[U-Boot] [PATCH 1/8] armv7: Add workaround for USB erratum A-009008
USB High Speed (HS) EYE Height Adjustment This patch is adding the erratum for LS1021.
Signed-off-by: Sriram Dash sriram.dash@nxp.com Signed-off-by: yinbo.zhu yinbo.zhu@nxp.com --- arch/arm/cpu/armv7/ls102xa/soc.c | 12 ++++++++++++ arch/arm/include/asm/arch-ls102xa/config.h | 4 ++++ arch/arm/include/asm/arch-ls102xa/immap_ls102xa.h | 4 ++++ 3 files changed, 20 insertions(+)
diff --git a/arch/arm/cpu/armv7/ls102xa/soc.c b/arch/arm/cpu/armv7/ls102xa/soc.c index 52fb6f8..c54daee 100644 --- a/arch/arm/cpu/armv7/ls102xa/soc.c +++ b/arch/arm/cpu/armv7/ls102xa/soc.c @@ -60,6 +60,16 @@ unsigned int get_soc_major_rev(void) return major; }
+static void erratum_a009008(void) +{ +#ifdef CONFIG_SYS_FSL_ERRATUM_A009008 + u32 __iomem *scfg = (u32 __iomem *)SCFG_BASE; + u32 val = in_be32(scfg + SCFG_USB3PRM1CR / 4); + val &= ~(0xF << 6); + out_be32(scfg + SCFG_USB3PRM1CR / 4, val|(USB_TXVREFTUNE << 6)); +#endif /* CONFIG_SYS_FSL_ERRATUM_A009008 */ +} + void s_init(void) { } @@ -146,6 +156,8 @@ int arch_soc_init(void) */ out_be32(&scfg->eddrtqcfg, 0x63b20042);
+ /* Erratum */ + erratum_a009008(); return 0; }
diff --git a/arch/arm/include/asm/arch-ls102xa/config.h b/arch/arm/include/asm/arch-ls102xa/config.h index 2f7233f..5b89f16 100644 --- a/arch/arm/include/asm/arch-ls102xa/config.h +++ b/arch/arm/include/asm/arch-ls102xa/config.h @@ -110,6 +110,10 @@
#ifdef CONFIG_LS102XA #define CONFIG_USB_MAX_CONTROLLER_COUNT 1 +#define CONFIG_SYS_FSL_ERRATUM_A008378 +#define CONFIG_SYS_FSL_ERRATUM_A009663 +#define CONFIG_SYS_FSL_ERRATUM_A009008 +#define CONFIG_SYS_FSL_ERRATUM_A009942 #define CONFIG_SYS_FSL_MAX_NUM_OF_SEC 1 #else #error SoC not defined diff --git a/arch/arm/include/asm/arch-ls102xa/immap_ls102xa.h b/arch/arm/include/asm/arch-ls102xa/immap_ls102xa.h index c34fd63..f474cfd 100644 --- a/arch/arm/include/asm/arch-ls102xa/immap_ls102xa.h +++ b/arch/arm/include/asm/arch-ls102xa/immap_ls102xa.h @@ -172,6 +172,10 @@ struct ccsr_gur { #define SCFG_PMCINTECR_ETSECERRG0 0x00080000 #define SCFG_PMCINTECR_ETSECERRG1 0x00040000 #define SCFG_CLUSTERPMCR_WFIL2EN 0x80000000 +#define SCFG_BASE 0x01570000 +#define SCFG_USB3PRM1CR 0x070 +#define USB_TXVREFTUNE 0x9 +
/* Supplemental Configuration Unit */ struct ccsr_scfg {
USB High Speed Squelch Threshold Adjustment This patch is adding the erratum for LS1021.
