[U-Boot] [PATCH] nand_spl: nand_boot.c: Remove last CONFIG_SYS_NAND_READ_DELAY occurance
Remove the last CONFIG_SYS_NAND_READ_DELAY occurance from nand_boot.c. I missed this one in patch a9c847cb [nand_spl: nand_boot.c: Remove CONFIG_SYS_NAND_READ_DELAY].
This fixes a compile breakage on kilauea_nand for example.
Signed-off-by: Stefan Roese sr@denx.de Cc: Scott Wood scottwood@freescale.com --- nand_spl/nand_boot.c | 7 ++----- 1 files changed, 2 insertions(+), 5 deletions(-)
diff --git a/nand_spl/nand_boot.c b/nand_spl/nand_boot.c index 00df2a0..9545a9a 100644 --- a/nand_spl/nand_boot.c +++ b/nand_spl/nand_boot.c @@ -33,11 +33,8 @@ static int nand_command(struct mtd_info *mtd, int block, int page, int offs, u8 struct nand_chip *this = mtd->priv; int page_addr = page + block * CONFIG_SYS_NAND_PAGE_COUNT;
- if (this->dev_ready) - while (!this->dev_ready(mtd)) - ; - else - CONFIG_SYS_NAND_READ_DELAY; + while (!this->dev_ready(mtd)) + ;
/* Begin command latch cycle */ this->cmd_ctrl(mtd, cmd, NAND_CTRL_CLE | NAND_CTRL_CHANGE);
Applied to u-boot-nand-flash
-Scott
Scott Wood
Stefan Roese
