[U-Boot] [PATCH v2 0/4] arm: atmel: add at91sam9n12ek board support
This patch series will add at91sam9n12ek board support. In the board, spi/nand flash, mmc, lcd are supported.
TODO: - ethernet support - usb support.
Changes since v1: - split into more patches to make it clearer. - include an extra patch that use run-time detect for spi ip. - include an extra patch to remove the chip select for clock part. - merge at91sam9n12 register definition with at91sam9x5. - fix copyright issue and add maintainer. - disable pull-up as possible as we can. - add mtdparts command. - fix warnings and typos.
Bo Shen (1): spi: atmel_spi: using ip version to check whether has wdrbt
Josh Wu (3): arm: at91: add at91sam9n12 register definition arm: at91: add at91sam9n12ek board support at91: clock: remove chip macro for plla div2.
MAINTAINERS | 3 + arch/arm/cpu/arm926ejs/at91/Makefile | 1 + arch/arm/cpu/arm926ejs/at91/at91sam9n12_devices.c | 180 +++++++++++++++ arch/arm/cpu/arm926ejs/at91/clock.c | 13 +- arch/arm/include/asm/arch-at91/at91sam9_matrix.h | 2 +- arch/arm/include/asm/arch-at91/at91sam9x5.h | 19 +- arch/arm/include/asm/arch-at91/at91sam9x5_matrix.h | 17 +- arch/arm/include/asm/arch-at91/hardware.h | 2 +- board/atmel/at91sam9n12ek/Makefile | 52 +++++ board/atmel/at91sam9n12ek/at91sam9n12ek.c | 228 +++++++++++++++++++ boards.cfg | 3 + drivers/spi/atmel_spi.c | 15 +- drivers/spi/atmel_spi.h | 2 +- include/configs/at91sam9n12ek.h | 232 ++++++++++++++++++++ 14 files changed, 751 insertions(+), 18 deletions(-) create mode 100644 arch/arm/cpu/arm926ejs/at91/at91sam9n12_devices.c create mode 100644 board/atmel/at91sam9n12ek/Makefile create mode 100644 board/atmel/at91sam9n12ek/at91sam9n12ek.c create mode 100644 include/configs/at91sam9n12ek.h
Using IP version to check whether it has wdrbt bit in mode register
Tested in at91sam9x5ek and at91sam9n12ek.
Signed-off-by: Bo Shen voice.shen@atmel.com [fix warning about incompatible parameter] Signed-off-by: Josh Wu josh.wu@atmel.com --- drivers/spi/atmel_spi.c | 15 ++++++++++++--- drivers/spi/atmel_spi.h | 2 +- 2 files changed, 13 insertions(+), 4 deletions(-)
diff --git a/drivers/spi/atmel_spi.c b/drivers/spi/atmel_spi.c index ce7d460..9cd7834 100644 --- a/drivers/spi/atmel_spi.c +++ b/drivers/spi/atmel_spi.c @@ -30,6 +30,15 @@
#include "atmel_spi.h"
+static int spi_has_wdrbt(struct atmel_spi_slave *slave) +{ + unsigned int ver; + + ver = spi_readl(slave, VERSION); + + return (ATMEL_SPI_VERSION_REV(ver) >= 0x210); +} + void spi_init() {
@@ -92,10 +101,10 @@ struct spi_slave *spi_setup_slave(unsigned int bus, unsigned int cs, as->slave.cs = cs; as->regs = regs; as->mr = ATMEL_SPI_MR_MSTR | ATMEL_SPI_MR_MODFDIS -#if defined(CONFIG_AT91SAM9X5) || defined(CONFIG_AT91SAM9M10G45) - | ATMEL_SPI_MR_WDRBT -#endif | ATMEL_SPI_MR_PCS(~(1 << cs) & 0xf); + if (spi_has_wdrbt(as)) + as->mr |= ATMEL_SPI_MR_WDRBT; + spi_writel(as, CSR(cs), csrx);
return &as->slave; diff --git a/drivers/spi/atmel_spi.h b/drivers/spi/atmel_spi.h index 057de9a..d240945 100644 --- a/drivers/spi/atmel_spi.h +++ b/drivers/spi/atmel_spi.h @@ -64,7 +64,7 @@ #define ATMEL_SPI_CSRx_DLYBCT(x) ((x) << 24)
/* Bits in VERSION */ -#define ATMEL_SPI_VERSION_REV(x) ((x) << 0) +#define ATMEL_SPI_VERSION_REV(x) ((x) & 0xfff) #define ATMEL_SPI_VERSION_MFN(x) ((x) << 16)
/* Constants for CSRx:BITS */
Since at91sam9n12 is a subset of at91sam9x5, so put all at91sam9n12 definitions in at91sam9x5 head file.
Signed-off-by: Josh Wu josh.wu@atmel.com --- arch/arm/include/asm/arch-at91/at91sam9_matrix.h | 2 +- arch/arm/include/asm/arch-at91/at91sam9x5.h | 19 ++++++++++++++++--- arch/arm/include/asm/arch-at91/at91sam9x5_matrix.h | 17 ++++++++++++++--- arch/arm/include/asm/arch-at91/hardware.h | 2 +- 4 files changed, 32 insertions(+), 8 deletions(-)
diff --git a/arch/arm/include/asm/arch-at91/at91sam9_matrix.h b/arch/arm/include/asm/arch-at91/at91sam9_matrix.h index b9a93b0..6e0bebd 100644 --- a/arch/arm/include/asm/arch-at91/at91sam9_matrix.h +++ b/arch/arm/include/asm/arch-at91/at91sam9_matrix.h @@ -23,7 +23,7 @@ #include <asm/arch/at91cap9_matrix.h> #elif defined(CONFIG_AT91SAM9G45) || defined(CONFIG_AT91SAM9M10G45) #include <asm/arch/at91sam9g45_matrix.h> -#elif defined(CONFIG_AT91SAM9X5) +#elif defined(CONFIG_AT91SAM9N12) || defined(CONFIG_AT91SAM9X5) #include <asm/arch/at91sam9x5_matrix.h> #else #error "Unsupported AT91SAM9/CAP9 processor" diff --git a/arch/arm/include/asm/arch-at91/at91sam9x5.h b/arch/arm/include/asm/arch-at91/at91sam9x5.h index b7d1932..85e42f5 100644 --- a/arch/arm/include/asm/arch-at91/at91sam9x5.h +++ b/arch/arm/include/asm/arch-at91/at91sam9x5.h @@ -1,10 +1,10 @@ /* * Chip-specific header file for the AT91SAM9x5 family * - * Copyright (C) 2012 Atmel Corporation. + * Copyright (C) 2012-2013 Atmel Corporation. * * Definitions for the SoC: - * AT91SAM9x5 + * AT91SAM9x5 & AT91SAM9N12 * * This program is free software; you can redistribute it and/or modify * it under the terms of the GNU General Public License as published by @@ -22,10 +22,12 @@ #define ATMEL_ID_SYS 1 /* System Controller Interrupt */ #define ATMEL_ID_PIOAB 2 /* Parallel I/O Controller A and B */ #define ATMEL_ID_PIOCD 3 /* Parallel I/O Controller C and D */ -#define ATMEL_ID_SMD 4 /* SMD Soft Modem (SMD) */ +#define ATMEL_ID_SMD 4 /* SMD Soft Modem (SMD), only for AT91SAM9X5 */ +#define ATMEL_ID_FUSE 4 /* FUSE Controller, only for AT91SAM9N12 */ #define ATMEL_ID_USART0 5 /* USART 0 */ #define ATMEL_ID_USART1 6 /* USART 1 */ #define ATMEL_ID_USART2 7 /* USART 2 */ +#define ATMEL_ID_USART3 8 /* USART 3 */ #define ATMEL_ID_TWI0 9 /* Two-Wire Interface 0 */ #define ATMEL_ID_TWI1 10 /* Two-Wire Interface 1 */ #define ATMEL_ID_TWI2 11 /* Two-Wire Interface 2 */ @@ -46,6 +48,7 @@ #define ATMEL_ID_HSMCI1 26 /* High Speed Multimedia Card Interface 1 */ #define ATMEL_ID_EMAC1 27 /* Ethernet MAC1 */ #define ATMEL_ID_SSC 28 /* Synchronous Serial Controller */ +#define ATMEL_ID_TRNG 30 /* True Random Number Generator */ #define ATMEL_ID_IRQ 31 /* Advanced Interrupt Controller */
/* @@ -85,6 +88,7 @@ /* * System Peripherals */ +#define ATMEL_BASE_FUSE 0xffffdc00 #define ATMEL_BASE_MATRIX 0xffffde00 #define ATMEL_BASE_PMECC 0xffffe000 #define ATMEL_BASE_PMERRLOC 0xffffe600 @@ -111,10 +115,15 @@ */ #define ATMEL_BASE_ROM 0x00100000 /* Internal ROM base address */ #define ATMEL_BASE_SRAM 0x00300000 /* Internal SRAM base address */ + +#ifdef CONFIG_AT91SAM9N12 +#define ATMEL_BASE_OHCI 0x00500000 /* USB Host controller */ +#else /* AT91SAM9X5 */ #define ATMEL_BASE_SMD 0x00400000 /* SMD Controller */ #define ATMEL_BASE_UDPHS_FIFO 0x00500000 /* USB Device HS controller */ #define ATMEL_BASE_OHCI 0x00600000 /* USB Host controller (OHCI) */ #define ATMEL_BASE_EHCI 0x00700000 /* USB Host controller (EHCI) */ +#endif