Signed-off-by: Sriram Dash sriram.dash@nxp.com Signed-off-by: Rajesh Bhagat rajesh.bhagat@nxp.com Signed-off-by: yinbo.zhu yinbo.zhu@nxp.com --- arch/arm/cpu/armv7/ls102xa/soc.c | 10 ++++++++++ arch/arm/include/asm/arch-ls102xa/config.h | 1 + arch/arm/include/asm/arch-ls102xa/immap_ls102xa.h | 1 + 3 files changed, 12 insertions(+)
diff --git a/arch/arm/cpu/armv7/ls102xa/soc.c b/arch/arm/cpu/armv7/ls102xa/soc.c index c54daee..2e64708 100644 --- a/arch/arm/cpu/armv7/ls102xa/soc.c +++ b/arch/arm/cpu/armv7/ls102xa/soc.c @@ -70,6 +70,15 @@ static void erratum_a009008(void) #endif /* CONFIG_SYS_FSL_ERRATUM_A009008 */ }
+static void erratum_a009798(void) +{ +#ifdef CONFIG_SYS_FSL_ERRATUM_A009798 + u32 __iomem *scfg = (u32 __iomem *)SCFG_BASE; + u32 val = in_be32(scfg + SCFG_USB3PRM1CR / 4); + out_be32(scfg + SCFG_USB3PRM1CR / 4, val & USB_SQRXTUNE); +#endif /* CONFIG_SYS_FSL_ERRATUM_A009798 */ +} + void s_init(void) { } @@ -158,6 +167,7 @@ int arch_soc_init(void)
/* Erratum */ erratum_a009008(); + erratum_a009798(); return 0; }
diff --git a/arch/arm/include/asm/arch-ls102xa/config.h b/arch/arm/include/asm/arch-ls102xa/config.h index 5b89f16..14d5de1 100644 --- a/arch/arm/include/asm/arch-ls102xa/config.h +++ b/arch/arm/include/asm/arch-ls102xa/config.h @@ -113,6 +113,7 @@ #define CONFIG_SYS_FSL_ERRATUM_A008378 #define CONFIG_SYS_FSL_ERRATUM_A009663 #define CONFIG_SYS_FSL_ERRATUM_A009008 +#define CONFIG_SYS_FSL_ERRATUM_A009798 #define CONFIG_SYS_FSL_ERRATUM_A009942 #define CONFIG_SYS_FSL_MAX_NUM_OF_SEC 1 #else diff --git a/arch/arm/include/asm/arch-ls102xa/immap_ls102xa.h b/arch/arm/include/asm/arch-ls102xa/immap_ls102xa.h index f474cfd..bfc92ee 100644 --- a/arch/arm/include/asm/arch-ls102xa/immap_ls102xa.h +++ b/arch/arm/include/asm/arch-ls102xa/immap_ls102xa.h @@ -175,6 +175,7 @@ struct ccsr_gur { #define SCFG_BASE 0x01570000 #define SCFG_USB3PRM1CR 0x070 #define USB_TXVREFTUNE 0x9 +#define USB_SQRXTUNE 0xFC7FFFFF
USB3 LFPS Peak-Peak Differential Output Voltage Adjustment This patch is adding the erratum for LS1021.
Signed-off-by: Sriram Dash sriram.dash@nxp.com Signed-off-by: Rajesh Bhagat rajesh.bhagat@nxp.com Signed-off-by: yinbo.zhu yinbo.zhu@nxp.com --- arch/arm/cpu/armv7/ls102xa/soc.c | 16 ++++++++++++++++ arch/arm/include/asm/arch-ls102xa/config.h | 1 + arch/arm/include/asm/arch-ls102xa/immap_ls102xa.h | 9 +++++++++ 3 files changed, 26 insertions(+)
diff --git a/arch/arm/cpu/armv7/ls102xa/soc.c b/arch/arm/cpu/armv7/ls102xa/soc.c index 2e64708..19eb361 100644 --- a/arch/arm/cpu/armv7/ls102xa/soc.c +++ b/arch/arm/cpu/armv7/ls102xa/soc.c @@ -79,6 +79,21 @@ static void erratum_a009798(void) #endif /* CONFIG_SYS_FSL_ERRATUM_A009798 */ }
