[PATCH] efi_loader: Allow capsule update on-disk without checking OsIndications
Although U-Boot supports capsule update on-disk, it's lack of support for SetVariable at runtime prevents applications like fwupd from using it.
In order to perform the capsule update on-disk the spec says that the OS must copy the capsule to the \EFI\UpdateCapsule directory and set a bit in the OsIndications variable. The firmware then checks for the EFI_OS_INDICATIONS_FILE_CAPSULE_DELIVERY_SUPPORTED bit in OsIndications variable, which is set by submitter to trigger processing of the capsule on next reboot.
Let's add a config option which ignores the bit checking in OsIndications and just rely on the capsule being present. Since U-Boot deletes the capsule while processing it, we won't end up running it multiple times.
Note that this is allowed for all capsules. In the future once, authenticated capsules is fully supported, we can limit the functionality to those only.
Signed-off-by: apalos ilias.apalodimas@linaro.org --- lib/efi_loader/Kconfig | 9 +++++++++ lib/efi_loader/efi_capsule.c | 36 ++++++++++++++++++++++++++++-------- 2 files changed, 37 insertions(+), 8 deletions(-)
diff --git a/lib/efi_loader/Kconfig b/lib/efi_loader/Kconfig index 684adfb62379..5a3820e76122 100644 --- a/lib/efi_loader/Kconfig +++ b/lib/efi_loader/Kconfig @@ -137,6 +137,15 @@ config EFI_CAPSULE_ON_DISK under a specific directory on UEFI system partition instead of via UpdateCapsule API.
+config EFI_IGNORE_OSINDICATIONS + bool "Ignore OsIndications for CapsuleUpdate on-disk" + depends on EFI_CAPSULE_ON_DISK + default n + help + There are boards were we can't support SetVariable at runtime. + Select this option if you want to use capsule-on-disk feature, + without setting the OsIndications bit. + config EFI_CAPSULE_ON_DISK_EARLY bool "Initiate capsule-on-disk at U-Boot boottime" depends on EFI_CAPSULE_ON_DISK diff --git a/lib/efi_loader/efi_capsule.c b/lib/efi_loader/efi_capsule.c index d7136035d8f9..50bed32bfb3b 100644 --- a/lib/efi_loader/efi_capsule.c +++ b/lib/efi_loader/efi_capsule.c @@ -948,6 +948,33 @@ efi_status_t __weak efi_load_capsule_drivers(void) return ret; }
+/** + * check_run_capsules - Check whether capsule update should run + * + * The spec says OsIndications must be set in order to run the capsule update + * on-disk. Since U-Boot doesn't support runtime SetVariable, allow capsules to + * run explicitly if CONFIG_EFI_IGNORE_OSINDICATIONS is selected + */ +static bool check_run_capsules(void) +{ + u64 os_indications; + efi_uintn_t size; + efi_status_t ret; + + if (IS_ENABLED(CONFIG_EFI_IGNORE_OSINDICATIONS)) + return true; + + size = sizeof(os_indications); + ret = efi_get_variable_int(L"OsIndications", &efi_global_variable_guid, + NULL, &size, &os_indications, NULL); + if (ret == EFI_SUCCESS && + (os_indications + & EFI_OS_INDICATIONS_FILE_CAPSULE_DELIVERY_SUPPORTED)) + return true; + + return false; +} + /** * efi_launch_capsule - launch capsules * @@ -958,20 +985,13 @@ efi_status_t __weak efi_load_capsule_drivers(void) */ efi_status_t efi_launch_capsules(void) { - u64 os_indications; - efi_uintn_t size; struct efi_capsule_header *capsule = NULL; u16 **files; unsigned int nfiles, index, i; u16 variable_name16[12]; efi_status_t ret;
- size = sizeof(os_indications); - ret = efi_get_variable_int(L"OsIndications", &efi_global_variable_guid, - NULL, &size, &os_indications, NULL); - if (ret != EFI_SUCCESS || - !(os_indications - & EFI_OS_INDICATIONS_FILE_CAPSULE_DELIVERY_SUPPORTED)) + if (!check_run_capsules()) return EFI_SUCCESS;
index = get_last_capsule();
- bool "Ignore OsIndications for CapsuleUpdate on-disk"
- depends on EFI_CAPSULE_ON_DISK
- default n
- help
- config EFI_CAPSULE_ON_DISK_EARLY bool "Initiate capsule-on-disk at U-Boot boottime" depends on EFI_CAPSULE_ON_DISK
- check_run_capsules - Check whether capsule update should run
- The spec says OsIndications must be set in order to run the capsule update
- on-disk. Since U-Boot doesn't support runtime SetVariable, allow capsules to
- run explicitly if CONFIG_EFI_IGNORE_OSINDICATIONS is selected
- efi_uintn_t size;
- efi_status_t ret;
- if (IS_ENABLED(CONFIG_EFI_IGNORE_OSINDICATIONS))
return true;
- if (ret == EFI_SUCCESS &&
(os_indications
The bit EFI_OS_INDICATIONS_FILE_CAPSULE_DELIVERY_SUPPORTED must be cleared in OsIndications after successfully applying the capsule. See related patch
[PATCH 1/1] efi_loader: fix set_capsule_result() https://lists.denx.de/pipermail/u-boot/2021-June/453111.html
Reviewed-by: Heinrich Schuchardt xypron.glpk@gmx.de
return true;
- return false;
- efi_launch_capsule - launch capsules
u64 os_indications;
!(os_indications
return true;
(os_indications
Yea I noticed that as well while I was coding this and meant to sent a patch afterwards. You've already done that,so let me go have a look!
return true;
- return false;
u64 os_indications;
!(os_indications
- default n
- help
Obviously, this option breaks the conformance to UEFI specification and must be turned on carefully in the limited use cases. You should describe that here explicitly.
Additionally, you may add depends on !EFI_MM_COMM_TEE (or better config?)
-Takahiro Akashi
- efi_uintn_t size;
- efi_status_t ret;
return true;
(os_indications
return true;
- return false;
u64 os_indications;
!(os_indications
- default n
- help
Fair enough, I'll send a v2
That's not the case (yet). I do have a kernel branch were SetVariable at runtime is supported, but that's not merged yet. So until this gets accepted *all* the boards that want to perform a capsuleupdate on-disk without setting the variable need this.
Cheers /Ilias
-Takahiro Akashi
- efi_uintn_t size;
- efi_status_t ret;
return true;
(os_indications
return true;
- return false;
u64 os_indications;
!(os_indications
- default n
- help
If so, I would suggest that another Kconfig option be added for the availability of SetVariable at runtime.
This will allow us to keep "depends on" unchanged even if yet another implementation of SetVariable is introduced in the future.
-Takahiro Akashi
Cheers /Ilias
-Takahiro Akashi
- efi_uintn_t size;
- efi_status_t ret;
return true;
(os_indications
return true;
- return false;
u64 os_indications;
!(os_indications
On Tue, 29 Jun 2021 at 16:04, AKASHI Takahiro takahiro.akashi@linaro.org wrote:
default n
help
Let's not fill in so many Kconfig options for now. We might need to do that in the future, but on the other hand, I would much prefer checking the RTPROP which has that info.
-Takahiro Akashi
Cheers /Ilias
-Takahiro Akashi
u64 os_indications;
efi_uintn_t size;
efi_status_t ret;
return true;
(os_indications
return true;
return false;
u64 os_indications;
!(os_indications
if (!check_run_capsules()) return EFI_SUCCESS; index = get_last_capsule();
AKASHI Takahiro
Ilias Apalodimas
