[U-Boot] ot1200: add basic SPL support
This patch series add basic SPL support for the ot1200. In future patches this support will gets extended to support different memory configurations.
Signed-off-by: Christian Gmeiner christian.gmeiner@gmail.com --- arch/arm/Kconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 5eb1d03..5734405 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -663,6 +663,7 @@ config TARGET_TQMA6 config TARGET_OT1200 bool "Bachmann OT1200" select CPU_V7 + select SUPPORT_SPL
config OMAP34XX bool "OMAP34XX SoC"
- select SUPPORT_SPL
Whole series merged into u-boot-imx, thanks !
Best regards, Stefano Babic
To support different ddr3 memory sizes we should start using imx_ddr_size(..) instead of the define PHYS_SDRAM_SIZE.
Signed-off-by: Christian Gmeiner christian.gmeiner@gmail.com --- board/bachmann/ot1200/ot1200.c | 3 ++- include/configs/ot1200.h | 1 - 2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/board/bachmann/ot1200/ot1200.c b/board/bachmann/ot1200/ot1200.c index 93f3d65..039e858 100644 --- a/board/bachmann/ot1200/ot1200.c +++ b/board/bachmann/ot1200/ot1200.c @@ -16,6 +16,7 @@ #include <asm/imx-common/mxc_i2c.h> #include <asm/imx-common/boot_mode.h> #include <asm/arch/crm_regs.h> +#include <asm/arch/sys_proto.h> #include <mmc.h> #include <fsl_esdhc.h> #include <netdev.h> @@ -46,7 +47,7 @@ DECLARE_GLOBAL_DATA_PTR;
int dram_init(void) { - gd->ram_size = get_ram_size((void *)PHYS_SDRAM, PHYS_SDRAM_SIZE); + gd->ram_size = imx_ddr_size();
return 0; } diff --git a/include/configs/ot1200.h b/include/configs/ot1200.h index 255c933..97ee664 100644 --- a/include/configs/ot1200.h +++ b/include/configs/ot1200.h @@ -159,7 +159,6 @@ /* Physical Memory Map */ #define CONFIG_NR_DRAM_BANKS 1 #define PHYS_SDRAM MMDC0_ARB_BASE_ADDR -#define PHYS_SDRAM_SIZE (1u * 1024 * 1024 * 1024)
#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM #define CONFIG_SYS_INIT_RAM_ADDR IRAM_BASE_ADDR
We need this way for SPL boot.
Signed-off-by: Christian Gmeiner christian.gmeiner@gmail.com --- board/bachmann/ot1200/mx6q_4x_mt41j128.cfg | 14 -------------- board/bachmann/ot1200/ot1200.c | 28 ++++++++++++++++++++++++++++ 2 files changed, 28 insertions(+), 14 deletions(-)
diff --git a/board/bachmann/ot1200/mx6q_4x_mt41j128.cfg b/board/bachmann/ot1200/mx6q_4x_mt41j128.cfg index bb6c60b..c25f99d 100644 --- a/board/bachmann/ot1200/mx6q_4x_mt41j128.cfg +++ b/board/bachmann/ot1200/mx6q_4x_mt41j128.cfg @@ -142,20 +142,6 @@ DATA 4 0x021b48b8 0x00000800 DATA 4 0x021b001c 0x00000000 DATA 4 0x021b0404 0x00011006
-/* set the default clock gate to save power */ -DATA 4 0x020c4068 0x00C03F3F -DATA 4 0x020c406c 0x0030FC03 -DATA 4 0x020c4070 0x0FFFC000 -DATA 4 0x020c4074 0x3FF00000 -DATA 4 0x020c4078 0x00FFF300 -DATA 4 0x020c407c 0x0F0000C3 -DATA 4 0x020c4080 0x000003FF - -/* enable AXI cache for VDOA/VPU/IPU */ -DATA 4 0x020e0010 0xF00000CF -/* set IPU AXI-id0 Qos=0xf(bypass) AXI-id1 Qos=0x7 */ -DATA 4 0x020e0018 0x007F007F -DATA 4 0x020e001c 0x007F007F