/* 9x5 series chip id definitions */ #define ARCH_ID_AT91SAM9X5 0x819a05a0 @@ -140,7 +149,11 @@ /* * Cpu Name */ +#ifdef CONFIG_AT91SAM9N12 +#define ATMEL_CPU_NAME "AT91SAM9N12" +#else /* AT91SAM9X5 */ #define ATMEL_CPU_NAME get_cpu_name() +#endif
/* * Other misc defines diff --git a/arch/arm/include/asm/arch-at91/at91sam9x5_matrix.h b/arch/arm/include/asm/arch-at91/at91sam9x5_matrix.h index d6ce6fa..0d33069 100644 --- a/arch/arm/include/asm/arch-at91/at91sam9x5_matrix.h +++ b/arch/arm/include/asm/arch-at91/at91sam9x5_matrix.h @@ -1,10 +1,10 @@ /* * Matrix-centric header file for the AT91SAM9X5 family * - * Copyright (C) 2012 Atmel Corporation. + * Copyright (C) 2012-2013 Atmel Corporation. * * Memory Controllers (MATRIX, EBI) - System peripherals registers. - * Based on AT91SAM9X5 preliminary datasheet. + * Based on AT91SAM9X5 & AT91SAM9N12 preliminary datasheet. * * This program is free software; you can redistribute it and/or modify * it under the terms of the GNU General Public License as published by @@ -17,14 +17,25 @@
#ifndef __ASSEMBLY__
+/* AT91SAM9N12 Matrix definition is a subset of AT91SAM9X5. */ struct at91_matrix { u32 mcfg[16]; u32 scfg[16]; u32 pras[16][2]; u32 mrcr; /* 0x100 Master Remap Control */ - u32 filler[7]; + u32 filler[5]; +#ifdef CONFIG_AT91SAM9X5 + u32 filler1[2]; +#endif + /* EBI Chip Select Assignment Register + * 0x118: AT91SAM9N12 + * 0x120: AT91SAM9X5 + */ u32 ebicsa; u32 filler4[47]; +#ifdef CONFIG_AT91SAM9N12 + u32 filler5[2]; +#endif u32 wpmr; u32 wpsr; }; diff --git a/arch/arm/include/asm/arch-at91/hardware.h b/arch/arm/include/asm/arch-at91/hardware.h index 4c4ee70..8812b11 100644 --- a/arch/arm/include/asm/arch-at91/hardware.h +++ b/arch/arm/include/asm/arch-at91/hardware.h @@ -37,7 +37,7 @@ # include <asm/arch/at91sam9rl.h> #elif defined(CONFIG_AT91SAM9G45) || defined(CONFIG_AT91SAM9M10G45) # include <asm/arch/at91sam9g45.h> -#elif defined(CONFIG_AT91SAM9X5) +#elif defined(CONFIG_AT91SAM9N12) || defined(CONFIG_AT91SAM9X5) # include <asm/arch/at91sam9x5.h> #elif defined(CONFIG_AT91CAP9) # include <asm/arch/at91cap9.h>
Add support for following features: - nand boot, with PMECC 2bit ECC for 512 bytes sector - SPI flash boot - SD card boot - LCD support
Signed-off-by: Josh Wu josh.wu@atmel.com --- MAINTAINERS | 3 + arch/arm/cpu/arm926ejs/at91/Makefile | 1 + arch/arm/cpu/arm926ejs/at91/at91sam9n12_devices.c | 180 ++++++++++++++++ arch/arm/cpu/arm926ejs/at91/clock.c | 4 +- board/atmel/at91sam9n12ek/Makefile | 52 +++++ board/atmel/at91sam9n12ek/at91sam9n12ek.c | 228 ++++++++++++++++++++ boards.cfg | 3 + include/configs/at91sam9n12ek.h | 232 +++++++++++++++++++++ 8 files changed, 701 insertions(+), 2 deletions(-) create mode 100644 arch/arm/cpu/arm926ejs/at91/at91sam9n12_devices.c create mode 100644 board/atmel/at91sam9n12ek/Makefile create mode 100644 board/atmel/at91sam9n12ek/at91sam9n12ek.c create mode 100644 include/configs/at91sam9n12ek.h
diff --git a/MAINTAINERS b/MAINTAINERS index e792a8b..5ecb2f7 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -1007,6 +1007,9 @@ Richard Woodruff r-woodruff2@ti.com
omap2420h4 ARM1136EJS
+Josh Wu josh.wu@atmel.com + at91sam9n12ek ARM926EJS (AT91SAM9N12 SoC) + Ilya Yanok yanok@emcraft.com
mcx ARM ARMV7 (AM35x SoC) diff --git a/arch/arm/cpu/arm926ejs/at91/Makefile b/arch/arm/cpu/arm926ejs/at91/Makefile index 346e58f..c4408f6 100644 --- a/arch/arm/cpu/arm926ejs/at91/Makefile +++ b/arch/arm/cpu/arm926ejs/at91/Makefile @@ -35,6 +35,7 @@ COBJS-$(CONFIG_AT91SAM9263) += at91sam9263_devices.o COBJS-$(CONFIG_AT91SAM9RL) += at91sam9rl_devices.o COBJS-$(CONFIG_AT91SAM9M10G45) += at91sam9m10g45_devices.o COBJS-$(CONFIG_AT91SAM9G45) += at91sam9m10g45_devices.o +COBJS-$(CONFIG_AT91SAM9N12) += at91sam9n12_devices.o COBJS-$(CONFIG_AT91SAM9X5) += at91sam9x5_devices.o COBJS-$(CONFIG_AT91_EFLASH) += eflash.o COBJS-$(CONFIG_AT91_LED) += led.o diff --git a/arch/arm/cpu/arm926ejs/at91/at91sam9n12_devices.c b/arch/arm/cpu/arm926ejs/at91/at91sam9n12_devices.c new file mode 100644 index 0000000..2333031 --- /dev/null +++ b/arch/arm/cpu/arm926ejs/at91/at91sam9n12_devices.c @@ -0,0 +1,180 @@ +/* + * (C) Copyright 2013 Atmel Corporation + * Josh Wu josh.wu@atmel.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/at91_common.h> +#include <asm/arch/at91_pmc.h> +#include <asm/arch/at91_pio.h> + +unsigned int has_lcdc() +{ + return 1; +} + +void at91_serial0_hw_init(void) +{ + struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; + + at91_set_a_periph(AT91_PIO_PORTA, 0, 1); /* TXD0 */ + at91_set_a_periph(AT91_PIO_PORTA, 1, 0); /* RXD0 */ + writel(1 << ATMEL_ID_USART0, &pmc->pcer); +} + +void at91_serial1_hw_init(void) +{ + struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; + + at91_set_a_periph(AT91_PIO_PORTA, 5, 1); /* TXD1 */ + at91_set_a_periph(AT91_PIO_PORTA, 6, 0); /* RXD1 */ + writel(1 << ATMEL_ID_USART1, &pmc->pcer); +} + +void at91_serial2_hw_init(void) +{ + struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; + + at91_set_a_periph(AT91_PIO_PORTA, 7, 1); /* TXD2 */ + at91_set_a_periph(AT91_PIO_PORTA, 8, 0); /* RXD2 */ + writel(1 << ATMEL_ID_USART2, &pmc->pcer); +} + +void at91_serial3_hw_init(void) +{ + struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; + + at91_set_b_periph(AT91_PIO_PORTC, 22, 1); /* TXD3 */ + at91_set_b_periph(AT91_PIO_PORTC, 23, 0); /* RXD3 */ + writel(1 << ATMEL_ID_USART3, &pmc->pcer); +} + +void at91_seriald_hw_init(void) +{ + struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; + + at91_set_a_periph(AT91_PIO_PORTA, 10, 1); /* DTXD */ + at91_set_a_periph(AT91_PIO_PORTA, 9, 0); /* DRXD */ + writel(1 << ATMEL_ID_SYS, &pmc->pcer); +} + +#ifdef CONFIG_ATMEL_SPI +void at91_spi0_hw_init(unsigned long cs_mask) +{ + struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; + + at91_set_a_periph(AT91_PIO_PORTA, 11, 0); /* SPI0_MISO */ + at91_set_a_periph(AT91_PIO_PORTA, 12, 0); /* SPI0_MOSI */ + at91_set_a_periph(AT91_PIO_PORTA, 13, 0); /* SPI0_SPCK */ + + /* Enable clock */ + writel(1 << ATMEL_ID_SPI0, &pmc->pcer); + + if (cs_mask & (1 << 0)) + at91_set_pio_output(AT91_PIO_PORTA, 14, 1); + if (cs_mask & (1 << 1)) + at91_set_pio_output(AT91_PIO_PORTA, 7, 1); + if (cs_mask & (1 << 2)) + at91_set_pio_output(AT91_PIO_PORTA, 1, 1); + if (cs_mask & (1 << 3)) + at91_set_pio_output(AT91_PIO_PORTB, 3, 1); +} + +void at91_spi1_hw_init(unsigned long cs_mask) +{ + struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; + + at91_set_b_periph(AT91_PIO_PORTA, 21, 0); /* SPI1_MISO */ + at91_set_b_periph(AT91_PIO_PORTA, 22, 0); /* SPI1_MOSI */ + at91_set_b_periph(AT91_PIO_PORTA, 23, 0); /* SPI1_SPCK */ + + /* Enable clock */ + writel(1 << ATMEL_ID_SPI1, &pmc->pcer); + + if (cs_mask & (1 << 0)) + at91_set_pio_output(AT91_PIO_PORTA, 8, 1); + if (cs_mask & (1 << 1)) + at91_set_pio_output(AT91_PIO_PORTA, 0, 1); + if (cs_mask & (1 << 2)) + at91_set_pio_output(AT91_PIO_PORTA, 31, 1); + if (cs_mask & (1 << 3)) + at91_set_pio_output(AT91_PIO_PORTA, 30, 1); +} +#endif + +void at91_mci_hw_init(void) +{ + struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; + + at91_set_a_periph(AT91_PIO_PORTA, 17, 0); /* MCCK */ + at91_set_a_periph(AT91_PIO_PORTA, 16, 0); /* MCCDA */ + at91_set_a_periph(AT91_PIO_PORTA, 15, 0); /* MCDA0 */ + at91_set_a_periph(AT91_PIO_PORTA, 18, 0); /* MCDA1 */ + at91_set_a_periph(AT91_PIO_PORTA, 19, 0); /* MCDA2 */ + at91_set_a_periph(AT91_PIO_PORTA, 20, 0); /* MCDA3 */ + + writel(1 << ATMEL_ID_HSMCI0, &pmc->pcer); +} + +#ifdef CONFIG_LCD +void at91_lcd_hw_init(void) +{ + struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; + + at91_set_a_periph(AT91_PIO_PORTC, 24, 0); /* LCDDPWR */ + at91_set_a_periph(AT91_PIO_PORTC, 26, 0); /* LCDVSYNC */ + at91_set_a_periph(AT91_PIO_PORTC, 27, 0); /* LCDHSYNC */ + at91_set_a_periph(AT91_PIO_PORTC, 28, 0); /* LCDDOTCK */ + at91_set_a_periph(AT91_PIO_PORTC, 29, 0); /* LCDDEN */ + at91_set_a_periph(AT91_PIO_PORTC, 30, 0); /* LCDDOTCK */ + + at91_set_a_periph(AT91_PIO_PORTC, 0, 0); /* LCDD0 */ + at91_set_a_periph(AT91_PIO_PORTC, 1, 0); /* LCDD1 */ + at91_set_a_periph(AT91_PIO_PORTC, 2, 0); /* LCDD2 */ + at91_set_a_periph(AT91_PIO_PORTC, 3, 0); /* LCDD3 */ + at91_set_a_periph(AT91_PIO_PORTC, 4, 0); /* LCDD4 */ + at91_set_a_periph(AT91_PIO_PORTC, 5, 0); /* LCDD5 */ + at91_set_a_periph(AT91_PIO_PORTC, 6, 0); /* LCDD6 */ + at91_set_a_periph(AT91_PIO_PORTC, 7, 0); /* LCDD7 */ + at91_set_a_periph(AT91_PIO_PORTC, 8, 0); /* LCDD8 */ + at91_set_a_periph(AT91_PIO_PORTC, 9, 0); /* LCDD9 */ + at91_set_a_periph(AT91_PIO_PORTC, 10, 0); /* LCDD10 */ + at91_set_a_periph(AT91_PIO_PORTC, 11, 0); /* LCDD11 */ + at91_set_a_periph(AT91_PIO_PORTC, 12, 0); /* LCDD12 */ + at91_set_b_periph(AT91_PIO_PORTC, 13, 0); /* LCDD13 */ + at91_set_a_periph(AT91_PIO_PORTC, 14, 0); /* LCDD14 */ + at91_set_a_periph(AT91_PIO_PORTC, 15, 0); /* LCDD15 */ + at91_set_a_periph(AT91_PIO_PORTC, 16, 0); /* LCDD16 */ + at91_set_a_periph(AT91_PIO_PORTC, 17, 0); /* LCDD17 */ + at91_set_a_periph(AT91_PIO_PORTC, 18, 0); /* LCDD18 */ + at91_set_a_periph(AT91_PIO_PORTC, 19, 0); /* LCDD19 */ + at91_set_a_periph(AT91_PIO_PORTC, 20, 0); /* LCDD20 */ + at91_set_b_periph(AT91_PIO_PORTC, 21, 0); /* LCDD21 */ + at91_set_a_periph(AT91_PIO_PORTC, 22, 0); /* LCDD22 */ + at91_set_a_periph(AT91_PIO_PORTC, 23, 0); /* LCDD23 */ + + writel(1 << ATMEL_ID_LCDC, &pmc->pcer); +} +#endif + + + diff --git a/arch/arm/cpu/arm926ejs/at91/clock.c b/arch/arm/cpu/arm926ejs/at91/clock.c index f825388..5b4923f 100644 --- a/arch/arm/cpu/arm926ejs/at91/clock.c +++ b/arch/arm/cpu/arm926ejs/at91/clock.c @@ -156,7 +156,7 @@ int at91_clock_init(unsigned long main_clock) */ mckr = readl(&pmc->mckr); #if defined(CONFIG_AT91SAM9G45) || defined(CONFIG_AT91SAM9M10G45) \ - || defined(CONFIG_AT91SAM9X5) + || defined(CONFIG_AT91SAM9N12) || defined(CONFIG_AT91SAM9X5) /* plla divisor by 2 */ gd->arch.plla_rate_hz /= (1 << ((mckr & 1 << 12) >> 12)); #endif @@ -171,7 +171,7 @@ int at91_clock_init(unsigned long main_clock) if (mckr & AT91_PMC_MCKR_MDIV_MASK) freq /= 2; /* processor clock division */ #elif defined(CONFIG_AT91SAM9G45) || defined(CONFIG_AT91SAM9M10G45) \ - || defined(CONFIG_AT91SAM9X5) + || defined(CONFIG_AT91SAM9N12) || defined(CONFIG_AT91SAM9X5) /* mdiv <==> divisor * 0 <==> 1 * 1 <==> 2 diff --git a/board/atmel/at91sam9n12ek/Makefile b/board/atmel/at91sam9n12ek/Makefile new file mode 100644 index 0000000..3aa67d5 --- /dev/null +++ b/board/atmel/at91sam9n12ek/Makefile @@ -0,0 +1,52 @@ +# +# (C) Copyright 2003-2008 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# (C) Copyright 2008 +# Stelian Pop stelian.pop@leadtechdesign.com +# Lead Tech Design <www.leadtechdesign.com> +# +# (C) Copyright 2013 +# Josh Wu josh.wu@atmel.com +# Atmel corporation <www.atmel.com> +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).o + +COBJS-y += at91sam9n12ek.o + +SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS-y)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(obj).depend $(OBJS) $(SOBJS) + $(call cmd_link_o_target, $(OBJS) $(SOBJS)) + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/atmel/at91sam9n12ek/at91sam9n12ek.c b/board/atmel/at91sam9n12ek/at91sam9n12ek.c new file mode 100644 index 0000000..8752794 --- /dev/null +++ b/board/atmel/at91sam9n12ek/at91sam9n12ek.c @@ -0,0 +1,228 @@ +/* + * (C) Copyright 2013 Atmel Corporation + * Josh Wu josh.wu@atmel.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/at91sam9x5_matrix.h> +#include <asm/arch/at91sam9_smc.h> +#include <asm/arch/at91_common.h> +#include <asm/arch/at91_pmc.h> +#include <asm/arch/at91_rstc.h> +#include <asm/arch/at91_pio.h> +#include <asm/arch/clk.h> +#include <lcd.h> +#include <atmel_hlcdc.h> +#include <atmel_mci.h> + +#ifdef CONFIG_LCD_INFO +#include <nand.h> +#include <version.h> +#endif + +DECLARE_GLOBAL_DATA_PTR; + +/* ------------------------------------------------------------------------- */ +/* + * Miscelaneous platform dependent initialisations + */ +#ifdef CONFIG_NAND_ATMEL +static void at91sam9n12ek_nand_hw_init(void) +{ + struct at91_smc *smc = (struct at91_smc *)ATMEL_BASE_SMC; + struct at91_matrix *matrix = (struct at91_matrix *)ATMEL_BASE_MATRIX; + unsigned long csa; + + /* Assign CS3 to NAND/SmartMedia Interface */ + csa = readl(&matrix->ebicsa); + csa |= AT91_MATRIX_EBI_CS3A_SMC_SMARTMEDIA; + /* Configure databus */ + csa &= ~AT91_MATRIX_NFD0_ON_D16; /* nandflash connect to D0~D15 */ + /* Configure IO drive */ + csa &= ~AT91_MATRIX_EBI_EBI_IOSR_NORMAL; + + writel(csa, &matrix->ebicsa); + + /* Configure SMC CS3 for NAND/SmartMedia */ + writel(AT91_SMC_SETUP_NWE(1) | AT91_SMC_SETUP_NCS_WR(0) | + AT91_SMC_SETUP_NRD(2) | AT91_SMC_SETUP_NCS_RD(0), + &smc->cs[3].setup); + writel(AT91_SMC_PULSE_NWE(3) | AT91_SMC_PULSE_NCS_WR(5) | + AT91_SMC_PULSE_NRD(4) | AT91_SMC_PULSE_NCS_RD(6), + &smc->cs[3].pulse); + writel(AT91_SMC_CYCLE_NWE(5) | AT91_SMC_CYCLE_NRD(7), + &smc->cs[3].cycle); + writel(AT91_SMC_MODE_RM_NRD | AT91_SMC_MODE_WM_NWE | + AT91_SMC_MODE_EXNW_DISABLE | +#ifdef CONFIG_SYS_NAND_DBW_16 + AT91_SMC_MODE_DBW_16 | +#else /* CONFIG_SYS_NAND_DBW_8 */ + AT91_SMC_MODE_DBW_8 | +#endif + AT91_SMC_MODE_TDF_CYCLE(1), + &smc->cs[3].mode); + + /* Configure RDY/BSY pin */ + at91_set_pio_input(AT91_PIO_PORTD, 5, 1); + + /* Configure ENABLE pin for NandFlash */ + at91_set_pio_output(AT91_PIO_PORTD, 4, 1); + + at91_set_a_periph(AT91_PIO_PORTD, 0, 1); /* NAND OE */ + at91_set_a_periph(AT91_PIO_PORTD, 1, 1); /* NAND WE */ + at91_set_a_periph(AT91_PIO_PORTD, 2, 1); /* ALE */ + at91_set_a_periph(AT91_PIO_PORTD, 3, 1); /* CLE */ +} +#endif + +#ifdef CONFIG_LCD +vidinfo_t panel_info = { + .vl_col = 480, + .vl_row = 272, + .vl_clk = 9000000, + .vl_bpix = LCD_BPP, + .vl_sync = 0, + .vl_tft = 1, + .vl_hsync_len = 5, + .vl_left_margin = 8, + .vl_right_margin = 43, + .vl_vsync_len = 10, + .vl_upper_margin = 4, + .vl_lower_margin = 12, + .mmio = ATMEL_BASE_LCDC, +}; + +void lcd_enable(void) +{ + at91_set_pio_output(AT91_PIO_PORTC, 