[PATCH 1/4] stm32mp: stm32prog: support empty flashlayout
When the STM32CubeProgrammer sent a empty flashlayout.tsv file, the command stm32prog correctly parse the file but data->dev_nb = 0 and the stm32prog_devices_init operations should be skipped.
Signed-off-by: Patrick Delaunay patrick.delaunay@foss.st.com ---
arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog.c | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog.c b/arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog.c index c391b6c7abb..65e32288af7 100644 --- a/arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog.c +++ b/arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog.c @@ -1884,6 +1884,10 @@ static void stm32prog_devices_init(struct stm32prog_data *data) if (ret) goto error;
+ /* empty flashlayout */ + if (!data->dev_nb) + return; + /* initialize the selected device */ for (i = 0; i < data->dev_nb; i++) { ret = init_device(data, &data->dev[i]);
Change the defaut flashlayout location, hardcoded at STM32_DDR_BASE, to CONFIG_SYS_LOAD_ADDR to avoid issue on board with reserved memory at STM32_DDR_BASE.
This patch changes the command behavior for STM32MP13 and STM32MP15 platform, as CONFIG_SYS_LOAD_ADDR(0xc2000000) != STM32_DDR_BASE but without impact for serial boot with STM32CubeProgrammer.
arch/arm/mach-stm32mp/cmd_stm32prog/cmd_stm32prog.c | 2 +- arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog.c | 8 ++++---- arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog_serial.c | 2 +- arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog_usb.c | 2 +- 4 files changed, 7 insertions(+), 7 deletions(-)
diff --git a/arch/arm/mach-stm32mp/cmd_stm32prog/cmd_stm32prog.c b/arch/arm/mach-stm32mp/cmd_stm32prog/cmd_stm32prog.c index f59414e716f..cb9e20da136 100644 --- a/arch/arm/mach-stm32mp/cmd_stm32prog/cmd_stm32prog.c +++ b/arch/arm/mach-stm32mp/cmd_stm32prog/cmd_stm32prog.c @@ -61,7 +61,7 @@ static int do_stm32prog(struct cmd_tbl *cmdtp, int flag, int argc,
dev = (int)dectoul(argv[2], NULL);
- addr = STM32_DDR_BASE; + addr = CONFIG_SYS_LOAD_ADDR; size = 0; if (argc > 3) { addr = hextoul(argv[3], NULL); diff --git a/arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog.c b/arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog.c index 65e32288af7..3b2652a0e0d 100644 --- a/arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog.c +++ b/arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog.c @@ -1388,7 +1388,7 @@ static int dfu_init_entities(struct stm32prog_data *data) char buf[ALT_BUF_LEN];
sprintf(buf, "@FlashLayout/0x%02x/1*256Ke ram %x 40000", - PHASE_FLASHLAYOUT, STM32_DDR_BASE); + PHASE_FLASHLAYOUT, CONFIG_SYS_LOAD_ADDR); ret = dfu_alt_add(dfu, "ram", NULL, buf); log_debug("dfu_alt_add(ram, NULL,%s) result %d\n", buf, ret); } @@ -1699,15 +1699,15 @@ static void stm32prog_end_phase(struct stm32prog_data *data, u64 offset) { if (data->phase == PHASE_FLASHLAYOUT) { #if defined(CONFIG_LEGACY_IMAGE_FORMAT) - if (genimg_get_format((void *)STM32_DDR_BASE) == IMAGE_FORMAT_LEGACY) { - data->script = STM32_DDR_BASE; + if (genimg_get_format((void *)CONFIG_SYS_LOAD_ADDR) == IMAGE_FORMAT_LEGACY) { + data->script = CONFIG_SYS_LOAD_ADDR; data->phase = PHASE_END; log_notice("U-Boot script received\n"); return; } #endif log_notice("\nFlashLayout received, size = %lld\n", offset); - if (parse_flash_layout(data, STM32_DDR_BASE, offset)) + if (parse_flash_layout(data, CONFIG_SYS_LOAD_ADDR, offset)) stm32prog_err("Layout: invalid FlashLayout"); return; } diff --git a/arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog_serial.c b/arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog_serial.c index 2932eae7578..1bf5f5ae0ac 100644 --- a/arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog_serial.c +++ b/arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog_serial.c @@ -462,7 +462,7 @@ static void get_phase_command(struct stm32prog_data *data) length = strlen(err_msg); } if (phase == PHASE_FLASHLAYOUT) - destination = STM32_DDR_BASE; + destination = CONFIG_SYS_LOAD_ADDR;
