[U-Boot] [PATCH v3 09/28] sf: probe: Add support for SST25* flash parts
Added SST25* parts are which are avilable in spi_flash_probe_legacy.c.
Updated the sector_size attributes as per the flash parts. Looks fine for with this sector_size for computing the size of flash.
Signed-off-by: Jagannadha Sutradharudu Teki jaganna@xilinx.com --- Changes for v3: - none Changes for v2: - Enable CONFIG_SPI_FLASH_SST
drivers/mtd/spi/spi_flash_probe.c | 13 ++++++++++++- 1 file changed, 12 insertions(+), 1 deletion(-)
diff --git a/drivers/mtd/spi/spi_flash_probe.c b/drivers/mtd/spi/spi_flash_probe.c index 6f0dd84..62c9d0a 100644 --- a/drivers/mtd/spi/spi_flash_probe.c +++ b/drivers/mtd/spi/spi_flash_probe.c @@ -88,6 +88,18 @@ static const struct spi_flash_params spi_flash_params_table[] = { {"N25Q1024", 0x20ba21, 0x0, 64 * 1024, 2048}, {"N25Q1024A", 0x20bb21, 0x0, 64 * 1024, 2048}, #endif +#ifdef CONFIG_SPI_FLASH_SST /* SST */ + {"SST25VF040B", 0xbf258d, 0x0, 64 * 1024, 8}, + {"SST25VF080B", 0xbf258e, 0x0, 64 * 1024, 16}, + {"SST25VF016B", 0xbf2541, 0x0, 64 * 1024, 32}, + {"SST25VF032B", 0xbf254a, 0x0, 64 * 1024, 64}, + {"SST25VF064C", 0xbf254b, 0x0, 64 * 1024, 128}, + {"SST25WF512", 0xbf2501, 0x0, 64 * 1024, 1}, + {"SST25WF010", 0xbf2502, 0x0, 64 * 1024, 2}, + {"SST25WF020", 0xbf2503, 0x0, 64 * 1024, 4}, + {"SST25WF040", 0xbf2504, 0x0, 64 * 1024, 8}, + {"SST25WF080", 0xbf2505, 0x0, 64 * 1024, 16}, +#endif #ifdef CONFIG_SPI_FLASH_WINBOND /* WINBOND */ {"W25P80", 0xef2014, 0x0, 64 * 1024, 16}, {"W25P16", 0xef2015, 0x0, 64 * 1024, 32}, @@ -125,7 +137,6 @@ static const struct spi_flash_params spi_flash_params_table[] = { * TODO: * ATMEL * RAMTRON - * SST */ };
Changes for v3:
- none
Changes for v2:
- {"SST25VF040B", 0xbf258d, 0x0, 64 * 1024, 8},
- {"SST25VF080B", 0xbf258e, 0x0, 64 * 1024, 16},
- {"SST25VF016B", 0xbf2541, 0x0, 64 * 1024, 32},
- {"SST25VF032B", 0xbf254a, 0x0, 64 * 1024, 64},
- {"SST25VF064C", 0xbf254b, 0x0, 64 * 1024, 128},
- {"SST25WF512", 0xbf2501, 0x0, 64 * 1024, 1},
- {"SST25WF010", 0xbf2502, 0x0, 64 * 1024, 2},
- {"SST25WF020", 0xbf2503, 0x0, 64 * 1024, 4},
- {"SST25WF040", 0xbf2504, 0x0, 64 * 1024, 8},
- {"SST25WF080", 0xbf2505, 0x0, 64 * 1024, 16},
*/ };* SST
Tested-by: Eric Nelson eric.nelson@boundarydevices.com
Tested on i.MX6Q (nitrogen6q) and i.MX6S (nitrogen6s) with p/n SST25VF016B.
Eric Nelson