25, 0); /* power up */ +} + +void lcd_disable(void) +{ + at91_set_pio_output(AT91_PIO_PORTC, 25, 1); /* power down */ +} + +#ifdef CONFIG_LCD_INFO +void lcd_show_board_info(void) +{ + ulong dram_size, nand_size; + int i; + char temp[32]; + + lcd_printf("%s\n", U_BOOT_VERSION); + lcd_printf("ATMEL Corp\n"); + lcd_printf("at91@atmel.com\n"); + lcd_printf("%s CPU at %s MHz\n", + ATMEL_CPU_NAME, + strmhz(temp, get_cpu_clk_rate())); + + dram_size = 0; + for (i = 0; i < CONFIG_NR_DRAM_BANKS; i++) + dram_size += gd->bd->bi_dram[i].size; + nand_size = 0; + for (i = 0; i < CONFIG_SYS_MAX_NAND_DEVICE; i++) + nand_size += nand_info[i].size; + lcd_printf(" %ld MB SDRAM, %ld MB NAND\n", + dram_size >> 20, + nand_size >> 20); +} +#endif /* CONFIG_LCD_INFO */ +#endif /* CONFIG_LCD */ + +/* SPI chip select control */ +#ifdef CONFIG_ATMEL_SPI +#include <spi.h> +int spi_cs_is_valid(unsigned int bus, unsigned int cs) +{ + return bus == 0 && cs < 2; +} + +void spi_cs_activate(struct spi_slave *slave) +{ + switch (slave->cs) { + case 0: + at91_set_pio_output(AT91_PIO_PORTA, 14, 0); + break; + case 1: + at91_set_pio_output(AT91_PIO_PORTA, 7, 0); + break; + } +} + +void spi_cs_deactivate(struct spi_slave *slave) +{ + switch (slave->cs) { + case 0: + at91_set_pio_output(AT91_PIO_PORTA, 14, 1); + break; + case 1: + at91_set_pio_output(AT91_PIO_PORTA, 7, 1); + break; + } +} +#endif /* CONFIG_ATMEL_SPI */ + +#ifdef CONFIG_GENERIC_ATMEL_MCI +int board_mmc_init(bd_t *bd) +{ + at91_mci_hw_init(); + + return atmel_mci_init((void *)ATMEL_BASE_HSMCI0); +} +#endif + +int board_early_init_f(void) +{ + /* Enable clocks for all PIOs */ + struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; + writel((1 << ATMEL_ID_PIOAB) | (1 << ATMEL_ID_PIOCD), &pmc->pcer); + + at91_seriald_hw_init(); + return 0; +} + +int board_init(void) +{ + /* adress of boot parameters */ + gd->bd->bi_boot_params = CONFIG_SYS_SDRAM_BASE + 0x100; + +#ifdef CONFIG_NAND_ATMEL + at91sam9n12ek_nand_hw_init(); +#endif + +#ifdef CONFIG_ATMEL_SPI + at91_spi0_hw_init(1 << 0); +#endif + +#ifdef CONFIG_LCD + at91_lcd_hw_init(); +#endif + + return 0; +} + +int dram_init(void) +{ + gd->ram_size = get_ram_size((void *)CONFIG_SYS_SDRAM_BASE, + CONFIG_SYS_SDRAM_SIZE); + return 0; +} diff --git a/boards.cfg b/boards.cfg index fdb32c2..5273c27 100644 --- a/boards.cfg +++ b/boards.cfg @@ -106,6 +106,9 @@ at91sam9x5ek_mmc arm arm926ejs at91sam9x5ek atmel at91sam9xeek_dataflash_cs0 arm arm926ejs at91sam9260ek atmel at91 at91sam9260ek:AT91SAM9XE,SYS_USE_DATAFLASH_CS0 at91sam9xeek_dataflash_cs1 arm arm926ejs at91sam9260ek atmel at91 at91sam9260ek:AT91SAM9XE,SYS_USE_DATAFLASH_CS1 at91sam9xeek_nandflash arm arm926ejs at91sam9260ek atmel at91 at91sam9260ek:AT91SAM9XE,SYS_USE_NANDFLASH +at91sam9n12ek_nandflash arm arm926ejs at91sam9n12ek atmel at91 at91sam9n12ek:AT91SAM9N12,SYS_USE_NANDFLASH +at91sam9n12ek_spiflash arm arm926ejs at91sam9n12ek atmel at91 at91sam9n12ek:AT91SAM9N12,SYS_USE_SPIFLASH +at91sam9n12ek_mmc arm arm926ejs at91sam9n12ek atmel at91 at91sam9n12ek:AT91SAM9N12,SYS_USE_MMC snapper9260 arm arm926ejs - bluewater at91 snapper9260:AT91SAM9260 snapper9g20 arm arm926ejs snapper9260 bluewater at91 snapper9260:AT91SAM9G20 vl_ma2sc arm arm926ejs vl_ma2sc BuS at91 diff --git a/include/configs/at91sam9n12ek.h b/include/configs/at91sam9n12ek.h new file mode 100644 index 0000000..8d2673d --- /dev/null +++ b/include/configs/at91sam9n12ek.h @@ -0,0 +1,232 @@ +/* + * (C) Copyright 2013 Atmel Corporation. + * Josh Wu josh.wu@atmel.com + * + * Configuation settings for the AT91SAM9N12-EK boards. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __AT91SAM9N12_CONFIG_H_ +#define __AT91SAM9N12_CONFIG_H_ + +/* + * SoC must be defined first, before hardware.h is included. + * In this case SoC is defined in boards.cfg. + */ +#include <asm/hardware.h> + +#define CONFIG_SYS_TEXT_BASE 0x26f00000 + +#define CONFIG_ARM926EJS +#define CONFIG_AT91FAMILY + +/* ARM asynchronous clock */ +#define CONFIG_SYS_AT91_SLOW_CLOCK 32768 /* slow clock xtal */ +#define CONFIG_SYS_AT91_MAIN_CLOCK 16000000 /* main clock xtal */ +#define CONFIG_SYS_HZ 1000 + +/* Misc CPU related */ +#define CONFIG_CMDLINE_TAG /* enable passing of ATAGs */ +#define CONFIG_SETUP_MEMORY_TAGS +#define CONFIG_INITRD_TAG +#define CONFIG_SKIP_LOWLEVEL_INIT +#define CONFIG_BOARD_EARLY_INIT_F +#define CONFIG_DISPLAY_CPUINFO + +#define CONFIG_OF_LIBFDT + +/* general purpose I/O */ +#define CONFIG_AT91_GPIO + +/* serial console */ +#define CONFIG_ATMEL_USART +#define CONFIG_USART_BASE ATMEL_BASE_DBGU +#define CONFIG_USART_ID ATMEL_ID_SYS +#define CONFIG_BAUDRATE 115200 + +/* LCD */ +#define CONFIG_LCD +#define LCD_BPP LCD_COLOR16 +#define LCD_OUTPUT_BPP 24 +#define CONFIG_LCD_LOGO +#define CONFIG_LCD_INFO +#define CONFIG_LCD_INFO_BELOW_LOGO +#define CONFIG_SYS_WHITE_ON_BLACK +#define CONFIG_ATMEL_HLCD +#define CONFIG_ATMEL_LCD_RGB565 +#define CONFIG_SYS_CONSOLE_IS_IN_ENV + +#define CONFIG_BOOTDELAY 3 + +/* + * BOOTP options + */ +#define CONFIG_BOOTP_BOOTFILESIZE +#define CONFIG_BOOTP_BOOTPATH +#define CONFIG_BOOTP_GATEWAY +#define CONFIG_BOOTP_HOSTNAME + +/* NOR flash - no real flash on this board */ +#define CONFIG_SYS_NO_FLASH + +/* + * Command line configuration. + */ +#include <config_cmd_default.h> +#undef CONFIG_CMD_FPGA + +#define CONFIG_CMD_BOOTZ +#define CONFIG_CMD_PING +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_NAND +#define CONFIG_CMD_SF +#define CONFIG_CMD_MMC +#define CONFIG_CMD_FAT + +#define CONFIG_NR_DRAM_BANKS 1 +#define CONFIG_SYS_SDRAM_BASE 0x20000000 +#define CONFIG_SYS_SDRAM_SIZE 0x08000000 + +/* + * Initial stack pointer: 4k - GENERATED_GBL_DATA_SIZE in internal SRAM, + * leaving the correct space for initial global data structure above + * that address while providing maximum stack area below. + */ +# define CONFIG_SYS_INIT_SP_ADDR \ + (ATMEL_BASE_SRAM + 0x1000 - GENERATED_GBL_DATA_SIZE) + +/* DataFlash */ +#ifdef CONFIG_CMD_SF +#define CONFIG_ATMEL_SPI +#define CONFIG_SPI_FLASH +#define CONFIG_SPI_FLASH_ATMEL +#define CONFIG_SF_DEFAULT_SPEED 30000000 +#define CONFIG_ENV_SPI_MODE SPI_MODE_3 +#define CONFIG_SF_DEFAULT_MODE SPI_MODE_3 +#endif + +/* NAND flash */ +#ifdef CONFIG_CMD_NAND +#define CONFIG_NAND_ATMEL +#define CONFIG_SYS_MAX_NAND_DEVICE 1 +#define CONFIG_SYS_NAND_BASE 0x40000000 +#define CONFIG_SYS_NAND_MASK_ALE (1 << 21) +#define CONFIG_SYS_NAND_MASK_CLE (1 << 22) +#define CONFIG_SYS_NAND_ENABLE_PIN AT91_PIO_PORTD, 4 +#define CONFIG_SYS_NAND_READY_PIN AT91_PIO_PORTD, 5 + +/* PMECC & PMERRLOC */ +#define CONFIG_ATMEL_NAND_HWECC +#define CONFIG_ATMEL_NAND_HW_PMECC +#define CONFIG_PMECC_CAP 2 +#define CONFIG_PMECC_SECTOR_SIZE 512 +#define CONFIG_PMECC_INDEX_TABLE_OFFSET 0x8000 +#endif + +#define CONFIG_MTD_PARTITIONS +#define CONFIG_MTD_DEVICE +#define CONFIG_CMD_MTDPARTS +#define MTDIDS_DEFAULT "nand0=atmel_nand" +#define MTDPARTS_DEFAULT \ + "mtdparts=atmel_nand:256k(bootstrap)ro,512k(uboot)ro," \ + "256k(env),256k(env_redundant),256k(spare)," \ + "512k(dtb),6M(kernel)ro,-(rootfs)" + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "console=console=ttyS0,115200\0" \ + "mtdparts="MTDPARTS_DEFAULT"\0" \ + "bootargs_nand=rootfstype=ubifs ubi.mtd=7 root=ubi0:rootfs rw\0"\ + "bootargs_mmc=root=/dev/mmcblk0p2 rw rootfstype=ext4 rootwait\0" + +/* MMC */ +#ifdef CONFIG_CMD_MMC +#define CONFIG_MMC +#define CONFIG_GENERIC_MMC +#define CONFIG_GENERIC_ATMEL_MCI +#endif + +/* FAT */ +#ifdef CONFIG_CMD_FAT +#define CONFIG_DOS_PARTITION +#endif + +#define CONFIG_SYS_LOAD_ADDR 0x22000000 /* load address */ + +#define CONFIG_SYS_MEMTEST_START CONFIG_SYS_SDRAM_BASE +#define CONFIG_SYS_MEMTEST_END 0x26e00000 + +#ifdef CONFIG_SYS_USE_SPIFLASH + +/* bootstrap + u-boot + env + linux in dataflash on CS0 */ +#define CONFIG_ENV_IS_IN_SPI_FLASH +#define CONFIG_ENV_OFFSET 0x5000 +#define CONFIG_ENV_SIZE 0x3000 +#define CONFIG_ENV_SECT_SIZE 0x1000 +#define CONFIG_BOOTCOMMAND \ + "setenv bootargs ${console} ${mtdparts} ${bootargs_nand};" \ + "sf probe 0; sf read 0x22000000 0x100000 0x300000; " \ + "bootm 0x22000000" + +#elif defined(CONFIG_SYS_USE_NANDFLASH) + +/* bootstrap + u-boot + env + linux in nandflash */ +#define CONFIG_ENV_IS_IN_NAND +#define CONFIG_ENV_OFFSET 0xc0000 +#define CONFIG_ENV_OFFSET_REDUND 0x100000 +#define CONFIG_ENV_SIZE 0x20000 /* 1 sector = 128 kB */ +#define CONFIG_BOOTCOMMAND \ + "setenv bootargs ${console} ${mtdparts} ${bootargs_nand};" \ + "nand read 0x21000000 0x180000 0x080000;" \ + "nand read 0x22000000 0x200000 0x400000;" \ + "bootm 0x22000000 - 0x21000000" + +#else /* CONFIG_SYS_USE_MMC */ + +/* bootstrap + u-boot + env + linux in mmc */ +#define CONFIG_ENV_IS_IN_MMC +/* For FAT system, most cases it should be in the reserved sector */ +#define CONFIG_ENV_OFFSET 0x2000 +#define CONFIG_ENV_SIZE 0x1000 +#define CONFIG_SYS_MMC_ENV_DEV 0 +#define CONFIG_BOOTCOMMAND \ + "setenv bootargs ${console} ${mtdparts} ${bootargs_mmc};" \ + "fatload mmc 0:1 0x21000000 dtb;" \ + "fatload mmc 0:1 0x22000000 uImage;" \ + "bootm 0x22000000 - 0x21000000" + +#endif + +#define CONFIG_SYS_PROMPT "U-Boot> " +#define CONFIG_SYS_CBSIZE 256 +#define CONFIG_SYS_MAXARGS 16 +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) \ + + 16) +#define CONFIG_SYS_LONGHELP +#define CONFIG_CMDLINE_EDITING +#define CONFIG_AUTO_COMPLETE +#define CONFIG_SYS_HUSH_PARSER + +/* + * Size of malloc() pool + */ +#define CONFIG_SYS_MALLOC_LEN (4 * 1024 * 1024) +#define CONFIG_STACKSIZE (32 * 1024) /* regular stack */ + +#endif
Hi, Andreas
Sorry, the lcd initialization function still has wrong config. see my comment below.
- SPI flash boot
- SD card boot
- LCD support
[snip]
- struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC;
- at91_set_a_periph(AT91_PIO_PORTC, 24, 0); /* LCDDPWR */
- at91_set_a_periph(AT91_PIO_PORTC, 26, 0); /* LCDVSYNC */
- at91_set_a_periph(AT91_PIO_PORTC, 27, 0); /* LCDHSYNC */
- at91_set_a_periph(AT91_PIO_PORTC, 28, 0); /* LCDDOTCK */
- at91_set_a_periph(AT91_PIO_PORTC, 29, 0); /* LCDDEN */
- at91_set_a_periph(AT91_PIO_PORTC, 30, 0); /* LCDDOTCK */
- at91_set_a_periph(AT91_PIO_PORTC, 0, 0); /* LCDD0 */
- at91_set_a_periph(AT91_PIO_PORTC, 1, 0); /* LCDD1 */
- at91_set_a_periph(AT91_PIO_PORTC, 2, 0); /* LCDD2 */
- at91_set_a_periph(AT91_PIO_PORTC, 3, 0); /* LCDD3 */
- at91_set_a_periph(AT91_PIO_PORTC, 4, 0); /* LCDD4 */
- at91_set_a_periph(AT91_PIO_PORTC, 5, 0); /* LCDD5 */
- at91_set_a_periph(AT91_PIO_PORTC, 6, 0); /* LCDD6 */
- at91_set_a_periph(AT91_PIO_PORTC, 7, 0); /* LCDD7 */
- at91_set_a_periph(AT91_PIO_PORTC, 8, 0); /* LCDD8 */
- at91_set_a_periph(AT91_PIO_PORTC, 9, 0); /* LCDD9 */
- at91_set_a_periph(AT91_PIO_PORTC, 10, 0); /* LCDD10 */
- at91_set_a_periph(AT91_PIO_PORTC, 11, 0); /* LCDD11 */
- at91_set_a_periph(AT91_PIO_PORTC, 12, 0); /* LCDD12 */
- at91_set_b_periph(AT91_PIO_PORTC, 13, 0); /* LCDD13 */
It should be:
+ at91_set_a_periph(AT91_PIO_PORTC, 13, 0); /* LCDD13 */
- at91_set_a_periph(AT91_PIO_PORTC, 14, 0); /* LCDD14 */
- at91_set_a_periph(AT91_PIO_PORTC, 15, 0); /* LCDD15 */
- at91_set_a_periph(AT91_PIO_PORTC, 16, 0); /* LCDD16 */
- at91_set_a_periph(AT91_PIO_PORTC, 17, 0); /* LCDD17 */
- at91_set_a_periph(AT91_PIO_PORTC, 18, 0); /* LCDD18 */
- at91_set_a_periph(AT91_PIO_PORTC, 19, 0); /* LCDD19 */
- at91_set_a_periph(AT91_PIO_PORTC, 20, 0); /* LCDD20 */
- at91_set_b_periph(AT91_PIO_PORTC, 21, 0); /* LCDD21 */
it should be
+ at91_set_a_periph(AT91_PIO_PORTC, 21, 0); /* LCDD21 */
I will resend this single patch again which includes above lcd pin fix.
Best Regards, Josh Wu
mcx ARM ARMV7 (AM35x SoC) diff --git a/arch/arm/cpu/arm926ejs/at91/Makefile b/arch/arm/cpu/arm926ejs/at91/Makefile index 346e58f..c4408f6 100644 --- a/arch/arm/cpu/arm926ejs/at91/Makefile +++ b/arch/arm/cpu/arm926ejs/at91/Makefile @@ -35,6 +35,7 @@ COBJS-$(CONFIG_AT91SAM9263) += at91sam9263_devices.o COBJS-$(CONFIG_AT91SAM9RL) += at91sam9rl_devices.o COBJS-$(CONFIG_AT91SAM9M10G45) += at91sam9m10g45_devices.o COBJS-$(CONFIG_AT91SAM9G45) += at91sam9m10g45_devices.o +COBJS-$(CONFIG_AT91SAM9N12) += at91sam9n12_devices.o COBJS-$(CONFIG_AT91SAM9X5) += at91sam9x5_devices.o COBJS-$(CONFIG_AT91_EFLASH) += eflash.o COBJS-$(CONFIG_AT91_LED) += led.o diff --git a/arch/arm/cpu/arm926ejs/at91/at91sam9n12_devices.c b/arch/arm/cpu/arm926ejs/at91/at91sam9n12_devices.c new file mode 100644 index 0000000..2333031 --- /dev/null +++ b/arch/arm/cpu/arm926ejs/at91/at91sam9n12_devices.c @@ -0,0 +1,180 @@ +/* + * (C) Copyright 2013 Atmel Corporation + * Josh Wu josh.wu@atmel.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/at91_common.h> +#include <asm/arch/at91_pmc.h> +#include <asm/arch/at91_pio.h> + +unsigned int has_lcdc() +{ + return 1; +} + +void at91_serial0_hw_init(void) +{ + struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; + + at91_set_a_periph(AT91_PIO_PORTA, 0, 1); /* TXD0 */ + at91_set_a_periph(AT91_PIO_PORTA, 1, 0); /* RXD0 */ + writel(1 << ATMEL_ID_USART0, &pmc->pcer); +} + +void at91_serial1_hw_init(void) +{ + struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; + + at91_set_a_periph(AT91_PIO_PORTA, 5, 1); /* TXD1 */ + at91_set_a_periph(AT91_PIO_PORTA, 6, 0); /* RXD1 */ + writel(1 << ATMEL_ID_USART1, &pmc->pcer); +} + +void at91_serial2_hw_init(void) +{ + struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; + + at91_set_a_periph(AT91_PIO_PORTA, 7, 1); /* TXD2 */ + at91_set_a_periph(AT91_PIO_PORTA, 8, 0); /* RXD2 */ + writel(1 << ATMEL_ID_USART2, &pmc->pcer); +} + +void at91_serial3_hw_init(void) +{ + struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; + + at91_set_b_periph(AT91_PIO_PORTC, 22, 1); /* TXD3 */ + at91_set_b_periph(AT91_PIO_PORTC, 23, 0); /* RXD3 */ + writel(1 << ATMEL_ID_USART3, &pmc->pcer); +} + +void at91_seriald_hw_init(void) +{ + struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; + + at91_set_a_periph(AT91_PIO_PORTA, 