[U-Boot] [PATCH 0/8] usb: Add support for Cadence USB controller driver
This series adds support for Cadence USB Host and Gadget controller drivers. This is borrowed directly from Linux kernel v5.4-rc1. Driver as such supports both 3.0 and 2.0 speeds. But USB 3.0 requires a PHY driver which will be added in a separate follow series
Patch 7 adds TI wrapper driver for Cadence USB controller.
Both host and device mode has been tested on TI's J721e SoC. DFU, UMS and fastboot gadgets have been tested.
Complete series (+ DT nodes required for J721e) can be found here: https://github.com/r-vignesh/u-boot.git branch: usb
Regards Vignesh
Sherry Sun (1): usb: udc: Introduce ->udc_set_speed() method
Vignesh Raghavendra (7): list: import list_first_entry_or_null() bitmaps: import for_each_set_bit() macro usb: gadget: Add match_ep() op to usb_gadget_ops usb: Add Cadence USB3 host and gadget driver usb: cdns3: gadget: Implement udc_set_speed() callback usb: cdns3: Add TI wrapper driver for CDNS USB3 controller usb: gadget: Add gadget_is_cdns3() macro
Makefile | 1 + drivers/usb/Kconfig | 2 + drivers/usb/cdns3/Kconfig | 58 + drivers/usb/cdns3/Makefile | 11 + drivers/usb/cdns3/cdns3-ti.c | 193 ++ drivers/usb/cdns3/core.c | 498 ++++++ drivers/usb/cdns3/core.h | 108 ++ drivers/usb/cdns3/debug.h | 162 ++ drivers/usb/cdns3/drd.c | 301 ++++ drivers/usb/cdns3/drd.h | 166 ++ drivers/usb/cdns3/ep0.c | 910 ++++++++++ drivers/usb/cdns3/gadget-export.h | 28 + drivers/usb/cdns3/gadget.c | 2760 +++++++++++++++++++++++++++++ drivers/usb/cdns3/gadget.h | 1338 ++++++++++++++ drivers/usb/cdns3/host-export.h | 28 + drivers/usb/cdns3/host.c | 55 + drivers/usb/cdns3/trace.c | 11 + drivers/usb/cdns3/trace.h | 26 + drivers/usb/gadget/epautoconf.c | 3 + drivers/usb/gadget/gadget_chips.h | 8 + drivers/usb/gadget/udc/udc-core.c | 23 + include/linux/bitmap.h | 61 + include/linux/list.h | 14 + include/linux/usb/gadget.h | 25 + scripts/Makefile.spl | 1 + 25 files changed, 6791 insertions(+) create mode 100644 drivers/usb/cdns3/Kconfig create mode 100644 drivers/usb/cdns3/Makefile create mode 100644 drivers/usb/cdns3/cdns3-ti.c create mode 100644 drivers/usb/cdns3/core.c create mode 100644 drivers/usb/cdns3/core.h create mode 100644 drivers/usb/cdns3/debug.h create mode 100644 drivers/usb/cdns3/drd.c create mode 100644 drivers/usb/cdns3/drd.h create mode 100644 drivers/usb/cdns3/ep0.c create mode 100644 drivers/usb/cdns3/gadget-export.h create mode 100644 drivers/usb/cdns3/gadget.c create mode 100644 drivers/usb/cdns3/gadget.h create mode 100644 drivers/usb/cdns3/host-export.h create mode 100644 drivers/usb/cdns3/host.c create mode 100644 drivers/usb/cdns3/trace.c create mode 100644 drivers/usb/cdns3/trace.h
Import list_first_entry_or_null() macro from Linux that would be used by Cadence USB driver
Signed-off-by: Vignesh Raghavendra vigneshr@ti.com --- include/linux/list.h | 14 ++++++++++++++ 1 file changed, 14 insertions(+)
diff --git a/include/linux/list.h b/include/linux/list.h index 5b8d1df5dfee..f62afa092c63 100644 --- a/include/linux/list.h +++ b/include/linux/list.h @@ -348,6 +348,20 @@ static inline void list_splice_tail_init(struct list_head *list, #define list_last_entry(ptr, type, member) \ list_entry((ptr)->prev, type, member)
+/** + * list_first_entry_or_null - get the first element from a list + * @ptr: the list head to take the element from. + * @type: the type of the struct this is embedded in. + * @member: the name of the list_head within the struct. + * + * Note that if the list is empty, it returns NULL. + */ +#define list_first_entry_or_null(ptr, type, member) ({ \ + struct list_head *head__ = (ptr); \ + struct list_head *pos__ = READ_ONCE(head__->next); \ + pos__ != head__ ? list_entry(pos__, type, member) : NULL; \ +}) + /** * list_for_each - iterate over a list * @pos: the &struct list_head to use as a loop cursor.
Import for_each_set_bit() and associated macros and functions from Linux. This is useful in parsing interrupt registers and take action on each bit that is set.
Signed-off-by: Vignesh Raghavendra vigneshr@ti.com --- include/linux/bitmap.h | 61 ++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 61 insertions(+)
diff --git a/include/linux/bitmap.h b/include/linux/bitmap.h index 4a54ae050912..fbbb67c8b24e 100644 --- a/include/linux/bitmap.h +++ b/include/linux/bitmap.h @@ -20,4 +20,65 @@ static inline void bitmap_zero(unsigned long *dst, int nbits) } }
+static inline unsigned long +find_next_bit(const unsigned long *addr, unsigned long size, + unsigned long offset) +{ + const unsigned long *p = addr + BIT_WORD(offset); + unsigned long result = offset & ~(BITS_PER_LONG - 1); + unsigned long tmp; + + if (offset >= size) + return size; + size -= result; + offset %= BITS_PER_LONG; + if (offset) { + tmp = *(p++); + tmp &= (~0UL << offset); + if (size < BITS_PER_LONG) + goto found_first; + if (tmp) + goto found_middle; + size -= BITS_PER_LONG; + result += BITS_PER_LONG; + } + while (size & ~(BITS_PER_LONG - 1)) { + tmp = *(p++); + if ((tmp)) + goto found_middle; + result += BITS_PER_LONG; + size -= BITS_PER_LONG; + } + if (!size) + return result; + tmp = *p; + +found_first: + tmp &= (~0UL >> (BITS_PER_LONG - size)); + if (tmp == 0UL) /* Are any bits set? */ + return result + size; /* Nope. */ +found_middle: + return result + __ffs(tmp); +} + +/* + * Find the first set bit in a memory region. + */ +static inline unsigned long find_first_bit(const unsigned long *addr, unsigned long size) +{ + unsigned long idx; + + for (idx = 0; idx * BITS_PER_LONG < size; idx++) { + if (addr[idx]) + return min(idx * BITS_PER_LONG + __ffs(addr[idx]), size); + } + + return size; +} + +#define for_each_set_bit(bit, addr, size) \ + for ((bit) = find_first_bit((addr), (size)); \ + (bit) < (size); \ + (bit) = find_next_bit((addr), (size), (bit) + 1)) + #endif /* __LINUX_BITMAP_H */
Add match_ep() op to usb_gadget_ops similar to Linux kernel which is useful in finding a suitable ep match for the function driver. This will avoid adding more gadget_is_xxx() handling code to usb_ep_autoconfig().
Also sync usb_ep_caps struct thats is usually used in the match_ep() callback by the gadget controller driver
Signed-off-by: Vignesh Raghavendra vigneshr@ti.com --- drivers/usb/gadget/epautoconf.c | 3 +++ include/linux/usb/gadget.h | 23 +++++++++++++++++++++++ 2 files changed, 26 insertions(+)
diff --git a/drivers/usb/gadget/epautoconf.c b/drivers/usb/gadget/epautoconf.c index 179b94cdd0ae..e61fe5d11445 100644 --- a/drivers/usb/gadget/epautoconf.c +++ b/drivers/usb/gadget/epautoconf.c @@ -282,6 +282,9 @@ struct usb_ep *usb_ep_autoconfig( return ep; }
+ if (gadget->ops->match_ep) + ep = gadget->ops->match_ep(gadget, desc, NULL); + /* Second, look at endpoints until an unclaimed one looks usable */ list_for_each_entry(ep, &gadget->ep_list, ep_list) { if (ep_matches(gadget, ep, desc)) diff --git a/include/linux/usb/gadget.h b/include/linux/usb/gadget.h index 497798a32a87..7dba61bac131 100644 --- a/include/linux/usb/gadget.h +++ b/include/linux/usb/gadget.h @@ -129,11 +129,30 @@ struct usb_ep_ops { void (*fifo_flush) (struct usb_ep *ep); };
+/** + * struct usb_ep_caps - endpoint capabilities description + * @type_control:Endpoint supports control type (reserved for ep0). + * @type_iso:Endpoint supports isochronous transfers. + * @type_bulk:Endpoint supports bulk transfers. + * @type_int:Endpoint supports interrupt transfers. + * @dir_in:Endpoint supports IN direction. + * @dir_out:Endpoint supports OUT direction. + */ +struct usb_ep_caps { + unsigned type_control:1; + unsigned type_iso:1; + unsigned type_bulk:1; + unsigned type_int:1; + unsigned dir_in:1; + unsigned dir_out:1; +}; + /** * struct usb_ep - device side representation of USB endpoint * @name:identifier for the endpoint, such as "ep-a" or "ep9in-bulk" * @ops: Function pointers used to access hardware-specific operations. * @ep_list:the gadget's ep_list holds all of its endpoints + * @caps:The structure describing types and directions supported by endoint. * @maxpacket:The maximum packet size used on this endpoint. The initial * value can sometimes be reduced (hardware allowing), according to * the endpoint descriptor used to configure the endpoint. @@ -159,6 +178,7 @@ struct usb_ep { const char *name; const struct usb_ep_ops *ops; struct list_head ep_list; + struct usb_ep_caps caps; unsigned maxpacket:16; unsigned maxpacket_limit:16; unsigned max_streams:16; @@ -447,6 +467,9 @@ struct usb_gadget_ops { int (*udc_start)(struct usb_gadget *, struct usb_gadget_driver *); int (*udc_stop)(struct usb_gadget *); + struct usb_ep *(*match_ep)(struct usb_gadget *, + struct usb_endpoint_descriptor *, + struct usb_ss_ep_comp_descriptor *); };
This patch was copied from kernel commit: 67fdfda4a99ed.
Sometimes, the gadget driver we want to run has max_speed lower than what the UDC supports. In such situations, UDC might want to make sure we don't try to connect on speeds not supported by the gadget driver because that will just fail.
So here introduce a new optional ->udc_set_speed() method which can be implemented by interested UDC drivers to achieve this purpose.
Signed-off-by: Sherry Sun sherry.sun@nxp.com Signed-off-by: Vignesh Raghavendra vigneshr@ti.com --- drivers/usb/gadget/udc/udc-core.c | 23 +++++++++++++++++++++++ include/linux/usb/gadget.h | 2 ++ 2 files changed, 25 insertions(+)
diff --git a/drivers/usb/gadget/udc/udc-core.c b/drivers/usb/gadget/udc/udc-core.c index 62b47781ddcc..8d1d90e3e39f 100644 --- a/drivers/usb/gadget/udc/udc-core.c +++ b/drivers/usb/gadget/udc/udc-core.c @@ -267,6 +267,27 @@ EXPORT_SYMBOL_GPL(usb_del_gadget_udc);
+/** + * usb_gadget_udc_set_speed - tells usb device controller speed supported by + * current driver + * @udc: The device we want to set maximum speed + * @speed: The maximum speed to allowed to run + * + * This call is issued by the UDC Class driver before calling + * usb_gadget_udc_start() in order to make sure that we don't try to + * connect on speeds the gadget driver doesn't support. + */ +static inline void usb_gadget_udc_set_speed(struct usb_udc *udc, + enum usb_device_speed speed) +{ + if (udc->gadget->ops->udc_set_speed) { + enum usb_device_speed s; + + s = min(speed, udc->gadget->max_speed); + udc->gadget->ops->udc_set_speed(udc->gadget, s); + } +} + static int udc_bind_to_driver(struct usb_udc *udc, struct usb_gadget_driver *driver) { int ret; @@ -276,6 +297,8 @@ static int udc_bind_to_driver(struct usb_udc *udc, struct usb_gadget_driver *dri
udc->driver = driver;
+ usb_gadget_udc_set_speed(udc, driver->speed); + ret = driver->bind(udc->gadget); if (ret) goto err1; diff --git a/include/linux/usb/gadget.h b/include/linux/usb/gadget.h index 7dba61bac131..66794d7894f6 100644 --- a/include/linux/usb/gadget.h +++ b/include/linux/usb/gadget.h @@ -470,6 +470,8 @@ struct usb_gadget_ops { struct usb_ep *(*match_ep)(struct usb_gadget *, struct usb_endpoint_descriptor *, struct usb_ss_ep_comp_descriptor *); + void (*udc_set_speed)(struct usb_gadget *gadget, + enum usb_device_speed); };
Add support for USB3 host and gadget driver. This is a direct sync of Linux kernel Cadence USB stack that from v5.4-rc1 release. Driver has been modified so that it compiles without errors against U-Boot code base. Features not required for U-Boot such as scatter-gather DMA and OTG interrupt handling has been dropped.
Signed-off-by: Jean-Jacques Hiblot jjhiblot@ti.com [jjhiblot@ti.com: Add PHY support] Signed-off-by: Vignesh Raghavendra vigneshr@ti.com --- Makefile | 1 + drivers/usb/Kconfig | 2 + drivers/usb/cdns3/Kconfig | 51 + drivers/usb/cdns3/Makefile | 9 + drivers/usb/cdns3/core.c | 498 ++++++ drivers/usb/cdns3/core.h | 108 ++ drivers/usb/cdns3/debug.h | 162 ++ drivers/usb/cdns3/drd.c | 301 ++++ drivers/usb/cdns3/drd.h | 166 ++ drivers/usb/cdns3/ep0.c | 910 ++++++++++ drivers/usb/cdns3/gadget-export.h | 28 + drivers/usb/cdns3/gadget.c | 2738 +++++++++++++++++++++++++++++ drivers/usb/cdns3/gadget.h | 1338 ++++++++++++++ drivers/usb/cdns3/host-export.h | 28 + drivers/usb/cdns3/host.c | 55 + drivers/usb/cdns3/trace.c | 11 + drivers/usb/cdns3/trace.h | 26 + scripts/Makefile.spl | 1 + 18 files changed, 6433 insertions(+) create mode 100644 drivers/usb/cdns3/Kconfig create mode 100644 drivers/usb/cdns3/Makefile create mode 100644 drivers/usb/cdns3/core.c create mode 100644 drivers/usb/cdns3/core.h create mode 100644 drivers/usb/cdns3/debug.h create mode 100644 drivers/usb/cdns3/drd.c create mode 100644 drivers/usb/cdns3/drd.h create mode 100644 drivers/usb/cdns3/ep0.c create mode 100644 drivers/usb/cdns3/gadget-export.h create mode 100644 drivers/usb/cdns3/gadget.c create mode 100644 drivers/usb/cdns3/gadget.h create mode 100644 drivers/usb/cdns3/host-export.h create mode 100644 drivers/usb/cdns3/host.c create mode 100644 drivers/usb/cdns3/trace.c create mode 100644 drivers/usb/cdns3/trace.h
diff --git a/Makefile b/Makefile index 1d9ade948bab..793f255098f1 100644 --- a/Makefile +++ b/Makefile @@ -728,6 +728,7 @@ libs-$(CONFIG_SYS_FSL_DDR) += drivers/ddr/fsl/ libs-$(CONFIG_SYS_FSL_MMDC) += drivers/ddr/fsl/ libs-$(CONFIG_$(SPL_)ALTERA_SDRAM) += drivers/ddr/altera/ libs-y += drivers/serial/ +libs-y += drivers/usb/cdns3/ libs-y += drivers/usb/dwc3/ libs-y += drivers/usb/common/ libs-y += drivers/usb/emul/ diff --git a/drivers/usb/Kconfig b/drivers/usb/Kconfig index 3b53bf2c58a1..9af78e88226a 100644 --- a/drivers/usb/Kconfig +++ b/drivers/usb/Kconfig @@ -68,6 +68,8 @@ config SPL_DM_USB_GADGET
source "drivers/usb/host/Kconfig"
+source "drivers/usb/cdns3/Kconfig" + source "drivers/usb/dwc3/Kconfig"
source "drivers/usb/musb/Kconfig" diff --git a/drivers/usb/cdns3/Kconfig b/drivers/usb/cdns3/Kconfig new file mode 100644 index 000000000000..25c0f103e742 --- /dev/null +++ b/drivers/usb/cdns3/Kconfig @@ -0,0 +1,51 @@ +config USB_CDNS3 + tristate "Cadence USB3 Dual-Role Controller" + depends on USB_HOST || USB_GADGET + help + Say Y here if your system has a Cadence USB3 dual-role controller. + It supports: Host-only, and Peripheral-only. + +if USB_CDNS3 + +config USB_CDNS3_GADGET + bool "Cadence USB3 device controller" + depends on USB_GADGET + select USB_GADGET_DUALSPEED + help + Say Y here to enable device controller functionality of the + Cadence USBSS-DEV driver. + + This controller supports FF and HS mode. It doesn't support + LS and SSP mode. + +config USB_CDNS3_HOST + bool "Cadence USB3 host controller" + depends on USB_XHCI_HCD + help + Say Y here to enable host controller functionality of the + Cadence driver. + + Host controller is compliant with XHCI so it will use + standard XHCI driver. + +config SPL_USB_CDNS3_GADGET + bool "SPL support for Cadence USB3 device controller" + depends on SPL_USB_GADGET + select USB_GADGET_DUALSPEED + help + Say Y here to enable device controller functionality of the + Cadence USBSS-DEV driver in SPL. + + This controller supports FF and HS mode. It doesn't support + LS and SSP mode. + +config SPL_USB_CDNS3_HOST + bool "Cadence USB3 host controller" + depends on USB_XHCI_HCD && SPL_USB_HOST_SUPPORT + help + Say Y here to enable host controller functionality of the + Cadence driver. + + Host controller is compliant with XHCI so it will use + standard XHCI driver. +endif diff --git a/drivers/usb/cdns3/Makefile b/drivers/usb/cdns3/Makefile new file mode 100644 index 000000000000..525477954dd8 --- /dev/null +++ b/drivers/usb/cdns3/Makefile @@ -0,0 +1,9 @@ +# SPDX-License-Identifier: GPL-2.0 + +cdns3-y := core.o drd.o + +obj-$(CONFIG_USB_CDNS3) += cdns3.o + +cdns3-$(CONFIG_$(SPL_)USB_CDNS3_GADGET) += gadget.o ep0.o + +cdns3-$(CONFIG_$(SPL_)USB_CDNS3_HOST) += host.o diff --git a/drivers/usb/cdns3/core.c b/drivers/usb/cdns3/core.c new file mode 100644 index 000000000000..f1e4bb627815 --- /dev/null +++ b/drivers/usb/cdns3/core.c @@ -0,0 +1,498 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Cadence USBSS DRD Driver. + * + * Copyright (C) 2018-2019 Cadence. + * Copyright (C) 2017-2018 NXP + * Copyright (C) 2019 Texas Instruments + * + * Author: Peter Chen peter.chen@nxp.com + * Pawel Laszczak pawell@cadence.com + * Roger Quadros rogerq@ti.com + */ + +#include <common.h> +#include <dm.h> +#include <dm/device-internal.h> +#include <dm/lists.h> +#include <linux/kernel.h> +#include <linux/io.h> +#include <usb.h> +#include "../host/xhci.h" + +#include "core.h" +#include "host-export.h" +#include "gadget-export.h" +#include "drd.h" + +static int cdns3_idle_init(struct cdns3 *cdns); + +struct cdns3_host_priv { + struct xhci_ctrl xhci_ctrl; + struct cdns3 cdns; +}; + +struct cdns3_gadget_priv { + struct cdns3 cdns; +}; + +static inline +struct cdns3_role_driver *cdns3_get_current_role_driver(struct cdns3 *cdns) +{ + WARN_ON(!cdns->roles[cdns->role]); + return cdns->roles[cdns->role]; +} + +static int cdns3_role_start(struct cdns3 *cdns, enum usb_role role) +{ + int ret; + + if (WARN_ON(role > USB_ROLE_DEVICE)) + return 0; + + mutex_lock(&cdns->mutex); + cdns->role = role; + mutex_unlock(&cdns->mutex); + + if (!cdns->roles[role]) + return -ENXIO; + + if (cdns->roles[role]->state == CDNS3_ROLE_STATE_ACTIVE) + return 0; + + mutex_lock(&cdns->mutex); + ret = cdns->roles[role]->start(cdns); + if (!ret) + cdns->roles[role]->state = CDNS3_ROLE_STATE_ACTIVE; + mutex_unlock(&cdns->mutex); + + return ret; +} + +static void cdns3_role_stop(struct cdns3 *cdns) +{ + enum usb_role role = cdns->role; + + if (WARN_ON(role > USB_ROLE_DEVICE)) + return; + + if (cdns->roles[role]->state == CDNS3_ROLE_STATE_INACTIVE) + return; + + mutex_lock(&cdns->mutex); + cdns->roles[role]->stop(cdns); + cdns->roles[role]->state = CDNS3_ROLE_STATE_INACTIVE; + mutex_unlock(&cdns->mutex); +} + +static void cdns3_exit_roles(struct cdns3 *cdns) +{ + cdns3_role_stop(cdns); + cdns3_drd_exit(cdns); +} + +static enum usb_role cdsn3_hw_role_state_machine(struct cdns3 *cdns); + +/** + * cdns3_core_init_role - initialize role of operation + * @cdns: Pointer to cdns3 structure + * + * Returns 0 on success otherwise negative errno + */ +static int cdns3_core_init_role(struct cdns3 *cdns) +{ + struct udevice *dev = cdns->dev; + enum usb_dr_mode best_dr_mode; + enum usb_dr_mode dr_mode; + int ret = 0; + + dr_mode = usb_get_dr_mode(dev_of_offset(dev)); + cdns->role = USB_ROLE_NONE; + + /* + * If driver can't read mode by means of usb_get_dr_mode function then + * chooses mode according with Kernel configuration. This setting + * can be restricted later depending on strap pin configuration. + */ + if (dr_mode == USB_DR_MODE_UNKNOWN) { + if (IS_ENABLED(CONFIG_USB_CDNS3_HOST) && + IS_ENABLED(CONFIG_USB_CDNS3_GADGET)) + dr_mode = USB_DR_MODE_OTG; + else if (IS_ENABLED(CONFIG_USB_CDNS3_HOST)) + dr_mode = USB_DR_MODE_HOST; + else if (IS_ENABLED(CONFIG_USB_CDNS3_GADGET)) + dr_mode = USB_DR_MODE_PERIPHERAL; + } + + /* + * At this point cdns->dr_mode contains strap configuration. + * Driver try update this setting considering kernel configuration + */ + best_dr_mode = cdns->dr_mode; + + ret = cdns3_idle_init(cdns); + if (ret) + return ret; + + if (dr_mode == USB_DR_MODE_OTG) { + best_dr_mode = cdns->dr_mode; + } else if (cdns->dr_mode == USB_DR_MODE_OTG) { + best_dr_mode = dr_mode; + } else if (cdns->dr_mode != dr_mode) { + dev_err(dev, "Incorrect DRD configuration\n"); + return -EINVAL; + } + + dr_mode = best_dr_mode; + +#if defined(CONFIG_SPL_USB_HOST_SUPPORT) || !defined(CONFIG_SPL_BUILD) + if (dr_mode == USB_DR_MODE_OTG || dr_mode == USB_DR_MODE_HOST) { + ret = cdns3_host_init(cdns); + if (ret) { + dev_err(dev, "Host initialization failed with %d\n", + ret); + goto err; + } + } +#endif + +#if CONFIG_IS_ENABLED(DM_USB_GADGET) + if (dr_mode == USB_DR_MODE_OTG || dr_mode == USB_DR_MODE_PERIPHERAL) { + ret = cdns3_gadget_init(cdns); + if (ret) { + dev_err(dev, "Device initialization failed with %d\n", + ret); + goto err; + } + } +#endif + + cdns->dr_mode = dr_mode; + + ret = cdns3_drd_update_mode(cdns); + if (ret) + goto err; + + if (cdns->dr_mode != USB_DR_MODE_OTG) { + ret = cdns3_hw_role_switch(cdns); + if (ret) + goto err; + } + + return ret; +err: + cdns3_exit_roles(cdns); + return ret; +} + +/** + * cdsn3_hw_role_state_machine - role switch state machine based on hw events + * @cdns: Pointer to controller structure. + * + * Returns next role to be entered based on hw events. + */ +static enum usb_role cdsn3_hw_role_state_machine(struct cdns3 *cdns) +{ + enum usb_role role; + int id, vbus; + + if (cdns->dr_mode != USB_DR_MODE_OTG) + goto not_otg; + + id = cdns3_get_id(cdns); + vbus = cdns3_get_vbus(cdns); + + /* + * Role change state machine + * Inputs: ID, VBUS + * Previous state: cdns->role + * Next state: role + */ + role = cdns->role; + + switch (role) { + case USB_ROLE_NONE: + /* + * Driver treats USB_ROLE_NONE synonymous to IDLE state from + * controller specification. + */ + if (!id) + role = USB_ROLE_HOST; + else if (vbus) + role = USB_ROLE_DEVICE; + break; + case USB_ROLE_HOST: /* from HOST, we can only change to NONE */ + if (id) + role = USB_ROLE_NONE; + break; + case USB_ROLE_DEVICE: /* from GADGET, we can only change to NONE*/ + if (!vbus) + role = USB_ROLE_NONE; + break; + } + + dev_dbg(cdns->dev, "role %d -> %d\n", cdns->role, role); + + return role; + +not_otg: + if (cdns3_is_host(cdns)) + role = USB_ROLE_HOST; + if (cdns3_is_device(cdns)) + role = USB_ROLE_DEVICE; + + return role; +} + +static int cdns3_idle_role_start(struct cdns3 *cdns) +{ + return 0; +} + +static void cdns3_idle_role_stop(struct cdns3 *cdns) +{ + /* Program Lane swap and bring PHY out of RESET */ + generic_phy_reset(&cdns->usb3_phy); +} + +static int cdns3_idle_init(struct cdns3 *cdns) +{ + struct cdns3_role_driver *rdrv; + + rdrv = devm_kzalloc(cdns->dev, sizeof(*rdrv), GFP_KERNEL); + if (!rdrv) + return -ENOMEM; + + rdrv->start = cdns3_idle_role_start; + rdrv->stop = cdns3_idle_role_stop; + rdrv->state = CDNS3_ROLE_STATE_INACTIVE; + rdrv->suspend = NULL; + rdrv->resume = NULL; + rdrv->name = "idle"; + + cdns->roles[USB_ROLE_NONE] = rdrv; + + return 0; +} + +/** + * cdns3_hw_role_switch - switch roles based on HW state + * @cdns3: controller + */ +int cdns3_hw_role_switch(struct cdns3 *cdns) +{ + enum usb_role real_role, current_role; + int ret = 0; + + /* Do nothing if role based on syfs. */ + if (cdns->role_override) + return 0; + + current_role = cdns->role; + real_role = cdsn3_hw_role_state_machine(cdns); + + /* Do nothing if nothing changed */ + if (current_role == real_role) + goto exit; + + cdns3_role_stop(cdns); + + dev_dbg(cdns->dev, "Switching role %d -> %d", current_role, real_role); + + ret = cdns3_role_start(cdns, real_role); + if (ret) { + /* Back to current role */ + dev_err(cdns->dev, "set %d has failed, back to %d\n", + real_role, current_role); + ret = cdns3_role_start(cdns, current_role); + if (ret) + dev_err(cdns->dev, "back to %d failed too\n", + current_role); + } +exit: + return ret; +} + +static int cdns3_probe(struct cdns3 *cdns) +{ + struct udevice *dev = cdns->dev; + int ret; + + cdns->xhci_regs = dev_remap_addr_name(dev, "xhci"); + if (!cdns->xhci_regs) + return -EINVAL; + + cdns->dev_regs = dev_remap_addr_name(dev, "dev"); + if (!cdns->dev_regs) + return -EINVAL; + + mutex_init(&cdns->mutex); + + ret = generic_phy_get_by_name(dev, "cdns3,usb2-phy", &cdns->usb2_phy); + if (ret) + dev_warn(dev, "Unable to get USB2 phy (ret %d)\n", ret); + + ret = generic_phy_init(&cdns->usb2_phy); + if (ret) + return ret; + + ret = generic_phy_get_by_name(dev, "cdns3,usb3-phy", &cdns->usb3_phy); + if (ret) + dev_warn(dev, "Unable to get USB3 phy (ret %d)\n", ret); + + ret = generic_phy_init(&cdns->usb3_phy); + if (ret) + return ret; + + ret = generic_phy_power_on(&cdns->usb2_phy); + if (ret) + return ret; + + ret = generic_phy_power_on(&cdns->usb3_phy); + if (ret) + return ret; + + ret = cdns3_drd_init(cdns); + if (ret) + return ret; + + ret = cdns3_core_init_role(cdns); + if (ret) + return ret; + + dev_dbg(dev, "Cadence USB3 core: probe succeed\n"); + + return 0; +} + +static int cdns3_remove(struct cdns3 *cdns) +{ + cdns3_exit_roles(cdns); + generic_phy_power_off(&cdns->usb2_phy); + generic_phy_power_off(&cdns->usb3_phy); + generic_phy_exit(&cdns->usb2_phy); + generic_phy_exit(&cdns->usb3_phy); + return 0; +} + +static const struct udevice_id cdns3_ids[] = { + { .compatible = "cdns,usb3" }, + { }, +}; + +int cdns3_bind(struct udevice *parent) +{ + int from = dev_of_offset(parent); + const void *fdt = gd->fdt_blob; + enum usb_dr_mode dr_mode; + struct udevice *dev; + const char *driver; + const char *name; + int node; + int ret; + + node = fdt_node_offset_by_compatible(fdt, from, "cdns,usb3"); + if (node < 0) { + ret = -ENODEV; + goto fail; + } + + name = fdt_get_name(fdt, node, NULL); + dr_mode = usb_get_dr_mode(node); + + switch (dr_mode) { +#if defined(CONFIG_SPL_USB_HOST_SUPPORT) || \ + (!defined(CONFIG_SPL_BUILD) && defined(CONFIG_USB_HOST)) + case USB_DR_MODE_HOST: + debug("%s: dr_mode: HOST\n", __func__); + driver = "cdns-usb3-host"; + break; +#endif +#if CONFIG_IS_ENABLED(DM_USB_GADGET) + case USB_DR_MODE_PERIPHERAL: + debug("%s: dr_mode: PERIPHERAL\n", __func__); + driver = "cdns-usb3-peripheral"; + break; +#endif + default: + printf("%s: unsupported dr_mode\n", __func__); + ret = -ENODEV; + goto fail; + }; + + ret = device_bind_driver_to_node(parent, driver, name, + offset_to_ofnode(node), &dev); + if (ret) { + printf("%s: not able to bind usb device mode\n", + __func__); + goto fail; + } + + return 0; + +fail: + /* do not return an error: failing to bind would hang the board */ + return 0; +} + +#if CONFIG_IS_ENABLED(DM_USB_GADGET) +static int cdns3_gadget_probe(struct udevice *dev) +{ + struct cdns3_gadget_priv *priv = dev_get_priv(dev); + struct cdns3 *cdns = &priv->cdns; + + cdns->dev = dev; + + return cdns3_probe(cdns); +} + +static int cdns3_gadget_remove(struct udevice *dev) +{ + struct cdns3_gadget_priv *priv = dev_get_priv(dev); + struct cdns3 *cdns = &priv->cdns; + + return cdns3_remove(cdns); +} + +U_BOOT_DRIVER(cdns_usb3_peripheral) = { + .name = "cdns-usb3-peripheral", + .id = UCLASS_USB_GADGET_GENERIC, + .of_match = cdns3_ids, + .probe = cdns3_gadget_probe, + .remove = cdns3_gadget_remove, + .priv_auto_alloc_size = sizeof(struct cdns3_gadget_priv), + .flags = DM_FLAG_ALLOC_PRIV_DMA, +}; +#endif + +#if defined(CONFIG_SPL_USB_HOST_SUPPORT) || \ + (!defined(CONFIG_SPL_BUILD) && defined(CONFIG_USB_HOST)) +static int cdns3_host_probe(struct udevice *dev) +{ + struct cdns3_host_priv *priv = dev_get_priv(dev); + struct cdns3 *cdns = &priv->cdns; + + cdns->dev = dev; + + return cdns3_probe(cdns); +} + +static int cdns3_host_remove(struct udevice *dev) +{ + struct cdns3_host_priv *priv = dev_get_priv(dev); + struct cdns3 *cdns = &priv->cdns; + + return cdns3_remove(cdns); +} + +U_BOOT_DRIVER(cdns_usb3_host) = { + .name = "cdns-usb3-host", + .id = UCLASS_USB, + .of_match = cdns3_ids, + .probe = cdns3_host_probe, + .remove = cdns3_host_remove, + .priv_auto_alloc_size = sizeof(struct cdns3_host_priv), + .ops = &xhci_usb_ops, + .flags = DM_FLAG_ALLOC_PRIV_DMA, +}; +#endif diff --git a/drivers/usb/cdns3/core.h b/drivers/usb/cdns3/core.h new file mode 100644 index 000000000000..0668d646fc49 --- /dev/null +++ b/drivers/usb/cdns3/core.h @@ -0,0 +1,108 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Cadence USBSS DRD Header File. + * + * Copyright (C) 2017-2018 NXP + * Copyright (C) 2018-2019 Cadence. + * + * Authors: Peter Chen peter.chen@nxp.com + * Pawel Laszczak pawell@cadence.com + */ +#include <linux/compiler.h> +#include <linux/types.h> +#include <linux/usb/otg.h> +#include <generic-phy.h> + +#ifndef __LINUX_CDNS3_CORE_H +#define __LINUX_CDNS3_CORE_H + +enum usb_role { + USB_ROLE_NONE, + USB_ROLE_HOST, + USB_ROLE_DEVICE, +}; + +struct cdns3; + +/** + * struct cdns3_role_driver - host/gadget role driver + * @start: start this role + * @stop: stop this role + * @suspend: suspend callback for this role + * @resume: resume callback for this role + * @irq: irq handler for this role + * @name: role name string (host/gadget) + * @state: current state + */ +struct cdns3_role_driver { + int (*start)(struct cdns3 *cdns); + void (*stop)(struct cdns3 *cdns); + int (*suspend)(struct cdns3 *cdns, bool do_wakeup); + int (*resume)(struct cdns3 *cdns, bool hibernated); + const char *name; +#define CDNS3_ROLE_STATE_INACTIVE 0 +#define CDNS3_ROLE_STATE_ACTIVE 1 + int state; +}; + +#define CDNS3_XHCI_RESOURCES_NUM 2 +/** + * struct cdns3 - Representation of Cadence USB3 DRD controller. + * @dev: pointer to Cadence device struct + * @xhci_regs: pointer to base of xhci registers + * @dev_regs: pointer to base of dev registers + * @otg_v0_regs: pointer to base of v0 otg registers + * @otg_v1_regs: pointer to base of v1 otg registers + * @otg_regs: pointer to base of otg registers + * @otg_irq: irq number for otg controller + * @dev_irq: irq number for device controller + * @roles: array of supported roles for this controller + * @role: current role + * @host_dev: the child host device pointer for cdns3 core + * @gadget_dev: the child gadget device pointer for cdns3 core + * @usb2_phy: pointer to USB2 PHY + * @usb3_phy: pointer to USB3 PHY + * @mutex: the mutex for concurrent code at driver + * @dr_mode: supported mode of operation it can be only Host, only Device + * or OTG mode that allow to switch between Device and Host mode. + * This field based on firmware setting, kernel configuration + * and hardware configuration. + * @role_sw: pointer to role switch object. + * @role_override: set 1 if role rely on SW. + */ +struct cdns3 { + struct udevice *dev; + void __iomem *xhci_regs; + struct cdns3_usb_regs __iomem *dev_regs; + + struct cdns3_otg_legacy_regs *otg_v0_regs; + struct cdns3_otg_regs *otg_v1_regs; + struct cdns3_otg_common_regs *otg_regs; +#define CDNS3_CONTROLLER_V0 0 +#define CDNS3_CONTROLLER_V1 1 + u32 version; + + int otg_irq; + int dev_irq; + struct cdns3_role_driver *roles[USB_ROLE_DEVICE + 1]; + enum usb_role role; + struct cdns3_device *gadget_dev; + struct phy usb2_phy; + struct phy usb3_phy; + /* mutext used in workqueue*/ + struct mutex mutex; + enum usb_dr_mode dr_mode; + int role_override; +}; + +int cdns3_hw_role_switch(struct cdns3 *cdns); + +/** + * cdns3_bind - generic bind function + * @parent - pointer to parent udevice of which cdns3 USB controller + * node is child of + * + * return 0 on success, negative errno otherwise + */ +int cdns3_bind(struct udevice *dev); +#endif /* __LINUX_CDNS3_CORE_H */ diff --git a/drivers/usb/cdns3/debug.h b/drivers/usb/cdns3/debug.h new file mode 100644 index 000000000000..0b4673a3a612 --- /dev/null +++ b/drivers/usb/cdns3/debug.h @@ -0,0 +1,162 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Cadence USBSS DRD Driver. + * Debug header file. + * + * Copyright (C) 2018-2019 Cadence. + * + * Author: Pawel Laszczak pawell@cadence.com + */ +#ifndef __LINUX_CDNS3_DEBUG +#define __LINUX_CDNS3_DEBUG + +#include "core.h" +#include "gadget.h" + +static inline char *cdns3_decode_usb_irq(char *str, + enum usb_device_speed speed, + u32 usb_ists) +{ + int ret; + + ret = sprintf(str, "IRQ %08x = ", usb_ists); + + if (usb_ists & (USB_ISTS_CON2I | USB_ISTS_CONI)) { + ret += sprintf(str + ret, "Connection %s\n", + usb_speed_string(speed)); + } + if (usb_ists & USB_ISTS_DIS2I || usb_ists & USB_ISTS_DISI) + ret += sprintf(str + ret, "Disconnection "); + if (usb_ists & USB_ISTS_L2ENTI) + ret += sprintf(str + ret, "suspended "); + if (usb_ists & USB_ISTS_L1ENTI) + ret += sprintf(str + ret, "L1 enter "); + if (usb_ists & USB_ISTS_L1EXTI) + ret += sprintf(str + ret, "L1 exit "); + if (usb_ists & USB_ISTS_L2ENTI) + ret += sprintf(str + ret, "L2 enter "); + if (usb_ists & USB_ISTS_L2EXTI) + ret += sprintf(str + ret, "L2 exit "); + if (usb_ists & USB_ISTS_U3EXTI) + ret += sprintf(str + ret, "U3 exit "); + if (usb_ists & USB_ISTS_UWRESI) + ret += sprintf(str + ret, "Warm Reset "); + if (usb_ists & USB_ISTS_UHRESI) + ret += sprintf(str + ret, "Hot Reset "); + if (usb_ists & USB_ISTS_U2RESI) + ret += sprintf(str + ret, "Reset"); + + return str; +} + +static inline char *cdns3_decode_ep_irq(char *str, + u32 ep_sts, + const char *ep_name) +{ + int ret; + + ret = sprintf(str, "IRQ for %s: %08x ", ep_name, ep_sts); + + if (ep_sts & EP_STS_SETUP) + ret += sprintf(str + ret, "SETUP "); + if (ep_sts & EP_STS_IOC) + ret += sprintf(str + ret, "IOC "); + if (ep_sts & EP_STS_ISP) + ret += sprintf(str + ret, "ISP "); + if (ep_sts & EP_STS_DESCMIS) + ret += sprintf(str + ret, "DESCMIS "); + if (ep_sts & EP_STS_STREAMR) + ret += sprintf(str + ret, "STREAMR "); + if (ep_sts & EP_STS_MD_EXIT) + ret += sprintf(str + ret, "MD_EXIT "); + if (ep_sts & EP_STS_TRBERR) + ret += sprintf(str + ret, "TRBERR "); + if (ep_sts & EP_STS_NRDY) + ret += sprintf(str + ret, "NRDY "); + if (ep_sts & EP_STS_PRIME) + ret += sprintf(str + ret, "PRIME "); + if (ep_sts & EP_STS_SIDERR) + ret += sprintf(str + ret, "SIDERRT "); + if (ep_sts & EP_STS_OUTSMM) + ret += sprintf(str + ret, "OUTSMM "); + if (ep_sts & EP_STS_ISOERR) + ret += sprintf(str + ret, "ISOERR "); + if (ep_sts & EP_STS_IOT) + ret += sprintf(str + ret, "IOT "); + + return str; +} + +static inline char *cdns3_decode_epx_irq(char *str, + char *ep_name, + u32 ep_sts) +{ + return cdns3_decode_ep_irq(str, ep_sts, ep_name); +} + +static inline char *cdns3_decode_ep0_irq(char *str, + int dir, + u32 ep_sts) +{ + return cdns3_decode_ep_irq(str, ep_sts, + dir ? "ep0IN" : "ep0OUT"); +} + +/** + * Debug a transfer ring. + * + * Prints out all TRBs in the endpoint ring, even those after the Link TRB. + *. + */ +static inline char *cdns3_dbg_ring(struct cdns3_endpoint *priv_ep, + struct cdns3_trb *ring, char *str) +{ + dma_addr_t addr = priv_ep->trb_pool_dma; + struct cdns3_trb *trb; + int trb_per_sector; + int ret = 0; + int i; + + trb_per_sector = GET_TRBS_PER_SEGMENT(priv_ep->type); + + trb = &priv_ep->trb_pool[priv_ep->dequeue]; + ret += sprintf(str + ret, "\n\t\tRing contents for %s:", priv_ep->name); + + ret += sprintf(str + ret, + "\n\t\tRing deq index: %d, trb: %p (virt), 0x%llx (dma)\n", + priv_ep->dequeue, trb, + (unsigned long long)cdns3_trb_virt_to_dma(priv_ep, trb)); + + trb = &priv_ep->trb_pool[priv_ep->enqueue]; + ret += sprintf(str + ret, + "\t\tRing enq index: %d, trb: %p (virt), 0x%llx (dma)\n", + priv_ep->enqueue, trb, + (unsigned long long)cdns3_trb_virt_to_dma(priv_ep, trb)); + + ret += sprintf(str + ret, + "\t\tfree trbs: %d, CCS=%d, PCS=%d\n", + priv_ep->free_trbs, priv_ep->ccs, priv_ep->pcs); + + if (trb_per_sector > TRBS_PER_SEGMENT) + trb_per_sector = TRBS_PER_SEGMENT; + + if (trb_per_sector > TRBS_PER_SEGMENT) { + sprintf(str + ret, "\t\tTo big transfer ring %d\n", + trb_per_sector); + return str; + } + + for (i = 0; i < trb_per_sector; ++i) { + trb = &ring[i]; + ret += sprintf(str + ret, + "\t\t@%pad %08x %08x %08x\n", &addr, + le32_to_cpu(trb->buffer), + le32_to_cpu(trb->length), + le32_to_cpu(trb->control)); + addr += sizeof(*trb); + } + + return str; +} + +#endif /*__LINUX_CDNS3_DEBUG*/ diff --git a/drivers/usb/cdns3/drd.c b/drivers/usb/cdns3/drd.c new file mode 100644 index 000000000000..13eb4899d49c --- /dev/null +++ b/drivers/usb/cdns3/drd.c @@ -0,0 +1,301 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Cadence USBSS DRD Driver. + * + * Copyright (C) 2018-2019 Cadence. + * Copyright (C) 2019 Texas Instruments + * + * Author: Pawel Laszczak pawell@cadence.com + * Roger Quadros rogerq@ti.com + * + * + */ +#include <dm.h> +#include <linux/delay.h> +#include <linux/iopoll.h> +#include <linux/kernel.h> +#include <linux/usb/otg.h> + +#include "gadget.h" +#include "drd.h" +#include "core.h" + +#define readl_poll_timeout_atomic readl_poll_timeout +#define usleep_range(a, b) udelay((b)) +/** + * cdns3_set_mode - change mode of OTG Core + * @cdns: pointer to context structure + * @mode: selected mode from cdns_role + * + * Returns 0 on success otherwise negative errno + */ +int cdns3_set_mode(struct cdns3 *cdns, enum usb_dr_mode mode) +{ + int ret = 0; + u32 reg; + + switch (mode) { + case USB_DR_MODE_PERIPHERAL: + break; + case USB_DR_MODE_HOST: + break; + case USB_DR_MODE_OTG: + dev_dbg(cdns->dev, "Set controller to OTG mode\n"); + if (cdns->version == CDNS3_CONTROLLER_V1) { + reg = readl(&cdns->otg_v1_regs->override); + reg |= OVERRIDE_IDPULLUP; + writel(reg, &cdns->otg_v1_regs->override); + } else { + reg = readl(&cdns->otg_v0_regs->ctrl1); + reg |= OVERRIDE_IDPULLUP_V0; + writel(reg, &cdns->otg_v0_regs->ctrl1); + } + + /* + * Hardware specification says: "ID_VALUE must be valid within + * 50ms after idpullup is set to '1" so driver must wait + * 50ms before reading this pin. + */ + usleep_range(50000, 60000); + break; + default: + dev_err(cdns->dev, "Unsupported mode of operation %d\n", mode); + return -EINVAL; + } + + return ret; +} + +int cdns3_get_id(struct cdns3 *cdns) +{ + int id; + + id = readl(&cdns->otg_regs->sts) & OTGSTS_ID_VALUE; + dev_dbg(cdns->dev, "OTG ID: %d", id); + + return id; +} + +int cdns3_get_vbus(struct cdns3 *cdns) +{ + int vbus; + + vbus = !!(readl(&cdns->otg_regs->sts) & OTGSTS_VBUS_VALID); + dev_dbg(cdns->dev, "OTG VBUS: %d", vbus); + + return vbus; +} + +int cdns3_is_host(struct cdns3 *cdns) +{ + if (cdns->dr_mode == USB_DR_MODE_HOST) + return 1; + else if (!cdns3_get_id(cdns)) + return 1; + + return 0; +} + +int cdns3_is_device(struct cdns3 *cdns) +{ + if (cdns->dr_mode == USB_DR_MODE_PERIPHERAL) + return 1; + else if (cdns->dr_mode == USB_DR_MODE_OTG) + if (cdns3_get_id(cdns)) + return 1; + + return 0; +} + +/** + * cdns3_drd_switch_host - start/stop host + * @cdns: Pointer to controller context structure + * @on: 1 for start, 0 for stop + * + * Returns 0 on success otherwise negative errno + */ +int cdns3_drd_switch_host(struct cdns3 *cdns, int on) +{ + int ret, val; + u32 reg = OTGCMD_OTG_DIS; + + /* switch OTG core */ + if (on) { + writel(OTGCMD_HOST_BUS_REQ | reg, &cdns->otg_regs->cmd); + + dev_dbg(cdns->dev, "Waiting till Host mode is turned on\n"); + ret = readl_poll_timeout_atomic(&cdns->otg_regs->sts, val, + val & OTGSTS_XHCI_READY, + 100000); + if (ret) { + dev_err(cdns->dev, "timeout waiting for xhci_ready\n"); + return ret; + } + } else { + writel(OTGCMD_HOST_BUS_DROP | OTGCMD_DEV_BUS_DROP | + OTGCMD_DEV_POWER_OFF | OTGCMD_HOST_POWER_OFF, + &cdns->otg_regs->cmd); + /* Waiting till H_IDLE state.*/ + readl_poll_timeout_atomic(&cdns->otg_regs->state, val, + !(val & OTGSTATE_HOST_STATE_MASK), + 2000000); + } + + return 0; +} + +/** + * cdns3_drd_switch_gadget - start/stop gadget + * @cdns: Pointer to controller context structure + * @on: 1 for start, 0 for stop + * + * Returns 0 on success otherwise negative errno + */ +int cdns3_drd_switch_gadget(struct cdns3 *cdns, int on) +{ + int ret, val; + u32 reg = OTGCMD_OTG_DIS; + + /* switch OTG core */ + if (on) { + writel(OTGCMD_DEV_BUS_REQ | reg, &cdns->otg_regs->cmd); + + dev_dbg(cdns->dev, "Waiting till Device mode is turned on\n"); + + ret = readl_poll_timeout_atomic(&cdns->otg_regs->sts, val, + val & OTGSTS_DEV_READY, + 100000); + if (ret) { + dev_err(cdns->dev, "timeout waiting for dev_ready\n"); + return ret; + } + } else { + /* + * driver should wait at least 10us after disabling Device + * before turning-off Device (DEV_BUS_DROP) + */ + usleep_range(20, 30); + writel(OTGCMD_HOST_BUS_DROP | OTGCMD_DEV_BUS_DROP | + OTGCMD_DEV_POWER_OFF | OTGCMD_HOST_POWER_OFF, + &cdns->otg_regs->cmd); + /* Waiting till DEV_IDLE state.*/ + readl_poll_timeout_atomic(&cdns->otg_regs->state, val, + !(val & OTGSTATE_DEV_STATE_MASK), + 2000000); + } + + return 0; +} + +/** + * cdns3_init_otg_mode - initialize drd controller + * @cdns: Pointer to controller context structure + * + * Returns 0 on success otherwise negative errno + */ +static int cdns3_init_otg_mode(struct cdns3 *cdns) +{ + int ret = 0; + + /* clear all interrupts */ + writel(~0, &cdns->otg_regs->ivect); + + ret = cdns3_set_mode(cdns, USB_DR_MODE_OTG); + if (ret) + return ret; + + return ret; +} + +/** + * cdns3_drd_update_mode - initialize mode of operation + * @cdns: Pointer to controller context structure + * + * Returns 0 on success otherwise negative errno + */ +int cdns3_drd_update_mode(struct cdns3 *cdns) +{ + int ret = 0; + + switch (cdns->dr_mode) { + case USB_DR_MODE_PERIPHERAL: + ret = cdns3_set_mode(cdns, USB_DR_MODE_PERIPHERAL); + break; + case USB_DR_MODE_HOST: + ret = cdns3_set_mode(cdns, USB_DR_MODE_HOST); + break; + case USB_DR_MODE_OTG: + ret = cdns3_init_otg_mode(cdns); + break; + default: + dev_err(cdns->dev, "Unsupported mode of operation %d\n", + cdns->dr_mode); + return -EINVAL; + } + + return ret; +} + +int cdns3_drd_init(struct cdns3 *cdns) +{ + void __iomem *regs; + int ret = 0; + u32 state; + + regs = dev_remap_addr_name(cdns->dev, "otg"); + if (!regs) + return -EINVAL; + + /* Detection of DRD version. Controller has been released + * in two versions. Both are similar, but they have same changes + * in register maps. + * The first register in old version is command register and it's read + * only, so driver should read 0 from it. On the other hand, in v1 + * the first register contains device ID number which is not set to 0. + * Driver uses this fact to detect the proper version of + * controller. + */ + cdns->otg_v0_regs = regs; + if (!readl(&cdns->otg_v0_regs->cmd)) { + cdns->version = CDNS3_CONTROLLER_V0; + cdns->otg_v1_regs = NULL; + cdns->otg_regs = regs; + writel(1, &cdns->otg_v0_regs->simulate); + dev_info(cdns->dev, "DRD version v0 (%08x)\n", + readl(&cdns->otg_v0_regs->version)); + } else { + cdns->otg_v0_regs = NULL; + cdns->otg_v1_regs = regs; + cdns->otg_regs = (void *)&cdns->otg_v1_regs->cmd; + cdns->version = CDNS3_CONTROLLER_V1; + writel(1, &cdns->otg_v1_regs->simulate); + dev_info(cdns->dev, "DRD version v1 (ID: %08x, rev: %08x)\n", + readl(&cdns->otg_v1_regs->did), + readl(&cdns->otg_v1_regs->rid)); + } + + state = OTGSTS_STRAP(readl(&cdns->otg_regs->sts)); + + /* Update dr_mode according to STRAP configuration. */ + cdns->dr_mode = USB_DR_MODE_OTG; + if (state == OTGSTS_STRAP_HOST) { + dev_dbg(cdns->dev, "Controller strapped to HOST\n"); + cdns->dr_mode = USB_DR_MODE_HOST; + } else if (state == OTGSTS_STRAP_GADGET) { + dev_dbg(cdns->dev, "Controller strapped to PERIPHERAL\n"); + cdns->dr_mode = USB_DR_MODE_PERIPHERAL; + } + + state = readl(&cdns->otg_regs->sts); + if (OTGSTS_OTG_NRDY(state) != 0) { + dev_err(cdns->dev, "Cadence USB3 OTG device not ready\n"); + return -ENODEV; + } + + return ret; +} + +int cdns3_drd_exit(struct cdns3 *cdns) +{ + return 0; +} diff --git a/drivers/usb/cdns3/drd.h b/drivers/usb/cdns3/drd.h new file mode 100644 index 000000000000..815b93f2fb40 --- /dev/null +++ b/drivers/usb/cdns3/drd.h @@ -0,0 +1,166 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Cadence USB3 DRD header file. + * + * Copyright (C) 2018-2019 Cadence. + * + * Author: Pawel Laszczak pawell@cadence.com + */ +#ifndef __LINUX_CDNS3_DRD +#define __LINUX_CDNS3_DRD + +#include <linux/types.h> +#include <linux/usb/otg.h> +#include "core.h" + +/* DRD register interface for version v1. */ +struct cdns3_otg_regs { + __le32 did; + __le32 rid; + __le32 capabilities; + __le32 reserved1; + __le32 cmd; + __le32 sts; + __le32 state; + __le32 reserved2; + __le32 ien; + __le32 ivect; + __le32 refclk; + __le32 tmr; + __le32 reserved3[4]; + __le32 simulate; + __le32 override; + __le32 susp_ctrl; + __le32 reserved4; + __le32 anasts; + __le32 adp_ramp_time; + __le32 ctrl1; + __le32 ctrl2; +}; + +/* DRD register interface for version v0. */ +struct cdns3_otg_legacy_regs { + __le32 cmd; + __le32 sts; + __le32 state; + __le32 refclk; + __le32 ien; + __le32 ivect; + __le32 reserved1[3]; + __le32 tmr; + __le32 reserved2[2]; + __le32 version; + __le32 capabilities; + __le32 reserved3[2]; + __le32 simulate; + __le32 reserved4[5]; + __le32 ctrl1; +}; + +/* + * Common registers interface for both version of DRD. + */ +struct cdns3_otg_common_regs { + __le32 cmd; + __le32 sts; + __le32 state; + __le32 different1; + __le32 ien; + __le32 ivect; +}; + +/* CDNS_RID - bitmasks */ +#define CDNS_RID(p) ((p) & GENMASK(15, 0)) + +/* CDNS_VID - bitmasks */ +#define CDNS_DID(p) ((p) & GENMASK(31, 0)) + +/* OTGCMD - bitmasks */ +/* "Request the bus for Device mode. */ +#define OTGCMD_DEV_BUS_REQ BIT(0) +/* Request the bus for Host mode */ +#define OTGCMD_HOST_BUS_REQ BIT(1) +/* Enable OTG mode. */ +#define OTGCMD_OTG_EN BIT(2) +/* Disable OTG mode */ +#define OTGCMD_OTG_DIS BIT(3) +/*"Configure OTG as A-Device. */ +#define OTGCMD_A_DEV_EN BIT(4) +/*"Configure OTG as A-Device. */ +#define OTGCMD_A_DEV_DIS BIT(5) +/* Drop the bus for Device mod e. */ +#define OTGCMD_DEV_BUS_DROP BIT(8) +/* Drop the bus for Host mode*/ +#define OTGCMD_HOST_BUS_DROP BIT(9) +/* Power Down USBSS-DEV. */ +#define OTGCMD_DEV_POWER_OFF BIT(11) +/* Power Down CDNSXHCI. */ +#define OTGCMD_HOST_POWER_OFF BIT(12) + +/* OTGIEN - bitmasks */ +/* ID change interrupt enable */ +#define OTGIEN_ID_CHANGE_INT BIT(0) +/* Vbusvalid fall detected interrupt enable.*/ +#define OTGIEN_VBUSVALID_RISE_INT BIT(4) +/* Vbusvalid fall detected interrupt enable */ +#define OTGIEN_VBUSVALID_FALL_INT BIT(5) + +/* OTGSTS - bitmasks */ +/* + * Current value of the ID pin. It is only valid when idpullup in + * OTGCTRL1_TYPE register is set to '1'. + */ +#define OTGSTS_ID_VALUE BIT(0) +/* Current value of the vbus_valid */ +#define OTGSTS_VBUS_VALID BIT(1) +/* Current value of the b_sess_vld */ +#define OTGSTS_SESSION_VALID BIT(2) +/*Device mode is active*/ +#define OTGSTS_DEV_ACTIVE BIT(3) +/* Host mode is active. */ +#define OTGSTS_HOST_ACTIVE BIT(4) +/* OTG Controller not ready. */ +#define OTGSTS_OTG_NRDY_MASK BIT(11) +#define OTGSTS_OTG_NRDY(p) ((p) & OTGSTS_OTG_NRDY_MASK) +/* + * Value of the strap pins. + * 000 - no default configuration + * 010 - Controller initiall configured as Host + * 100 - Controller initially configured as Device + */ +#define OTGSTS_STRAP(p) (((p) & GENMASK(14, 12)) >> 12) +#define OTGSTS_STRAP_NO_DEFAULT_CFG 0x00 +#define OTGSTS_STRAP_HOST_OTG 0x01 +#define OTGSTS_STRAP_HOST 0x02 +#define OTGSTS_STRAP_GADGET 0x04 +/* Host mode is turned on. */ +#define OTGSTS_XHCI_READY BIT(26) +/* "Device mode is turned on .*/ +#define OTGSTS_DEV_READY BIT(27) + +/* OTGSTATE- bitmasks */ +#define OTGSTATE_DEV_STATE_MASK GENMASK(2, 0) +#define OTGSTATE_HOST_STATE_MASK GENMASK(5, 3) +#define OTGSTATE_HOST_STATE_IDLE 0x0 +#define OTGSTATE_HOST_STATE_VBUS_FALL 0x7 +#define OTGSTATE_HOST_STATE(p) (((p) & OTGSTATE_HOST_STATE_MASK) >> 3) + +/* OTGREFCLK - bitmasks */ +#define OTGREFCLK_STB_CLK_SWITCH_EN BIT(31) + +/* OVERRIDE - bitmasks */ +#define OVERRIDE_IDPULLUP BIT(0) +/* Only for CDNS3_CONTROLLER_V0 version */ +#define OVERRIDE_IDPULLUP_V0 BIT(24) + +int cdns3_is_host(struct cdns3 *cdns); +int cdns3_is_device(struct cdns3 *cdns); +int cdns3_get_id(struct cdns3 *cdns); +int cdns3_get_vbus(struct cdns3 *cdns); +int cdns3_drd_init(struct cdns3 *cdns); +int cdns3_drd_exit(struct cdns3 *cdns); +int cdns3_drd_update_mode(struct cdns3 *cdns); +int cdns3_drd_switch_gadget(struct cdns3 *cdns, int on); +int cdns3_drd_switch_host(struct cdns3 *cdns, int on); + +#endif /* __LINUX_CDNS3_DRD */ diff --git a/drivers/usb/cdns3/ep0.c b/drivers/usb/cdns3/ep0.c new file mode 100644 index 000000000000..1903f6110388 --- /dev/null +++ b/drivers/usb/cdns3/ep0.c @@ -0,0 +1,910 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Cadence USBSS DRD Driver - gadget side. + * + * Copyright (C) 2018 Cadence Design Systems. + * Copyright (C) 2017-2018 NXP + * + * Authors: Pawel Jez pjez@cadence.com, + * Pawel Laszczak pawell@cadence.com + * Peter Chen peter.chen@nxp.com + */ + +#include <linux/usb/composite.h> +#include <linux/iopoll.h> + +#include "gadget.h" +#include "trace.h" + +#define readl_poll_timeout_atomic readl_poll_timeout +#define usleep_range(a, b) udelay((b)) + +static struct usb_endpoint_descriptor cdns3_gadget_ep0_desc = { + .bLength = USB_DT_ENDPOINT_SIZE, + .bDescriptorType = USB_DT_ENDPOINT, + .bmAttributes = USB_ENDPOINT_XFER_CONTROL, +}; + +/** + * cdns3_ep0_run_transfer - Do transfer on default endpoint hardware + * @priv_dev: extended gadget object + * @dma_addr: physical address where data is/will be stored + * @length: data length + * @erdy: set it to 1 when ERDY packet should be sent - + * exit from flow control state + */ +static void cdns3_ep0_run_transfer(struct cdns3_device *priv_dev, + dma_addr_t dma_addr, + unsigned int length, int erdy, int zlp) +{ + struct cdns3_usb_regs __iomem *regs = priv_dev->regs; + struct cdns3_endpoint *priv_ep = priv_dev->eps[0]; + + priv_ep->trb_pool[0].buffer = TRB_BUFFER(dma_addr); + priv_ep->trb_pool[0].length = TRB_LEN(length); + + if (zlp) { + priv_ep->trb_pool[0].control = TRB_CYCLE | TRB_TYPE(TRB_NORMAL); + priv_ep->trb_pool[1].buffer = TRB_BUFFER(dma_addr); + priv_ep->trb_pool[1].length = TRB_LEN(0); + priv_ep->trb_pool[1].control = TRB_CYCLE | TRB_IOC | + TRB_TYPE(TRB_NORMAL); + } else { + priv_ep->trb_pool[0].control = TRB_CYCLE | TRB_IOC | + TRB_TYPE(TRB_NORMAL); + priv_ep->trb_pool[1].control = 0; + } + + /* Flush both TRBs */ + flush_dcache_range((unsigned long)priv_ep->trb_pool, + (unsigned long)priv_ep->trb_pool + + ROUND(sizeof(struct cdns3_trb) * 2, + CONFIG_SYS_CACHELINE_SIZE)); + + trace_cdns3_prepare_trb(priv_ep, priv_ep->trb_pool); + + cdns3_select_ep(priv_dev, priv_dev->ep0_data_dir); + + writel(EP_STS_TRBERR, ®s->ep_sts); + writel(EP_TRADDR_TRADDR(priv_ep->trb_pool_dma), ®s->ep_traddr); + trace_cdns3_doorbell_ep0(priv_dev->ep0_data_dir ? "ep0in" : "ep0out", + readl(®s->ep_traddr)); + + /* TRB should be prepared before starting transfer. */ + writel(EP_CMD_DRDY, ®s->ep_cmd); + + /* Resume controller before arming transfer. */ + __cdns3_gadget_wakeup(priv_dev); + + if (erdy) + writel(EP_CMD_ERDY, &priv_dev->regs->ep_cmd); +} + +/** + * cdns3_ep0_delegate_req - Returns status of handling setup packet + * Setup is handled by gadget driver + * @priv_dev: extended gadget object + * @ctrl_req: pointer to received setup packet + * + * Returns zero on success or negative value on failure + */ +static int cdns3_ep0_delegate_req(struct cdns3_device *priv_dev, + struct usb_ctrlrequest *ctrl_req) +{ + int ret; + + spin_unlock(&priv_dev->lock); + priv_dev->setup_pending = 1; + ret = priv_dev->gadget_driver->setup(&priv_dev->gadget, ctrl_req); + priv_dev->setup_pending = 0; + spin_lock(&priv_dev->lock); + return ret; +} + +static void cdns3_prepare_setup_packet(struct cdns3_device *priv_dev) +{ + priv_dev->ep0_data_dir = 0; + priv_dev->ep0_stage = CDNS3_SETUP_STAGE; + cdns3_ep0_run_transfer(priv_dev, priv_dev->setup_dma, + sizeof(struct usb_ctrlrequest), 0, 0); +} + +static void cdns3_ep0_complete_setup(struct cdns3_device *priv_dev, + u8 send_stall, u8 send_erdy) +{ + struct cdns3_endpoint *priv_ep = priv_dev->eps[0]; + struct usb_request *request; + + request = cdns3_next_request(&priv_ep->pending_req_list); + if (request) + list_del_init(&request->list); + + if (send_stall) { + trace_cdns3_halt(priv_ep, send_stall, 0); + /* set_stall on ep0 */ + cdns3_select_ep(priv_dev, 0x00); + writel(EP_CMD_SSTALL, &priv_dev->regs->ep_cmd); + } else { + cdns3_prepare_setup_packet(priv_dev); + } + + priv_dev->ep0_stage = CDNS3_SETUP_STAGE; + writel((send_erdy ? EP_CMD_ERDY : 0) | EP_CMD_REQ_CMPL, + &priv_dev->regs->ep_cmd); + + cdns3_allow_enable_l1(priv_dev, 1); +} + +/** + * cdns3_req_ep0_set_configuration - Handling of SET_CONFIG standard USB request + * @priv_dev: extended gadget object + * @ctrl_req: pointer to received setup packet + * + * Returns 0 if success, USB_GADGET_DELAYED_STATUS on deferred status stage, + * error code on error + */ +static int cdns3_req_ep0_set_configuration(struct cdns3_device *priv_dev, + struct usb_ctrlrequest *ctrl_req) +{ + enum usb_device_state device_state = priv_dev->gadget.state; + struct cdns3_endpoint *priv_ep; + u32 config = le16_to_cpu(ctrl_req->wValue); + int result = 0; + int i; + + switch (device_state) { + case USB_STATE_ADDRESS: + /* Configure non-control EPs */ + for (i = 0; i < CDNS3_ENDPOINTS_MAX_COUNT; i++) { + priv_ep = priv_dev->eps[i]; + if (!priv_ep) + continue; + + if (priv_ep->flags & EP_CLAIMED) + cdns3_ep_config(priv_ep); + } + + result = cdns3_ep0_delegate_req(priv_dev, ctrl_req); + + if (result) + return result; + + if (config) { + cdns3_set_hw_configuration(priv_dev); + } else { + cdns3_hw_reset_eps_config(priv_dev); + usb_gadget_set_state(&priv_dev->gadget, + USB_STATE_ADDRESS); + } + break; + case USB_STATE_CONFIGURED: + result = cdns3_ep0_delegate_req(priv_dev, ctrl_req); + + if (!config && !result) { + cdns3_hw_reset_eps_config(priv_dev); + usb_gadget_set_state(&priv_dev->gadget, + USB_STATE_ADDRESS); + } + break; + default: + result = -EINVAL; + } + + return result; +} + +/** + * cdns3_req_ep0_set_address - Handling of SET_ADDRESS standard USB request + * @priv_dev: extended gadget object + * @ctrl_req: pointer to received setup packet + * + * Returns 0 if success, error code on error + */ +static int cdns3_req_ep0_set_address(struct cdns3_device *priv_dev, + struct usb_ctrlrequest *ctrl_req) +{ + enum usb_device_state device_state = priv_dev->gadget.state; + u32 reg; + u32 addr; + + addr = le16_to_cpu(ctrl_req->wValue); + + if (addr > USB_DEVICE_MAX_ADDRESS) { + dev_err(priv_dev->dev, + "Device address (%d) cannot be greater than %d\n", + addr, USB_DEVICE_MAX_ADDRESS); + return -EINVAL; + } + + if (device_state == USB_STATE_CONFIGURED) { + dev_err(priv_dev->dev, + "can't set_address from configured state\n"); + return -EINVAL; + } + + reg = readl(&priv_dev->regs->usb_cmd); + + writel(reg | USB_CMD_FADDR(addr) | USB_CMD_SET_ADDR, + &priv_dev->regs->usb_cmd); + + usb_gadget_set_state(&priv_dev->gadget, + (addr ? USB_STATE_ADDRESS : USB_STATE_DEFAULT)); + + return 0; +} + +/** + * cdns3_req_ep0_get_status - Handling of GET_STATUS standard USB request + * @priv_dev: extended gadget object + * @ctrl_req: pointer to received setup packet + * + * Returns 0 if success, error code on error + */ +static int cdns3_req_ep0_get_status(struct cdns3_device *priv_dev, + struct usb_ctrlrequest *ctrl) +{ + __le16 *response_pkt; + u16 usb_status = 0; + u32 recip; + + recip = ctrl->bRequestType & USB_RECIP_MASK; + + switch (recip) { + case USB_RECIP_DEVICE: + /* self powered */ + if (priv_dev->is_selfpowered) + usb_status = BIT(USB_DEVICE_SELF_POWERED); + + if (priv_dev->wake_up_flag) + usb_status |= BIT(USB_DEVICE_REMOTE_WAKEUP); + + if (priv_dev->gadget.speed != USB_SPEED_SUPER) + break; + + if (priv_dev->u1_allowed) + usb_status |= BIT(USB_DEV_STAT_U1_ENABLED); + + if (priv_dev->u2_allowed) + usb_status |= BIT(USB_DEV_STAT_U2_ENABLED); + + break; + case USB_RECIP_INTERFACE: + return cdns3_ep0_delegate_req(priv_dev, ctrl); + case USB_RECIP_ENDPOINT: + /* check if endpoint is stalled */ + cdns3_select_ep(priv_dev, ctrl->wIndex); + if (EP_STS_STALL(readl(&priv_dev->regs->ep_sts))) + usb_status = BIT(USB_ENDPOINT_HALT); + break; + default: + return -EINVAL; + } + + response_pkt = (__le16 *)priv_dev->setup_buf; + *response_pkt = cpu_to_le16(usb_status); + + /* Flush setup response */ + flush_dcache_range((unsigned long)priv_dev->setup_buf, + (unsigned long)priv_dev->setup_buf + + ROUND(sizeof(struct usb_ctrlrequest), + CONFIG_SYS_CACHELINE_SIZE)); + + cdns3_ep0_run_transfer(priv_dev, priv_dev->setup_dma, + sizeof(*response_pkt), 1, 0); + return 0; +} + +static int cdns3_ep0_feature_handle_device(struct cdns3_device *priv_dev, + struct usb_ctrlrequest *ctrl, + int set) +{ + enum usb_device_state state; + enum usb_device_speed speed; + int ret = 0; + u16 tmode; + + state = priv_dev->gadget.state; + speed = priv_dev->gadget.speed; + + switch (ctrl->wValue) { + case USB_DEVICE_REMOTE_WAKEUP: + priv_dev->wake_up_flag = !!set; + break; + case USB_DEVICE_U1_ENABLE: + if (state != USB_STATE_CONFIGURED || speed != USB_SPEED_SUPER) + return -EINVAL; + + priv_dev->u1_allowed = !!set; + break; + case USB_DEVICE_U2_ENABLE: + if (state != USB_STATE_CONFIGURED || speed != USB_SPEED_SUPER) + return -EINVAL; + + priv_dev->u2_allowed = !!set; + break; + case USB_DEVICE_LTM_ENABLE: + ret = -EINVAL; + break; + case USB_DEVICE_TEST_MODE: + if (state != USB_STATE_CONFIGURED || speed > USB_SPEED_HIGH) + return -EINVAL; + + tmode = le16_to_cpu(ctrl->wIndex); + + if (!set || (tmode & 0xff) != 0) + return -EINVAL; + + switch (tmode >> 8) { + case TEST_J: + case TEST_K: + case TEST_SE0_NAK: + case TEST_PACKET: + cdns3_ep0_complete_setup(priv_dev, 0, 1); + /** + * Little delay to give the controller some time + * for sending status stage. + * This time should be less then 3ms. + */ + usleep_range(1000, 2000); + cdns3_set_register_bit(&priv_dev->regs->usb_cmd, + USB_CMD_STMODE | + USB_STS_TMODE_SEL(tmode - 1)); + break; + default: + ret = -EINVAL; + } + break; + default: + ret = -EINVAL; + } + + return ret; +} + +static int cdns3_ep0_feature_handle_intf(struct cdns3_device *priv_dev, + struct usb_ctrlrequest *ctrl, + int set) +{ + u32 wValue; + int ret = 0; + + wValue = le16_to_cpu(ctrl->wValue); + + switch (wValue) { + case USB_INTRF_FUNC_SUSPEND: + break; + default: + ret = -EINVAL; + } + + return ret; +} + +static int cdns3_ep0_feature_handle_endpoint(struct cdns3_device *priv_dev, + struct usb_ctrlrequest *ctrl, + int set) +{ + struct cdns3_endpoint *priv_ep; + int ret = 0; + u8 index; + + if (le16_to_cpu(ctrl->wValue) != USB_ENDPOINT_HALT) + return -EINVAL; + + if (!(ctrl->wIndex & ~USB_DIR_IN)) + return 0; + + index = cdns3_ep_addr_to_index(ctrl->wIndex); + priv_ep = priv_dev->eps[index]; + + cdns3_select_ep(priv_dev, ctrl->wIndex); + + if (set) + __cdns3_gadget_ep_set_halt(priv_ep); + else if (!(priv_ep->flags & EP_WEDGE)) + ret = __cdns3_gadget_ep_clear_halt(priv_ep); + + cdns3_select_ep(priv_dev, 0x00); + + return ret; +} + +/** + * cdns3_req_ep0_handle_feature - + * Handling of GET/SET_FEATURE standard USB request + * + * @priv_dev: extended gadget object + * @ctrl_req: pointer to received setup packet + * @set: must be set to 1 for SET_FEATURE request + * + * Returns 0 if success, error code on error + */ +static int cdns3_req_ep0_handle_feature(struct cdns3_device *priv_dev, + struct usb_ctrlrequest *ctrl, + int set) +{ + int ret = 0; + u32 recip; + + recip = ctrl->bRequestType & USB_RECIP_MASK; + + switch (recip) { + case USB_RECIP_DEVICE: + ret = cdns3_ep0_feature_handle_device(priv_dev, ctrl, set); + break; + case USB_RECIP_INTERFACE: + ret = cdns3_ep0_feature_handle_intf(priv_dev, ctrl, set); + break; + case USB_RECIP_ENDPOINT: + ret = cdns3_ep0_feature_handle_endpoint(priv_dev, ctrl, set); + break; + default: + return -EINVAL; + } + + return ret; +} + +/** + * cdns3_req_ep0_set_sel - Handling of SET_SEL standard USB request + * @priv_dev: extended gadget object + * @ctrl_req: pointer to received setup packet + * + * Returns 0 if success, error code on error + */ +static int cdns3_req_ep0_set_sel(struct cdns3_device *priv_dev, + struct usb_ctrlrequest *ctrl_req) +{ + if (priv_dev->gadget.state < USB_STATE_ADDRESS) + return -EINVAL; + + if (ctrl_req->wLength != 6) { + dev_err(priv_dev->dev, "Set SEL should be 6 bytes, got %d\n", + ctrl_req->wLength); + return -EINVAL; + } + + cdns3_ep0_run_transfer(priv_dev, priv_dev->setup_dma, 6, 1, 0); + return 0; +} + +/** + * cdns3_req_ep0_set_isoch_delay - + * Handling of GET_ISOCH_DELAY standard USB request + * @priv_dev: extended gadget object + * @ctrl_req: pointer to received setup packet + * + * Returns 0 if success, error code on error + */ +static int cdns3_req_ep0_set_isoch_delay(struct cdns3_device *priv_dev, + struct usb_ctrlrequest *ctrl_req) +{ + if (ctrl_req->wIndex || ctrl_req->wLength) + return -EINVAL; + + priv_dev->isoch_delay = ctrl_req->wValue; + + return 0; +} + +/** + * cdns3_ep0_standard_request - Handling standard USB requests + * @priv_dev: extended gadget object + * @ctrl_req: pointer to received setup packet + * + * Returns 0 if success, error code on error + */ +static int cdns3_ep0_standard_request(struct cdns3_device *priv_dev, + struct usb_ctrlrequest *ctrl_req) +{ + int ret; + + switch (ctrl_req->bRequest) { + case USB_REQ_SET_ADDRESS: + ret = cdns3_req_ep0_set_address(priv_dev, ctrl_req); + break; + case USB_REQ_SET_CONFIGURATION: + ret = cdns3_req_ep0_set_configuration(priv_dev, ctrl_req); + break; + case USB_REQ_GET_STATUS: + ret = cdns3_req_ep0_get_status(priv_dev, ctrl_req); + break; + case USB_REQ_CLEAR_FEATURE: + ret = cdns3_req_ep0_handle_feature(priv_dev, ctrl_req, 0); + break; + case USB_REQ_SET_FEATURE: + ret = cdns3_req_ep0_handle_feature(priv_dev, ctrl_req, 1); + break; + case USB_REQ_SET_SEL: + ret = cdns3_req_ep0_set_sel(priv_dev, ctrl_req); + break; + case USB_REQ_SET_ISOCH_DELAY: + ret = cdns3_req_ep0_set_isoch_delay(priv_dev, ctrl_req); + break; + default: + ret = cdns3_ep0_delegate_req(priv_dev, ctrl_req); + break; + } + + return ret; +} + +static void __pending_setup_status_handler(struct cdns3_device *priv_dev) +{ + struct usb_request *request = priv_dev->pending_status_request; + + if (priv_dev->status_completion_no_call && request && + request->complete) { + request->complete(&priv_dev->eps[0]->endpoint, request); + priv_dev->status_completion_no_call = 0; + } +} + +void cdns3_pending_setup_status_handler(struct work_struct *work) +{ + struct cdns3_device *priv_dev = container_of(work, struct cdns3_device, + pending_status_wq); + unsigned long flags; + + spin_lock_irqsave(&priv_dev->lock, flags); + __pending_setup_status_handler(priv_dev); + spin_unlock_irqrestore(&priv_dev->lock, flags); +} + +/** + * cdns3_ep0_setup_phase - Handling setup USB requests + * @priv_dev: extended gadget object + */ +static void cdns3_ep0_setup_phase(struct cdns3_device *priv_dev) +{ + struct usb_ctrlrequest *ctrl = priv_dev->setup_buf; + struct cdns3_endpoint *priv_ep = priv_dev->eps[0]; + int result; + + priv_dev->ep0_data_dir = ctrl->bRequestType & USB_DIR_IN; + + trace_cdns3_ctrl_req(ctrl); + + if (!list_empty(&priv_ep->pending_req_list)) { + struct usb_request *request; + + request = cdns3_next_request(&priv_ep->pending_req_list); + priv_ep->dir = priv_dev->ep0_data_dir; + cdns3_gadget_giveback(priv_ep, to_cdns3_request(request), + -ECONNRESET); + } + + if (le16_to_cpu(ctrl->wLength)) + priv_dev->ep0_stage = CDNS3_DATA_STAGE; + else + priv_dev->ep0_stage = CDNS3_STATUS_STAGE; + + if ((ctrl->bRequestType & USB_TYPE_MASK) == USB_TYPE_STANDARD) + result = cdns3_ep0_standard_request(priv_dev, ctrl); + else + result = cdns3_ep0_delegate_req(priv_dev, ctrl); + + if (result == USB_GADGET_DELAYED_STATUS) + return; + + if (result < 0) + cdns3_ep0_complete_setup(priv_dev, 1, 1); + else if (priv_dev->ep0_stage == CDNS3_STATUS_STAGE) + cdns3_ep0_complete_setup(priv_dev, 0, 1); +} + +static void cdns3_transfer_completed(struct cdns3_device *priv_dev) +{ + struct cdns3_endpoint *priv_ep = priv_dev->eps[0]; + + if (!list_empty(&priv_ep->pending_req_list)) { + struct usb_request *request; + + trace_cdns3_complete_trb(priv_ep, priv_ep->trb_pool); + request = cdns3_next_request(&priv_ep->pending_req_list); + + /* Invalidate TRB before accessing it */ + invalidate_dcache_range((unsigned long)priv_ep->trb_pool, + (unsigned long)priv_ep->trb_pool + + ROUND(sizeof(struct cdns3_trb), + CONFIG_SYS_CACHELINE_SIZE)); + + request->actual = + TRB_LEN(le32_to_cpu(priv_ep->trb_pool->length)); + + priv_ep->dir = priv_dev->ep0_data_dir; + cdns3_gadget_giveback(priv_ep, to_cdns3_request(request), 0); + } + + cdns3_ep0_complete_setup(priv_dev, 0, 0); +} + +/** + * cdns3_check_new_setup - Check if controller receive new SETUP packet. + * @priv_dev: extended gadget object + * + * The SETUP packet can be kept in on-chip memory or in system memory. + */ +static bool cdns3_check_new_setup(struct cdns3_device *priv_dev) +{ + u32 ep_sts_reg; + + cdns3_select_ep(priv_dev, 0 | USB_DIR_OUT); + ep_sts_reg = readl(&priv_dev->regs->ep_sts); + + return !!(ep_sts_reg & (EP_STS_SETUP | EP_STS_STPWAIT)); +} + +/** + * cdns3_check_ep0_interrupt_proceed - Processes interrupt related to endpoint 0 + * @priv_dev: extended gadget object + * @dir: USB_DIR_IN for IN direction, USB_DIR_OUT for OUT direction + */ +void cdns3_check_ep0_interrupt_proceed(struct cdns3_device *priv_dev, int dir) +{ + u32 ep_sts_reg; + + cdns3_select_ep(priv_dev, dir); + + ep_sts_reg = readl(&priv_dev->regs->ep_sts); + writel(ep_sts_reg, &priv_dev->regs->ep_sts); + + trace_cdns3_ep0_irq(priv_dev, ep_sts_reg); + + __pending_setup_status_handler(priv_dev); + + if (ep_sts_reg & EP_STS_SETUP) + priv_dev->wait_for_setup = 1; + + if (priv_dev->wait_for_setup && ep_sts_reg & EP_STS_IOC) { + priv_dev->wait_for_setup = 0; + cdns3_allow_enable_l1(priv_dev, 0); + cdns3_ep0_setup_phase(priv_dev); + } else if ((ep_sts_reg & EP_STS_IOC) || (ep_sts_reg & EP_STS_ISP)) { + priv_dev->ep0_data_dir = dir; + cdns3_transfer_completed(priv_dev); + } + + if (ep_sts_reg & EP_STS_DESCMIS) { + if (dir == 0 && !priv_dev->setup_pending) + cdns3_prepare_setup_packet(priv_dev); + } +} + +/** + * cdns3_gadget_ep0_enable + * Function shouldn't be called by gadget driver, + * endpoint 0 is allways active + */ +static int cdns3_gadget_ep0_enable(struct usb_ep *ep, + const struct usb_endpoint_descriptor *desc) +{ + return -EINVAL; +} + +/** + * cdns3_gadget_ep0_disable + * Function shouldn't be called by gadget driver, + * endpoint 0 is allways active + */ +static int cdns3_gadget_ep0_disable(struct usb_ep *ep) +{ + return -EINVAL; +} + +/** + * cdns3_gadget_ep0_set_halt + * @ep: pointer to endpoint zero object + * @value: 1 for set stall, 0 for clear stall + * + * Returns 0 + */ +static int cdns3_gadget_ep0_set_halt(struct usb_ep *ep, int value) +{ + /* TODO */ + return 0; +} + +/** + * cdns3_gadget_ep0_queue Transfer data on endpoint zero + * @ep: pointer to endpoint zero object + * @request: pointer to request object + * @gfp_flags: gfp flags + * + * Returns 0 on success, error code elsewhere + */ +static int cdns3_gadget_ep0_queue(struct usb_ep *ep, + struct usb_request *request, + gfp_t gfp_flags) +{ + struct cdns3_endpoint *priv_ep = ep_to_cdns3_ep(ep); + struct cdns3_device *priv_dev = priv_ep->cdns3_dev; + unsigned long flags; + int erdy_sent = 0; + int ret = 0; + u8 zlp = 0; + + trace_cdns3_ep0_queue(priv_dev, request); + + /* cancel the request if controller receive new SETUP packet. */ + if (cdns3_check_new_setup(priv_dev)) + return -ECONNRESET; + + /* send STATUS stage. Should be called only for SET_CONFIGURATION */ + if (priv_dev->ep0_stage == CDNS3_STATUS_STAGE) { + spin_lock_irqsave(&priv_dev->lock, flags); + cdns3_select_ep(priv_dev, 0x00); + + erdy_sent = !priv_dev->hw_configured_flag; + cdns3_set_hw_configuration(priv_dev); + + if (!erdy_sent) + cdns3_ep0_complete_setup(priv_dev, 0, 1); + + cdns3_allow_enable_l1(priv_dev, 1); + + request->actual = 0; + priv_dev->status_completion_no_call = true; + priv_dev->pending_status_request = request; + spin_unlock_irqrestore(&priv_dev->lock, flags); + + /* + * Since there is no completion interrupt for status stage, + * it needs to call ->completion in software after + * ep0_queue is back. + */ +#ifndef __UBOOT__ + queue_work(system_freezable_wq, &priv_dev->pending_status_wq); +#else + __pending_setup_status_handler(priv_dev); +#endif + return 0; + } + + spin_lock_irqsave(&priv_dev->lock, flags); + if (!list_empty(&priv_ep->pending_req_list)) { + dev_err(priv_dev->dev, + "can't handle multiple requests for ep0\n"); + spin_unlock_irqrestore(&priv_dev->lock, flags); + return -EBUSY; + } + + ret = usb_gadget_map_request(&priv_dev->gadget, request, + priv_dev->ep0_data_dir); + if (ret) { + spin_unlock_irqrestore(&priv_dev->lock, flags); + dev_err(priv_dev->dev, "failed to map request\n"); + return -EINVAL; + } + + request->status = -EINPROGRESS; + list_add_tail(&request->list, &priv_ep->pending_req_list); + + if (request->zero && request->length && + (request->length % ep->maxpacket == 0)) + zlp = 1; + + cdns3_ep0_run_transfer(priv_dev, request->dma, request->length, 1, zlp); + + spin_unlock_irqrestore(&priv_dev->lock, flags); + + return ret; +} + +/** + * cdns3_gadget_ep_set_wedge Set wedge on selected endpoint + * @ep: endpoint object + * + * Returns 0 + */ +int cdns3_gadget_ep_set_wedge(struct usb_ep *ep) +{ + struct cdns3_endpoint *priv_ep = ep_to_cdns3_ep(ep); + + dev_dbg(priv_dev->dev, "Wedge for %s\n", ep->name); + cdns3_gadget_ep_set_halt(ep, 1); + priv_ep->flags |= EP_WEDGE; + + return 0; +} + +const struct usb_ep_ops cdns3_gadget_ep0_ops = { + .enable = cdns3_gadget_ep0_enable, + .disable = cdns3_gadget_ep0_disable, + .alloc_request = cdns3_gadget_ep_alloc_request, + .free_request = cdns3_gadget_ep_free_request, + .queue = cdns3_gadget_ep0_queue, + .dequeue = cdns3_gadget_ep_dequeue, + .set_halt = cdns3_gadget_ep0_set_halt, + .set_wedge = cdns3_gadget_ep_set_wedge, +}; + +/** + * cdns3_ep0_config - Configures default endpoint + * @priv_dev: extended gadget object + * + * Functions sets parameters: maximal packet size and enables interrupts + */ +void cdns3_ep0_config(struct cdns3_device *priv_dev) +{ + struct cdns3_usb_regs __iomem *regs; + struct cdns3_endpoint *priv_ep; + u32 max_packet_size = 64; + + regs = priv_dev->regs; + + if (priv_dev->gadget.speed == USB_SPEED_SUPER) + max_packet_size = 512; + + priv_ep = priv_dev->eps[0]; + + if (!list_empty(&priv_ep->pending_req_list)) { + struct usb_request *request; + + request = cdns3_next_request(&priv_ep->pending_req_list); + list_del_init(&request->list); + } + + priv_dev->u1_allowed = 0; + priv_dev->u2_allowed = 0; + + priv_dev->gadget.ep0->maxpacket = max_packet_size; + cdns3_gadget_ep0_desc.wMaxPacketSize = cpu_to_le16(max_packet_size); + + /* init ep out */ + cdns3_select_ep(priv_dev, USB_DIR_OUT); + + if (priv_dev->dev_ver >= DEV_VER_V3) { + cdns3_set_register_bit(&priv_dev->regs->dtrans, + BIT(0) | BIT(16)); + cdns3_set_register_bit(&priv_dev->regs->tdl_from_trb, + BIT(0) | BIT(16)); + } + + writel(EP_CFG_ENABLE | EP_CFG_MAXPKTSIZE(max_packet_size), + ®s->ep_cfg); + + writel(EP_STS_EN_SETUPEN | EP_STS_EN_DESCMISEN | EP_STS_EN_TRBERREN, + ®s->ep_sts_en); + + /* init ep in */ + cdns3_select_ep(priv_dev, USB_DIR_IN); + + writel(EP_CFG_ENABLE | EP_CFG_MAXPKTSIZE(max_packet_size), + ®s->ep_cfg); + + writel(EP_STS_EN_SETUPEN | EP_STS_EN_TRBERREN, ®s->ep_sts_en); + + cdns3_set_register_bit(®s->usb_conf, USB_CONF_U1DS | USB_CONF_U2DS); +} + +/** + * cdns3_init_ep0 Initializes software endpoint 0 of gadget + * @priv_dev: extended gadget object + * @ep_priv: extended endpoint object + * + * Returns 0 on success else error code. + */ +int cdns3_init_ep0(struct cdns3_device *priv_dev, + struct cdns3_endpoint *priv_ep) +{ + sprintf(priv_ep->name, "ep0"); + + /* fill linux fields */ + priv_ep->endpoint.ops = &cdns3_gadget_ep0_ops; + priv_ep->endpoint.maxburst = 1; + usb_ep_set_maxpacket_limit(&priv_ep->endpoint, + CDNS3_EP0_MAX_PACKET_LIMIT); +#ifndef __UBOOT__ + priv_ep->endpoint.address = 0; +#endif + priv_ep->endpoint.caps.type_control = 1; + priv_ep->endpoint.caps.dir_in = 1; + priv_ep->endpoint.caps.dir_out = 1; + priv_ep->endpoint.name = priv_ep->name; + priv_ep->endpoint.desc = &cdns3_gadget_ep0_desc; + priv_dev->gadget.ep0 = &priv_ep->endpoint; + priv_ep->type = USB_ENDPOINT_XFER_CONTROL; + + return cdns3_allocate_trb_pool(priv_ep); +} diff --git a/drivers/usb/cdns3/gadget-export.h b/drivers/usb/cdns3/gadget-export.h new file mode 100644 index 000000000000..577469eee961 --- /dev/null +++ b/drivers/usb/cdns3/gadget-export.h @@ -0,0 +1,28 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Cadence USBSS DRD Driver - Gadget Export APIs. + * + * Copyright (C) 2017 NXP + * Copyright (C) 2017-2018 NXP + * + * Authors: Peter Chen peter.chen@nxp.com + */ +#ifndef __LINUX_CDNS3_GADGET_EXPORT +#define __LINUX_CDNS3_GADGET_EXPORT + +#ifdef CONFIG_USB_CDNS3_GADGET + +int cdns3_gadget_init(struct cdns3 *cdns); +void cdns3_gadget_exit(struct cdns3 *cdns); +#else + +static inline int cdns3_gadget_init(struct cdns3 *cdns) +{ + return -ENXIO; +} + +static inline void cdns3_gadget_exit(struct cdns3 *cdns) { } + +#endif + +#endif /* __LINUX_CDNS3_GADGET_EXPORT */ diff --git a/drivers/usb/cdns3/gadget.c b/drivers/usb/cdns3/gadget.c new file mode 100644 index 000000000000..a4debb0ddf1d --- /dev/null +++ b/drivers/usb/cdns3/gadget.c @@ -0,0 +1,2738 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Cadence USBSS DRD Driver - gadget side. + * + * Copyright (C) 2018-2019 Cadence Design Systems. + * Copyright (C) 2017-2018 NXP + * + * Authors: Pawel Jez pjez@cadence.com, + * Pawel Laszczak pawell@cadence.com + * Peter Chen peter.chen@nxp.com + */ + +/* + * Work around 1: + * At some situations, the controller may get stale data address in TRB + * at below sequences: + * 1. Controller read TRB includes data address + * 2. Software updates TRBs includes data address and Cycle bit + * 3. Controller read TRB which includes Cycle bit + * 4. DMA run with stale data address + * + * To fix this problem, driver needs to make the first TRB in TD as invalid. + * After preparing all TRBs driver needs to check the position of DMA and + * if the DMA point to the first just added TRB and doorbell is 1, + * then driver must defer making this TRB as valid. This TRB will be make + * as valid during adding next TRB only if DMA is stopped or at TRBERR + * interrupt. + * + * Issue has been fixed in DEV_VER_V3 version of controller. + * + * Work around 2: + * Controller for OUT endpoints has shared on-chip buffers for all incoming + * packets, including ep0out. It's FIFO buffer, so packets must be handle by DMA + * in correct order. If the first packet in the buffer will not be handled, + * then the following packets directed for other endpoints and functions + * will be blocked. + * Additionally the packets directed to one endpoint can block entire on-chip + * buffers. In this case transfer to other endpoints also will blocked. + * + * To resolve this issue after raising the descriptor missing interrupt + * driver prepares internal usb_request object and use it to arm DMA transfer. + * + * The problematic situation was observed in case when endpoint has been enabled + * but no usb_request were queued. Driver try detects such endpoints and will + * use this workaround only for these endpoint. + * + * Driver use limited number of buffer. This number can be set by macro + * CDNS3_WA2_NUM_BUFFERS. + * + * Such blocking situation was observed on ACM gadget. For this function + * host send OUT data packet but ACM function is not prepared for this packet. + * It's cause that buffer placed in on chip memory block transfer to other + * endpoints. + * + * Issue has been fixed in DEV_VER_V2 version of controller. + * + */ + +#include <dm.h> +#include <linux/usb/gadget.h> +#include <linux/compat.h> +#include <linux/iopoll.h> +#include <asm/dma-mapping.h> +#include <linux/bitmap.h> +#include <linux/bug.h> + +#include "core.h" +#include "gadget-export.h" +#include "gadget.h" +#include "trace.h" +#include "drd.h" + +#define readl_poll_timeout_atomic readl_poll_timeout +#define usleep_range(a, b) udelay((b)) + +static int __cdns3_gadget_ep_queue(struct usb_ep *ep, + struct usb_request *request, + gfp_t gfp_flags); + +/** + * cdns3_set_register_bit - set bit in given register. + * @ptr: address of device controller register to be read and changed + * @mask: bits requested to set + */ +void cdns3_set_register_bit(void __iomem *ptr, u32 mask) +{ + mask = readl(ptr) | mask; + writel(mask, ptr); +} + +/** + * cdns3_ep_addr_to_index - Macro converts endpoint address to + * index of endpoint object in cdns3_device.eps[] container + * @ep_addr: endpoint address for which endpoint object is required + * + */ +u8 cdns3_ep_addr_to_index(u8 ep_addr) +{ + return (((ep_addr & 0x7F)) + ((ep_addr & USB_DIR_IN) ? 16 : 0)); +} + +static int cdns3_get_dma_pos(struct cdns3_device *priv_dev, + struct cdns3_endpoint *priv_ep) +{ + int dma_index; + + dma_index = readl(&priv_dev->regs->ep_traddr) - priv_ep->trb_pool_dma; + + return dma_index / TRB_SIZE; +} + +/** + * cdns3_next_request - returns next request from list + * @list: list containing requests + * + * Returns request or NULL if no requests in list + */ +struct usb_request *cdns3_next_request(struct list_head *list) +{ + return list_first_entry_or_null(list, struct usb_request, list); +} + +/** + * cdns3_next_align_buf - returns next buffer from list + * @list: list containing buffers + * + * Returns buffer or NULL if no buffers in list + */ +struct cdns3_aligned_buf *cdns3_next_align_buf(struct list_head *list) +{ + return list_first_entry_or_null(list, struct cdns3_aligned_buf, list); +} + +/** + * cdns3_next_priv_request - returns next request from list + * @list: list containing requests + * + * Returns request or NULL if no requests in list + */ +struct cdns3_request *cdns3_next_priv_request(struct list_head *list) +{ + return list_first_entry_or_null(list, struct cdns3_request, list); +} + +/** + * select_ep - selects endpoint + * @priv_dev: extended gadget object + * @ep: endpoint address + */ +void cdns3_select_ep(struct cdns3_device *priv_dev, u32 ep) +{ + if (priv_dev->selected_ep == ep) + return; + + priv_dev->selected_ep = ep; + writel(ep, &priv_dev->regs->ep_sel); +} + +dma_addr_t cdns3_trb_virt_to_dma(struct cdns3_endpoint *priv_ep, + struct cdns3_trb *trb) +{ + u32 offset = (char *)trb - (char *)priv_ep->trb_pool; + + return priv_ep->trb_pool_dma + offset; +} + +int cdns3_ring_size(struct cdns3_endpoint *priv_ep) +{ + switch (priv_ep->type) { + case USB_ENDPOINT_XFER_ISOC: + return TRB_ISO_RING_SIZE; + case USB_ENDPOINT_XFER_CONTROL: + return TRB_CTRL_RING_SIZE; + default: + return TRB_RING_SIZE; + } +} + +/** + * cdns3_allocate_trb_pool - Allocates TRB's pool for selected endpoint + * @priv_ep: endpoint object + * + * Function will return 0 on success or -ENOMEM on allocation error + */ +int cdns3_allocate_trb_pool(struct cdns3_endpoint *priv_ep) +{ + int ring_size = cdns3_ring_size(priv_ep); + struct cdns3_trb *link_trb; + + if (!priv_ep->trb_pool) { + priv_ep->trb_pool = + dma_alloc_coherent(ring_size, + (unsigned long *)&priv_ep->trb_pool_dma); + if (!priv_ep->trb_pool) + return -ENOMEM; + } else { + memset(priv_ep->trb_pool, 0, ring_size); + } + + if (!priv_ep->num) + return 0; + + priv_ep->num_trbs = ring_size / TRB_SIZE; + /* Initialize the last TRB as Link TRB. */ + link_trb = (priv_ep->trb_pool + (priv_ep->num_trbs - 1)); + link_trb->buffer = TRB_BUFFER(priv_ep->trb_pool_dma); + link_trb->control = TRB_CYCLE | TRB_TYPE(TRB_LINK) | TRB_TOGGLE; + + return 0; +} + +static void cdns3_free_trb_pool(struct cdns3_endpoint *priv_ep) +{ + if (priv_ep->trb_pool) { + dma_free_coherent(priv_ep->trb_pool); + priv_ep->trb_pool = NULL; + } +} + +/** + * cdns3_ep_stall_flush - Stalls and flushes selected endpoint + * @priv_ep: endpoint object + * + * Endpoint must be selected before call to this function + */ +static void cdns3_ep_stall_flush(struct cdns3_endpoint *priv_ep) +{ + struct cdns3_device *priv_dev = priv_ep->cdns3_dev; + int val; + + trace_cdns3_halt(priv_ep, 1, 1); + + writel(EP_CMD_DFLUSH | EP_CMD_ERDY | EP_CMD_SSTALL, + &priv_dev->regs->ep_cmd); + + /* wait for DFLUSH cleared */ + readl_poll_timeout_atomic(&priv_dev->regs->ep_cmd, val, + !