Re: [U-Boot] [PATCH] Canyonlands SATA harddisk driver
This patch adds a SATA harddisk driver for the canyonlands. This patch is kernel driver's porting. This pach corresponded to not cmd_scsi but cmd_sata.
[environment variable, boot script] setenv bootargs root=/dev/sda7 rw setenv bootargs ${bootargs} console=ttyS0,115200 ext2load sata 0:2 0x400000 /canyonlands/uImage ext2load sata 0:2 0x800000 /canyonlands/canyonlands.dtb fdt addr 0x800000 0x4000 bootm 0x400000 - 0x800000
If you drive SATA-2 disk on Canyonlands, you must change parts from PI2PCIE212 to PI2PCIE2212 on U25. We confirmed to boot by using following disk.
1.Vender: Fujitsu Type: MHW2040BS 2.Vender: Fujitsu Type: MHW2060BK 3.Vendor: HAGIWARA SYS-COM:HFD25S-032GT 4.Vender: WesternDigital Type: WD3200BJKT (CONFIG_LBA48 required) 5.Vender: WesternDigital Type: WD3200BEVT (CONFIG_LBA48 required) 6.Vender: hitachi Type: HTS543232L9A300 (CONFIG_LBA48 required) 7.Vender: Seagate Type: ST31000333AS (CONFIG_LBA48 required) 8.Vender: Transcend Type: TS32GSSD25S-M 9.Vender: MTRON Type: MSD-SATA1525-016
Signed-off-by: Kazuaki Ichinohe <kazuichi at fsi.co.jp> --- diff -uprN u-boot-0512/drivers/block/Makefile u-boot-sata/drivers/block/Makefile --- u-boot-0512/drivers/block/Makefile 2009-05-12 12:48:38.000000000 +0900 +++ u-boot-sata/drivers/block/Makefile 2009-05-12 14:54:43.000000000 +0900 @@ -31,6 +31,7 @@ COBJS-$(CONFIG_FSL_SATA) += fsl_sata.o COBJS-$(CONFIG_IDE_SIL680) += sil680.o COBJS-$(CONFIG_LIBATA) += libata.o COBJS-$(CONFIG_PATA_BFIN) += pata_bfin.o +COBJS-$(CONFIG_SATA_DWC) += sata_dwc.o COBJS-$(CONFIG_SATA_SIL3114) += sata_sil3114.o COBJS-$(CONFIG_SCSI_AHCI) += ahci.o COBJS-$(CONFIG_SCSI_SYM53C8XX) += sym53c8xx.o diff -uprN u-boot-0512/drivers/block/sata_dwc.c u-boot-sata/drivers/block/sata_dwc.c --- u-boot-0512/drivers/block/sata_dwc.c 1970-01-01 09:00:00.000000000 +0900 +++ u-boot-sata/drivers/block/sata_dwc.c 2009-05-07 09:37:53.000000000 +0900 @@ -0,0 +1,2110 @@ +/* + * sata_dwc.c + * + * Synopsys DesignWare Cores (DWC) SATA host driver + * + * Author: Mark Miesfeld mmiesfeld@amcc.com + * + * Ported from 2.6.19.2 to 2.6.25/26 by Stefan Roese sr@denx.de + * Copyright 2008 DENX Software Engineering + * + * Based on versions provided by AMCC and Synopsys which are: + * Copyright 2006 Applied Micro Circuits Corporation + * COPYRIGHT (C) 2005 SYNOPSYS, INC. ALL RIGHTS RESERVED + * + * This program is free software; you can redistribute + * it and/or modify it under the terms of the GNU + * General Public License as published by the + * Free Software Foundation; either version 2 of the License, + * or (at your option) any later version. + * + */ +/* + * SATA support based on the chip canyonlands. + * + * 04-17-2009 + * The local version of this driver for the canyonlands board + * does not use interrupts but polls the chip instead. + */ + +#include <common.h> +#include <command.h> +#include <pci.h> +#include <asm/processor.h> +#include <asm/errno.h> +#include <asm/io.h> +#include <malloc.h> +#include <ata.h> +#include <linux/ctype.h> + +#include "sata_dwc.h" + +#define DMA_NUM_CHANS 1 +#define DMA_NUM_CHAN_REGS 8 + +#define AHB_DMA_BRST_DFLT 16 + +struct dmareg { + u32 low; + u32 high; +}; + +struct dma_chan_regs { + struct dmareg sar; + struct dmareg dar; + struct dmareg llp; + struct dmareg ctl; + struct dmareg sstat; + struct dmareg dstat; + struct dmareg sstatar; + struct dmareg dstatar; + struct dmareg cfg; + struct dmareg sgr; + struct dmareg dsr; +}; + +struct dma_interrupt_regs { + struct dmareg tfr; + struct dmareg block; + struct dmareg srctran; + struct dmareg dsttran; + struct dmareg error; +}; + +struct ahb_dma_regs { + struct dma_chan_regs chan_regs[DMA_NUM_CHAN_REGS]; + struct dma_interrupt_regs interrupt_raw; + struct dma_interrupt_regs interrupt_status; + struct dma_interrupt_regs