[U-Boot] [PATCH] powerpc/t104xrdb: Add T1042RDB board support
T1042RDB is Freescale Reference Design Board supporting the T1042 QorIQ Power Architecture processor. T1042 is a reduced personality of T1040 SoC without Integrated 8-port Gigabit. The board is designed with low power features targeted for Printing Image Market.
T1042RDB board Overview ----------------------- - Four e5500 cores, each with a private 256 KB L2 cache - 256 KB shared L3 CoreNet platform cache (CPC) - Interconnect CoreNet platform - 32-/64-bit DDR3L/DDR4 SDRAM memory controller with ECC and interleaving support - Data Path Acceleration Architecture (DPAA) incorporating acceleration for the following functions: - Packet parsing, classification, and distribution - Queue management for scheduling, packet sequencing, and congestion management - Cryptography Acceleration - RegEx Pattern Matching Acceleration - IEEE Std 1588 support - Hardware buffer management for buffer allocation and deallocation - Ethernet interfaces - Two on-board RGMII 10/100/1G ethernet ports. - SERDES Connections, 8 lanes supporting: - PCI - SGMII - SATA 2.0 - DDR Controller 32-/64-bit DDR3L/DDR4 SDRAM memory controller with ECC and Interleaving - IFC/Local Bus - NAND flash: 1GB 8-bit NAND flash - NOR: 128MB 16-bit NOR Flash - Ethernet - Two on-board RGMII 10/100/1G ethernet ports. - PHY #0 remains powered up during deep-sleep - CPLD - Clocks - System and DDR clock (SYSCLK, ?DDRCLK?) - SERDES clocks - Video - DIU supports video at up to 1280x1024x32bpp - HDMI connector - Power Supplies - USB - Supports two USB 2.0 ports with integrated PHYs - Two type A ports with 5V@1.5A per port. - SDHC - SDHC/SDXC connector - SPI - On-board 64MB SPI flash - I2C - Device connected: EEPROM, thermal monitor, VID controller, RTC - Other IO - Two Serial ports - ProfiBus port
T1042RDB is configured as serdes protocol 0x86 which can support following interfaces 2 RGMIIS on DTSEC4, DTSEC5 1 SGMII on DTSEC3
Comments updated for 0x06 protocol in place of 0x66 protocol for T1042RDB_PI
This patch also does minor clean ups for fdt defines for T1042RDB_PI board
Signed-off-by: Vijay Rai vijay.rai@freescale.com Signed-off-by: Priyanka Jain Priyanka.Jain@freescale.com --- board/freescale/t104xrdb/t1042_rcw.cfg | 2 +- boards.cfg | 1 + include/configs/T104xRDB.h | 15 +++++++++------ 3 files changed, 11 insertions(+), 7 deletions(-)
diff --git a/board/freescale/t104xrdb/t1042_rcw.cfg b/board/freescale/t104xrdb/t1042_rcw.cfg index a3ea8ad..57de89a 100644 --- a/board/freescale/t104xrdb/t1042_rcw.cfg +++ b/board/freescale/t104xrdb/t1042_rcw.cfg @@ -1,6 +1,6 @@ #PBL preamble and RCW header aa55aa55 010e0100 -# serdes protocol 0x66 +# serdes protocol 0x06 0c18000e 0e000000 00000000 00000000 06000002 00400002 e8106000 01000000 00000000 00000000 00000000 00030810 diff --git a/boards.cfg b/boards.cfg index b8cfead..a989ea2 100644 --- a/boards.cfg +++ b/boards.cfg @@ -961,6 +961,7 @@ Active powerpc mpc85xx - freescale t104xrdb Active powerpc mpc85xx - freescale