(val & EP_CMD_DFLUSH), 1000); + priv_ep->flags |= EP_STALLED; + priv_ep->flags &= ~EP_STALL_PENDING; +} + +/** + * cdns3_hw_reset_eps_config - reset endpoints configuration kept by controller. + * @priv_dev: extended gadget object + */ +void cdns3_hw_reset_eps_config(struct cdns3_device *priv_dev) +{ + writel(USB_CONF_CFGRST, &priv_dev->regs->usb_conf); + + cdns3_allow_enable_l1(priv_dev, 0); + priv_dev->hw_configured_flag = 0; + priv_dev->onchip_used_size = 0; + priv_dev->out_mem_is_allocated = 0; + priv_dev->wait_for_setup = 0; +} + +/** + * cdns3_ep_inc_trb - increment a trb index. + * @index: Pointer to the TRB index to increment. + * @cs: Cycle state + * @trb_in_seg: number of TRBs in segment + * + * The index should never point to the link TRB. After incrementing, + * if it is point to the link TRB, wrap around to the beginning and revert + * cycle state bit The + * link TRB is always at the last TRB entry. + */ +static void cdns3_ep_inc_trb(int *index, u8 *cs, int trb_in_seg) +{ + (*index)++; + if (*index == (trb_in_seg - 1)) { + *index = 0; + *cs ^= 1; + } +} + +/** + * cdns3_ep_inc_enq - increment endpoint's enqueue pointer + * @priv_ep: The endpoint whose enqueue pointer we're incrementing + */ +static void cdns3_ep_inc_enq(struct cdns3_endpoint *priv_ep) +{ + priv_ep->free_trbs--; + cdns3_ep_inc_trb(&priv_ep->enqueue, &priv_ep->pcs, priv_ep->num_trbs); +} + +/** + * cdns3_ep_inc_deq - increment endpoint's dequeue pointer + * @priv_ep: The endpoint whose dequeue pointer we're incrementing + */ +static void cdns3_ep_inc_deq(struct cdns3_endpoint *priv_ep) +{ + priv_ep->free_trbs++; + cdns3_ep_inc_trb(&priv_ep->dequeue, &priv_ep->ccs, priv_ep->num_trbs); +} + +void cdns3_move_deq_to_next_trb(struct cdns3_request *priv_req) +{ + struct cdns3_endpoint *priv_ep = priv_req->priv_ep; + int current_trb = priv_req->start_trb; + + while (current_trb != priv_req->end_trb) { + cdns3_ep_inc_deq(priv_ep); + current_trb = priv_ep->dequeue; + } + + cdns3_ep_inc_deq(priv_ep); +} + +/** + * cdns3_allow_enable_l1 - enable/disable permits to transition to L1. + * @priv_dev: Extended gadget object + * @enable: Enable/disable permit to transition to L1. + * + * If bit USB_CONF_L1EN is set and device receive Extended Token packet, + * then controller answer with ACK handshake. + * If bit USB_CONF_L1DS is set and device receive Extended Token packet, + * then controller answer with NYET handshake. + */ +void cdns3_allow_enable_l1(struct cdns3_device *priv_dev, int enable) +{ + if (enable) + writel(USB_CONF_L1EN, &priv_dev->regs->usb_conf); + else + writel(USB_CONF_L1DS, &priv_dev->regs->usb_conf); +} + +enum usb_device_speed cdns3_get_speed(struct cdns3_device *priv_dev) +{ + u32 reg; + + reg = readl(&priv_dev->regs->usb_sts); + + if (DEV_SUPERSPEED(reg)) + return USB_SPEED_SUPER; + else if (DEV_HIGHSPEED(reg)) + return USB_SPEED_HIGH; + else if (DEV_FULLSPEED(reg)) + return USB_SPEED_FULL; + else if (DEV_LOWSPEED(reg)) + return USB_SPEED_LOW; + return USB_SPEED_UNKNOWN; +} + +/** + * cdns3_start_all_request - add to ring all request not started + * @priv_dev: Extended gadget object + * @priv_ep: The endpoint for whom request will be started. + * + * Returns return ENOMEM if transfer ring i not enough TRBs to start + * all requests. + */ +static int cdns3_start_all_request(struct cdns3_device *priv_dev, + struct cdns3_endpoint *priv_ep) +{ + struct usb_request *request; + int ret = 0; + + while (!list_empty(&priv_ep->deferred_req_list)) { + request = cdns3_next_request(&priv_ep->deferred_req_list); + + ret = cdns3_ep_run_transfer(priv_ep, request); + if (ret) + return ret; + + list_del(&request->list); + list_add_tail(&request->list, + &priv_ep->pending_req_list); + } + + priv_ep->flags &= ~EP_RING_FULL; + return ret; +} + +/* + * WA2: Set flag for all not ISOC OUT endpoints. If this flag is set + * driver try to detect whether endpoint need additional internal + * buffer for unblocking on-chip FIFO buffer. This flag will be cleared + * if before first DESCMISS interrupt the DMA will be armed. + */ +#define cdns3_wa2_enable_detection(priv_dev, ep_priv, reg) do { \ + if (!priv_ep->dir && priv_ep->type != USB_ENDPOINT_XFER_ISOC) { \ + priv_ep->flags |= EP_QUIRK_EXTRA_BUF_DET; \ + (reg) |= EP_STS_EN_DESCMISEN; \ + } } while (0) + +/** + * cdns3_wa2_descmiss_copy_data copy data from internal requests to + * request queued by class driver. + * @priv_ep: extended endpoint object + * @request: request object + */ +static void cdns3_wa2_descmiss_copy_data(struct cdns3_endpoint *priv_ep, + struct usb_request *request) +{ + struct usb_request *descmiss_req; + struct cdns3_request *descmiss_priv_req; + + while (!list_empty(&priv_ep->wa2_descmiss_req_list)) { + int chunk_end; + int length; + + descmiss_priv_req = + cdns3_next_priv_request(&priv_ep->wa2_descmiss_req_list); + descmiss_req = &descmiss_priv_req->request; + + /* driver can't touch pending request */ + if (descmiss_priv_req->flags & REQUEST_PENDING) + break; + + chunk_end = descmiss_priv_req->flags & REQUEST_INTERNAL_CH; + length = request->actual + descmiss_req->actual; + + request->status = descmiss_req->status; + + if (length <= request->length) { + memcpy(&((u8 *)request->buf)[request->actual], + descmiss_req->buf, + descmiss_req->actual); + request->actual = length; + } else { + /* It should never occur */ + request->status = -ENOMEM; + } + + list_del_init(&descmiss_priv_req->list); + + kfree(descmiss_req->buf); + cdns3_gadget_ep_free_request(&priv_ep->endpoint, descmiss_req); + --priv_ep->wa2_counter; + + if (!chunk_end) + break; + } +} + +struct usb_request *cdns3_wa2_gadget_giveback(struct cdns3_device *priv_dev, + struct cdns3_endpoint *priv_ep, + struct cdns3_request *priv_req) +{ + if (priv_ep->flags & EP_QUIRK_EXTRA_BUF_EN && + priv_req->flags & REQUEST_INTERNAL) { + struct usb_request *req; + + req = cdns3_next_request(&priv_ep->deferred_req_list); + + priv_ep->descmis_req = NULL; + + if (!req) + return NULL; + + cdns3_wa2_descmiss_copy_data(priv_ep, req); + if (!(priv_ep->flags & EP_QUIRK_END_TRANSFER) && + req->length != req->actual) { + /* wait for next part of transfer */ + return NULL; + } + + if (req->status == -EINPROGRESS) + req->status = 0; + + list_del_init(&req->list); + cdns3_start_all_request(priv_dev, priv_ep); + return req; + } + + return &priv_req->request; +} + +int cdns3_wa2_gadget_ep_queue(struct cdns3_device *priv_dev, + struct cdns3_endpoint *priv_ep, + struct cdns3_request *priv_req) +{ + int deferred = 0; + + /* + * If transfer was queued before DESCMISS appear than we + * can disable handling of DESCMISS interrupt. Driver assumes that it + * can disable special treatment for this endpoint. + */ + if (priv_ep->flags & EP_QUIRK_EXTRA_BUF_DET) { + u32 reg; + + cdns3_select_ep(priv_dev, priv_ep->num | priv_ep->dir); + priv_ep->flags &= ~EP_QUIRK_EXTRA_BUF_DET; + reg = readl(&priv_dev->regs->ep_sts_en); + reg &= ~EP_STS_EN_DESCMISEN; + trace_cdns3_wa2(priv_ep, "workaround disabled\n"); + writel(reg, &priv_dev->regs->ep_sts_en); + } + + if (priv_ep->flags & EP_QUIRK_EXTRA_BUF_EN) { + u8 pending_empty = list_empty(&priv_ep->pending_req_list); + u8 descmiss_empty = list_empty(&priv_ep->wa2_descmiss_req_list); + + /* + * DESCMISS transfer has been finished, so data will be + * directly copied from internal allocated usb_request + * objects. + */ + if (pending_empty && !descmiss_empty && + !(priv_req->flags & REQUEST_INTERNAL)) { + cdns3_wa2_descmiss_copy_data(priv_ep, + &priv_req->request); + + trace_cdns3_wa2(priv_ep, "get internal stored data"); + + list_add_tail(&priv_req->request.list, + &priv_ep->pending_req_list); + cdns3_gadget_giveback(priv_ep, priv_req, + priv_req->request.status); + + /* + * Intentionally driver returns positive value as + * correct value. It informs that transfer has + * been finished. + */ + return EINPROGRESS; + } + + /* + * Driver will wait for completion DESCMISS transfer, + * before starts new, not DESCMISS transfer. + */ + if (!pending_empty && !descmiss_empty) { + trace_cdns3_wa2(priv_ep, "wait for pending transfer\n"); + deferred = 1; + } + + if (priv_req->flags & REQUEST_INTERNAL) + list_add_tail(&priv_req->list, + &priv_ep->wa2_descmiss_req_list); + } + + return deferred; +} + +static void cdns3_wa2_remove_old_request(struct cdns3_endpoint *priv_ep) +{ + struct cdns3_request *priv_req; + + while (!list_empty(&priv_ep->wa2_descmiss_req_list)) { + u8 chain; + + priv_req = cdns3_next_priv_request(&priv_ep->wa2_descmiss_req_list); + chain = !!(priv_req->flags & REQUEST_INTERNAL_CH); + + trace_cdns3_wa2(priv_ep, "removes eldest request"); + + kfree(priv_req->request.buf); + cdns3_gadget_ep_free_request(&priv_ep->endpoint, + &priv_req->request); + list_del_init(&priv_req->list); + --priv_ep->wa2_counter; + + if (!chain) + break; + } +} + +/** + * cdns3_wa2_descmissing_packet - handles descriptor missing event. + * @priv_dev: extended gadget object + * + * This function is used only for WA2. For more information see Work around 2 + * description. + */ +static void cdns3_wa2_descmissing_packet(struct cdns3_endpoint *priv_ep) +{ + struct cdns3_request *priv_req; + struct usb_request *request; + + if (priv_ep->flags & EP_QUIRK_EXTRA_BUF_DET) { + priv_ep->flags &= ~EP_QUIRK_EXTRA_BUF_DET; + priv_ep->flags |= EP_QUIRK_EXTRA_BUF_EN; + } + + trace_cdns3_wa2(priv_ep, "Description Missing detected\n"); + + if (priv_ep->wa2_counter >= CDNS3_WA2_NUM_BUFFERS) + cdns3_wa2_remove_old_request(priv_ep); + + request = cdns3_gadget_ep_alloc_request(&priv_ep->endpoint, + GFP_ATOMIC); + if (!request) + goto err; + + priv_req = to_cdns3_request(request); + priv_req->flags |= REQUEST_INTERNAL; + + /* if this field is still assigned it indicate that transfer related + * with this request has not been finished yet. Driver in this + * case simply allocate next request and assign flag REQUEST_INTERNAL_CH + * flag to previous one. It will indicate that current request is + * part of the previous one. + */ + if (priv_ep->descmis_req) + priv_ep->descmis_req->flags |= REQUEST_INTERNAL_CH; + + priv_req->request.buf = kzalloc(CDNS3_DESCMIS_BUF_SIZE, + GFP_ATOMIC); + priv_ep->wa2_counter++; + + if (!priv_req->request.buf) { + cdns3_gadget_ep_free_request(&priv_ep->endpoint, request); + goto err; + } + + priv_req->request.length = CDNS3_DESCMIS_BUF_SIZE; + priv_ep->descmis_req = priv_req; + + __cdns3_gadget_ep_queue(&priv_ep->endpoint, + &priv_ep->descmis_req->request, + GFP_ATOMIC); + + return; + +err: + dev_err(priv_ep->cdns3_dev->dev, + "Failed: No sufficient memory for DESCMIS\n"); +} + +/** + * cdns3_gadget_giveback - call struct usb_request's ->complete callback + * @priv_ep: The endpoint to whom the request belongs to + * @priv_req: The request we're giving back + * @status: completion code for the request + * + * Must be called with controller's lock held and interrupts disabled. This + * function will unmap @req and call its ->complete() callback to notify upper + * layers that it has completed. + */ +void cdns3_gadget_giveback(struct cdns3_endpoint *priv_ep, + struct cdns3_request *priv_req, + int status) +{ + struct cdns3_device *priv_dev = priv_ep->cdns3_dev; + struct usb_request *request = &priv_req->request; + + list_del_init(&request->list); + + if (request->status == -EINPROGRESS) + request->status = status; + + usb_gadget_unmap_request(&priv_dev->gadget, request, + priv_ep->dir); + + if ((priv_req->flags & REQUEST_UNALIGNED) && + priv_ep->dir == USB_DIR_OUT && !request->status) + memcpy(request->buf, priv_req->aligned_buf->buf, + request->length); + + priv_req->flags &= ~(REQUEST_PENDING | REQUEST_UNALIGNED); + trace_cdns3_gadget_giveback(priv_req); + + if (priv_dev->dev_ver < DEV_VER_V2) { + request = cdns3_wa2_gadget_giveback(priv_dev, priv_ep, + priv_req); + if (!request) + return; + } + + if (request->complete) { + spin_unlock(&priv_dev->lock); + usb_gadget_giveback_request(&priv_ep->endpoint, + request); + spin_lock(&priv_dev->lock); + } + + if (request->buf == priv_dev->zlp_buf) + cdns3_gadget_ep_free_request(&priv_ep->endpoint, request); +} + +void cdns3_wa1_restore_cycle_bit(struct cdns3_endpoint *priv_ep) +{ + /* Work around for stale data address in TRB*/ + if (priv_ep->wa1_set) { + trace_cdns3_wa1(priv_ep, "restore cycle bit"); + + priv_ep->wa1_set = 0; + priv_ep->wa1_trb_index = 0xFFFF; + if (priv_ep->wa1_cycle_bit) { + priv_ep->wa1_trb->control = + priv_ep->wa1_trb->control | 0x1; + } else { + priv_ep->wa1_trb->control = + priv_ep->wa1_trb->control & ~0x1; + } + } +} + +static void cdns3_free_aligned_request_buf(struct cdns3_device *priv_dev) +{ + struct cdns3_aligned_buf *buf, *tmp; + unsigned long flags; + + spin_lock_irqsave(&priv_dev->lock, flags); + + list_for_each_entry_safe(buf, tmp, &priv_dev->aligned_buf_list, list) { + if (!buf->in_use) { + list_del(&buf->list); + + /* + * Re-enable interrupts to free DMA capable memory. + * Driver can't free this memory with disabled + * interrupts. + */ + spin_unlock_irqrestore(&priv_dev->lock, flags); + dma_free_coherent(buf->buf); + kfree(buf); + spin_lock_irqsave(&priv_dev->lock, flags); + } + } + + spin_unlock_irqrestore(&priv_dev->lock, flags); +} + +static int cdns3_prepare_aligned_request_buf(struct cdns3_request *priv_req) +{ + struct cdns3_endpoint *priv_ep = priv_req->priv_ep; + struct cdns3_device *priv_dev = priv_ep->cdns3_dev; + struct cdns3_aligned_buf *buf; + + /* check if buffer is aligned to 8. */ + if (!((uintptr_t)priv_req->request.buf & 0x7)) + return 0; + + buf = priv_req->aligned_buf; + + if (!buf || priv_req->request.length > buf->size) { + buf = kzalloc(sizeof(*buf), GFP_ATOMIC); + if (!buf) + return -ENOMEM; + + buf->size = priv_req->request.length; + + buf->buf = dma_alloc_coherent(buf->size, + (unsigned long *)&buf->dma); + if (!buf->buf) { + kfree(buf); + return -ENOMEM; + } + + if (priv_req->aligned_buf) { + trace_cdns3_free_aligned_request(priv_req); + priv_req->aligned_buf->in_use = 0; +#ifndef __UBOOT__ + queue_work(system_freezable_wq, + &priv_dev->aligned_buf_wq); +#else + cdns3_free_aligned_request_buf(priv_dev); +#endif + } + + buf->in_use = 1; + priv_req->aligned_buf = buf; + + list_add_tail(&buf->list, + &priv_dev->aligned_buf_list); + } + + if (priv_ep->dir == USB_DIR_IN) { + memcpy(buf->buf, priv_req->request.buf, + priv_req->request.length); + } + + priv_req->flags |= REQUEST_UNALIGNED; + trace_cdns3_prepare_aligned_request(priv_req); + + return 0; +} + +static int cdns3_wa1_update_guard(struct cdns3_endpoint *priv_ep, + struct cdns3_trb *trb) +{ + struct cdns3_device *priv_dev = priv_ep->cdns3_dev; + + if (!priv_ep->wa1_set) { + u32 doorbell; + + doorbell = !!(readl(&priv_dev->regs->ep_cmd) & EP_CMD_DRDY); + + if (doorbell) { + priv_ep->wa1_cycle_bit = priv_ep->pcs ? TRB_CYCLE : 0; + priv_ep->wa1_set = 1; + priv_ep->wa1_trb = trb; + priv_ep->wa1_trb_index = priv_ep->enqueue; + trace_cdns3_wa1(priv_ep, "set guard"); + return 0; + } + } + return 1; +} + +static void cdns3_wa1_tray_restore_cycle_bit(struct cdns3_device *priv_dev, + struct cdns3_endpoint *priv_ep) +{ + int dma_index; + u32 doorbell; + + doorbell = !!(readl(&priv_dev->regs->ep_cmd) & EP_CMD_DRDY); + dma_index = cdns3_get_dma_pos(priv_dev, priv_ep); + + if (!doorbell || dma_index != priv_ep->wa1_trb_index) + cdns3_wa1_restore_cycle_bit(priv_ep); +} + +/** + * cdns3_ep_run_transfer - start transfer on no-default endpoint hardware + * @priv_ep: endpoint object + * + * Returns zero on success or negative value on failure + */ +int cdns3_ep_run_transfer(struct cdns3_endpoint *priv_ep, + struct usb_request *request) +{ + struct cdns3_device *priv_dev = priv_ep->cdns3_dev; + struct cdns3_request *priv_req; + struct cdns3_trb *trb; + dma_addr_t trb_dma; + u32 togle_pcs = 1; + int sg_iter = 0; + int num_trb = 1; + int address; + u32 control; + int pcs; + + if (num_trb > priv_ep->free_trbs) { + priv_ep->flags |= EP_RING_FULL; + return -ENOBUFS; + } + + priv_req = to_cdns3_request(request); + address = priv_ep->endpoint.desc->bEndpointAddress; + + priv_ep->flags |= EP_PENDING_REQUEST; + + /* must allocate buffer aligned to 8 */ + if (priv_req->flags & REQUEST_UNALIGNED) + trb_dma = priv_req->aligned_buf->dma; + else + trb_dma = request->dma; + + trb = priv_ep->trb_pool + priv_ep->enqueue; + priv_req->start_trb = priv_ep->enqueue; + priv_req->trb = trb; + + cdns3_select_ep(priv_ep->cdns3_dev, address); + + /* prepare ring */ + if ((priv_ep->enqueue + num_trb) >= (priv_ep->num_trbs - 1)) { + struct cdns3_trb *link_trb; + int doorbell, dma_index; + u32 ch_bit = 0; + + doorbell = !!(readl(&priv_dev->regs->ep_cmd) & EP_CMD_DRDY); + dma_index = cdns3_get_dma_pos(priv_dev, priv_ep); + + /* Driver can't update LINK TRB if it is current processed. */ + if (doorbell && dma_index == priv_ep->num_trbs - 1) { + priv_ep->flags |= EP_DEFERRED_DRDY; + return -ENOBUFS; + } + + /*updating C bt in Link TRB before starting DMA*/ + link_trb = priv_ep->trb_pool + (priv_ep->num_trbs - 1); + /* + * For TRs size equal 2 enabling TRB_CHAIN for epXin causes + * that DMA stuck at the LINK TRB. + * On the other hand, removing TRB_CHAIN for longer TRs for + * epXout cause that DMA stuck after handling LINK TRB. + * To eliminate this strange behavioral driver set TRB_CHAIN + * bit only for TR size > 2. + */ + if (priv_ep->type == USB_ENDPOINT_XFER_ISOC || + TRBS_PER_SEGMENT > 2) + ch_bit = TRB_CHAIN; + + link_trb->control = ((priv_ep->pcs) ? TRB_CYCLE : 0) | + TRB_TYPE(TRB_LINK) | TRB_TOGGLE | ch_bit; + } + + if (priv_dev->dev_ver <= DEV_VER_V2) + togle_pcs = cdns3_wa1_update_guard(priv_ep, trb); + + /* set incorrect Cycle Bit for first trb*/ + control = priv_ep->pcs ? 0 : TRB_CYCLE; + + do { + u32 length; + u16 td_size = 0; + + /* fill TRB */ + control |= TRB_TYPE(TRB_NORMAL); + trb->buffer = TRB_BUFFER(trb_dma); + + length = request->length; + + if (likely(priv_dev->dev_ver >= DEV_VER_V2)) + td_size = DIV_ROUND_UP(length, + priv_ep->endpoint.maxpacket); + + trb->length = TRB_BURST_LEN(priv_ep->trb_burst_size) | + TRB_LEN(length); + if (priv_dev->gadget.speed == USB_SPEED_SUPER) + trb->length |= TRB_TDL_SS_SIZE(td_size); + else + control |= TRB_TDL_HS_SIZE(td_size); + + pcs = priv_ep->pcs ? TRB_CYCLE : 0; + + /* + * first trb should be prepared as last to avoid processing + * transfer to early + */ + if (sg_iter != 0) + control |= pcs; + + if (priv_ep->type == USB_ENDPOINT_XFER_ISOC && !priv_ep->dir) { + control |= TRB_IOC | TRB_ISP; + } else { + /* for last element in TD or in SG list */ + if (sg_iter == (num_trb - 1) && sg_iter != 0) + control |= pcs | TRB_IOC | TRB_ISP; + } + + if (sg_iter) + trb->control = control; + else + priv_req->trb->control = control; + + control = 0; + ++sg_iter; + priv_req->end_trb = priv_ep->enqueue; + cdns3_ep_inc_enq(priv_ep); + trb = priv_ep->trb_pool + priv_ep->enqueue; + } while (sg_iter < num_trb); + + trb = priv_req->trb; + + priv_req->flags |= REQUEST_PENDING; + + if (sg_iter == 1) + trb->control |= TRB_IOC | TRB_ISP; + + /* + * Memory barrier - cycle bit must be set before other filds in trb. + */ + dmb(); + + /* give the TD to the consumer*/ + if (togle_pcs) + trb->control = trb->control ^ 1; + + if (priv_dev->dev_ver <= DEV_VER_V2) + cdns3_wa1_tray_restore_cycle_bit(priv_dev, priv_ep); + + trace_cdns3_prepare_trb(priv_ep, priv_req->trb); + + /* + * Memory barrier - Cycle Bit must be set before trb->length and + * trb->buffer fields. + */ + dmb(); + + /* + * For DMULT mode we can set address to transfer ring only once after + * enabling endpoint. + */ + if (priv_ep->flags & EP_UPDATE_EP_TRBADDR) { + /* + * Until SW is not ready to handle the OUT transfer the ISO OUT + * Endpoint should be disabled (EP_CFG.ENABLE = 0). + * EP_CFG_ENABLE must be set before updating ep_traddr. + */ + if (priv_ep->type == USB_ENDPOINT_XFER_ISOC && !priv_ep->dir && + !(priv_ep->flags & EP_QUIRK_ISO_OUT_EN)) { + priv_ep->flags |= EP_QUIRK_ISO_OUT_EN; + cdns3_set_register_bit(&priv_dev->regs->ep_cfg, + EP_CFG_ENABLE); + } + + writel(EP_TRADDR_TRADDR(priv_ep->trb_pool_dma + + priv_req->start_trb * TRB_SIZE), + &priv_dev->regs->ep_traddr); + + priv_ep->flags &= ~EP_UPDATE_EP_TRBADDR; + } + + if (!priv_ep->wa1_set && !(priv_ep->flags & EP_STALLED)) { + trace_cdns3_ring(priv_ep); + /*clearing TRBERR and EP_STS_DESCMIS before seting DRDY*/ + writel(EP_STS_TRBERR | EP_STS_DESCMIS, &priv_dev->regs->ep_sts); + writel(EP_CMD_DRDY, &priv_dev->regs->ep_cmd); + trace_cdns3_doorbell_epx(priv_ep->name, + readl(&priv_dev->regs->ep_traddr)); + } + + /* WORKAROUND for transition to L0 */ + __cdns3_gadget_wakeup(priv_dev); + + return 0; +} + +void cdns3_set_hw_configuration(struct cdns3_device *priv_dev) +{ + struct cdns3_endpoint *priv_ep; + struct usb_ep *ep; + int val; + + if (priv_dev->hw_configured_flag) + return; + + writel(USB_CONF_CFGSET, &priv_dev->regs->usb_conf); + writel(EP_CMD_ERDY | EP_CMD_REQ_CMPL, &priv_dev->regs->ep_cmd); + + cdns3_set_register_bit(&priv_dev->regs->usb_conf, + USB_CONF_U1EN | USB_CONF_U2EN); + + /* wait until configuration set */ + readl_poll_timeout_atomic(&priv_dev->regs->usb_sts, val, + val & USB_STS_CFGSTS_MASK, 100); + + priv_dev->hw_configured_flag = 1; + + list_for_each_entry(ep, &priv_dev->gadget.ep_list, ep_list) { + priv_ep = ep_to_cdns3_ep(ep); + if (priv_ep->flags & EP_ENABLED) + cdns3_start_all_request(priv_dev, priv_ep); + } +} + +/** + * cdns3_request_handled - check whether request has been handled by DMA + * + * @priv_ep: extended endpoint object. + * @priv_req: request object for checking + * + * Endpoint must be selected before invoking this function. + * + * Returns false if request has not been handled by DMA, else returns true. + * + * SR - start ring + * ER - end ring + * DQ = priv_ep->dequeue - dequeue position + * EQ = priv_ep->enqueue - enqueue position + * ST = priv_req->start_trb - index of first TRB in transfer ring + * ET = priv_req->end_trb - index of last TRB in transfer ring + * CI = current_index - index of processed TRB by DMA. + * + * As first step, function checks if cycle bit for priv_req->start_trb is + * correct. + * + * some rules: + * 1. priv_ep->dequeue never exceed current_index. + * 2 priv_ep->enqueue never exceed priv_ep->dequeue + * 3. exception: priv_ep->enqueue == priv_ep->dequeue + * and priv_ep->free_trbs is zero. + * This case indicate that TR is full. + * + * Then We can split recognition into two parts: + * Case 1 - priv_ep->dequeue < current_index + * SR ... EQ ... DQ ... CI ... ER + * SR ... DQ ... CI ... EQ ... ER + * + * Request has been handled by DMA if ST and ET is between DQ and CI. + * + * Case 2 - priv_ep->dequeue > current_index + * This situation take place when CI go through the LINK TRB at the end of + * transfer ring. + * SR ... CI ... EQ ... DQ ... ER + * + * Request has been handled by DMA if ET is less then CI or + * ET is greater or equal DQ. + */ +static bool cdns3_request_handled(struct cdns3_endpoint *priv_ep, + struct cdns3_request *priv_req) +{ + struct cdns3_device *priv_dev = priv_ep->cdns3_dev; + struct cdns3_trb *trb = priv_req->trb; + int current_index = 0; + int handled = 0; + int doorbell; + + current_index = cdns3_get_dma_pos(priv_dev, priv_ep); + doorbell = !!(readl(&priv_dev->regs->ep_cmd) & EP_CMD_DRDY); + + trb = &priv_ep->trb_pool[priv_req->start_trb]; + + if ((trb->control & TRB_CYCLE) != priv_ep->ccs) + goto finish; + + if (doorbell == 1 && current_index == priv_ep->dequeue) + goto finish; + + /* The corner case for TRBS_PER_SEGMENT equal 2). */ + if (TRBS_PER_SEGMENT == 2 && priv_ep->type != USB_ENDPOINT_XFER_ISOC) { + handled = 1; + goto finish; + } + + if (priv_ep->enqueue == priv_ep->dequeue && + priv_ep->free_trbs == 0) { + handled = 1; + } else if (priv_ep->dequeue < current_index) { + if ((current_index == (priv_ep->num_trbs - 1)) && + !priv_ep->dequeue) + goto finish; + + if (priv_req->end_trb >= priv_ep->dequeue && + priv_req->end_trb < current_index) + handled = 1; + } else if (priv_ep->dequeue > current_index) { + if (priv_req->end_trb < current_index || + priv_req->end_trb >= priv_ep->dequeue) + handled = 1; + } + +finish: + trace_cdns3_request_handled(priv_req, current_index, handled); + + return handled; +} + +static void cdns3_transfer_completed(struct cdns3_device *priv_dev, + struct cdns3_endpoint *priv_ep) +{ + struct cdns3_request *priv_req; + struct usb_request *request; + struct cdns3_trb *trb; + + while (!list_empty(&priv_ep->pending_req_list)) { + request = cdns3_next_request(&priv_ep->pending_req_list); + priv_req = to_cdns3_request(request); + + /* Re-select endpoint. It could be changed by other CPU during + * handling usb_gadget_giveback_request. + */ +#ifndef __UBOOT__ + cdns3_select_ep(priv_dev, priv_ep->endpoint.address); +#else + cdns3_select_ep(priv_dev, + priv_ep->endpoint.desc->bEndpointAddress); +#endif + + if (!cdns3_request_handled(priv_ep, priv_req)) + goto prepare_next_td; + + trb = priv_ep->trb_pool + priv_ep->dequeue; + trace_cdns3_complete_trb(priv_ep, trb); + + if (trb != priv_req->trb) + dev_warn(priv_dev->dev, + "request_trb=0x%p, queue_trb=0x%p\n", + priv_req->trb, trb); + + request->actual = TRB_LEN(le32_to_cpu(trb->length)); + cdns3_move_deq_to_next_trb(priv_req); + cdns3_gadget_giveback(priv_ep, priv_req, 0); + + if (priv_ep->type != USB_ENDPOINT_XFER_ISOC && + TRBS_PER_SEGMENT == 2) + break; + } + priv_ep->flags &= ~EP_PENDING_REQUEST; + +prepare_next_td: + if (!