500MHz <= VCO <= 800MHz */ -#define PLL_TUNE_VCO_HI 0x00000080 /* 800MHz < VCO <= 1000MHz */ - -/* Defines for CPC0_PLLMR0 Register fields */ - /* CPU divisor */ -#define PLL_CPUDIV 0x00300000 -#define CPC0_PLLMR0_CCDV 0x00300000 -#define PLL_CPUDIV_1 0x00000000 -#define PLL_CPUDIV_2 0x00100000 -#define PLL_CPUDIV_3 0x00200000 -#define PLL_CPUDIV_4 0x00300000 - /* PLB divisor */ -#define PLL_PLBDIV 0x00030000 -#define CPC0_PLLMR0_CBDV 0x00030000 -#define PLL_PLBDIV_1 0x00000000 -#define PLL_PLBDIV_2 0x00010000 -#define PLL_PLBDIV_3 0x00020000 -#define PLL_PLBDIV_4 0x00030000 - /* OPB divisor */ -#define PLL_OPBDIV 0x00003000 -#define CPC0_PLLMR0_OPDV 0x00003000 -#define PLL_OPBDIV_1 0x00000000 -#define PLL_OPBDIV_2 0x00001000 -#define PLL_OPBDIV_3 0x00002000 -#define PLL_OPBDIV_4 0x00003000 - /* EBC divisor */ -#define PLL_EXTBUSDIV 0x00000300 -#define CPC0_PLLMR0_EPDV 0x00000300 -#define PLL_EXTBUSDIV_2 0x00000000 -#define PLL_EXTBUSDIV_3 0x00000100 -#define PLL_EXTBUSDIV_4 0x00000200 -#define PLL_EXTBUSDIV_5 0x00000300 - /* MAL divisor */ -#define PLL_MALDIV 0x00000030 -#define CPC0_PLLMR0_MPDV 0x00000030 -#define PLL_MALDIV_1 0x00000000 -#define PLL_MALDIV_2 0x00000010 -#define PLL_MALDIV_3 0x00000020 -#define PLL_MALDIV_4 0x00000030 - /* PCI divisor */ -#define PLL_PCIDIV 0x00000003 -#define CPC0_PLLMR0_PPFD 0x00000003 -#define PLL_PCIDIV_1 0x00000000 -#define PLL_PCIDIV_2 0x00000001 -#define PLL_PCIDIV_3 0x00000002 -#define PLL_PCIDIV_4 0x00000003 - -/* - *------------------------------------------------------------------------------ - * PLL settings for 266MHz CPU, 133MHz PLB/SDRAM, 66MHz EBC, 33MHz PCI, - * assuming a 33.3MHz input clock to the 405EP. - *------------------------------------------------------------------------------ - */ -#define PLLMR0_266_133_66 (PLL_CPUDIV_1 | PLL_PLBDIV_2 | \ - PLL_OPBDIV_2 | PLL_EXTBUSDIV_2 | \ - PLL_MALDIV_1 | PLL_PCIDIV_4) -#define PLLMR1_266_133_66 (PLL_FBKDIV_8 | \ - PLL_FWDDIVA_3 | PLL_FWDDIVB_3 | \ - PLL_TUNE_15_M_40 | PLL_TUNE_VCO_LOW) - -#define PLLMR0_133_66_66_33 (PLL_CPUDIV_1 | PLL_PLBDIV_1 | \ - PLL_OPBDIV_2 | PLL_EXTBUSDIV_4 | \ - PLL_MALDIV_1 | PLL_PCIDIV_4) -#define PLLMR1_133_66_66_33 (PLL_FBKDIV_4 | \ - PLL_FWDDIVA_6 | PLL_FWDDIVB_6 | \ - PLL_TUNE_15_M_40 | PLL_TUNE_VCO_LOW) -#define PLLMR0_200_100_50_33 (PLL_CPUDIV_1 | PLL_PLBDIV_2 | \ - PLL_OPBDIV_2 | PLL_EXTBUSDIV_3 | \ - PLL_MALDIV_1 | PLL_PCIDIV_4) -#define PLLMR1_200_100_50_33 (PLL_FBKDIV_6 | \ - PLL_FWDDIVA_4 | PLL_FWDDIVB_4 | \ - PLL_TUNE_15_M_40 | PLL_TUNE_VCO_LOW) -#define PLLMR0_266_133_66_33 (PLL_CPUDIV_1 | PLL_PLBDIV_2 | \ - PLL_OPBDIV_2 | PLL_EXTBUSDIV_4 | \ - PLL_MALDIV_1 | PLL_PCIDIV_4) -#define PLLMR1_266_133_66_33 (PLL_FBKDIV_8 | \ - PLL_FWDDIVA_3 | PLL_FWDDIVB_3 | \ - PLL_TUNE_15_M_40 | PLL_TUNE_VCO_LOW) -#define PLLMR0_266_66_33_33 (PLL_CPUDIV_1 | PLL_PLBDIV_4 | \ - PLL_OPBDIV_2 | PLL_EXTBUSDIV_2 | \ - PLL_MALDIV_1 | PLL_PCIDIV_2) -#define PLLMR1_266_66_33_33 (PLL_FBKDIV_8 | \ - PLL_FWDDIVA_3 | PLL_FWDDIVB_3 | \ - PLL_TUNE_15_M_40 | PLL_TUNE_VCO_LOW) -#define PLLMR0_333_111_55_37 (PLL_CPUDIV_1 | PLL_PLBDIV_3 | \ - PLL_OPBDIV_2 | PLL_EXTBUSDIV_2 | \ - PLL_MALDIV_1 | PLL_PCIDIV_3) -#define PLLMR1_333_111_55_37 (PLL_FBKDIV_10 | \ - PLL_FWDDIVA_3 | PLL_FWDDIVB_3 | \ - PLL_TUNE_15_M_40 | PLL_TUNE_VCO_HI) -#define PLLMR0_333_111_55_111 (PLL_CPUDIV_1 | PLL_PLBDIV_3 | \ - PLL_OPBDIV_2 | PLL_EXTBUSDIV_2 | \ - PLL_MALDIV_1 | PLL_PCIDIV_1) -#define PLLMR1_333_111_55_111 (PLL_FBKDIV_10 | \ - PLL_FWDDIVA_3 | PLL_FWDDIVB_3 | \ - PLL_TUNE_15_M_40 | PLL_TUNE_VCO_HI) - -/* - * PLL Voltage Controlled Oscillator (VCO) definitions - * Maximum and minimum values (in MHz) for correct PLL operation. - */ -#define VCO_MIN 500 -#define VCO_MAX 1000 -#elif defined(CONFIG_405EZ) -#define SDR0_NAND0 0x4000 -#define SDR0_ULTRA0 0x4040 -#define SDR0_ULTRA1 0x4050 -#define SDR0_ICINTSTAT 0x4510 - -#define SDR_NAND0_NDEN 0x80000000 -#define SDR_NAND0_NDBTEN 0x40000000 -#define SDR_NAND0_NDBADR_MASK 0x30000000 -#define SDR_NAND0_NDBPG_MASK 0x0f000000 -#define SDR_NAND0_NDAREN 0x00800000 -#define SDR_NAND0_NDRBEN 0x00400000 - -#define SDR_ULTRA0_NDGPIOBP 0x80000000 -#define SDR_ULTRA0_CSN_MASK 0x78000000 -#define SDR_ULTRA0_CSNSEL0 0x40000000 -#define SDR_ULTRA0_CSNSEL1 0x20000000 -#define SDR_ULTRA0_CSNSEL2 0x10000000 -#define SDR_ULTRA0_CSNSEL3 0x08000000 -#define SDR_ULTRA0_EBCRDYEN 0x04000000 -#define SDR_ULTRA0_SPISSINEN 0x02000000 -#define SDR_ULTRA0_NFSRSTEN 0x01000000 - -#define SDR_ULTRA1_LEDNENABLE 0x40000000 - -#define SDR_ICRX_STAT 0x80000000 -#define SDR_ICTX0_STAT 0x40000000 -#define SDR_ICTX1_STAT 0x20000000 - -#define SDR0_PINSTP 0x40 - -/****************************************************************************** - * Control - ******************************************************************************/ -/* CPR Registers */ -#define CPR0_CLKUP 0x020 /* CPR_CLKUPD */ -#define CPR0_PLLC 0x040 /* CPR_PLLC */ -#define CPR0_PLLD 0x060 /* CPR_PLLD */ -#define CPC0_PRIMAD 0x080 /* CPR_PRIMAD */ -#define CPC0_PERD0 0x0e0 /* CPR_PERD0 */ -#define CPC0_PERD1 0x0e1 /* CPR_PERD1 */ -#define CPC0_PERC0 0x180 /* CPR_PERC0 */ - -#define CPR_CLKUPD_ENPLLCH_EN 0x40000000 /* Enable CPR PLL Changes */ -#define CPR_CLKUPD_ENDVCH_EN 0x20000000 /* Enable CPR Sys. Div. Changes */ -#define CPR_PERD0_SPIDV_MASK 0x000F0000 /* SPI Clock Divider */ - -#define PLLC_SRC_MASK 0x20000000 /* PLL feedback source */ - -#define PLLD_FBDV_MASK 0x1F000000 /* PLL feedback divider value */ -#define PLLD_FWDVA_MASK 0x000F0000 /* PLL forward divider A value */ -#define PLLD_FWDVB_MASK 0x00000700 /* PLL forward divider B value */ - -#define PRIMAD_CPUDV_MASK 0x0F000000 /* CPU Clock Divisor Mask */ -#define PRIMAD_PLBDV_MASK 0x000F0000 /* PLB Clock Divisor Mask */ -#define PRIMAD_OPBDV_MASK 0x00000F00 /* OPB Clock Divisor Mask */ -#define PRIMAD_EBCDV_MASK 0x0000000F /* EBC Clock Divisor Mask */ - -#define PERD0_PWMDV_MASK 0xFF000000 /* PWM Divider Mask */ -#define PERD0_SPIDV_MASK 0x000F0000 /* SPI Divider Mask */ -#define PERD0_U0DV_MASK 0x0000FF00 /* UART 0 Divider Mask */ -#define PERD0_U1DV_MASK 0x000000FF /* UART 1 Divider Mask */ - -#else /* #ifdef CONFIG_405EP */ -/****************************************************************************** - * Control - ******************************************************************************/ -#define CNTRL_DCR_BASE 0x0b0 -#define CPC0_PLLMR (CNTRL_DCR_BASE + 0x0) /* PLL mode register */ -#define CPC0_CR0 (CNTRL_DCR_BASE + 0x1) /* chip control register 0 */ -#define CPC0_CR1 (CNTRL_DCR_BASE + 0x2) /* chip control register 1 */ -#define CPC0_PSR (CNTRL_DCR_BASE + 0x4) /* chip pin strapping reg */ - -/* CPC0_ECR/CPC0_EIRR: PPC405GPr only */ -#define CPC0_EIRR (CNTRL_DCR_BASE + 0x6) /* ext interrupt routing reg */ -#define CPC0_ECR 0xaa /* edge conditioner register */ - -/* Bit definitions */ -#define PLLMR_FWD_DIV_MASK 0xE0000000 /* Forward Divisor */ -#define PLLMR_FWD_DIV_BYPASS 0xE0000000 -#define PLLMR_FWD_DIV_3 0xA0000000 -#define PLLMR_FWD_DIV_4 0x80000000 -#define PLLMR_FWD_DIV_6 0x40000000 - -#define PLLMR_FB_DIV_MASK 0x1E000000 /* Feedback Divisor */ -#define PLLMR_FB_DIV_1 0x02000000 -#define PLLMR_FB_DIV_2 0x04000000 -#define PLLMR_FB_DIV_3 0x06000000 -#define PLLMR_FB_DIV_4 0x08000000 - -#define PLLMR_TUNING_MASK 0x01F80000 - -#define PLLMR_CPU_TO_PLB_MASK 0x00060000 /* CPU:PLB Frequency Divisor */ -#define PLLMR_CPU_PLB_DIV_1 0x00000000 -#define PLLMR_CPU_PLB_DIV_2 0x00020000 -#define PLLMR_CPU_PLB_DIV_3 0x00040000 -#define PLLMR_CPU_PLB_DIV_4 0x00060000 - -#define PLLMR_OPB_TO_PLB_MASK 0x00018000 /* OPB:PLB Frequency Divisor */ -#define PLLMR_OPB_PLB_DIV_1 0x00000000 -#define PLLMR_OPB_PLB_DIV_2 0x00008000 -#define PLLMR_OPB_PLB_DIV_3 0x00010000 -#define PLLMR_OPB_PLB_DIV_4 0x00018000 - -#define PLLMR_PCI_TO_PLB_MASK 0x00006000 /* PCI:PLB Frequency Divisor */ -#define PLLMR_PCI_PLB_DIV_1 0x00000000 -#define PLLMR_PCI_PLB_DIV_2 0x00002000 -#define PLLMR_PCI_PLB_DIV_3 0x00004000 -#define PLLMR_PCI_PLB_DIV_4 0x00006000 - -#define PLLMR_EXB_TO_PLB_MASK 0x00001800 /* External Bus:PLB Divisor */ -#define PLLMR_EXB_PLB_DIV_2 0x00000000 -#define PLLMR_EXB_PLB_DIV_3 0x00000800 -#define PLLMR_EXB_PLB_DIV_4 0x00001000 -#define PLLMR_EXB_PLB_DIV_5 0x00001800 - -/* definitions for PPC405GPr (new mode strapping) */ -#define PLLMR_FWDB_DIV_MASK 0x00000007 /* Forward Divisor B */ - -#define PSR_PLL_FWD_MASK 0xC0000000 -#define PSR_PLL_FDBACK_MASK 0x30000000 -#define PSR_PLL_TUNING_MASK 0x0E000000 -#define PSR_PLB_CPU_MASK 0x01800000 -#define PSR_OPB_PLB_MASK 0x00600000 -#define PSR_PCI_PLB_MASK 0x00180000 -#define PSR_EB_PLB_MASK 0x00060000 -#define PSR_ROM_WIDTH_MASK 0x00018000 -#define PSR_ROM_LOC 0x00004000 -#define PSR_PCI_ASYNC_EN 