[PATCH v2] dm: core: fix no null pointer detection in ofnode_get_addr_size_index()
Fixed a defect of a null pointer being discovered by Coverity Scan: CID 331544: Null pointer dereferences (REVERSE_INULL) Null-checking "size" suggests that it may be null, but it has already been dereferenced on all paths leading to the check.
Signed-off-by: Chen Guanqiao chenguanqiao@kuaishou.com --- drivers/core/ofnode.c | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/drivers/core/ofnode.c b/drivers/core/ofnode.c index eeeccfb446..dda6c76e83 100644 --- a/drivers/core/ofnode.c +++ b/drivers/core/ofnode.c @@ -329,7 +329,8 @@ static fdt_addr_t __ofnode_get_addr_size_index(ofnode node, int index, { int na, ns;
- *size = FDT_SIZE_T_NONE; + if (size) + *size = FDT_SIZE_T_NONE;
if (ofnode_is_np(node)) { const __be32 *prop_val; @@ -340,6 +341,7 @@ static fdt_addr_t __ofnode_get_addr_size_index(ofnode node, int index, &flags); if (!prop_val) return FDT_ADDR_T_NONE; + if (size) *size = size64;
@@ -359,8 +361,6 @@ static fdt_addr_t __ofnode_get_addr_size_index(ofnode node, int index, index, na, ns, size, translate); } - - return FDT_ADDR_T_NONE; }
fdt_addr_t ofnode_get_addr_size_index(ofnode node, int index, fdt_size_t *size)
Hi Chenguanqiao,
This is a v2 but does not have a change log.
chenguanqiao
