[U-Boot] [PATCH] fs/ext4: fix calling put_ext4 with truncated offset
Curently, we are using 32 bit multiplication to calculate the offset, so the result will always be 32 bit. This can silently cause file system corruption when performing a write operation on partition larger than 4 GiB.
This patch address the issue by simply promoting the terms to 64 bit, and let compilers decide how to do the multiplication efficiently.
Signed-off-by: Ma Haijun mahaijuns@gmail.com --- fs/ext4/ext4_common.c | 34 +++++++++++++++++----------------- fs/ext4/ext4_journal.c | 8 ++++---- fs/ext4/ext4_write.c | 14 +++++++------- 3 files changed, 28 insertions(+), 28 deletions(-)
diff --git a/fs/ext4/ext4_common.c b/fs/ext4/ext4_common.c index 352943e..cff50d8 100644 --- a/fs/ext4/ext4_common.c +++ b/fs/ext4/ext4_common.c @@ -445,9 +445,9 @@ restart: goto fail; } put_ext4(((uint64_t) - (g_parent_inode->b. + ((uint64_t)g_parent_inode->b. blocks.dir_blocks[direct_blk_idx] * - fs->blksz)), zero_buffer, fs->blksz); + (uint64_t)fs->blksz)), zero_buffer, fs->blksz); g_parent_inode->size = g_parent_inode->size + fs->blksz; g_parent_inode->blockcnt = @@ -864,8 +864,8 @@ long int ext4fs_get_new_blk_no(void) for (i = 0; i < fs->no_blkgrp; i++) { if (bgd[i].free_blocks) { if (bgd[i].bg_flags & EXT4_BG_BLOCK_UNINIT) { - put_ext4(((uint64_t) (bgd[i].block_id * - fs->blksz)), + put_ext4(((uint64_t) ((uint64_t)bgd[i].block_id * + (uint64_t)fs->blksz)), zero_buffer, fs->blksz); bgd[i].bg_flags = bgd[i]. @@ -929,8 +929,8 @@ restart:
if (bgd[bg_idx].bg_flags & EXT4_BG_BLOCK_UNINIT) { memset(zero_buffer, '\0', fs->blksz); - put_ext4(((uint64_t) (bgd[bg_idx].block_id * - fs->blksz)), zero_buffer, fs->blksz); + put_ext4(((uint64_t) ((uint64_t)bgd[bg_idx].block_id * + (uint64_t)fs->blksz)), zero_buffer, fs->blksz); memcpy(fs->blk_bmaps[bg_idx], zero_buffer, fs->blksz); bgd[bg_idx].bg_flags = bgd[bg_idx].bg_flags & ~EXT4_BG_BLOCK_UNINIT; @@ -996,8 +996,8 @@ int ext4fs_get_new_inode_no(void) bgd[i].free_inodes; if (bgd[i].bg_flags & EXT4_BG_INODE_UNINIT) { put_ext4(((uint64_t) - (bgd[i].inode_id * - fs->blksz)), + ((uint64_t)bgd[i].inode_id * + (uint64_t)fs->blksz)), zero_buffer, fs->blksz); bgd[i].bg_flags = bgd[i].bg_flags & ~EXT4_BG_INODE_UNINIT; @@ -1037,8 +1037,8 @@ restart: ibmap_idx = fs->curr_inode_no / inodes_per_grp; if (bgd[ibmap_idx].bg_flags & EXT4_BG_INODE_UNINIT) { memset(zero_buffer, '\0', fs->blksz); - put_ext4(((uint64_t) (bgd[ibmap_idx].inode_id * - fs->blksz)), zero_buffer, + put_ext4(((uint64_t) ((uint64_t)bgd[ibmap_idx].inode_id * + (uint64_t)fs->blksz)), zero_buffer, fs->blksz); bgd[ibmap_idx].bg_flags = bgd[ibmap_idx].bg_flags & ~EXT4_BG_INODE_UNINIT; @@ -1143,7 +1143,7 @@ static void alloc_single_indirect_block(struct ext2_inode *file_inode, }