0x00001000 -#define PSR_PERCLK_SYNC_MODE_EN 0x00000800 /* PPC405GPr only */ -#define PSR_PCI_ARBIT_EN 0x00000400 -#define PSR_NEW_MODE_EN 0x00000020 /* PPC405GPr only */ - -#ifndef CONFIG_IOP480 -/* - * PLL Voltage Controlled Oscillator (VCO) definitions - * Maximum and minimum values (in MHz) for correct PLL operation. -*/ -#define VCO_MIN 400 -#define VCO_MAX 800 -#endif /* #ifndef CONFIG_IOP480 */ -#endif /* #ifdef CONFIG_405EP */ - -#if 0 -/****************************************************************************** - * Memory Access Layer - ******************************************************************************/ -#define MAL0_CFG (MAL_DCR_BASE + 0x00) /* MAL Config reg */ -#define MAL0_ESR (MAL_DCR_BASE + 0x01) /* Err Status (Read/Clear) */ -#define MAL0_IER (MAL_DCR_BASE + 0x02) /* Interrupt enable */ -#define MAL0_TXCASR (MAL_DCR_BASE + 0x04) /* TX Channel active (set) */ -#define MAL0_TXCARR (MAL_DCR_BASE + 0x05) /* TX Channel active (reset) */ -#define MAL0_TXEOBISR (MAL_DCR_BASE + 0x06) /* TX End of buffer int status */ -#define MAL0_TXDEIR (MAL_DCR_BASE + 0x07) /* TX Descr. Error Int reg */ -#define MAL0_RXCASR (MAL_DCR_BASE + 0x10) /* RX Channel active (set) */ -#define MAL0_RXCARR (MAL_DCR_BASE + 0x11) /* RX Channel active (reset) */ -#define MAL0_RXEOBISR (MAL_DCR_BASE + 0x12) /* RX End of buffer int status */ -#define MAL0_RXDEIR (MAL_DCR_BASE + 0x13) /* RX Descr. Error Int reg */ -#define MAL0_TXCTP0R (MAL_DCR_BASE + 0x20) /* TX 0 Channel table ptr */ -#define MAL0_TXCTP1R (MAL_DCR_BASE + 0x21) /* TX 1 Channel table ptr */ -#define MAL0_TXCTP2R (MAL_DCR_BASE + 0x22) /* TX 2 Channel table ptr */ -#define MAL0_TXCTP3R (MAL_DCR_BASE + 0x23) /* TX 3 Channel table ptr */ -#define MAL0_RXCTP0R (MAL_DCR_BASE + 0x40) /* RX 0 Channel table ptr */ -#define MAL0_RXCTP1R (MAL_DCR_BASE + 0x41) /* RX 1 Channel table ptr */ -#define MAL0_RXCTP2R (MAL_DCR_BASE + 0x42) /* RX 2 Channel table ptr */ -#define MAL0_RXCTP3R (MAL_DCR_BASE + 0x43) /* RX 3 Channel table ptr */ -#define MAL0_RXCTP8R (MAL_DCR_BASE + 0x48) /* RX 8 Channel table ptr */ -#define MAL0_RXCTP16R (MAL_DCR_BASE + 0x50) /* RX 16 Channel table ptr */ -#define MAL0_RXCTP24R (MAL_DCR_BASE + 0x58) /* RX 24 Channel table ptr */ -#define MAL0_RCBS0 (MAL_DCR_BASE + 0x60) /* RX 0 Channel buffer size */ -#define MAL0_RCBS1 (MAL_DCR_BASE + 0x61) /* RX 1 Channel buffer size */ -#define MAL0_RCBS2 (MAL_DCR_BASE + 0x62) /* RX 2 Channel buffer size */ -#define MAL0_RCBS3 (MAL_DCR_BASE + 0x63) /* RX 3 Channel buffer size */ -#define MAL0_RCBS8 (MAL_DCR_BASE + 0x68) /* RX 8 Channel buffer size */ -#define MAL0_RCBS16 (MAL_DCR_BASE + 0x70) /* RX 16 Channel buffer size */ -#define MAL0_RCBS24 (MAL_DCR_BASE + 0x78) /* RX 24 Channel buffer size */ -#endif - -/*----------------------------------------------------------------------------- -| UART Register Offsets -'----------------------------------------------------------------------------*/ -#define DATA_REG 0x00 -#define DL_LSB 0x00 -#define DL_MSB 0x01 -#define INT_ENABLE 0x01 -#define FIFO_CONTROL 0x02 -#define LINE_CONTROL 0x03 -#define MODEM_CONTROL 0x04 -#define LINE_STATUS 0x05 -#define MODEM_STATUS 0x06 -#define SCRATCH 0x07 - -/****************************************************************************** - * On Chip Memory - ******************************************************************************/ -#if defined(CONFIG_405EZ) -#define OCM_DCR_BASE 0x020 -#define OCM0_PLBCR1 (OCM_DCR_BASE + 0x00) /* OCM PLB3 Bank 1 Config */ -#define OCM0_PLBCR2 (OCM_DCR_BASE + 0x01) /* OCM PLB3 Bank 2 Config */ -#define OCM0_PLBBEAR (OCM_DCR_BASE + 0x02) /* OCM PLB3 Bus Error Add */ -#define OCM0_DSRC1 (OCM_DCR_BASE + 0x08) /* OCM D-side Bank 1 Config */ -#define OCM0_DSRC2 (OCM_DCR_BASE + 0x09) /* OCM D-side Bank 2 Config */ -#define OCM0_ISRC1 (OCM_DCR_BASE + 0x0A) /* OCM I-side Bank 1Config */ -#define OCM0_ISRC2 (OCM_DCR_BASE + 0x0B) /* OCM I-side Bank 2 Config */ -#define OCM0_DISDPC (OCM_DCR_BASE + 0x0C) /* OCM D-/I-side Data Par Chk */ -#else -#define OCM_DCR_BASE 0x018 -#define OCM0_ISCNTL (OCM_DCR_BASE+0x01) /* OCM I-side control reg */ -#define OCM0_DSARC (OCM_DCR_BASE+0x02) /* OCM D-side address compare */ -#define OCM0_DSCNTL (OCM_DCR_BASE+0x03) /* OCM D-side control */ -#endif /* CONFIG_405EZ */ - -/****************************************************************************** - * GPIO macro register defines - ******************************************************************************/ -#if defined(CONFIG_405EZ) -/* Only the 405EZ has 2 GPIOs */ -#define GPIO_BASE 0xEF600700 -#define GPIO0_OR (GPIO_BASE+0x0) -#define GPIO0_TCR (GPIO_BASE+0x4) -#define GPIO0_OSRL (GPIO_BASE+0x8) -#define GPIO0_OSRH (GPIO_BASE+0xC) -#define GPIO0_TSRL (GPIO_BASE+0x10) -#define GPIO0_TSRH (GPIO_BASE+0x14) -#define GPIO0_ODR (GPIO_BASE+0x18) -#define GPIO0_IR (GPIO_BASE+0x1C) -#define GPIO0_RR1 (GPIO_BASE+0x20) -#define GPIO0_RR2 (GPIO_BASE+0x24) -#define GPIO0_RR3 (GPIO_BASE+0x28) -#define GPIO0_ISR1L (GPIO_BASE+0x30) -#define GPIO0_ISR1H (GPIO_BASE+0x34) -#define GPIO0_ISR2L (GPIO_BASE+0x38) -#define GPIO0_ISR2H (GPIO_BASE+0x3C) -#define GPIO0_ISR3L (GPIO_BASE+0x40) -#define GPIO0_ISR3H (GPIO_BASE+0x44) - -#define GPIO1_BASE 0xEF600800 -#define GPIO1_OR (GPIO1_BASE+0x0) -#define GPIO1_TCR (GPIO1_BASE+0x4) -#define GPIO1_OSRL (GPIO1_BASE+0x8) -#define GPIO1_OSRH (GPIO1_BASE+0xC) -#define GPIO1_TSRL (GPIO1_BASE+0x10) -#define GPIO1_TSRH (GPIO1_BASE+0x14) -#define GPIO1_ODR (GPIO1_BASE+0x18) -#define GPIO1_IR (GPIO1_BASE+0x1C) -#define GPIO1_RR1 (GPIO1_BASE+0x20) -#define GPIO1_RR2 (GPIO1_BASE+0x24) -#define GPIO1_RR3 (GPIO1_BASE+0x28) -#define GPIO1_ISR1L (GPIO1_BASE+0x30) -#define GPIO1_ISR1H (GPIO1_BASE+0x34) -#define GPIO1_ISR2L (GPIO1_BASE+0x38) -#define GPIO1_ISR2H (GPIO1_BASE+0x3C) -#define GPIO1_ISR3L (GPIO1_BASE+0x40) -#define GPIO1_ISR3H (GPIO1_BASE+0x44) - -#elif defined(CONFIG_405EX) -#define GPIO_BASE 0xEF600800 -#define GPIO0_OR (GPIO_BASE+0x0) -#define GPIO0_TCR (GPIO_BASE+0x4) -#define GPIO0_OSRL (GPIO_BASE+0x8) -#define GPIO0_OSRH (GPIO_BASE+0xC) -#define GPIO0_TSRL (GPIO_BASE+0x10) -#define GPIO0_TSRH (GPIO_BASE+0x14) -#define GPIO0_ODR (GPIO_BASE+0x18) -#define GPIO0_IR (GPIO_BASE+0x1C) -#define GPIO0_RR1 (GPIO_BASE+0x20) -#define GPIO0_RR2 (GPIO_BASE+0x24) -#define GPIO0_ISR1L (GPIO_BASE+0x30) -#define GPIO0_ISR1H (GPIO_BASE+0x34) -#define GPIO0_ISR2L (GPIO_BASE+0x38) -#define GPIO0_ISR2H (GPIO_BASE+0x3C) -#define GPIO0_ISR3L (GPIO_BASE+0x40) -#define GPIO0_ISR3H (GPIO_BASE+0x44) - -#else /* !405EZ */ - -#define GPIO_BASE 0xEF600700 -#define GPIO0_OR (GPIO_BASE+0x0) -#define GPIO0_TCR (GPIO_BASE+0x4) -#define GPIO0_OSRH (GPIO_BASE+0x8) -#define GPIO0_OSRL (GPIO_BASE+0xC) -#define GPIO0_TSRH (GPIO_BASE+0x10) -#define GPIO0_TSRL (GPIO_BASE+0x14) -#define GPIO0_ODR (GPIO_BASE+0x18) -#define GPIO0_IR (GPIO_BASE+0x1C) -#define GPIO0_RR1 (GPIO_BASE+0x20) -#define GPIO0_RR2 (GPIO_BASE+0x24) -#define GPIO0_ISR1H (GPIO_BASE+0x30) -#define GPIO0_ISR1L (GPIO_BASE+0x34) -#define GPIO0_ISR2H (GPIO_BASE+0x38) -#define GPIO0_ISR2L (GPIO_BASE+0x3C) - -#endif /* CONFIG_405EZ */ - -#define GPIO0_BASE GPIO_BASE +/* SDR registers */ +#define SDR0_PINSTP 0x0040
-#if defined(CONFIG_405EX) -#define SDR0_SRST 0x0200 +/* CPR registers */ +#define CPR0_CLKUPD 0x0020 +#define CPR0_PLLC 0x0040 +#define CPR0_PLLD 0x0060 +#define CPR0_CPUD 0x0080 +#define CPR0_PLBD 0x00a0 +#define CPR0_OPBD0 0x00c0 +#define CPR0_PERD 0x00e0
