[U-Boot] [PATCH] spi: Drop atmel_dataflash_spi.c
Dropped drivers/spi/atmel_dataflash_spi.c becuase of - No 'driver model' conversion - Similar driver be there at mtd flash side - Flash drivers shouldn't be part of spi area - No response for prior mail in mailing-list
Signed-off-by: Jagan Teki jagan@openedev.com --- Note: - https://lists.denx.de/pipermail/u-boot/2016-August/265107.html
board/atmel/at91sam9260ek/partition.c | 1 - board/atmel/at91sam9261ek/partition.c | 1 - drivers/spi/Makefile | 1 - drivers/spi/atmel_dataflash_spi.c | 184 ---------------------------------- include/configs/at91sam9260ek.h | 15 --- include/configs/at91sam9261ek.h | 15 --- include/configs/pm9261.h | 1 - scripts/config_whitelist.txt | 4 - 8 files changed, 222 deletions(-) delete mode 100644 drivers/spi/atmel_dataflash_spi.c
diff --git a/board/atmel/at91sam9260ek/partition.c b/board/atmel/at91sam9260ek/partition.c index e41eefe..8617f48 100644 --- a/board/atmel/at91sam9260ek/partition.c +++ b/board/atmel/at91sam9260ek/partition.c @@ -13,7 +13,6 @@ AT91S_DATAFLASH_INFO dataflash_info[CONFIG_SYS_MAX_DATAFLASH_BANKS];
struct dataflash_addr cs[CONFIG_SYS_MAX_DATAFLASH_BANKS] = { {CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS0, 0}, /* Logical adress, CS */ - {CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS1, 1} };
/*define the area offsets*/ diff --git a/board/atmel/at91sam9261ek/partition.c b/board/atmel/at91sam9261ek/partition.c index ed97609..8617f48 100644 --- a/board/atmel/at91sam9261ek/partition.c +++ b/board/atmel/at91sam9261ek/partition.c @@ -13,7 +13,6 @@ AT91S_DATAFLASH_INFO dataflash_info[CONFIG_SYS_MAX_DATAFLASH_BANKS];
struct dataflash_addr cs[CONFIG_SYS_MAX_DATAFLASH_BANKS] = { {CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS0, 0}, /* Logical adress, CS */ - {CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS3, 3} };
/*define the area offsets*/ diff --git a/drivers/spi/Makefile b/drivers/spi/Makefile index c090562..ef48ee9 100644 --- a/drivers/spi/Makefile +++ b/drivers/spi/Makefile @@ -17,7 +17,6 @@ endif
obj-$(CONFIG_ALTERA_SPI) += altera_spi.o obj-$(CONFIG_ATH79_SPI) += ath79_spi.o -obj-$(CONFIG_ATMEL_DATAFLASH_SPI) += atmel_dataflash_spi.o obj-$(CONFIG_ATMEL_SPI) += atmel_spi.o obj-$(CONFIG_CADENCE_QSPI) += cadence_qspi.o cadence_qspi_apb.o obj-$(CONFIG_CF_SPI) += cf_spi.o diff --git a/drivers/spi/atmel_dataflash_spi.c b/drivers/spi/atmel_dataflash_spi.c deleted file mode 100644 index a2e9c00..0000000 --- a/drivers/spi/atmel_dataflash_spi.c +++ /dev/null @@ -1,184 +0,0 @@ -/* - * Driver for ATMEL DataFlash support - * Author : Hamid Ikdoumi (Atmel) - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -/* - * This driver desperately needs rework: - * - * - use structure SoC access - * - get rid of including asm/arch/at91_spi.h - * - remove asm/arch/at91_spi.h - * - get rid of all CONFIG_ATMEL_LEGACY defines and uses - * - * 02-Aug-2010 Reinhard Meyer uboot@emk-elektronik.de - */ - -#include <common.h> -#ifndef CONFIG_ATMEL_LEGACY -# define CONFIG_ATMEL_LEGACY -#endif -#include <spi.h> -#include <malloc.h> - -#include <asm/io.h> - -#include <asm/arch/clk.h> -#include <asm/arch/hardware.h> - -#include "atmel_spi.h" - -#include <asm/arch/gpio.h> -#include <asm/arch/at91_pio.h> -#include <asm/arch/at91_spi.h> - -#include <dataflash.h> - -#define AT91_SPI_PCS0_DATAFLASH_CARD 0xE /* Chip Select 0: NPCS0%1110 */ -#define AT91_SPI_PCS1_DATAFLASH_CARD 0xD /* Chip Select 1: NPCS1%1101 */ -#define AT91_SPI_PCS2_DATAFLASH_CARD 0xB /* Chip Select 2: NPCS2%1011 */ -#define AT91_SPI_PCS3_DATAFLASH_CARD 0x7 /* Chip Select 3: NPCS3%0111 */ - -void AT91F_SpiInit(void) -{ - /* Reset the SPI */ - writel(AT91_SPI_SWRST, ATMEL_BASE_SPI0 + AT91_SPI_CR); - - /* Configure SPI in Master Mode with No CS selected !!! */ - writel(AT91_SPI_MSTR | AT91_SPI_MODFDIS | AT91_SPI_PCS, - ATMEL_BASE_SPI0 + AT91_SPI_MR); - - /* Configure CS0 */ - writel(AT91_SPI_NCPHA | - (AT91_SPI_DLYBS & DATAFLASH_TCSS) | - (AT91_SPI_DLYBCT & DATAFLASH_TCHS) | - ((get_mck_clk_rate() / AT91_SPI_CLK) << 8), - ATMEL_BASE_SPI0 + AT91_SPI_CSR(0)); - -#ifdef CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS1 - /* Configure CS1 */ - writel(AT91_SPI_NCPHA | - (AT91_SPI_DLYBS & DATAFLASH_TCSS) | - (AT91_SPI_DLYBCT & DATAFLASH_TCHS) | - ((get_mck_clk_rate() / AT91_SPI_CLK) << 8), - ATMEL_BASE_SPI0 + AT91_SPI_CSR(1)); -#endif -#ifdef CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS2 - /* Configure CS2 */ - writel(AT91_SPI_NCPHA | - (AT91_SPI_DLYBS & DATAFLASH_TCSS) | - (AT91_SPI_DLYBCT & DATAFLASH_TCHS) | - ((get_mck_clk_rate() / AT91_SPI_CLK) << 8), - ATMEL_BASE_SPI0 + AT91_SPI_CSR(2)); -#endif -#ifdef CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS3 - /* Configure CS3 */ - writel(AT91_SPI_NCPHA | - (AT91_SPI_DLYBS & DATAFLASH_TCSS) | - (AT91_SPI_DLYBCT & DATAFLASH_TCHS) | - ((get_mck_clk_rate() / AT91_SPI_CLK) << 8), - ATMEL_BASE_SPI0 + AT91_SPI_CSR(3)); -#endif - - /* SPI_Enable */ - writel(AT91_SPI_SPIEN, ATMEL_BASE_SPI0 + AT91_SPI_CR); - - while (!(readl(ATMEL_BASE_SPI0 + AT91_SPI_SR) & AT91_SPI_SPIENS)) - ; - - /* - * Add tempo to get SPI in a safe state. - * Should not be needed for new silicon (Rev B) - */ - udelay(500000); - readl(ATMEL_BASE_SPI0 + AT91_SPI_SR); - readl(ATMEL_BASE_SPI0 + AT91_SPI_RDR); - -} - -void AT91F_SpiEnable(int cs) -{ - unsigned long mode; - - mode = readl(ATMEL_BASE_SPI0 + AT91_SPI_MR); - mode &= ~AT91_SPI_PCS; - - switch (cs) { - case 0: - mode |= AT91_SPI_PCS0_DATAFLASH_CARD << 16; - break; - case 1: - mode |= AT91_SPI_PCS1_DATAFLASH_CARD << 16; - break; - case 2: - mode |= AT91_SPI_PCS2_DATAFLASH_CARD << 16; - break; - case 3: - mode |= AT91_SPI_PCS3_DATAFLASH_CARD << 16; - break; - } - - writel(mode, ATMEL_BASE_SPI0 + AT91_SPI_MR); - - /* SPI_Enable */ - writel(AT91_SPI_SPIEN, ATMEL_BASE_SPI0 + AT91_SPI_CR); -} - -unsigned int AT91F_SpiWrite1(AT91PS_DataflashDesc pDesc); - -unsigned int AT91F_SpiWrite(AT91PS_DataflashDesc pDesc) -{ - unsigned int timeout; - unsigned int timebase; - - pDesc->state = BUSY; - - writel(AT91_SPI_TXTDIS + AT91_SPI_RXTDIS, - ATMEL_BASE_SPI0 + AT91_SPI_PTCR); - - /* Initialize the Transmit and Receive Pointer */ - writel((unsigned int)pDesc->rx_cmd_pt, - ATMEL_BASE_SPI0 + AT91_SPI_RPR); - writel((unsigned int)pDesc->tx_cmd_pt, - ATMEL_BASE_SPI0 + AT91_SPI_TPR); - - /* Intialize the Transmit and Receive Counters */ - writel(pDesc->rx_cmd_size, ATMEL_BASE_SPI0 + AT91_SPI_RCR); - writel(pDesc->tx_cmd_size, ATMEL_BASE_SPI0 + AT91_SPI_TCR); - - if (pDesc->tx_data_size != 0) { - /* Initialize the Next Transmit and Next Receive Pointer */ - writel((unsigned int)pDesc->rx_data_pt, - ATMEL_BASE_SPI0 + AT91_SPI_RNPR); - writel((unsigned int)pDesc->tx_data_pt, - ATMEL_BASE_SPI0 + AT91_SPI_TNPR); - - /* Intialize the Next Transmit and Next Receive Counters */ - writel(pDesc->rx_data_size, - ATMEL_BASE_SPI0 + AT91_SPI_RNCR); - writel(pDesc->tx_data_size, - ATMEL_BASE_SPI0 + AT91_SPI_TNCR); - } - - /* arm simple, non interrupt dependent timer */ - timebase = get_timer(0); - timeout = 0; - - writel(AT91_SPI_TXTEN + AT91_SPI_RXTEN, - ATMEL_BASE_SPI0 + AT91_SPI_PTCR); - while (!(readl(ATMEL_BASE_SPI0 + AT91_SPI_SR) & AT91_SPI_RXBUFF) && - ((timeout = get_timer(timebase)) < CONFIG_SYS_SPI_WRITE_TOUT)) - ; - writel(AT91_SPI_TXTDIS + AT91_SPI_RXTDIS, - ATMEL_BASE_SPI0 + AT91_SPI_PTCR); - pDesc->state = IDLE; - - if (timeout >= CONFIG_SYS_SPI_WRITE_TOUT) { - printf("Error Timeout\n\r"); - return DATAFLASH_ERROR; - } - - return DATAFLASH_OK; -} diff --git a/include/configs/at91sam9260ek.h b/include/configs/at91sam9260ek.h index 48d7f6a..4bd025c 100644 --- a/include/configs/at91sam9260ek.h +++ b/include/configs/at91sam9260ek.h @@ -104,7 +104,6 @@ #define CONFIG_HAS_DATAFLASH 1 #define CONFIG_SYS_MAX_DATAFLASH_BANKS 2 #define CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS0 0xC0000000 /* CS0 */ -#define CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS1 0xD0000000 /* CS1 */ #define AT91_SPI_CLK 15000000 #else /* Enable MMC. The MCCK is conflicted with DataFlash */ @@ -157,20 +156,6 @@ "mtdparts=atmel_nand:-(root) " \ "rw rootfstype=jffs2"
-#elif CONFIG_SYS_USE_DATAFLASH_CS1 - -/* bootstrap + u-boot + env + linux in dataflash on CS1 */ -#define CONFIG_ENV_IS_IN_DATAFLASH 1 -#define CONFIG_SYS_MONITOR_BASE (CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS1 + 0x8400) -#define CONFIG_ENV_OFFSET 0x4200 -#define CONFIG_ENV_ADDR (CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS1 + CONFIG_ENV_OFFSET) -#define CONFIG_ENV_SIZE 0x4200 -#define CONFIG_BOOTCOMMAND "cp.b 0xD0084000 0x22000000 0x210000; bootm" -#define CONFIG_BOOTARGS "console=ttyS0,115200 " \ - "root=/dev/mtdblock0 " \ - "mtdparts=atmel_nand:-(root) " \ - "rw rootfstype=jffs2" - #elif defined(CONFIG_SYS_USE_NANDFLASH)
/* bootstrap + u-boot + env + linux in nandflash */ diff --git a/include/configs/at91sam9261ek.h b/include/configs/at91sam9261ek.h index 505f945..3715ba2 100644 --- a/include/configs/at91sam9261ek.h +++ b/include/configs/at91sam9261ek.h @@ -88,7 +88,6 @@ #define CONFIG_HAS_DATAFLASH #define CONFIG_SYS_MAX_DATAFLASH_BANKS 2 #define CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS0 0xC0000000 /* CS0 */ -#define CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS3 0xD0000000 /* CS3 */ #define AT91_SPI_CLK 15000000 #define DATAFLASH_TCSS (0x1a << 16) #define DATAFLASH_TCHS (0x1 << 24) @@ -150,20 +149,6 @@ "mtdparts=atmel_nand:-(root) " \ "rw rootfstype=jffs2"
