[U-Boot] [PATCH] ARM: bcm283x: Fix definition of MBOX_TAG_TEST_PIXEL_ORDER
The MBOX_TAG_TEST_PIXEL_ORDER define is incorrect. According to official documentation it has a slightly different numbering.
Correct mailbox constants are defined in e.g. linux raspberry-firmware https://code.woboq.org/linux/linux/include/soc/bcm2835/raspberrypi-firmware....
These are obtained from the bcm2835 documentation e.g. https://github.com/raspberrypi/firmware/wiki/Mailbox-property-interface#test...
Fix the define to get us back in sync with the spec.
Signed-off-by: Berkus Decker berkus+github@metta.systems [agraf: clarify subject, extend commit message] Signed-off-by: Alexander Graf agraf@suse.de --- arch/arm/mach-bcm283x/include/mach/mbox.h | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/mach-bcm283x/include/mach/mbox.h b/arch/arm/mach-bcm283x/include/mach/mbox.h index 2776a396c7..e3a893e49c 100644 --- a/arch/arm/mach-bcm283x/include/mach/mbox.h +++ b/arch/arm/mach-bcm283x/include/mach/mbox.h @@ -348,7 +348,7 @@ struct bcm2835_mbox_tag_depth { };
#define BCM2835_MBOX_TAG_GET_PIXEL_ORDER 0x00040006 -#define BCM2835_MBOX_TAG_TEST_PIXEL_ORDER 0x00044005 +#define BCM2835_MBOX_TAG_TEST_PIXEL_ORDER 0x00044006 #define BCM2835_MBOX_TAG_SET_PIXEL_ORDER 0x00048006
#define BCM2835_MBOX_PIXEL_ORDER_BGR 0
Alexander Graf
