Re: [U-Boot-Users] Re: [PATCH] Spartan3 family support
Hello,
Thanks for the file!
you're welcome.
What the problem with the loadb command ?
IIRC loadb did not parse the header correctly.
and what is the difference between the loadb and load ?
loadb gets a .bit file while load gets a .bin file. .bin file is the pure bitstream while .bit = <header> + .bin. The header provides information about bitstream name, creation date etc.
llandre
DAVE Electronics System House - R&D Department web: http://www.dave-tech.it email: r&d2@dave-tech.it
----- Original Message ----- From: "llandre" r&d2@dave-tech.it To: "Nicolas Colombain" nicolas.colombain@laposte.net Cc: u-boot-users@lists.sourceforge.net Sent: Thursday, June 30, 2005 9:49 AM Subject: Re: [U-Boot-Users] Re: [PATCH] Spartan3 family support
Hi Nicolas,
I used the patch provided by Kurt Stremerch (see attached file). However I was not able to make the "fpga loadb" command to work while "fpga load" works fine. Then I applied the patch posted by Andrew Dyer to the mailing list but loadb still did not work (for me this is not a problem).
HTH, llandre
Hi Ilandre and Kurt,
I need to download my Spartan 3 by using uboot and I was wondering if someone had already written something for that. I found your mails but unfortunately not the patch. :( This patch will be added to the next uboot version ?? Where can I find it
Thanks in advance.
llandre
