[U-Boot] [PATCH v2 0/9] arm: ls1021atwr: Convert to driver model and enable serial support
This series converts Freescale LS1021A-TWR board to driver model. - Enable ns16550 serial driver on ls1021atwr_nor configuration - Convert LPUART serial driver to driver model - Enable LPUART serial driver on ls1021atwr_nor_lpuart configuration
Changes in v2: - Rewrite the commit message using 'git revert' format. - Add missing 'base' parameter in the call to _lpuart_serial_tstc() - Change internal routines' parameter 'reg' to 'base' - Split to use two separate U_BOOT_DRIVER() - New patch to split off board device tree - Create a ls1021a-twr-lpuart.dts for ls1021atwr_nor_lpuart_defconfig
Bin Meng (9): Revert "fdt_support: Add multi-serial support for stdout fixup" arm: ls1021atwr: Convert to driver model and enable serial support serial: lpuart: Move CONFIG_FSL_LPUART to Kconfig serial: lpuart: Fix several cosmetic issues serial: lpuart: Call local version of setbrg and putc directly serial: lpuart: Prepare the driver for DM conversion serial: lpuart: Add driver model serial support arm: ls1021atwr: Split off board device tree arm: ls1021atwr: Enable driver model lpuart serial driver
arch/arm/dts/Makefile | 2 +- arch/arm/dts/ls1021a-twr-duart.dts | 16 ++ arch/arm/dts/ls1021a-twr-lpuart.dts | 16 ++ arch/arm/dts/{ls1021a-twr.dts => ls1021a-twr.dtsi} | 7 +- arch/arm/dts/ls1021a.dtsi | 4 - common/fdt_support.c | 16 +- configs/colibri_vf_defconfig | 1 + configs/colibri_vf_dtb_defconfig | 1 + configs/ls1021aqds_ddr4_nor_lpuart_defconfig | 1 + configs/ls1021aqds_nor_lpuart_defconfig | 1 + configs/ls1021atwr_nor_defconfig | 4 + configs/ls1021atwr_nor_lpuart_defconfig | 5 + configs/ls1021atwr_qspi_defconfig | 2 +- configs/ls1021atwr_sdcard_qspi_defconfig | 2 +- configs/pcm052_defconfig | 1 + configs/vf610twr_defconfig | 1 + configs/vf610twr_nand_defconfig | 1 + doc/driver-model/serial-howto.txt | 1 - drivers/serial/Kconfig | 6 + drivers/serial/serial_lpuart.c | 286 ++++++++++++++++++--- include/configs/colibri_vf.h | 1 - include/configs/ls1021aqds.h | 1 - include/configs/ls1021atwr.h | 3 +- include/configs/pcm052.h | 1 - include/configs/vf610twr.h | 1 - 25 files changed, 311 insertions(+), 70 deletions(-) create mode 100644 arch/arm/dts/ls1021a-twr-duart.dts create mode 100644 arch/arm/dts/ls1021a-twr-lpuart.dts rename arch/arm/dts/{ls1021a-twr.dts => ls1021a-twr.dtsi} (93%)
This reverts commit 3e303f748cf57fb23e8ec95ab7eac0074be50e2b.
The fix up in the /aliases node does not work under the following scenarios: - Not every non-DM serial driver was written to have a driver name that conforms the format of "serial%d" or "eserial%d". - With driver model serial, the stdio_devices[] stores the serial device node name in the device tree.
Signed-off-by: Bin Meng bmeng.cn@gmail.com
common/fdt_support.c | 16 +--------------- 1 file changed, 1 insertion(+), 15 deletions(-)
diff --git a/common/fdt_support.c b/common/fdt_support.c index a539389..4e0d07c 100644 --- a/common/fdt_support.c +++ b/common/fdt_support.c @@ -131,18 +131,6 @@ static int fdt_fixup_stdout(void *fdt, int chosenoff) OF_STDOUT_PATH, strlen(OF_STDOUT_PATH) + 1); } #elif defined(CONFIG_OF_STDOUT_VIA_ALIAS) && defined(CONFIG_CONS_INDEX) -static void fdt_fill_multisername(char *sername, size_t maxlen) -{ - const char *outname = stdio_devices[stdout]->name; - - if (strcmp(outname, "serial") > 0) - strncpy(sername, outname, maxlen); - - /* eserial? */ - if (strcmp(outname + 1, "serial") > 0) - strncpy(sername, outname + 1, maxlen); -} - static int fdt_fixup_stdout(void *fdt, int chosenoff) { int err; @@ -152,9 +140,7 @@ static int fdt_fixup_stdout(void *fdt, int chosenoff) int len; char tmp[256]; /* long enough */
- fdt_fill_multisername(sername, sizeof(sername) - 1); - if (!sername[0]) - sprintf(sername, "serial%d", CONFIG_CONS_INDEX - 1); + sprintf(sername, "serial%d", CONFIG_CONS_INDEX - 1);
aliasoff = fdt_path_offset(fdt, "/aliases"); if (aliasoff < 0) {
Changes in v2:
Changes in v2:
Applied to u-boot-dm, thanks!
Convert ls1021atwr_nor to driver model support. As a start, enable ns16550 serial port driver.