/* - * Software Reset Register + * DMA */ -#define SDR0_SRST_BGO PPC_REG_VAL(0, 1) -#define SDR0_SRST_PLB4 PPC_REG_VAL(1, 1) -#define SDR0_SRST_EBC PPC_REG_VAL(2, 1) -#define SDR0_SRST_OPB PPC_REG_VAL(3, 1) -#define SDR0_SRST_UART0 PPC_REG_VAL(4, 1) -#define SDR0_SRST_UART1 PPC_REG_VAL(5, 1) -#define SDR0_SRST_IIC0 PPC_REG_VAL(6, 1) -#define SDR0_SRST_BGI PPC_REG_VAL(7, 1) -#define SDR0_SRST_GPIO PPC_REG_VAL(8, 1) -#define SDR0_SRST_GPT PPC_REG_VAL(9, 1) -#define SDR0_SRST_DMC PPC_REG_VAL(10, 1) -#define SDR0_SRST_RGMII PPC_REG_VAL(11, 1) -#define SDR0_SRST_EMAC0 PPC_REG_VAL(12, 1) -#define SDR0_SRST_EMAC1 PPC_REG_VAL(13, 1) -#define SDR0_SRST_CPM PPC_REG_VAL(14, 1) -#define SDR0_SRST_EPLL PPC_REG_VAL(15, 1) -#define SDR0_SRST_UIC PPC_REG_VAL(16, 1) -#define SDR0_SRST_UPRST PPC_REG_VAL(17, 1) -#define SDR0_SRST_IIC1 PPC_REG_VAL(18, 1) -#define SDR0_SRST_SCP PPC_REG_VAL(19, 1) -#define SDR0_SRST_UHRST PPC_REG_VAL(20, 1) -#define SDR0_SRST_DMA PPC_REG_VAL(21, 1) -#define SDR0_SRST_DMAC PPC_REG_VAL(22, 1) -#define SDR0_SRST_MAL PPC_REG_VAL(23, 1) -#define SDR0_SRST_EBM PPC_REG_VAL(24, 1) -#define SDR0_SRST_GPTR PPC_REG_VAL(25, 1) -#define SDR0_SRST_PE0 PPC_REG_VAL(26, 1) -#define SDR0_SRST_PE1 PPC_REG_VAL(27, 1) -#define SDR0_SRST_CRYP PPC_REG_VAL(28, 1) -#define SDR0_SRST_PKP PPC_REG_VAL(29, 1) -#define SDR0_SRST_AHB PPC_REG_VAL(30, 1) -#define SDR0_SRST_NDFC PPC_REG_VAL(31, 1) - -#define SDR0_UART0 0x0120 /* UART0 Config */ -#define SDR0_UART1 0x0121 /* UART1 Config */ -#define SDR0_MFR 0x4300 /* SDR0_MFR reg */ - -/* Defines for CPC0_EPRCSR register */ -#define CPC0_EPRCSR_E0NFE 0x80000000 -#define CPC0_EPRCSR_E1NFE 0x40000000 -#define CPC0_EPRCSR_E1RPP 0x00000080 -#define CPC0_EPRCSR_E0RPP 0x00000040 -#define CPC0_EPRCSR_E1ERP 0x00000020 -#define CPC0_EPRCSR_E0ERP 0x00000010 -#define CPC0_EPRCSR_E1PCI 0x00000002 -#define CPC0_EPRCSR_E0PCI 0x00000001 - -#define CPR0_CLKUPD 0x020 -#define CPR0_PLLC 0x040 -#define CPR0_PLLD 0x060 -#define CPR0_CPUD 0x080 -#define CPR0_PLBD 0x0a0 -#define CPR0_OPBD0 0x0c0 -#define CPR0_PERD 0x0e0 - -#define SDR0_PINSTP 0x0040 -#define SDR0_SDCS0 0x0060 - -#define SDR0_SDCS_SDD (0x80000000 >> 31) - -/* CUST0 Customer Configuration Register0 */ -#define SDR0_CUST0 0x4000 -#define SDR0_CUST0_MUX_E_N_G_MASK 0xC0000000 /* Mux_Emac_NDFC_GPIO */ -#define SDR0_CUST0_MUX_EMAC_SEL 0x40000000 /* Emac Selection */ -#define SDR0_CUST0_MUX_NDFC_SEL 0x80000000 /* NDFC Selection */ -#define SDR0_CUST0_MUX_GPIO_SEL 0xC0000000 /* GPIO Selection */ - -#define SDR0_CUST0_NDFC_EN_MASK 0x20000000 /* NDFC Enable Mask */ -#define SDR0_CUST0_NDFC_ENABLE 0x20000000 /* NDFC Enable */ -#define SDR0_CUST0_NDFC_DISABLE 0x00000000 /* NDFC Disable */ - -#define SDR0_CUST0_NDFC_BW_MASK 0x10000000 /* NDFC Boot Width */ -#define SDR0_CUST0_NDFC_BW_16_BIT 0x10000000 /* NDFC Boot Width= 16 Bit */ -#define SDR0_CUST0_NDFC_BW_8_BIT 0x00000000 /* NDFC Boot Width= 8 Bit */ - -#define SDR0_CUST0_NDFC_BP_MASK 0x0F000000 /* NDFC Boot Page */ -#define SDR0_CUST0_NDFC_BP_ENCODE(n) ((((unsigned long)(n))&0xF)<<24) -#define SDR0_CUST0_NDFC_BP_DECODE(n) ((((unsigned long)(n))>>24)&0x0F) - -#define SDR0_CUST0_NDFC_BAC_MASK 0x00C00000 /* NDFC Boot Address Cycle */ -#define SDR0_CUST0_NDFC_BAC_ENCODE(n) ((((unsigned long)(n))&0x3)<<22) -#define SDR0_CUST0_NDFC_BAC_DECODE(n) ((((unsigned long)(n))>>22)&0x03) - -#define SDR0_CUST0_NDFC_ARE_MASK 0x00200000 /* NDFC Auto Read Enable */ -#define SDR0_CUST0_NDFC_ARE_ENABLE 0x00200000 /* NDFC Auto Read Enable */ -#define SDR0_CUST0_NDFC_ARE_DISABLE 0x00000000 /* NDFC Auto Read Disable */ - -#define SDR0_CUST0_NRB_MASK 0x00100000 /* NDFC Ready / Busy */ -#define SDR0_CUST0_NRB_BUSY 0x00100000 /* Busy */ -#define SDR0_CUST0_NRB_READY 0x00000000 /* Ready */ - -#define SDR0_CUST0_NDRSC_MASK 0x0000FFF0 /* NDFC Device Reset Count Mask */ -#define SDR0_CUST0_NDRSC_ENCODE(n) ((((unsigned long)(n))&0xFFF)<<4) -#define SDR0_CUST0_NDRSC_DECODE(n) ((((unsigned long)(n))>>4)&0xFFF) - -#define SDR0_CUST0_CHIPSELGAT_MASK 0x0000000F /* Chip Sel Gating Mask */ -#define SDR0_CUST0_CHIPSELGAT_DIS 0x00000000 /* Chip Sel Gating Disable */ -#define SDR0_CUST0_CHIPSELGAT_ENALL 0x0000000F /* All Chip Sel Gating Enable */ -#define SDR0_CUST0_CHIPSELGAT_EN0 0x00000008 /* Chip Sel0 Gating Enable */ -#define SDR0_CUST0_CHIPSELGAT_EN1 0x00000004 /* Chip Sel1 Gating Enable */ -#define SDR0_CUST0_CHIPSELGAT_EN2 0x00000002 /* Chip Sel2 Gating Enable */ -#define SDR0_CUST0_CHIPSELGAT_EN3 0x00000001 /* Chip Sel3 Gating Enable */ - -#define SDR0_PFC0 0x4100 -#define SDR0_PFC1 0x4101 -#define SDR0_PFC1_U1ME 0x02000000 -#define SDR0_PFC1_U0ME 0x00080000 -#define SDR0_PFC1_U0IM 0x00040000 -#define SDR0_PFC1_SIS 0x00020000 -#define SDR0_PFC1_DMAAEN 0x00010000 -#define SDR0_PFC1_DMADEN 0x00008000 -#define SDR0_PFC1_USBEN 0x00004000 -#define SDR0_PFC1_AHBSWAP 0x00000020 -#define SDR0_PFC1_USBBIGEN 0x00000010 -#define SDR0_PFC1_GPT_FREQ 0x0000000f -#endif +#define DMA_DCR_BASE 0x0100 +#define DMACR0 (DMA_DCR_BASE + 0x00) /* DMA channel control reg 0 */ +#define DMACT0 (DMA_DCR_BASE + 0x01) /* DMA count reg 0 */ +#define DMADA0 (DMA_DCR_BASE + 0x02) /* DMA destination address reg 0 */ +#define DMASA0 (DMA_DCR_BASE + 0x03) /* DMA source address reg 0 */ +#define DMASB0 (DMA_DCR_BASE + 0x04) /* DMA sg descriptor addr 0 */ +#define DMACR1 (DMA_DCR_BASE + 0x08) /* DMA channel control reg 1 */ +#define DMACT1 (DMA_DCR_BASE + 0x09) /* DMA count reg 1 */ +#define DMADA1 (DMA_DCR_BASE + 0x0a) /* DMA destination address reg 1 */ +#define DMASA1 (DMA_DCR_BASE + 0x0b) /* DMA source address reg 1 */ +#define DMASB1 (DMA_DCR_BASE + 0x0c) /* DMA sg descriptor addr 1 */ +#define DMACR2 (DMA_DCR_BASE + 0x10) /* DMA channel control reg 2 */ +#define DMACT2 (DMA_DCR_BASE + 0x11) /* DMA count reg 2 */ +#define DMADA2 (DMA_DCR_BASE + 0x12) /* DMA destination address reg 2 */ +#define DMASA2 (DMA_DCR_BASE + 0x13) /* DMA source address reg 2 */ +#define DMASB2 (DMA_DCR_BASE + 0x14) /* DMA sg descriptor addr 2 */ +#define DMACR3 (DMA_DCR_BASE + 0x18) /* DMA channel control reg 3 */ +#define DMACT3 (DMA_DCR_BASE + 0x19) /* DMA count reg 3 */ +#define DMADA3 (DMA_DCR_BASE + 0x1a) /* DMA destination address reg 3 */ +#define DMASA3 (DMA_DCR_BASE + 0x1b) /* DMA source address reg 3 */ +#define DMASB3 (DMA_DCR_BASE + 0x1c) /* DMA sg descriptor addr 3 */ +#define DMASR (DMA_DCR_BASE + 0x20) /* DMA status reg */ +#define DMASGC (DMA_DCR_BASE + 0x23) /* DMA scatter/gather command reg*/ +#define DMAADR (DMA_DCR_BASE + 0x24) /* DMA address decode reg */
#endif /* __PPC405_H__ */ diff --git a/arch/powerpc/include/asm/ppc405cr.h b/arch/powerpc/include/asm/ppc405cr.h index 53a6ce8..176c427 100644 --- a/arch/powerpc/include/asm/ppc405cr.h +++ b/arch/powerpc/include/asm/ppc405cr.h @@ -23,4 +23,78 @@
#define CONFIG_SDRAM_PPC4xx_IBM_SDRAM /* IBM SDRAM controller */
+/* Memory mapped register */ +#define GPIO0_BASE 0xef600700 + +/* DCR's */ +#define DCP0_CFGADDR 0x0014 /* Decompression controller addr reg */ +#define DCP0_CFGDATA 0x0015 /* Decompression controller data reg */ +#define OCM0_ISCNTL 0x0019 /* OCM I-side control reg */ +#define OCM0_DSARC 0x001a /* OCM D-side address compare */ +#define OCM0_DSCNTL 0x001b /* OCM D-side control */ +#define CPC0_PLLMR 0x00b0 /* PLL mode register */ +#define CPC0_CR0 0x00b1 /* chip control register 0 */ +#define CPC0_CR1 0x00b2 /* chip control register 1 */ +#define CPC0_PSR 0x00b4 /* chip pin strapping reg */ +#define CPC0_EIRR 0x00b6 /* ext interrupt routing reg */ +#define CPC0_SR 0x00b8 /* Power management status */ +#define CPC0_ER 0x00b9 /* Power management enable */ +#define CPC0_FR 0x00ba /* Power management force */ +#define CPC0_ECR 0x00aa /* edge conditioner register */ + +#define PLLMR_FWD_DIV_MASK 0xE0000000 /* Forward Divisor */ +#define PLLMR_FWD_DIV_BYPASS 0xE0000000 +#define PLLMR_FWD_DIV_3 0xA0000000 +#define PLLMR_FWD_DIV_4 0x80000000 +#define PLLMR_FWD_DIV_6 0x40000000 + +#define PLLMR_FB_DIV_MASK 0x1E000000 /* Feedback Divisor */ +#define PLLMR_FB_DIV_1 0x02000000 +#define PLLMR_FB_DIV_2 0x04000000 +#define PLLMR_FB_DIV_3 0x06000000 +#define PLLMR_FB_DIV_4 0x08000000 + +#define PLLMR_TUNING_MASK 0x01F80000 + +#define PLLMR_CPU_TO_PLB_MASK 0x00060000 /* CPU:PLB Frequency Divisor */ +#define PLLMR_CPU_PLB_DIV_1 0x00000000 +#define PLLMR_CPU_PLB_DIV_2 0x00020000 +#define PLLMR_CPU_PLB_DIV_3 0x00040000 +#define PLLMR_CPU_PLB_DIV_4 0x00060000 + +#define PLLMR_OPB_TO_PLB_MASK 0x00018000 /* OPB:PLB Frequency Divisor */ +#define PLLMR_OPB_PLB_DIV_1 0x00000000 +#define PLLMR_OPB_PLB_DIV_2 0x00008000 +#define PLLMR_OPB_PLB_DIV_3 0x00010000 +#define PLLMR_OPB_PLB_DIV_4 0x00018000 + +#define PLLMR_PCI_TO_PLB_MASK 0x00006000 /* PCI:PLB Frequency Divisor */ +#define PLLMR_PCI_PLB_DIV_1 0x00000000 +#define PLLMR_PCI_PLB_DIV_2 0x00002000 +#define PLLMR_PCI_PLB_DIV_3 0x00004000 +#define PLLMR_PCI_PLB_DIV_4 0x00006000 + +#define PLLMR_EXB_TO_PLB_MASK 0x00001800 /* External Bus:PLB Divisor */ +#define PLLMR_EXB_PLB_DIV_2 0x00000000 +#define PLLMR_EXB_PLB_DIV_3 0x00000800 +#define PLLMR_EXB_PLB_DIV_4 0x00001000 +#define PLLMR_EXB_PLB_DIV_5 0x00001800 + +/* definitions for PPC405GPr (new mode strapping) */ +#define PLLMR_FWDB_DIV_MASK 0x00000007 /* Forward Divisor B */ + +#define PSR_PLL_FWD_MASK 0xC0000000 +#define PSR_PLL_FDBACK_MASK 0x30000000 +#define PSR_PLL_TUNING_MASK 0x0E000000 +#define PSR_PLB_CPU_MASK 0x01800000 +#define PSR_OPB_PLB_MASK 0x00600000 +#define PSR_PCI_PLB_MASK 0x00180000 +#define PSR_EB_PLB_MASK 0x00060000 +#define PSR_ROM_WIDTH_MASK 0x00018000 +#define PSR_ROM_LOC 0x00004000 +#define PSR_PCI_ASYNC_EN 0x00001000 +#define PSR_PERCLK_SYNC_MODE_EN 0x00000800 /* PPC405GPr only */ +#define PSR_PCI_ARBIT_EN 0x00000400 +#define PSR_NEW_MODE_EN 0x00000020 /* PPC405GPr only */ + #endif /* _PPC405CR_H_ */ diff --git a/arch/powerpc/include/asm/ppc405ep.h b/arch/powerpc/include/asm/ppc405ep.h index 38b1205..e0b6a85 100644 --- a/arch/powerpc/include/asm/ppc405ep.h +++ b/arch/powerpc/include/asm/ppc405ep.h @@ -23,4 +23,225 @@