/* write the block to disk */ - put_ext4(((uint64_t) (si_blockno * fs->blksz)), + put_ext4(((uint64_t) ((uint64_t)si_blockno * (uint64_t)fs->blksz)), si_start_addr, fs->blksz); file_inode->b.blocks.indir_block = si_blockno; } @@ -1242,7 +1242,7 @@ static void alloc_double_indirect_block(struct ext2_inode *file_inode, break; } /* write the block table */ - put_ext4(((uint64_t) (di_blockno_child * fs->blksz)), + put_ext4(((uint64_t) ((uint64_t)di_blockno_child * (uint64_t)fs->blksz)), di_child_buff_start, fs->blksz); free(di_child_buff_start); di_child_buff_start = NULL; @@ -1250,7 +1250,7 @@ static void alloc_double_indirect_block(struct ext2_inode *file_inode, if (*total_remaining_blocks == 0) break; } - put_ext4(((uint64_t) (di_blockno_parent * fs->blksz)), + put_ext4(((uint64_t) ((uint64_t)di_blockno_parent * (uint64_t)fs->blksz)), di_block_start_addr, fs->blksz); file_inode->b.blocks.double_indir_block = di_blockno_parent; } @@ -1348,8 +1348,8 @@ static void alloc_triple_indirect_block(struct ext2_inode *file_inode, break; } /* write the child block */ - put_ext4(((uint64_t) (ti_child_blockno * - fs->blksz)), + put_ext4(((uint64_t) ((uint64_t)ti_child_blockno * + (uint64_t)fs->blksz)), ti_cbuff_start_addr, fs->blksz); free(ti_cbuff_start_addr);
@@ -1357,7 +1357,7 @@ static void alloc_triple_indirect_block(struct ext2_inode *file_inode, break; } /* write the parent block */ - put_ext4(((uint64_t) (ti_parent_blockno * fs->blksz)), + put_ext4(((uint64_t) ((uint64_t)ti_parent_blockno * (uint64_t)fs->blksz)), ti_pbuff_start_addr, fs->blksz); free(ti_pbuff_start_addr);
@@ -1365,7 +1365,7 @@ static void alloc_triple_indirect_block(struct ext2_inode *file_inode, break; } /* write the grand parent block */ - put_ext4(((uint64_t) (ti_gp_blockno * fs->blksz)), + put_ext4(((uint64_t) ((uint64_t)ti_gp_blockno * (uint64_t)fs->blksz)), ti_gp_buff_start_addr, fs->blksz); file_inode->b.blocks.triple_indir_block = ti_gp_blockno; } diff --git a/fs/ext4/ext4_journal.c b/fs/ext4/ext4_journal.c index d4a46ed..3f61335 100644 --- a/fs/ext4/ext4_journal.c +++ b/fs/ext4/ext4_journal.c @@ -371,7 +371,7 @@ void recover_transaction(int prev_desc_logical_no) blknr = read_allocated_block(&inode_journal, i); ext4fs_devread((lbaint_t)blknr * fs->sect_perblk, 0, fs->blksz, metadata_buff); - put_ext4((uint64_t)(be32_to_cpu(tag->block) * fs->blksz), + put_ext4((uint64_t)((uint64_t)be32_to_cpu(tag->block) * (uint64_t)fs->blksz), metadata_buff, (uint32_t) fs->blksz); } while (!(flags & EXT3_JOURNAL_FLAG_LAST_TAG)); fail: @@ -531,7 +531,7 @@ end:
blknr = read_allocated_block(&inode_journal, EXT2_JOURNAL_SUPERBLOCK); - put_ext4((uint64_t) (blknr * fs->blksz), + put_ext4((uint64_t) ((uint64_t)blknr * (uint64_t)fs->blksz), (struct journal_superblock_t *)temp_buff, (uint32_t) fs->blksz); ext4fs_free_revoke_blks(); @@ -590,7 +590,7 @@ static void update_descriptor_block(long int blknr) tag.flags = cpu_to_be32(EXT3_JOURNAL_FLAG_LAST_TAG); memcpy(temp - sizeof(struct ext3_journal_block_tag), &tag, sizeof(struct ext3_journal_block_tag)); - put_ext4((uint64_t) (blknr * fs->blksz), buf, (uint32_t) fs->blksz); + put_ext4((uint64_t) ((uint64_t)blknr * (uint64_t)fs->blksz), buf, (uint32_t) fs->blksz);
