[U-Boot] [PATCH-V2 3/3] at91: Enabeling USB host on meesc board
There was an redesign, so USB is available now.
Signed-off-by: Daniel Gorsulowski Daniel.Gorsulowski@esd.eu ---
v2: Nothing changed but commit message
Note: This patch depends on 'at91: Update meesc board to new SoC access' patch!
board/esd/meesc/meesc.c | 6 +++++- include/configs/meesc.h | 13 ++++++++++++- 2 files changed, 17 insertions(+), 2 deletions(-)
diff --git a/board/esd/meesc/meesc.c b/board/esd/meesc/meesc.c index b827214..f7c9b62 100644 --- a/board/esd/meesc/meesc.c +++ b/board/esd/meesc/meesc.c @@ -253,7 +253,8 @@ int board_init(void) /* Peripheral Clock Enable Register */ writel( 1 << AT91SAM9263_ID_PIOA | 1 << AT91SAM9263_ID_PIOB | - 1 << AT91SAM9263_ID_PIOCDE, + 1 << AT91SAM9263_ID_PIOCDE | + 1 << AT91SAM9263_ID_UHP, &pmc->pcer);
/* initialize ET1100 Controller */ @@ -275,5 +276,8 @@ int board_init(void) #ifdef CONFIG_AT91_CAN at91_can_hw_init(); #endif +#ifdef CONFIG_USB_OHCI_NEW + at91_uhp_hw_init(); +#endif return 0; } diff --git a/include/configs/meesc.h b/include/configs/meesc.h index 0fb4034..9b9041a 100644 --- a/include/configs/meesc.h +++ b/include/configs/meesc.h @@ -85,11 +85,11 @@ #undef CONFIG_CMD_FPGA #undef CONFIG_CMD_LOADS #undef CONFIG_CMD_IMLS -#undef CONFIG_CMD_USB
#define CONFIG_CMD_PING 1 #define CONFIG_CMD_DHCP 1 #define CONFIG_CMD_NAND 1 +#define CONFIG_CMD_USB 1
/* LED */ #define CONFIG_AT91_LED 1 @@ -133,6 +133,17 @@ #define CONFIG_NET_RETRY_COUNT 20 #undef CONFIG_RESET_PHY_R
+/* USB */ +#define CONFIG_USB_ATMEL +#define CONFIG_USB_OHCI_NEW 1 +#define CONFIG_DOS_PARTITION 1 +#define CONFIG_SYS_USB_OHCI_CPU_INIT 1 +#define CONFIG_SYS_USB_OHCI_REGS_BASE 0x00a00000 +#define CONFIG_SYS_USB_OHCI_SLOT_NAME "at91sam9263" +#define CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS 2 +#define CONFIG_USB_STORAGE 1 +#define CONFIG_CMD_FAT 1 + #define CONFIG_SYS_LOAD_ADDR 0x22000000 /* load address */
#define CONFIG_SYS_MEMTEST_START PHYS_SDRAM
Hi Daniel,
-----Original Message----- From: Daniel Gorsulowski [mailto:Daniel.Gorsulowski@esd.eu] Sent: 2010?7?16? 14:23 To: u-boot@lists.denx.de Cc: Xu, Hong; Daniel Gorsulowski Subject: [PATCH-V2 3/3] at91: Enabeling USB host on meesc board
Acked-By: Hong Xu hong.xu@atmel.com
BR, Eric
Daniel Gorsulowski
Xu, Hong