+/* Memory mapped register */ +#define GPIO0_BASE 0xef600700 + +/* DCR */ +#define OCM0_ISCNTL 0x0019 /* OCM I-side control reg */ +#define OCM0_DSARC 0x001a /* OCM D-side address compare */ +#define OCM0_DSCNTL 0x001b /* OCM D-side control */ +#define CPC0_PLLMR0 0x00f0 /* PLL mode register 0 */ +#define CPC0_BOOT 0x00f1 /* Clock status register */ +#define CPC0_CR1 0x00f2 /* Chip Control 1 register */ +#define CPC0_EPCTL 0x00f3 /* EMAC to PHY control register */ +#define CPC0_PLLMR1 0x00f4 /* PLL mode register 1 */ +#define CPC0_UCR 0x00f5 /* UART control register */ +#define CPC0_SRR 0x00f6 /* Soft Reset register */ +#define CPC0_PCI 0x00f9 /* PCI control register */ + +/* Defines for CPC0_EPCTL register */ +#define CPC0_EPCTL_E0NFE 0x80000000 +#define CPC0_EPCTL_E1NFE 0x40000000 + +/* Defines for CPC0_PCI Register */ +#define CPC0_PCI_SPE 0x00000010 /* PCIINT/WE select */ +#define CPC0_PCI_HOST_CFG_EN 0x00000008 /* PCI host config Enable */ +#define CPC0_PCI_ARBIT_EN 0x00000001 /* PCI Internal Arb Enabled */ + +/* Defines for CPC0_BOOR Register */ +#define CPC0_BOOT_SEP 0x00000002 /* serial EEPROM present */ + +/* Bit definitions */ +#define PLLMR0_CPU_DIV_MASK 0x00300000 /* CPU clock divider */ +#define PLLMR0_CPU_DIV_BYPASS 0x00000000 +#define PLLMR0_CPU_DIV_2 0x00100000 +#define PLLMR0_CPU_DIV_3 0x00200000 +#define PLLMR0_CPU_DIV_4 0x00300000 + +#define PLLMR0_CPU_TO_PLB_MASK 0x00030000 /* CPU:PLB Frequency Divisor */ +#define PLLMR0_CPU_PLB_DIV_1 0x00000000 +#define PLLMR0_CPU_PLB_DIV_2 0x00010000 +#define PLLMR0_CPU_PLB_DIV_3 0x00020000 +#define PLLMR0_CPU_PLB_DIV_4 0x00030000 + +#define PLLMR0_OPB_TO_PLB_MASK 0x00003000 /* OPB:PLB Frequency Divisor */ +#define PLLMR0_OPB_PLB_DIV_1 0x00000000 +#define PLLMR0_OPB_PLB_DIV_2 0x00001000 +#define PLLMR0_OPB_PLB_DIV_3 0x00002000 +#define PLLMR0_OPB_PLB_DIV_4 0x00003000 + +#define PLLMR0_EXB_TO_PLB_MASK 0x00000300 /* External Bus:PLB Divisor */ +#define PLLMR0_EXB_PLB_DIV_2 0x00000000 +#define PLLMR0_EXB_PLB_DIV_3 0x00000100 +#define PLLMR0_EXB_PLB_DIV_4 0x00000200 +#define PLLMR0_EXB_PLB_DIV_5 0x00000300 + +#define PLLMR0_MAL_TO_PLB_MASK 0x00000030 /* MAL:PLB Divisor */ +#define PLLMR0_MAL_PLB_DIV_1 0x00000000 +#define PLLMR0_MAL_PLB_DIV_2 0x00000010 +#define PLLMR0_MAL_PLB_DIV_3 0x00000020 +#define PLLMR0_MAL_PLB_DIV_4 0x00000030 + +#define PLLMR0_PCI_TO_PLB_MASK 0x00000003 /* PCI:PLB Frequency Divisor */ +#define PLLMR0_PCI_PLB_DIV_1 0x00000000 +#define PLLMR0_PCI_PLB_DIV_2 0x00000001 +#define PLLMR0_PCI_PLB_DIV_3 0x00000002 +#define PLLMR0_PCI_PLB_DIV_4 0x00000003 + +#define PLLMR1_SSCS_MASK 0x80000000 /* Select system clock source */ +#define PLLMR1_PLLR_MASK 0x40000000 /* PLL reset */ +#define PLLMR1_FBMUL_MASK 0x00F00000 /* PLL feedback multiplier value */ + +#define PLLMR1_FWDVA_MASK 0x00070000 /* PLL forward divider A value */ +#define PLLMR1_FWDVB_MASK 0x00007000 /* PLL forward divider B value */ +#define PLLMR1_TUNING_MASK 0x000003FF /* PLL tune bits */ + +/* Defines for CPC0_PLLMR1 Register fields */ +#define PLL_ACTIVE 0x80000000 +#define CPC0_PLLMR1_SSCS 0x80000000 +#define PLL_RESET 0x40000000 +#define CPC0_PLLMR1_PLLR 0x40000000 +/* Feedback multiplier */ +#define PLL_FBKDIV 0x00F00000 +#define CPC0_PLLMR1_FBDV 0x00F00000 +#define PLL_FBKDIV_16 0x00000000 +#define PLL_FBKDIV_1 0x00100000 +#define PLL_FBKDIV_2 0x00200000 +#define PLL_FBKDIV_3 0x00300000 +#define PLL_FBKDIV_4 0x00400000 +#define PLL_FBKDIV_5 0x00500000 +#define PLL_FBKDIV_6 0x00600000 +#define PLL_FBKDIV_7 0x00700000 +#define PLL_FBKDIV_8 0x00800000 +#define PLL_FBKDIV_9 0x00900000 +#define PLL_FBKDIV_10 0x00A00000 +#define PLL_FBKDIV_11 0x00B00000 +#define PLL_FBKDIV_12 0x00C00000 +#define PLL_FBKDIV_13 0x00D00000 +#define PLL_FBKDIV_14 0x00E00000 +#define PLL_FBKDIV_15 0x00F00000 +/* Forward A divisor */ +#define PLL_FWDDIVA 0x00070000 +#define CPC0_PLLMR1_FWDVA 0x00070000 +#define PLL_FWDDIVA_8 0x00000000 +#define PLL_FWDDIVA_7 0x00010000 +#define PLL_FWDDIVA_6 0x00020000 +#define PLL_FWDDIVA_5 0x00030000 +#define PLL_FWDDIVA_4 0x00040000 +#define PLL_FWDDIVA_3 0x00050000 +#define PLL_FWDDIVA_2 0x00060000 +#define PLL_FWDDIVA_1 0x00070000 +/* Forward B divisor */ +#define PLL_FWDDIVB 0x00007000 +#define CPC0_PLLMR1_FWDVB 0x00007000 +#define PLL_FWDDIVB_8 0x00000000 +#define PLL_FWDDIVB_7 0x00001000 +#define PLL_FWDDIVB_6 0x00002000 +#define PLL_FWDDIVB_5 0x00003000 +#define PLL_FWDDIVB_4 0x00004000 +#define PLL_FWDDIVB_3 0x00005000 +#define PLL_FWDDIVB_2 0x00006000 +#define PLL_FWDDIVB_1 0x00007000 +/* PLL tune bits */ +#define PLL_TUNE_MASK 0x000003FF +#define PLL_TUNE_2_M_3 0x00000133 /* 2 <= M <= 3 */ +#define PLL_TUNE_4_M_6 0x00000134 /* 3 < M <= 6 */ +#define PLL_TUNE_7_M_10 0x00000138 /* 6 < M <= 10 */ +#define PLL_TUNE_11_M_14 0x0000013C /* 10 < M <= 14 */ +#define PLL_TUNE_15_M_40 0x0000023E /* 14 < M <= 40 */ +#define PLL_TUNE_VCO_LOW 0x00000000 /* 500MHz <= VCO <= 800MHz */ +#define PLL_TUNE_VCO_HI 0x00000080 /* 800MHz < VCO <= 1000MHz */ + +/* Defines for CPC0_PLLMR0 Register fields */ +/* CPU divisor */ +#define PLL_CPUDIV 0x00300000 +#define CPC0_PLLMR0_CCDV 0x00300000 +#define PLL_CPUDIV_1 0x00000000 +#define PLL_CPUDIV_2 0x00100000 +#define PLL_CPUDIV_3 0x00200000 +#define PLL_CPUDIV_4 0x00300000 +/* PLB divisor */ +#define PLL_PLBDIV 0x00030000 +#define CPC0_PLLMR0_CBDV 0x00030000 +#define PLL_PLBDIV_1 0x00000000 +#define PLL_PLBDIV_2 0x00010000 +#define PLL_PLBDIV_3 0x00020000 +#define PLL_PLBDIV_4 0x00030000 +/* OPB divisor */ +#define PLL_OPBDIV 0x00003000 +#define CPC0_PLLMR0_OPDV 0x00003000 +#define PLL_OPBDIV_1 0x00000000 +#define PLL_OPBDIV_2 0x00001000 +#define PLL_OPBDIV_3 0x00002000 +#define PLL_OPBDIV_4 0x00003000 +/* EBC divisor */ +#define PLL_EXTBUSDIV 0x00000300 +#define CPC0_PLLMR0_EPDV 0x00000300 +#define PLL_EXTBUSDIV_2 0x00000000 +#define PLL_EXTBUSDIV_3 0x00000100 +#define PLL_EXTBUSDIV_4 0x00000200 +#define PLL_EXTBUSDIV_5 0x00000300 +/* MAL divisor */ +#define PLL_MALDIV 0x00000030 +#define CPC0_PLLMR0_MPDV 0x00000030 +#define PLL_MALDIV_1 0x00000000 +#define PLL_MALDIV_2 0x00000010 +#define PLL_MALDIV_3 0x00000020 +#define PLL_MALDIV_4 0x00000030 +/* PCI divisor */ +#define PLL_PCIDIV 0x00000003 +#define CPC0_PLLMR0_PPFD 0x00000003 +#define PLL_PCIDIV_1 0x00000000 +#define PLL_PCIDIV_2 0x00000001 +#define PLL_PCIDIV_3 0x00000002 +#define PLL_PCIDIV_4 0x00000003 + +/* + * PLL settings for 266MHz CPU, 133MHz PLB/SDRAM, 66MHz EBC, 33MHz PCI, + * assuming a 33.3MHz input clock to the 405EP. + */ +#define PLLMR0_266_133_66 (PLL_CPUDIV_1 | PLL_PLBDIV_2 | \ + PLL_OPBDIV_2 | PLL_EXTBUSDIV_2 | \ + PLL_MALDIV_1 | PLL_PCIDIV_4) +#define PLLMR1_266_133_66 (PLL_FBKDIV_8 | \ + PLL_FWDDIVA_3 | PLL_FWDDIVB_3 | \ + PLL_TUNE_15_M_40 | PLL_TUNE_VCO_LOW) + +#define PLLMR0_133_66_66_33 (PLL_CPUDIV_1 | PLL_PLBDIV_1 | \ + PLL_OPBDIV_2 | PLL_EXTBUSDIV_4 | \ + PLL_MALDIV_1 | PLL_PCIDIV_4) +#define PLLMR1_133_66_66_33 (PLL_FBKDIV_4 | \ + PLL_FWDDIVA_6 | PLL_FWDDIVB_6 | \ + PLL_TUNE_15_M_40 | PLL_TUNE_VCO_LOW) +#define PLLMR0_200_100_50_33 (PLL_CPUDIV_1 | PLL_PLBDIV_2 | \ + PLL_OPBDIV_2 | PLL_EXTBUSDIV_3 | \ + PLL_MALDIV_1 | PLL_PCIDIV_4) +#define PLLMR1_200_100_50_33 (PLL_FBKDIV_6 | \ + PLL_FWDDIVA_4 | PLL_FWDDIVB_4 | \ + PLL_TUNE_15_M_40 | PLL_TUNE_VCO_LOW) +#define PLLMR0_266_133_66_33 (PLL_CPUDIV_1 | PLL_PLBDIV_2 | \ + PLL_OPBDIV_2 | PLL_EXTBUSDIV_4 | \ + PLL_MALDIV_1 | PLL_PCIDIV_4) +#define PLLMR1_266_133_66_33 (PLL_FBKDIV_8 | \ + PLL_FWDDIVA_3 | PLL_FWDDIVB_3 | \ + PLL_TUNE_15_M_40 | PLL_TUNE_VCO_LOW) +#define PLLMR0_266_66_33_33 (PLL_CPUDIV_1 | PLL_PLBDIV_4 | \ + PLL_OPBDIV_2 | PLL_EXTBUSDIV_2 | \ + PLL_MALDIV_1 | PLL_PCIDIV_2) +#define PLLMR1_266_66_33_33 (PLL_FBKDIV_8 | \ + PLL_FWDDIVA_3 | PLL_FWDDIVB_3 | \ + PLL_TUNE_15_M_40 | PLL_TUNE_VCO_LOW) +#define PLLMR0_333_111_55_37 (PLL_CPUDIV_1 | PLL_PLBDIV_3 | \ + PLL_OPBDIV_2 | PLL_EXTBUSDIV_2 | \ + PLL_MALDIV_1 | PLL_PCIDIV_3) +#define PLLMR1_333_111_55_37 (PLL_FBKDIV_10 | \ + PLL_FWDDIVA_3 | PLL_FWDDIVB_3 | \ + PLL_TUNE_15_M_40 | PLL_TUNE_VCO_HI) +#define PLLMR0_333_111_55_111 (PLL_CPUDIV_1 | PLL_PLBDIV_3 | \ + PLL_OPBDIV_2 | PLL_EXTBUSDIV_2 | \ + PLL_MALDIV_1 | PLL_PCIDIV_1) +#define PLLMR1_333_111_55_111 (PLL_FBKDIV_10 | \ + PLL_FWDDIVA_3 | PLL_FWDDIVB_3 | \ + PLL_TUNE_15_M_40 | PLL_TUNE_VCO_HI) + #endif /* _PPC405EP_H_ */ diff --git a/arch/powerpc/include/asm/ppc405ex.h b/arch/powerpc/include/asm/ppc405ex.h index f2c860a..880d53a 100644 --- a/arch/powerpc/include/asm/ppc405ex.h +++ b/arch/powerpc/include/asm/ppc405ex.h @@ -25,6 +25,61 @@
#define CONFIG_NAND_NDFC