+static void erratum_a008997(void) +{ +#ifdef CONFIG_SYS_FSL_ERRATUM_A008997 + u32 __iomem *usb_phy = (u32 __iomem *)USB_PHY_BASE; + writew(USB_PHY_TX_OVRD_DRV_LO_VAL, + (u8 *)(usb_phy) + USB_PHY_TX_OVRD_DRV_LO); + writew(USB_PHY_MPLL_OVRD_IN_HI_VAL, + (u8 *)(usb_phy) + USB_PHY_MPLL_OVRD_IN_HI); + writew(USB_PHY_LEVEL_OVRD_IN_VAL, + (u8 *)(usb_phy) + USB_PHY_LEVEL_OVRD_IN); + writew(USB_PHY_TX_OVRD_IN_HI_VAL, + (u8 *)(usb_phy) + USB_PHY_TX_OVRD_IN_HI); +#endif /* CONFIG_SYS_FSL_ERRATUM_A008997 */ +} + void s_init(void) { } @@ -168,6 +183,7 @@ int arch_soc_init(void) /* Erratum */ erratum_a009008(); erratum_a009798(); + erratum_a008997(); return 0; }
diff --git a/arch/arm/include/asm/arch-ls102xa/config.h b/arch/arm/include/asm/arch-ls102xa/config.h index 14d5de1..1bec9d0 100644 --- a/arch/arm/include/asm/arch-ls102xa/config.h +++ b/arch/arm/include/asm/arch-ls102xa/config.h @@ -114,6 +114,7 @@ #define CONFIG_SYS_FSL_ERRATUM_A009663 #define CONFIG_SYS_FSL_ERRATUM_A009008 #define CONFIG_SYS_FSL_ERRATUM_A009798 +#define CONFIG_SYS_FSL_ERRATUM_A008997 #define CONFIG_SYS_FSL_ERRATUM_A009942 #define CONFIG_SYS_FSL_MAX_NUM_OF_SEC 1 #else diff --git a/arch/arm/include/asm/arch-ls102xa/immap_ls102xa.h b/arch/arm/include/asm/arch-ls102xa/immap_ls102xa.h index bfc92ee..5f05e0d 100644 --- a/arch/arm/include/asm/arch-ls102xa/immap_ls102xa.h +++ b/arch/arm/include/asm/arch-ls102xa/immap_ls102xa.h @@ -176,6 +176,15 @@ struct ccsr_gur { #define SCFG_USB3PRM1CR 0x070 #define USB_TXVREFTUNE 0x9 #define USB_SQRXTUNE 0xFC7FFFFF +#define USB_PHY_BASE 0x08510000 +#define USB_PHY_TX_OVRD_DRV_LO 0x2004 +#define USB_PHY_MPLL_OVRD_IN_HI 0x0024 +#define USB_PHY_LEVEL_OVRD_IN 0x002a +#define USB_PHY_TX_OVRD_IN_HI 0x2002 +#define USB_PHY_TX_OVRD_DRV_LO_VAL 0x784C +#define USB_PHY_MPLL_OVRD_IN_HI_VAL 0x0080 +#define USB_PHY_LEVEL_OVRD_IN_VAL 0xA9A5 +#define USB_PHY_TX_OVRD_IN_HI_VAL 0x0003
USB3PHY Observing Intermittent Failure in Rx This patch is adding the erratum for LS1021.
Signed-off-by: Sriram Dash sriram.dash@nxp.com Signed-off-by: Rajesh Bhagat rajesh.bhagat@nxp.com Signed-off-by: yinbo.zhu yinbo.zhu@nxp.com --- arch/arm/cpu/armv7/ls102xa/soc.c | 12 ++++++++++++ arch/arm/include/asm/arch-ls102xa/config.h | 1 + arch/arm/include/asm/arch-ls102xa/immap_ls102xa.h | 5 +++++ 3 files changed, 18 insertions(+)
diff --git a/arch/arm/cpu/armv7/ls102xa/soc.c b/arch/arm/cpu/armv7/ls102xa/soc.c index 19eb361..4754907 100644 --- a/arch/arm/cpu/armv7/ls102xa/soc.c +++ b/arch/arm/cpu/armv7/ls102xa/soc.c @@ -94,6 +94,17 @@ static void erratum_a008997(void) #endif /* CONFIG_SYS_FSL_ERRATUM_A008997 */ }