Signed-off-by: Bin Meng bmeng.cn@gmail.com ---
Changes in v2: None
arch/arm/dts/ls1021a-twr.dts | 4 ++++ arch/arm/dts/ls1021a.dtsi | 4 ---- configs/ls1021atwr_nor_defconfig | 4 ++++ include/configs/ls1021atwr.h | 2 ++ 4 files changed, 10 insertions(+), 4 deletions(-)
diff --git a/arch/arm/dts/ls1021a-twr.dts b/arch/arm/dts/ls1021a-twr.dts index 6ccd332..aead13f 100644 --- a/arch/arm/dts/ls1021a-twr.dts +++ b/arch/arm/dts/ls1021a-twr.dts @@ -19,6 +19,10 @@ spi0 = &qspi; spi1 = &dspi1; }; + + chosen { + stdout-path = &uart0; + }; };
&qspi { diff --git a/arch/arm/dts/ls1021a.dtsi b/arch/arm/dts/ls1021a.dtsi index 7fadd7c..ee0e554 100644 --- a/arch/arm/dts/ls1021a.dtsi +++ b/arch/arm/dts/ls1021a.dtsi @@ -218,7 +218,6 @@ compatible = "fsl,16550-FIFO64", "ns16550a"; reg = <0x21c0500 0x100>; interrupts = <GIC_SPI 86 IRQ_TYPE_LEVEL_HIGH>; - clock-frequency = <0>; fifo-size = <15>; status = "disabled"; }; @@ -227,7 +226,6 @@ compatible = "fsl,16550-FIFO64", "ns16550a"; reg = <0x21c0600 0x100>; interrupts = <GIC_SPI 86 IRQ_TYPE_LEVEL_HIGH>; - clock-frequency = <0>; fifo-size = <15>; status = "disabled"; }; @@ -236,7 +234,6 @@ compatible = "fsl,16550-FIFO64", "ns16550a"; reg = <0x21d0500 0x100>; interrupts = <GIC_SPI 87 IRQ_TYPE_LEVEL_HIGH>; - clock-frequency = <0>; fifo-size = <15>; status = "disabled"; }; @@ -245,7 +242,6 @@ compatible = "fsl,16550-FIFO64", "ns16550a"; reg = <0x21d0600 0x100>; interrupts = <GIC_SPI 87 IRQ_TYPE_LEVEL_HIGH>; - clock-frequency = <0>; fifo-size = <15>; status = "disabled"; }; diff --git a/configs/ls1021atwr_nor_defconfig b/configs/ls1021atwr_nor_defconfig index aa874fd..2b79443 100644 --- a/configs/ls1021atwr_nor_defconfig +++ b/configs/ls1021atwr_nor_defconfig @@ -1,6 +1,10 @@ CONFIG_ARM=y CONFIG_TARGET_LS1021ATWR=y +CONFIG_DM_SERIAL=y +CONFIG_DEFAULT_DEVICE_TREE="ls1021a-twr" # CONFIG_CMD_SETEXPR is not set +CONFIG_OF_CONTROL=y +CONFIG_DM=y CONFIG_NETDEVICES=y CONFIG_E1000=y CONFIG_SYS_NS16550=y diff --git a/include/configs/ls1021atwr.h b/include/configs/ls1021atwr.h index c12ba3a..bbef2a7 100644 --- a/include/configs/ls1021atwr.h +++ b/include/configs/ls1021atwr.h @@ -271,7 +271,9 @@ #else #define CONFIG_CONS_INDEX 1 #define CONFIG_SYS_NS16550_SERIAL +#ifndef CONFIG_DM_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1 +#endif #define CONFIG_SYS_NS16550_CLK get_serial_clock() #endif
Changes in v2: None
Changes in v2: None
LPUART is seen on Freescale VF610 and QorIQ Layerscape devices. Create a Kconfig option and move it to defconfig for all boards that have this serial driver.
Signed-off-by: Bin Meng bmeng.cn@gmail.com Reviewed-by: Simon Glass sjg@chromium.org ---
Changes in v2: None
configs/colibri_vf_defconfig | 1 + configs/colibri_vf_dtb_defconfig | 1 + configs/ls1021aqds_ddr4_nor_lpuart_defconfig | 1 + configs/ls1021aqds_nor_lpuart_defconfig | 1 + configs/ls1021atwr_nor_lpuart_defconfig | 1 + configs/pcm052_defconfig | 1 + configs/vf610twr_defconfig | 1 + configs/vf610twr_nand_defconfig | 1 + drivers/serial/Kconfig | 6 ++++++ include/configs/colibri_vf.h | 1 - include/configs/ls1021aqds.h | 1 - include/configs/ls1021atwr.h | 1 - include/configs/pcm052.h | 1 - include/configs/vf610twr.h | 1 - 14 files changed, 14 insertions(+), 5 deletions(-)
diff --git a/configs/colibri_vf_defconfig b/configs/colibri_vf_defconfig index f8441e3..45917c8 100644 --- a/configs/colibri_vf_defconfig +++ b/configs/colibri_vf_defconfig @@ -8,3 +8,4 @@ CONFIG_CMD_GPIO=y CONFIG_DM=y CONFIG_NAND_VF610_NFC=y CONFIG_SYS_NAND_VF610_NFC_60_ECC_BYTES=y +CONFIG_FSL_LPUART=y diff --git a/configs/colibri_vf_dtb_defconfig b/configs/colibri_vf_dtb_defconfig index 3596cec..b1a843a 100644 --- a/configs/colibri_vf_dtb_defconfig +++ b/configs/colibri_vf_dtb_defconfig @@ -11,3 +11,4 @@ CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_NAND_VF610_NFC=y CONFIG_SYS_NAND_VF610_NFC_60_ECC_BYTES=y +CONFIG_FSL_LPUART=y diff --git a/configs/ls1021aqds_ddr4_nor_lpuart_defconfig b/configs/ls1021aqds_ddr4_nor_lpuart_defconfig index 68bd117..44b2a0d 100644 --- a/configs/ls1021aqds_ddr4_nor_lpuart_defconfig +++ b/configs/ls1021aqds_ddr4_nor_lpuart_defconfig @@ -4,3 +4,4 @@ CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4,LPUART" # CONFIG_CMD_SETEXPR is not set CONFIG_NETDEVICES=y CONFIG_E1000=y +CONFIG_FSL_LPUART=y diff --git a/configs/ls1021aqds_nor_lpuart_defconfig b/configs/ls1021aqds_nor_lpuart_defconfig index b2f6832..1186af2 100644 --- a/configs/ls1021aqds_nor_lpuart_defconfig +++ b/configs/ls1021aqds_nor_lpuart_defconfig @@ -4,3 +4,4 @@ CONFIG_SYS_EXTRA_OPTIONS="LPUART" # CONFIG_CMD_SETEXPR is not set CONFIG_NETDEVICES=y CONFIG_E1000=y +CONFIG_FSL_LPUART=y diff --git a/configs/ls1021atwr_nor_lpuart_defconfig b/configs/ls1021atwr_nor_lpuart_defconfig index d7afca9..58cd61f 100644 --- a/configs/ls1021atwr_nor_lpuart_defconfig +++ b/configs/ls1021atwr_nor_lpuart_defconfig @@ -4,3 +4,4 @@ CONFIG_SYS_EXTRA_OPTIONS="LPUART" # CONFIG_CMD_SETEXPR is not set CONFIG_NETDEVICES=y CONFIG_E1000=y +CONFIG_FSL_LPUART=y diff --git a/configs/pcm052_defconfig b/configs/pcm052_defconfig index 9125645..26ab733 100644 --- a/configs/pcm052_defconfig +++ b/configs/pcm052_defconfig @@ -3,3 +3,4 @@ CONFIG_TARGET_PCM052=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/phytec/pcm052/imximage.cfg,ENV_IS_IN_NAND" CONFIG_NAND_VF610_NFC=y CONFIG_SYS_NAND_BUSWIDTH_16BIT=y +CONFIG_FSL_LPUART=y diff --git a/configs/vf610twr_defconfig b/configs/vf610twr_defconfig index dc8df5c..d51c93b 100644 --- a/configs/vf610twr_defconfig +++ b/configs/vf610twr_defconfig @@ -6,3 +6,4 @@ CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/vf610twr/imximage.cfg,ENV_I CONFIG_NAND_VF610_NFC=y CONFIG_SYS_NAND_BUSWIDTH_16BIT=y CONFIG_SPI_FLASH=y +CONFIG_FSL_LPUART=y diff --git a/configs/vf610twr_nand_defconfig b/configs/vf610twr_nand_defconfig index 98880f3..299fa8f 100644 --- a/configs/vf610twr_nand_defconfig +++ b/configs/vf610twr_nand_defconfig @@ -6,3 +6,4 @@ CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/vf610twr/imximage.cfg,ENV_I CONFIG_NAND_VF610_NFC=y CONFIG_SYS_NAND_BUSWIDTH_16BIT=y CONFIG_SPI_FLASH=y +CONFIG_FSL_LPUART=y diff --git a/drivers/serial/Kconfig b/drivers/serial/Kconfig index 1fc287e..3b54511 100644 --- a/drivers/serial/Kconfig +++ b/drivers/serial/Kconfig @@ -186,6 +186,12 @@ config ALTERA_UART Select this to enable an UART for Altera devices. Please find details on the "Embedded Peripherals IP User Guide" of Altera.
+config FSL_LPUART + bool "Freescale LPUART support" + help + Select this to enable a Low Power UART for Freescale VF610 and + QorIQ Layerscape devices. + config SYS_NS16550 bool "NS16550 UART or compatible" help diff --git a/include/configs/colibri_vf.h b/include/configs/colibri_vf.h index 708c79a..5aed3a5 100644 --- a/include/configs/colibri_vf.h +++ b/include/configs/colibri_vf.h @@ -36,7 +36,6 @@
#define CONFIG_BOARD_EARLY_INIT_F
-#define CONFIG_FSL_LPUART #define LPUART_BASE UART0_BASE
/* Allow to overwrite serial and ethaddr */ diff --git a/include/configs/ls1021aqds.h b/include/configs/ls1021aqds.h index 2e8dbc7..e8b1eca 100644 --- a/include/configs/ls1021aqds.h +++ b/include/configs/ls1021aqds.h @@ -371,7 +371,6 @@ unsigned long get_board_ddr_clk(void); * Serial Port */ #ifdef CONFIG_LPUART -#define CONFIG_FSL_LPUART #define CONFIG_LPUART_32B_REG #else #define CONFIG_CONS_INDEX 1 diff --git a/include/configs/ls1021atwr.h b/include/configs/ls1021atwr.h index bbef2a7..317ba62 100644 --- a/include/configs/ls1021atwr.h +++ b/include/configs/ls1021atwr.h @@ -266,7 +266,6 @@ * Serial Port */ #ifdef CONFIG_LPUART -#define CONFIG_FSL_LPUART #define CONFIG_LPUART_32B_REG #else #define CONFIG_CONS_INDEX 1 diff --git a/include/configs/pcm052.h b/include/configs/pcm052.h index b851bba..891bdb0 100644 --- a/include/configs/pcm052.h +++ b/include/configs/pcm052.h @@ -27,7 +27,6 @@
-#define CONFIG_FSL_LPUART #define LPUART_BASE UART1_BASE
/* Allow to overwrite serial and ethaddr */ diff --git a/include/configs/vf610twr.h b/include/configs/vf610twr.h index 34df6f0..dcfafaf 100644 --- a/include/configs/vf610twr.h +++ b/include/configs/vf610twr.h @@ -34,7 +34,6 @@
Looks good to me,
Acked-by: Stefan Agner stefan.agner@toradex.com
Changes in v2: None
+config FSL_LPUART
- bool "Freescale LPUART support"
- help
- Serial Port
- Serial Port
On 15 January 2016 at 14:11, Stefan Agner stefan.agner@toradex.com wrote:
Looks good to me,
Changes in v2: None
Looks good to me,
Changes in v2: None
Clean up the driver codes a little bit, by: - Use tab instead of space in the macro defines - Use single line comment whenever possible - Fix insertion of blank lines
Changes in v2: None
drivers/serial/serial_lpuart.c | 35 +++++++++++++++-------------------- 1 file changed, 15 insertions(+), 20 deletions(-)
diff --git a/drivers/serial/serial_lpuart.c b/drivers/serial/serial_lpuart.c index 63fc388..ae47183 100644 --- a/drivers/serial/serial_lpuart.c +++ b/drivers/serial/serial_lpuart.c @@ -12,15 +12,15 @@ #include <asm/arch/imx-regs.h> #include <asm/arch/clock.h>