interrupt_mask; + struct dma_interrupt_regs interrupt_clear; + struct dmareg statusInt; + struct dmareg rq_srcreg; + struct dmareg rq_dstreg; + struct dmareg rq_sgl_srcreg; + struct dmareg rq_sgl_dstreg; + struct dmareg rq_lst_srcreg; + struct dmareg rq_lst_dstreg; + struct dmareg dma_cfg; + struct dmareg dma_chan_en; + struct dmareg dma_id; + struct dmareg dma_test; + struct dmareg res1; + struct dmareg res2; + /* DMA Comp Params + * Param 6 = dma_param[0], Param 5 = dma_param[1], + * Param 4 = dma_param[2] ... + */ + struct dmareg dma_params[6]; +}; + +#define DMA_EN 0x00000001 +#define DMA_DI 0x00000000 +#define DMA_CHANNEL(ch) (0x00000001 << (ch)) +#define DMA_ENABLE_CHAN(ch) ((0x00000001 << (ch)) | \ + ((0x000000001 << (ch)) << 8)) +#define DMA_DISABLE_CHAN(ch) (0x00000000 | \ + ((0x000000001 << (ch)) << 8)) + +#define SATA_DWC_MAX_PORTS 1 +#define SATA_DWC_SCR_OFFSET 0x24 +#define SATA_DWC_REG_OFFSET 0x64 + +struct sata_dwc_regs { + u32 fptagr; + u32 fpbor; + u32 fptcr; + u32 dmacr; + u32 dbtsr; + u32 intpr; + u32 intmr; + u32 errmr; + u32 llcr; + u32 phycr; + u32 physr; + u32 rxbistpd; + u32 rxbistpd1; + u32 rxbistpd2; + u32 txbistpd; + u32 txbistpd1; + u32 txbistpd2; + u32 bistcr; + u32 bistfctr; + u32 bistsr; + u32 bistdecr; + u32 res[15]; + u32 testr; + u32 versionr; + u32 idr; + u32 unimpl[192]; + u32 dmadr[256]; +}; + +#define SATA_DWC_TXFIFO_DEPTH 0x01FF +#define SATA_DWC_RXFIFO_DEPTH 0x01FF + +#define SATA_DWC_DBTSR_MWR(size) ((size / 4) & SATA_DWC_TXFIFO_DEPTH) +#define SATA_DWC_DBTSR_MRD(size) (((size / 4) & \ + SATA_DWC_RXFIFO_DEPTH) << 16) +#define SATA_DWC_INTPR_DMAT 0x00000001 +#define SATA_DWC_INTPR_NEWFP 0x00000002 +#define SATA_DWC_INTPR_PMABRT 0x00000004 +#define SATA_DWC_INTPR_ERR 0x00000008 +#define SATA_DWC_INTPR_NEWBIST 0x00000010 +#define SATA_DWC_INTPR_IPF 0x10000000 +#define SATA_DWC_INTMR_DMATM 0x00000001 +#define SATA_DWC_INTMR_NEWFPM 0x00000002 +#define SATA_DWC_INTMR_PMABRTM 0x00000004 +#define SATA_DWC_INTMR_ERRM 0x00000008 +#define SATA_DWC_INTMR_NEWBISTM 0x00000010 + +#define SATA_DWC_DMACR_TMOD_TXCHEN 0x00000004 +#define SATA_DWC_DMACR_TXRXCH_CLEAR SATA_DWC_DMACR_TMOD_TXCHEN + +#define SATA_DWC_QCMD_MAX 32 + +#define SATA_DWC_SERROR_ERR_BITS 0x0FFF0F03 + +#define HSDEVP_FROM_AP(ap) (struct sata_dwc_device_port*) \ + (ap)->private_data + +struct sata_dwc_device { + struct device *dev; + struct ata_probe_ent *pe; + struct ata_host *host; + u8 *reg_base; + struct sata_dwc_regs *sata_dwc_regs; + int irq_dma; +}; + +struct sata_dwc_device_port { + struct sata_dwc_device *hsdev; + int cmd_issued[SATA_DWC_QCMD_MAX]; + u32 dma_chan[SATA_DWC_QCMD_MAX]; + int dma_pending[SATA_DWC_QCMD_MAX]; +}; + +enum { + SATA_DWC_CMD_ISSUED_NOT = 0, + SATA_DWC_CMD_ISSUED_PEND = 1, + SATA_DWC_CMD_ISSUED_EXEC = 2, + SATA_DWC_CMD_ISSUED_NODATA = 3, + + SATA_DWC_DMA_PENDING_NONE = 0, + SATA_DWC_DMA_PENDING_TX = 1, + SATA_DWC_DMA_PENDING_RX = 2, +}; + +#define msleep(a) udelay(a * 1000) +#define ssleep(a) msleep(a * 1000) + +static int ata_probe_timeout = (ATA_TMOUT_INTERNAL / 100); + +enum sata_dev_state { + SATA_INIT = 0, + SATA_READY = 1, + SATA_NODEVICE = 2, + SATA_ERROR = 3, +}; +enum sata_dev_state dev_state = SATA_INIT; + +static struct ahb_dma_regs *sata_dma_regs = 0; +static struct ata_host *phost; +static struct ata_port ap; +static struct ata_port *pap = ≈ +static struct ata_device ata_device; +static struct sata_dwc_device_port dwc_devp; + +static void *scr_addr_sstatus; +static u32 temp_n_block = 0; + +static unsigned ata_exec_internal(struct ata_device *dev, + struct ata_taskfile *tf, const u8 *cdb, + int dma_dir, unsigned int buflen, + unsigned long timeout); +static unsigned int ata_dev_set_feature(struct ata_device *dev, + u8 enable,u8 feature); +static unsigned int ata_dev_init_params(struct ata_device *dev, + u16 heads, u16 