/* * Setup CCM_CCOSR register as follows: diff --git a/board/bachmann/ot1200/ot1200.c b/board/bachmann/ot1200/ot1200.c index 039e858..6b6c1a3 100644 --- a/board/bachmann/ot1200/ot1200.c +++ b/board/bachmann/ot1200/ot1200.c @@ -6,6 +6,7 @@ */
#include <common.h> +#include <asm/io.h> #include <asm/arch/clock.h> #include <asm/arch/imx-regs.h> #include <asm/arch/iomux.h> @@ -119,8 +120,35 @@ static void setup_iomux_features(void) ARRAY_SIZE(feature_pads)); }
+static void ccgr_init(void) +{ + struct mxc_ccm_reg *ccm = (struct mxc_ccm_reg *)CCM_BASE_ADDR; + + writel(0x00C03F3F, &ccm->CCGR0); + writel(0x0030FC03, &ccm->CCGR1); + writel(0x0FFFC000, &ccm->CCGR2); + writel(0x3FF00000, &ccm->CCGR3); + writel(0x00FFF300, &ccm->CCGR4); + writel(0x0F0000C3, &ccm->CCGR5); + writel(0x000003FF, &ccm->CCGR6); +} + +static void gpr_init(void) +{ + struct iomuxc *iomux = (struct iomuxc *)IOMUXC_BASE_ADDR; + + /* enable AXI cache for VDOA/VPU/IPU */ + writel(0xF00000CF, &iomux->gpr[4]); + /* set IPU AXI-id0 Qos=0xf(bypass) AXI-id1 Qos=0x7 */ + writel(0x007F007F, &iomux->gpr[6]); + writel(0x007F007F, &iomux->gpr[7]); +} + int board_early_init_f(void) { + ccgr_init(); + gpr_init(); + setup_iomux_uart(); setup_iomux_spi(); setup_iomux_features();
Signed-off-by: Christian Gmeiner christian.gmeiner@gmail.com --- board/bachmann/ot1200/ot1200.c | 5 +---- 1 file changed, 1 insertion(+), 4 deletions(-)
diff --git a/board/bachmann/ot1200/ot1200.c b/board/bachmann/ot1200/ot1200.c index 6b6c1a3..e434ed9 100644 --- a/board/bachmann/ot1200/ot1200.c +++ b/board/bachmann/ot1200/ot1200.c @@ -125,7 +125,7 @@ static void ccgr_init(void) struct mxc_ccm_reg *ccm = (struct mxc_ccm_reg *)CCM_BASE_ADDR;
writel(0x00C03F3F, &ccm->CCGR0); - writel(0x0030FC03, &ccm->CCGR1); + writel(0x0030FC33, &ccm->CCGR1); writel(0x0FFFC000, &ccm->CCGR2); writel(0x3FF00000, &ccm->CCGR3); writel(0x00FFF300, &ccm->CCGR4); @@ -319,9 +319,6 @@ int board_init(void)
leds_on();
- /* enable ecspi3 clocks */ - enable_cspi_clock(1, 2); - #ifdef CONFIG_CMD_SATA setup_sata(); #endif
We will only support loading u-boot.img from SPI flash stored at the offset of 64k.
Signed-off-by: Christian Gmeiner christian.gmeiner@gmail.com --- include/configs/ot1200.h | 10 ++++++++++ 1 file changed, 10 insertions(+)
diff --git a/include/configs/ot1200.h b/include/configs/ot1200.h index 97ee664..c061e93 100644 --- a/include/configs/ot1200.h +++ b/include/configs/ot1200.h @@ -108,6 +108,16 @@ #endif
+/* SPL */ +#ifdef CONFIG_SPL +#include "imx6_spl.h" +#define CONFIG_SPL_SPI_SUPPORT +#define CONFIG_SPL_LIBCOMMON_SUPPORT +#define CONFIG_SPL_SPI_FLASH_SUPPORT +#define CONFIG_SYS_SPI_U_BOOT_OFFS (64 * 1024) +#define CONFIG_SPL_SPI_LOAD +#endif + #define CONFIG_CMD_PING #define CONFIG_CMD_DHCP #define CONFIG_CMD_MII
Currently we only support the Micron MT41K128M16JT-125 ddr3 chip.