(priv_ep->flags & EP_STALLED) && + !(priv_ep->flags & EP_STALL_PENDING)) + cdns3_start_all_request(priv_dev, priv_ep); +} + +void cdns3_rearm_transfer(struct cdns3_endpoint *priv_ep, u8 rearm) +{ + struct cdns3_device *priv_dev = priv_ep->cdns3_dev; + + cdns3_wa1_restore_cycle_bit(priv_ep); + + if (rearm) { + trace_cdns3_ring(priv_ep); + + /* Cycle Bit must be updated before arming DMA. */ + dmb(); + writel(EP_CMD_DRDY, &priv_dev->regs->ep_cmd); + + __cdns3_gadget_wakeup(priv_dev); + + trace_cdns3_doorbell_epx(priv_ep->name, + readl(&priv_dev->regs->ep_traddr)); + } +} + +/** + * cdns3_check_ep_interrupt_proceed - Processes interrupt related to endpoint + * @priv_ep: endpoint object + * + * Returns 0 + */ +static int cdns3_check_ep_interrupt_proceed(struct cdns3_endpoint *priv_ep) +{ + struct cdns3_device *priv_dev = priv_ep->cdns3_dev; + u32 ep_sts_reg; + +#ifndef __UBOOT__ + cdns3_select_ep(priv_dev, priv_ep->endpoint.address); +#else + cdns3_select_ep(priv_dev, priv_ep->endpoint.desc->bEndpointAddress); +#endif + + trace_cdns3_epx_irq(priv_dev, priv_ep); + + ep_sts_reg = readl(&priv_dev->regs->ep_sts); + writel(ep_sts_reg, &priv_dev->regs->ep_sts); + + if (ep_sts_reg & EP_STS_TRBERR) { + if (priv_ep->flags & EP_STALL_PENDING && + !(ep_sts_reg & EP_STS_DESCMIS && + priv_dev->dev_ver < DEV_VER_V2)) { + cdns3_ep_stall_flush(priv_ep); + } + + /* + * For isochronous transfer driver completes request on + * IOC or on TRBERR. IOC appears only when device receive + * OUT data packet. If host disable stream or lost some packet + * then the only way to finish all queued transfer is to do it + * on TRBERR event. + */ + if (priv_ep->type == USB_ENDPOINT_XFER_ISOC && + !priv_ep->wa1_set) { + if (!priv_ep->dir) { + u32 ep_cfg = readl(&priv_dev->regs->ep_cfg); + + ep_cfg &= ~EP_CFG_ENABLE; + writel(ep_cfg, &priv_dev->regs->ep_cfg); + priv_ep->flags &= ~EP_QUIRK_ISO_OUT_EN; + } + cdns3_transfer_completed(priv_dev, priv_ep); + } else if (!(priv_ep->flags & EP_STALLED) && + !(priv_ep->flags & EP_STALL_PENDING)) { + if (priv_ep->flags & EP_DEFERRED_DRDY) { + priv_ep->flags &= ~EP_DEFERRED_DRDY; + cdns3_start_all_request(priv_dev, priv_ep); + } else { + cdns3_rearm_transfer(priv_ep, + priv_ep->wa1_set); + } + } + } + + if ((ep_sts_reg & EP_STS_IOC) || (ep_sts_reg & EP_STS_ISP)) { + if (priv_ep->flags & EP_QUIRK_EXTRA_BUF_EN) { + if (ep_sts_reg & EP_STS_ISP) + priv_ep->flags |= EP_QUIRK_END_TRANSFER; + else + priv_ep->flags &= ~EP_QUIRK_END_TRANSFER; + } + + cdns3_transfer_completed(priv_dev, priv_ep); + } + + /* + * WA2: this condition should only be meet when + * priv_ep->flags & EP_QUIRK_EXTRA_BUF_DET or + * priv_ep->flags & EP_QUIRK_EXTRA_BUF_EN. + * In other cases this interrupt will be disabled/ + */ + if (ep_sts_reg & EP_STS_DESCMIS && priv_dev->dev_ver < DEV_VER_V2 && + !(priv_ep->flags & EP_STALLED)) + cdns3_wa2_descmissing_packet(priv_ep); + + return 0; +} + +static void cdns3_disconnect_gadget(struct cdns3_device *priv_dev) +{ + if (priv_dev->gadget_driver && priv_dev->gadget_driver->disconnect) { + spin_unlock(&priv_dev->lock); + priv_dev->gadget_driver->disconnect(&priv_dev->gadget); + spin_lock(&priv_dev->lock); + } +} + +/** + * cdns3_check_usb_interrupt_proceed - Processes interrupt related to device + * @priv_dev: extended gadget object + * @usb_ists: bitmap representation of device's reported interrupts + * (usb_ists register value) + */ +static void cdns3_check_usb_interrupt_proceed(struct cdns3_device *priv_dev, + u32 usb_ists) +{ + int speed = 0; + + trace_cdns3_usb_irq(priv_dev, usb_ists); + if (usb_ists & USB_ISTS_L1ENTI) { + /* + * WORKAROUND: CDNS3 controller has issue with hardware resuming + * from L1. To fix it, if any DMA transfer is pending driver + * must starts driving resume signal immediately. + */ + if (readl(&priv_dev->regs->drbl)) + __cdns3_gadget_wakeup(priv_dev); + } + + /* Connection detected */ + if (usb_ists & (USB_ISTS_CON2I | USB_ISTS_CONI)) { + speed = cdns3_get_speed(priv_dev); + priv_dev->gadget.speed = speed; + usb_gadget_set_state(&priv_dev->gadget, USB_STATE_POWERED); + cdns3_ep0_config(priv_dev); + } + + /* Disconnection detected */ + if (usb_ists & (USB_ISTS_DIS2I | USB_ISTS_DISI)) { + cdns3_disconnect_gadget(priv_dev); + priv_dev->gadget.speed = USB_SPEED_UNKNOWN; + usb_gadget_set_state(&priv_dev->gadget, USB_STATE_NOTATTACHED); + cdns3_hw_reset_eps_config(priv_dev); + } + + if (usb_ists & (USB_ISTS_L2ENTI | USB_ISTS_U3ENTI)) { + if (priv_dev->gadget_driver && + priv_dev->gadget_driver->suspend) { + spin_unlock(&priv_dev->lock); + priv_dev->gadget_driver->suspend(&priv_dev->gadget); + spin_lock(&priv_dev->lock); + } + } + + if (usb_ists & (USB_ISTS_L2EXTI | USB_ISTS_U3EXTI)) { + if (priv_dev->gadget_driver && + priv_dev->gadget_driver->resume) { + spin_unlock(&priv_dev->lock); + priv_dev->gadget_driver->resume(&priv_dev->gadget); + spin_lock(&priv_dev->lock); + } + } + + /* reset*/ + if (usb_ists & (USB_ISTS_UWRESI | USB_ISTS_UHRESI | USB_ISTS_U2RESI)) { + if (priv_dev->gadget_driver) { + spin_unlock(&priv_dev->lock); + usb_gadget_udc_reset(&priv_dev->gadget, + priv_dev->gadget_driver); + spin_lock(&priv_dev->lock); + + /*read again to check the actual speed*/ + speed = cdns3_get_speed(priv_dev); + priv_dev->gadget.speed = speed; + cdns3_hw_reset_eps_config(priv_dev); + cdns3_ep0_config(priv_dev); + } + } +} + +/** + * cdns3_device_irq_handler- interrupt handler for device part of controller + * + * @irq: irq number for cdns3 core device + * @data: structure of cdns3 + * + * Returns IRQ_HANDLED or IRQ_NONE + */ +static irqreturn_t cdns3_device_irq_handler(int irq, void *data) +{ + struct cdns3_device *priv_dev; + struct cdns3 *cdns = data; + irqreturn_t ret = IRQ_NONE; + u32 reg; + + priv_dev = cdns->gadget_dev; + + /* check USB device interrupt */ + reg = readl(&priv_dev->regs->usb_ists); + if (reg) { + /* After masking interrupts the new interrupts won't be + * reported in usb_ists/ep_ists. In order to not lose some + * of them driver disables only detected interrupts. + * They will be enabled ASAP after clearing source of + * interrupt. This an unusual behavior only applies to + * usb_ists register. + */ + reg = ~reg & readl(&priv_dev->regs->usb_ien); + /* mask deferred interrupt. */ + writel(reg, &priv_dev->regs->usb_ien); + ret = IRQ_WAKE_THREAD; + } + + /* check endpoint interrupt */ + reg = readl(&priv_dev->regs->ep_ists); + if (reg) { + writel(0, &priv_dev->regs->ep_ien); + ret = IRQ_WAKE_THREAD; + } + + return ret; +} + +/** + * cdns3_device_thread_irq_handler- interrupt handler for device part + * of controller + * + * @irq: irq number for cdns3 core device + * @data: structure of cdns3 + * + * Returns IRQ_HANDLED or IRQ_NONE + */ +static irqreturn_t cdns3_device_thread_irq_handler(int irq, void *data) +{ + struct cdns3_device *priv_dev; + struct cdns3 *cdns = data; + irqreturn_t ret = IRQ_NONE; + unsigned long flags; + int bit; + u32 reg; + + priv_dev = cdns->gadget_dev; + spin_lock_irqsave(&priv_dev->lock, flags); + + reg = readl(&priv_dev->regs->usb_ists); + if (reg) { + writel(reg, &priv_dev->regs->usb_ists); + writel(USB_IEN_INIT, &priv_dev->regs->usb_ien); + cdns3_check_usb_interrupt_proceed(priv_dev, reg); + ret = IRQ_HANDLED; + } + + reg = readl(&priv_dev->regs->ep_ists); + + /* handle default endpoint OUT */ + if (reg & EP_ISTS_EP_OUT0) { + cdns3_check_ep0_interrupt_proceed(priv_dev, USB_DIR_OUT); + ret = IRQ_HANDLED; + } + + /* handle default endpoint IN */ + if (reg & EP_ISTS_EP_IN0) { + cdns3_check_ep0_interrupt_proceed(priv_dev, USB_DIR_IN); + ret = IRQ_HANDLED; + } + + /* check if interrupt from non default endpoint, if no exit */ + reg &= ~(EP_ISTS_EP_OUT0 | EP_ISTS_EP_IN0); + if (!reg) + goto irqend; + + for_each_set_bit(bit, (unsigned long *)®, + sizeof(u32) * BITS_PER_BYTE) { + cdns3_check_ep_interrupt_proceed(priv_dev->eps[bit]); + ret = IRQ_HANDLED; + } + +irqend: + writel(~0, &priv_dev->regs->ep_ien); + spin_unlock_irqrestore(&priv_dev->lock, flags); + + return ret; +} + +/** + * cdns3_ep_onchip_buffer_reserve - Try to reserve onchip buf for EP + * + * The real reservation will occur during write to EP_CFG register, + * this function is used to check if the 'size' reservation is allowed. + * + * @priv_dev: extended gadget object + * @size: the size (KB) for EP would like to allocate + * @is_in: endpoint direction + * + * Return 0 if the required size can met or negative value on failure + */ +static int cdns3_ep_onchip_buffer_reserve(struct cdns3_device *priv_dev, + int size, int is_in) +{ + int remained; + + /* 2KB are reserved for EP0*/ + remained = priv_dev->onchip_buffers - priv_dev->onchip_used_size - 2; + + if (is_in) { + if (remained < size) + return -EPERM; + + priv_dev->onchip_used_size += size; + } else { + int required; + + /** + * ALL OUT EPs are shared the same chunk onchip memory, so + * driver checks if it already has assigned enough buffers + */ + if (priv_dev->out_mem_is_allocated >= size) + return 0; + + required = size - priv_dev->out_mem_is_allocated; + + if (required > remained) + return -EPERM; + + priv_dev->out_mem_is_allocated += required; + priv_dev->onchip_used_size += required; + } + + return 0; +} + +void cdns3_configure_dmult(struct cdns3_device *priv_dev, + struct cdns3_endpoint *priv_ep) +{ + struct cdns3_usb_regs __iomem *regs = priv_dev->regs; + + /* For dev_ver > DEV_VER_V2 DMULT is configured per endpoint */ + if (priv_dev->dev_ver <= DEV_VER_V2) + writel(USB_CONF_DMULT, ®s->usb_conf); + + if (priv_dev->dev_ver == DEV_VER_V2) + writel(USB_CONF2_EN_TDL_TRB, ®s->usb_conf2); + + if (priv_dev->dev_ver >= DEV_VER_V3 && priv_ep) { + u32 mask; + + if (priv_ep->dir) + mask = BIT(priv_ep->num + 16); + else + mask = BIT(priv_ep->num); + + if (priv_ep->type != USB_ENDPOINT_XFER_ISOC) { + cdns3_set_register_bit(®s->tdl_from_trb, mask); + cdns3_set_register_bit(®s->tdl_beh, mask); + cdns3_set_register_bit(®s->tdl_beh2, mask); + cdns3_set_register_bit(®s->dma_adv_td, mask); + } + + if (priv_ep->type == USB_ENDPOINT_XFER_ISOC && !priv_ep->dir) + cdns3_set_register_bit(®s->tdl_from_trb, mask); + + cdns3_set_register_bit(®s->dtrans, mask); + } +} + +/** + * cdns3_ep_config Configure hardware endpoint + * @priv_ep: extended endpoint object + */ +void cdns3_ep_config(struct cdns3_endpoint *priv_ep) +{ + bool is_iso_ep = (priv_ep->type == USB_ENDPOINT_XFER_ISOC); + struct cdns3_device *priv_dev = priv_ep->cdns3_dev; + u32 bEndpointAddress = priv_ep->num | priv_ep->dir; + u32 max_packet_size = 0; + u8 maxburst = 0; + u32 ep_cfg = 0; + u8 buffering; + u8 mult = 0; + int ret; + + buffering = CDNS3_EP_BUF_SIZE - 1; + + cdns3_configure_dmult(priv_dev, priv_ep); + + switch (priv_ep->type) { + case USB_ENDPOINT_XFER_INT: + ep_cfg = EP_CFG_EPTYPE(USB_ENDPOINT_XFER_INT); + + if ((priv_dev->dev_ver == DEV_VER_V2 && !priv_ep->dir) || + priv_dev->dev_ver > DEV_VER_V2) + ep_cfg |= EP_CFG_TDL_CHK; + break; + case USB_ENDPOINT_XFER_BULK: + ep_cfg = EP_CFG_EPTYPE(USB_ENDPOINT_XFER_BULK); + + if ((priv_dev->dev_ver == DEV_VER_V2 && !priv_ep->dir) || + priv_dev->dev_ver > DEV_VER_V2) + ep_cfg |= EP_CFG_TDL_CHK; + break; + default: + ep_cfg = EP_CFG_EPTYPE(USB_ENDPOINT_XFER_ISOC); + mult = CDNS3_EP_ISO_HS_MULT - 1; + buffering = mult + 1; + } + + switch (priv_dev->gadget.speed) { + case USB_SPEED_FULL: + max_packet_size = is_iso_ep ? 1023 : 64; + break; + case USB_SPEED_HIGH: + max_packet_size = is_iso_ep ? 1024 : 512; + break; + case USB_SPEED_SUPER: + /* It's limitation that driver assumes in driver. */ + mult = 0; + max_packet_size = 1024; + if (priv_ep->type == USB_ENDPOINT_XFER_ISOC) { + maxburst = CDNS3_EP_ISO_SS_BURST - 1; + buffering = (mult + 1) * + (maxburst + 1); + + if (priv_ep->interval > 1) + buffering++; + } else { + maxburst = CDNS3_EP_BUF_SIZE - 1; + } + break; + default: + /* all other speed are not supported */ + return; + } + + if (max_packet_size == 1024) + priv_ep->trb_burst_size = 128; + else if (max_packet_size >= 512) + priv_ep->trb_burst_size = 64; + else + priv_ep->trb_burst_size = 16; + + ret = cdns3_ep_onchip_buffer_reserve(priv_dev, buffering + 1, + !!priv_ep->dir); + if (ret) { + dev_err(priv_dev->dev, "onchip mem is full, ep is invalid\n"); + return; + } + + ep_cfg |= EP_CFG_MAXPKTSIZE(max_packet_size) | + EP_CFG_MULT(mult) | + EP_CFG_BUFFERING(buffering) | + EP_CFG_MAXBURST(maxburst); + + cdns3_select_ep(priv_dev, bEndpointAddress); + writel(ep_cfg, &priv_dev->regs->ep_cfg); + + dev_dbg(priv_dev->dev, "Configure %s: with val %08x\n", + priv_ep->name, ep_cfg); +} + +/* Find correct direction for HW endpoint according to description */ +static int cdns3_ep_dir_is_correct(struct usb_endpoint_descriptor *desc, + struct cdns3_endpoint *priv_ep) +{ + return (priv_ep->endpoint.caps.dir_in && usb_endpoint_dir_in(desc)) || + (priv_ep->endpoint.caps.dir_out && usb_endpoint_dir_out(desc)); +} + +static struct +cdns3_endpoint *cdns3_find_available_ep(struct cdns3_device *priv_dev, + struct usb_endpoint_descriptor *desc) +{ + struct usb_ep *ep; + struct cdns3_endpoint *priv_ep; + + list_for_each_entry(ep, &priv_dev->gadget.ep_list, ep_list) { + unsigned long num; + /* ep name pattern likes epXin or epXout */ + char c[2] = {ep->name[2], '\0'}; + + num = simple_strtoul(c, NULL, 10); + + priv_ep = ep_to_cdns3_ep(ep); + if (cdns3_ep_dir_is_correct(desc, priv_ep)) { + if (!(priv_ep->flags & EP_CLAIMED)) { + priv_ep->num = num; + return priv_ep; + } + } + } + + return ERR_PTR(-ENOENT); +} + +/* + * Cadence IP has one limitation that all endpoints must be configured + * (Type & MaxPacketSize) before setting configuration through hardware + * register, it means we can't change endpoints configuration after + * set_configuration. + * + * This function set EP_CLAIMED flag which is added when the gadget driver + * uses usb_ep_autoconfig to configure specific endpoint; + * When the udc driver receives set_configurion request, + * it goes through all claimed endpoints, and configure all endpoints + * accordingly. + * + * At usb_ep_ops.enable/disable, we only enable and disable endpoint through + * ep_cfg register which can be changed after set_configuration, and do + * some software operation accordingly. + */ +static struct +usb_ep *cdns3_gadget_match_ep(struct usb_gadget *gadget, + struct usb_endpoint_descriptor *desc, + struct usb_ss_ep_comp_descriptor *comp_desc) +{ + struct cdns3_device *priv_dev = gadget_to_cdns3_device(gadget); + struct cdns3_endpoint *priv_ep; + unsigned long flags; + + priv_ep = cdns3_find_available_ep(priv_dev, desc); + if (IS_ERR(priv_ep)) { + dev_err(priv_dev->dev, "no available ep\n"); + return NULL; + } + + dev_dbg(priv_dev->dev, "match endpoint: %s\n", priv_ep->name); + + spin_lock_irqsave(&priv_dev->lock, flags); + priv_ep->endpoint.desc = desc; + priv_ep->dir = usb_endpoint_dir_in(desc) ? USB_DIR_IN : USB_DIR_OUT; + priv_ep->type = usb_endpoint_type(desc); + priv_ep->flags |= EP_CLAIMED; + priv_ep->interval = desc->bInterval ? BIT(desc->bInterval - 1) : 0; + + spin_unlock_irqrestore(&priv_dev->lock, flags); + return &priv_ep->endpoint; +} + +/** + * cdns3_gadget_ep_alloc_request Allocates request + * @ep: endpoint object associated with request + * @gfp_flags: gfp flags + * + * Returns allocated request address, NULL on allocation error + */ +struct usb_request *cdns3_gadget_ep_alloc_request(struct usb_ep *ep, + gfp_t gfp_flags) +{ + struct cdns3_endpoint *priv_ep = ep_to_cdns3_ep(ep); + struct cdns3_request *priv_req; + + priv_req = kzalloc(sizeof(*priv_req), gfp_flags); + if (!priv_req) + return NULL; + + priv_req->priv_ep = priv_ep; + + trace_cdns3_alloc_request(priv_req); + return &priv_req->request; +} + +/** + * cdns3_gadget_ep_free_request Free memory occupied by request + * @ep: endpoint object associated with request + * @request: request to free memory + */ +void cdns3_gadget_ep_free_request(struct usb_ep *ep, + struct usb_request *request) +{ + struct cdns3_request *priv_req = to_cdns3_request(request); + + if (priv_req->aligned_buf) + priv_req->aligned_buf->in_use = 0; + + trace_cdns3_free_request(priv_req); + kfree(priv_req); +} + +/** + * cdns3_gadget_ep_enable Enable endpoint + * @ep: endpoint object + * @desc: endpoint descriptor + * + * Returns 0 on success, error code elsewhere + */ +static int cdns3_gadget_ep_enable(struct usb_ep *ep, + const struct usb_endpoint_descriptor *desc) +{ + struct cdns3_endpoint *priv_ep; + struct cdns3_device *priv_dev; + u32 reg = EP_STS_EN_TRBERREN; + u32 bEndpointAddress; + unsigned long flags; + int enable = 1; + int ret; + int val; + + priv_ep = ep_to_cdns3_ep(ep); + priv_dev = priv_ep->cdns3_dev; + + if (!ep || !desc || desc->bDescriptorType != USB_DT_ENDPOINT) { + dev_dbg(priv_dev->dev, "usbss: invalid parameters\n"); + return -EINVAL; + } + + if (!desc->wMaxPacketSize) { + dev_err(priv_dev->dev, "usbss: missing wMaxPacketSize\n"); + return -EINVAL; + } + + if (WARN_ON(priv_ep->flags & EP_ENABLED)) + return 0; + + spin_lock_irqsave(&priv_dev->lock, flags); + + priv_ep->endpoint.desc = desc; + priv_ep->type = usb_endpoint_type(desc); + priv_ep->interval = desc->bInterval ? BIT(desc->bInterval - 1) : 0; + + if (priv_ep->interval > ISO_MAX_INTERVAL && + priv_ep->type == USB_ENDPOINT_XFER_ISOC) { + dev_err(priv_dev->dev, "Driver is limited to %d period\n", + ISO_MAX_INTERVAL); + + ret = -EINVAL; + goto exit; + } + + ret = cdns3_allocate_trb_pool(priv_ep); + + if (ret) + goto exit; + + bEndpointAddress = priv_ep->num | priv_ep->dir; + cdns3_select_ep(priv_dev, bEndpointAddress); + + trace_cdns3_gadget_ep_enable(priv_ep); + + writel(EP_CMD_EPRST, &priv_dev->regs->ep_cmd); + + ret = readl_poll_timeout_atomic(&priv_dev->regs->ep_cmd, val, + !(val & (EP_CMD_CSTALL | EP_CMD_EPRST)), + 1000); + + if (unlikely(ret)) { + cdns3_free_trb_pool(priv_ep); + ret = -EINVAL; + goto exit; + } + + /* enable interrupt for selected endpoint */ + cdns3_set_register_bit(&priv_dev->regs->ep_ien, + BIT(cdns3_ep_addr_to_index(bEndpointAddress))); + + if (priv_dev->dev_ver < DEV_VER_V2) + cdns3_wa2_enable_detection(priv_dev, priv_ep, reg); + + writel(reg, &priv_dev->regs->ep_sts_en); + + /* + * For some versions of controller at some point during ISO OUT traffic + * DMA reads Transfer Ring for the EP which has never got doorbell. + * This issue was detected only on simulation, but to avoid this issue + * driver add protection against it. To fix it driver enable ISO OUT + * endpoint before setting DRBL. This special treatment of ISO OUT + * endpoints are recommended by controller specification. + */ + if (priv_ep->type == USB_ENDPOINT_XFER_ISOC && !priv_ep->dir) + enable = 0; + + if (enable) + cdns3_set_register_bit(&priv_dev->regs->ep_cfg, EP_CFG_ENABLE); + + ep->desc = desc; + priv_ep->flags &= ~(EP_PENDING_REQUEST | EP_STALLED | EP_STALL_PENDING | + EP_QUIRK_ISO_OUT_EN | EP_QUIRK_EXTRA_BUF_EN); + priv_ep->flags |= EP_ENABLED | EP_UPDATE_EP_TRBADDR; + priv_ep->wa1_set = 0; + priv_ep->enqueue = 0; + priv_ep->dequeue = 0; + reg = readl(&priv_dev->regs->ep_sts); + priv_ep->pcs = !!EP_STS_CCS(reg); + priv_ep->ccs = !!EP_STS_CCS(reg); + /* one TRB is reserved for link TRB used in DMULT mode*/ + priv_ep->free_trbs = priv_ep->num_trbs - 1; +exit: + spin_unlock_irqrestore(&priv_dev->lock, flags); + + return ret; +} + +/** + * cdns3_gadget_ep_disable Disable endpoint + * @ep: endpoint object + * + * Returns 0 on success, error code elsewhere + */ +static int cdns3_gadget_ep_disable(struct usb_ep *ep) +{ + struct cdns3_endpoint *priv_ep; + struct cdns3_request *priv_req; + struct cdns3_device *priv_dev; + struct usb_request *request; + unsigned long flags; + int ret = 0; + u32 ep_cfg; + int val; + + if (!ep) { + pr_err("usbss: invalid parameters\n"); + return -EINVAL; + } + + priv_ep = ep_to_cdns3_ep(ep); + priv_dev = priv_ep->cdns3_dev; + + if (WARN_ON(!(priv_ep->flags & EP_ENABLED))) + return 0; + + spin_lock_irqsave(&priv_dev->lock, flags); + + trace_cdns3_gadget_ep_disable(priv_ep); + + cdns3_select_ep(priv_dev, ep->desc->bEndpointAddress); + + ep_cfg = readl(&priv_dev->regs->ep_cfg); + ep_cfg &= ~EP_CFG_ENABLE; + writel(ep_cfg, &priv_dev->regs->ep_cfg); + + /** + * Driver needs some time before resetting endpoint. + * It need waits for clearing DBUSY bit or for timeout expired. + * 10us is enough time for controller to stop transfer. + */ + readl_poll_timeout_atomic(&priv_dev->regs->ep_sts, val, + !(val & EP_STS_DBUSY), 10); + writel(EP_CMD_EPRST, &priv_dev->regs->ep_cmd); + + readl_poll_timeout_atomic(&priv_dev->regs->ep_cmd, val, + !(val & (EP_CMD_CSTALL | EP_CMD_EPRST)), + 1000); + if (unlikely(ret)) + dev_err(priv_dev->dev, "Timeout: %s resetting failed.\n", + priv_ep->name); + + while (!list_empty(&priv_ep->pending_req_list)) { + request = cdns3_next_request(&priv_ep->pending_req_list); + + cdns3_gadget_giveback(priv_ep, to_cdns3_request(request), + -ESHUTDOWN); + } + + while (!list_empty(&priv_ep->wa2_descmiss_req_list)) { + priv_req = cdns3_next_priv_request(&priv_ep->wa2_descmiss_req_list); + + kfree(priv_req->request.buf); + cdns3_gadget_ep_free_request(&priv_ep->endpoint, + &priv_req->request); + list_del_init(&priv_req->list); + --priv_ep->wa2_counter; + } + + while (!list_empty(&priv_ep->deferred_req_list)) { + request = cdns3_next_request(&priv_ep->deferred_req_list); + + cdns3_gadget_giveback(priv_ep, to_cdns3_request(request), + -ESHUTDOWN); + } + + priv_ep->descmis_req = NULL; + + ep->desc = NULL; + priv_ep->flags &= ~EP_ENABLED; + + spin_unlock_irqrestore(&priv_dev->lock, flags); + + return ret; +} + +/** + * cdns3_gadget_ep_queue Transfer data on endpoint + * @ep: endpoint object + * @request: request object + * @gfp_flags: gfp flags + * + * Returns 0 on success, error code elsewhere + */ +static int __cdns3_gadget_ep_queue(struct usb_ep *ep, + struct usb_request *request, + gfp_t gfp_flags) +{ + struct cdns3_endpoint *priv_ep = ep_to_cdns3_ep(ep); + struct cdns3_device *priv_dev = priv_ep->cdns3_dev; + struct cdns3_request *priv_req; + int ret = 0; + + request->actual = 0; + request->status = -EINPROGRESS; + priv_req = to_cdns3_request(request); + trace_cdns3_ep_queue(priv_req); + + if (priv_dev->dev_ver < DEV_VER_V2) { + ret = cdns3_wa2_gadget_ep_queue(priv_dev, priv_ep, + priv_req); + + if (ret == EINPROGRESS) + return 0; + } + + ret = cdns3_prepare_aligned_request_buf(priv_req); + if (ret < 0) + return ret; + + ret = usb_gadget_map_request(&priv_dev->gadget, request, + usb_endpoint_dir_in(ep->desc)); + if (ret) + return ret; + + list_add_tail(&request->list, &priv_ep->deferred_req_list); + + /* + * If hardware endpoint configuration has not been set yet then + * just queue request in deferred list. Transfer will be started in + * cdns3_set_hw_configuration. + */ + if (priv_dev->hw_configured_flag && !(priv_ep->flags & EP_STALLED) && + !(priv_ep->flags & EP_STALL_PENDING)) + cdns3_start_all_request(priv_dev, priv_ep); + + return 0; +} + +static int cdns3_gadget_ep_queue(struct usb_ep *ep, struct usb_request *request, + gfp_t gfp_flags) +{ + struct usb_request *zlp_request; + struct cdns3_endpoint *priv_ep; + struct cdns3_device *priv_dev; + unsigned long flags; + int ret; + + if (!request || !ep) + return -EINVAL; + + priv_ep = ep_to_cdns3_ep(ep); + priv_dev = priv_ep->cdns3_dev; + + spin_lock_irqsave(&priv_dev->lock, flags); + + ret = __cdns3_gadget_ep_queue(ep, request, gfp_flags); + + if (ret == 0 && request->zero && request->length && + (request->length % ep->maxpacket == 0)) { + struct cdns3_request *priv_req; + + zlp_request = cdns3_gadget_ep_alloc_request(ep, GFP_ATOMIC); + zlp_request->buf = priv_dev->zlp_buf; + zlp_request->length = 0; + + priv_req = to_cdns3_request(zlp_request); + priv_req->flags |= REQUEST_ZLP; + + dev_dbg(priv_dev->dev, "Queuing ZLP for endpoint: %s\n", + priv_ep->name); + ret = __cdns3_gadget_ep_queue(ep, zlp_request, gfp_flags); + } + + spin_unlock_irqrestore(&priv_dev->lock, flags); + return ret; +} + +/** + * cdns3_gadget_ep_dequeue Remove request from transfer queue + * @ep: endpoint object associated with request + * @request: request object + * + * Returns 0 on success, error code elsewhere + */ +int cdns3_gadget_ep_dequeue(struct usb_ep *ep, + struct usb_request *request) +{ + struct cdns3_endpoint *priv_ep = ep_to_cdns3_ep(ep); + struct cdns3_device *priv_dev = priv_ep->cdns3_dev; + struct usb_request *req, *req_temp; + struct cdns3_request *priv_req; + struct cdns3_trb *link_trb; + unsigned long flags; + int ret = 0; + + if (!ep || !request || !ep->desc) + return -EINVAL; + + spin_lock_irqsave(&priv_dev->lock, flags); + + priv_req = to_cdns3_request(request); + + trace_cdns3_ep_dequeue(priv_req); + + cdns3_select_ep(priv_dev, ep->desc->bEndpointAddress); + + list_for_each_entry_safe(req, req_temp, &priv_ep->pending_req_list, + list) { + if (request == req) + goto found; + } + + list_for_each_entry_safe(req, req_temp, &priv_ep->deferred_req_list, + list) { + if (request == req) + goto found; + } + + goto not_found; + +found: + + if (priv_ep->wa1_trb == priv_req->trb) + cdns3_wa1_restore_cycle_bit(priv_ep); + + link_trb = priv_req->trb; + cdns3_move_deq_to_next_trb(priv_req); + cdns3_gadget_giveback(priv_ep, priv_req, -ECONNRESET); + + /* Update ring */ + request = cdns3_next_request(&priv_ep->deferred_req_list); + if (request) { + priv_req = to_cdns3_request(request); + + link_trb->buffer = TRB_BUFFER(priv_ep->trb_pool_dma + + (priv_req->start_trb * TRB_SIZE)); + link_trb->control = (link_trb->control & TRB_CYCLE) | + TRB_TYPE(TRB_LINK) | TRB_CHAIN | TRB_TOGGLE; + } else { + priv_ep->flags |= EP_UPDATE_EP_TRBADDR; + } + +not_found: + spin_unlock_irqrestore(&priv_dev->lock, flags); + return ret; +} + +/** + * __cdns3_gadget_ep_set_halt Sets stall on selected endpoint + * Should be called after acquiring spin_lock and selecting ep + * @ep: endpoint object to set stall on. + */ +void __cdns3_gadget_ep_set_halt(struct cdns3_endpoint *priv_ep) +{ + struct cdns3_device *priv_dev = priv_ep->cdns3_dev; + + trace_cdns3_halt(priv_ep, 1, 0); + + if (!