+static void erratum_a009007(void) +{ +#ifdef CONFIG_SYS_FSL_ERRATUM_A009007 + u32 __iomem *usb_phy = (u32 __iomem *)USB_PHY_BASE; + writew(USB_PHY_RX_EQ_VAL_1, (u8 *)(usb_phy) + USB_PHY_RX_OVRD_IN_HI); + writew(USB_PHY_RX_EQ_VAL_2, (u8 *)(usb_phy) + USB_PHY_RX_OVRD_IN_HI); + writew(USB_PHY_RX_EQ_VAL_3, (u8 *)(usb_phy) + USB_PHY_RX_OVRD_IN_HI); + writew(USB_PHY_RX_EQ_VAL_4, (u8 *)(usb_phy) + USB_PHY_RX_OVRD_IN_HI); +#endif /* CONFIG_SYS_FSL_ERRATUM_A009007 */ +} + void s_init(void) { } @@ -184,6 +195,7 @@ int arch_soc_init(void) erratum_a009008(); erratum_a009798(); erratum_a008997(); + erratum_a009007(); return 0; }
diff --git a/arch/arm/include/asm/arch-ls102xa/config.h b/arch/arm/include/asm/arch-ls102xa/config.h index 1bec9d0..20a7baf 100644 --- a/arch/arm/include/asm/arch-ls102xa/config.h +++ b/arch/arm/include/asm/arch-ls102xa/config.h @@ -115,6 +115,7 @@ #define CONFIG_SYS_FSL_ERRATUM_A009008 #define CONFIG_SYS_FSL_ERRATUM_A009798 #define CONFIG_SYS_FSL_ERRATUM_A008997 +#define CONFIG_SYS_FSL_ERRATUM_A009007 #define CONFIG_SYS_FSL_ERRATUM_A009942 #define CONFIG_SYS_FSL_MAX_NUM_OF_SEC 1 #else diff --git a/arch/arm/include/asm/arch-ls102xa/immap_ls102xa.h b/arch/arm/include/asm/arch-ls102xa/immap_ls102xa.h index 5f05e0d..fc406f7 100644 --- a/arch/arm/include/asm/arch-ls102xa/immap_ls102xa.h +++ b/arch/arm/include/asm/arch-ls102xa/immap_ls102xa.h @@ -181,10 +181,15 @@ struct ccsr_gur { #define USB_PHY_MPLL_OVRD_IN_HI 0x0024 #define USB_PHY_LEVEL_OVRD_IN 0x002a #define USB_PHY_TX_OVRD_IN_HI 0x2002 +#define USB_PHY_RX_OVRD_IN_HI 0x200c #define USB_PHY_TX_OVRD_DRV_LO_VAL 0x784C #define USB_PHY_MPLL_OVRD_IN_HI_VAL 0x0080 #define USB_PHY_LEVEL_OVRD_IN_VAL 0xA9A5 #define USB_PHY_TX_OVRD_IN_HI_VAL 0x0003 +#define USB_PHY_RX_EQ_VAL_1 0x0000 +#define USB_PHY_RX_EQ_VAL_2 0x8000 +#define USB_PHY_RX_EQ_VAL_3 0x8004 +#define USB_PHY_RX_EQ_VAL_4 0x800C
USB High Speed Squelch Threshold Adjustment This patch is adding the erratum for LS1043 and LS2080 SoCs.
Signed-off-by: Sriram Dash sriram.dash@nxp.com Signed-off-by: Rajesh Bhagat rajesh.bhagat@nxp.com Signed-off-by: yinbo.zhu yinbo.zhu@nxp.com --- arch/arm/cpu/armv8/fsl-layerscape/soc.c | 22 ++++++++++++++++++++++ arch/arm/include/asm/arch-fsl-layerscape/config.h | 1 + .../include/asm/arch-fsl-layerscape/immap_lsch2.h | 5 +++++ .../include/asm/arch-fsl-layerscape/immap_lsch3.h | 2 ++ 4 files changed, 30 insertions(+)
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/soc.c b/arch/arm/cpu/armv8/fsl-layerscape/soc.c index 1544eaa..27eb8fb 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/soc.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/soc.c @@ -28,6 +28,25 @@
DECLARE_GLOBAL_DATA_PTR;
