Re: [PATCH 5/6] pogo_v4: Disable LTO
Resend to include the mailing list!
Tony
On Tue, Nov 22, 2022 at 11:58 AM Tony Dinh mibodhi@gmail.com wrote:
Hi Tom,
On Tue, Nov 22, 2022 at 9:32 AM Tom Rini trini@konsulko.com wrote:
With gcc-12.2 we now get: lib/zlib/inflate.c:360: undefined reference to `__gnu_thumb1_case_si' when building this platform. This seems like some odd problem with LTO and Thumb, but since the platform continues to link, I assume it's within size constraints, so lets just disable LTO for now.
We don't have a hard size constraint for this board. Thumb and LTO were to help keep the image 512K or less (by convention, for some downstream scripts).
Thanks, Acked-by: Tony Dinh mibodhi@gmail.com
Cc: Tony Dinh mibodhi@gmail.com Signed-off-by: Tom Rini trini@konsulko.com
configs/pogo_v4_defconfig | 1 - 1 file changed, 1 deletion(-)
diff --git a/configs/pogo_v4_defconfig b/configs/pogo_v4_defconfig index 3b08cb7b1d14..c4b7f7c31471 100644 --- a/configs/pogo_v4_defconfig +++ b/configs/pogo_v4_defconfig @@ -17,7 +17,6 @@ CONFIG_DEFAULT_DEVICE_TREE="kirkwood-pogoplug-series-4" CONFIG_SYS_PROMPT="Pogo_V4> " CONFIG_IDENT_STRING="\nPogoplug V4" CONFIG_SYS_LOAD_ADDR=0x800000 -CONFIG_LTO=y CONFIG_DISTRO_DEFAULTS=y CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0xc8012000 -- 2.25.1
Tony
Hi Tom,
Ah, well, uh-oh. Then we needed to add: CONFIG_HAS_BOARD_SIZE_LIMIT=y CONFIG_BOARD_SIZE_LIMIT=524288 to the config. Which is fine now, but without both LTO and thumb, we now are too big. So this means digging harder at that error message. Which in turn shows that 806f86bd826e ("arm: lib: Import Thumb1 functions") is where we imported the __gnu_thumb1_case_* functions we have now, and need to do similar work to import (and then do the follow-up improvements to) __gnu_thumb1_case_si. Can you please take a look at that? FWIW, the gcc-12.2.0 toolchain I'm using is just https://mirrors.edge.kernel.org/pub/tools/crosstool/files/bin/x86_64/12.2.0/...
Hi Tom,
Tony
Hi Tom,
I think I was not clear in my previous response. We did not implement a hard size constraint, but only tried to keep it small at 512K. If it grows larger, it's OK. Others and I just need to modify the flashing script, which is not a big deal. So removing LTO and Thumb is fine to get through this gcc build problem. Nothing will break because it is still small enough at 670K (built using gcc 11).
I'm not well versed in troubleshooting this type of compiler problem. I could try, but I think someone like Simon would be able to solve it quicker. Please let me know what you think.
All the best, Tony
-- Tom
Tony Dinh