(priv_ep->flags & EP_STALLED)) { + u32 ep_sts_reg = readl(&priv_dev->regs->ep_sts); + + if (!(ep_sts_reg & EP_STS_DBUSY)) + cdns3_ep_stall_flush(priv_ep); + else + priv_ep->flags |= EP_STALL_PENDING; + } +} + +/** + * __cdns3_gadget_ep_clear_halt Clears stall on selected endpoint + * Should be called after acquiring spin_lock and selecting ep + * @ep: endpoint object to clear stall on + */ +int __cdns3_gadget_ep_clear_halt(struct cdns3_endpoint *priv_ep) +{ + struct cdns3_device *priv_dev = priv_ep->cdns3_dev; + struct usb_request *request; + int ret = 0; + int val; + + trace_cdns3_halt(priv_ep, 0, 0); + + writel(EP_CMD_CSTALL | EP_CMD_EPRST, &priv_dev->regs->ep_cmd); + + /* wait for EPRST cleared */ + readl_poll_timeout_atomic(&priv_dev->regs->ep_cmd, val, + !(val & EP_CMD_EPRST), 100); + if (ret) + return -EINVAL; + + priv_ep->flags &= ~(EP_STALLED | EP_STALL_PENDING); + + request = cdns3_next_request(&priv_ep->pending_req_list); + + if (request) + cdns3_rearm_transfer(priv_ep, 1); + + cdns3_start_all_request(priv_dev, priv_ep); + return ret; +} + +/** + * cdns3_gadget_ep_set_halt Sets/clears stall on selected endpoint + * @ep: endpoint object to set/clear stall on + * @value: 1 for set stall, 0 for clear stall + * + * Returns 0 on success, error code elsewhere + */ +int cdns3_gadget_ep_set_halt(struct usb_ep *ep, int value) +{ + struct cdns3_endpoint *priv_ep = ep_to_cdns3_ep(ep); + struct cdns3_device *priv_dev = priv_ep->cdns3_dev; + unsigned long flags; + int ret = 0; + + if (!(priv_ep->flags & EP_ENABLED)) + return -EPERM; + + spin_lock_irqsave(&priv_dev->lock, flags); + + cdns3_select_ep(priv_dev, ep->desc->bEndpointAddress); + + if (!value) { + priv_ep->flags &= ~EP_WEDGE; + ret = __cdns3_gadget_ep_clear_halt(priv_ep); + } else { + __cdns3_gadget_ep_set_halt(priv_ep); + } + + spin_unlock_irqrestore(&priv_dev->lock, flags); + + return ret; +} + +extern const struct usb_ep_ops cdns3_gadget_ep0_ops; + +static const struct usb_ep_ops cdns3_gadget_ep_ops = { + .enable = cdns3_gadget_ep_enable, + .disable = cdns3_gadget_ep_disable, + .alloc_request = cdns3_gadget_ep_alloc_request, + .free_request = cdns3_gadget_ep_free_request, + .queue = cdns3_gadget_ep_queue, + .dequeue = cdns3_gadget_ep_dequeue, + .set_halt = cdns3_gadget_ep_set_halt, + .set_wedge = cdns3_gadget_ep_set_wedge, +}; + +/** + * cdns3_gadget_get_frame Returns number of actual ITP frame + * @gadget: gadget object + * + * Returns number of actual ITP frame + */ +static int cdns3_gadget_get_frame(struct usb_gadget *gadget) +{ + struct cdns3_device *priv_dev = gadget_to_cdns3_device(gadget); + + return readl(&priv_dev->regs->usb_itpn); +} + +int __cdns3_gadget_wakeup(struct cdns3_device *priv_dev) +{ + enum usb_device_speed speed; + + speed = cdns3_get_speed(priv_dev); + + if (speed >= USB_SPEED_SUPER) + return 0; + + /* Start driving resume signaling to indicate remote wakeup. */ + writel(USB_CONF_LGO_L0, &priv_dev->regs->usb_conf); + + return 0; +} + +static int cdns3_gadget_wakeup(struct usb_gadget *gadget) +{ + struct cdns3_device *priv_dev = gadget_to_cdns3_device(gadget); + unsigned long flags; + int ret = 0; + + spin_lock_irqsave(&priv_dev->lock, flags); + ret = __cdns3_gadget_wakeup(priv_dev); + spin_unlock_irqrestore(&priv_dev->lock, flags); + return ret; +} + +static int cdns3_gadget_set_selfpowered(struct usb_gadget *gadget, + int is_selfpowered) +{ + struct cdns3_device *priv_dev = gadget_to_cdns3_device(gadget); + unsigned long flags; + + spin_lock_irqsave(&priv_dev->lock, flags); + priv_dev->is_selfpowered = !!is_selfpowered; + spin_unlock_irqrestore(&priv_dev->lock, flags); + return 0; +} + +static int cdns3_gadget_pullup(struct usb_gadget *gadget, int is_on) +{ + struct cdns3_device *priv_dev = gadget_to_cdns3_device(gadget); + + if (is_on) + writel(USB_CONF_DEVEN, &priv_dev->regs->usb_conf); + else + writel(USB_CONF_DEVDS, &priv_dev->regs->usb_conf); + + return 0; +} + +static void cdns3_gadget_config(struct cdns3_device *priv_dev) +{ + struct cdns3_usb_regs __iomem *regs = priv_dev->regs; + u32 reg; + + cdns3_ep0_config(priv_dev); + + /* enable interrupts for endpoint 0 (in and out) */ + writel(EP_IEN_EP_OUT0 | EP_IEN_EP_IN0, ®s->ep_ien); + + /* + * Driver needs to modify LFPS minimal U1 Exit time for DEV_VER_TI_V1 + * revision of controller. + */ + if (priv_dev->dev_ver == DEV_VER_TI_V1) { + reg = readl(®s->dbg_link1); + + reg &= ~DBG_LINK1_LFPS_MIN_GEN_U1_EXIT_MASK; + reg |= DBG_LINK1_LFPS_MIN_GEN_U1_EXIT(0x55) | + DBG_LINK1_LFPS_MIN_GEN_U1_EXIT_SET; + writel(reg, ®s->dbg_link1); + } + + /* + * By default some platforms has set protected access to memory. + * This cause problem with cache, so driver restore non-secure + * access to memory. + */ + reg = readl(®s->dma_axi_ctrl); + reg |= DMA_AXI_CTRL_MARPROT(DMA_AXI_CTRL_NON_SECURE) | + DMA_AXI_CTRL_MAWPROT(DMA_AXI_CTRL_NON_SECURE); + writel(reg, ®s->dma_axi_ctrl); + + /* enable generic interrupt*/ + writel(USB_IEN_INIT, ®s->usb_ien); + writel(USB_CONF_CLK2OFFDS | USB_CONF_L1DS, ®s->usb_conf); + + cdns3_configure_dmult(priv_dev, NULL); + + cdns3_gadget_pullup(&priv_dev->gadget, 1); +} + +/** + * cdns3_gadget_udc_start Gadget start + * @gadget: gadget object + * @driver: driver which operates on this gadget + * + * Returns 0 on success, error code elsewhere + */ +static int cdns3_gadget_udc_start(struct usb_gadget *gadget, + struct usb_gadget_driver *driver) +{ + struct cdns3_device *priv_dev = gadget_to_cdns3_device(gadget); + unsigned long flags; + + spin_lock_irqsave(&priv_dev->lock, flags); + priv_dev->gadget_driver = driver; + cdns3_gadget_config(priv_dev); + spin_unlock_irqrestore(&priv_dev->lock, flags); + return 0; +} + +/** + * cdns3_gadget_udc_stop Stops gadget + * @gadget: gadget object + * + * Returns 0 + */ +static int cdns3_gadget_udc_stop(struct usb_gadget *gadget) +{ + struct cdns3_device *priv_dev = gadget_to_cdns3_device(gadget); + struct cdns3_endpoint *priv_ep; + u32 bEndpointAddress; + struct usb_ep *ep; + int ret = 0; + int val; + + priv_dev->gadget_driver = NULL; + + priv_dev->onchip_used_size = 0; + priv_dev->out_mem_is_allocated = 0; + priv_dev->gadget.speed = USB_SPEED_UNKNOWN; + + list_for_each_entry(ep, &priv_dev->gadget.ep_list, ep_list) { + priv_ep = ep_to_cdns3_ep(ep); + bEndpointAddress = priv_ep->num | priv_ep->dir; + cdns3_select_ep(priv_dev, bEndpointAddress); + writel(EP_CMD_EPRST, &priv_dev->regs->ep_cmd); + readl_poll_timeout_atomic(&priv_dev->regs->ep_cmd, val, + !(val & EP_CMD_EPRST), 100); + } + + /* disable interrupt for device */ + writel(0, &priv_dev->regs->usb_ien); + writel(USB_CONF_DEVDS, &priv_dev->regs->usb_conf); + + return ret; +} + +static const struct usb_gadget_ops cdns3_gadget_ops = { + .get_frame = cdns3_gadget_get_frame, + .wakeup = cdns3_gadget_wakeup, + .set_selfpowered = cdns3_gadget_set_selfpowered, + .pullup = cdns3_gadget_pullup, + .udc_start = cdns3_gadget_udc_start, + .udc_stop = cdns3_gadget_udc_stop, + .match_ep = cdns3_gadget_match_ep, +}; + +static void cdns3_free_all_eps(struct cdns3_device *priv_dev) +{ + int i; + + /* ep0 OUT point to ep0 IN. */ + priv_dev->eps[16] = NULL; + + for (i = 0; i < CDNS3_ENDPOINTS_MAX_COUNT; i++) + if (priv_dev->eps[i]) { + cdns3_free_trb_pool(priv_dev->eps[i]); + devm_kfree(priv_dev->dev, priv_dev->eps[i]); + } +} + +/** + * cdns3_init_eps Initializes software endpoints of gadget + * @cdns3: extended gadget object + * + * Returns 0 on success, error code elsewhere + */ +static int cdns3_init_eps(struct cdns3_device *priv_dev) +{ + u32 ep_enabled_reg, iso_ep_reg; + struct cdns3_endpoint *priv_ep; + int ep_dir, ep_number; + u32 ep_mask; + int ret = 0; + int i; + + /* Read it from USB_CAP3 to USB_CAP5 */ + ep_enabled_reg = readl(&priv_dev->regs->usb_cap3); + iso_ep_reg = readl(&priv_dev->regs->usb_cap4); + + dev_dbg(priv_dev->dev, "Initializing non-zero endpoints\n"); + + for (i = 0; i < CDNS3_ENDPOINTS_MAX_COUNT; i++) { + ep_dir = i >> 4; /* i div 16 */ + ep_number = i & 0xF; /* i % 16 */ + ep_mask = BIT(i); + + if (!(ep_enabled_reg & ep_mask)) + continue; + + if (ep_dir && !ep_number) { + priv_dev->eps[i] = priv_dev->eps[0]; + continue; + } + + priv_ep = devm_kzalloc(priv_dev->dev, sizeof(*priv_ep), + GFP_KERNEL); + if (!priv_ep) { + ret = -ENOMEM; + goto err; + } + + /* set parent of endpoint object */ + priv_ep->cdns3_dev = priv_dev; + priv_dev->eps[i] = priv_ep; + priv_ep->num = ep_number; + priv_ep->dir = ep_dir ? USB_DIR_IN : USB_DIR_OUT; + + if (!ep_number) { + ret = cdns3_init_ep0(priv_dev, priv_ep); + if (ret) { + dev_err(priv_dev->dev, "Failed to init ep0\n"); + goto err; + } + } else { + snprintf(priv_ep->name, sizeof(priv_ep->name), "ep%d%s", + ep_number, !!ep_dir ? "in" : "out"); + priv_ep->endpoint.name = priv_ep->name; + + usb_ep_set_maxpacket_limit(&priv_ep->endpoint, + CDNS3_EP_MAX_PACKET_LIMIT); + priv_ep->endpoint.max_streams = CDNS3_EP_MAX_STREAMS; + priv_ep->endpoint.ops = &cdns3_gadget_ep_ops; + if (ep_dir) + priv_ep->endpoint.caps.dir_in = 1; + else + priv_ep->endpoint.caps.dir_out = 1; + + if (iso_ep_reg & ep_mask) + priv_ep->endpoint.caps.type_iso = 1; + + priv_ep->endpoint.caps.type_bulk = 1; + priv_ep->endpoint.caps.type_int = 1; + + list_add_tail(&priv_ep->endpoint.ep_list, + &priv_dev->gadget.ep_list); + } + + priv_ep->flags = 0; + + dev_info(priv_dev->dev, "Initialized %s support: %s %s\n", + priv_ep->name, + priv_ep->endpoint.caps.type_bulk ? "BULK, INT" : "", + priv_ep->endpoint.caps.type_iso ? "ISO" : ""); + + INIT_LIST_HEAD(&priv_ep->pending_req_list); + INIT_LIST_HEAD(&priv_ep->deferred_req_list); + INIT_LIST_HEAD(&priv_ep->wa2_descmiss_req_list); + } + + return 0; +err: + cdns3_free_all_eps(priv_dev); + return -ENOMEM; +} + +void cdns3_gadget_exit(struct cdns3 *cdns) +{ + struct cdns3_device *priv_dev; + + priv_dev = cdns->gadget_dev; + + usb_del_gadget_udc(&priv_dev->gadget); + + cdns3_free_all_eps(priv_dev); + + while (!list_empty(&priv_dev->aligned_buf_list)) { + struct cdns3_aligned_buf *buf; + + buf = cdns3_next_align_buf(&priv_dev->aligned_buf_list); + dma_free_coherent(buf->buf); + + list_del(&buf->list); + kfree(buf); + } + + dma_free_coherent(priv_dev->setup_buf); + + kfree(priv_dev->zlp_buf); + kfree(priv_dev); + cdns->gadget_dev = NULL; + cdns3_drd_switch_gadget(cdns, 0); +} + +static int cdns3_gadget_start(struct cdns3 *cdns) +{ + struct cdns3_device *priv_dev; + u32 max_speed; + int ret; + + priv_dev = kzalloc(sizeof(*priv_dev), GFP_KERNEL); + if (!priv_dev) + return -ENOMEM; + + cdns->gadget_dev = priv_dev; + priv_dev->sysdev = cdns->dev; + priv_dev->dev = cdns->dev; + priv_dev->regs = cdns->dev_regs; + + dev_read_u32(priv_dev->dev, "cdns,on-chip-buff-size", + &priv_dev->onchip_buffers); + + if (priv_dev->onchip_buffers <= 0) { + u32 reg = readl(&priv_dev->regs->usb_cap2); + + priv_dev->onchip_buffers = USB_CAP2_ACTUAL_MEM_SIZE(reg); + } + + if (!priv_dev->onchip_buffers) + priv_dev->onchip_buffers = 256; + + max_speed = usb_get_maximum_speed(dev_of_offset(cdns->dev)); + + /* Check the maximum_speed parameter */ + switch (max_speed) { + case USB_SPEED_FULL: + writel(USB_CONF_SFORCE_FS, &priv_dev->regs->usb_conf); + break; + case USB_SPEED_HIGH: + writel(USB_CONF_USB3DIS, &priv_dev->regs->usb_conf); + break; + case USB_SPEED_SUPER: + break; + default: + dev_err(cdns->dev, "invalid maximum_speed parameter %d\n", + max_speed); + /* fall through */ + case USB_SPEED_UNKNOWN: + /* default to superspeed */ + max_speed = USB_SPEED_SUPER; + break; + } + + /* fill gadget fields */ + priv_dev->gadget.max_speed = max_speed; + priv_dev->gadget.speed = USB_SPEED_UNKNOWN; + priv_dev->gadget.ops = &cdns3_gadget_ops; + priv_dev->gadget.name = "cdns3-gadget"; +#ifndef __UBOOT__ + priv_dev->gadget.name = "usb-ss-gadget"; + priv_dev->gadget.sg_supported = 1; + priv_dev->gadget.quirk_avoids_skb_reserve = 1; +#endif + + spin_lock_init(&priv_dev->lock); + INIT_WORK(&priv_dev->pending_status_wq, + cdns3_pending_setup_status_handler); + + /* initialize endpoint container */ + INIT_LIST_HEAD(&priv_dev->gadget.ep_list); + INIT_LIST_HEAD(&priv_dev->aligned_buf_list); + + ret = cdns3_init_eps(priv_dev); + if (ret) { + dev_err(priv_dev->dev, "Failed to create endpoints\n"); + goto err1; + } + + /* allocate memory for setup packet buffer */ + priv_dev->setup_buf = + dma_alloc_coherent(8, (unsigned long *)&priv_dev->setup_dma); + if (!priv_dev->setup_buf) { + ret = -ENOMEM; + goto err2; + } + + priv_dev->dev_ver = readl(&priv_dev->regs->usb_cap6); + + dev_dbg(priv_dev->dev, "Device Controller version: %08x\n", + readl(&priv_dev->regs->usb_cap6)); + dev_dbg(priv_dev->dev, "USB Capabilities:: %08x\n", + readl(&priv_dev->regs->usb_cap1)); + dev_dbg(priv_dev->dev, "On-Chip memory cnfiguration: %08x\n", + readl(&priv_dev->regs->usb_cap2)); + + priv_dev->dev_ver = GET_DEV_BASE_VERSION(priv_dev->dev_ver); + + priv_dev->zlp_buf = kzalloc(CDNS3_EP_ZLP_BUF_SIZE, GFP_KERNEL); + if (!priv_dev->zlp_buf) { + ret = -ENOMEM; + goto err3; + } + + /* add USB gadget device */ + ret = usb_add_gadget_udc((struct device *)priv_dev->dev, + &priv_dev->gadget); + if (ret < 0) { + dev_err(priv_dev->dev, + "Failed to register USB device controller\n"); + goto err4; + } + + return 0; +err4: + kfree(priv_dev->zlp_buf); +err3: + dma_free_coherent(priv_dev->setup_buf); +err2: + cdns3_free_all_eps(priv_dev); +err1: + cdns->gadget_dev = NULL; + return ret; +} + +static int __cdns3_gadget_init(struct cdns3 *cdns) +{ + int ret = 0; + + cdns3_drd_switch_gadget(cdns, 1); + + ret = cdns3_gadget_start(cdns); + if (ret) + return ret; + + return 0; +} + +static int cdns3_gadget_suspend(struct cdns3 *cdns, bool do_wakeup) +{ + struct cdns3_device *priv_dev = cdns->gadget_dev; + + cdns3_disconnect_gadget(priv_dev); + + priv_dev->gadget.speed = USB_SPEED_UNKNOWN; + usb_gadget_set_state(&priv_dev->gadget, USB_STATE_NOTATTACHED); + cdns3_hw_reset_eps_config(priv_dev); + + /* disable interrupt for device */ + writel(0, &priv_dev->regs->usb_ien); + + cdns3_gadget_pullup(&priv_dev->gadget, 0); + + return 0; +} + +static int cdns3_gadget_resume(struct cdns3 *cdns, bool hibernated) +{ + struct cdns3_device *priv_dev = cdns->gadget_dev; + + if (!priv_dev->gadget_driver) + return 0; + + cdns3_gadget_config(priv_dev); + + return 0; +} + +/** + * cdns3_gadget_init - initialize device structure + * + * cdns: cdns3 instance + * + * This function initializes the gadget. + */ +int cdns3_gadget_init(struct cdns3 *cdns) +{ + struct cdns3_role_driver *rdrv; + + rdrv = devm_kzalloc(cdns->dev, sizeof(*rdrv), GFP_KERNEL); + if (!rdrv) + return -ENOMEM; + + rdrv->start = __cdns3_gadget_init; + rdrv->stop = cdns3_gadget_exit; + rdrv->suspend = cdns3_gadget_suspend; + rdrv->resume = cdns3_gadget_resume; + rdrv->state = CDNS3_ROLE_STATE_INACTIVE; + rdrv->name = "gadget"; + cdns->roles[USB_ROLE_DEVICE] = rdrv; + + return 0; +} + +/** + * cdns3_gadget_uboot_handle_interrupt - handle cdns3 gadget interrupt + * @cdns: pointer to struct cdns3 + * + * Handles ep0 and gadget interrupt + */ +static void cdns3_gadget_uboot_handle_interrupt(struct cdns3 *cdns) +{ + int ret = cdns3_device_irq_handler(0, cdns); + + if (ret == IRQ_WAKE_THREAD) + cdns3_device_thread_irq_handler(0, cdns); +} + +int dm_usb_gadget_handle_interrupts(struct udevice *dev) +{ + struct cdns3 *cdns = dev_get_priv(dev); + + cdns3_gadget_uboot_handle_interrupt(cdns); + + return 0; +} diff --git a/drivers/usb/cdns3/gadget.h b/drivers/usb/cdns3/gadget.h new file mode 100644 index 000000000000..3d5242b331d0 --- /dev/null +++ b/drivers/usb/cdns3/gadget.h @@ -0,0 +1,1338 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * USBSS device controller driver header file + * + * Copyright (C) 2018-2019 Cadence. + * Copyright (C) 2017-2018 NXP + * + * Author: Pawel Laszczak pawell@cadence.com + * Pawel Jez pjez@cadence.com + * Peter Chen peter.chen@nxp.com + */ +#ifndef __LINUX_CDNS3_GADGET +#define __LINUX_CDNS3_GADGET +#include <linux/usb/gadget.h> + +/* + * USBSS-DEV register interface. + * This corresponds to the USBSS Device Controller Interface + */ + +/** + * struct cdns3_usb_regs - device controller registers. + * @usb_conf: Global Configuration. + * @usb_sts: Global Status. + * @usb_cmd: Global Command. + * @usb_itpn: ITP/SOF number. + * @usb_lpm: Global Command. + * @usb_ien: USB Interrupt Enable. + * @usb_ists: USB Interrupt Status. + * @ep_sel: Endpoint Select. + * @ep_traddr: Endpoint Transfer Ring Address. + * @ep_cfg: Endpoint Configuration. + * @ep_cmd: Endpoint Command. + * @ep_sts: Endpoint Status. + * @ep_sts_sid: Endpoint Status. + * @ep_sts_en: Endpoint Status Enable. + * @drbl: Doorbell. + * @ep_ien: EP Interrupt Enable. + * @ep_ists: EP Interrupt Status. + * @usb_pwr: Global Power Configuration. + * @usb_conf2: Global Configuration 2. + * @usb_cap1: Capability 1. + * @usb_cap2: Capability 2. + * @usb_cap3: Capability 3. + * @usb_cap4: Capability 4. + * @usb_cap5: Capability 5. + * @usb_cap6: Capability 6. + * @usb_cpkt1: Custom Packet 1. + * @usb_cpkt2: Custom Packet 2. + * @usb_cpkt3: Custom Packet 3. + * @ep_dma_ext_addr: Upper address for DMA operations. + * @buf_addr: Address for On-chip Buffer operations. + * @buf_data: Data for On-chip Buffer operations. + * @buf_ctrl: On-chip Buffer Access Control. + * @dtrans: DMA Transfer Mode. + * @tdl_from_trb: Source of TD Configuration. + * @tdl_beh: TDL Behavior Configuration. + * @ep_tdl: Endpoint TDL. + * @tdl_beh2: TDL Behavior 2 Configuration. + * @dma_adv_td: DMA Advance TD Configuration. + * @reserved1: Reserved. + * @cfg_regs: Configuration. + * @reserved2: Reserved. + * @dma_axi_ctrl: AXI Control. + * @dma_axi_id: AXI ID register. + * @dma_axi_cap: AXI Capability. + * @dma_axi_ctrl0: AXI Control 0. + * @dma_axi_ctrl1: AXI Control 1. + */ +struct cdns3_usb_regs { + __le32 usb_conf; + __le32 usb_sts; + __le32 usb_cmd; + __le32 usb_itpn; + __le32 usb_lpm; + __le32 usb_ien; + __le32 usb_ists; + __le32 ep_sel; + __le32 ep_traddr; + __le32 ep_cfg; + __le32 ep_cmd; + __le32 ep_sts; + __le32 ep_sts_sid; + __le32 ep_sts_en; + __le32 drbl; + __le32 ep_ien; + __le32 ep_ists; + __le32 usb_pwr; + __le32 usb_conf2; + __le32 usb_cap1; + __le32 usb_cap2; + __le32 usb_cap3; + __le32 usb_cap4; + __le32 usb_cap5; + __le32 usb_cap6; + __le32 usb_cpkt1; + __le32 usb_cpkt2; + __le32 usb_cpkt3; + __le32 ep_dma_ext_addr; + __le32 buf_addr; + __le32 buf_data; + __le32 buf_ctrl; + __le32 dtrans; + __le32 tdl_from_trb; + __le32 tdl_beh; + __le32 ep_tdl; + __le32 tdl_beh2; + __le32 dma_adv_td; + __le32 reserved1[26]; + __le32 cfg_reg1; + __le32 dbg_link1; + __le32 dbg_link2; + __le32 cfg_regs[74]; + __le32 reserved2[51]; + __le32 dma_axi_ctrl; + __le32 dma_axi_id; + __le32 dma_axi_cap; + __le32 dma_axi_ctrl0; + __le32 dma_axi_ctrl1; +}; + +/* USB_CONF - bitmasks */ +/* Reset USB device configuration. */ +#define USB_CONF_CFGRST BIT(0) +/* Set Configuration. */ +#define USB_CONF_CFGSET BIT(1) +/* Disconnect USB device in SuperSpeed. */ +#define USB_CONF_USB3DIS BIT(3) +/* Disconnect USB device in HS/FS */ +#define USB_CONF_USB2DIS BIT(4) +/* Little Endian access - default */ +#define USB_CONF_LENDIAN BIT(5) +/* + * Big Endian access. Driver assume that byte order for + * SFRs access always is as Little Endian so this bit + * is not used. + */ +#define USB_CONF_BENDIAN BIT(6) +/* Device software reset. */ +#define USB_CONF_SWRST BIT(7) +/* Singular DMA transfer mode. Only for VER < DEV_VER_V3*/ +#define USB_CONF_DSING BIT(8) +/* Multiple DMA transfers mode. Only for VER < DEV_VER_V3 */ +#define USB_CONF_DMULT BIT(9) +/* DMA clock turn-off enable. */ +#define USB_CONF_DMAOFFEN BIT(10) +/* DMA clock turn-off disable. */ +#define USB_CONF_DMAOFFDS BIT(11) +/* Clear Force Full Speed. */ +#define USB_CONF_CFORCE_FS BIT(12) +/* Set Force Full Speed. */ +#define USB_CONF_SFORCE_FS BIT(13) +/* Device enable. */ +#define USB_CONF_DEVEN BIT(14) +/* Device disable. */ +#define USB_CONF_DEVDS BIT(15) +/* L1 LPM state entry enable (used in HS/FS mode). */ +#define USB_CONF_L1EN BIT(16) +/* L1 LPM state entry disable (used in HS/FS mode). */ +#define USB_CONF_L1DS BIT(17) +/* USB 2.0 clock gate disable. */ +#define USB_CONF_CLK2OFFEN BIT(18) +/* USB 2.0 clock gate enable. */ +#define USB_CONF_CLK2OFFDS BIT(19) +/* L0 LPM state entry request (used in HS/FS mode). */ +#define USB_CONF_LGO_L0 BIT(20) +/* USB 3.0 clock gate disable. */ +#define USB_CONF_CLK3OFFEN BIT(21) +/* USB 3.0 clock gate enable. */ +#define USB_CONF_CLK3OFFDS BIT(22) +/* Bit 23 is reserved*/ +/* U1 state entry enable (used in SS mode). */ +#define USB_CONF_U1EN BIT(24) +/* U1 state entry disable (used in SS mode). */ +#define USB_CONF_U1DS BIT(25) +/* U2 state entry enable (used in SS mode). */ +#define USB_CONF_U2EN BIT(26) +/* U2 state entry disable (used in SS mode). */ +#define USB_CONF_U2DS BIT(27) +/* U0 state entry request (used in SS mode). */ +#define USB_CONF_LGO_U0 BIT(28) +/* U1 state entry request (used in SS mode). */ +#define USB_CONF_LGO_U1 BIT(29) +/* U2 state entry request (used in SS mode). */ +#define USB_CONF_LGO_U2 BIT(30) +/* SS.Inactive state entry request (used in SS mode) */ +#define USB_CONF_LGO_SSINACT BIT(31) + +/* USB_STS - bitmasks */ +/* + * Configuration status. + * 1 - device is in the configured state. + * 0 - device is not configured. + */ +#define USB_STS_CFGSTS_MASK BIT(0) +#define USB_STS_CFGSTS(p) ((p) & USB_STS_CFGSTS_MASK) +/* + * On-chip memory overflow. + * 0 - On-chip memory status OK. + * 1 - On-chip memory overflow. + */ +#define USB_STS_OV_MASK BIT(1) +#define USB_STS_OV(p) ((p) & USB_STS_OV_MASK) +/* + * SuperSpeed connection status. + * 0 - USB in SuperSpeed mode disconnected. + * 1 - USB in SuperSpeed mode connected. + */ +#define USB_STS_USB3CONS_MASK BIT(2) +#define USB_STS_USB3CONS(p) ((p) & USB_STS_USB3CONS_MASK) +/* + * DMA transfer configuration status. + * 0 - single request. + * 1 - multiple TRB chain + * Supported only for controller version < DEV_VER_V3 + */ +#define USB_STS_DTRANS_MASK BIT(3) +#define USB_STS_DTRANS(p) ((p) & USB_STS_DTRANS_MASK) +/* + * Device speed. + * 0 - Undefined (value after reset). + * 1 - Low speed + * 2 - Full speed + * 3 - High speed + * 4 - Super speed + */ +#define USB_STS_USBSPEED_MASK GENMASK(6, 4) +#define USB_STS_USBSPEED(p) (((p) & USB_STS_USBSPEED_MASK) >> 4) +#define USB_STS_LS (0x1 << 4) +#define USB_STS_FS (0x2 << 4) +#define USB_STS_HS (0x3 << 4) +#define USB_STS_SS (0x4 << 4) +#define DEV_UNDEFSPEED(p) (((p) & USB_STS_USBSPEED_MASK) == (0x0 << 4)) +#define DEV_LOWSPEED(p) (((p) & USB_STS_USBSPEED_MASK) == USB_STS_LS) +#define DEV_FULLSPEED(p) (((p) & USB_STS_USBSPEED_MASK) == USB_STS_FS) +#define DEV_HIGHSPEED(p) (((p) & USB_STS_USBSPEED_MASK) == USB_STS_HS) +#define DEV_SUPERSPEED(p) (((p) & USB_STS_USBSPEED_MASK) == USB_STS_SS) +/* + * Endianness for SFR access. + * 0 - Little Endian order (default after hardware reset). + * 1 - Big Endian order + */ +#define USB_STS_ENDIAN_MASK BIT(7) +#define USB_STS_ENDIAN(p) ((p) & USB_STS_ENDIAN_MASK) +/* + * HS/FS clock turn-off status. + * 0 - hsfs clock is always on. + * 1 - hsfs clock turn-off in L2 (HS/FS mode) is enabled + * (default after hardware reset). + */ +#define USB_STS_CLK2OFF_MASK BIT(8) +#define USB_STS_CLK2OFF(p) ((p) & USB_STS_CLK2OFF_MASK) +/* + * PCLK clock turn-off status. + * 0 - pclk clock is always on. + * 1 - pclk clock turn-off in U3 (SS mode) is enabled + * (default after hardware reset). + */ +#define USB_STS_CLK3OFF_MASK BIT(9) +#define USB_STS_CLK3OFF(p) ((p) & USB_STS_CLK3OFF_MASK) +/* + * Controller in reset state. + * 0 - Internal reset is active. + * 1 - Internal reset is not active and controller is fully operational. + */ +#define USB_STS_IN_RST_MASK BIT(10) +#define USB_STS_IN_RST(p) ((p) & USB_STS_IN_RST_MASK) +/* + * Status of the "TDL calculation basing on TRB" feature. + * 0 - disabled + * 1 - enabled + * Supported only for DEV_VER_V2 controller version. + */ +#define USB_STS_TDL_TRB_ENABLED BIT(11) +/* + * Device enable Status. + * 0 - USB device is disabled (VBUS input is disconnected from internal logic). + * 1 - USB device is enabled (VBUS input is connected to the internal logic). + */ +#define USB_STS_DEVS_MASK BIT(14) +#define USB_STS_DEVS(p) ((p) & USB_STS_DEVS_MASK) +/* + * Address status. + * 0 - USB device is default state. + * 1 - USB device is at least in address state. + */ +#define USB_STS_ADDRESSED_MASK BIT(15) +#define USB_STS_ADDRESSED(p) ((p) & USB_STS_ADDRESSED_MASK) +/* + * L1 LPM state enable status (used in HS/FS mode). + * 0 - Entering to L1 LPM state disabled. + * 1 - Entering to L1 LPM state enabled. + */ +#define USB_STS_L1ENS_MASK BIT(16) +#define USB_STS_L1ENS(p) ((p) & USB_STS_L1ENS_MASK) +/* + * Internal VBUS connection status (used both in HS/FS and SS mode). + * 0 - internal VBUS is not detected. + * 1 - internal VBUS is detected. + */ +#define USB_STS_VBUSS_MASK BIT(17) +#define USB_STS_VBUSS(p) ((p) & USB_STS_VBUSS_MASK) +/* + * HS/FS LPM state (used in FS/HS mode). + * 0 - L0 State + * 1 - L1 State + * 2 - L2 State + * 3 - L3 State + */ +#define USB_STS_LPMST_MASK GENMASK(19, 18) +#define DEV_L0_STATE(p) (((p) & USB_STS_LPMST_MASK) == (0x0 << 18)) +#define DEV_L1_STATE(p) (((p) & USB_STS_LPMST_MASK) == (0x1 << 18)) +#define DEV_L2_STATE(p) (((p) & USB_STS_LPMST_MASK) == (0x2 << 18)) +#define DEV_L3_STATE(p) (((p) & USB_STS_LPMST_MASK) == (0x3 << 18)) +/* + * Disable HS status (used in FS/HS mode). + * 0 - the disconnect bit for HS/FS mode is set . + * 1 - the disconnect bit for HS/FS mode is not set. + */ +#define USB_STS_USB2CONS_MASK BIT(20) +#define USB_STS_USB2CONS(p) ((p) & USB_STS_USB2CONS_MASK) +/* + * HS/FS mode connection status (used in FS/HS mode). + * 0 - High Speed operations in USB2.0 (FS/HS) mode not disabled. + * 1 - High Speed operations in USB2.0 (FS/HS). + */ +#define USB_STS_DISABLE_HS_MASK BIT(21) +#define USB_STS_DISABLE_HS(p) ((p) & USB_STS_DISABLE_HS_MASK) +/* + * U1 state enable status (used in SS mode). + * 0 - Entering to U1 state disabled. + * 1 - Entering to U1 state enabled. + */ +#define USB_STS_U1ENS_MASK BIT(24) +#define USB_STS_U1ENS(p) ((p) & USB_STS_U1ENS_MASK) +/* + * U2 state enable status (used in SS mode). + * 0 - Entering to U2 state disabled. + * 1 - Entering to U2 state enabled. + */ +#define USB_STS_U2ENS_MASK BIT(25) +#define USB_STS_U2ENS(p) ((p) & USB_STS_U2ENS_MASK) +/* + * SuperSpeed Link LTSSM state. This field reflects USBSS-DEV current + * SuperSpeed link state + */ +#define USB_STS_LST_MASK GENMASK(29, 26) +#define DEV_LST_U0 (((p) & USB_STS_LST_MASK) == (0x0 << 26)) +#define DEV_LST_U1 (((p) & USB_STS_LST_MASK) == (0x1 << 26)) +#define DEV_LST_U2 (((p) & USB_STS_LST_MASK) == (0x2 << 26)) +#define DEV_LST_U3 (((p) & USB_STS_LST_MASK) == (0x3 << 26)) +#define DEV_LST_DISABLED (((p) & USB_STS_LST_MASK) == (0x4 << 26)) +#define DEV_LST_RXDETECT (((p) & USB_STS_LST_MASK) == (0x5 << 26)) +#define DEV_LST_INACTIVE (((p) & USB_STS_LST_MASK) == (0x6 << 26)) +#define DEV_LST_POLLING (((p) & USB_STS_LST_MASK) == (0x7 << 26)) +#define DEV_LST_RECOVERY (((p) & USB_STS_LST_MASK) == (0x8 << 26)) +#define DEV_LST_HOT_RESET (((p) & USB_STS_LST_MASK) == (0x9 << 26)) +#define DEV_LST_COMP_MODE (((p) & USB_STS_LST_MASK) == (0xa << 26)) +#define DEV_LST_LB_STATE (((p) & USB_STS_LST_MASK) == (0xb << 26)) +/* + * DMA clock turn-off status. + * 0 - DMA clock is always on (default after hardware reset). + * 1 - DMA clock turn-off in U1, U2 and U3 (SS mode) is enabled. + */ +#define USB_STS_DMAOFF_MASK BIT(30) +#define USB_STS_DMAOFF(p) ((p) & USB_STS_DMAOFF_MASK) +/* + * SFR Endian status. + * 0 - Little Endian order (default after hardware reset). + * 1 - Big Endian order. + */ +#define USB_STS_ENDIAN2_MASK BIT(31) +#define USB_STS_ENDIAN2(p) ((p) & USB_STS_ENDIAN2_MASK) + +/* USB_CMD - bitmasks */ +/* Set Function Address */ +#define USB_CMD_SET_ADDR BIT(0) +/* + * Function Address This field is saved to the device only when the field + * SET_ADDR is set '1 ' during write to USB_CMD register. + * Software is responsible for entering the address of the device during + * SET_ADDRESS request service. This field should be set immediately after + * the SETUP packet is decoded, and prior to confirmation of the status phase + */ +#define USB_CMD_FADDR_MASK GENMASK(7, 1) +#define USB_CMD_FADDR(p) (((p) << 1) & USB_CMD_FADDR_MASK) +/* Send Function Wake Device Notification TP (used only in SS mode). */ +#define USB_CMD_SDNFW BIT(8) +/* Set Test Mode (used only in HS/FS mode). */ +#define USB_CMD_STMODE BIT(9) +/* Test mode selector (used only in HS/FS mode) */ +#define USB_STS_TMODE_SEL_MASK GENMASK(11, 10) +#define USB_STS_TMODE_SEL(p) (((p) << 10) & USB_STS_TMODE_SEL_MASK) +/* + * Send Latency Tolerance Message Device Notification TP (used only + * in SS mode). + */ +#define USB_CMD_SDNLTM BIT(12) +/* Send Custom Transaction Packet (used only in SS mode) */ +#define USB_CMD_SPKT BIT(13) +/*Device Notification 'Function Wake' - Interface value (only in SS mode. */ +#define USB_CMD_DNFW_INT_MASK GENMASK(23, 16) +#define USB_STS_DNFW_INT(p) (((p) << 16) & USB_CMD_DNFW_INT_MASK) +/* + * Device Notification 'Latency Tolerance Message' -373 BELT value [7:0] + * (used only in SS mode). + */ +#define USB_CMD_DNLTM_BELT_MASK GENMASK(27, 16) +#define USB_STS_DNLTM_BELT(p) (((p) << 16) & USB_CMD_DNLTM_BELT_MASK) + +/* USB_ITPN - bitmasks */ +/* + * ITP(SS) / SOF (HS/FS) number + * In SS mode this field represent number of last ITP received from host. + * In HS/FS mode this field represent number of last SOF received from host. + */ +#define USB_ITPN_MASK GENMASK(13, 0) +#define USB_ITPN(p) ((p) & USB_ITPN_MASK) + +/* USB_LPM - bitmasks */ +/* Host Initiated Resume Duration. */ +#define USB_LPM_HIRD_MASK GENMASK(3, 0) +#define USB_LPM_HIRD(p) ((p) & USB_LPM_HIRD_MASK) +/* Remote Wakeup Enable (bRemoteWake). */ +#define USB_LPM_BRW BIT(4) + +/* USB_IEN - bitmasks */ +/* SS connection interrupt enable */ +#define USB_IEN_CONIEN BIT(0) +/* SS disconnection interrupt enable. */ +#define USB_IEN_DISIEN BIT(1) +/* USB SS warm reset interrupt enable. */ +#define USB_IEN_UWRESIEN BIT(2) +/* USB SS hot reset interrupt enable */ +#define USB_IEN_UHRESIEN BIT(3) +/* SS link U3 state enter interrupt enable (suspend).*/ +#define USB_IEN_U3ENTIEN BIT(4) +/* SS link U3 state exit interrupt enable (wakeup). */ +#define USB_IEN_U3EXTIEN BIT(5) +/* SS link U2 state enter interrupt enable.*/ +#define USB_IEN_U2ENTIEN BIT(6) +/* SS link U2 state exit interrupt enable.*/ +#define USB_IEN_U2EXTIEN BIT(7) +/* SS link U1 state enter interrupt enable.*/ +#define USB_IEN_U1ENTIEN BIT(8) +/* SS link U1 state exit interrupt enable.*/ +#define USB_IEN_U1EXTIEN BIT(9) +/* ITP/SOF packet detected interrupt enable.*/ +#define USB_IEN_ITPIEN BIT(10) +/* Wakeup interrupt enable.*/ +#define USB_IEN_WAKEIEN BIT(11) +/* Send Custom Packet interrupt enable.*/ +#define USB_IEN_SPKTIEN BIT(12) +/* HS/FS mode connection interrupt enable.*/ +#define USB_IEN_CON2IEN BIT(16) +/* HS/FS mode disconnection interrupt enable.*/ +#define USB_IEN_DIS2IEN BIT(17) +/* USB reset (HS/FS mode) interrupt enable.*/ +#define USB_IEN_U2RESIEN BIT(18) +/* LPM L2 state enter interrupt enable.*/ +#define USB_IEN_L2ENTIEN BIT(20) +/* LPM L2 state exit interrupt enable.*/ +#define USB_IEN_L2EXTIEN BIT(21) +/* LPM L1 state enter interrupt enable.*/ +#define USB_IEN_L1ENTIEN BIT(24) +/* LPM L1 state exit interrupt enable.*/ +#define USB_IEN_L1EXTIEN BIT(25) +/* Configuration reset interrupt enable.*/ +#define USB_IEN_CFGRESIEN BIT(26) +/* Start of the USB SS warm reset interrupt enable.*/ +#define USB_IEN_UWRESSIEN BIT(28) +/* End of the USB SS warm reset interrupt enable.*/ +#define USB_IEN_UWRESEIEN BIT(29) + +#define USB_IEN_INIT (USB_IEN_U2RESIEN | USB_ISTS_DIS2I | USB_IEN_CON2IEN \ + | USB_IEN_UHRESIEN | USB_IEN_UWRESIEN | USB_IEN_DISIEN \ + | USB_IEN_CONIEN | USB_IEN_U3EXTIEN | USB_IEN_L2ENTIEN \ + | USB_IEN_L2EXTIEN | USB_IEN_L1ENTIEN | USB_IEN_U3ENTIEN) + +/* USB_ISTS - bitmasks */ +/* SS Connection detected. */ +#define USB_ISTS_CONI BIT(0) +/* SS Disconnection detected. */ +#define USB_ISTS_DISI BIT(1) +/* UUSB warm reset detectede. */ +#define USB_ISTS_UWRESI BIT(2) +/* USB hot reset detected. */ +#define USB_ISTS_UHRESI BIT(3) +/* U3 link state enter detected (suspend).*/ +#define USB_ISTS_U3ENTI BIT(4) +/* U3 link state exit detected (wakeup). */ +#define USB_ISTS_U3EXTI BIT(5) +/* U2 link state enter detected.*/ +#define USB_ISTS_U2ENTI BIT(6) +/* U2 link state exit detected.*/ +#define USB_ISTS_U2EXTI BIT(7) +/* U1 link state enter detected.*/ +#define USB_ISTS_U1ENTI BIT(8) +/* U1 link state exit detected.*/ +#define USB_ISTS_U1EXTI BIT(9) +/* ITP/SOF packet detected.*/ +#define USB_ISTS_ITPI BIT(10) +/* Wakeup detected.*/ +#define USB_ISTS_WAKEI BIT(11) +/* Send Custom Packet detected.*/ +#define USB_ISTS_SPKTI BIT(12) +/* HS/FS mode connection detected.*/ +#define USB_ISTS_CON2I BIT(16) +/* HS/FS mode disconnection detected.*/ +#define USB_ISTS_DIS2I BIT(17) +/* USB reset (HS/FS mode) detected.*/ +#define USB_ISTS_U2RESI BIT(18) +/* LPM L2 state enter detected.*/ +#define USB_ISTS_L2ENTI BIT(20) +/* LPM L2 state exit detected.*/ +#define USB_ISTS_L2EXTI BIT(21) +/* LPM L1 state enter detected.*/ +#define USB_ISTS_L1ENTI BIT(24) +/* LPM L1 state exit detected.*/ +#define USB_ISTS_L1EXTI BIT(25) +/* USB configuration reset detected.*/ +#define USB_ISTS_CFGRESI BIT(26) +/* Start of the USB warm reset detected.*/ +#define USB_ISTS_UWRESSI BIT(28) +/* End of the USB warm reset detected.*/ +#define USB_ISTS_UWRESEI BIT(29) + +/* USB_SEL - bitmasks */ +#define EP_SEL_EPNO_MASK GENMASK(3, 0) +/* Endpoint number. */ +#define EP_SEL_EPNO(p) ((p) & EP_SEL_EPNO_MASK) +/* Endpoint direction bit - 0 - OUT, 1 - IN. */ +#define EP_SEL_DIR BIT(7) + +#define select_ep_in(nr) (EP_SEL_EPNO(p) | EP_SEL_DIR) +#define select_ep_out (EP_SEL_EPNO(p)) + +/* EP_TRADDR - bitmasks */ +/* Transfer Ring address. */ +#define EP_TRADDR_TRADDR(p) ((p)) + +/* EP_CFG - bitmasks */ +/* Endpoint enable */ +#define EP_CFG_ENABLE BIT(0) +/* + * Endpoint type. + * 1 - isochronous + * 2 - bulk + * 3 - interrupt + */ +#define EP_CFG_EPTYPE_MASK GENMASK(2, 1) +#define EP_CFG_EPTYPE(p) (((p) << 1) & EP_CFG_EPTYPE_MASK) +/* Stream support enable (only in SS mode). */ +#define EP_CFG_STREAM_EN BIT(3) +/* TDL check (only in SS mode for BULK EP). */ +#define EP_CFG_TDL_CHK BIT(4) +/* SID check (only in SS mode for BULK OUT EP). */ +#define EP_CFG_SID_CHK BIT(5) +/* DMA transfer endianness. */ +#define EP_CFG_EPENDIAN BIT(7) +/* Max burst size (used only in SS mode). */ +#define EP_CFG_MAXBURST_MASK GENMASK(11, 8) +#define EP_CFG_MAXBURST(p) (((p) << 8) & EP_CFG_MAXBURST_MASK) +/* ISO max burst. */ +#define EP_CFG_MULT_MASK GENMASK(15, 14) +#define EP_CFG_MULT(p) (((p) << 14) & EP_CFG_MULT_MASK) +/* ISO max burst. */ +#define EP_CFG_MAXPKTSIZE_MASK GENMASK(26, 16) +#define EP_CFG_MAXPKTSIZE(p) (((p) << 16) & EP_CFG_MAXPKTSIZE_MASK) +/* Max number of buffered packets. */ +#define EP_CFG_BUFFERING_MASK GENMASK(31, 27) +#define EP_CFG_BUFFERING(p) (((p) << 27) & EP_CFG_BUFFERING_MASK) + +/* EP_CMD - bitmasks */ +/* Endpoint reset. */ +#define EP_CMD_EPRST BIT(0) +/* Endpoint STALL set. */ +#define EP_CMD_SSTALL BIT(1) +/* Endpoint STALL clear. */ +#define EP_CMD_CSTALL BIT(2) +/* Send ERDY TP. */ +#define EP_CMD_ERDY BIT(3) +/* Request complete. */ +#define EP_CMD_REQ_CMPL BIT(5) +/* Transfer descriptor ready. */ +#define EP_CMD_DRDY BIT(6) +/* Data flush. */ +#define EP_CMD_DFLUSH BIT(7) +/* + * Transfer Descriptor Length write (used only for Bulk Stream capable + * endpoints in SS mode). + * Bit Removed from DEV_VER_V3 controller version. + */ +#define EP_CMD_STDL BIT(8) +/* + * Transfer Descriptor Length (used only in SS mode for bulk endpoints). + * Bits Removed from DEV_VER_V3 controller version. + */ +#define EP_CMD_TDL_MASK GENMASK(15, 9) +#define EP_CMD_TDL_SET(p) (((p) << 9) & EP_CMD_TDL_MASK) +#define EP_CMD_TDL_GET(p) (((p) & EP_CMD_TDL_MASK) >> 9) + +/* ERDY Stream ID value (used in SS mode). */ +#define EP_CMD_ERDY_SID_MASK GENMASK(31, 16) +#define EP_CMD_ERDY_SID(p) (((p) << 16) & EP_CMD_ERDY_SID_MASK) + +/* EP_STS - bitmasks */ +/* Setup transfer complete. */ +#define EP_STS_SETUP BIT(0) +/* Endpoint STALL status. */ +#define EP_STS_STALL(p) ((p) & BIT(1)) +/* Interrupt On Complete. */ +#define EP_STS_IOC BIT(2) +/* Interrupt on Short Packet. */ +#define EP_STS_ISP BIT(3) +/* Transfer descriptor missing. */ +#define EP_STS_DESCMIS BIT(4) +/* Stream Rejected (used only in SS mode) */ +#define EP_STS_STREAMR BIT(5) +/* EXIT from MOVE DATA State (used only for stream transfers in SS mode). */ +#define EP_STS_MD_EXIT BIT(6) +/* TRB error. */ +#define EP_STS_TRBERR BIT(7) +/* Not ready (used only in SS mode). */ +#define EP_STS_NRDY BIT(8) +/* DMA busy bit. */ +#define EP_STS_DBUSY BIT(9) +/* Endpoint Buffer Empty */ +#define EP_STS_BUFFEMPTY(p) ((p) & BIT(10)) +/* Current Cycle Status */ +#define EP_STS_CCS(p) ((p) & BIT(11)) +/* Prime (used only in SS mode. */ +#define EP_STS_PRIME BIT(12) +/* Stream error (used only in SS mode). */ +#define EP_STS_SIDERR BIT(13) +/* OUT size mismatch. */ +#define EP_STS_OUTSMM BIT(14) +/* ISO transmission error. */ +#define EP_STS_ISOERR BIT(15) +/* Host Packet Pending (only for SS mode). */ +#define EP_STS_HOSTPP(p) ((p) & BIT(16)) +/* Stream Protocol State Machine State (only for Bulk stream endpoints). */ +#define EP_STS_SPSMST_MASK GENMASK(18, 17) +#define EP_STS_SPSMST_DISABLED(p) (((p) & EP_STS_SPSMST_MASK) >> 17) +#define EP_STS_SPSMST_IDLE(p) (((p) & EP_STS_SPSMST_MASK) >> 17) +#define EP_STS_SPSMST_START_STREAM(p) (((p) & EP_STS_SPSMST_MASK) >> 17) +#define EP_STS_SPSMST_MOVE_DATA(p) (((p) & EP_STS_SPSMST_MASK) >> 17) +/* Interrupt On Transfer complete. */ +#define EP_STS_IOT BIT(19) +/* OUT queue endpoint number. */ +#define EP_STS_OUTQ_NO_MASK GENMASK(27, 24) +#define EP_STS_OUTQ_NO(p) (((p) & EP_STS_OUTQ_NO_MASK) >> 24) +/* OUT queue valid flag. */ +#define EP_STS_OUTQ_VAL_MASK BIT(28) +#define EP_STS_OUTQ_VAL(p) ((p) & EP_STS_OUTQ_VAL_MASK) +/* SETUP WAIT. */ +#define EP_STS_STPWAIT BIT(31) + +/* EP_STS_SID - bitmasks */ +/* Stream ID (used only in SS mode). */ +#define EP_STS_SID_MASK GENMASK(15, 0) +#define EP_STS_SID(p) ((p) & EP_STS_SID_MASK) + +/* EP_STS_EN - bitmasks */ +/* SETUP interrupt enable. */ +#define EP_STS_EN_SETUPEN BIT(0) +/* OUT transfer missing descriptor enable. */ +#define EP_STS_EN_DESCMISEN BIT(4) +/* Stream Rejected enable. */ +#define EP_STS_EN_STREAMREN BIT(5) +/* Move Data Exit enable.*/ +#define EP_STS_EN_MD_EXITEN BIT(6) +/* TRB enable. */ +#define EP_STS_EN_TRBERREN BIT(7) +/* NRDY enable. */ +#define EP_STS_EN_NRDYEN BIT(8) +/* Prime enable. */ +#define EP_STS_EN_PRIMEEEN BIT(12) +/* Stream error enable. */ +#define EP_STS_EN_SIDERREN BIT(13) +/* OUT size mismatch enable. */ +#define EP_STS_EN_OUTSMMEN BIT(14) +/* ISO transmission error enable. */ +#define EP_STS_EN_ISOERREN BIT(15) +/* Interrupt on Transmission complete enable. */ +#define EP_STS_EN_IOTEN BIT(19) +/* Setup Wait interrupt enable. */ +#define EP_STS_EN_STPWAITEN BIT(31) + +/* DRBL- bitmasks */ +#define DB_VALUE_BY_INDEX(index) (1 << (index)) +#define DB_VALUE_EP0_OUT BIT(0) +#define DB_VALUE_EP0_IN BIT(16) + +/* EP_IEN - bitmasks */ +#define EP_IEN(index) (1 << (index)) +#define EP_IEN_EP_OUT0 BIT(0) +#define EP_IEN_EP_IN0 BIT(16) + +/* EP_ISTS - bitmasks */ +#define EP_ISTS(index) (1 << (index)) +#define EP_ISTS_EP_OUT0 BIT(0) +#define EP_ISTS_EP_IN0 BIT(16) + +/* USB_PWR- bitmasks */ +/*Power Shut Off capability enable*/ +#define PUSB_PWR_PSO_EN BIT(0) +/*Power Shut Off capability disable*/ +#define PUSB_PWR_PSO_DS BIT(1) +/* + * Enables turning-off Reference Clock. + * This bit is optional and implemented only when support for OTG is + * implemented (indicated by OTG_READY bit set to '1'). + */ +#define PUSB_PWR_STB_CLK_SWITCH_EN BIT(8) +/* + * Status bit indicating that operation required by STB_CLK_SWITCH_EN write + * is completed + */ +#define PUSB_PWR_STB_CLK_SWITCH_DONE BIT(9) +/* This bit informs if Fast Registers Access is enabled. */ +#define PUSB_PWR_FST_REG_ACCESS_STAT BIT(30) +/* Fast Registers Access Enable. */ +#define PUSB_PWR_FST_REG_ACCESS BIT(31) + +/* USB_CONF2- bitmasks */ +/* + * Writing 1 disables TDL calculation basing on TRB feature in controller + * for DMULT mode. + * Bit supported only for DEV_VER_V2 version. + */ +#define USB_CONF2_DIS_TDL_TRB BIT(1) +/* + * Writing 1 enables TDL calculation basing on TRB feature in controller + * for DMULT mode. + * Bit supported only for DEV_VER_V2 version. + */ +#define USB_CONF2_EN_TDL_TRB BIT(2) + +/* USB_CAP1- bitmasks */ +/* + * SFR Interface type + * These field reflects type of SFR interface implemented: + * 0x0 - OCP + * 0x1 - AHB, + * 0x2 - PLB + * 0x3 - AXI + * 0x4-0xF - reserved + */ +#define USB_CAP1_SFR_TYPE_MASK GENMASK(3, 0) +#define DEV_SFR_TYPE_OCP(p) (((p) & USB_CAP1_SFR_TYPE_MASK) == 0x0) +#define DEV_SFR_TYPE_AHB(p) (((p) & USB_CAP1_SFR_TYPE_MASK) == 0x1) +#define DEV_SFR_TYPE_PLB(p) (((p) & USB_CAP1_SFR_TYPE_MASK) == 0x2) +#define DEV_SFR_TYPE_AXI(p) (((p) & USB_CAP1_SFR_TYPE_MASK) == 0x3) +/* + * SFR Interface width + * These field reflects width of SFR interface implemented: + * 0x0 - 8 bit interface, + * 0x1 - 16 bit interface, + * 0x2 - 32 bit interface + * 0x3 - 64 bit interface + * 0x4-0xF - reserved + */ +#define USB_CAP1_SFR_WIDTH_MASK GENMASK(7, 4) +#define DEV_SFR_WIDTH_8(p) (((p) & USB_CAP1_SFR_WIDTH_MASK) == (0x0 << 4)) +#define DEV_SFR_WIDTH_16(p) (((p) & USB_CAP1_SFR_WIDTH_MASK) == (0x1 << 4)) +#define DEV_SFR_WIDTH_32(p) (((p) & USB_CAP1_SFR_WIDTH_MASK) == (0x2 << 4)) +#define DEV_SFR_WIDTH_64(p) (((p) & USB_CAP1_SFR_WIDTH_MASK) == (0x3 << 4)) +/* + * DMA Interface type + * These field reflects type of DMA interface implemented: + * 0x0 - OCP + * 0x1 - AHB, + * 0x2 - PLB + * 0x3 - AXI + * 0x4-0xF - reserved + */ +#define USB_CAP1_DMA_TYPE_MASK GENMASK(11, 8) +#define DEV_DMA_TYPE_OCP(p) (((p) & USB_CAP1_DMA_TYPE_MASK) == (0x0 << 8)) +#define DEV_DMA_TYPE_AHB(p) (((p) & USB_CAP1_DMA_TYPE_MASK) == (0x1 << 8)) +#define DEV_DMA_TYPE_PLB(p) (((p) & USB_CAP1_DMA_TYPE_MASK) == (0x2 << 8)) +#define DEV_DMA_TYPE_AXI(p) (((p) & USB_CAP1_DMA_TYPE_MASK) == (0x3 << 8)) +/* + * DMA Interface width + * These field reflects width of DMA interface implemented: + * 0x0 - reserved, + * 0x1 - reserved, + * 0x2 - 32 bit interface + * 0x3 - 64 bit interface + * 0x4-0xF - reserved + */ +#define USB_CAP1_DMA_WIDTH_MASK GENMASK(15, 12) +#define DEV_DMA_WIDTH_32(p) (((p) & USB_CAP1_DMA_WIDTH_MASK) == (0x2 << 12)) +#define DEV_DMA_WIDTH_64(p) (((p) & USB_CAP1_DMA_WIDTH_MASK) == (0x3 << 12)) +/* + * USB3 PHY Interface type + * These field reflects type of USB3 PHY interface implemented: + * 0x0 - USB PIPE, + * 0x1 - RMMI, + * 0x2-0xF - reserved + */ +#define USB_CAP1_U3PHY_TYPE_MASK GENMASK(19, 16) +#define DEV_U3PHY_PIPE(p) (((p) & USB_CAP1_U3PHY_TYPE_MASK) == (0x0 << 16)) +#define DEV_U3PHY_RMMI(p) (((p) & USB_CAP1_U3PHY_TYPE_MASK) == (0x1 << 16)) +/* + * USB3 PHY Interface width + * These field reflects width of USB3 PHY interface implemented: + * 0x0 - 8 bit PIPE interface, + * 0x1 - 16 bit PIPE interface, + * 0x2 - 32 bit PIPE interface, + * 0x3 - 64 bit PIPE interface + * 0x4-0xF - reserved + * Note: When SSIC interface is implemented this field shows the width of + * internal PIPE interface. The RMMI interface is always 20bit wide. + */ +#define USB_CAP1_U3PHY_WIDTH_MASK GENMASK(23, 20) +#define DEV_U3PHY_WIDTH_8(p) \ + (((p) & USB_CAP1_U3PHY_WIDTH_MASK) == (0x0 << 20)) +#define DEV_U3PHY_WIDTH_16(p) \ + (((p) & USB_CAP1_U3PHY_WIDTH_MASK) == (0x1 << 16)) +#define DEV_U3PHY_WIDTH_32(p) \ + (((p) & USB_CAP1_U3PHY_WIDTH_MASK) == (0x2 << 20)) +#define DEV_U3PHY_WIDTH_64(p) \ + (((p) & USB_CAP1_U3PHY_WIDTH_MASK) == (0x3 << 16)) + +/* + * USB2 PHY Interface enable + * These field informs if USB2 PHY interface is implemented: + * 0x0 - interface NOT implemented, + * 0x1 - interface implemented + */ +#define USB_CAP1_U2PHY_EN(p) ((p) & BIT(24)) +/* + * USB2 PHY Interface type + * These field reflects type of USB2 PHY interface implemented: + * 0x0 - UTMI, + * 0x1 - ULPI + */ +#define DEV_U2PHY_ULPI(p) ((p) & BIT(25)) +/* + * USB2 PHY Interface width + * These field reflects width of USB2 PHY interface implemented: + * 0x0 - 8 bit interface, + * 0x1 - 16 bit interface, + * Note: The ULPI interface is always 8bit wide. + */ +#define DEV_U2PHY_WIDTH_16(p) ((p) & BIT(26)) +/* + * OTG Ready + * 0x0 - pure device mode + * 0x1 - some features and ports for CDNS USB OTG controller are implemented. + */ +#define USB_CAP1_OTG_READY(p) ((p) & BIT(27)) + +/* + * When set, indicates that controller supports automatic internal TDL + * calculation basing on the size provided in TRB (TRB[22:17]) for DMULT mode + * Supported only for DEV_VER_V2 controller version. + */ +#define USB_CAP1_TDL_FROM_TRB(p) ((p) & BIT(28)) + +/* USB_CAP2- bitmasks */ +/* + * The actual size of the connected On-chip RAM memory in kB: + * - 0 means 256 kB (max supported mem size) + * - value other than 0 reflects the mem size in kB + */ +#define USB_CAP2_ACTUAL_MEM_SIZE(p) ((p) & GENMASK(7, 0)) +/* + * Max supported mem size + * These field reflects width of on-chip RAM address bus width, + * which determines max supported mem size: + * 0x0-0x7 - reserved, + * 0x8 - support for 4kB mem, + * 0x9 - support for 8kB mem, + * 0xA - support for 16kB mem, + * 0xB - support for 32kB mem, + * 0xC - support for 64kB mem, + * 0xD - support for 128kB mem, + * 0xE - support for 256kB mem, + * 0xF - reserved + */ +#define USB_CAP2_MAX_MEM_SIZE(p) ((p) & GENMASK(11, 8)) + +/* USB_CAP3- bitmasks */ +#define EP_IS_IMPLEMENTED(reg, index) ((reg) & (1 << (index))) + +/* USB_CAP4- bitmasks */ +#define EP_SUPPORT_ISO(reg, index) ((reg) & (1 << (index))) + +/* USB_CAP5- bitmasks */ +#define EP_SUPPORT_STREAM(reg, index) ((reg) & (1 << (index))) + +/* USB_CAP6- bitmasks */ +/* The USBSS-DEV Controller Internal build number. */ +#define GET_DEV_BASE_VERSION(p) ((p) & GENMASK(23, 0)) +/* The USBSS-DEV Controller version number. */ +#define GET_DEV_CUSTOM_VERSION(p) ((p) & GENMASK(31, 24)) + +#define DEV_VER_NXP_V1 0x00024502 +#define DEV_VER_TI_V1 0x00024509 +#define DEV_VER_V2 0x0002450C +#define DEV_VER_V3 0x0002450d + +/* DBG_LINK1- bitmasks */ +/* + * LFPS_MIN_DET_U1_EXIT value This parameter configures the minimum + * time required for decoding the received LFPS as an LFPS.U1_Exit. + */ +#define DBG_LINK1_LFPS_MIN_DET_U1_EXIT(p) ((p) & GENMASK(7, 0)) +/* + * LFPS_MIN_GEN_U1_EXIT value This parameter configures the minimum time for + * phytxelecidle deassertion when LFPS.U1_Exit + */ +#define DBG_LINK1_LFPS_MIN_GEN_U1_EXIT_MASK GENMASK(15, 8) +#define DBG_LINK1_LFPS_MIN_GEN_U1_EXIT(p) (((p) << 8) & GENMASK(15, 8)) +/* + * RXDET_BREAK_DIS value This parameter configures terminating the Far-end + * Receiver termination detection sequence: + * 0: it is possible that USBSS_DEV will terminate Farend receiver + * termination detection sequence + * 1: USBSS_DEV will not terminate Far-end receiver termination + * detection sequence + */ +#define DBG_LINK1_RXDET_BREAK_DIS BIT(16) +/* LFPS_GEN_PING value This parameter configures the LFPS.Ping generation */ +#define DBG_LINK1_LFPS_GEN_PING(p) (((p) << 17) & GENMASK(21, 17)) +/* + * Set the LFPS_MIN_DET_U1_EXIT value Writing '1' to this bit writes the + * LFPS_MIN_DET_U1_EXIT field value to the device. This bit is automatically + * cleared. Writing '0' has no effect + */ +#define DBG_LINK1_LFPS_MIN_DET_U1_EXIT_SET BIT(24) +/* + * Set the LFPS_MIN_GEN_U1_EXIT value. Writing '1' to this bit writes the + * LFPS_MIN_GEN_U1_EXIT field value to the device. This bit is automatically + * cleared. Writing '0' has no effect + */ +#define DBG_LINK1_LFPS_MIN_GEN_U1_EXIT_SET BIT(25) +/* + * Set the RXDET_BREAK_DIS value Writing '1' to this bit writes + * the RXDET_BREAK_DIS field value to the device. This bit is automatically + * cleared. Writing '0' has no effect + */ +#define DBG_LINK1_RXDET_BREAK_DIS_SET BIT(26) +/* + * Set the LFPS_GEN_PING_SET value Writing '1' to this bit writes + * the LFPS_GEN_PING field value to the device. This bit is automatically + * cleared. Writing '0' has no effect." + */ +#define DBG_LINK1_LFPS_GEN_PING_SET BIT(27) + +/* DMA_AXI_CTRL- bitmasks */ +/* The mawprot pin configuration. */ +#define DMA_AXI_CTRL_MARPROT(p) ((p) & GENMASK(2, 0)) +/* The marprot pin configuration. */ +#define DMA_AXI_CTRL_MAWPROT(p) (((p) & GENMASK(2, 0)) << 16) +#define DMA_AXI_CTRL_NON_SECURE 0x02 + +#define gadget_to_cdns3_device(g) (container_of(g, struct cdns3_device, gadget)) + +#define ep_to_cdns3_ep(ep) (container_of(ep, struct cdns3_endpoint, endpoint)) + +/*-------------------------------------------------------------------------*/ +/* + * USBSS-DEV DMA interface. + */ +#define TRBS_PER_SEGMENT 40 + +#define ISO_MAX_INTERVAL 10 + +#if TRBS_PER_SEGMENT < 2 +#error "Incorrect TRBS_PER_SEGMENT. Minimal Transfer Ring size is 2." +#endif + +/* + *Only for ISOC endpoints - maximum number of TRBs is calculated as + * pow(2, bInterval-1) * number of usb requests. It is limitation made by + * driver to save memory. Controller must prepare TRB for each ITP even + * if bInterval > 1. It's the reason why driver needs so many TRBs for + * isochronous endpoints. + */ +#define TRBS_PER_ISOC_SEGMENT (ISO_MAX_INTERVAL * 8) + +#define GET_TRBS_PER_SEGMENT(ep_type) ((ep_type) == USB_ENDPOINT_XFER_ISOC ? \ + TRBS_PER_ISOC_SEGMENT : TRBS_PER_SEGMENT) +/** + * struct cdns3_trb - represent Transfer Descriptor block. + * @buffer: pointer to buffer data + * @length: length of data + * @control: control flags. + * + * This structure describes transfer block serviced by DMA module. + */ +struct cdns3_trb { + __le32 buffer; + __le32 length; + __le32 control; +}; + +#define TRB_SIZE (sizeof(struct cdns3_trb)) +#define TRB_RING_SIZE (TRB_SIZE * TRBS_PER_SEGMENT) +#define TRB_ISO_RING_SIZE (TRB_SIZE * TRBS_PER_ISOC_SEGMENT) +#define TRB_CTRL_RING_SIZE (TRB_SIZE * 2) + +/* TRB bit mask */ +#define TRB_TYPE_BITMASK GENMASK(15, 10) +#define TRB_TYPE(p) ((p) << 10) +#define TRB_FIELD_TO_TYPE(p) (((p) & TRB_TYPE_BITMASK) >> 10) + +/* TRB type IDs */ +/* bulk, interrupt, isoc , and control data stage */ +#define TRB_NORMAL 1 +/* TRB for linking ring segments */ +#define TRB_LINK 6 + +/* Cycle bit - indicates TRB ownership by driver or hw*/ +#define TRB_CYCLE BIT(0) +/* + * When set to '1', the device will toggle its interpretation of the Cycle bit + */ +#define TRB_TOGGLE BIT(1) + +/* + * Short Packet (SP). OUT EPs at DMULT=1 only. Indicates if the TRB was + * processed while USB short packet was received. No more buffers defined by + * the TD will be used. DMA will automatically advance to next TD. + * - Shall be set to 0 by Software when putting TRB on the Transfer Ring + * - Shall be set to 1 by Controller when Short Packet condition for this TRB + * is detected independent if ISP is set or not. + */ +#define TRB_SP BIT(1) + +/* Interrupt on short packet*/ +#define TRB_ISP BIT(2) +/*Setting this bit enables FIFO DMA operation mode*/ +#define TRB_FIFO_MODE BIT(3) +/* Set PCIe no snoop attribute */ +#define TRB_CHAIN BIT(4) +/* Interrupt on completion */ +#define TRB_IOC BIT(5) + +/* stream ID bitmasks. */ +#define TRB_STREAM_ID_BITMASK GENMASK(31, 16) +#define TRB_STREAM_ID(p) ((p) << 16) +#define TRB_FIELD_TO_STREAMID(p) (((p) & TRB_STREAM_ID_BITMASK) >> 16) + +/* Size of TD expressed in USB packets for HS/FS mode. */ +#define TRB_TDL_HS_SIZE(p) (((p) << 16) & GENMASK(31, 16)) +#define TRB_TDL_HS_SIZE_GET(p) (((p) & GENMASK(31, 16)) >> 16) + +/* transfer_len bitmasks. */ +#define TRB_LEN(p) ((p) & GENMASK(16, 0)) + +/* Size of TD expressed in USB packets for SS mode. */ +#define TRB_TDL_SS_SIZE(p) (((p) << 17) & GENMASK(23, 17)) +#define TRB_TDL_SS_SIZE_GET(p) (((p) & GENMASK(23, 17)) >> 17) + +/* transfer_len bitmasks - bits 31:24 */ +#define TRB_BURST_LEN(p) (((p) << 24) & GENMASK(31, 24)) +#define