+static void erratum_a009798(void) +{ +#ifdef CONFIG_SYS_FSL_ERRATUM_A009798 +#if defined(CONFIG_LS1043A) || defined(CONFIG_LS1046A) + u32 __iomem *scfg = (u32 __iomem *)SCFG_BASE; + u32 val = scfg_in32(scfg + SCFG_USB3PRM1CR_USB1 / 4); + scfg_out32(scfg + SCFG_USB3PRM1CR_USB1 / 4 , val & USB_SQRXTUNE); + val = gur_in32(scfg + SCFG_USB3PRM1CR_USB2 / 4); + scfg_out32(scfg + SCFG_USB3PRM1CR_USB2 / 4 , val & USB_SQRXTUNE); + val = scfg_in32(scfg + SCFG_USB3PRM1CR_USB3 / 4); + scfg_out32(scfg + SCFG_USB3PRM1CR_USB3 / 4 , val & USB_SQRXTUNE); +#elif defined(CONFIG_LS2080A) || defined(CONFIG_LS2085A) + u32 __iomem *scfg = (u32 __iomem *)SCFG_BASE; + u32 val = scfg_in32(scfg + SCFG_USB3PRM1CR / 4); + scfg_out32(scfg + SCFG_USB3PRM1CR / 4, val & USB_SQRXTUNE); +#endif +#endif /* CONFIG_SYS_FSL_ERRATUM_A009798 */ +} + bool soc_has_dp_ddr(void) { struct ccsr_gur __iomem *gur = (void *)(CONFIG_SYS_FSL_GUTS_ADDR); @@ -200,6 +219,8 @@ void fsl_lsch3_early_init_f(void) #endif erratum_a008514(); erratum_a008336(); + erratum_a009008(); + erratum_a009798(); #ifdef CONFIG_CHAIN_OF_TRUST /* In case of Secure Boot, the IBR configures the SMMU * to allow only Secure transactions. @@ -471,6 +492,7 @@ void fsl_lsch2_early_init_f(void) erratum_a009929(); erratum_a009660(); erratum_a010539(); + erratum_a009798(); } #endif
diff --git a/arch/arm/include/asm/arch-fsl-layerscape/config.h b/arch/arm/include/asm/arch-fsl-layerscape/config.h index 8f66938..e66253f 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/config.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/config.h @@ -113,6 +113,7 @@ #define EPU_EPGCR 0x700060000ULL
#define CONFIG_SYS_FSL_ERRATUM_A008751 +#define CONFIG_SYS_FSL_ERRATUM_A009798
diff --git a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h index 5210b8c..5763586 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h @@ -198,6 +198,11 @@ struct ccsr_gur { #define FSL_CHASSIS2_DEVDISR2_10GEC1_2 0x00400000 #define FSL_CHASSIS2_DEVDISR2_10GEC1_3 0x80000000 #define FSL_CHASSIS2_DEVDISR2_10GEC1_4 0x40000000 +#define SCFG_USB3PRM1CR_USB2 0x07C +#define SCFG_USB3PRM1CR_USB3 0x088 +#define USB_TXVREFTUNE 0x9 +#define USB_SQRXTUNE 0xFC7FFFFF + u32 devdisr2; /* Device disable control 2 */ u32 devdisr3; /* Device disable control 3 */ u32 devdisr4; /* Device disable control 4 */ diff --git a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h index e181ef2..281f0ee 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h @@ -130,6 +130,8 @@ #define SCFG_BASE 0x01fc0000 #define SCFG_USB3PRM1CR 0x000 #define SCFG_USB3PRM1CR_INIT 0x27672b2a +#define USB_TXVREFTUNE 0x9 +#define USB_SQRXTUNE 0xFC7FFFFF #define SCFG_QSPICLKCTLR 0x10
#define TP_ITYP_AV 0x00000001 /* Initiator available */
USB3 LFPS Peak-Peak Differential Output Voltage Adjustment This patch is adding the erratum for LS1043 and LS2080 SoCs.
