[PATCH 1/1] i2c: mvtwsi: Add compatible string for allwinner, sun4i-a10-i2c
This adds a compatible string for the Allwinner Sun4i-A10 I2C controller. Without this, boards based on the R8 and A13 (at a minimum) fail to boot.
Signed-off-by: Chris Morgan macromorgan@hotmail.com --- drivers/i2c/mvtwsi.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/drivers/i2c/mvtwsi.c b/drivers/i2c/mvtwsi.c index ff21e3c52b..979b825eec 100644 --- a/drivers/i2c/mvtwsi.c +++ b/drivers/i2c/mvtwsi.c @@ -900,6 +900,7 @@ static const struct dm_i2c_ops mvtwsi_i2c_ops = { static const struct udevice_id mvtwsi_i2c_ids[] = { { .compatible = "marvell,mv64xxx-i2c", }, { .compatible = "marvell,mv78230-i2c", }, + { .compatible = "allwinner,sun4i-a10-i2c", }, { .compatible = "allwinner,sun6i-a31-i2c", }, { /* sentinel */ } };
Acked-by: Akash Gajjar gajjar04akash@gmail.com
2.30.2
On Fri, 7 Jan 2022 11:52:54 -0600 Chris Morgan macroalpha82@gmail.com wrote:
Hi Chris,
Applied to sunxi/master, thanks!
Out of curiosity, can you say what "fail to boot" means, exactly? I see that indeed i2c in U-Boot proper got lost when I2C was moved to DM in the v2022.01 merge window, but that didn't have any visible effect apart from the "i2c" command not working on my BananaPi. Ethernet, USB and Linux boot worked fine, still.
Cheers, Andre
- { .compatible = "allwinner,sun4i-a10-i2c", }, { .compatible = "allwinner,sun6i-a31-i2c", }, { /* sentinel */ }
Hi Chris,
It must have been something in my defconfig. I can confirm using a pristine master branch (without this patch applied) that it does boot correctly, at least via FEL. Sorry for the confusion.
Thank you.
Cheers, Andre
Andre Przywara
Chris Morgan
Chris Morgan
Gajjar Akash