-#define CONFIG_SYS_PPC4xx_PLB4_ARBITER +/* Memory mapped register */ +#define GPIO0_BASE 0xef600800 + +/* SDR */ +#define SDR0_SDCS0 0x0060 +#define SDR0_UART0 0x0120 /* UART0 Config */ +#define SDR0_UART1 0x0121 /* UART1 Config */ +#define SDR0_SRST 0x0200 +#define SDR0_CUST0 0x4000 +#define SDR0_PFC0 0x4100 +#define SDR0_PFC1 0x4101 +#define SDR0_MFR 0x4300 /* SDR0_MFR reg */ + +#define SDR0_SDCS_SDD (0x80000000 >> 31) + +#define SDR0_SRST_DMC (0x80000000 >> 10) + +#define SDR0_CUST0_MUX_E_N_G_MASK 0xC0000000 /* Mux_Emac_NDFC_GPIO */ +#define SDR0_CUST0_MUX_EMAC_SEL 0x40000000 /* Emac Selection */ +#define SDR0_CUST0_MUX_NDFC_SEL 0x80000000 /* NDFC Selection */ +#define SDR0_CUST0_MUX_GPIO_SEL 0xC0000000 /* GPIO Selection */ + +#define SDR0_CUST0_NDFC_EN_MASK 0x20000000 /* NDFC Enable Mask */ +#define SDR0_CUST0_NDFC_ENABLE 0x20000000 /* NDFC Enable */ +#define SDR0_CUST0_NDFC_DISABLE 0x00000000 /* NDFC Disable */ + +#define SDR0_CUST0_NDFC_BW_MASK 0x10000000 /* NDFC Boot Width */ +#define SDR0_CUST0_NDFC_BW_16_BIT 0x10000000 /* NDFC Boot Width= 16 Bit */ +#define SDR0_CUST0_NDFC_BW_8_BIT 0x00000000 /* NDFC Boot Width= 8 Bit */ + +#define SDR0_CUST0_NDFC_BP_MASK 0x0F000000 /* NDFC Boot Page */ +#define SDR0_CUST0_NDFC_BP_ENCODE(n) ((((u32)(n)) & 0xF) << 24) +#define SDR0_CUST0_NDFC_BP_DECODE(n) ((((u32)(n)) >> 24) & 0xF) + +#define SDR0_CUST0_NDFC_BAC_MASK 0x00C00000 /* NDFC Boot Address Cycle */ +#define SDR0_CUST0_NDFC_BAC_ENCODE(n) ((((u32)(n)) & 0x3) << 22) +#define SDR0_CUST0_NDFC_BAC_DECODE(n) ((((u32)(n)) >> 22) & 0x3) + +#define SDR0_CUST0_NDFC_ARE_MASK 0x00200000 /* NDFC Auto Read Enable */ +#define SDR0_CUST0_NDFC_ARE_ENABLE 0x00200000 /* NDFC Auto Read Enable */ +#define SDR0_CUST0_NDFC_ARE_DISABLE 0x00000000 /* NDFC Auto Read Disable */ + +#define SDR0_CUST0_NRB_MASK 0x00100000 /* NDFC Ready / Busy */ +#define SDR0_CUST0_NRB_BUSY 0x00100000 /* Busy */ +#define SDR0_CUST0_NRB_READY 0x00000000 /* Ready */ + +#define SDR0_PFC1_U1ME 0x02000000 +#define SDR0_PFC1_U0ME 0x00080000 +#define SDR0_PFC1_U0IM 0x00040000 +#define SDR0_PFC1_SIS 0x00020000 +#define SDR0_PFC1_DMAAEN 0x00010000 +#define SDR0_PFC1_DMADEN 0x00008000 +#define SDR0_PFC1_USBEN 0x00004000 +#define SDR0_PFC1_AHBSWAP 0x00000020 +#define SDR0_PFC1_USBBIGEN 0x00000010 +#define SDR0_PFC1_GPT_FREQ 0x0000000f
#endif /* _PPC405EX_H_ */ diff --git a/arch/powerpc/include/asm/ppc405ez.h b/arch/powerpc/include/asm/ppc405ez.h index 69baa20..9192c62 100644 --- a/arch/powerpc/include/asm/ppc405ez.h +++ b/arch/powerpc/include/asm/ppc405ez.h @@ -23,6 +23,75 @@
+/* Memory mapped register */ +#define GPIO0_BASE 0xef600700 +#define GPIO1_BASE 0xef600800 + +/* DCR register */ +#define OCM0_PLBCR1 0x0020 /* OCM PLB3 Bank 1 Config */ +#define OCM0_PLBCR2 0x0021 /* OCM PLB3 Bank 2 Config */ +#define OCM0_PLBBEAR 0x0022 /* OCM PLB3 Bus Error Add */ +#define OCM0_DSRC1 0x0028 /* OCM D-side Bank 1 Config */ +#define OCM0_DSRC2 0x0029 /* OCM D-side Bank 2 Config */ +#define OCM0_ISRC1 0x002A /* OCM I-side Bank 1Config */ +#define OCM0_ISRC2 0x002B /* OCM I-side Bank 2 Config */ +#define OCM0_DISDPC 0x002C /* OCM D-/I-side Data Par Chk */ + +/* SDR register */ +#define SDR0_NAND0 0x4000 +#define SDR0_ULTRA0 0x4040 +#define SDR0_ULTRA1 0x4050 +#define SDR0_ICINTSTAT 0x4510 + +/* CPR register */ +#define CPR0_PRIMAD 0x0080 +#define CPR0_PERD0 0x00e0 +#define CPR0_PERD1 0x00e1 +#define CPR0_PERC0 0x0180 + #define MAL_DCR_BASE 0x380
+#define SDR_NAND0_NDEN 0x80000000 +#define SDR_NAND0_NDBTEN 0x40000000 +#define SDR_NAND0_NDBADR_MASK 0x30000000 +#define SDR_NAND0_NDBPG_MASK 0x0f000000 +#define SDR_NAND0_NDAREN 0x00800000 +#define SDR_NAND0_NDRBEN 0x00400000 + +#define SDR_ULTRA0_NDGPIOBP 0x80000000 +#define SDR_ULTRA0_CSN_MASK 0x78000000 +#define SDR_ULTRA0_CSNSEL0 0x40000000 +#define SDR_ULTRA0_CSNSEL1 0x20000000 +#define SDR_ULTRA0_CSNSEL2 0x10000000 +#define SDR_ULTRA0_CSNSEL3 0x08000000 +#define SDR_ULTRA0_EBCRDYEN 0x04000000 +#define SDR_ULTRA0_SPISSINEN 0x02000000 +#define SDR_ULTRA0_NFSRSTEN 0x01000000 + +#define SDR_ULTRA1_LEDNENABLE 0x40000000 + +#define SDR_ICRX_STAT 0x80000000 +#define SDR_ICTX0_STAT 0x40000000 +#define SDR_ICTX1_STAT 0x20000000 + +#define CPR_CLKUPD_ENPLLCH_EN 0x40000000 /* Enable CPR PLL Changes */ +#define CPR_CLKUPD_ENDVCH_EN 0x20000000 /* Enable CPR Sys. Div. Changes */ +#define CPR_PERD0_SPIDV_MASK 0x000F0000 /* SPI Clock Divider */ + +#define PLLC_SRC_MASK 0x20000000 /* PLL feedback source */ + +#define PLLD_FBDV_MASK 0x1F000000 /* PLL feedback divider value */ +#define PLLD_FWDVA_MASK 0x000F0000 /* PLL forward divider A value */ +#define PLLD_FWDVB_MASK 0x00000700 /* PLL forward divider B value */ + +#define PRIMAD_CPUDV_MASK 0x0F000000 /* CPU Clock Divisor Mask */ +#define PRIMAD_PLBDV_MASK 0x000F0000 /* PLB Clock Divisor Mask */ +#define PRIMAD_OPBDV_MASK 0x00000F00 /* OPB Clock Divisor Mask */ +#define PRIMAD_EBCDV_MASK 0x0000000F /* EBC Clock Divisor Mask */ + +#define PERD0_PWMDV_MASK 0xFF000000 /* PWM Divider Mask */ +#define PERD0_SPIDV_MASK 0x000F0000 /* SPI Divider Mask */ +#define PERD0_U0DV_MASK 0x0000FF00 /* UART 0 Divider Mask */ +#define PERD0_U1DV_MASK 0x000000FF /* UART 1 Divider Mask */ + #endif /* _PPC405EZ_H_ */ diff --git a/arch/powerpc/include/asm/ppc405gp.h b/arch/powerpc/include/asm/ppc405gp.h index 50e0a19..79f930b 100644 --- a/arch/powerpc/include/asm/ppc405gp.h +++ b/arch/powerpc/include/asm/ppc405gp.h @@ -23,4 +23,81 @@
+/* Memory mapped register */ +#define GPIO0_BASE 0xef600700 + +/* DCR's */ +#define DCP0_CFGADDR 0x0014 /* Decompression controller addr reg */ +#define DCP0_CFGDATA 0x0015 /* Decompression controller data reg */ +#define OCM0_ISCNTL 0x0019 /* OCM I-side control reg */ +#define OCM0_DSARC 0x001a /* OCM D-side address compare */ +#define OCM0_DSCNTL 0x001b /* OCM D-side control */ +#define CPC0_PLLMR 0x00b0 /* PLL mode register */ +#define CPC0_CR0 0x00b1 /* chip control register 0 */ +#define CPC0_CR1 0x00b2 /* chip control register 1 */ +#define CPC0_PSR 0x00b4 /* chip pin strapping reg */ +#define CPC0_EIRR 0x00b6 /* ext interrupt routing reg */ +#define CPC0_SR 0x00b8 /* Power management status */ +#define CPC0_ER 0x00b9 /* Power management enable */ +#define CPC0_FR 0x00ba /* Power management force */ +#define CPC0_ECR 0x00aa /* edge conditioner register */ + +/* values for kiar register - indirect addressing of these regs */ +#define KCONF 0x40 /* decompression core config register */ + +#define PLLMR_FWD_DIV_MASK 0xE0000000 /* Forward Divisor */ +#define PLLMR_FWD_DIV_BYPASS 0xE0000000 +#define PLLMR_FWD_DIV_3 0xA0000000 +#define PLLMR_FWD_DIV_4 0x80000000 +#define PLLMR_FWD_DIV_6 0x40000000 + +#define PLLMR_FB_DIV_MASK 0x1E000000 /* Feedback Divisor */ +#define PLLMR_FB_DIV_1 0x02000000 +#define PLLMR_FB_DIV_2 0x04000000 +#define PLLMR_FB_DIV_3 0x06000000 +#define PLLMR_FB_DIV_4 0x08000000 + +#define PLLMR_TUNING_MASK 0x01F80000 + +#define PLLMR_CPU_TO_PLB_MASK 0x00060000 /* CPU:PLB Frequency Divisor */ +#define PLLMR_CPU_PLB_DIV_1 0x00000000 +#define PLLMR_CPU_PLB_DIV_2 0x00020000 +#define PLLMR_CPU_PLB_DIV_3 0x00040000 +#define PLLMR_CPU_PLB_DIV_4 0x00060000 + +#define PLLMR_OPB_TO_PLB_MASK 0x00018000 /* OPB:PLB Frequency Divisor */ +#define PLLMR_OPB_PLB_DIV_1 0x00000000 +#define PLLMR_OPB_PLB_DIV_2 0x00008000 +#define PLLMR_OPB_PLB_DIV_3 0x00010000 +#define PLLMR_OPB_PLB_DIV_4 0x00018000 + +#define PLLMR_PCI_TO_PLB_MASK 0x00006000 /* PCI:PLB Frequency Divisor */ +#define PLLMR_PCI_PLB_DIV_1 0x00000000 +#define PLLMR_PCI_PLB_DIV_2 0x00002000 +#define PLLMR_PCI_PLB_DIV_3 0x00004000 +#define PLLMR_PCI_PLB_DIV_4 0x00006000 + +#define PLLMR_EXB_TO_PLB_MASK 0x00001800 /* External Bus:PLB Divisor */ +#define PLLMR_EXB_PLB_DIV_2 0x00000000 +#define PLLMR_EXB_PLB_DIV_3 0x00000800 +#define PLLMR_EXB_PLB_DIV_4 0x00001000 +#define PLLMR_EXB_PLB_DIV_5 0x00001800 + +/* definitions for PPC405GPr (new mode strapping) */ +#define PLLMR_FWDB_DIV_MASK 0x00000007 /* Forward Divisor B */ + +#define PSR_PLL_FWD_MASK 0xC0000000 +#define PSR_PLL_FDBACK_MASK 0x30000000 +#define PSR_PLL_TUNING_MASK 0x0E000000 +#define PSR_PLB_CPU_MASK 0x01800000 +#define PSR_OPB_PLB_MASK 0x00600000 +#define PSR_PCI_PLB_MASK 0x00180000 +#define PSR_EB_PLB_MASK 0x00060000 +#define PSR_ROM_WIDTH_MASK 0x00018000 +#define PSR_ROM_LOC 0x00004000 +#define PSR_PCI_ASYNC_EN 0x00001000 +#define PSR_PERCLK_SYNC_MODE_EN 0x00000800 /* PPC405GPr only */ +#define PSR_PCI_ARBIT_EN 0x00000400 +#define PSR_NEW_MODE_EN 0x00000020 /* PPC405GPr only */ + #endif /* _PPC405GP_H_ */ diff --git a/arch/powerpc/include/asm/ppc440.h b/arch/powerpc/include/asm/ppc440.h index f5d01d9..1e4c633 100644 --- a/arch/powerpc/include/asm/ppc440.h +++ b/arch/powerpc/include/asm/ppc440.h @@ -130,30 +130,6 @@ #define CCR0_DAPUIB 0x00100000 #define CCR0_DTB 0x00008000