10, 1); /* DTXD */ + at91_set_a_periph(AT91_PIO_PORTA, 9, 0); /* DRXD */ + writel(1 << ATMEL_ID_SYS, &pmc->pcer); +} + +#ifdef CONFIG_ATMEL_SPI +void at91_spi0_hw_init(unsigned long cs_mask) +{ + struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; + + at91_set_a_periph(AT91_PIO_PORTA, 11, 0); /* SPI0_MISO */ + at91_set_a_periph(AT91_PIO_PORTA, 12, 0); /* SPI0_MOSI */ + at91_set_a_periph(AT91_PIO_PORTA, 13, 0); /* SPI0_SPCK */ + + /* Enable clock */ + writel(1 << ATMEL_ID_SPI0, &pmc->pcer); + + if (cs_mask & (1 << 0)) + at91_set_pio_output(AT91_PIO_PORTA, 14, 1); + if (cs_mask & (1 << 1)) + at91_set_pio_output(AT91_PIO_PORTA, 7, 1); + if (cs_mask & (1 << 2)) + at91_set_pio_output(AT91_PIO_PORTA, 1, 1); + if (cs_mask & (1 << 3)) + at91_set_pio_output(AT91_PIO_PORTB, 3, 1); +} + +void at91_spi1_hw_init(unsigned long cs_mask) +{ + struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; + + at91_set_b_periph(AT91_PIO_PORTA, 21, 0); /* SPI1_MISO */ + at91_set_b_periph(AT91_PIO_PORTA, 22, 0); /* SPI1_MOSI */ + at91_set_b_periph(AT91_PIO_PORTA, 23, 0); /* SPI1_SPCK */ + + /* Enable clock */ + writel(1 << ATMEL_ID_SPI1, &pmc->pcer); + + if (cs_mask & (1 << 0)) + at91_set_pio_output(AT91_PIO_PORTA, 8, 1); + if (cs_mask & (1 << 1)) + at91_set_pio_output(AT91_PIO_PORTA, 0, 1); + if (cs_mask & (1 << 2)) + at91_set_pio_output(AT91_PIO_PORTA, 31, 1); + if (cs_mask & (1 << 3)) + at91_set_pio_output(AT91_PIO_PORTA, 30, 1); +} +#endif + +void at91_mci_hw_init(void) +{ + struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; + + at91_set_a_periph(AT91_PIO_PORTA, 17, 0); /* MCCK */ + at91_set_a_periph(AT91_PIO_PORTA, 16, 0); /* MCCDA */ + at91_set_a_periph(AT91_PIO_PORTA, 15, 0); /* MCDA0 */ + at91_set_a_periph(AT91_PIO_PORTA, 18, 0); /* MCDA1 */ + at91_set_a_periph(AT91_PIO_PORTA, 19, 0); /* MCDA2 */ + at91_set_a_periph(AT91_PIO_PORTA, 20, 0); /* MCDA3 */ + + writel(1 << ATMEL_ID_HSMCI0, &pmc->pcer); +} + +#ifdef CONFIG_LCD +void at91_lcd_hw_init(void) +{ + struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; + + at91_set_a_periph(AT91_PIO_PORTC, 24, 0); /* LCDDPWR */ + at91_set_a_periph(AT91_PIO_PORTC, 26, 0); /* LCDVSYNC */ + at91_set_a_periph(AT91_PIO_PORTC, 27, 0); /* LCDHSYNC */ + at91_set_a_periph(AT91_PIO_PORTC, 28, 0); /* LCDDOTCK */ + at91_set_a_periph(AT91_PIO_PORTC, 29, 0); /* LCDDEN */ + at91_set_a_periph(AT91_PIO_PORTC, 30, 0); /* LCDDOTCK */ + + at91_set_a_periph(AT91_PIO_PORTC, 0, 0); /* LCDD0 */ + at91_set_a_periph(AT91_PIO_PORTC, 1, 0); /* LCDD1 */ + at91_set_a_periph(AT91_PIO_PORTC, 2, 0); /* LCDD2 */ + at91_set_a_periph(AT91_PIO_PORTC, 3, 0); /* LCDD3 */ + at91_set_a_periph(AT91_PIO_PORTC, 4, 0); /* LCDD4 */ + at91_set_a_periph(AT91_PIO_PORTC, 5, 0); /* LCDD5 */ + at91_set_a_periph(AT91_PIO_PORTC, 6, 0); /* LCDD6 */ + at91_set_a_periph(AT91_PIO_PORTC, 7, 0); /* LCDD7 */ + at91_set_a_periph(AT91_PIO_PORTC, 8, 0); /* LCDD8 */ + at91_set_a_periph(AT91_PIO_PORTC, 9, 0); /* LCDD9 */ + at91_set_a_periph(AT91_PIO_PORTC, 10, 0); /* LCDD10 */ + at91_set_a_periph(AT91_PIO_PORTC, 11, 0); /* LCDD11 */ + at91_set_a_periph(AT91_PIO_PORTC, 12, 0); /* LCDD12 */ + at91_set_a_periph(AT91_PIO_PORTC, 13, 0); /* LCDD13 */ + at91_set_a_periph(AT91_PIO_PORTC, 14, 0); /* LCDD14 */ + at91_set_a_periph(AT91_PIO_PORTC, 15, 0); /* LCDD15 */ + at91_set_a_periph(AT91_PIO_PORTC, 16, 0); /* LCDD16 */ + at91_set_a_periph(AT91_PIO_PORTC, 17, 0); /* LCDD17 */ + at91_set_a_periph(AT91_PIO_PORTC, 18, 0); /* LCDD18 */ + at91_set_a_periph(AT91_PIO_PORTC, 19, 0); /* LCDD19 */ + at91_set_a_periph(AT91_PIO_PORTC, 20, 0); /* LCDD20 */ + at91_set_a_periph(AT91_PIO_PORTC, 21, 0); /* LCDD21 */ + at91_set_a_periph(AT91_PIO_PORTC, 22, 0); /* LCDD22 */ + at91_set_a_periph(AT91_PIO_PORTC, 23, 0); /* LCDD23 */ + + writel(1 << ATMEL_ID_LCDC, &pmc->pcer); +} +#endif + + + diff --git a/arch/arm/cpu/arm926ejs/at91/clock.c b/arch/arm/cpu/arm926ejs/at91/clock.c index f825388..5b4923f 100644 --- a/arch/arm/cpu/arm926ejs/at91/clock.c +++ b/arch/arm/cpu/arm926ejs/at91/clock.c @@ -156,7 +156,7 @@ int at91_clock_init(unsigned long main_clock) */ mckr = readl(&pmc->mckr); #if defined(CONFIG_AT91SAM9G45) || defined(CONFIG_AT91SAM9M10G45) \ - || defined(CONFIG_AT91SAM9X5) + || defined(CONFIG_AT91SAM9N12) || defined(CONFIG_AT91SAM9X5) /* plla divisor by 2 */ gd->arch.plla_rate_hz /= (1 << ((mckr & 1 << 12) >> 12)); #endif @@ -171,7 +171,7 @@ int at91_clock_init(unsigned long main_clock) if (mckr & AT91_PMC_MCKR_MDIV_MASK) freq /= 2; /* processor clock division */ #elif defined(CONFIG_AT91SAM9G45) || defined(CONFIG_AT91SAM9M10G45) \ - || defined(CONFIG_AT91SAM9X5) + || defined(CONFIG_AT91SAM9N12) || defined(CONFIG_AT91SAM9X5) /* mdiv <==> divisor * 0 <==> 1 * 1 <==> 2 diff --git a/board/atmel/at91sam9n12ek/Makefile b/board/atmel/at91sam9n12ek/Makefile new file mode 100644 index 0000000..3aa67d5 --- /dev/null +++ b/board/atmel/at91sam9n12ek/Makefile @@ -0,0 +1,52 @@ +# +# (C) Copyright 2003-2008 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# (C) Copyright 2008 +# Stelian Pop stelian.pop@leadtechdesign.com +# Lead Tech Design <www.leadtechdesign.com> +# +# (C) Copyright 2013 +# Josh Wu josh.wu@atmel.com +# Atmel corporation <www.atmel.com> +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).o + +COBJS-y += at91sam9n12ek.o + +SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS-y)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(obj).depend $(OBJS) $(SOBJS) + $(call cmd_link_o_target, $(OBJS) $(SOBJS)) + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/atmel/at91sam9n12ek/at91sam9n12ek.c b/board/atmel/at91sam9n12ek/at91sam9n12ek.c new file mode 100644 index 0000000..8752794 --- /dev/null +++ b/board/atmel/at91sam9n12ek/at91sam9n12ek.c @@ -0,0 +1,228 @@ +/* + * (C) Copyright 2013 Atmel Corporation + * Josh Wu josh.wu@atmel.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/at91sam9x5_matrix.h> +#include <asm/arch/at91sam9_smc.h> +#include <asm/arch/at91_common.h> +#include <asm/arch/at91_pmc.h> +#include <asm/arch/at91_rstc.h> +#include <asm/arch/at91_pio.h> +#include <asm/arch/clk.h> +#include <lcd.h> +#include <atmel_hlcdc.h> +#include <atmel_mci.h> + +#ifdef CONFIG_LCD_INFO +#include <nand.h> +#include <version.h> +#endif + +DECLARE_GLOBAL_DATA_PTR; + +/* ------------------------------------------------------------------------- */ +/* + * Miscelaneous platform dependent initialisations + */ +#ifdef CONFIG_NAND_ATMEL +static void at91sam9n12ek_nand_hw_init(void) +{ + struct at91_smc *smc = (struct at91_smc *)ATMEL_BASE_SMC; + struct at91_matrix *matrix = (struct at91_matrix *)ATMEL_BASE_MATRIX; + unsigned long csa; + + /* Assign CS3 to NAND/SmartMedia Interface */ + csa = readl(&matrix->ebicsa); + csa |= AT91_MATRIX_EBI_CS3A_SMC_SMARTMEDIA; + /* Configure databus */ + csa &= ~AT91_MATRIX_NFD0_ON_D16; /* nandflash connect to D0~D15 */ + /* Configure IO drive */ + csa &= ~AT91_MATRIX_EBI_EBI_IOSR_NORMAL; + + writel(csa, &matrix->ebicsa); + + /* Configure SMC CS3 for NAND/SmartMedia */ + writel(AT91_SMC_SETUP_NWE(1) | AT91_SMC_SETUP_NCS_WR(0) | + AT91_SMC_SETUP_NRD(2) | AT91_SMC_SETUP_NCS_RD(0), + &smc->cs[3].setup); + writel(AT91_SMC_PULSE_NWE(3) | AT91_SMC_PULSE_NCS_WR(5) | + AT91_SMC_PULSE_NRD(4) | AT91_SMC_PULSE_NCS_RD(6), + &smc->cs[3].pulse); + writel(AT91_SMC_CYCLE_NWE(5) | AT91_SMC_CYCLE_NRD(7), + &smc->cs[3].cycle); + writel(AT91_SMC_MODE_RM_NRD | AT91_SMC_MODE_WM_NWE | + AT91_SMC_MODE_EXNW_DISABLE | +#ifdef CONFIG_SYS_NAND_DBW_16 + AT91_SMC_MODE_DBW_16 | +#else /* CONFIG_SYS_NAND_DBW_8 */ + AT91_SMC_MODE_DBW_8 | +#endif + AT91_SMC_MODE_TDF_CYCLE(1), + &smc->cs[3].mode); + + /* Configure RDY/BSY pin */ + at91_set_pio_input(AT91_PIO_PORTD, 5, 1); + + /* Configure ENABLE pin for NandFlash */ + at91_set_pio_output(AT91_PIO_PORTD, 4, 1); + + at91_set_a_periph(AT91_PIO_PORTD, 0, 1); /* NAND OE */ + at91_set_a_periph(AT91_PIO_PORTD, 1, 1); /* NAND WE */ + at91_set_a_periph(AT91_PIO_PORTD, 2, 1); /* ALE */ + at91_set_a_periph(AT91_PIO_PORTD, 3, 1); /* CLE */ +} +#endif + +#ifdef CONFIG_LCD +vidinfo_t panel_info = { + .vl_col = 480, + .vl_row = 272, + .vl_clk = 9000000, + .vl_bpix = LCD_BPP, + .vl_sync = 0, + .vl_tft = 1, + .vl_hsync_len = 5, + .vl_left_margin = 8, + .vl_right_margin = 43, + .vl_vsync_len = 10, + .vl_upper_margin = 4, + .vl_lower_margin = 12, + .mmio = ATMEL_BASE_LCDC, +}; + +void lcd_enable(void) +{ + at91_set_pio_output(AT91_PIO_PORTC, 25, 0); /* power up */ +} + +void lcd_disable(void) +{ + at91_set_pio_output(AT91_PIO_PORTC, 25, 1); /* power down */ +} + +#ifdef CONFIG_LCD_INFO +void lcd_show_board_info(void) +{ + ulong dram_size, nand_size; + int i; + char temp[32]; + + lcd_printf("%s\n", U_BOOT_VERSION); + lcd_printf("ATMEL Corp\n"); + lcd_printf("at91@atmel.com\n"); + lcd_printf("%s CPU at %s MHz\n", + ATMEL_CPU_NAME, + strmhz(temp, get_cpu_clk_rate())); + + dram_size = 0; + for (i = 0; i < CONFIG_NR_DRAM_BANKS; i++) + dram_size += gd->bd->bi_dram[i].size; + nand_size = 0; + for (i = 0; i < CONFIG_SYS_MAX_NAND_DEVICE; i++) + nand_size += nand_info[i].size; + lcd_printf(" %ld MB SDRAM, %ld MB NAND\n", + dram_size >> 20, + nand_size >> 20); +} +#endif /* CONFIG_LCD_INFO */ +#endif /* CONFIG_LCD */ + +/* SPI chip select control */ +#ifdef CONFIG_ATMEL_SPI +#include <spi.h> +int spi_cs_is_valid(unsigned int bus, unsigned int cs) +{ + return bus == 0 && cs < 2; +} + +void spi_cs_activate(struct spi_slave *slave) +{ + switch (slave->cs) { + case 0: + at91_set_pio_output(AT91_PIO_PORTA, 14, 0); + break; + case 1: + at91_set_pio_output(AT91_PIO_PORTA, 7, 0); + break; + } +} + +void spi_cs_deactivate(struct spi_slave *slave) +{ + switch (slave->cs) { + case 0: + at91_set_pio_output(AT91_PIO_PORTA, 14, 1); + break; + case 1: + at91_set_pio_output(AT91_PIO_PORTA, 7, 1); + break; + } +} +#endif /* CONFIG_ATMEL_SPI */ + +#ifdef CONFIG_GENERIC_ATMEL_MCI +int board_mmc_init(bd_t *bd) +{ + at91_mci_hw_init(); + + return atmel_mci_init((void *)ATMEL_BASE_HSMCI0); +} +#endif + +int board_early_init_f(void) +{ + /* Enable clocks for all PIOs */ + struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; + writel((1 << ATMEL_ID_PIOAB) | (1 << ATMEL_ID_PIOCD), &pmc->pcer); + + at91_seriald_hw_init(); + return 0; +} + +int board_init(void) +{ + /* adress of boot parameters */ + gd->bd->bi_boot_params = CONFIG_SYS_SDRAM_BASE + 0x100; + +#ifdef CONFIG_NAND_ATMEL + at91sam9n12ek_nand_hw_init(); +#endif + +#ifdef CONFIG_ATMEL_SPI + at91_spi0_hw_init(1 << 0); +#endif + +#ifdef CONFIG_LCD + at91_lcd_hw_init(); +#endif + + return 0; +} + +int dram_init(void) +{ + gd->ram_size = get_ram_size((void *)CONFIG_SYS_SDRAM_BASE, + CONFIG_SYS_SDRAM_SIZE); + return 0; +} diff --git a/boards.cfg b/boards.cfg index fdb32c2..5273c27 100644 --- a/boards.cfg +++ b/boards.cfg @@ -106,6 +106,9 @@ at91sam9x5ek_mmc arm arm926ejs at91sam9x5ek atmel at91sam9xeek_dataflash_cs0 arm arm926ejs at91sam9260ek atmel at91 at91sam9260ek:AT91SAM9XE,SYS_USE_DATAFLASH_CS0 at91sam9xeek_dataflash_cs1 arm arm926ejs at91sam9260ek atmel at91 at91sam9260ek:AT91SAM9XE,SYS_USE_DATAFLASH_CS1 at91sam9xeek_nandflash arm arm926ejs at91sam9260ek atmel at91 at91sam9260ek:AT91SAM9XE,SYS_USE_NANDFLASH +at91sam9n12ek_nandflash arm arm926ejs at91sam9n12ek atmel at91 at91sam9n12ek:AT91SAM9N12,SYS_USE_NANDFLASH +at91sam9n12ek_spiflash arm arm926ejs at91sam9n12ek atmel at91 at91sam9n12ek:AT91SAM9N12,SYS_USE_SPIFLASH +at91sam9n12ek_mmc arm arm926ejs at91sam9n12ek atmel at91 at91sam9n12ek:AT91SAM9N12,SYS_USE_MMC snapper9260 arm arm926ejs - bluewater at91 snapper9260:AT91SAM9260 snapper9g20 arm arm926ejs snapper9260 bluewater at91 snapper9260:AT91SAM9G20 vl_ma2sc arm arm926ejs vl_ma2sc BuS at91 diff --git a/include/configs/at91sam9n12ek.h b/include/configs/at91sam9n12ek.h new file mode 100644 index 0000000..8d2673d --- /dev/null +++ b/include/configs/at91sam9n12ek.h @@ -0,0 +1,232 @@ +/* + * (C) Copyright 2013 Atmel Corporation. + * Josh Wu josh.wu@atmel.com + * + * Configuation settings for the AT91SAM9N12-EK boards. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __AT91SAM9N12_CONFIG_H_ +#define __AT91SAM9N12_CONFIG_H_ + +/* + * SoC must be defined first, before hardware.h is included. + * In this case SoC is defined in boards.cfg. + */ +#include <asm/hardware.h> + +#define CONFIG_SYS_TEXT_BASE 0x26f00000 + +#define CONFIG_ARM926EJS +#define CONFIG_AT91FAMILY + +/* ARM asynchronous clock */ +#define CONFIG_SYS_AT91_SLOW_CLOCK 32768 /* slow clock xtal */ +#define CONFIG_SYS_AT91_MAIN_CLOCK 16000000 /* main clock xtal */ +#define CONFIG_SYS_HZ 1000 + +/* Misc CPU related */ +#define CONFIG_CMDLINE_TAG /* enable passing of ATAGs */ +#define CONFIG_SETUP_MEMORY_TAGS +#define CONFIG_INITRD_TAG +#define CONFIG_SKIP_LOWLEVEL_INIT +#define CONFIG_BOARD_EARLY_INIT_F +#define CONFIG_DISPLAY_CPUINFO + +#define CONFIG_OF_LIBFDT + +/* general purpose I/O */ +#define CONFIG_AT91_GPIO + +/* serial console */ +#define CONFIG_ATMEL_USART +#define CONFIG_USART_BASE ATMEL_BASE_DBGU +#define CONFIG_USART_ID ATMEL_ID_SYS +#define CONFIG_BAUDRATE 115200 + +/* LCD */ +#define CONFIG_LCD +#define LCD_BPP LCD_COLOR16 +#define LCD_OUTPUT_BPP 24 +#define CONFIG_LCD_LOGO +#define CONFIG_LCD_INFO +#define CONFIG_LCD_INFO_BELOW_LOGO +#define CONFIG_SYS_WHITE_ON_BLACK +#define CONFIG_ATMEL_HLCD +#define CONFIG_ATMEL_LCD_RGB565 +#define CONFIG_SYS_CONSOLE_IS_IN_ENV + +#define CONFIG_BOOTDELAY 3 + +/* + * BOOTP options + */ +#define CONFIG_BOOTP_BOOTFILESIZE +#define CONFIG_BOOTP_BOOTPATH +#define CONFIG_BOOTP_GATEWAY +#define CONFIG_BOOTP_HOSTNAME + +/* NOR flash - no real flash on this board */ +#define CONFIG_SYS_NO_FLASH + +/* + * Command line configuration. + */ +#include <config_cmd_default.h> +#undef CONFIG_CMD_FPGA + +#define CONFIG_CMD_BOOTZ +#define CONFIG_CMD_PING +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_NAND +#define CONFIG_CMD_SF +#define CONFIG_CMD_MMC +#define CONFIG_CMD_FAT + +#define CONFIG_NR_DRAM_BANKS 1 +#define CONFIG_SYS_SDRAM_BASE 0x20000000 +#define CONFIG_SYS_SDRAM_SIZE 0x08000000 + +/* + * Initial stack pointer: 4k - GENERATED_GBL_DATA_SIZE in internal SRAM, + * leaving the correct space for initial global data structure above + * that address while providing maximum stack area below. + */ +# define CONFIG_SYS_INIT_SP_ADDR \ + (ATMEL_BASE_SRAM + 0x1000 - GENERATED_GBL_DATA_SIZE) + +/* DataFlash */ +#ifdef CONFIG_CMD_SF +#define CONFIG_ATMEL_SPI +#define CONFIG_SPI_FLASH +#define CONFIG_SPI_FLASH_ATMEL +#define CONFIG_SF_DEFAULT_SPEED 30000000 +#define CONFIG_ENV_SPI_MODE SPI_MODE_3 +#define CONFIG_SF_DEFAULT_MODE SPI_MODE_3 +#endif + +/* NAND flash */ +#ifdef CONFIG_CMD_NAND +#define CONFIG_NAND_ATMEL +#define CONFIG_SYS_MAX_NAND_DEVICE 1 +#define CONFIG_SYS_NAND_BASE 0x40000000 +#define CONFIG_SYS_NAND_MASK_ALE (1 << 21) +#define CONFIG_SYS_NAND_MASK_CLE (1 << 22) +#define CONFIG_SYS_NAND_ENABLE_PIN AT91_PIO_PORTD, 4 +#define CONFIG_SYS_NAND_READY_PIN AT91_PIO_PORTD, 5 + +/* PMECC & PMERRLOC */ +#define CONFIG_ATMEL_NAND_HWECC +#define CONFIG_ATMEL_NAND_HW_PMECC +#define CONFIG_PMECC_CAP 2 +#define CONFIG_PMECC_SECTOR_SIZE 512 +#define CONFIG_PMECC_INDEX_TABLE_OFFSET 0x8000 +#endif + +#define CONFIG_MTD_PARTITIONS +#define CONFIG_MTD_DEVICE +#define CONFIG_CMD_MTDPARTS +#define MTDIDS_DEFAULT "nand0=atmel_nand" +#define MTDPARTS_DEFAULT \ + "mtdparts=atmel_nand:256k(bootstrap)ro,512k(uboot)ro," \ + "256k(env),256k(env_redundant),256k(spare)," \ + "512k(dtb),6M(kernel)ro,-(rootfs)" + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "console=console=ttyS0,115200\0" \ + "mtdparts="MTDPARTS_DEFAULT"\0" \ + "bootargs_nand=rootfstype=ubifs ubi.mtd=7 root=ubi0:rootfs rw\0"\ + "bootargs_mmc=root=/dev/mmcblk0p2 rw rootfstype=ext4 rootwait\0" + +/* MMC */ +#ifdef CONFIG_CMD_MMC +#define CONFIG_MMC +#define CONFIG_GENERIC_MMC +#define CONFIG_GENERIC_ATMEL_MCI +#endif + +/* FAT */ +#ifdef CONFIG_CMD_FAT +#define CONFIG_DOS_PARTITION +#endif + +#define CONFIG_SYS_LOAD_ADDR 0x22000000 /* load address */ + +#define CONFIG_SYS_MEMTEST_START CONFIG_SYS_SDRAM_BASE +#define CONFIG_SYS_MEMTEST_END 0x26e00000 + +#ifdef CONFIG_SYS_USE_SPIFLASH + +/* bootstrap + u-boot + env + linux in dataflash on CS0 */ +#define CONFIG_ENV_IS_IN_SPI_FLASH +#define CONFIG_ENV_OFFSET 0x5000 +#define CONFIG_ENV_SIZE 0x3000 +#define CONFIG_ENV_SECT_SIZE 0x1000 +#define CONFIG_BOOTCOMMAND \ + "setenv bootargs ${console} ${mtdparts} ${bootargs_nand};" \ + "sf probe 0; sf read 0x22000000 0x100000 0x300000; " \ + "bootm 0x22000000" + +#elif defined(CONFIG_SYS_USE_NANDFLASH) + +/* bootstrap + u-boot + env + linux in nandflash */ +#define CONFIG_ENV_IS_IN_NAND +#define CONFIG_ENV_OFFSET 0xc0000 +#define CONFIG_ENV_OFFSET_REDUND 0x100000 +#define CONFIG_ENV_SIZE 0x20000 /* 1 sector = 128 kB */ +#define CONFIG_BOOTCOMMAND \ + "setenv bootargs ${console} ${mtdparts} ${bootargs_nand};" \ + "nand read 0x21000000 0x180000 0x080000;" \ + "nand read 0x22000000 0x200000 0x400000;" \ + "bootm 0x22000000 - 0x21000000" + +#else /* CONFIG_SYS_USE_MMC */ + +/* bootstrap + u-boot + env + linux in mmc */ +#define CONFIG_ENV_IS_IN_MMC +/* For FAT system, most cases it should be in the reserved sector */ +#define CONFIG_ENV_OFFSET 0x2000 +#define CONFIG_ENV_SIZE 0x1000 +#define CONFIG_SYS_MMC_ENV_DEV 0 +#define CONFIG_BOOTCOMMAND \ + "setenv bootargs ${console} ${mtdparts} ${bootargs_mmc};" \ + "fatload mmc 0:1 0x21000000 dtb;" \ + "fatload mmc 0:1 0x22000000 uImage;" \ + "bootm 0x22000000 - 0x21000000" + +#endif + +#define CONFIG_SYS_PROMPT "U-Boot> " +#define CONFIG_SYS_CBSIZE 256 +#define CONFIG_SYS_MAXARGS 16 +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) \ + + 16) +#define CONFIG_SYS_LONGHELP +#define CONFIG_CMDLINE_EDITING +#define CONFIG_AUTO_COMPLETE +#define CONFIG_SYS_HUSH_PARSER + +/* + * Size of malloc() pool + */ +#define CONFIG_SYS_MALLOC_LEN (4 * 1024 * 1024) +#define CONFIG_STACKSIZE (32 * 1024) /* regular stack */ + +#endif
Hi Josh, minor comment as following.
- SPI flash boot
- SD card boot
- LCD support
[snip]
- at91_set_a_periph(AT91_PIO_PORTC, 13, 0); /* LCDD13 */
- at91_set_a_periph(AT91_PIO_PORTC, 21, 0); /* LCDD21 */
- at91_set_a_periph(AT91_PIO_PORTC, 22, 0); /* LCDD22 */
- at91_set_a_periph(AT91_PIO_PORTC, 23, 0); /* LCDD23 */
- writel(1 << ATMEL_ID_LCDC, &pmc->pcer);
+} +#endif
when apply this patch, it will show following warning:
.git/rebase-apply/patch:225: new blank line at EOF. + warning: 1 line adds whitespace errors.
Best Regards, Bo Shen
Hi, Shen Bo
- SPI flash boot
- SD card boot
- LCD support
[snip]
+} +#endif
ok, I will fix the blank line in v3. thanks.
Dear Josh Wu,
you'd better used v3 for this patch. It is easier to dsitinguish the patches than and it is allowed to send a single patch in a series in a newer version. You could use patman to manage your patches. I have to confess that I never used it, but I should have a look for it.
- SPI flash boot
- SD card boot
- LCD support
<snip>
/* plla divisor by 2 */ gd->arch.plla_rate_hz /= (1 << ((mckr & 1 << 12) >> 12));|| defined(CONFIG_AT91SAM9N12) || defined(CONFIG_AT91SAM9X5)
Can you please re-arrange the patches here and add the 'at91: clock: remove chip macro for plla_div2' before this patch. So we wouldn't need to add the macro here and remove it in the next patch.
<snip>
Rest looks good to me.
Best regards
Andreas Bießmann
at91sam9x5, at91sam9n12, at91sam9g45/m10g45 has plla div2 bits. For other at91 arm926ejs chips, this plla div2 bits (bit-12 in mckr) is reserved and default value after reset is 0. So we can handle all the chip in a same way.
now we can simply remove the chip select macro.
This patch also changes the div2 code to a more readable format.
Signed-off-by: Josh Wu josh.wu@atmel.com --- arch/arm/cpu/arm926ejs/at91/clock.c | 11 ++++++----- 1 file changed, 6 insertions(+), 5 deletions(-)
diff --git a/arch/arm/cpu/arm926ejs/at91/clock.c b/arch/arm/cpu/arm926ejs/at91/clock.c index 5b4923f..cc28896 100644 --- a/arch/arm/cpu/arm926ejs/at91/clock.c +++ b/arch/arm/cpu/arm926ejs/at91/clock.c @@ -155,11 +155,12 @@ int at91_clock_init(unsigned long main_clock) * For now, assume this parentage won't change. */ mckr = readl(&pmc->mckr); -#if defined(CONFIG_AT91SAM9G45) || defined(CONFIG_AT91SAM9M10G45) \ - || defined(CONFIG_AT91SAM9N12) || defined(CONFIG_AT91SAM9X5) - /* plla divisor by 2 */ - gd->arch.plla_rate_hz /= (1 << ((mckr & 1 << 12) >> 12)); -#endif + + /* plla divisor by 2, Only for AT91SAM9G45, 9M10G45, 9X5, 9N12 */ + /* For other AT91 chip, the bit 12 of MCKR is reserved, default is 0 */ + if (mckr & (1 << 12)) + gd->arch.plla_rate_hz >>= 1; + gd->arch.mck_rate_hz = at91_css_to_rate(mckr & AT91_PMC_MCKR_CSS_MASK); freq = gd->arch.mck_rate_hz;
Andreas Bießmann
Bo Shen
Josh Wu