stm32prog_serial_putc(length + 5); /* Total length */ stm32prog_serial_putc(phase & 0xFF); /* partition ID */ diff --git a/arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog_usb.c b/arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog_usb.c index a8b57c4d8f0..bcb4d373f69 100644 --- a/arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog_usb.c +++ b/arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog_usb.c @@ -90,7 +90,7 @@ static int stm32prog_cmd_read(u64 offset, void *buf, long *len) } phase = stm32prog_data->phase; if (phase == PHASE_FLASHLAYOUT) - destination = STM32_DDR_BASE; + destination = CONFIG_SYS_LOAD_ADDR; dfu_offset = stm32prog_data->offset;
/* mandatory header, size = PHASE_MIN_SIZE */
Hi Patrick
- addr = CONFIG_SYS_LOAD_ADDR; size = 0; if (argc > 3) { addr = hextoul(argv[3], NULL);
ret = dfu_alt_add(dfu, "ram", NULL, buf); log_debug("dfu_alt_add(ram, NULL,%s) result %d\n", buf, ret); }PHASE_FLASHLAYOUT, CONFIG_SYS_LOAD_ADDR);
}data->script = CONFIG_SYS_LOAD_ADDR; data->phase = PHASE_END; log_notice("U-Boot script received\n"); return;
return; }if (parse_flash_layout(data, CONFIG_SYS_LOAD_ADDR, offset)) stm32prog_err("Layout: invalid FlashLayout");
Reviewed-by: Patrice Chotard patrice.chotard@foss.st.com
Thanks Patrice
Solve many compilation warning when stm32prog is activated on the aarch64.
.../mach-stm32mp/cmd_stm32prog/cmd_stm32prog.c | 14 +++++++------- arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog.c | 16 ++++++++-------- arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog.h | 14 +++++++------- .../cmd_stm32prog/stm32prog_serial.c | 15 +++++++-------- .../mach-stm32mp/cmd_stm32prog/stm32prog_usb.c | 4 ++-- 5 files changed, 31 insertions(+), 32 deletions(-)
diff --git a/arch/arm/mach-stm32mp/cmd_stm32prog/cmd_stm32prog.c b/arch/arm/mach-stm32mp/cmd_stm32prog/cmd_stm32prog.c index cb9e20da136..d2666b97757 100644 --- a/arch/arm/mach-stm32mp/cmd_stm32prog/cmd_stm32prog.c +++ b/arch/arm/mach-stm32mp/cmd_stm32prog/cmd_stm32prog.c @@ -126,21 +126,21 @@ static int do_stm32prog(struct cmd_tbl *cmdtp, int flag, int argc, char *bootm_argv[5] = { "bootm", boot_addr_start, "-", dtb_addr, NULL }; - u32 uimage = data->uimage; - u32 dtb = data->dtb; - u32 initrd = data->initrd; + const void *uimage = (void *)data->uimage; + const void *dtb = (void *)data->dtb; + const void *initrd = (void *)data->initrd;
if (!dtb) bootm_argv[3] = env_get("fdtcontroladdr"); else snprintf(dtb_addr, sizeof(dtb_addr) - 1, - "0x%x", dtb); + "0x%p", dtb);
snprintf(boot_addr_start, sizeof(boot_addr_start) - 1, - "0x%x", uimage); + "0x%p", uimage);
if (initrd) { - snprintf(initrd_addr, sizeof(initrd_addr) - 1, "0x%x:0x%x", + snprintf(initrd_addr, sizeof(initrd_addr) - 1, "0x%p:0x%zx", initrd, data->initrd_size); bootm_argv[2] = initrd_addr; } @@ -148,7 +148,7 @@ static int do_stm32prog(struct cmd_tbl *cmdtp, int flag, int argc, printf("Booting kernel at %s %s %s...\n\n\n", boot_addr_start, bootm_argv[2], bootm_argv[3]); /* Try bootm for legacy and FIT format image */ - if (genimg_get_format((void *)uimage) != IMAGE_FORMAT_INVALID) + if (genimg_get_format(uimage) != IMAGE_FORMAT_INVALID) do_bootm(cmdtp, 0, 4, bootm_argv); else if (CONFIG_IS_ENABLED(CMD_BOOTZ)) do_bootz(cmdtp, 0, 4, bootm_argv); diff --git a/arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog.c b/arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog.c index 3b2652a0e0d..67be1ac7ff8 100644 --- a/arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog.c +++ b/arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog.c @@ -322,7 +322,7 @@ void stm32prog_header_check(uintptr_t raw_header, struct image_header_s *header) header->image_length = 0x0; }