-#define US1_TDRE (1 << 7) -#define US1_RDRF (1 << 5) -#define US1_OR (1 << 3) -#define UC2_TE (1 << 3) -#define UC2_RE (1 << 2) -#define CFIFO_TXFLUSH (1 << 7) -#define CFIFO_RXFLUSH (1 << 6) -#define SFIFO_RXOF (1 << 2) -#define SFIFO_RXUF (1 << 0) +#define US1_TDRE (1 << 7) +#define US1_RDRF (1 << 5) +#define US1_OR (1 << 3) +#define UC2_TE (1 << 3) +#define UC2_RE (1 << 2) +#define CFIFO_TXFLUSH (1 << 7) +#define CFIFO_RXFLUSH (1 << 6) +#define SFIFO_RXOF (1 << 2) +#define SFIFO_RXUF (1 << 0)
#define STAT_LBKDIF (1 << 31) #define STAT_RXEDGIF (1 << 30) @@ -34,7 +34,7 @@ #define STAT_MA1F (1 << 15) #define STAT_MA2F (1 << 14) #define STAT_FLAGS (STAT_LBKDIF | STAT_RXEDGIF | STAT_IDLE | STAT_OR | \ - STAT_NF | STAT_FE | STAT_PF | STAT_MA1F | STAT_MA2F) + STAT_NF | STAT_FE | STAT_PF | STAT_MA1F | STAT_MA2F)
#define CTRL_TE (1 << 19) #define CTRL_RE (1 << 18) @@ -59,8 +59,8 @@ static void lpuart_serial_setbrg(void) gd->baudrate = CONFIG_BAUDRATE;
sbr = (u16)(clk / (16 * gd->baudrate)); - /* place adjustment later - n/32 BRFA */
+ /* place adjustment later - n/32 BRFA */ __raw_writeb(sbr >> 8, &base->ubdh); __raw_writeb(sbr & 0xff, &base->ubdl); } @@ -86,9 +86,7 @@ static void lpuart_serial_putc(const char c) __raw_writeb(c, &base->ud); }
-/* - * Test whether a character is in the RX buffer - */ +/* Test whether a character is in the RX buffer */ static int lpuart_serial_tstc(void) { if (__raw_readb(&base->urcfifo) == 0) @@ -120,7 +118,6 @@ static int lpuart_serial_init(void) __raw_writeb(CFIFO_TXFLUSH | CFIFO_RXFLUSH, &base->ucfifo);
/* provide data bits, parity, stop bit, etc */ - serial_setbrg();
__raw_writeb(UC2_RE | UC2_TE, &base->uc2); @@ -148,8 +145,8 @@ static void lpuart32_serial_setbrg(void) gd->baudrate = CONFIG_BAUDRATE;
sbr = (clk / (16 * gd->baudrate)); - /* place adjustment later - n/32 BRFA */
+ /* place adjustment later - n/32 BRFA */ out_be32(&base->baud, sbr); }
@@ -176,9 +173,7 @@ static void lpuart32_serial_putc(const char c) out_be32(&base->data, c); }
-/* - * Test whether a character is in the RX buffer - */ +/* Test whether a character is in the RX buffer */ static int lpuart32_serial_tstc(void) { if ((in_be32(&base->water) >> 24) == 0) @@ -204,8 +199,8 @@ static int lpuart32_serial_init(void) out_be32(&base->fifo, ~(FIFO_TXFE | FIFO_RXFE));
out_be32(&base->match, 0); - /* provide data bits, parity, stop bit, etc */
+ /* provide data bits, parity, stop bit, etc */ serial_setbrg();
out_be32(&base->ctrl, CTRL_RE | CTRL_TE);
Changes in v2: None
Changes in v2: None
There is no need to go through serial driver subsystem, instead call the driver's setbrg and putc routines directly.
Changes in v2: None
drivers/serial/serial_lpuart.c | 8 ++++---- 1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/drivers/serial/serial_lpuart.c b/drivers/serial/serial_lpuart.c index ae47183..0c0ab87 100644 --- a/drivers/serial/serial_lpuart.c +++ b/drivers/serial/serial_lpuart.c @@ -78,7 +78,7 @@ static int lpuart_serial_getc(void) static void lpuart_serial_putc(const char c) { if (c == '\n') - serial_putc('\r'); + lpuart_serial_putc('\r');
while (!(__raw_readb(&base->us1) & US1_TDRE)) WATCHDOG_RESET(); @@ -118,7 +118,7 @@ static int lpuart_serial_init(void) __raw_writeb(CFIFO_TXFLUSH | CFIFO_RXFLUSH, &base->ucfifo);
/* provide data bits, parity, stop bit, etc */ - serial_setbrg(); + lpuart_serial_setbrg();
@@ -165,7 +165,7 @@ static int lpuart32_serial_getc(void) static void lpuart32_serial_putc(const char c) { if (c == '\n') - serial_putc('\r'); + lpuart32_serial_putc('\r');
while (!(in_be32(&base->stat) & STAT_TDRE)) WATCHDOG_RESET(); @@ -201,7 +201,7 @@ static int lpuart32_serial_init(void) out_be32(&base->match, 0);
/* provide data bits, parity, stop bit, etc */ - serial_setbrg(); + lpuart32_serial_setbrg();
Changes in v2: None
Changes in v2: None
Create internal routines which take lpuart's register base as a parameter, in preparation for driver model conversion.
Changes in v2: - Add missing 'base' parameter in the call to _lpuart_serial_tstc() - Change internal routines' parameter 'reg' to 'base'
drivers/serial/serial_lpuart.c | 88 +++++++++++++++++++++++++++++++----------- 1 file changed, 66 insertions(+), 22 deletions(-)
diff --git a/drivers/serial/serial_lpuart.c b/drivers/serial/serial_lpuart.c index 0c0ab87..5cc1997 100644 --- a/drivers/serial/serial_lpuart.c +++ b/drivers/serial/serial_lpuart.c @@ -50,22 +50,19 @@ DECLARE_GLOBAL_DATA_PTR; struct lpuart_fsl *base = (struct lpuart_fsl *)LPUART_BASE;