-/* - * External Bus Controller - */ -/* Values for EBC0_CFGADDR register - indirect addressing of these regs */ -#define PB0CR 0x00 /* periph bank 0 config reg */ -#define PB1CR 0x01 /* periph bank 1 config reg */ -#define PB2CR 0x02 /* periph bank 2 config reg */ -#define PB3CR 0x03 /* periph bank 3 config reg */ -#define PB4CR 0x04 /* periph bank 4 config reg */ -#define PB5CR 0x05 /* periph bank 5 config reg */ -#define PB6CR 0x06 /* periph bank 6 config reg */ -#define PB7CR 0x07 /* periph bank 7 config reg */ -#define PB0AP 0x10 /* periph bank 0 access parameters */ -#define PB1AP 0x11 /* periph bank 1 access parameters */ -#define PB2AP 0x12 /* periph bank 2 access parameters */ -#define PB3AP 0x13 /* periph bank 3 access parameters */ -#define PB4AP 0x14 /* periph bank 4 access parameters */ -#define PB5AP 0x15 /* periph bank 5 access parameters */ -#define PB6AP 0x16 /* periph bank 6 access parameters */ -#define PB7AP 0x17 /* periph bank 7 access parameters */ -#define PBEAR 0x20 /* periph bus error addr reg */ -#define PBESR 0x21 /* periph bus error status reg */ -#define EBC0_CFG 0x23 /* external bus configuration reg */ - #define SDR0_SDCS_SDD (0x80000000 >> 31)
/* todo: move this code from macro offsets to struct */ @@ -214,44 +190,4 @@
#define PCIL0_STS (PCIL0_CFGBASE + 0x00e0)
-/* - * GPIO macro register defines - */ -/* todo: move to ppc4xx.h and merge with gpio.h header */ -#define GPIO0_OR (GPIO0_BASE + 0x0) -#define GPIO0_TCR (GPIO0_BASE + 0x4) -#define GPIO0_OSRL (GPIO0_BASE + 0x8) -#define GPIO0_OSRH (GPIO0_BASE + 0xC) -#define GPIO0_TSRL (GPIO0_BASE + 0x10) -#define GPIO0_TSRH (GPIO0_BASE + 0x14) -#define GPIO0_ODR (GPIO0_BASE + 0x18) -#define GPIO0_IR (GPIO0_BASE + 0x1C) -#define GPIO0_RR1 (GPIO0_BASE + 0x20) -#define GPIO0_RR2 (GPIO0_BASE + 0x24) -#define GPIO0_RR3 (GPIO0_BASE + 0x28) -#define GPIO0_ISR1L (GPIO0_BASE + 0x30) -#define GPIO0_ISR1H (GPIO0_BASE + 0x34) -#define GPIO0_ISR2L (GPIO0_BASE + 0x38) -#define GPIO0_ISR2H (GPIO0_BASE + 0x3C) -#define GPIO0_ISR3L (GPIO0_BASE + 0x40) -#define GPIO0_ISR3H (GPIO0_BASE + 0x44) - -#define GPIO1_OR (GPIO1_BASE + 0x0) -#define GPIO1_TCR (GPIO1_BASE + 0x4) -#define GPIO1_OSRL (GPIO1_BASE + 0x8) -#define GPIO1_OSRH (GPIO1_BASE + 0xC) -#define GPIO1_TSRL (GPIO1_BASE + 0x10) -#define GPIO1_TSRH (GPIO1_BASE + 0x14) -#define GPIO1_ODR (GPIO1_BASE + 0x18) -#define GPIO1_IR (GPIO1_BASE + 0x1C) -#define GPIO1_RR1 (GPIO1_BASE + 0x20) -#define GPIO1_RR2 (GPIO1_BASE + 0x24) -#define GPIO1_RR3 (GPIO1_BASE + 0x28) -#define GPIO1_ISR1L (GPIO1_BASE + 0x30) -#define GPIO1_ISR1H (GPIO1_BASE + 0x34) -#define GPIO1_ISR2L (GPIO1_BASE + 0x38) -#define GPIO1_ISR2H (GPIO1_BASE + 0x3C) -#define GPIO1_ISR3L (GPIO1_BASE + 0x40) -#define GPIO1_ISR3H (GPIO1_BASE + 0x44) - #endif /* __PPC440_H__ */ diff --git a/arch/powerpc/include/asm/ppc440ep_gr.h b/arch/powerpc/include/asm/ppc440ep_gr.h index 2535787..0fd4019 100644 --- a/arch/powerpc/include/asm/ppc440ep_gr.h +++ b/arch/powerpc/include/asm/ppc440ep_gr.h @@ -25,8 +25,6 @@
-#define CONFIG_SYS_PPC4xx_PLB4_ARBITER - /* * Some SoC specific registers (not common for all 440 SoC's) */ diff --git a/arch/powerpc/include/asm/ppc440epx_grx.h b/arch/powerpc/include/asm/ppc440epx_grx.h index dfaa609..e0d7e3f 100644 --- a/arch/powerpc/include/asm/ppc440epx_grx.h +++ b/arch/powerpc/include/asm/ppc440epx_grx.h @@ -25,8 +25,6 @@
-#define CONFIG_SYS_PPC4xx_PLB4_ARBITER - /* * Some SoC specific registers (not common for all 440 SoC's) */ diff --git a/arch/powerpc/include/asm/ppc440sp.h b/arch/powerpc/include/asm/ppc440sp.h index 70b91a2..2ce5612 100644 --- a/arch/powerpc/include/asm/ppc440sp.h +++ b/arch/powerpc/include/asm/ppc440sp.h @@ -23,8 +23,6 @@
#define CONFIG_SDRAM_PPC4xx_IBM_DDR2 /* IBM DDR(2) controller */
-#define CONFIG_SYS_PPC4xx_PLB4_ARBITER - /* * Some SoC specific registers (not common for all 440 SoC's) */ diff --git a/arch/powerpc/include/asm/ppc440spe.h b/arch/powerpc/include/asm/ppc440spe.h index 2c6d8f2..6aea786 100644 --- a/arch/powerpc/include/asm/ppc440spe.h +++ b/arch/powerpc/include/asm/ppc440spe.h @@ -23,8 +23,6 @@
-#define CONFIG_SYS_PPC4xx_PLB4_ARBITER - /* * Some SoC specific registers (not common for all 440 SoC's) */ diff --git a/arch/powerpc/include/asm/ppc460ex_gt.h b/arch/powerpc/include/asm/ppc460ex_gt.h index 6dffc2c..a78a6a9 100644 --- a/arch/powerpc/include/asm/ppc460ex_gt.h +++ b/arch/powerpc/include/asm/ppc460ex_gt.h @@ -25,8 +25,6 @@
-#define CONFIG_SYS_PPC4xx_PLB4_ARBITER - /* * Some SoC specific registers */ diff --git a/arch/powerpc/include/asm/ppc460sx.h b/arch/powerpc/include/asm/ppc460sx.h index 08ea7c4..cb72e28 100644 --- a/arch/powerpc/include/asm/ppc460sx.h +++ b/arch/powerpc/include/asm/ppc460sx.h @@ -23,8 +23,6 @@
-#define CONFIG_SYS_PPC4xx_PLB4_ARBITER - #define GPIO0_BASE (CONFIG_SYS_PERIPHERAL_BASE + 0x00000700)
#define SDR0_SRST0_DMC 0x00200000 diff --git a/arch/powerpc/include/asm/ppc4xx.h b/arch/powerpc/include/asm/ppc4xx.h index 7aff401..15be343 100644 --- a/arch/powerpc/include/asm/ppc4xx.h +++ b/arch/powerpc/include/asm/ppc4xx.h @@ -95,6 +95,8 @@ #define PLB4A0_ACR 0x0081 #define PLB4A1_ACR 0x0089
+/* CPR register declarations */ + #define PLB4Ax_ACR_PPM_MASK 0xf0000000 #define PLB4Ax_ACR_PPM_FIXED 0x00000000 #define PLB4Ax_ACR_PPM_FAIR 0xd0000000 @@ -110,6 +112,73 @@ #define PLB4Ax_ACR_WRP_DISABLED 0x00000000 #define PLB4Ax_ACR_WRP_2DEEP 0x01000000
+/* + * External Bus Controller + */ +/* Values for EBC0_CFGADDR register - indirect addressing of these regs */ +#define PB0CR 0x00 /* periph bank 0 config reg */ +#define PB1CR 0x01 /* periph bank 1 config reg */ +#define PB2CR 0x02 /* periph bank 2 config reg */ +#define PB3CR 0x03 /* periph bank 3 config reg */ +#define PB4CR 0x04 /* periph bank 4 config reg */ +#define PB5CR 0x05 /* periph bank 5 config reg */ +#define PB6CR 0x06 /* periph bank 6 config reg */ +#define PB7CR 0x07 /* periph bank 7 config reg */ +#define PB0AP 0x10 /* periph bank 0 access parameters */ +#define PB1AP 0x11 /* periph bank 1 access parameters */ +#define PB2AP 0x12 /* periph bank 2 access parameters */ +#define PB3AP 0x13 /* periph bank 3 access parameters */ +#define PB4AP 0x14 /* periph bank 4 access parameters */ +#define PB5AP 0x15 /* periph bank 5 access parameters */ +#define PB6AP 0x16 /* periph bank 6 access parameters */ +#define PB7AP 0x17 /* periph bank 7 access parameters */ +#define PBEAR 0x20 /* periph bus error addr reg */ +#define PBESR0 0x21 /* periph bus error status reg 0 */ +#define PBESR1 0x22 /* periph bus error status reg 1 */ +#define EBC0_CFG 0x23 /* external bus configuration reg */ + +/* + * GPIO macro register defines + */ +/* todo: merge with gpio.h header */ +#define GPIO_BASE GPIO0_BASE + +#define GPIO0_OR (GPIO0_BASE + 0x0) +#define GPIO0_TCR (GPIO0_BASE + 0x4) +#define GPIO0_OSRL (GPIO0_BASE + 0x8) +#define GPIO0_OSRH (GPIO0_BASE + 0xC) +#define GPIO0_TSRL (GPIO0_BASE + 0x10) +#define GPIO0_TSRH (GPIO0_BASE + 0x14) +#define GPIO0_ODR (GPIO0_BASE + 0x18) +#define GPIO0_IR (GPIO0_BASE + 0x1C) +#define GPIO0_RR1 (GPIO0_BASE + 0x20) +#define GPIO0_RR2 (GPIO0_BASE + 0x24) +#define GPIO0_RR3 (GPIO0_BASE + 0x28) +#define GPIO0_ISR1L (GPIO0_BASE + 0x30) +#define GPIO0_ISR1H (GPIO0_BASE + 0x34) +#define GPIO0_ISR2L (GPIO0_BASE + 0x38) +#define GPIO0_ISR2H (GPIO0_BASE + 0x3C) +#define GPIO0_ISR3L (GPIO0_BASE + 0x40) +#define GPIO0_ISR3H (GPIO0_BASE + 0x44) + +#define GPIO1_OR (GPIO1_BASE + 0x0) +#define GPIO1_TCR (GPIO1_BASE + 0x4) +#define GPIO1_OSRL (GPIO1_BASE + 0x8) +#define GPIO1_OSRH (GPIO1_BASE + 0xC) +#define GPIO1_TSRL (GPIO1_BASE + 0x10) +#define GPIO1_TSRH (GPIO1_BASE + 0x14) +#define GPIO1_ODR (GPIO1_BASE + 0x18) +#define GPIO1_IR (GPIO1_BASE + 0x1C) +#define GPIO1_RR1 (GPIO1_BASE + 0x20) +#define GPIO1_RR2 (GPIO1_BASE + 0x24) +#define GPIO1_RR3 (GPIO1_BASE + 0x28) +#define GPIO1_ISR1L (GPIO1_BASE + 0x30) +#define GPIO1_ISR1H (GPIO1_BASE + 0x34) +#define GPIO1_ISR2L (GPIO1_BASE + 0x38) +#define GPIO1_ISR2H (GPIO1_BASE + 0x3C) +#define GPIO1_ISR3L (GPIO1_BASE + 0x40) +#define GPIO1_ISR3H (GPIO1_BASE + 0x44) + /* General Purpose Timer (GPT) Register Offsets */ #define GPT0_TBC 0x00000000 #define GPT0_IM 0x00000018 diff --git a/board/amcc/acadia/pll.c b/board/amcc/acadia/pll.c index 452961d..6327d6c 100644 --- a/board/amcc/acadia/pll.c +++ b/board/amcc/acadia/pll.c @@ -53,9 +53,9 @@ void board_pll_init_f(void) /* Initialize PLL */ mtcpr(CPR0_PLLC, 0x0000033c); mtcpr(CPR0_PLLD, 0x0c010200); - mtcpr(CPC0_PRIMAD, 0x04060c0c); - mtcpr(CPC0_PERD0, 0x000c0000); /* SPI clk div. eq. OPB clk div. */ - mtcpr(CPR0_CLKUP, 0x40000000); + mtcpr(CPR0_PRIMAD, 0x04060c0c); + mtcpr(CPR0_PERD0, 0x000c0000); /* SPI clk div. eq. OPB clk div. */ + mtcpr(CPR0_CLKUPD, 0x40000000); }