free(temp_buff); free(buf); @@ -625,7 +625,7 @@ static void update_commit_block(long int blknr) return; } memcpy(buf, &jdb, sizeof(struct journal_header_t)); - put_ext4((uint64_t) (blknr * fs->blksz), buf, (uint32_t) fs->blksz); + put_ext4((uint64_t) ((uint64_t)blknr * (uint64_t)fs->blksz), buf, (uint32_t) fs->blksz);
free(temp_buff); free(buf); diff --git a/fs/ext4/ext4_write.c b/fs/ext4/ext4_write.c index 1e1924c..b674b6f 100644 --- a/fs/ext4/ext4_write.c +++ b/fs/ext4/ext4_write.c @@ -40,18 +40,18 @@ static void ext4fs_update(void) /* update block groups */ for (i = 0; i < fs->no_blkgrp; i++) { fs->bgd[i].bg_checksum = ext4fs_checksum_update(i); - put_ext4((uint64_t)(fs->bgd[i].block_id * fs->blksz), + put_ext4((uint64_t)((uint64_t)fs->bgd[i].block_id * (uint64_t)fs->blksz), fs->blk_bmaps[i], fs->blksz); }
/* update inode table groups */ for (i = 0; i < fs->no_blkgrp; i++) { - put_ext4((uint64_t) (fs->bgd[i].inode_id * fs->blksz), + put_ext4((uint64_t) ((uint64_t)fs->bgd[i].inode_id * (uint64_t)fs->blksz), fs->inode_bmaps[i], fs->blksz); }
/* update the block group descriptor table */ - put_ext4((uint64_t)(fs->gdtable_blkno * fs->blksz), + put_ext4((uint64_t)((uint64_t)fs->gdtable_blkno * (uint64_t)fs->blksz), (struct ext2_block_group *)fs->gdtable, (fs->blksz * fs->no_blk_pergdt));
@@ -709,7 +709,7 @@ void ext4fs_deinit(void) temp_buff); jsb = (struct journal_superblock_t *)temp_buff; jsb->s_start = cpu_to_be32(0); - put_ext4((uint64_t) (blknr * fs->blksz), + put_ext4((uint64_t) ((uint64_t)blknr * (uint64_t)fs->blksz), (struct journal_superblock_t *)temp_buff, fs->blksz); free(temp_buff); } @@ -793,7 +793,7 @@ static int ext4fs_write_file(struct ext2_inode *file_inode, delayed_next += blockend >> log2blksz; } else { /* spill */ put_ext4((uint64_t) - (delayed_start << log2blksz), + ((uint64_t)delayed_start << log2blksz), delayed_buf, (uint32_t) delayed_extent); previous_block_number = blknr; @@ -814,7 +814,7 @@ static int ext4fs_write_file(struct ext2_inode *file_inode, } else { if (previous_block_number != -1) { /* spill */ - put_ext4((uint64_t) (delayed_start << + put_ext4((uint64_t) ((uint64_t)delayed_start << log2blksz), delayed_buf, (uint32_t) delayed_extent); @@ -826,7 +826,7 @@ static int ext4fs_write_file(struct ext2_inode *file_inode, } if (previous_block_number != -1) { /* spill */ - put_ext4((uint64_t) (delayed_start << log2blksz), + put_ext4((uint64_t) ((uint64_t)delayed_start << log2blksz), delayed_buf, (uint32_t) delayed_extent); previous_block_number = -1; }
Ma Haijun