#ifndef CONFIG_LPUART_32B_REG -static void lpuart_serial_setbrg(void) +static void _lpuart_serial_setbrg(struct lpuart_fsl *base, int baudrate) { u32 clk = mxc_get_clock(MXC_UART_CLK); u16 sbr;
- if (!gd->baudrate) - gd->baudrate = CONFIG_BAUDRATE; - - sbr = (u16)(clk / (16 * gd->baudrate)); + sbr = (u16)(clk / (16 * baudrate));
-static int lpuart_serial_getc(void) +static int _lpuart_serial_getc(struct lpuart_fsl *base) { while (!(__raw_readb(&base->us1) & (US1_RDRF | US1_OR))) WATCHDOG_RESET(); @@ -75,10 +72,10 @@ static int lpuart_serial_getc(void) return __raw_readb(&base->ud); }
-static void lpuart_serial_putc(const char c) +static void _lpuart_serial_putc(struct lpuart_fsl *base, const char c) { if (c == '\n') - lpuart_serial_putc('\r'); + _lpuart_serial_putc(base, '\r');
while (!(__raw_readb(&base->us1) & US1_TDRE)) WATCHDOG_RESET(); @@ -87,7 +84,7 @@ static void lpuart_serial_putc(const char c) }
/* Test whether a character is in the RX buffer */ -static int lpuart_serial_tstc(void) +static int _lpuart_serial_tstc(struct lpuart_fsl *base) { if (__raw_readb(&base->urcfifo) == 0) return 0; @@ -99,7 +96,7 @@ static int lpuart_serial_tstc(void) * Initialise the serial port with the given baudrate. The settings * are always 8 data bits, no parity, 1 stop bit, no start bits. */ -static int lpuart_serial_init(void) +static int _lpuart_serial_init(struct lpuart_fsl *base) { u8 ctrl;
@@ -118,13 +115,38 @@ static int lpuart_serial_init(void) __raw_writeb(CFIFO_TXFLUSH | CFIFO_RXFLUSH, &base->ucfifo);
/* provide data bits, parity, stop bit, etc */ - lpuart_serial_setbrg(); + _lpuart_serial_setbrg(base, gd->baudrate);
return 0; }
+static void lpuart_serial_setbrg(void) +{ + _lpuart_serial_setbrg(base, gd->baudrate); +} + +static int lpuart_serial_getc(void) +{ + return _lpuart_serial_getc(base); +} + +static void lpuart_serial_putc(const char c) +{ + _lpuart_serial_putc(base, c); +} + +static int lpuart_serial_tstc(void) +{ + return _lpuart_serial_tstc(base); +} + +static int lpuart_serial_init(void) +{ + return _lpuart_serial_init(base); +} + static struct serial_device lpuart_serial_drv = { .name = "lpuart_serial", .start = lpuart_serial_init, @@ -136,21 +158,18 @@ static struct serial_device lpuart_serial_drv = { .tstc = lpuart_serial_tstc, }; #else -static void lpuart32_serial_setbrg(void) +static void _lpuart32_serial_setbrg(struct lpuart_fsl *base, int baudrate) { u32 clk = CONFIG_SYS_CLK_FREQ; u32 sbr;
- if (!gd->baudrate) - gd->baudrate = CONFIG_BAUDRATE; - - sbr = (clk / (16 * gd->baudrate)); + sbr = (clk / (16 * baudrate));
-static int lpuart32_serial_getc(void) +static int _lpuart32_serial_getc(struct lpuart_fsl *base) { u32 stat;
@@ -162,10 +181,10 @@ static int lpuart32_serial_getc(void) return in_be32(&base->data) & 0x3ff; }
-static void lpuart32_serial_putc(const char c) +static void _lpuart32_serial_putc(struct lpuart_fsl *base, const char c) { if (c == '\n') - lpuart32_serial_putc('\r'); + _lpuart32_serial_putc(base, '\r');
while (!(in_be32(&base->stat) & STAT_TDRE)) WATCHDOG_RESET(); @@ -174,7 +193,7 @@ static void lpuart32_serial_putc(const char c) }
/* Test whether a character is in the RX buffer */ -static int lpuart32_serial_tstc(void) +static int _lpuart32_serial_tstc(struct lpuart_fsl *base) { if ((in_be32(&base->water) >> 24) == 0) return 0; @@ -186,7 +205,7 @@ static int lpuart32_serial_tstc(void) * Initialise the serial port with the given baudrate. The settings * are always 8 data bits, no parity, 1 stop bit, no start bits. */ -static int lpuart32_serial_init(void) +static int _lpuart32_serial_init(struct lpuart_fsl *base) { u8 ctrl;
@@ -201,13 +220,38 @@ static int lpuart32_serial_init(void) out_be32(&base->match, 0);
/* provide data bits, parity, stop bit, etc */ - lpuart32_serial_setbrg(); + _lpuart32_serial_setbrg(base, gd->baudrate);
return 0; }
+static void lpuart32_serial_setbrg(void) +{ + _lpuart32_serial_setbrg(base, gd->baudrate); +} + +static int lpuart32_serial_getc(void) +{ + return _lpuart32_serial_getc(base); +} + +static void lpuart32_serial_putc(const char c) +{ + _lpuart32_serial_putc(base, c); +} + +static int lpuart32_serial_tstc(void) +{ + return _lpuart32_serial_tstc(base); +} + +static int lpuart32_serial_init(void) +{ + return _lpuart32_serial_init(base); +} + static struct serial_device lpuart32_serial_drv = { .name = "lpuart32_serial", .start = lpuart32_serial_init,
Changes in v2:
Changes in v2:
This adds driver model support to lpuart serial driver.