sectors); +static u8 ata_irq_on(struct ata_port *ap); +static struct ata_queued_cmd *__ata_qc_from_tag(struct ata_port *ap, + unsigned int tag); +static int ata_hsm_move(struct ata_port *ap, struct ata_queued_cmd *qc, + u8 status, int in_wq); +static void ata_tf_to_host(struct ata_port *ap, + const struct ata_taskfile *tf); +static void ata_exec_command(struct ata_port *ap, + const struct ata_taskfile *tf); +static unsigned int ata_qc_issue_prot(struct ata_queued_cmd *qc); +static u8 ata_check_altstatus(struct ata_port *ap); +static u8 ata_check_status(struct ata_port *ap); +static void ata_dev_select(struct ata_port *ap, unsigned int device, + unsigned int wait, unsigned int can_sleep); +static void ata_qc_issue(struct ata_queued_cmd *qc); +static void ata_tf_load(struct ata_port *ap, + const struct ata_taskfile *tf); +static int ata_dev_read_sectors(unsigned char* pdata, + unsigned long datalen, u32 block, u32 n_block); +static int ata_dev_write_sectors(unsigned char* pdata, + unsigned long datalen , u32 block, u32 n_block); +static void ata_std_dev_select(struct ata_port *ap, unsigned int device); +static void ata_qc_complete(struct ata_queued_cmd *qc); +static void __ata_qc_complete(struct ata_queued_cmd *qc); +static void fill_result_tf(struct ata_queued_cmd *qc); +static void ata_tf_read(struct ata_port *ap, struct ata_taskfile *tf); +static void ata_mmio_data_xfer(struct ata_device *dev, + unsigned char *buf, + unsigned int buflen,int do_write); +static void ata_pio_task(struct ata_port *arg_ap); +static void __ata_port_freeze(struct ata_port *ap); +static int ata_port_freeze(struct ata_port *ap); +static void ata_qc_free(struct ata_queued_cmd *qc); +static void ata_pio_sectors(struct ata_queued_cmd *qc); +static void ata_pio_sector(struct ata_queued_cmd *qc); +static void ata_pio_queue_task(struct ata_port *ap, + void *data,unsigned long delay); +static void ata_hsm_qc_complete(struct ata_queued_cmd *qc, int in_wq); +static int sata_dwc_softreset(struct ata_port *ap); +static int ata_dev_read_id(struct ata_device *dev, unsigned int *p_class, + unsigned int flags, u16 *id); +static int check_sata_dev_state(void); + +extern block_dev_desc_t sata_dev_desc[CONFIG_SYS_SATA_MAX_DEVICE]; + +static const struct ata_port_info sata_dwc_port_info[] = { + { + .flags = ATA_FLAG_SATA | ATA_FLAG_NO_LEGACY | + ATA_FLAG_MMIO | ATA_FLAG_PIO_POLLING | + ATA_FLAG_SRST | ATA_FLAG_NCQ, + .pio_mask = 0x1f, + .mwdma_mask = 0x07, + .udma_mask = 0x7f, + }, +}; + +int init_sata (int dev) +{ + struct sata_dwc_device hsdev; + struct ata_host host; + struct ata_port_info pi = sata_dwc_port_info[0]; + struct ata_link *link; + struct sata_dwc_device_port hsdevp = dwc_devp; + u8 *base = 0; + u8 *sata_dma_regs_addr = 0; + u8 status; + unsigned long base_addr = 0; + int chan = 0; + int rc; + int i; + + phost = &host; + + base = (u8*)SATA_BASE_ADDR; + + hsdev.sata_dwc_regs = (void *__iomem)(base + SATA_DWC_REG_OFFSET); + + host.n_ports = SATA_DWC_MAX_PORTS; + + for (i = 0; i < SATA_DWC_MAX_PORTS; i++) { + ap.pflags |= ATA_PFLAG_INITIALIZING; + ap.flags = ATA_FLAG_DISABLED; + ap.print_id = -1; + ap.ctl = ATA_DEVCTL_OBS; + ap.host = &host; + ap.last_ctl = 0xFF; + + link = &ap.link; + link->ap = ≈ + link->pmp = 0; + link->active_tag = ATA_TAG_POISON; + link->hw_sata_spd_limit = 0; + + ap.port_no = i; + host.ports[i] = ≈ + } + + ap.pio_mask = pi.pio_mask; + ap.mwdma_mask = pi.mwdma_mask; + ap.udma_mask = pi.udma_mask; + ap.flags |= pi.flags; + ap.link.flags |= pi.link_flags; + + host.ports[0]->ioaddr.cmd_addr = base; + host.ports[0]->ioaddr.scr_addr = base + SATA_DWC_SCR_OFFSET; + scr_addr_sstatus = base + SATA_DWC_SCR_OFFSET; + + base_addr = (unsigned long)base; + + host.ports[0]->ioaddr.cmd_addr = (void *)base_addr + 0x00; + host.ports[0]->ioaddr.data_addr = (void *)base_addr + 