Re: [U-Boot] [PATCH v2] powerpc/t2080: CPU erratum A-007907
26 Oct
2016
26 Oct
'16
6:25 p.m.
On 10/24/2016 02:16 PM, york.sun@nxp.com wrote:
+#ifdef CONFIG_SYS_FSL_ERRATUM_A007907
- flush_dcache();
- mtspr(L1CSR2, (mfspr(L1CSR2) & ~L1CSR2_DCSTASHID));
- sync();
My erratum document shows a second step is to insert sync instruction before each dcbtls CT=0 or dcbtstls CT=0. I only see dcbtls used in start.S and no referendce to dcbtstls at all. I will consult the design team to confirm if the second step.
I got feedback from our design team. The second step is a must if these instructions are used. However, we don't hit either in U-Boot. Please be advised, if you have other code using dcbtls or dcbtstls with CT=0, you need to implement the 2nd step, i.e. proceed with a sync instruction.
York
3117
york sun