Changes in v2: - Split to use two separate U_BOOT_DRIVER()
doc/driver-model/serial-howto.txt | 1 - drivers/serial/serial_lpuart.c | 167 ++++++++++++++++++++++++++++++++++++++ 2 files changed, 167 insertions(+), 1 deletion(-)
diff --git a/doc/driver-model/serial-howto.txt b/doc/driver-model/serial-howto.txt index 4706d56..c933b90 100644 --- a/doc/driver-model/serial-howto.txt +++ b/doc/driver-model/serial-howto.txt @@ -11,7 +11,6 @@ is time for maintainers to start converting over the remaining serial drivers: opencores_yanu.c serial_bfin.c serial_imx.c - serial_lpuart.c serial_max3100.c serial_pxa.c serial_s3c24x0.c diff --git a/drivers/serial/serial_lpuart.c b/drivers/serial/serial_lpuart.c index 5cc1997..3f9c4d1 100644 --- a/drivers/serial/serial_lpuart.c +++ b/drivers/serial/serial_lpuart.c @@ -5,6 +5,7 @@ */
#include <common.h> +#include <dm.h> #include <watchdog.h> #include <asm/io.h> #include <serial.h> @@ -49,6 +50,10 @@ DECLARE_GLOBAL_DATA_PTR;
+struct lpuart_serial_platdata { + struct lpuart_fsl *reg; +}; + #ifndef CONFIG_LPUART_32B_REG static void _lpuart_serial_setbrg(struct lpuart_fsl *base, int baudrate) { @@ -122,6 +127,7 @@ static int _lpuart_serial_init(struct lpuart_fsl *base) return 0; }
+#ifndef CONFIG_DM_SERIAL static void lpuart_serial_setbrg(void) { _lpuart_serial_setbrg(base, gd->baudrate); @@ -157,6 +163,54 @@ static struct serial_device lpuart_serial_drv = { .getc = lpuart_serial_getc, .tstc = lpuart_serial_tstc, }; +#else /* CONFIG_DM_SERIAL */ +static int lpuart_serial_setbrg(struct udevice *dev, int baudrate) +{ + struct lpuart_serial_platdata *plat = dev->platdata; + struct lpuart_fsl *reg = plat->reg; + + _lpuart_serial_setbrg(reg, baudrate); + + return 0; +} + +static int lpuart_serial_getc(struct udevice *dev) +{ + struct lpuart_serial_platdata *plat = dev->platdata; + struct lpuart_fsl *reg = plat->reg; + + return _lpuart_serial_getc(reg); +} + +static int lpuart_serial_putc(struct udevice *dev, const char c) +{ + struct lpuart_serial_platdata *plat = dev->platdata; + struct lpuart_fsl *reg = plat->reg; + + _lpuart_serial_putc(reg, c); + + return 0; +} + +static int lpuart_serial_pending(struct udevice *dev, bool input) +{ + struct lpuart_serial_platdata *plat = dev->platdata; + struct lpuart_fsl *reg = plat->reg; + + if (input) + return _lpuart_serial_tstc(reg); + else + return __raw_readb(®->us1) & US1_TDRE ? 0 : 1; +} + +static int lpuart_serial_probe(struct udevice *dev) +{ + struct lpuart_serial_platdata *plat = dev->platdata; + struct lpuart_fsl *reg = plat->reg; + + return _lpuart_serial_init(reg); +} +#endif /* CONFIG_DM_SERIAL */ #else static void _lpuart32_serial_setbrg(struct lpuart_fsl *base, int baudrate) { @@ -227,6 +281,7 @@ static int _lpuart32_serial_init(struct lpuart_fsl *base) return 0; }
+#ifndef CONFIG_DM_SERIAL static void lpuart32_serial_setbrg(void) { _lpuart32_serial_setbrg(base, gd->baudrate); @@ -262,8 +317,57 @@ static struct serial_device lpuart32_serial_drv = { .getc = lpuart32_serial_getc, .tstc = lpuart32_serial_tstc, }; +#else /* CONFIG_DM_SERIAL */ +static int lpuart32_serial_setbrg(struct udevice *dev, int baudrate) +{ + struct lpuart_serial_platdata *plat = dev->platdata; + struct lpuart_fsl *reg = plat->reg; + + _lpuart32_serial_setbrg(reg, baudrate); + + return 0; +} + +static int lpuart32_serial_getc(struct udevice *dev) +{ + struct lpuart_serial_platdata *plat = dev->platdata; + struct lpuart_fsl *reg = plat->reg; + + return _lpuart32_serial_getc(reg); +} + +static int lpuart32_serial_putc(struct udevice *dev, const char c) +{ + struct lpuart_serial_platdata *plat = dev->platdata; + struct lpuart_fsl *reg = plat->reg; + + _lpuart32_serial_putc(reg, c); + + return 0; +} + +static int lpuart32_serial_pending(struct udevice *dev, bool input) +{ + struct lpuart_serial_platdata *plat = dev->platdata; + struct lpuart_fsl *reg = plat->reg; + + if (input) + return _lpuart32_serial_tstc(reg); + else + return in_be32(®->stat) & STAT_TDRE ? 0 : 1; +} + +static int lpuart32_serial_probe(struct udevice *dev) +{ + struct lpuart_serial_platdata *plat = dev->platdata; + struct lpuart_fsl *reg = plat->reg; + + return _lpuart32_serial_init(reg); +} +#endif /* CONFIG_DM_SERIAL */ #endif
+#ifndef CONFIG_DM_SERIAL void lpuart_serial_initialize(void) { #ifdef CONFIG_LPUART_32B_REG @@ -281,3 +385,66 @@ __weak struct serial_device *default_serial_console(void) return &lpuart_serial_drv; #endif } +#else /* CONFIG_DM_SERIAL */ +static int lpuart_serial_ofdata_to_platdata(struct udevice *dev) +{ + struct lpuart_serial_platdata *plat = dev->platdata; + fdt_addr_t addr; + + addr = dev_get_addr(dev); + if (addr == FDT_ADDR_T_NONE) + return -EINVAL; + + plat->reg = (struct lpuart_fsl *)addr; + + return 0; +} + +#ifndef CONFIG_LPUART_32B_REG +static const struct dm_serial_ops lpuart_serial_ops = { + .putc = lpuart_serial_putc, + .pending = lpuart_serial_pending, + .getc = lpuart_serial_getc, + .setbrg = lpuart_serial_setbrg, +}; + +static const struct udevice_id lpuart_serial_ids[] = { + { .compatible = "fsl,vf610-lpuart" }, + { } +}; + +U_BOOT_DRIVER(serial_lpuart) = { + .name = "serial_lpuart", + .id = UCLASS_SERIAL, + .of_match = lpuart_serial_ids, + .ofdata_to_platdata = lpuart_serial_ofdata_to_platdata, + .platdata_auto_alloc_size = sizeof(struct lpuart_serial_platdata), + .probe = lpuart_serial_probe, + .ops = &lpuart_serial_ops, + .flags = DM_FLAG_PRE_RELOC, +}; +#else /* CONFIG_LPUART_32B_REG */ +static const struct dm_serial_ops lpuart32_serial_ops = { + .putc = lpuart32_serial_putc, + .pending = lpuart32_serial_pending, + .getc = lpuart32_serial_getc, + .setbrg = lpuart32_serial_setbrg, +}; + +static const struct udevice_id lpuart32_serial_ids[] = { + { .compatible = "fsl,ls1021a-lpuart" }, + { } +}; + +U_BOOT_DRIVER(serial_lpuart32) = { + .name = "serial_lpuart32", + .id = UCLASS_SERIAL, + .of_match = lpuart32_serial_ids, + .ofdata_to_platdata = lpuart_serial_ofdata_to_platdata, + .platdata_auto_alloc_size = sizeof(struct lpuart_serial_platdata), + .probe = lpuart32_serial_probe, + .ops = &lpuart32_serial_ops, + .flags = DM_FLAG_PRE_RELOC, +}; +#endif /* CONFIG_LPUART_32B_REG */ +#endif /* CONFIG_DM_SERIAL */
Tested on Toradex Colibri VF50/VF61 h/w with legacy and DT, works fine as expected.
