[U-Boot] [PATCH] spi: ftssp010_spi: Simplify code flow in ftssp010_[wait|wait_tx|wait_rx]
No functional change, just simplify the code a bit.
Signed-off-by: Axel Lin axel.lin@ingics.com --- drivers/spi/ftssp010_spi.c | 36 ++++++++++++------------------------ 1 file changed, 12 insertions(+), 24 deletions(-)
diff --git a/drivers/spi/ftssp010_spi.c b/drivers/spi/ftssp010_spi.c index aa3b5a0..267e4d8 100644 --- a/drivers/spi/ftssp010_spi.c +++ b/drivers/spi/ftssp010_spi.c @@ -169,61 +169,49 @@ static int get_spi_gpio(int bus, struct ftssp010_gpio *chip) static int ftssp010_wait(struct ftssp010_spi *chip) { struct ftssp010_regs *regs = chip->regs; - int ret = -1; ulong t;
/* wait until device idle */ for (t = get_timer(0); get_timer(t) < CONFIG_FTSSP010_TIMEOUT; ) { - if (readl(®s->sr) & SR_BUSY) - continue; - ret = 0; - break; + if (!(readl(®s->sr) & SR_BUSY)) + return 0; }
- if (ret) - puts("ftspi010: busy timeout\n"); + puts("ftspi010: busy timeout\n");
- return ret; + return -1; }
static int ftssp010_wait_tx(struct ftssp010_spi *chip) { struct ftssp010_regs *regs = chip->regs; - int ret = -1; ulong t;
/* wait until tx fifo not full */ for (t = get_timer(0); get_timer(t) < CONFIG_FTSSP010_TIMEOUT; ) { - if (!(readl(®s->sr) & SR_TFNF)) - continue; - ret = 0; - break; + if (readl(®s->sr) & SR_TFNF) + return 0; }
- if (ret) - puts("ftssp010: tx timeout\n"); + puts("ftssp010: tx timeout\n");
static int ftssp010_wait_rx(struct ftssp010_spi *chip) { struct ftssp010_regs *regs = chip->regs; - int ret = -1; ulong t;
/* wait until rx fifo not empty */ for (t = get_timer(0); get_timer(t) < CONFIG_FTSSP010_TIMEOUT; ) { - if (!SR_RFVE(readl(®s->sr))) - continue; - ret = 0; - break; + if (SR_RFVE(readl(®s->sr))) + return 0; }
- if (ret) - puts("ftssp010: rx timeout\n"); + puts("ftssp010: rx timeout\n");
static int ftssp010_spi_work_transfer_v2(struct ftssp010_spi *chip,
int ret = -1; ulong t; /* wait until device idle */ for (t = get_timer(0); get_timer(t) < CONFIG_FTSSP010_TIMEOUT; ) {
continue;
ret = 0;
break;
return 0; }
if (ret)
return ret;
return -1;
int ret = -1; ulong t; /* wait until tx fifo not full */ for (t = get_timer(0); get_timer(t) < CONFIG_FTSSP010_TIMEOUT; ) {
continue;
ret = 0;
break;
return 0; }
if (ret)
return ret;
return -1;
int ret = -1; ulong t; /* wait until rx fifo not empty */ for (t = get_timer(0); get_timer(t) < CONFIG_FTSSP010_TIMEOUT; ) {
continue;
ret = 0;
break;
return 0; }
if (ret)
return ret;
return -1;
1.9.1
Applied to u-boot-spi/master
thanks!
Axel Lin
Jagan Teki