Signed-off-by: Sriram Dash sriram.dash@nxp.com Signed-off-by: Rajesh Bhagat rajesh.bhagat@nxp.com Signed-off-by: yinbo.zhu yinbo.zhu@nxp.com --- arch/arm/cpu/armv8/fsl-layerscape/soc.c | 29 ++++++++++++++++++++++ .../include/asm/arch-fsl-layerscape/immap_lsch2.h | 4 +++ .../include/asm/arch-fsl-layerscape/immap_lsch3.h | 2 ++ 3 files changed, 35 insertions(+)
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/soc.c b/arch/arm/cpu/armv8/fsl-layerscape/soc.c index 27eb8fb..c42d778 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/soc.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/soc.c @@ -47,6 +47,33 @@ static void erratum_a009798(void) #endif /* CONFIG_SYS_FSL_ERRATUM_A009798 */ }
+static void erratum_a008997(void) +{ +#ifdef CONFIG_SYS_FSL_ERRATUM_A008997 +#if defined(CONFIG_LS1043A) || defined(CONFIG_LS1046A) + u32 __iomem *scfg = (u32 __iomem *)SCFG_BASE; + u32 val = scfg_in32(scfg + SCFG_USB3PRM2CR_USB1 / 4); + val &= ~(0x7F << 9); + scfg_out32(scfg + SCFG_USB3PRM2CR_USB1 / 4, + val | (USB_PCSTXSWINGFULL << 9)); + val = scfg_in32(scfg + SCFG_USB3PRM2CR_USB2 / 4); + val &= ~(0x7F << 9); + scfg_out32(scfg + SCFG_USB3PRM2CR_USB2 / 4, + val | (USB_PCSTXSWINGFULL << 9)); + val = scfg_in32(scfg + SCFG_USB3PRM2CR_USB3 / 4); + val &= ~(0x7F << 9); + scfg_out32(scfg + SCFG_USB3PRM2CR_USB3 / 4, + val | (USB_PCSTXSWINGFULL << 9)); +#elif defined(CONFIG_LS2080A) || defined(CONFIG_LS2085A) + u32 __iomem *scfg = (u32 __iomem *)SCFG_BASE; + u32 val = scfg_in32(scfg + SCFG_USB3PRM2CR / 4); + val &= ~(0x7F << 9); + scfg_out32(scfg + SCFG_USB3PRM2CR / 4, + val | (USB_PCSTXSWINGFULL << 9)); +#endif +#endif /* CONFIG_SYS_FSL_ERRATUM_A008997 */ +} + bool soc_has_dp_ddr(void) { struct ccsr_gur __iomem *gur = (void *)(CONFIG_SYS_FSL_GUTS_ADDR); @@ -221,6 +248,7 @@ void fsl_lsch3_early_init_f(void) erratum_a008336(); erratum_a009008(); erratum_a009798(); + erratum_a008997(); #ifdef CONFIG_CHAIN_OF_TRUST /* In case of Secure Boot, the IBR configures the SMMU * to allow only Secure transactions. @@ -493,6 +521,7 @@ void fsl_lsch2_early_init_f(void) erratum_a009660(); erratum_a010539(); erratum_a009798(); + erratum_a008997(); } #endif
diff --git a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h index 5763586..554def5 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h @@ -198,8 +198,12 @@ struct ccsr_gur { #define FSL_CHASSIS2_DEVDISR2_10GEC1_2 0x00400000 #define FSL_CHASSIS2_DEVDISR2_10GEC1_3 0x80000000 #define FSL_CHASSIS2_DEVDISR2_10GEC1_4 0x40000000 +#define SCFG_BASE 0x01570000 +#define SCFG_USB3PRM1CR_USB1 0x070 +#define SCFG_USB3PRM2CR_USB1 0x074 #define SCFG_USB3PRM1CR_USB2 0x07C #define SCFG_USB3PRM1CR_USB3 0x088 +#define SCFG_USB3PRM2CR_USB3 0x08c #define USB_TXVREFTUNE 0x9 #define USB_SQRXTUNE 0xFC7FFFFF
diff --git a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h index 281f0ee..b428b18 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h @@ -129,9 +129,11 @@ /* Supplemental Configuration */ #define SCFG_BASE 0x01fc0000 #define SCFG_USB3PRM1CR 0x000 +#define SCFG_USB3PRM2CR 0x004 #define SCFG_USB3PRM1CR_INIT 0x27672b2a #define USB_TXVREFTUNE 0x9 #define USB_SQRXTUNE 0xFC7FFFFF +#define USB_PCSTXSWINGFULL 0x47 #define SCFG_QSPICLKCTLR 0x10
USB3PHY Observing Intermittent Failure in Rx This patch is adding the erratum for LS1043 and LS2080 SoCs.