-#elif CONFIG_SYS_USE_DATAFLASH_CS3 - -/* bootstrap + u-boot + env + linux in dataflash on CS3 */ -#define CONFIG_ENV_IS_IN_DATAFLASH -#define CONFIG_SYS_MONITOR_BASE (CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS3 + 0x8400) -#define CONFIG_ENV_OFFSET 0x4200 -#define CONFIG_ENV_ADDR (CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS3 + CONFIG_ENV_OFFSET) -#define CONFIG_ENV_SIZE 0x4200 -#define CONFIG_BOOTCOMMAND "cp.b 0xD0084000 0x22000000 0x210000; bootm" -#define CONFIG_BOOTARGS "console=ttyS0,115200 " \ - "root=/dev/mtdblock0 " \ - "mtdparts=atmel_nand:-(root) " \ - "rw rootfstype=jffs2" - #else /* CONFIG_SYS_USE_NANDFLASH */
/* bootstrap + u-boot + env + linux in nandflash */ diff --git a/include/configs/pm9261.h b/include/configs/pm9261.h index b22a3b6..1b997b3 100644 --- a/include/configs/pm9261.h +++ b/include/configs/pm9261.h @@ -185,7 +185,6 @@ #define CONFIG_HAS_DATAFLASH #define CONFIG_SYS_MAX_DATAFLASH_BANKS 1 #define CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS0 0xC0000000 /* CS0 */ -#define CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS3 0xD0000000 /* CS3 */ #define AT91_SPI_CLK 15000000 #define DATAFLASH_TCSS (0x1a << 16) #define DATAFLASH_TCHS (0x1 << 24) diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index fa9c3fc..e462496 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -192,7 +192,6 @@ CONFIG_ATA_ACPI CONFIG_ATI CONFIG_ATI_RADEON_FB CONFIG_ATM -CONFIG_ATMEL_DATAFLASH_SPI CONFIG_ATMEL_LCD CONFIG_ATMEL_LCD_BGR555 CONFIG_ATMEL_LCD_RGB565 @@ -3189,9 +3188,6 @@ CONFIG_SYS_DA850_PLL1_PLLM CONFIG_SYS_DA850_PLL1_POSTDIV CONFIG_SYS_DA850_SYSCFG_SUSPSRC CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS0 -CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS1 -CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS2 -CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS3 CONFIG_SYS_DAVINCI_EMAC_PHY_COUNT CONFIG_SYS_DAVINCI_I2C_SLAVE CONFIG_SYS_DAVINCI_I2C_SLAVE1
On Tue, May 23, 2017 at 03:14:36PM +0530, Jagannadha Sutradharudu Teki wrote:
Note:
The problem here is that you need to remove the boards in question as well. I see the baord maintainer was Cc'd on this email, so this is a bit stronger of a poke, as I guess we need to drop these boards.. Thanks!
Hi everybody,
It looks like I'm still listed as the maintainer, although I haven't been involved in u-boot development for years...
I no longer have access to any AT91 board, so if someone wants to take over, it's ok to me. Otherwise, you can mark those boards as orphaned, or remove them from the tree.
Thanks,
Stelian.
On Mon, Jun 05, 2017 at 09:32:28PM +0200, Stelian Pop wrote:
Hi everybody,
Thanks Stelian. Wenyou, you've done some changes to some of these boards recently, would you care to pick them up, or should I go ahead and remove them? Thanks!
Hi Tom,
Hi everybody,
Please don't remove these boards.
We agree to drop atmel_dataflash_spi.c, and I will convert these boards by using the new dataflash driver.
Thank you.
Best Regards, Wenyou Yang
On Tue, Jun 06, 2017 at 09:07:51AM +0000, Wenyou.Yang@microchip.com wrote:
Hi Tom,
Hi everybody,
Please do the conversion and then we can drop the old file (otherwise the build fails), and please send a patch updating the MAINTAINERS file soon, thanks!
Hi Tom,
Hi everybody,
All right, thanks.
participants (5)
Jagan Teki
Stelian Pop
Yang, Wenyou