#elif defined(PLLMR0_266_160_80) @@ -85,10 +85,10 @@ void board_pll_init_f(void) /* Initialize PLL */ mtcpr(CPR0_PLLC, 0x20000238); mtcpr(CPR0_PLLD, 0x03010400); - mtcpr(CPC0_PRIMAD, 0x03050a0a); - mtcpr(CPC0_PERC0, 0x00000000); - mtcpr(CPC0_PERD0, 0x070a0707); /* SPI clk div. eq. OPB clk div. */ - mtcpr(CPC0_PERD1, 0x07323200); + mtcpr(CPR0_PRIMAD, 0x03050a0a); + mtcpr(CPR0_PERC0, 0x00000000); + mtcpr(CPR0_PERD0, 0x070a0707); /* SPI clk div. eq. OPB clk div. */ + mtcpr(CPR0_PERD1, 0x07323200); mtcpr(CPR0_CLKUP, 0x40000000); }
@@ -119,9 +119,9 @@ void board_pll_init_f(void) /* Initialize PLL */ mtcpr(CPR0_PLLC, 0x0000033C); mtcpr(CPR0_PLLD, 0x0a010000); - mtcpr(CPC0_PRIMAD, 0x02040808); - mtcpr(CPC0_PERD0, 0x02080505); /* SPI clk div. eq. OPB clk div. */ - mtcpr(CPC0_PERD1, 0xA6A60300); + mtcpr(CPR0_PRIMAD, 0x02040808); + mtcpr(CPR0_PERD0, 0x02080505); /* SPI clk div. eq. OPB clk div. */ + mtcpr(CPR0_PERD1, 0xA6A60300); mtcpr(CPR0_CLKUP, 0x40000000); }
@@ -145,9 +145,9 @@ void board_pll_init_f(void) /* Initialize PLL */ mtcpr(CPR0_PLLC, 0x000003BC); mtcpr(CPR0_PLLD, 0x06060600); - mtcpr(CPC0_PRIMAD, 0x02020004); - mtcpr(CPC0_PERD0, 0x04002828); /* SPI clk div. eq. OPB clk div. */ - mtcpr(CPC0_PERD1, 0xC8C81600); + mtcpr(CPR0_PRIMAD, 0x02020004); + mtcpr(CPR0_PERD0, 0x04002828); /* SPI clk div. eq. OPB clk div. */ + mtcpr(CPR0_PERD1, 0xC8C81600); mtcpr(CPR0_CLKUP, 0x40000000); } #endif /* CPU_<speed>_405EZ */ @@ -172,7 +172,7 @@ unsigned long get_tbclk(void) /* * Read CPR_PRIMAD register */ - mfcpr(CPC0_PRIMAD, cpr_primad); + mfcpr(CPR0_PRIMAD, cpr_primad);
/* * Determine CPU clock frequency diff --git a/board/mpl/mip405/init.S b/board/mpl/mip405/init.S index 67988ba..39a1d68 100644 --- a/board/mpl/mip405/init.S +++ b/board/mpl/mip405/init.S @@ -39,8 +39,6 @@ * Bank 6 - not used * Bank 7 - PLD Register *-----------------------------------------------------------------------------*/ -#include <asm/ppc4xx.h> - #define _LINUX_CONFIG_H 1 /* avoid reading Linux autoconf.h file */
#include <configs/MIP405.h> @@ -49,6 +47,7 @@
#include <asm/cache.h> #include <asm/mmu.h> +#include <asm/ppc4xx.h> #include "mip405.h"
diff --git a/board/mpl/mip405/mip405.c b/board/mpl/mip405/mip405.c index 3db06e7..e93d994 100644 --- a/board/mpl/mip405/mip405.c +++ b/board/mpl/mip405/mip405.c @@ -65,6 +65,7 @@ #include <common.h> #include "mip405.h" #include <asm/processor.h> +#include <asm/ppc4xx.h> #include <asm/ppc4xx-i2c.h> #include <miiphy.h> #include "../common/common_util.h" diff --git a/board/mpl/pip405/init.S b/board/mpl/pip405/init.S index e82be89..b77517f 100644 --- a/board/mpl/pip405/init.S +++ b/board/mpl/pip405/init.S @@ -39,8 +39,6 @@ * Bank 6 - used to switch on the 12V for the Multipurpose socket * Bank 7 - Config Register *-----------------------------------------------------------------------------*/ -#include <asm/ppc4xx.h> - #define _LINUX_CONFIG_H 1 /* avoid reading Linux autoconf.h file */
#include <configs/PIP405.h> @@ -49,6 +47,7 @@
#include <asm/cache.h> #include <asm/mmu.h> +#include <asm/ppc4xx.h> #include "pip405.h"
.globl ext_bus_cntlr_init diff --git a/board/sc3/sc3.c b/board/sc3/sc3.c index 63927f7..f148ad6 100644 --- a/board/sc3/sc3.c +++ b/board/sc3/sc3.c @@ -331,16 +331,16 @@ int board_early_init_f (void) }
/* Code decompression disabled */ - mtdcr (KIAR, KCONF); - mtdcr (KIDR, 0x2B); + mtdcr (DCP0_CFGADDR, KCONF); + mtdcr (DCP0_CFGDATA, 0x2B);
/* CPC0_ER: enable sleep mode of (currently) unused components */ /* CPC0_FR: force unused components into sleep mode */ - mtdcr (CPMER, 0x3F800000); - mtdcr (CPMFR, 0x14000000); + mtdcr (CPC0_ER, 0x3F800000); + mtdcr (CPC0_FR, 0x14000000);
/* set PLB priority */ - mtdcr (0x87, 0x08000000); + mtdcr (PLB0_ACR, 0x08000000);
/* --------------- DMA stuff ------------------------------------- */ mtdcr (0x126, 0x49200000); diff --git a/include/configs/ASH405.h b/include/configs/ASH405.h index 4cb8052..98bd6f3 100644 --- a/include/configs/ASH405.h +++ b/include/configs/ASH405.h @@ -335,12 +335,12 @@ * GPIO0[28-29] - UART1 data signal input/output * GPIO0[30-31] - EMAC0 and EMAC1 reject packet inputs */ -#define CONFIG_SYS_GPIO0_OSRH 0x40000550 -#define CONFIG_SYS_GPIO0_OSRL 0x00000110 -#define CONFIG_SYS_GPIO0_ISR1H 0x00000000 -#define CONFIG_SYS_GPIO0_ISR1L 0x15555445 -#define CONFIG_SYS_GPIO0_TSRH 0x00000000 +#define CONFIG_SYS_GPIO0_OSRL 0x40000550 +#define CONFIG_SYS_GPIO0_OSRH 0x00000110 +#define CONFIG_SYS_GPIO0_ISR1L 0x00000000 +#define CONFIG_SYS_GPIO0_ISR1H 0x15555445 #define CONFIG_SYS_GPIO0_TSRL 0x00000000 +#define CONFIG_SYS_GPIO0_TSRH 0x00000000 #define CONFIG_SYS_GPIO0_TCR 0xF7FE0014
#define CONFIG_SYS_DUART_RST (0x80000000 >> 14) diff --git a/include/configs/CATcenter.h b/include/configs/CATcenter.h index 229a513..da85442 100644 --- a/include/configs/CATcenter.h +++ b/include/configs/CATcenter.h @@ -535,13 +535,13 @@ * GPIO0[30] - EMAC0 input * GPIO0[31] - EMAC1 reject packet as output */ -#define CONFIG_SYS_GPIO0_OSRH 0x40000550 -#define CONFIG_SYS_GPIO0_OSRL 0x00000110 -#define CONFIG_SYS_GPIO0_ISR1H 0x00000000 -/*#define CONFIG_SYS_GPIO0_ISR1L 0x15555445*/ -#define CONFIG_SYS_GPIO0_ISR1L 0x15555444 -#define CONFIG_SYS_GPIO0_TSRH 0x00000000 +#define CONFIG_SYS_GPIO0_OSRL 0x40000550 +#define CONFIG_SYS_GPIO0_OSRH 0x00000110 +#define CONFIG_SYS_GPIO0_ISR1L 0x00000000 +/*#define CONFIG_SYS_GPIO0_ISR1H 0x15555445*/ +#define CONFIG_SYS_GPIO0_ISR1H 0x15555444 #define CONFIG_SYS_GPIO0_TSRL 0x00000000 +#define CONFIG_SYS_GPIO0_TSRH 0x00000000 #define CONFIG_SYS_GPIO0_TCR 0xF7FF8014
/* diff --git a/include/configs/CMS700.h b/include/configs/CMS700.h index 2b6786b..ede9970 100644 --- a/include/configs/CMS700.h +++ b/include/configs/CMS700.h @@ -301,12 +301,12 @@ /* GPIO Output: OSR=00, ISR=00, TSR=00, TCR=1 */ /* Alt. Funtion Input: OSR=00, ISR=01, TSR=00, TCR=0 */ /* Alt. Funtion Output: OSR=01, ISR=00, TSR=00, TCR=1 */ -#define CONFIG_SYS_GPIO0_OSRH 0x40000500 /* 0 ... 15 */ -#define CONFIG_SYS_GPIO0_OSRL 0x00000110 /* 16 ... 31 */ -#define CONFIG_SYS_GPIO0_ISR1H 0x00000000 /* 0 ... 15 */ -#define CONFIG_SYS_GPIO0_ISR1L 0x14000045 /* 16 ... 31 */ -#define CONFIG_SYS_GPIO0_TSRH 0x00000000 /* 0 ... 15 */ -#define CONFIG_SYS_GPIO0_TSRL 0x00000000 /* 16 ... 31 */ +#define CONFIG_SYS_GPIO0_OSRL 0x40000500 /* 0 ... 15 */ +#define CONFIG_SYS_GPIO0_OSRH 0x00000110 /* 16 ... 31 */ +#define CONFIG_SYS_GPIO0_ISR1L 0x00000000 /* 0 ... 15 */ +#define CONFIG_SYS_GPIO0_ISR1H 0x14000045 /* 16 ... 31 */ +#define CONFIG_SYS_GPIO0_TSRL 0x00000000 /* 0 ... 15 */ +#define CONFIG_SYS_GPIO0_TSRH 0x00000000 /* 16 ... 31 */ #define CONFIG_SYS_GPIO0_TCR 0xF7FE0014 /* 0 ... 31 */
#define CONFIG_SYS_EEPROM_WP (0x80000000 >> 8) /* GPIO8 */ diff --git a/include/configs/DP405.h b/include/configs/DP405.h index 4423f2a..0ee456b 100644 --- a/include/configs/DP405.h +++ b/include/configs/DP405.h @@ -243,12 +243,12 @@ /* GPIO Output: OSR=00, ISR=00, TSR=00, TCR=1 */ /* Alt. Funtion Input: OSR=00, ISR=01, TSR=00, TCR=0 */ /* Alt. Funtion Output: OSR=01, ISR=00, TSR=00, TCR=1 */ -#define CONFIG_SYS_GPIO0_OSRH 0x40000540 /* 0 ... 15 */ -#define CONFIG_SYS_GPIO0_OSRL 0x00000110 /* 16 ... 31 */ -#define CONFIG_SYS_GPIO0_ISR1H 0x00000000 /* 0 ... 15 */ -#define CONFIG_SYS_GPIO0_ISR1L 0x14000045 /* 16 ... 31 */ -#define CONFIG_SYS_GPIO0_TSRH 0x00000000 /* 0 ... 15 */ -#define CONFIG_SYS_GPIO0_TSRL 0x00000000 /* 16 ... 31 */ +#define CONFIG_SYS_GPIO0_OSRL 0x40000540 /* 0 ... 15 */ +#define CONFIG_SYS_GPIO0_OSRH 0x00000110 /* 16 ... 31 */ +#define CONFIG_SYS_GPIO0_ISR1L 0x00000000 /* 0 ... 15 */ +#define CONFIG_SYS_GPIO0_ISR1H 0x14000045 /* 16 ... 31 */ +#define CONFIG_SYS_GPIO0_TSRL 0x00000000 /* 0 ... 15 */ +#define CONFIG_SYS_GPIO0_TSRH 0x00000000 /* 16 ... 31 */ #define CONFIG_SYS_GPIO0_TCR 0xB7FE0014 /* 0 ... 31 */
/* diff --git a/include/configs/G2000.h b/include/configs/G2000.h index d2883eb..4d29f21 100644 --- a/include/configs/G2000.h +++ b/include/configs/G2000.h @@ -367,12 +367,12 @@ * * following GPIO setting changed for G20000, 080304 */ -#define CONFIG_SYS_GPIO0_OSRH 0x40005555 -#define CONFIG_SYS_GPIO0_OSRL 0x40000110 -#define CONFIG_SYS_GPIO0_ISR1H 0x00000000 -#define CONFIG_SYS_GPIO0_ISR1L 0x15555445 -#define CONFIG_SYS_GPIO0_TSRH 0x00000000 +#define CONFIG_SYS_GPIO0_OSRL 0x40005555 +#define CONFIG_SYS_GPIO0_OSRH 0x40000110 +#define CONFIG_SYS_GPIO0_ISR1L 0x00000000 +#define CONFIG_SYS_GPIO0_ISR1H 0x15555445 #define CONFIG_SYS_GPIO0_TSRL 0x00000000 +#define CONFIG_SYS_GPIO0_TSRH 0x00000000 #define CONFIG_SYS_GPIO0_TCR 0xF7FF8014