-static u32 stm32prog_header_checksum(u32 addr, struct image_header_s *header) +static u32 stm32prog_header_checksum(uintptr_t addr, struct image_header_s *header) { u32 i, checksum; u8 *payload; @@ -398,7 +398,7 @@ static int parse_name(struct stm32prog_data *data, if (strlen(p) < sizeof(part->name)) { strcpy(part->name, p); } else { - stm32prog_err("Layout line %d: partition name too long [%d]: %s", + stm32prog_err("Layout line %d: partition name too long [%zd]: %s", i, strlen(p), p); result = -EINVAL; } @@ -537,7 +537,7 @@ int (* const parse[COL_NB_STM32])(struct stm32prog_data *data, int i, char *p, };
static int parse_flash_layout(struct stm32prog_data *data, - ulong addr, + uintptr_t addr, ulong size) { int column = 0, part_nb = 0, ret; @@ -1440,7 +1440,7 @@ int stm32prog_otp_write(struct stm32prog_data *data, u32 offset, u8 *buffer, if (offset + *size > otp_size) *size = otp_size - offset;
- memcpy((void *)((u32)data->otp_part + offset), buffer, *size); + memcpy((void *)((uintptr_t)data->otp_part + offset), buffer, *size);
return 0; } @@ -1479,7 +1479,7 @@ int stm32prog_otp_read(struct stm32prog_data *data, u32 offset, u8 *buffer, data->otp_part, OTP_SIZE_TA); else if (IS_ENABLED(CONFIG_ARM_SMCCC)) result = stm32_smc_exec(STM32_SMC_BSEC, STM32_SMC_READ_ALL, - (u32)data->otp_part, 0); + (unsigned long)data->otp_part, 0); if (result) goto end_otp_read; } @@ -1491,7 +1491,7 @@ int stm32prog_otp_read(struct stm32prog_data *data, u32 offset, u8 *buffer,
if (offset + *size > otp_size) *size = otp_size - offset; - memcpy(buffer, (void *)((u32)data->otp_part + offset), *size); + memcpy(buffer, (void *)((uintptr_t)data->otp_part + offset), *size);
end_otp_read: log_debug("%s: result %i\n", __func__, result); @@ -1521,7 +1521,7 @@ int stm32prog_otp_start(struct stm32prog_data *data) data->otp_part, OTP_SIZE_TA); } else if (IS_ENABLED(CONFIG_ARM_SMCCC)) { arm_smccc_smc(STM32_SMC_BSEC, STM32_SMC_WRITE_ALL, - (u32)data->otp_part, 0, 0, 0, 0, 0, &res); + (uintptr_t)data->otp_part, 0, 0, 0, 0, 0, &res);
if (!res.a0) { switch (res.a1) { @@ -1951,7 +1951,7 @@ int stm32prog_dfu_init(struct stm32prog_data *data) return dfu_init_entities(data); }
-int stm32prog_init(struct stm32prog_data *data, ulong addr, ulong size) +int stm32prog_init(struct stm32prog_data *data, uintptr_t addr, ulong size) { memset(data, 0x0, sizeof(*data)); data->read_phase = PHASE_RESET; diff --git a/arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog.h b/arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog.h index ac300768ca0..397506ac47c 100644 --- a/arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog.h +++ b/arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog.h @@ -154,7 +154,7 @@ struct stm32prog_data { u32 offset; char error[255]; struct stm32prog_part_t *cur_part; - u32 *otp_part; + void *otp_part; u8 pmic_part[PMIC_SIZE];
/* SERIAL information */ @@ -165,12 +165,12 @@ struct stm32prog_data { u8 read_phase;
/* bootm information */ - u32 uimage; - u32 dtb; - u32 initrd; - u32 initrd_size; + uintptr_t uimage; + uintptr_t dtb; + uintptr_t initrd; + size_t initrd_size;
- u32 script; + uintptr_t script;
/* OPTEE PTA NVMEM */ struct udevice *tee; @@ -209,7 +209,7 @@ char *stm32prog_get_error(struct stm32prog_data *data); }
/* Main function */ -int stm32prog_init(struct stm32prog_data *data, ulong addr, ulong size); +int stm32prog_init(struct stm32prog_data *data, uintptr_t addr, ulong size); void stm32prog_clean(struct stm32prog_data *data);
#ifdef CONFIG_CMD_STM32PROG_SERIAL diff --git a/arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog_serial.c b/arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog_serial.c index 1bf5f5ae0ac..9f2ab2b625c 100644 --- a/arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog_serial.c +++ b/arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog_serial.c @@ -300,7 +300,7 @@ static void stm32prog_serial_putc(u8 w_byte) }
