[PATCH] efi_loader: use event callback for initrd deregistration
Currently efi_initrd_deregister() is called in bootefi.c when the image started from bootefi command returns. Since efi_guid_event_group_return_to_efibootmgr event is implemented, so let's use this event for invoking initrd deregistration.
Signed-off-by: Masahisa Kojima masahisa.kojima@linaro.org --- Note that this patch can be applied to u-boot/next. This patch requires the patch e0d1a1ea68("efi_loader: add return to efibootmgr event group")
cmd/bootefi.c | 5 -- lib/efi_loader/efi_load_initrd.c | 82 +++++++++++++++++++++----------- 2 files changed, 55 insertions(+), 32 deletions(-)
diff --git a/cmd/bootefi.c b/cmd/bootefi.c index 4d74969ad6..e52bd3f743 100644 --- a/cmd/bootefi.c +++ b/cmd/bootefi.c @@ -390,11 +390,6 @@ static efi_status_t do_bootefi_exec(efi_handle_t handle, void *load_options) out: free(load_options);
- if (IS_ENABLED(CONFIG_EFI_LOAD_FILE2_INITRD)) { - if (efi_initrd_deregister() != EFI_SUCCESS) - log_err("Failed to remove loadfile2 for initrd\n"); - } - /* Notify EFI_EVENT_GROUP_RETURN_TO_EFIBOOTMGR event group. */ list_for_each_entry(evt, &efi_events, link) { if (evt->group && diff --git a/lib/efi_loader/efi_load_initrd.c b/lib/efi_loader/efi_load_initrd.c index 193433782c..7ca7785c04 100644 --- a/lib/efi_loader/efi_load_initrd.c +++ b/lib/efi_loader/efi_load_initrd.c @@ -184,6 +184,50 @@ out: return ret; }
+/** + * efi_initrd_deregister() - delete the handle for loading initial RAM disk + * + * This will delete the handle containing the Linux specific vendor device + * path and EFI_LOAD_FILE2_PROTOCOL for loading an initrd + * + * Return: status code + */ +efi_status_t efi_initrd_deregister(void) +{ + efi_status_t ret; + + if (!efi_initrd_handle) + return EFI_SUCCESS; + + ret = efi_uninstall_multiple_protocol_interfaces(efi_initrd_handle, + /* initramfs */ + &efi_guid_device_path, + &dp_lf2_handle, + /* LOAD_FILE2 */ + &efi_guid_load_file2_protocol, + &efi_lf2_protocol, + NULL); + efi_initrd_handle = NULL; + + return ret; +} + +/** + * efi_initrd_return_notify() - return to efibootmgr callback + * + * @event: the event for which this notification function is registered + * @context: event context + */ +static void EFIAPI efi_initrd_return_notify(struct efi_event *event, + void *context) +{ + efi_status_t ret; + + EFI_ENTRY("%p, %p", event, context); + ret = efi_initrd_deregister(); + EFI_EXIT(ret); +} + /** * efi_initrd_register() - create handle for loading initial RAM disk * @@ -197,6 +241,7 @@ out: efi_status_t efi_initrd_register(void) { efi_status_t ret; + struct efi_event *event;
/* * Allow the user to continue if Boot#### file path is not set for @@ -215,34 +260,17 @@ efi_status_t efi_initrd_register(void) &efi_guid_load_file2_protocol, &efi_lf2_protocol, NULL); + if (ret != EFI_SUCCESS) { + log_err("installing EFI_LOAD_FILE2_PROTOCOL failed\n"); + return ret; + }
- return ret; -} - -/** - * efi_initrd_deregister() - delete the handle for loading initial RAM disk - * - * This will delete the handle containing the Linux specific vendor device - * path and EFI_LOAD_FILE2_PROTOCOL for loading an initrd - * - * Return: status code - */ -efi_status_t efi_initrd_deregister(void) -{ - efi_status_t ret; - - if (!efi_initrd_handle) - return EFI_SUCCESS; - - ret = efi_uninstall_multiple_protocol_interfaces(efi_initrd_handle, - /* initramfs */ - &efi_guid_device_path, - &dp_lf2_handle, - /* LOAD_FILE2 */ - &efi_guid_load_file2_protocol, - &efi_lf2_protocol, - NULL); - efi_initrd_handle = NULL; + ret = efi_create_event(EVT_NOTIFY_SIGNAL, TPL_CALLBACK, + efi_initrd_return_notify, NULL, + &efi_guid_event_group_return_to_efibootmgr, + &event); + if (ret != EFI_SUCCESS) + log_err("Creating event failed\n");
return ret; }
base-commit: 4a363dd516856344558034027e40d903868f67b4
Thanks for cleaning this up!
On Mon, 4 Dec 2023 at 06:31, Masahisa Kojima masahisa.kojima@linaro.org wrote:
Reviewed-by: Ilias Apalodimas ilias.apalodimas@linaro.org Tested-by: Ilias Apalodimas ilias.apalodimas@linaro.org
- efi_initrd_deregister() - delete the handle for loading initial RAM disk
- This will delete the handle containing the Linux specific vendor device
- path and EFI_LOAD_FILE2_PROTOCOL for loading an initrd
- Return: status code
efi_status_t ret;
return EFI_SUCCESS;
/* initramfs */
&dp_lf2_handle,
/* LOAD_FILE2 */
&efi_lf2_protocol,
NULL);
return ret;
- efi_initrd_return_notify() - return to efibootmgr callback
- @event: the event for which this notification function is registered
- @context: event context
void *context)
efi_status_t ret;
EFI_EXIT(ret);
- efi_initrd_register() - create handle for loading initial RAM disk
struct efi_event *event; /* * Allow the user to continue if Boot#### file path is not set for
return ret;
return ret;
efi_status_t ret;
return EFI_SUCCESS;
/* initramfs */
&dp_lf2_handle,
/* LOAD_FILE2 */
&efi_lf2_protocol,
NULL);
&event);
log_err("Creating event failed\n"); return ret;
2.34.1
Kojima-san
Apologies but for some reason we failed to pull this patch.... In meantime some parts of the bootefi.c code -- specifically theinitrd cleanup, have been moved to efi_helper.c
Any chance you can rebase this? If not I'll try to find some time to do it
efi_status_t ret;
return EFI_SUCCESS;
/* initramfs */
&dp_lf2_handle,
/* LOAD_FILE2 */
&efi_lf2_protocol,
NULL);
return ret;
void *context)
efi_status_t ret;
EFI_EXIT(ret);
return ret;
return ret;
efi_status_t ret;
return EFI_SUCCESS;
/* initramfs */
&dp_lf2_handle,
/* LOAD_FILE2 */
&efi_lf2_protocol,
NULL);
&event);
2.34.1
Ilias Apalodimas
Masahisa Kojima
