[PATCH] net: phy: dp83867: Clean force link good bit
On Xilinx ZynqMP revA board initial value of PHYCR register is 0x5448 which means FORCE_LINK_GOOD is already setup. Origin code was doing write but the new code is doing read/modify/write and keep this bit untouched. That's why ethernet stop to work. The patch is cleaning this bit when PHYCR value is composed.
Tested on Xilinx zcu102-revA and zcu104-rev1.0 boards.
Fixes: 37d6265f2bfa ("net: phy: dp83867: refactor rgmii configuration") Signed-off-by: Michal Simek michal.simek@xilinx.com ---
drivers/net/phy/dp83867.c | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/drivers/net/phy/dp83867.c b/drivers/net/phy/dp83867.c index a43793cd4274..4d796e289c45 100644 --- a/drivers/net/phy/dp83867.c +++ b/drivers/net/phy/dp83867.c @@ -64,6 +64,7 @@ #define DP83867_PHYCR_FIFO_DEPTH_SHIFT 14 #define DP83867_PHYCR_FIFO_DEPTH_MASK GENMASK(15, 14) #define DP83867_PHYCR_RESERVED_MASK BIT(11) +#define DP83867_PHYCR_FORCE_LINK_GOOD BIT(10) #define DP83867_MDI_CROSSOVER 5 #define DP83867_MDI_CROSSOVER_MDIX 2 #define DP83867_PHYCTRL_SGMIIEN 0x0800 @@ -283,6 +284,9 @@ static int dp83867_config(struct phy_device *phydev) val &= ~DP83867_PHYCR_FIFO_DEPTH_MASK; val |= (dp83867->fifo_depth << DP83867_PHYCR_FIFO_DEPTH_SHIFT);
+ /* Do not force link good */ + val &= ~DP83867_PHYCR_FORCE_LINK_GOOD; + /* The code below checks if "port mirroring" N/A MODE4 has been * enabled during power on bootstrap. *
Reviewed-by: Grygorii Strashko grygorii.strashko@ti.com
- /* The code below checks if "port mirroring" N/A MODE4 has been
- enabled during power on bootstrap.
čt 6. 2. 2020 v 16:03 odesílatel Michal Simek michal.simek@xilinx.com napsal:
-- 2.25.0
Applied. M
Grygorii Strashko
Michal Simek
Michal Simek