/* Helper function ************************************************/ -static u8 stm32prog_start(struct stm32prog_data *data, u32 address) +static u8 stm32prog_start(struct stm32prog_data *data, uintptr_t address) { u8 ret = 0; struct dfu_entity *dfu_entity; @@ -353,7 +353,7 @@ static u8 stm32prog_start(struct stm32prog_data *data, u32 address) } else { void (*entry)(void) = (void *)address;
- printf("## Starting application at 0x%x ...\n", address); + printf("## Starting application at 0x%p ...\n", (void *)address); (*entry)(); printf("## Application terminated\n"); ret = -ENOEXEC; @@ -368,9 +368,9 @@ static u8 stm32prog_start(struct stm32prog_data *data, u32 address) * @tmp_xor: Current xor value to update * Return: The address area */ -static u32 get_address(u8 *tmp_xor) +static uintptr_t get_address(u8 *tmp_xor) { - u32 address = 0x0; + uintptr_t address = 0x0; u8 data;
data = stm32prog_serial_getc(); @@ -487,7 +487,7 @@ static void get_phase_command(struct stm32prog_data *data) */ static void read_memory_command(struct stm32prog_data *data) { - u32 address = 0x0; + uintptr_t address = 0x0; u8 rcv_data = 0x0, tmp_xor = 0x0; u32 counter = 0x0;
@@ -532,7 +532,7 @@ static void read_memory_command(struct stm32prog_data *data) */ static void start_command(struct stm32prog_data *data) { - u32 address = 0; + uintptr_t address = 0; u8 tmp_xor = 0x0; u8 ret, rcv_data;
@@ -546,8 +546,7 @@ static void start_command(struct stm32prog_data *data) return; } /* validate partition */ - ret = stm32prog_start(data, - address); + ret = stm32prog_start(data, address);
if (ret) stm32prog_serial_result(ABORT_BYTE); diff --git a/arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog_usb.c b/arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog_usb.c index bcb4d373f69..be38ff239b2 100644 --- a/arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog_usb.c +++ b/arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog_usb.c @@ -41,7 +41,7 @@ static int stm32prog_set_phase(struct stm32prog_data *data, u8 phase, static int stm32prog_cmd_write(u64 offset, void *buf, long *len) { u8 phase; - u32 address; + uintptr_t address; u8 *pt = buf; void (*entry)(void); int ret; @@ -58,7 +58,7 @@ static int stm32prog_cmd_write(u64 offset, void *buf, long *len) address = (pt[1] << 24) | (pt[2] << 16) | (pt[3] << 8) | pt[4]; if (phase == PHASE_RESET) { entry = (void *)address; - printf("## Starting application at 0x%x ...\n", address); + printf("## Starting application at 0x%p ...\n", entry); (*entry)(); printf("## Application terminated\n"); return 0;
Hi Patrick
"0x%x", dtb);
"0x%p", dtb);
"0x%x", uimage);
"0x%p", uimage);
if (initrd) {
}snprintf(initrd_addr, sizeof(initrd_addr) - 1, "0x%p:0x%zx", initrd, data->initrd_size); bootm_argv[2] = initrd_addr;
else if (CONFIG_IS_ENABLED(CMD_BOOTZ)) do_bootz(cmdtp, 0, 4, bootm_argv);if (genimg_get_format(uimage) != IMAGE_FORMAT_INVALID) do_bootm(cmdtp, 0, 4, bootm_argv);
result = -EINVAL; }stm32prog_err("Layout line %d: partition name too long [%zd]: %s", i, strlen(p), p);
ulong addr,
if (result) goto end_otp_read; }(unsigned long)data->otp_part, 0);
- memcpy(buffer, (void *)((uintptr_t)data->otp_part + offset), *size);
- u32 *otp_part;
- u32 uimage;
- u32 dtb;
- u32 initrd;
- u32 initrd_size;
- uintptr_t uimage;
- uintptr_t dtb;
- uintptr_t initrd;
- size_t initrd_size;
- u32 script;
uintptr_t script;
(*entry)(); printf("## Application terminated\n"); ret = -ENOEXEC;printf("## Starting application at 0x%p ...\n", (void *)address);
- @tmp_xor: Current xor value to update
- Return: The address area
- uintptr_t address = 0x0; u8 rcv_data = 0x0, tmp_xor = 0x0; u32 counter = 0x0;
- u32 address = 0;
- uintptr_t address = 0; u8 tmp_xor = 0x0; u8 ret, rcv_data;
address);
- u32 address;
- uintptr_t address; u8 *pt = buf; void (*entry)(void); int ret;
(*entry)(); printf("## Application terminated\n"); return 0;printf("## Starting application at 0x%p ...\n", entry);
Thanks Patrice
As the SMC is only supported in SP-MIN for STM32MP15x, the associated partition should be absent when the TA NVMEM is not available in OPT-TEE in STM32MP13x.