Signed-off-by: Sriram Dash sriram.dash@nxp.com Signed-off-by: Rajesh Bhagat rajesh.bhagat@nxp.com Signed-off-by: yinbo.zhu yinbo.zhu@nxp.com --- arch/arm/cpu/armv8/fsl-layerscape/soc.c | 43 ++++++++++++++++++++++ arch/arm/include/asm/arch-fsl-layerscape/config.h | 5 +++ .../include/asm/arch-fsl-layerscape/immap_lsch2.h | 12 ++++++ .../include/asm/arch-fsl-layerscape/immap_lsch3.h | 7 ++++ 4 files changed, 67 insertions(+)
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/soc.c b/arch/arm/cpu/armv8/fsl-layerscape/soc.c index c42d778..4e9c718 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/soc.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/soc.c @@ -74,6 +74,47 @@ static void erratum_a008997(void) #endif /* CONFIG_SYS_FSL_ERRATUM_A008997 */ }
+static void erratum_a009007(void) +{ +/* TODO:implement the out_be16 instead of writew which is taking +little endian style */ +#if defined(CONFIG_LS1043A) || defined(CONFIG_LS1046A) + u32 __iomem *usb_phy = (u32 __iomem *)USB_PHY1; + writew(USB_PHY_RX_EQ_VAL_1, (u8 *)(usb_phy) + USB_PHY_RX_OVRD_IN_HI); + writew(USB_PHY_RX_EQ_VAL_2, (u8 *)(usb_phy) + USB_PHY_RX_OVRD_IN_HI); + writew(USB_PHY_RX_EQ_VAL_3, (u8 *)(usb_phy) + USB_PHY_RX_OVRD_IN_HI); + writew(USB_PHY_RX_EQ_VAL_4, (u8 *)(usb_phy) + USB_PHY_RX_OVRD_IN_HI); + usb_phy = (u32 __iomem *)USB_PHY2; + writew(USB_PHY_RX_EQ_VAL_1, (u8 *)(usb_phy) + USB_PHY_RX_OVRD_IN_HI); + writew(USB_PHY_RX_EQ_VAL_2, (u8 *)(usb_phy) + USB_PHY_RX_OVRD_IN_HI); + writew(USB_PHY_RX_EQ_VAL_3, (u8 *)(usb_phy) + USB_PHY_RX_OVRD_IN_HI); + writew(USB_PHY_RX_EQ_VAL_4, (u8 *)(usb_phy) + USB_PHY_RX_OVRD_IN_HI); + usb_phy = (u32 __iomem *)USB_PHY3; + writew(USB_PHY_RX_EQ_VAL_1, (u8 *)(usb_phy) + USB_PHY_RX_OVRD_IN_HI); + writew(USB_PHY_RX_EQ_VAL_2, (u8 *)(usb_phy) + USB_PHY_RX_OVRD_IN_HI); + writew(USB_PHY_RX_EQ_VAL_3, (u8 *)(usb_phy) + USB_PHY_RX_OVRD_IN_HI); + writew(USB_PHY_RX_EQ_VAL_4, (u8 *)(usb_phy) + USB_PHY_RX_OVRD_IN_HI); +#elif defined(CONFIG_LS2080A) || defined(CONFIG_LS2085A) + u32 __iomem *dcsr = (u32 __iomem *)DCSR_BASE; + writew(USB_PHY_RX_EQ_VAL_1, + (u8 *)(dcsr) + DCSR_USB_PHY1 + DCSR_USB_PHY_RX_OVRD_IN_HI); + writew(USB_PHY_RX_EQ_VAL_2, + (u8 *)(dcsr) + DCSR_USB_PHY1 + DCSR_USB_PHY_RX_OVRD_IN_HI); + writew(USB_PHY_RX_EQ_VAL_3, + (u8 *)(dcsr) + DCSR_USB_PHY1 + DCSR_USB_PHY_RX_OVRD_IN_HI); + writew(USB_PHY_RX_EQ_VAL_4, + (u8 *)(dcsr) + DCSR_USB_PHY1 + DCSR_USB_PHY_RX_OVRD_IN_HI); + writew(USB_PHY_RX_EQ_VAL_1, + (u8 *)(dcsr) + DCSR_USB_PHY2 + DCSR_USB_PHY_RX_OVRD_IN_HI); + writew(USB_PHY_RX_EQ_VAL_2, + (u8 *)(dcsr) + DCSR_USB_PHY2 + DCSR_USB_PHY_RX_OVRD_IN_HI); + writew(USB_PHY_RX_EQ_VAL_3, + (u8 *)(dcsr) + DCSR_USB_PHY2 + DCSR_USB_PHY_RX_OVRD_IN_HI); + writew(USB_PHY_RX_EQ_VAL_4, + (u8 *)(dcsr) + DCSR_USB_PHY2 + DCSR_USB_PHY_RX_OVRD_IN_HI); +#endif /* CONFIG_SYS_FSL_ERRATUM_A009007 */ +} + bool soc_has_dp_ddr(void) { struct ccsr_gur __iomem *gur = (void *)(CONFIG_SYS_FSL_GUTS_ADDR); @@ -249,6 +290,7 @@ void fsl_lsch3_early_init_f(void) erratum_a009008(); erratum_a009798(); erratum_a008997(); + erratum_a009007(); #ifdef CONFIG_CHAIN_OF_TRUST /* In case of Secure Boot, the IBR configures the SMMU * to allow only Secure transactions. @@ -522,6 +564,7 @@ void fsl_lsch2_early_init_f(void) erratum_a010539(); erratum_a009798(); erratum_a008997(); + erratum_a009007(); } #endif