/* diff --git a/include/configs/HH405.h b/include/configs/HH405.h index 01e0bc6..d940a88 100644 --- a/include/configs/HH405.h +++ b/include/configs/HH405.h @@ -461,12 +461,12 @@ * GPIO0[28-29] - UART1 data signal input/output * GPIO0[30-31] - EMAC0 and EMAC1 reject packet inputs */ -#define CONFIG_SYS_GPIO0_OSRH 0x40000550 -#define CONFIG_SYS_GPIO0_OSRL 0x00000110 -#define CONFIG_SYS_GPIO0_ISR1H 0x00000000 -#define CONFIG_SYS_GPIO0_ISR1L 0x15555440 -#define CONFIG_SYS_GPIO0_TSRH 0x00000000 +#define CONFIG_SYS_GPIO0_OSRL 0x40000550 +#define CONFIG_SYS_GPIO0_OSRH 0x00000110 +#define CONFIG_SYS_GPIO0_ISR1L 0x00000000 +#define CONFIG_SYS_GPIO0_ISR1H 0x15555440 #define CONFIG_SYS_GPIO0_TSRL 0x00000000 +#define CONFIG_SYS_GPIO0_TSRH 0x00000000 #define CONFIG_SYS_GPIO0_TCR 0xF7FE0017
#define CONFIG_SYS_LCD_ENDIAN (0x80000000 >> 7) diff --git a/include/configs/HUB405.h b/include/configs/HUB405.h index 8c6d5ed..72e907b 100644 --- a/include/configs/HUB405.h +++ b/include/configs/HUB405.h @@ -334,12 +334,12 @@ * GPIO0[28-29] - UART1 data signal input/output * GPIO0[30-31] - EMAC0 and EMAC1 reject packet inputs */ -#define CONFIG_SYS_GPIO0_OSRH 0x40000550 -#define CONFIG_SYS_GPIO0_OSRL 0x00000110 -#define CONFIG_SYS_GPIO0_ISR1H 0x00000000 -#define CONFIG_SYS_GPIO0_ISR1L 0x15555445 -#define CONFIG_SYS_GPIO0_TSRH 0x00000000 +#define CONFIG_SYS_GPIO0_OSRL 0x40000550 +#define CONFIG_SYS_GPIO0_OSRH 0x00000110 +#define CONFIG_SYS_GPIO0_ISR1L 0x00000000 +#define CONFIG_SYS_GPIO0_ISR1H 0x15555445 #define CONFIG_SYS_GPIO0_TSRL 0x00000000 +#define CONFIG_SYS_GPIO0_TSRH 0x00000000 #define CONFIG_SYS_GPIO0_TCR 0xF7FE0014
#define CONFIG_SYS_DUART_RST (0x80000000 >> 14) diff --git a/include/configs/PLU405.h b/include/configs/PLU405.h index f917eb5..a308782 100644 --- a/include/configs/PLU405.h +++ b/include/configs/PLU405.h @@ -379,12 +379,12 @@ * GPIO0[28-29] - UART1 data signal input/output * GPIO0[30-31] - EMAC0 and EMAC1 reject packet inputs */ -#define CONFIG_SYS_GPIO0_OSRH 0x00000550 -#define CONFIG_SYS_GPIO0_OSRL 0x00000110 -#define CONFIG_SYS_GPIO0_ISR1H 0x00000000 -#define CONFIG_SYS_GPIO0_ISR1L 0x15555445 -#define CONFIG_SYS_GPIO0_TSRH 0x00000000 +#define CONFIG_SYS_GPIO0_OSRL 0x00000550 +#define CONFIG_SYS_GPIO0_OSRH 0x00000110 +#define CONFIG_SYS_GPIO0_ISR1L 0x00000000 +#define CONFIG_SYS_GPIO0_ISR1H 0x15555445 #define CONFIG_SYS_GPIO0_TSRL 0x00000000 +#define CONFIG_SYS_GPIO0_TSRH 0x00000000 #define CONFIG_SYS_GPIO0_TCR 0x77FE0014
#define CONFIG_SYS_DUART_RST (0x80000000 >> 14) diff --git a/include/configs/PPChameleonEVB.h b/include/configs/PPChameleonEVB.h index 09f3544..e9cae85 100644 --- a/include/configs/PPChameleonEVB.h +++ b/include/configs/PPChameleonEVB.h @@ -542,13 +542,13 @@ * GPIO0[30] - EMAC0 input * GPIO0[31] - EMAC1 reject packet as output */ -#define CONFIG_SYS_GPIO0_OSRH 0x40000550 -#define CONFIG_SYS_GPIO0_OSRL 0x00000110 -#define CONFIG_SYS_GPIO0_ISR1H 0x00000000 -/*#define CONFIG_SYS_GPIO0_ISR1L 0x15555445*/ -#define CONFIG_SYS_GPIO0_ISR1L 0x15555444 -#define CONFIG_SYS_GPIO0_TSRH 0x00000000 +#define CONFIG_SYS_GPIO0_OSRL 0x40000550 +#define CONFIG_SYS_GPIO0_OSRH 0x00000110 +#define CONFIG_SYS_GPIO0_ISR1L 0x00000000 +/*#define CONFIG_SYS_GPIO0_ISR1H 0x15555445*/ +#define CONFIG_SYS_GPIO0_ISR1H 0x15555444 #define CONFIG_SYS_GPIO0_TSRL 0x00000000 +#define CONFIG_SYS_GPIO0_TSRH 0x00000000 #define CONFIG_SYS_GPIO0_TCR 0xF7FF8014
/* diff --git a/include/configs/VOH405.h b/include/configs/VOH405.h index 9c91fcc..21bb5b6 100644 --- a/include/configs/VOH405.h +++ b/include/configs/VOH405.h @@ -388,12 +388,12 @@ * GPIO0[28-29] - UART1 data signal input/output * GPIO0[30-31] - EMAC0 and EMAC1 reject packet inputs -> GPIO */ -#define CONFIG_SYS_GPIO0_OSRH 0x00000550 -#define CONFIG_SYS_GPIO0_OSRL 0x00000110 -#define CONFIG_SYS_GPIO0_ISR1H 0x00000000 -#define CONFIG_SYS_GPIO0_ISR1L 0x15555440 -#define CONFIG_SYS_GPIO0_TSRH 0x00000000 +#define CONFIG_SYS_GPIO0_OSRL 0x00000550 +#define CONFIG_SYS_GPIO0_OSRH 0x00000110 +#define CONFIG_SYS_GPIO0_ISR1L 0x00000000 +#define CONFIG_SYS_GPIO0_ISR1H 0x15555440 #define CONFIG_SYS_GPIO0_TSRL 0x00000000 +#define CONFIG_SYS_GPIO0_TSRH 0x00000000 #define CONFIG_SYS_GPIO0_TCR 0x777E0017
#define CONFIG_SYS_DUART_RST (0x80000000 >> 14) diff --git a/include/configs/VOM405.h b/include/configs/VOM405.h index 871e4c3..747d6a0 100644 --- a/include/configs/VOM405.h +++ b/include/configs/VOM405.h @@ -273,12 +273,12 @@ /* GPIO Output: OSR=00, ISR=00, TSR=00, TCR=1 */ /* Alt. Funtion Input: OSR=00, ISR=01, TSR=00, TCR=0 */ /* Alt. Funtion Output: OSR=01, ISR=00, TSR=00, TCR=1 */ -#define CONFIG_SYS_GPIO0_OSRH 0x40000500 /* 0 ... 15 */ -#define CONFIG_SYS_GPIO0_OSRL 0x00000110 /* 16 ... 31 */ -#define CONFIG_SYS_GPIO0_ISR1H 0x00000000 /* 0 ... 15 */ -#define CONFIG_SYS_GPIO0_ISR1L 0x14000045 /* 16 ... 31 */ -#define CONFIG_SYS_GPIO0_TSRH 0x00000000 /* 0 ... 15 */ -#define CONFIG_SYS_GPIO0_TSRL 0x00000000 /* 16 ... 31 */ +#define CONFIG_SYS_GPIO0_OSRL 0x40000500 /* 0 ... 15 */ +#define CONFIG_SYS_GPIO0_OSRH 0x00000110 /* 16 ... 31 */ +#define CONFIG_SYS_GPIO0_ISR1L 0x00000000 /* 0 ... 15 */ +#define CONFIG_SYS_GPIO0_ISR1H 0x14000045 /* 16 ... 31 */ +#define CONFIG_SYS_GPIO0_TSRL 0x00000000 /* 0 ... 15 */ +#define CONFIG_SYS_GPIO0_TSRH 0x00000000 /* 16 ... 31 */ #define CONFIG_SYS_GPIO0_TCR 0xF7FE0014 /* 0 ... 31 */
/* diff --git a/include/configs/WUH405.h b/include/configs/WUH405.h index be9ac62..7756d3a 100644 --- a/include/configs/WUH405.h +++ b/include/configs/WUH405.h @@ -332,12 +332,12 @@ * GPIO0[28-29] - UART1 data signal input/output * GPIO0[30-31] - EMAC0 and EMAC1 reject packet inputs */ -#define CONFIG_SYS_GPIO0_OSRH 0x40000550 -#define CONFIG_SYS_GPIO0_OSRL 0x00000110 -#define CONFIG_SYS_GPIO0_ISR1H 0x00000000 -#define CONFIG_SYS_GPIO0_ISR1L 0x15555445 -#define CONFIG_SYS_GPIO0_TSRH 0x00000000 +#define CONFIG_SYS_GPIO0_OSRL 0x40000550 +#define CONFIG_SYS_GPIO0_OSRH 0x00000110 +#define CONFIG_SYS_GPIO0_ISR1L 0x00000000 +#define CONFIG_SYS_GPIO0_ISR1H 0x15555445 #define CONFIG_SYS_GPIO0_TSRL 0x00000000 +#define CONFIG_SYS_GPIO0_TSRH 0x00000000 #define CONFIG_SYS_GPIO0_TCR 0xF7FE0014
#define CONFIG_SYS_DUART_RST (0x80000000 >> 14) diff --git a/include/configs/bubinga.h b/include/configs/bubinga.h index 159a265..05c4766 100644 --- a/include/configs/bubinga.h +++ b/include/configs/bubinga.h @@ -284,12 +284,12 @@ * GPIO0[28-29] - UART1 data signal input/output * GPIO0[30-31] - EMAC0 and EMAC1 reject packet inputs */ -#define CONFIG_SYS_GPIO0_OSRH 0x55555555 -#define CONFIG_SYS_GPIO0_OSRL 0x40000110 -#define CONFIG_SYS_GPIO0_ISR1H 0x00000000 -#define CONFIG_SYS_GPIO0_ISR1L 0x15555445 -#define CONFIG_SYS_GPIO0_TSRH 0x00000000 +#define CONFIG_SYS_GPIO0_OSRL 0x55555555 +#define CONFIG_SYS_GPIO0_OSRH 0x40000110 +#define CONFIG_SYS_GPIO0_ISR1L 0x00000000 +#define CONFIG_SYS_GPIO0_ISR1H 0x15555445 #define CONFIG_SYS_GPIO0_TSRL 0x00000000 +#define CONFIG_SYS_GPIO0_TSRH 0x00000000 #define CONFIG_SYS_GPIO0_TCR 0xFFFF8014
/*----------------------------------------------------------------------- diff --git a/include/configs/quad100hd.h b/include/configs/quad100hd.h index 5538b18..b778187 100644 --- a/include/configs/quad100hd.h +++ b/include/configs/quad100hd.h @@ -270,12 +270,12 @@ * Taken in part from PPCBoot board/icecube/icecube.h */ /* see ./arch/powerpc/cpu/ppc4xx/cpu_init.c ./cpu/ppc4xx/start.S */ -#define CONFIG_SYS_GPIO0_OSRH 0x55555550 -#define CONFIG_SYS_GPIO0_OSRL 0x00000110 -#define CONFIG_SYS_GPIO0_ISR1H 0x00000000 -#define CONFIG_SYS_GPIO0_ISR1L 0x15555445 -#define CONFIG_SYS_GPIO0_TSRH 0x00000000 +#define CONFIG_SYS_GPIO0_OSRL 0x55555550 +#define CONFIG_SYS_GPIO0_OSRH 0x00000110 +#define CONFIG_SYS_GPIO0_ISR1L 0x00000000 +#define CONFIG_SYS_GPIO0_ISR1H 0x15555445 #define CONFIG_SYS_GPIO0_TSRL 0x00000000 +#define CONFIG_SYS_GPIO0_TSRH 0x00000000 #define CONFIG_SYS_GPIO0_TCR 0xFFFF8097 #define CONFIG_SYS_GPIO0_ODR 0x00000000
diff --git a/include/configs/zeus.h b/include/configs/zeus.h index 3b2aede..1ae990f 100644 --- a/include/configs/zeus.h +++ b/include/configs/zeus.h @@ -279,12 +279,12 @@ * GPIO0[28-29] - UART1 data signal input/output * GPIO0[30-31] - EMAC0 and EMAC1 reject packet inputs */ -#define CONFIG_SYS_GPIO0_OSRH 0x15555550 /* Chip selects */ -#define CONFIG_SYS_GPIO0_OSRL 0x00000110 /* UART_DTR-pin 27 alt out */ -#define CONFIG_SYS_GPIO0_ISR1H 0x10000041 /* Pin 2, 12 is input */ -#define CONFIG_SYS_GPIO0_ISR1L 0x15505440 /* OUT: LEDs 22/23; IN: pin12,2, NVALID# */ -#define CONFIG_SYS_GPIO0_TSRH 0x00000000 +#define CONFIG_SYS_GPIO0_OSRL 0x15555550 /* Chip selects */ +#define CONFIG_SYS_GPIO0_OSRH 0x00000110 /* UART_DTR-pin 27 alt out */ +#define CONFIG_SYS_GPIO0_ISR1L 0x10000041 /* Pin 2, 12 is input */ +#define CONFIG_SYS_GPIO0_ISR1H 0x15505440 /* OUT: LEDs 22/23; IN: pin12,2, NVALID# */ #define CONFIG_SYS_GPIO0_TSRL 0x00000000 +#define CONFIG_SYS_GPIO0_TSRH 0x00000000 #define CONFIG_SYS_GPIO0_TCR 0xBFF68317 /* 3-state OUT: 22/23/29; 12,2 is not 3-state */ #define CONFIG_SYS_GPIO0_ODR 0x00000000
Stefan Roese