0x00; + + host.ports[0]->ioaddr.error_addr = (void *)base_addr + 0x04; + host.ports[0]->ioaddr.feature_addr = (void *)base_addr + 0x04; + + host.ports[0]->ioaddr.nsect_addr = (void *)base_addr + 0x08; + + host.ports[0]->ioaddr.lbal_addr = (void *)base_addr + 0x0c; + host.ports[0]->ioaddr.lbam_addr = (void *)base_addr + 0x10; + host.ports[0]->ioaddr.lbah_addr = (void *)base_addr + 0x14; + + host.ports[0]->ioaddr.device_addr = (void *)base_addr + 0x18; + host.ports[0]->ioaddr.command_addr = (void *)base_addr + 0x1c; + host.ports[0]->ioaddr.status_addr = (void *)base_addr + 0x1c; + + host.ports[0]->ioaddr.altstatus_addr = (void *)base_addr + 0x20; + host.ports[0]->ioaddr.ctl_addr = (void *)base_addr + 0x20; + + sata_dma_regs_addr = (u8*)SATA_DMA_REG_ADDR; + sata_dma_regs = (void *__iomem)sata_dma_regs_addr; + + status = ata_check_altstatus(&ap); + + if (status == 0x7f) { + printf("Hard Disk not found.\n"); + dev_state = SATA_NODEVICE; + rc = FALSE; + return rc; + } + + printf("waitng for device ready."); + i = 0; + while (1) { + udelay (10000); + + status = ata_check_altstatus(&ap); + + if ((status & ATA_BUSY) == 0) { + printf("\n"); + break; + } + + i++; + if (i > (ATA_RESET_TIME * 100)) { + printf("** TimeOUT **\n"); + + dev_state = SATA_NODEVICE; + rc = FALSE; + return rc; + } + if ((i >= 100) && ((i % 100) == 0)) + printf("."); + } + + rc = sata_dwc_softreset(&ap); + + if (rc) { + printf("sata_dwc : error. soft reset failed\n"); + return rc; + } + + for (chan = 0; chan < DMA_NUM_CHANS; chan++) { + out_le32(&(sata_dma_regs->interrupt_mask.error.low), + DMA_DISABLE_CHAN(chan)); + + out_le32(&(sata_dma_regs->interrupt_mask.tfr.low), + DMA_DISABLE_CHAN(chan)); + } + + out_le32(&(sata_dma_regs->dma_cfg.low), DMA_DI); + + out_le32(&hsdev.sata_dwc_regs->intmr, + SATA_DWC_INTMR_ERRM | + SATA_DWC_INTMR_PMABRTM); + + /* Unmask the error bits that should trigger + * an error interrupt by setting the error mask register. + */ + out_le32(&hsdev.sata_dwc_regs->errmr,SATA_DWC_SERROR_ERR_BITS); + + hsdev.host = ap.host; + memset(&hsdevp, 0, sizeof(hsdevp)); + hsdevp.hsdev = &hsdev; + + for (i = 0; i < SATA_DWC_QCMD_MAX; i++) + hsdevp.cmd_issued[i] = SATA_DWC_CMD_ISSUED_NOT; + + out_le32((void __iomem *)scr_addr_sstatus + 4, + in_le32((void __iomem *)scr_addr_sstatus + 4)); + + rc = 0; + return rc; +} + +static u8 ata_check_altstatus(struct ata_port *ap) +{ + u8 val = 0; + val = readb(ap->ioaddr.altstatus_addr); + return val; +} + +static int sata_dwc_softreset(struct ata_port *ap) +{ + u8 nsect,lbal = 0; + u8 tmp = 0; + u32 serror = 0; + u8 status = 0; + struct ata_ioports *ioaddr = &ap->ioaddr; + + serror = in_le32((void *)ap->ioaddr.scr_addr + (SCR_ERROR * 4)); + + writeb(0x55, ioaddr->nsect_addr); + writeb(0xaa, ioaddr->lbal_addr); + writeb(0xaa, ioaddr->nsect_addr); + writeb(0x55, ioaddr->lbal_addr); + writeb(0x55, ioaddr->nsect_addr); + writeb(0xaa, ioaddr->lbal_addr); + + nsect = readb(ioaddr->nsect_addr); + lbal = readb(ioaddr->lbal_addr); + + if ((nsect == 0x55) && (lbal == 0xaa)) { + printf("we found a device\n"); + } else { + printf("Not found a device.\n"); + dev_state = SATA_NODEVICE; + return FALSE; + } + + tmp = ATA_DEVICE_OBS; + writeb(tmp,ioaddr->device_addr); + writeb(ap->ctl,ioaddr->ctl_addr); + + udelay(200); + + writeb(ap->ctl | ATA_SRST, ioaddr->ctl_addr); + + udelay(200); + writeb(ap->ctl,ioaddr->ctl_addr); + + msleep(150); + status = ata_check_status(ap); + + msleep(50); + ata_check_status(ap); + + while (1) { + u8 status = ata_check_status(ap); + + if (!(status & ATA_BUSY)) + break; + + printf("Hard Disk status is BUSY.