diff --git a/arch/arm/include/asm/arch-fsl-layerscape/config.h b/arch/arm/include/asm/arch-fsl-layerscape/config.h index e66253f..7d263fa 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/config.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/config.h @@ -114,6 +114,11 @@
#define CONFIG_SYS_FSL_ERRATUM_A008751 #define CONFIG_SYS_FSL_ERRATUM_A009798 +#define CONFIG_SYS_FSL_ERRATUM_A008997 +#define CONFIG_SYS_FSL_ERRATUM_A009007 +#define CONFIG_SYS_FSL_ERRATUM_A010165 + +
diff --git a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h index 554def5..2634195 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h @@ -206,6 +206,18 @@ struct ccsr_gur { #define SCFG_USB3PRM2CR_USB3 0x08c #define USB_TXVREFTUNE 0x9 #define USB_SQRXTUNE 0xFC7FFFFF +#define USB_PCSTXSWINGFULL 0x47 +#define USB_PHY1 0x084F0000 +#define USB_PHY2 0x08500000 +#define USB_PHY3 0x08510000 +#define USB_PHY_RX_OVRD_IN_HI 0x200c +/* TODO : make it generic */ +#define USB_PHY_RX_EQ_VAL_1 0x0000 +#define USB_PHY_RX_EQ_VAL_2 0x8000 +#define USB_PHY_RX_EQ_VAL_3 0x8003 + +#define USB_PHY_RX_EQ_VAL_4 0x800b +
u32 devdisr2; /* Device disable control 2 */ u32 devdisr3; /* Device disable control 3 */ diff --git a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h index b428b18..a7a9364 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h @@ -120,6 +120,13 @@ #define DCFG_RCWSR15_IFCGRPABASE_QSPI 0x3
#define DCFG_DCSR_BASE 0X700100000ULL +#define DCSR_USB_PHY1 0x4600000 +#define DCSR_USB_PHY2 0x4610000 +#define DCSR_USB_PHY_RX_OVRD_IN_HI 0x1006 +#define USB_PHY_RX_EQ_VAL_1 0x0000 +#define USB_PHY_RX_EQ_VAL_2 0x0080 +#define USB_PHY_RX_EQ_VAL_3 0x0380 +#define USB_PHY_RX_EQ_VAL_4 0x0b80 #define DCFG_DCSR_PORCR1 0x000
/* Interrupt Sampling Control */
Signed-off-by: yinbo.zhu yinbo.zhu@nxp.com --- arch/arm/include/asm/arch-ls102xa/config.h | 7 ------- 1 file changed, 7 deletions(-)
diff --git a/arch/arm/include/asm/arch-ls102xa/config.h b/arch/arm/include/asm/arch-ls102xa/config.h index 20a7baf..2f7233f 100644 --- a/arch/arm/include/asm/arch-ls102xa/config.h +++ b/arch/arm/include/asm/arch-ls102xa/config.h @@ -110,13 +110,6 @@
#ifdef CONFIG_LS102XA #define CONFIG_USB_MAX_CONTROLLER_COUNT 1 -#define CONFIG_SYS_FSL_ERRATUM_A008378 -#define CONFIG_SYS_FSL_ERRATUM_A009663 -#define CONFIG_SYS_FSL_ERRATUM_A009008 -#define CONFIG_SYS_FSL_ERRATUM_A009798 -#define CONFIG_SYS_FSL_ERRATUM_A008997 -#define CONFIG_SYS_FSL_ERRATUM_A009007 -#define CONFIG_SYS_FSL_ERRATUM_A009942 #define CONFIG_SYS_FSL_MAX_NUM_OF_SEC 1 #else #error SoC not defined
This needs to be selected / enabled in defconfigs not config.h, please fix the entire series, thanks!
yinbo.zhu