Signed-off-by: Christian Gmeiner christian.gmeiner@gmail.com --- board/bachmann/ot1200/Makefile | 4 + board/bachmann/ot1200/ot1200_spl.c | 162 +++++++++++++++++++++++++++++++++++++ 2 files changed, 166 insertions(+) create mode 100644 board/bachmann/ot1200/ot1200_spl.c
diff --git a/board/bachmann/ot1200/Makefile b/board/bachmann/ot1200/Makefile index 1bd42e8..9e50bfe 100644 --- a/board/bachmann/ot1200/Makefile +++ b/board/bachmann/ot1200/Makefile @@ -6,4 +6,8 @@ # SPDX-License-Identifier: GPL-2.0+ #
+ifdef CONFIG_SPL_BUILD +obj-y := ot1200.o ot1200_spl.o +else obj-y := ot1200.o +endif diff --git a/board/bachmann/ot1200/ot1200_spl.c b/board/bachmann/ot1200/ot1200_spl.c new file mode 100644 index 0000000..9c77fd3 --- /dev/null +++ b/board/bachmann/ot1200/ot1200_spl.c @@ -0,0 +1,162 @@ +/* + * Copyright (C) 2015, Bachmann electronic GmbH + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <spl.h> +#include <asm/arch/mx6-ddr.h> + +DECLARE_GLOBAL_DATA_PTR; + +/* Configure MX6Q/DUAL mmdc DDR io registers */ +static struct mx6dq_iomux_ddr_regs ot1200_ddr_ioregs = { + /* SDCLK[0:1], CAS, RAS, Reset: Differential input, 48ohm */ + .dram_sdclk_0 = 0x00000028, + .dram_sdclk_1 = 0x00000028, + .dram_cas = 0x00000028, + .dram_ras = 0x00000028, + .dram_reset = 0x00000028, + /* SDCKE[0:1]: 100k pull-up */ + .dram_sdcke0 = 0x00003000, + .dram_sdcke1 = 0x00003000, + /* SDBA2: pull-up disabled */ + .dram_sdba2 = 0x00000000, + /* SDODT[0:1]: 100k pull-up, 48 ohm */ + .dram_sdodt0 = 0x00000028, + .dram_sdodt1 = 0x00000028, + /* SDQS[0:7]: Differential input, 48 ohm */ + .dram_sdqs0 = 0x00000028, + .dram_sdqs1 = 0x00000028, + .dram_sdqs2 = 0x00000028, + .dram_sdqs3 = 0x00000028, + .dram_sdqs4 = 0x00000028, + .dram_sdqs5 = 0x00000028, + .dram_sdqs6 = 0x00000028, + .dram_sdqs7 = 0x00000028, + /* DQM[0:7]: Differential input, 48 ohm */ + .dram_dqm0 = 0x00000028, + .dram_dqm1 = 0x00000028, + .dram_dqm2 = 0x00000028, + .dram_dqm3 = 0x00000028, + .dram_dqm4 = 0x00000028, + .dram_dqm5 = 0x00000028, + .dram_dqm6 = 0x00000028, + .dram_dqm7 = 0x00000028, +}; + +/* Configure MX6Q/DUAL mmdc GRP io registers */ +static struct mx6dq_iomux_grp_regs ot1200_grp_ioregs = { + /* DDR3 */ + .grp_ddr_type = 0x000c0000, + .grp_ddrmode_ctl = 0x00020000, + /* Disable DDR pullups */ + .grp_ddrpke = 0x00000000, + /* ADDR[00:16], SDBA[0:1]: 48 ohm */ + .grp_addds = 0x00000028, + /* CS0/CS1/SDBA2/CKE0/CKE1/SDWE: 48 ohm */ + .grp_ctlds = 0x00000028, + /* DATA[00:63]: Differential input, 48 ohm */ + .grp_ddrmode = 0x00020000, + .grp_b0ds = 0x00000028, + .grp_b1ds = 0x00000028, + .grp_b2ds = 0x00000028, + .grp_b3ds = 0x00000028, + .grp_b4ds = 0x00000028, + .grp_b5ds = 0x00000028, + .grp_b6ds = 0x00000028, + .grp_b7ds = 0x00000028, +}; + +static struct mx6_ddr_sysinfo ot1200_ddr_sysinfo = { + /* Width of data bus: 0=16, 1=32, 2=64 */ + .dsize = 2, + /* config for full 4GB range so that get_mem_size() works */ + .cs_density = 32, /* 32Gb per CS */ + /* Single chip select */ + .ncs = 1, + .cs1_mirror = 0, /* war 0 */ + .rtt_wr = 1, /* DDR3_RTT_60_OHM - RTT_Wr = RZQ/4 */ + .rtt_nom = 1, /* DDR3_RTT_60_OHM - RTT_Nom = RZQ/4 */ + .walat = 1, /* Write additional latency */ + .ralat = 5, /* Read additional latency */ + .mif3_mode = 3, /* Command prediction working mode */ + .bi_on = 1, /* Bank interleaving enabled */ /* war 1 */ + .sde_to_rst = 0x10, /* 14 cycles, 200us (JEDEC default) */ + .rst_to_cke = 0x23, /* 33 cycles, 500us (JEDEC default) */ +}; + +/* MT41K128M16JT-125 */ +static struct mx6_ddr3_cfg micron_2gib_1600 = { + .mem_speed = 1600, + .density = 2, + .width = 16, + .banks = 8, + .rowaddr = 14, + .coladdr = 10, + .pagesz = 2, + .trcd = 1375, + .trcmin = 4875, + .trasmin = 3500, + .SRT = 1, +}; + +static struct mx6_mmdc_calibration micron_2gib_1600_mmdc_calib = { + /* write leveling calibration determine */ + .p0_mpwldectrl0 = 0x00260025, + .p0_mpwldectrl1 = 0x00270021, + .p1_mpwldectrl0 = 0x00180034, + .p1_mpwldectrl1 = 0x00180024, + /* Read DQS Gating calibration */ + .p0_mpdgctrl0 = 0x04380344, + .p0_mpdgctrl1 = 0x0330032C, + .p1_mpdgctrl0 = 0x0338033C, + .p1_mpdgctrl1 = 0x032C0300, + /* Read Calibration: DQS delay relative to DQ read access */ + .p0_mprddlctl = 0x3C2E3238, + .p1_mprddlctl = 0x3A2E303C, + /* Write Calibration: DQ/DM delay relative to DQS write access */ + .p0_mpwrdlctl = 0x36384036, + .p1_mpwrdlctl = 0x442E4438, +}; + +static void ot1200_spl_dram_init(void) +{ + mx6dq_dram_iocfg(64, &ot1200_ddr_ioregs, &ot1200_grp_ioregs); + mx6_dram_cfg(&ot1200_ddr_sysinfo, µn_2gib_1600_mmdc_calib, + µn_2gib_1600); +} + +/* + * called from C runtime startup code (arch/arm/lib/crt0.S:_main) + * - we have a stack and a place to store GD, both in SRAM + * - no variable global data is available + */ +void board_init_f(ulong dummy) +{ + /* setup AIPS and disable watchdog */ + arch_cpu_init(); + + /* iomux and setup of i2c */ + board_early_init_f(); + + /* setup GP timer */ + timer_init(); + + /* UART clocks enabled and gd valid - init serial console */ + preloader_console_init(); + + /* configure MMDC for SDRAM width/size and per-model calibration */ + ot1200_spl_dram_init(); + + /* Clear the BSS. */ + memset(__bss_start, 0, __bss_end - __bss_start); + + /* load/boot image from boot device */ + board_init_r(NULL, 0); +} + +void reset_cpu(ulong addr) +{ +}
Signed-off-by: Christian Gmeiner christian.gmeiner@gmail.com --- configs/ot1200_spl_defconfig | 4 ++++ 1 file changed, 4 insertions(+) create mode 100644 configs/ot1200_spl_defconfig
diff --git a/configs/ot1200_spl_defconfig b/configs/ot1200_spl_defconfig new file mode 100644 index 0000000..74ebf85 --- /dev/null +++ b/configs/ot1200_spl_defconfig @@ -0,0 +1,4 @@ +CONFIG_SPL=y +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,MX6Q" ++S:CONFIG_ARM=y ++S:CONFIG_TARGET_OT1200=y \ No newline at end of file
Hi Christian,
The series looks ok to me - ready to be merged.
Acked-by: Stefano Babic sbabic@denx.de#
Christian Gmeiner
Stefano Babic