\n"); + msleep(50); + } + + tmp = ATA_DEVICE_OBS; + writeb(tmp,ioaddr->device_addr); + + nsect = readb(ioaddr->nsect_addr); + lbal = readb(ioaddr->lbal_addr); + + return 0; +} + +static u8 ata_check_status(struct ata_port *ap) +{ + u8 val = 0; + val = readb(ap->ioaddr.status_addr); + return val; +} + +static int ata_id_has_hipm(const u16 *id) +{ + u16 val = id[76]; + + if (val == 0 || val == 0xffff) + return -1; + + return val & (1 << 9); +} + +static int ata_id_has_dipm(const u16 *id) +{ + u16 val = id[78]; + + if (val == 0 || val == 0xffff) + return -1; + + return val & (1 << 3); +} + +int scan_sata (int dev) +{ + int i; + int rc; + u8 status; + const u16 *id; + struct ata_device *ata_dev = &ata_device; + unsigned long pio_mask, mwdma_mask, udma_mask; + unsigned long xfer_mask; + char revbuf[7]; + u16 iobuf[ATA_SECTOR_WORDS]; + + memset ( iobuf, 0, sizeof(iobuf)); + + if (dev_state == SATA_NODEVICE) + return 1; + + printf("waitng for device ready."); + i = 0; + while (1) { + udelay (10000); + + status = ata_check_altstatus(&ap); + + if ((status & ATA_BUSY) == 0) { + printf("\n"); + break; + } + + i++; + if (i > (ATA_RESET_TIME * 100)) { + printf("** TimeOUT **\n"); + + dev_state = SATA_NODEVICE; + return 1; + } + if ((i >= 100) && ((i % 100) == 0)) + printf("."); + } + + udelay (1000); + + rc = ata_dev_read_id(ata_dev, &ata_dev->class, + ATA_READID_POSTRESET,ata_dev->id); + if (rc) { + printf("sata_dwc : error. failed sata scan\n"); + return 1; + } + + /* SATA drives indicate we have a bridge. We don't know which + * end of the link the bridge is which is a problem + */ + if (ata_id_is_sata(ata_dev->id)) + ap.cbl = ATA_CBL_SATA; + + id = ata_dev->id; + + ata_dev->flags &= ~ATA_DFLAG_CFG_MASK; + ata_dev->max_sectors = 0; + ata_dev->cdb_len = 0; + ata_dev->n_sectors = 0; + ata_dev->cylinders = 0; + ata_dev->heads = 0; + ata_dev->sectors = 0; + + if (id[ATA_ID_FIELD_VALID] & (1 << 1)) { + pio_mask = id[ATA_ID_PIO_MODES] & 0x03; + pio_mask <<= 3; + pio_mask |= 0x7; + } else { + /* If word 64 isn't valid then Word 51 high byte holds + * the PIO timing number for the maximum. Turn it into + * a mask. + */ + u8 mode = (id[ATA_ID_OLD_PIO_MODES] >> 8) & 0xFF; + if (mode < 5) { + pio_mask = (2 << mode) - 1; + } else { + pio_mask = 1; + } + } + + mwdma_mask = id[ATA_ID_MWDMA_MODES] & 0x07; + + if (ata_id_is_cfa(id)) { + int pio = id[163] & 0x7; + int dma = (id[163] >> 3) & 7; + + if (pio) + pio_mask |= (1 << 5); + if (pio > 1) + pio_mask |= (1 << 6); + if (dma) + mwdma_mask |= (1 << 3); + if (dma > 1) + mwdma_mask |= (1 << 4); + } + + udma_mask = 0; + if (id[ATA_ID_FIELD_VALID] & (1 << 2)) + udma_mask = id[ATA_ID_UDMA_MODES] & 0xff; + + xfer_mask = ((pio_mask << ATA_SHIFT_PIO) & ATA_MASK_PIO) | + ((mwdma_mask << ATA_SHIFT_MWDMA) & ATA_MASK_MWDMA) | + ((udma_mask << ATA_SHIFT_UDMA) & ATA_MASK_UDMA); + + if (ata_dev->class == ATA_DEV_ATA) { + if (ata_id_is_cfa(id)) { + if (id[162] & 1) + printf("supports DRM functions and may " + "not be fully accessable.\n"); + sprintf(revbuf, "%s", "CFA"); + } else { + if (ata_id_has_tpm(id)) + printf("supports DRM functions and may " + "not be fully accessable.\n"); + } + + ata_dev->n_sectors = ata_id_n_sectors((u16*)id); + + if (ata_dev->id[59] & 0x100) + ata_dev->multi_count = ata_dev->id[59] & 0xff; + + if (ata_id_has_lba(id)) { + const char *lba_desc; + char ncq_desc[20]; + + lba_desc = "LBA"; + ata_dev->flags |= ATA_DFLAG_LBA; + if (ata_id_has_lba48(id)) { + ata_dev->flags |= ATA_DFLAG_LBA48; + lba_desc = "LBA48"; + + if (ata_dev->n_sectors >= (1UL << 28) && + ata_id_has_flush_ext(id)) + ata_dev->flags |= ATA_DFLAG_FLUSH_EXT; + } + if (!ata_id_has_ncq(ata_dev->id)) + ncq_desc[0] = '\0'; + + if (ata_dev->horkage & ATA_HORKAGE_NONCQ) + sprintf(ncq_desc, "%s", "NCQ (not used)"); + + if (ap.flags & ATA_FLAG_NCQ) + ata_dev->flags |= ATA_DFLAG_NCQ; + } + ata_dev->cdb_len = 16; + } + ata_dev->max_sectors = ATA_MAX_SECTORS; + if (ata_dev->flags & ATA_DFLAG_LBA48) + ata_dev->max_sectors = ATA_MAX_SECTORS_LBA48; + + if (!