TRB_BURST_LEN_GET(p) (((p) & GENMASK(31, 24)) >> 24) + +/* Data buffer pointer bitmasks*/ +#define TRB_BUFFER(p) ((p) & GENMASK(31, 0)) + +/*-------------------------------------------------------------------------*/ +/* Driver numeric constants */ + +/* Such declaration should be added to ch9.h */ +#define USB_DEVICE_MAX_ADDRESS 127 + +/* Endpoint init values */ +#define CDNS3_EP_MAX_PACKET_LIMIT 1024 +#define CDNS3_EP_MAX_STREAMS 15 +#define CDNS3_EP0_MAX_PACKET_LIMIT 512 + +/* All endpoints including EP0 */ +#define CDNS3_ENDPOINTS_MAX_COUNT 32 +#define CDNS3_EP_ZLP_BUF_SIZE 1024 + +#define CDNS3_EP_BUF_SIZE 2 /* KB */ +#define CDNS3_EP_ISO_HS_MULT 3 +#define CDNS3_EP_ISO_SS_BURST 3 +#define CDNS3_MAX_NUM_DESCMISS_BUF 32 +#define CDNS3_DESCMIS_BUF_SIZE 2048 /* Bytes */ +#define CDNS3_WA2_NUM_BUFFERS 128 +/*-------------------------------------------------------------------------*/ +/* Used structs */ + +struct cdns3_device; + +/** + * struct cdns3_endpoint - extended device side representation of USB endpoint. + * @endpoint: usb endpoint + * @pending_req_list: list of requests queuing on transfer ring. + * @deferred_req_list: list of requests waiting for queuing on transfer ring. + * @wa2_descmiss_req_list: list of requests internally allocated by driver. + * @trb_pool: transfer ring - array of transaction buffers + * @trb_pool_dma: dma address of transfer ring + * @cdns3_dev: device associated with this endpoint + * @name: a human readable name e.g. ep1out + * @flags: specify the current state of endpoint + * @descmis_req: internal transfer object used for getting data from on-chip + * buffer. It can happen only if function driver doesn't send usb_request + * object on time. + * @dir: endpoint direction + * @num: endpoint number (1 - 15) + * @type: set to bmAttributes & USB_ENDPOINT_XFERTYPE_MASK + * @interval: interval between packets used for ISOC endpoint. + * @free_trbs: number of free TRBs in transfer ring + * @num_trbs: number of all TRBs in transfer ring + * @pcs: producer cycle state + * @ccs: consumer cycle state + * @enqueue: enqueue index in transfer ring + * @dequeue: dequeue index in transfer ring + * @trb_burst_size: number of burst used in trb. + */ +struct cdns3_endpoint { + struct usb_ep endpoint; + struct list_head pending_req_list; + struct list_head deferred_req_list; + struct list_head wa2_descmiss_req_list; + int wa2_counter; + + struct cdns3_trb *trb_pool; + dma_addr_t trb_pool_dma; + + struct cdns3_device *cdns3_dev; + char name[20]; + +#define EP_ENABLED BIT(0) +#define EP_STALLED BIT(1) +#define EP_STALL_PENDING BIT(2) +#define EP_WEDGE BIT(3) +#define EP_TRANSFER_STARTED BIT(4) +#define EP_UPDATE_EP_TRBADDR BIT(5) +#define EP_PENDING_REQUEST BIT(6) +#define EP_RING_FULL BIT(7) +#define EP_CLAIMED BIT(8) +#define EP_DEFERRED_DRDY BIT(9) +#define EP_QUIRK_ISO_OUT_EN BIT(10) +#define EP_QUIRK_END_TRANSFER BIT(11) +#define EP_QUIRK_EXTRA_BUF_DET BIT(12) +#define EP_QUIRK_EXTRA_BUF_EN BIT(13) + u32 flags; + + struct cdns3_request *descmis_req; + + u8 dir; + u8 num; + u8 type; + int interval; + + int free_trbs; + int num_trbs; + u8 pcs; + u8 ccs; + int enqueue; + int dequeue; + u8 trb_burst_size; + + unsigned int wa1_set:1; + struct cdns3_trb *wa1_trb; + unsigned int wa1_trb_index; + unsigned int wa1_cycle_bit:1; +}; + +/** + * struct cdns3_aligned_buf - represent aligned buffer used for DMA transfer + * @buf: aligned to 8 bytes data buffer. Buffer address used in + * TRB shall be aligned to 8. + * @dma: dma address + * @size: size of buffer + * @in_use: inform if this buffer is associated with usb_request + * @list: used to adding instance of this object to list + */ +struct cdns3_aligned_buf { + void *buf; + dma_addr_t dma; + u32 size; + int in_use:1; + struct list_head list; +}; + +/** + * struct cdns3_request - extended device side representation of usb_request + * object . + * @request: generic usb_request object describing single I/O request. + * @priv_ep: extended representation of usb_ep object + * @trb: the first TRB association with this request + * @start_trb: number of the first TRB in transfer ring + * @end_trb: number of the last TRB in transfer ring + * @aligned_buf: object holds information about aligned buffer associated whit + * this endpoint + * @flags: flag specifying special usage of request + * @list: used by internally allocated request to add to wa2_descmiss_req_list. + */ +struct cdns3_request { + struct usb_request request; + struct cdns3_endpoint *priv_ep; + struct cdns3_trb *trb; + int start_trb; + int end_trb; + struct cdns3_aligned_buf *aligned_buf; +#define REQUEST_PENDING BIT(0) +#define REQUEST_INTERNAL BIT(1) +#define REQUEST_INTERNAL_CH BIT(2) +#define REQUEST_ZLP BIT(3) +#define REQUEST_UNALIGNED BIT(4) + u32 flags; + struct list_head list; +}; + +#define to_cdns3_request(r) (container_of(r, struct cdns3_request, request)) + +/*Stages used during enumeration process.*/ +#define CDNS3_SETUP_STAGE 0x0 +#define CDNS3_DATA_STAGE 0x1 +#define CDNS3_STATUS_STAGE 0x2 + +/** + * struct cdns3_device - represent USB device. + * @dev: pointer to device structure associated whit this controller + * @sysdev: pointer to the DMA capable device + * @gadget: device side representation of the peripheral controller + * @gadget_driver: pointer to the gadget driver + * @dev_ver: device controller version. + * @lock: for synchronizing + * @regs: base address for device side registers + * @setup_buf: used while processing usb control requests + * @setup_dma: dma address for setup_buf + * @zlp_buf - zlp buffer + * @ep0_stage: ep0 stage during enumeration process. + * @ep0_data_dir: direction for control transfer + * @eps: array of pointers to all endpoints with exclusion ep0 + * @aligned_buf_list: list of aligned buffers internally allocated by driver + * @aligned_buf_wq: workqueue freeing no longer used aligned buf. + * @selected_ep: actually selected endpoint. It's used only to improve + * performance. + * @isoch_delay: value from Set Isoch Delay request. Only valid on SS/SSP. + * @u1_allowed: allow device transition to u1 state + * @u2_allowed: allow device transition to u2 state + * @is_selfpowered: device is self powered + * @setup_pending: setup packet is processing by gadget driver + * @hw_configured_flag: hardware endpoint configuration was set. + * @wake_up_flag: allow device to remote up the host + * @status_completion_no_call: indicate that driver is waiting for status s + * stage completion. It's used in deferred SET_CONFIGURATION request. + * @onchip_buffers: number of available on-chip buffers. + * @onchip_used_size: actual size of on-chip memory assigned to endpoints. + * @pending_status_wq: workqueue handling status stage for deferred requests. + * @pending_status_request: request for which status stage was deferred + */ +struct cdns3_device { + struct udevice *dev; + struct udevice *sysdev; + + struct usb_gadget gadget; + struct usb_gadget_driver *gadget_driver; + +#define CDNS_REVISION_V0 0x00024501 +#define CDNS_REVISION_V1 0x00024509 + u32 dev_ver; + + /* generic spin-lock for drivers */ + spinlock_t lock; + + struct cdns3_usb_regs __iomem *regs; + + struct usb_ctrlrequest *setup_buf; + dma_addr_t setup_dma; + void *zlp_buf; + + u8 ep0_stage; + int ep0_data_dir; + + struct cdns3_endpoint *eps[CDNS3_ENDPOINTS_MAX_COUNT]; + + struct list_head aligned_buf_list; + struct work_struct aligned_buf_wq; + + u32 selected_ep; + u16 isoch_delay; + + unsigned wait_for_setup:1; + unsigned u1_allowed:1; + unsigned u2_allowed:1; + unsigned is_selfpowered:1; + unsigned setup_pending:1; + int hw_configured_flag:1; + int wake_up_flag:1; + unsigned status_completion_no_call:1; + int out_mem_is_allocated; + + struct work_struct pending_status_wq; + struct usb_request *pending_status_request; + + /*in KB */ + u32 onchip_buffers; + u16 onchip_used_size; +}; + +void cdns3_set_register_bit(void __iomem *ptr, u32 mask); +dma_addr_t cdns3_trb_virt_to_dma(struct cdns3_endpoint *priv_ep, + struct cdns3_trb *trb); +enum usb_device_speed cdns3_get_speed(struct cdns3_device *priv_dev); +void cdns3_pending_setup_status_handler(struct work_struct *work); +void cdns3_hw_reset_eps_config(struct cdns3_device *priv_dev); +void cdns3_set_hw_configuration(struct cdns3_device *priv_dev); +void cdns3_select_ep(struct cdns3_device *priv_dev, u32 ep); +void cdns3_allow_enable_l1(struct cdns3_device *priv_dev, int enable); +struct usb_request *cdns3_next_request(struct list_head *list); +int cdns3_ep_run_transfer(struct cdns3_endpoint *priv_ep, + struct usb_request *request); +void cdns3_rearm_transfer(struct cdns3_endpoint *priv_ep, u8 rearm); +int cdns3_allocate_trb_pool(struct cdns3_endpoint *priv_ep); +u8 cdns3_ep_addr_to_index(u8 ep_addr); +int cdns3_gadget_ep_set_wedge(struct usb_ep *ep); +int cdns3_gadget_ep_set_halt(struct usb_ep *ep, int value); +void __cdns3_gadget_ep_set_halt(struct cdns3_endpoint *priv_ep); +int __cdns3_gadget_ep_clear_halt(struct cdns3_endpoint *priv_ep); +struct usb_request *cdns3_gadget_ep_alloc_request(struct usb_ep *ep, + gfp_t gfp_flags); +void cdns3_gadget_ep_free_request(struct usb_ep *ep, + struct usb_request *request); +int cdns3_gadget_ep_dequeue(struct usb_ep *ep, struct usb_request *request); +void cdns3_gadget_giveback(struct cdns3_endpoint *priv_ep, + struct cdns3_request *priv_req, + int status); + +int cdns3_init_ep0(struct cdns3_device *priv_dev, + struct cdns3_endpoint *priv_ep); +void cdns3_ep0_config(struct cdns3_device *priv_dev); +void cdns3_ep_config(struct cdns3_endpoint *priv_ep); +void cdns3_check_ep0_interrupt_proceed(struct cdns3_device *priv_dev, int dir); +int __cdns3_gadget_wakeup(struct cdns3_device *priv_dev); + +#endif /* __LINUX_CDNS3_GADGET */ diff --git a/drivers/usb/cdns3/host-export.h b/drivers/usb/cdns3/host-export.h new file mode 100644 index 000000000000..b498a170b7e8 --- /dev/null +++ b/drivers/usb/cdns3/host-export.h @@ -0,0 +1,28 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Cadence USBSS DRD Driver - Host Export APIs + * + * Copyright (C) 2017-2018 NXP + * + * Authors: Peter Chen peter.chen@nxp.com + */ +#ifndef __LINUX_CDNS3_HOST_EXPORT +#define __LINUX_CDNS3_HOST_EXPORT + +#ifdef CONFIG_USB_CDNS3_HOST + +int cdns3_host_init(struct cdns3 *cdns); +void cdns3_host_exit(struct cdns3 *cdns); + +#else + +static inline int cdns3_host_init(struct cdns3 *cdns) +{ + return -ENXIO; +} + +static inline void cdns3_host_exit(struct cdns3 *cdns) { } + +#endif /* CONFIG_USB_CDNS3_HOST */ + +#endif /* __LINUX_CDNS3_HOST_EXPORT */ diff --git a/drivers/usb/cdns3/host.c b/drivers/usb/cdns3/host.c new file mode 100644 index 000000000000..79be63001d44 --- /dev/null +++ b/drivers/usb/cdns3/host.c @@ -0,0 +1,55 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Cadence USBSS DRD Driver - host side + * + * Copyright (C) 2018-2019 Cadence Design Systems. + * Copyright (C) 2017-2018 NXP + * + * Authors: Peter Chen peter.chen@nxp.com + * Pawel Laszczak pawell@cadence.com + */ +#include <dm.h> +#include <linux/compat.h> +#include <usb.h> +#include "../host/xhci.h" + +#include "core.h" +#include "drd.h" + +static int __cdns3_host_init(struct cdns3 *cdns) +{ + struct xhci_hcor *hcor; + struct xhci_hccr *hccr; + + cdns3_drd_switch_host(cdns, 1); + + hccr = (struct xhci_hccr *)cdns->xhci_regs; + hcor = (struct xhci_hcor *)(cdns->xhci_regs + + HC_LENGTH(xhci_readl(&(hccr)->cr_capbase))); + + return xhci_register(cdns->dev, hccr, hcor); +} + +static void cdns3_host_exit(struct cdns3 *cdns) +{ + xhci_deregister(cdns->dev); + cdns3_drd_switch_host(cdns, 0); +} + +int cdns3_host_init(struct cdns3 *cdns) +{ + struct cdns3_role_driver *rdrv; + + rdrv = devm_kzalloc(cdns->dev, sizeof(*rdrv), GFP_KERNEL); + if (!rdrv) + return -ENOMEM; + + rdrv->start = __cdns3_host_init; + rdrv->stop = cdns3_host_exit; + rdrv->state = CDNS3_ROLE_STATE_INACTIVE; + rdrv->name = "host"; + + cdns->roles[USB_ROLE_HOST] = rdrv; + + return 0; +} diff --git a/drivers/usb/cdns3/trace.c b/drivers/usb/cdns3/trace.c new file mode 100644 index 000000000000..459fa72d9c74 --- /dev/null +++ b/drivers/usb/cdns3/trace.c @@ -0,0 +1,11 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * USBSS device controller driver Trace Support + * + * Copyright (C) 2018-2019 Cadence. + * + * Author: Pawel Laszczak pawell@cadence.com + */ + +#define CREATE_TRACE_POINTS +#include "trace.h" diff --git a/drivers/usb/cdns3/trace.h b/drivers/usb/cdns3/trace.h new file mode 100644 index 000000000000..e86c02ae9b3b --- /dev/null +++ b/drivers/usb/cdns3/trace.h @@ -0,0 +1,26 @@ +/* SPDX-License-Identifier: GPL-2.0 */ + +#define trace_cdns3_prepare_trb(a, b) +#define trace_cdns3_doorbell_ep0(a, b) +#define trace_cdns3_ctrl_req(a) +#define trace_cdns3_complete_trb(a, b) +#define trace_cdns3_ep0_irq(a, b) +#define trace_cdns3_gadget_giveback(a) +#define trace_cdns3_free_aligned_request(a) +#define trace_cdns3_prepare_aligned_request(a) +#define trace_cdns3_ring(a) +#define trace_cdns3_doorbell_epx(a, b) +#define trace_cdns3_request_handled(a, b, c) +#define trace_cdns3_epx_irq(a, b) +#define trace_cdns3_usb_irq(a, b) +#define trace_cdns3_alloc_request(a) +#define trace_cdns3_free_request(a) +#define trace_cdns3_gadget_ep_enable(a) +#define trace_cdns3_gadget_ep_disable(a) +#define trace_cdns3_ep0_queue(a, b) +#define trace_cdns3_ep0_dequeue(a) +#define trace_cdns3_ep_queue(a) +#define trace_cdns3_ep_dequeue(a) +#define trace_cdns3_halt(a, b, c) +#define trace_cdns3_wa1(a, b) +#define trace_cdns3_wa2(a, b) diff --git a/scripts/Makefile.spl b/scripts/Makefile.spl index 7af6b120b6c1..d731c21aa4c8 100644 --- a/scripts/Makefile.spl +++ b/scripts/Makefile.spl @@ -88,6 +88,7 @@ endif
libs-y += drivers/ libs-$(CONFIG_SPL_USB_GADGET) += drivers/usb/dwc3/ +libs-$(CONFIG_SPL_USB_GADGET) += drivers/usb/cdns3/ libs-y += dts/ libs-y += fs/ libs-$(CONFIG_SPL_POST_MEM_SUPPORT) += post/drivers/
Implement udc_set_speed() callback to limit Controller's speed to high-speed/full-speed when working with gadgets that are high-speed or full-speed only
Signed-off-by: Vignesh Raghavendra vigneshr@ti.com --- drivers/usb/cdns3/gadget.c | 30 ++++++++++++++++++++++++++---- 1 file changed, 26 insertions(+), 4 deletions(-)
diff --git a/drivers/usb/cdns3/gadget.c b/drivers/usb/cdns3/gadget.c index a4debb0ddf1d..0e02b779656c 100644 --- a/drivers/usb/cdns3/gadget.c +++ b/drivers/usb/cdns3/gadget.c @@ -2378,6 +2378,29 @@ static int cdns3_gadget_udc_stop(struct usb_gadget *gadget) return ret; }
+static void cdns3_gadget_udc_set_speed(struct usb_gadget *gadget, + enum usb_device_speed speed) +{ + struct cdns3_device *priv_dev = gadget_to_cdns3_device(gadget); + + switch (speed) { + case USB_SPEED_FULL: + writel(USB_CONF_SFORCE_FS, &priv_dev->regs->usb_conf); + writel(USB_CONF_USB3DIS, &priv_dev->regs->usb_conf); + break; + case USB_SPEED_HIGH: + writel(USB_CONF_USB3DIS, &priv_dev->regs->usb_conf); + break; + case USB_SPEED_SUPER: + break; + default: + dev_err(cdns->dev, "invalid speed parameter %d\n", + speed); + } + + priv_dev->gadget.speed = speed; +} + static const struct usb_gadget_ops cdns3_gadget_ops = { .get_frame = cdns3_gadget_get_frame, .wakeup = cdns3_gadget_wakeup, @@ -2386,6 +2409,7 @@ static const struct usb_gadget_ops cdns3_gadget_ops = { .udc_start = cdns3_gadget_udc_start, .udc_stop = cdns3_gadget_udc_stop, .match_ep = cdns3_gadget_match_ep, + .udc_set_speed = cdns3_gadget_udc_set_speed, };
static void cdns3_free_all_eps(struct cdns3_device *priv_dev) @@ -2557,11 +2581,9 @@ static int cdns3_gadget_start(struct cdns3 *cdns) /* Check the maximum_speed parameter */ switch (max_speed) { case USB_SPEED_FULL: - writel(USB_CONF_SFORCE_FS, &priv_dev->regs->usb_conf); - break; + /* fall through */ case USB_SPEED_HIGH: - writel(USB_CONF_USB3DIS, &priv_dev->regs->usb_conf); - break; + /* fall through */ case USB_SPEED_SUPER: break; default:
Add driver to handle TI specific wrapper for Cadence USB3 controller present on J721e SoC. Based on Linux driver for the same.
Signed-off-by: Vignesh Raghavendra vigneshr@ti.com --- drivers/usb/cdns3/Kconfig | 7 ++ drivers/usb/cdns3/Makefile | 2 + drivers/usb/cdns3/cdns3-ti.c | 193 +++++++++++++++++++++++++++++++++++ 3 files changed, 202 insertions(+) create mode 100644 drivers/usb/cdns3/cdns3-ti.c
diff --git a/drivers/usb/cdns3/Kconfig b/drivers/usb/cdns3/Kconfig index 25c0f103e742..4cf59c70d431 100644 --- a/drivers/usb/cdns3/Kconfig +++ b/drivers/usb/cdns3/Kconfig @@ -48,4 +48,11 @@ config SPL_USB_CDNS3_HOST
Host controller is compliant with XHCI so it will use standard XHCI driver. + +config USB_CDNS3_TI + tristate "Cadence USB3 support on TI platforms" + default USB_CDNS3 + help + Say 'Y' here if you are building for Texas Instruments + platforms that contain Cadence USB3 controller core. E.g.: J721e. endif diff --git a/drivers/usb/cdns3/Makefile b/drivers/usb/cdns3/Makefile index 525477954dd8..18d7190755d2 100644 --- a/drivers/usb/cdns3/Makefile +++ b/drivers/usb/cdns3/Makefile @@ -7,3 +7,5 @@ obj-$(CONFIG_USB_CDNS3) += cdns3.o cdns3-$(CONFIG_$(SPL_)USB_CDNS3_GADGET) += gadget.o ep0.o
cdns3-$(CONFIG_$(SPL_)USB_CDNS3_HOST) += host.o + +obj-$(CONFIG_USB_CDNS3_TI) += cdns3-ti.o diff --git a/drivers/usb/cdns3/cdns3-ti.c b/drivers/usb/cdns3/cdns3-ti.c new file mode 100644 index 000000000000..2fa0104f1bee --- /dev/null +++ b/drivers/usb/cdns3/cdns3-ti.c @@ -0,0 +1,193 @@ +// SPDX-License-Identifier: GPL-2.0 +/** + * cdns_ti-ti.c - TI specific Glue layer for Cadence USB Controller + * + * Copyright (C) 2019 Texas Instruments Incorporated - http://www.ti.com + */ + +#include <common.h> +#include <asm-generic/io.h> +#include <clk.h> +#include <dm.h> +#include <linux/io.h> +#include <linux/usb/otg.h> +#include <malloc.h> + +#include "core.h" + +/* USB Wrapper register offsets */ +#define USBSS_PID 0x0 +#define USBSS_W1 0x4 +#define USBSS_STATIC_CONFIG 0x8 +#define USBSS_PHY_TEST 0xc +#define USBSS_DEBUG_CTRL 0x10 +#define USBSS_DEBUG_INFO 0x14 +#define USBSS_DEBUG_LINK_STATE 0x18 +#define USBSS_DEVICE_CTRL 0x1c + +/* Wrapper 1 register bits */ +#define USBSS_W1_PWRUP_RST BIT(0) +#define USBSS_W1_OVERCURRENT_SEL BIT(8) +#define USBSS_W1_MODESTRAP_SEL BIT(9) +#define USBSS_W1_OVERCURRENT BIT(16) +#define USBSS_W1_MODESTRAP_MASK GENMASK(18, 17) +#define USBSS_W1_MODESTRAP_SHIFT 17 +#define USBSS_W1_USB2_ONLY BIT(19) + +/* Static config register bits */ +#define USBSS1_STATIC_PLL_REF_SEL_MASK GENMASK(8, 5) +#define USBSS1_STATIC_PLL_REF_SEL_SHIFT 5 +#define USBSS1_STATIC_LOOPBACK_MODE_MASK GENMASK(4, 3) +#define USBSS1_STATIC_LOOPBACK_MODE_SHIFT 3 +#define USBSS1_STATIC_VBUS_SEL_MASK GENMASK(2, 1) +#define USBSS1_STATIC_VBUS_SEL_SHIFT 1 +#define USBSS1_STATIC_LANE_REVERSE BIT(0) + +/* Modestrap modes */ +enum modestrap_mode { USBSS_MODESTRAP_MODE_NONE, + USBSS_MODESTRAP_MODE_HOST, + USBSS_MODESTRAP_MODE_PERIPHERAL}; + +struct cdns_ti { + struct udevice *dev; + void __iomem *usbss; + int usb2_only:1; + int vbus_divider:1; + struct clk *usb2_refclk; + struct clk *lpm_clk; +}; + +static const int cdns_ti_rate_table[] = { /* in KHZ */ + 9600, + 10000, + 12000, + 19200, + 20000, + 24000, + 25000, + 26000, + 38400, + 40000, + 58000, + 50000, + 52000, +}; + +static inline u32 cdns_ti_readl(struct cdns_ti *data, u32 offset) +{ + return readl(data->usbss + offset); +} + +static inline void cdns_ti_writel(struct cdns_ti *data, u32 offset, u32 value) +{ + writel(value, data->usbss + offset); +} + +static int cdns_ti_probe(struct udevice *dev) +{ + struct cdns_ti *data = dev_get_platdata(dev); + struct clk usb2_refclk; + int modestrap_mode; + unsigned long rate; + int rate_code, i; + u32 reg; + int ret; + + data->dev = dev; + + data->usbss = dev_remap_addr_index(dev, 0); + if (!data->usbss) + return -EINVAL; + + ret = clk_get_by_name(dev, "usb2_refclk", &usb2_refclk); + if (ret) { + dev_err(dev, "Failed to get usb2_refclk\n"); + return ret; + } + + rate = clk_get_rate(&usb2_refclk); + rate /= 1000; /* To KHz */ + for (i = 0; i < ARRAY_SIZE(cdns_ti_rate_table); i++) { + if (cdns_ti_rate_table[i] == rate) + break; + } + + if (i == ARRAY_SIZE(cdns_ti_rate_table)) { + dev_err(dev, "unsupported usb2_refclk rate: %lu KHz\n", rate); + return -EINVAL; + } + + rate_code = i; + + /* assert RESET */ + reg = cdns_ti_readl(data, USBSS_W1); + reg &= ~USBSS_W1_PWRUP_RST; + cdns_ti_writel(data, USBSS_W1, reg); + + /* set static config */ + reg = cdns_ti_readl(data, USBSS_STATIC_CONFIG); + reg &= ~USBSS1_STATIC_PLL_REF_SEL_MASK; + reg |= rate_code << USBSS1_STATIC_PLL_REF_SEL_SHIFT; + + reg &= ~USBSS1_STATIC_VBUS_SEL_MASK; + data->vbus_divider = dev_read_bool(dev, "ti,vbus-divider"); + if (data->vbus_divider) + reg |= 1 << USBSS1_STATIC_VBUS_SEL_SHIFT; + + cdns_ti_writel(data, USBSS_STATIC_CONFIG, reg); + reg = cdns_ti_readl(data, USBSS_STATIC_CONFIG); + + /* set USB2_ONLY mode if requested */ + reg = cdns_ti_readl(data, USBSS_W1); + data->usb2_only = dev_read_bool(dev, "ti,usb2-only"); + if (data->usb2_only) + reg |= USBSS_W1_USB2_ONLY; + + /* set modestrap */ + if (dev_read_bool(dev, "ti,modestrap-host")) + modestrap_mode = USBSS_MODESTRAP_MODE_HOST; + else if (dev_read_bool(dev, "ti,modestrap-peripheral")) + modestrap_mode = USBSS_MODESTRAP_MODE_PERIPHERAL; + else + modestrap_mode = USBSS_MODESTRAP_MODE_NONE; + + reg |= USBSS_W1_MODESTRAP_SEL; + reg &= ~USBSS_W1_MODESTRAP_MASK; + reg |= modestrap_mode << USBSS_W1_MODESTRAP_SHIFT; + cdns_ti_writel(data, USBSS_W1, reg); + + /* de-assert RESET */ + reg |= USBSS_W1_PWRUP_RST; + cdns_ti_writel(data, USBSS_W1, reg); + + return 0; +} + +static int cdns_ti_remove(struct udevice *dev) +{ + struct cdns_ti *data = dev_get_platdata(dev); + u32 reg; + + /* put device back to RESET*/ + reg = cdns_ti_readl(data, USBSS_W1); + reg &= ~USBSS_W1_PWRUP_RST; + cdns_ti_writel(data, USBSS_W1, reg); + + return 0; +} + +static const struct udevice_id cdns_ti_of_match[] = { + { .compatible = "ti,j721e-usb", }, + {}, +}; + +U_BOOT_DRIVER(cdns_ti) = { + .name = "cdns-ti", + .id = UCLASS_NOP, + .of_match = cdns_ti_of_match, + .bind = cdns3_bind, + .probe = cdns_ti_probe, + .remove = cdns_ti_remove, + .platdata_auto_alloc_size = sizeof(struct cdns_ti), + .flags = DM_FLAG_OS_PREPARE, +};
Add a new bcdDevice entry for Cadence USB gadget controller similar to other controller and add gadget_is_cdns3() macro as well.
Signed-off-by: Vignesh Raghavendra vigneshr@ti.com --- drivers/usb/gadget/gadget_chips.h | 8 ++++++++ 1 file changed, 8 insertions(+)
diff --git a/drivers/usb/gadget/gadget_chips.h b/drivers/usb/gadget/gadget_chips.h index 2c8f235d51c8..91b0285244ec 100644 --- a/drivers/usb/gadget/gadget_chips.h +++ b/drivers/usb/gadget/gadget_chips.h @@ -149,6 +149,12 @@ #define gadget_is_dwc3(g) 0 #endif
+#ifdef CONFIG_USB_CDNS3_GADGET +#define gadget_is_cdns3(g) (!strcmp("cdns3-gadget", (g)->name)) +#else +#define gadget_is_cdns3(g) 0 +#endif + /** * usb_gadget_controller_number - support bcdDevice id convention * @gadget: the controller being driven @@ -208,5 +214,7 @@ static inline int usb_gadget_controller_number(struct usb_gadget *gadget) return 0x22; else if (gadget_is_dwc3(gadget)) return 0x23; + else if (gadget_is_cdns3(gadget)) + return 0x24; return -ENOENT; }
On 01/10/2019 13:56, Vignesh Raghavendra wrote:
This series adds support for Cadence USB Host and Gadget controller drivers. This is borrowed directly from Linux kernel v5.4-rc1. Driver as such supports both 3.0 and 2.0 speeds. But USB 3.0 requires a PHY driver which will be added in a separate follow series
Patch 7 adds TI wrapper driver for Cadence USB controller.
Both host and device mode has been tested on TI's J721e SoC. DFU, UMS and fastboot gadgets have been tested.
Complete series (+ DT nodes required for J721e) can be found here: https://github.com/r-vignesh/u-boot.git branch: usb
Regards Vignesh
Sherry Sun (1): usb: udc: Introduce ->udc_set_speed() method
Vignesh Raghavendra (7): list: import list_first_entry_or_null() bitmaps: import for_each_set_bit() macro usb: gadget: Add match_ep() op to usb_gadget_ops usb: Add Cadence USB3 host and gadget driver usb: cdns3: gadget: Implement udc_set_speed() callback usb: cdns3: Add TI wrapper driver for CDNS USB3 controller usb: gadget: Add gadget_is_cdns3() macro
Makefile | 1 + drivers/usb/Kconfig | 2 + drivers/usb/cdns3/Kconfig | 58 + drivers/usb/cdns3/Makefile | 11 + drivers/usb/cdns3/cdns3-ti.c | 193 ++ drivers/usb/cdns3/core.c | 498 ++++++ drivers/usb/cdns3/core.h | 108 ++ drivers/usb/cdns3/debug.h | 162 ++ drivers/usb/cdns3/drd.c | 301 ++++ drivers/usb/cdns3/drd.h | 166 ++ drivers/usb/cdns3/ep0.c | 910 ++++++++++ drivers/usb/cdns3/gadget-export.h | 28 + drivers/usb/cdns3/gadget.c | 2760 +++++++++++++++++++++++++++++ drivers/usb/cdns3/gadget.h | 1338 ++++++++++++++ drivers/usb/cdns3/host-export.h | 28 + drivers/usb/cdns3/host.c | 55 + drivers/usb/cdns3/trace.c | 11 + drivers/usb/cdns3/trace.h | 26 + drivers/usb/gadget/epautoconf.c | 3 + drivers/usb/gadget/gadget_chips.h | 8 + drivers/usb/gadget/udc/udc-core.c | 23 + include/linux/bitmap.h | 61 + include/linux/list.h | 14 + include/linux/usb/gadget.h | 25 + scripts/Makefile.spl | 1 + 25 files changed, 6791 insertions(+) create mode 100644 drivers/usb/cdns3/Kconfig create mode 100644 drivers/usb/cdns3/Makefile create mode 100644 drivers/usb/cdns3/cdns3-ti.c create mode 100644 drivers/usb/cdns3/core.c create mode 100644 drivers/usb/cdns3/core.h create mode 100644 drivers/usb/cdns3/debug.h create mode 100644 drivers/usb/cdns3/drd.c create mode 100644 drivers/usb/cdns3/drd.h create mode 100644 drivers/usb/cdns3/ep0.c create mode 100644 drivers/usb/cdns3/gadget-export.h create mode 100644 drivers/usb/cdns3/gadget.c create mode 100644 drivers/usb/cdns3/gadget.h create mode 100644 drivers/usb/cdns3/host-export.h create mode 100644 drivers/usb/cdns3/host.c create mode 100644 drivers/usb/cdns3/trace.c create mode 100644 drivers/usb/cdns3/trace.h
I tested the series for Host and device operations onĀ with a J721e-evm.
As expected, USB3 is not yet supported on the J721e because the driver for the USB3 phy is not there yet.
Tested-by: Jean-Jacques Hiblot jjhiblot@ti.com
Jean-Jacques Hiblot
Vignesh Raghavendra