Acked-by: Bhuvanchandra DV bhuvanchandra.dv@toradex.com also Tested-by: Bhuvanchandra DV bhuvanchandra.dv@toradex.com
Changes in v2:
- struct lpuart_fsl *reg;
- #ifndef CONFIG_LPUART_32B_REG static void _lpuart_serial_setbrg(struct lpuart_fsl *base, int baudrate) {
- struct lpuart_serial_platdata *plat = dev->platdata;
- struct lpuart_fsl *reg = plat->reg;
- _lpuart_serial_setbrg(reg, baudrate);
- return _lpuart_serial_getc(reg);
- _lpuart_serial_putc(reg, c);
- if (input)
- else
- return _lpuart_serial_init(reg);
- _lpuart32_serial_setbrg(reg, baudrate);
- return _lpuart32_serial_getc(reg);
- _lpuart32_serial_putc(reg, c);
- if (input)
- else
- return _lpuart32_serial_init(reg);
- fdt_addr_t addr;
- addr = dev_get_addr(dev);
- if (addr == FDT_ADDR_T_NONE)
return -EINVAL;
- plat->reg = (struct lpuart_fsl *)addr;
- .putc = lpuart_serial_putc,
- .pending = lpuart_serial_pending,
- .getc = lpuart_serial_getc,
- .setbrg = lpuart_serial_setbrg,
- { .compatible = "fsl,vf610-lpuart" },
- .name = "serial_lpuart",
- .id = UCLASS_SERIAL,
- .of_match = lpuart_serial_ids,
- .ofdata_to_platdata = lpuart_serial_ofdata_to_platdata,
- .platdata_auto_alloc_size = sizeof(struct lpuart_serial_platdata),
- .probe = lpuart_serial_probe,
- .ops = &lpuart_serial_ops,
- .flags = DM_FLAG_PRE_RELOC,
- .putc = lpuart32_serial_putc,
- .pending = lpuart32_serial_pending,
- .getc = lpuart32_serial_getc,
- .setbrg = lpuart32_serial_setbrg,
- { .compatible = "fsl,ls1021a-lpuart" },
- .name = "serial_lpuart32",
- .of_match = lpuart32_serial_ids,
- .probe = lpuart32_serial_probe,
- .ops = &lpuart32_serial_ops,
Changes in v2:
Changes in v2:
Move /chosen node out of the board device tree.
Changes in v2: - New patch to split off board device tree
arch/arm/dts/Makefile | 2 +- arch/arm/dts/ls1021a-twr-duart.dts | 16 ++++++++++++++++ arch/arm/dts/{ls1021a-twr.dts => ls1021a-twr.dtsi} | 3 +-- configs/ls1021atwr_nor_defconfig | 2 +- configs/ls1021atwr_qspi_defconfig | 2 +- configs/ls1021atwr_sdcard_qspi_defconfig | 2 +- 6 files changed, 21 insertions(+), 6 deletions(-) create mode 100644 arch/arm/dts/ls1021a-twr-duart.dts rename arch/arm/dts/{ls1021a-twr.dts => ls1021a-twr.dtsi} (96%)
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 0bcd316..02b031e 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -89,7 +89,7 @@ dtb-$(CONFIG_TARGET_BEAGLE_X15) += am57xx-beagle-x15.dtb dtb-$(CONFIG_TARGET_STV0991) += stv0991.dtb
dtb-$(CONFIG_LS102XA) += ls1021a-qds.dtb \ - ls1021a-twr.dtb + ls1021a-twr-duart.dtb dtb-$(CONFIG_FSL_LSCH3) += fsl-ls2080a-qds.dtb \ fsl-ls2080a-rdb.dtb dtb-$(CONFIG_FSL_LSCH2) += fsl-ls1043a-qds.dtb \ diff --git a/arch/arm/dts/ls1021a-twr-duart.dts b/arch/arm/dts/ls1021a-twr-duart.dts new file mode 100644 index 0000000..aaf7296 --- /dev/null +++ b/arch/arm/dts/ls1021a-twr-duart.dts @@ -0,0 +1,16 @@ +/* + * Freescale ls1021a TWR board device tree source + * + * Copyright 2013-2015 Freescale Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +/dts-v1/; +#include "ls1021a-twr.dtsi" + +/ { + chosen { + stdout-path = &uart0; + }; +}; diff --git a/arch/arm/dts/ls1021a-twr.dts b/arch/arm/dts/ls1021a-twr.dtsi similarity index 96% rename from arch/arm/dts/ls1021a-twr.dts rename to arch/arm/dts/ls1021a-twr.dtsi index aead13f..d1be9ae 100644 --- a/arch/arm/dts/ls1021a-twr.dts +++ b/arch/arm/dts/ls1021a-twr.dtsi @@ -1,12 +1,11 @@ /* - * Freescale ls1021a TWR board device tree source + * Freescale ls1021a TWR board common device tree source * * Copyright 2013-2015 Freescale Semiconductor, Inc. * * SPDX-License-Identifier: GPL-2.0+ */
-/dts-v1/; #include "ls1021a.dtsi"
/ { diff --git a/configs/ls1021atwr_nor_defconfig b/configs/ls1021atwr_nor_defconfig index 2b79443..b7b3a8d 100644 --- a/configs/ls1021atwr_nor_defconfig +++ b/configs/ls1021atwr_nor_defconfig @@ -1,7 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_LS1021ATWR=y CONFIG_DM_SERIAL=y -CONFIG_DEFAULT_DEVICE_TREE="ls1021a-twr" +CONFIG_DEFAULT_DEVICE_TREE="ls1021a-twr-duart" # CONFIG_CMD_SETEXPR is not set CONFIG_OF_CONTROL=y CONFIG_DM=y diff --git a/configs/ls1021atwr_qspi_defconfig b/configs/ls1021atwr_qspi_defconfig index 0c71df6..d7c7e4c 100644 --- a/configs/ls1021atwr_qspi_defconfig +++ b/configs/ls1021atwr_qspi_defconfig @@ -1,7 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_LS1021ATWR=y CONFIG_DM_SPI=y -CONFIG_DEFAULT_DEVICE_TREE="ls1021a-twr" +CONFIG_DEFAULT_DEVICE_TREE="ls1021a-twr-duart" CONFIG_SYS_EXTRA_OPTIONS="QSPI_BOOT" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_SETEXPR is not set diff --git a/configs/ls1021atwr_sdcard_qspi_defconfig b/configs/ls1021atwr_sdcard_qspi_defconfig index 2b4ebd9..453a3bb 100644 --- a/configs/ls1021atwr_sdcard_qspi_defconfig +++ b/configs/ls1021atwr_sdcard_qspi_defconfig @@ -1,7 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_LS1021ATWR=y CONFIG_DM_SPI=y -CONFIG_DEFAULT_DEVICE_TREE="ls1021a-twr" +CONFIG_DEFAULT_DEVICE_TREE="ls1021a-twr-duart" CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SPL_FSL_PBL,SD_BOOT,SD_BOOT_QSPI" CONFIG_OF_CONTROL=y
Changes in v2:
Changes in v2:
Convert ls1021atwr_nor_lpuart to driver model support. As a start, enable lpuart serial port driver.