(ata_dev->horkage & ATA_HORKAGE_IPM)) { + if (ata_id_has_hipm(ata_dev->id)) + ata_dev->flags |= ATA_DFLAG_HIPM; + if (ata_id_has_dipm(ata_dev->id)) + ata_dev->flags |= ATA_DFLAG_DIPM; + } + + if ((ap.cbl == ATA_CBL_SATA) && (!ata_id_is_sata(ata_dev->id))) { + ata_dev->udma_mask &= ATA_UDMA5; + ata_dev->max_sectors = ATA_MAX_SECTORS; + } + + if (ata_dev->horkage & ATA_HORKAGE_DIAGNOSTIC) { + printf("Drive reports diagnostics failure." + "This may indicate a drive\n"); + printf("fault or invalid emulation." + "Contact drive vendor for information.\n"); + } + + rc = check_sata_dev_state(); + + ata_id_c_string (ata_dev->id, + (unsigned char *)sata_dev_desc[dev].revision, + ATA_ID_FW_REV, sizeof(sata_dev_desc[dev].revision)); + ata_id_c_string (ata_dev->id, + (unsigned char *)sata_dev_desc[dev].vendor, + ATA_ID_PROD, sizeof(sata_dev_desc[dev].vendor)); + ata_id_c_string (ata_dev->id, + (unsigned char *)sata_dev_desc[dev].product, + ATA_ID_SERNO, sizeof(sata_dev_desc[dev].product)); + + sata_dev_desc[dev].lba = (u32) ata_dev->n_sectors; + +#ifdef CONFIG_LBA48 + if (ata_dev->id[83] & (1 << 10)) { + sata_dev_desc[dev].lba48 = 1; + } else { + sata_dev_desc[dev].lba48 = 0; + } +#endif + + return 0; +} + +static u8 ata_busy_wait(struct ata_port *ap, + unsigned int bits,unsigned int max) +{ + u8 status; + + do { + udelay(10); + status = ata_check_status(ap); + max--; + } while (status != 0xff && (status & bits) && (max > 0)); + + return status; +} + +static int ata_dev_read_id(struct ata_device *dev, unsigned int *p_class, + unsigned int flags, u16 *id) +{ + struct ata_port *ap = pap; + unsigned int class = *p_class; + struct ata_taskfile tf; + unsigned int err_mask = 0; + const char *reason; + int may_fallback = 1, tried_spinup = 0; + u8 status; + int rc; + + status = ata_busy_wait(ap, ATA_BUSY, 30000); + if (status & ATA_BUSY) { + printf("BSY = 0 check. timeout.\n"); + rc = FALSE; + return rc; + } + + ata_dev_select(ap, dev->devno, 1, 1); + +retry: + memset(&tf, 0, sizeof(tf)); + ap->print_id = 1; + ap->flags &= ~ATA_FLAG_DISABLED; + tf.ctl = ap->ctl; + tf.device = ATA_DEVICE_OBS; + tf.command = ATA_CMD_ID_ATA; + tf.protocol = ATA_PROT_PIO; + + /* Some devices choke if TF registers contain garbage. Make + * sure those are properly initialized. + */ + tf.flags |= ATA_TFLAG_ISADDR | ATA_TFLAG_DEVICE; + + /* Device presence detection is unreliable on some + * controllers. Always poll IDENTIFY if available. + */ + tf.flags |= ATA_TFLAG_POLLING; + + temp_n_block = 1; + + err_mask = ata_exec_internal(dev, &tf, NULL, DMA_FROM_DEVICE, + sizeof(id[0]) * ATA_ID_WORDS, 0); + + if (err_mask) { + if (err_mask & AC_ERR_NODEV_HINT) { + printf("NODEV after polling detection\n"); + return -ENOENT; + } + + if ((err_mask == AC_ERR_DEV) && (tf.feature & ATA_ABORTED)) { + /* Device or controller might have reported + * the wrong device class. Give a shot at the + * other IDENTIFY if the current one is + * aborted by the device. + */ + if (may_fallback) { + may_fallback = 0; + + if (class == ATA_DEV_ATA) { + class = ATA_DEV_ATAPI; + } else { + class = ATA_DEV_ATA; + } + goto retry; + } + /* Control reaches here iff the device aborted + * both flavors of IDENTIFYs which happens + * sometimes with phantom devices. + */ + printf("both IDENTIFYs aborted, assuming NODEV\n"); + return -ENOENT; + } + rc = -EIO; + reason = "I/O error"; + goto err_out; + } + + /* Falling back doesn't make sense if ID data was read + * successfully at least once. + */ + may_fallback = 0; + + unsigned int id_cnt; + + for (id_cnt = 0; id_cnt < ATA_ID_WORDS; id_cnt++) + id[id_cnt] = le16_to_cpu(id[id_cnt]); + + + rc = -EINVAL; + reason = "device reports invalid type"; + + if (class == ATA_DEV_ATA) { + if (!ata_id_is_ata(id) && !ata_id_is_cfa(id)) + goto err_out; + } else { + if (ata_id_is_ata(id)) + goto err_out; + } + if (!tried_spinup && (id[2] == 0x37c8 || id[2] == 0x738c)) { + tried_spinup = 1; + /* + * Drive powered-up in standby mode, and requires a specific + * SET_FEATURES spin-up subcommand before it will accept + * anything other than the original IDENTIFY command. + */ + err_mask = ata_dev_set_feature(dev, SETFEATURES_SPINUP, 0); + if (err_mask && id[2] != 0x738c) { + rc = -EIO; + reason = "SPINUP failed"; + goto err_out; + } + /* + * If the drive initially returned incomplete IDENTIFY info, + * we now must reissue the IDENTIFY command. + */ + if (id[2] == 0x37c8) + goto retry; + } + + if ((flags & ATA_READID_POSTRESET) && class == ATA_DEV_ATA) { + /* + * The exact sequence expected by certain pre-ATA4 drives is: + * SRST RESET + * IDENTIFY (optional in early ATA) + * INITIALIZE DEVICE PARAMETERS (later IDE and ATA) + * anything else.. + * Some drives were very specific about that exact sequence. + * + * Note that ATA4 says lba is mandatory so the second check + * shoud never trigger. + */ + if (ata_id_major_version(id) < 4 || !ata_id_has_lba(id)) { + err_mask = ata_dev_init_params(dev, id[3], id[6]); + if (err_mask) { + rc = -EIO; + reason = "INIT_DEV_PARAMS failed"; + goto err_out; + } + + /* current CHS translation info (id[53-58]) might be + * changed. reread the identify device info. + */ + flags &= ~ATA_READID_POSTRESET; + goto retry; + } + } + + *p_class = class; + return 0; + +err_out: + return rc; +} + +static u8 ata_wait_idle(struct ata_port *ap) +{ + u8 status = ata_busy_wait(ap, ATA_BUSY | ATA_DRQ, 1000); + return status; +} + +static void ata_dev_select(struct ata_port *ap, unsigned int device, + unsigned int wait, unsigned int can_sleep) +{ + if (wait) + ata_wait_idle(ap); + + ata_std_dev_select(ap, device); + + if (wait) + ata_wait_idle(ap); +} + +static void ata_std_dev_select(struct ata_port *ap, unsigned int device) +{ + u8 tmp; + + if (device == 0) { + tmp = ATA_DEVICE_OBS; + } else { + tmp = ATA_DEVICE_OBS | ATA_DEV1; + } + + writeb(tmp, ap->ioaddr.device_addr); + + readb(ap->ioaddr.altstatus_addr); + + udelay(1); +} + +static int waiting_for_reg_state(volatile u8 *offset, + int timeout_msec, + u32 sign) +{ + int i; + u32 status; + + for (i = 0; i < timeout_msec; i++) { + status = readl(offset); + if ((status & sign) != 0) + break; + msleep(1); + } + + return (i < timeout_msec) ? 0 : -1; +} + +static void ata_qc_reinit(struct ata_queued_cmd *qc) +{ + qc->dma_dir = DMA_NONE; + qc->flags = 0; + qc->nbytes = qc->extrabytes = qc->curbytes = 0; + qc->n_elem = 0; + qc->err_mask = 0; + qc->sect_size = ATA_SECT_SIZE; + qc->nbytes = ATA_SECT_SIZE * temp_n_block; + + memset(&qc->tf, 0, sizeof(qc->tf)); + qc->tf.ctl = 0; + qc->tf.device = ATA_DEVICE_OBS; + + qc->result_tf.command = ATA_DRDY; + qc->result_tf.feature = 0; +} + +struct ata_queued_cmd *__ata_qc_from_tag(struct ata_port *ap, + unsigned int tag) +{ + if (tag < ATA_MAX_QUEUE) + return &ap->qcmd[tag]; + return NULL; +} + +static void __ata_port_freeze(struct ata_port *ap) +{ + printf("set port freeze.\n"); + ap->pflags |= ATA_PFLAG_FROZEN; +} + +static int ata_port_freeze(struct ata_port *ap) +{ + __ata_port_freeze(ap); + return 0; +} + +unsigned ata_exec_internal(struct ata_device *dev, + struct ata_taskfile *tf, const u8 *cdb, + int dma_dir, unsigned int buflen, + unsigned long timeout) +{ + struct ata_link *link = dev->link; + struct ata_port *ap = pap; + struct ata_queued_cmd *qc; + unsigned int tag, preempted_tag; + u32 preempted_sactive, preempted_qc_active; + int preempted_nr_active_links; + unsigned int err_mask; + int rc = 0; + u8 status; + + status = ata_busy_wait(ap, ATA_BUSY, 300000); + if (status & ATA_BUSY) { + printf("BSY = 0 check. timeout.