[U-Boot] [PATCH] mx53: Make PLL2 to be the parent of UART clock
Change the parent UART clock to be PLL2, so that U-boot can also boot a Freescale 2.6.35 kernel for mx53.
FSL kernel and U-boot changed the UART parent from PLL3 to PLL2 to avoid conflicts with IPU clocks, so that the video resolution can be changed without affecting the UART clock.
On a 2.6.35 kernel the serial console is messed up after IPU driver is loaded and this patch fixes this problem.
Tested on a mx53loco board booting a FSL kernel and also a mainline kernel.
Reported-by: Otavio Salvador otavio@ossystems.com.br Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- arch/arm/cpu/armv7/mx5/lowlevel_init.S | 20 +++++++++++++++++--- 1 files changed, 17 insertions(+), 3 deletions(-)
diff --git a/arch/arm/cpu/armv7/mx5/lowlevel_init.S b/arch/arm/cpu/armv7/mx5/lowlevel_init.S index 01f6d75..90c6ec1 100644 --- a/arch/arm/cpu/armv7/mx5/lowlevel_init.S +++ b/arch/arm/cpu/armv7/mx5/lowlevel_init.S @@ -284,10 +284,24 @@ ldr r1, =0x00C30321 str r1, [r0, #CLKCTL_CSCDR1] #elif defined(CONFIG_MX53) + /* Switch peripheral to PLL2 */ + ldr r0, =CCM_BASE_ADDR + ldr r1, =0x00808145 + orr r1, r1, #(2 << 10) + orr r1, r1, #(0 << 16) + orr r1, r1, #(1 << 19) + str r1, [r0, #CLKCTL_CBCDR] + + ldr r1, =0x00016154 + str r1, [r0, #CLKCTL_CBCMR] + /* Change uart clk parent to pll2*/ + ldr r1, [r0, #CLKCTL_CSCMR1] + and r1, r1, #0xfcffffff + orr r1, r1, #0x01000000 + str r1, [r0, #CLKCTL_CSCMR1] ldr r1, [r0, #CLKCTL_CSCDR1] - orr r1, r1, #0x3f - eor r1, r1, #0x3f - orr r1, r1, #0x21 + and r1, r1, #0xffffffc0 + orr r1, r1, #0x0a str r1, [r0, #CLKCTL_CSCDR1] #endif /* make sure divider effective */
On Wed, Mar 21, 2012 at 12:42, Fabio Estevam festevam@gmail.com wrote: ...
I tested it on my imx53qsb and it does fix the issue.
Acked-by: Otavio Salvador otavio@ossystems.com.br
Applied to u-boot-imx, thanks.
Best regards, Stefano Babic
Fabio Estevam
Otavio Salvador
Stefano Babic
