[PATCH] arm: kirkwood: sheevaplug: reduce u-boot image size
Sheevaplug board has 512K CONFIG_BOARD_SIZE_LIMIT. Recently, DM_SERIAL has pushed the image size a few hundred bytes over that limit. So explicitly deselect some configs that are unrelated to this board (and gain back a bit over 2K).
Signed-off-by: Tony Dinh mibodhi@gmail.com ---
configs/sheevaplug_defconfig | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/configs/sheevaplug_defconfig b/configs/sheevaplug_defconfig index cb38a3fbd5..40ab16dfa0 100644 --- a/configs/sheevaplug_defconfig +++ b/configs/sheevaplug_defconfig @@ -26,6 +26,11 @@ CONFIG_USE_PREBOOT=y CONFIG_HUSH_PARSER=y CONFIG_SYS_MAXARGS=32 CONFIG_CMD_BOOTZ=y +# CONFIG_BOOTM_PLAN9 is not set +# CONFIG_BOOTM_RTEMS is not set +# CONFIG_BOOTM_VXWORKS is not set +# CONFIG_CMD_IMI is not set +# CONFIG_CMD_XIMG is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_MMC=y CONFIG_CMD_NAND=y
Applied to u-boot-marvell/master
Thanks, Stefan
Viele Grüße, Stefan Roese
Stefan Roese
Tony Dinh