Changes in v2: - Create a ls1021a-twr-lpuart.dts for ls1021atwr_nor_lpuart_defconfig
arch/arm/dts/Makefile | 2 +- arch/arm/dts/ls1021a-twr-lpuart.dts | 16 ++++++++++++++++ configs/ls1021atwr_nor_lpuart_defconfig | 4 ++++ 3 files changed, 21 insertions(+), 1 deletion(-) create mode 100644 arch/arm/dts/ls1021a-twr-lpuart.dts
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 02b031e..4bbf661 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -89,7 +89,7 @@ dtb-$(CONFIG_TARGET_BEAGLE_X15) += am57xx-beagle-x15.dtb dtb-$(CONFIG_TARGET_STV0991) += stv0991.dtb
dtb-$(CONFIG_LS102XA) += ls1021a-qds.dtb \ - ls1021a-twr-duart.dtb + ls1021a-twr-duart.dtb ls1021a-twr-lpuart.dtb dtb-$(CONFIG_FSL_LSCH3) += fsl-ls2080a-qds.dtb \ fsl-ls2080a-rdb.dtb dtb-$(CONFIG_FSL_LSCH2) += fsl-ls1043a-qds.dtb \ diff --git a/arch/arm/dts/ls1021a-twr-lpuart.dts b/arch/arm/dts/ls1021a-twr-lpuart.dts new file mode 100644 index 0000000..2941ec0 --- /dev/null +++ b/arch/arm/dts/ls1021a-twr-lpuart.dts @@ -0,0 +1,16 @@ +/* + * Freescale ls1021a TWR board device tree source + * + * Copyright 2013-2015 Freescale Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +/dts-v1/; +#include "ls1021a-twr.dtsi" + +/ { + chosen { + stdout-path = &lpuart0; + }; +}; diff --git a/configs/ls1021atwr_nor_lpuart_defconfig b/configs/ls1021atwr_nor_lpuart_defconfig index 58cd61f..599342f 100644 --- a/configs/ls1021atwr_nor_lpuart_defconfig +++ b/configs/ls1021atwr_nor_lpuart_defconfig @@ -1,7 +1,11 @@ CONFIG_ARM=y CONFIG_TARGET_LS1021ATWR=y +CONFIG_DM_SERIAL=y +CONFIG_DEFAULT_DEVICE_TREE="ls1021a-twr-lpuart" CONFIG_SYS_EXTRA_OPTIONS="LPUART" # CONFIG_CMD_SETEXPR is not set +CONFIG_OF_CONTROL=y +CONFIG_DM=y CONFIG_NETDEVICES=y CONFIG_E1000=y CONFIG_FSL_LPUART=y
-----Original Message----- From: Bin Meng [mailto:bmeng.cn@gmail.com] Sent: Thursday, January 14, 2016 11:39 AM To: Simon Glass; Stefan Agner; Bhuvanchandra DV; Albert ARIBAUD (3ADEV); York Sun; Alison Wang; U-Boot Mailing List Subject: [PATCH v2 9/9] arm: ls1021atwr: Enable driver model lpuart serial driver
Changes in v2:
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 02b031e..4bbf661 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -89,7 +89,7 @@ dtb-$(CONFIG_TARGET_BEAGLE_X15) += am57xx-beagle- x15.dtb dtb-$(CONFIG_TARGET_STV0991) += stv0991.dtb
- ls1021a-twr-duart.dtb ls1021a-twr-lpuart.dtb
dtb-$(CONFIG_FSL_LSCH3) += fsl-ls2080a-qds.dtb \ fsl-ls2080a-rdb.dtb dtb-$(CONFIG_FSL_LSCH2) += fsl-ls1043a-qds.dtb \ diff --git a/arch/arm/dts/ls1021a-twr-lpuart.dts b/arch/arm/dts/ls1021a-twr- lpuart.dts new file mode 100644 index 0000000..2941ec0 --- /dev/null +++ b/arch/arm/dts/ls1021a-twr-lpuart.dts @@ -0,0 +1,16 @@ +/*
- Freescale ls1021a TWR board device tree source
- Copyright 2013-2015 Freescale Semiconductor, Inc.
- chosen {
+}; diff --git a/configs/ls1021atwr_nor_lpuart_defconfig b/configs/ls1021atwr_nor_lpuart_defconfig index 58cd61f..599342f 100644 --- a/configs/ls1021atwr_nor_lpuart_defconfig +++ b/configs/ls1021atwr_nor_lpuart_defconfig @@ -1,7 +1,11 @@ CONFIG_ARM=y CONFIG_TARGET_LS1021ATWR=y +CONFIG_DM_SERIAL=y +CONFIG_DEFAULT_DEVICE_TREE="ls1021a-twr-lpuart" CONFIG_SYS_EXTRA_OPTIONS="LPUART" # CONFIG_CMD_SETEXPR is not set +CONFIG_OF_CONTROL=y +CONFIG_DM=y CONFIG_NETDEVICES=y CONFIG_E1000=y CONFIG_FSL_LPUART=y -- 1.8.2.1
Reviewed-by: Alison Wang alison.wang@nxp.com Tested-by: Alison Wang alison.wang@nxp.com
Best Regards, Alison Wang
Changes in v2:
chosen {
Changes in v2:
chosen {
participants (5)
Bhuvanchandra DV
Bin Meng
Huan Wang
Stefan Agner