.../mach-stm32mp/cmd_stm32prog/stm32prog.c | 25 +++++++++++++------ .../mach-stm32mp/cmd_stm32prog/stm32prog.h | 5 ++++ 2 files changed, 22 insertions(+), 8 deletions(-)
diff --git a/arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog.c b/arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog.c index 67be1ac7ff8..b151ce10475 100644 --- a/arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog.c +++ b/arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog.c @@ -1342,10 +1342,22 @@ static int dfu_init_entities(struct stm32prog_data *data) struct stm32prog_part_t *part; struct dfu_entity *dfu; int alt_nb; + u32 otp_size = 0;
alt_nb = 1; /* number of virtual = CMD*/ - if (IS_ENABLED(CONFIG_CMD_STM32PROG_OTP)) - alt_nb++; /* OTP*/ + + if (IS_ENABLED(CONFIG_CMD_STM32PROG_OTP)) { + /* OTP_SIZE_SMC = 0 if SMC is not supported */ + otp_size = OTP_SIZE_SMC; + /* check if PTA BSEC is supported */ + ret = optee_ta_open(data); + log_debug("optee_ta_open(PTA_NVMEM) result %d\n", ret); + if (!ret && data->tee) + otp_size = OTP_SIZE_TA; + if (otp_size) + alt_nb++; /* OTP*/ + } + if (CONFIG_IS_ENABLED(DM_PMIC)) alt_nb++; /* PMIC NVMEM*/
@@ -1363,6 +1375,7 @@ static int dfu_init_entities(struct stm32prog_data *data) puts("DFU alt info setting: "); if (data->part_nb) { alt_id = 0; + ret = 0; for (phase = 1; (phase <= PHASE_LAST_USER) && (alt_id < alt_nb) && !ret; @@ -1396,12 +1409,8 @@ static int dfu_init_entities(struct stm32prog_data *data) if (!ret) ret = stm32prog_alt_add_virt(dfu, "virtual", PHASE_CMD, CMD_SIZE);
- if (!ret && IS_ENABLED(CONFIG_CMD_STM32PROG_OTP)) { - ret = optee_ta_open(data); - log_debug("optee_ta result %d\n", ret); - ret = stm32prog_alt_add_virt(dfu, "OTP", PHASE_OTP, - data->tee ? OTP_SIZE_TA : OTP_SIZE_SMC); - } + if (!ret && IS_ENABLED(CONFIG_CMD_STM32PROG_OTP) && otp_size) + ret = stm32prog_alt_add_virt(dfu, "OTP", PHASE_OTP, otp_size);
if (!ret && CONFIG_IS_ENABLED(DM_PMIC)) ret = stm32prog_alt_add_virt(dfu, "PMIC", PHASE_PMIC, PMIC_SIZE); diff --git a/arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog.h b/arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog.h index 397506ac47c..58f4b96fa75 100644 --- a/arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog.h +++ b/arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog.h @@ -20,7 +20,12 @@ #define DEFAULT_ADDRESS 0xFFFFFFFF
#define CMD_SIZE 512 +/* SMC is only supported in SPMIN for STM32MP15x */ +#ifdef CONFIG_STM32MP15x #define OTP_SIZE_SMC 1024 +#else +#define OTP_SIZE_SMC 0 +#endif #define OTP_SIZE_TA 776 #define PMIC_SIZE 8
Hi Patrick
u32 otp_size = 0;
alt_nb++; /* OTP*/
- if (IS_ENABLED(CONFIG_CMD_STM32PROG_OTP)) {
if (otp_size)
alt_nb++; /* OTP*/
- if (CONFIG_IS_ENABLED(DM_PMIC)) alt_nb++; /* PMIC NVMEM*/
for (phase = 1; (phase <= PHASE_LAST_USER) && (alt_id < alt_nb) && !ret;ret = 0;
Thanks Patrice
Hi Patrick
- /* empty flashlayout */
- if (!data->dev_nb)
return;
- /* initialize the selected device */ for (i = 0; i < data->dev_nb; i++) { ret = init_device(data, &data->dev[i]);
Thanks Patrice
Hi Patrick
For the series: applied on u-boot-stm32/next
Thanks Patrice
return;
Patrice CHOTARD
Patrick Delaunay