t104xrdb T1040RDB_SDCARD T104xRDB:PPC_T1040,T1040RDB,RAMBOOT_PBL,SPL_FSL_PBL,SDCARD - Active powerpc mpc85xx - freescale t104xrdb T1040RDB_SECURE_BOOT T104xRDB:PPC_T1040,SECURE_BOOT,T1040RDB Aneesh Bansal aneesh.bansal@freescale.com Active powerpc mpc85xx - freescale t104xrdb T1040RDB_SPIFLASH T104xRDB:PPC_T1040,T1040RDB,RAMBOOT_PBL,SPL_FSL_PBL,SPIFLASH Priyanka Jain Priyanka.Jain@freescale.com +Active powerpc mpc85xx - freescale t104xrdb T1042RDB T104xRDB:PPC_T1042,T1042RDB Priyanka Jain Priyanka.Jain@freescale.com Active powerpc mpc85xx - freescale t104xrdb T1042RDB_PI T104xRDB:PPC_T1042,T1042RDB_PI Priyanka Jain Priyanka.Jain@freescale.com Active powerpc mpc85xx - freescale t104xrdb T1042RDB_PI_NAND T104xRDB:PPC_T1042,T1042RDB_PI,RAMBOOT_PBL,SPL_FSL_PBL,NAND Priyanka Jain Priyanka.Jain@freescale.com Active powerpc mpc85xx - freescale t104xrdb T1042RDB_PI_SDCARD T104xRDB:PPC_T1042,T1042RDB_PI,RAMBOOT_PBL,SPL_FSL_PBL,SDCARD - diff --git a/include/configs/T104xRDB.h b/include/configs/T104xRDB.h index 8d6c51b..0e6b2e8 100644 --- a/include/configs/T104xRDB.h +++ b/include/configs/T104xRDB.h @@ -451,7 +451,7 @@
/* I2C bus multiplexer */ #define I2C_MUX_PCA_ADDR 0x70 -#ifdef CONFIG_T1040RDB +#if defined (CONFIG_T1040RDB) || defined (CONFIG_T1042RDB) #define I2C_MUX_CH_DEFAULT 0x8 #endif
@@ -603,7 +603,7 @@ #define CONFIG_SYS_DPAA_FMAN #define CONFIG_SYS_DPAA_PME
-#ifdef CONFIG_T1040RDB +#if defined (CONFIG_T1040RDB) || defined (CONFIG_T1042RDB) #define CONFIG_QE #define CONFIG_U_QE #endif @@ -632,7 +632,7 @@ #define CONFIG_SYS_FMAN_FW_ADDR 0xEFF00000 #endif
-#ifdef CONFIG_T1040RDB +#if defined (CONFIG_T1040RDB) || defined (CONFIG_T1042RDB) #if defined(CONFIG_SPIFLASH) #define CONFIG_SYS_QE_FW_ADDR 0x130000 #elif defined(CONFIG_SDCARD) @@ -656,7 +656,7 @@ #endif
#ifdef CONFIG_FMAN_ENET -#ifdef CONFIG_T1040RDB +#if defined (CONFIG_T1040RDB) || defined (CONFIG_T1042RDB) #define CONFIG_SYS_SGMII1_PHY_ADDR 0x03 #endif #define CONFIG_SYS_RGMII1_PHY_ADDR 0x01 @@ -763,8 +763,11 @@ #define FDTFILE "t1040rdb/t1040rdb.dtb" #define RAMDISKFILE "t1040rdb/ramdisk.uboot" #elif CONFIG_T1042RDB_PI -#define FDTFILE "t1040rdb_pi/t1040rdb_pi.dtb" -#define RAMDISKFILE "t1040rdb_pi/ramdisk.uboot" +#define FDTFILE "t1042rdb_pi/t1042rdb_pi.dtb" +#define RAMDISKFILE "t1042rdb_pi/ramdisk.uboot" +#elif CONFIG_T1042RDB +#define FDTFILE "t1042rdb/t1042rdb.dtb" +#define RAMDISKFILE "t1042rdb/ramdisk.uboot" #endif
#define CONFIG_EXTRA_ENV_SETTINGS \
- CPLD
- Power Supplies
I prefer you move this to board README file.
Can you explain the difference among T1040RDB, T1042RDB_PI, T1042RDB? It would be nice to put them in a table in README.
Just say "fix the comment to match serdes protocol".
This is for both T1042RDB and T1042RDB_PI, right?
I can see the value of defaulting fdt file. But I don't see the value of differentiating ramdisk file name. Do you really need put a path before the file name? It would be cleaner to get rid of the path and use a common ramdisk file name.
York
Vijay Rai
York Sun
