[U-Boot] [PATCH v3 29/29] doc: Update the zynq u-boot status
Updated doc/README.zynq to current status.
Signed-off-by: Jagannadha Sutradharudu Teki jaganna@xilinx.com --- V3: Updated acc to current status V2: none
doc/README.zynq | 26 ++++++++++++++++++-------- 1 file changed, 18 insertions(+), 8 deletions(-)
diff --git a/doc/README.zynq b/doc/README.zynq index ea1c8c1..6330408 100644 --- a/doc/README.zynq +++ b/doc/README.zynq @@ -28,7 +28,16 @@ and I/O programmability. - zc770-xm012 (nor) - zc770-xm013 (dual parallel qspi, gem1)
-3. Bootmode +3. Building + + # Configure for microzed board + $ make zynq_microzed_config + Configuring for zynq_microzed board... + + # Building + $ make DEVICE_TREE=zynq-microzed + +4. Bootmode
Zynq has a facility to read the bootmode from the slcr bootmode register once user is setting through jumpers on the board - see page no:1546 on [5] @@ -48,11 +57,11 @@ SLCR bootmode register Bit[3:0] values "modeboot" variable can assign any of "norboot", "sdboot" or "jtagboot" bootmode strings at runtime.
-4. Mainline status +5. Mainline status
- Added basic board configurations support. - Added zynq u-boot bsp code - arch/arm/cpu/armv7/zynq -- Added zynq boards named - zynq, zynq_dcc +- Added zynq boards named - zc70x, zed, microzed, zc770_xm010, zc770_xm012, zc770_xm013 - Added zynq drivers: serial - drivers/serial/serial_zynq.c net - drivers/net/zynq_gem.c @@ -60,15 +69,16 @@ bootmode strings at runtime. mmc - drivers/mmc/zynq_sdhci.c spi- drivers/spi/zynq_spi.c i2c - drivers/i2c/zynq_i2c.c +- Done proper cleanups on board configurations +- Added basic FDT support for zynq boards +- d-cache support for zynq_gem.c
-5. TODO +6. TODO
-- Add zynq boards support - zc70x, zed, microzed, zc770 +- Add zynq boards support - zc770_xm011 - Add zynq qspi controller driver - Add zynq nand controller driver -- d-cache support for zynq_gem.c -- FDT support for zynq boards -- Need proper cleanups on board configurations +- Add FDT support on individual drivers
[1] http://www.xilinx.com/products/boards-and-kits/EK-Z7-ZC702-G.htm [2] http://www.xilinx.com/products/boards-and-kits/EK-Z7-ZC706-G.htm
