[U-Boot] [PATCH] ARM64: zynqmp: Wire up both USBs available on ZynqMP
The second USB wasn't enabled. This patch fixes it.
board/xilinx/zynqmp/zynqmp.c | 20 ++++++++++++++++++-- include/configs/xilinx_zynqmp.h | 2 +- 2 files changed, 19 insertions(+), 3 deletions(-)
diff --git a/board/xilinx/zynqmp/zynqmp.c b/board/xilinx/zynqmp/zynqmp.c index 0c5d9979316f..7b4b5ffd89f4 100644 --- a/board/xilinx/zynqmp/zynqmp.c +++ b/board/xilinx/zynqmp/zynqmp.c @@ -283,13 +283,20 @@ int checkboard(void) }
#ifdef CONFIG_USB_DWC3 -static struct dwc3_device dwc3_device_data = { +static struct dwc3_device dwc3_device_data0 = { .maximum_speed = USB_SPEED_HIGH, .base = ZYNQMP_USB0_XHCI_BASEADDR, .dr_mode = USB_DR_MODE_PERIPHERAL, .index = 0, };
+static struct dwc3_device dwc3_device_data1 = { + .maximum_speed = USB_SPEED_HIGH, + .base = ZYNQMP_USB1_XHCI_BASEADDR, + .dr_mode = USB_DR_MODE_PERIPHERAL, + .index = 1, +}; + int usb_gadget_handle_interrupts(void) { dwc3_uboot_handle_interrupt(0); @@ -298,7 +305,16 @@ int usb_gadget_handle_interrupts(void)
int board_usb_init(int index, enum usb_init_type init) { - return dwc3_uboot_init(&dwc3_device_data); + debug("%s: index %x\n", __func__, index); + + switch (index) { + case 0: + return dwc3_uboot_init(&dwc3_device_data0); + case 1: + return dwc3_uboot_init(&dwc3_device_data1); + }; + + return -1; }
int board_usb_cleanup(int index, enum usb_init_type init) diff --git a/include/configs/xilinx_zynqmp.h b/include/configs/xilinx_zynqmp.h index 78d8bf476872..96b6da8bed4b 100644 --- a/include/configs/xilinx_zynqmp.h +++ b/include/configs/xilinx_zynqmp.h @@ -115,7 +115,7 @@ #define CONFIG_SYS_LOAD_ADDR 0x8000000
#if defined(CONFIG_ZYNQMP_USB) -#define CONFIG_USB_MAX_CONTROLLER_COUNT 1 +#define CONFIG_USB_MAX_CONTROLLER_COUNT 2 #define CONFIG_SYS_USB_XHCI_MAX_ROOT_PORTS 2 #define CONFIG_USB_XHCI_ZYNQMP
Michal Simek