\n"); + rc = FALSE; + return rc; + } + + if (ap->pflags & ATA_PFLAG_FROZEN) + return AC_ERR_SYSTEM; + + tag = ATA_TAG_INTERNAL; + + if (test_and_set_bit(tag, &ap->qc_allocated)) { + rc = FALSE; + return rc; + } + + qc = __ata_qc_from_tag(ap, tag); + qc->tag = tag; + qc->ap = ap; + qc->dev = dev; + + ata_qc_reinit(qc); + + preempted_tag = link->active_tag; + preempted_sactive = link->sactive; + preempted_qc_active = ap->qc_active; + preempted_nr_active_links = ap->nr_active_links; + link->active_tag = ATA_TAG_POISON; + link->sactive = 0; + ap->qc_active = 0; + ap->nr_active_links = 0; + + qc->tf = *tf; + if (cdb) + memcpy(qc->cdb, cdb, ATAPI_CDB_LEN); + qc->flags |= ATA_QCFLAG_RESULT_TF; + qc->dma_dir = dma_dir; + qc->private_data = 0; + + ata_qc_issue(qc); + + if (!timeout) + timeout = ata_probe_timeout * 1000 / HZ; + + status = ata_busy_wait(ap, ATA_BUSY, 30000); + if (status & ATA_BUSY) { + printf("BSY = 0 check. timeout.\n"); + printf("altstatus = 0x%x.\n",status); + qc->err_mask |= AC_ERR_OTHER; + return qc->err_mask; + } + + if (waiting_for_reg_state(ap->ioaddr.altstatus_addr,1000,0x8)) { + u8 status = 0; + u8 errorStatus = 0; + + status = readb( ap->ioaddr.altstatus_addr); + if ((status & 0x01) != 0) { + errorStatus = readb( ap->ioaddr.feature_addr); + if (errorStatus == 0x04 && + qc->tf.command == ATA_CMD_PIO_READ_EXT){ + printf("Hard Disk doesn't support LBA48\n"); + dev_state = SATA_ERROR; + qc->err_mask |= AC_ERR_OTHER; + return qc->err_mask; + } + } + qc->err_mask |= AC_ERR_OTHER; + return qc->err_mask; + } + + status = ata_busy_wait(ap, ATA_BUSY, 10); + if (status & ATA_BUSY) { + printf("BSY = 0 check. timeout.\n"); + qc->err_mask |= AC_ERR_OTHER; + return qc->err_mask; + } + + ata_pio_task(ap); + + if (!rc) { + if (qc->flags & ATA_QCFLAG_ACTIVE) { + qc->err_mask |= AC_ERR_TIMEOUT; + ata_port_freeze(ap); + } + } + + if (qc->flags & ATA_QCFLAG_FAILED) { + if (qc->result_tf.command & (ATA_ERR | ATA_DF)) + qc->err_mask |= AC_ERR_DEV; + + if (!qc->err_mask) + qc->err_mask |= AC_ERR_OTHER; + + if (qc->err_mask & ~AC_ERR_OTHER) + qc->err_mask &= ~AC_ERR_OTHER; + } + + *tf = qc->result_tf; + err_mask = qc->err_mask; + ata_qc_free(qc); + link->active_tag = preempted_tag; + link->sactive = preempted_sactive; + ap->qc_active = preempted_qc_active; + ap->nr_active_links = preempted_nr_active_links; + + if (ap->flags & ATA_FLAG_DISABLED) { + err_mask |= AC_ERR_SYSTEM; + ap->flags &= ~ATA_FLAG_DISABLED; + } + + return err_mask; +} + +static void ata_qc_issue(struct ata_queued_cmd *qc) +{ + struct ata_port *ap = qc->ap; + struct ata_link *link = qc->dev->link; + u8 prot = qc->tf.protocol; + + if (ata_is_ncq(prot)) { + if (!link->sactive) + ap->nr_active_links++; + link->sactive |= 1 << qc->tag; + } else { + ap->nr_active_links++; + link->active_tag = qc->tag; + } + + qc->flags |= ATA_QCFLAG_ACTIVE; + ap->qc_active |= 1 << qc->tag; + + if (qc->dev->flags & ATA_DFLAG_SLEEPING) { + msleep(1); + return; + } + + qc->err_mask |= ata_qc_issue_prot(qc); + if (qc->err_mask) + goto err; + + return; +err: + ata_qc_complete(qc); +} + +static unsigned int ata_qc_issue_prot(struct ata_queued_cmd *qc) +{ + struct ata_port *ap = qc->ap; + + if (ap->flags & ATA_FLAG_PIO_POLLING) { + switch (qc->tf.protocol) { + case ATA_PROT_PIO: + case ATA_PROT_NODATA: + case ATAPI_PROT_PIO: + case ATAPI_PROT_NODATA: + qc->tf.flags |= ATA_TFLAG_POLLING; + break; + default: + break; + } + } + + ata_dev_select(ap, qc->dev->devno, 1, 0); + + switch (qc->tf.protocol) { + case ATA_PROT_PIO: + if (qc->tf.flags & ATA_TFLAG_POLLING) + qc->tf.ctl |= ATA_NIEN; + + ata_tf_to_host(ap, &qc->tf); + + ap->hsm_task_state = HSM_ST; + + if (qc->tf.flags & ATA_TFLAG_POLLING) + ata_pio_queue_task(ap, qc, 0); + + break; + + default: + return AC_ERR_SYSTEM; + } + + return 0; +} + +static void ata_tf_to_host(struct ata_port *ap, + const struct ata_taskfile *tf) +{ + ata_tf_load(ap, tf); + ata_exec_command(ap, tf); +} + +static void ata_tf_load(struct ata_port *ap, + const struct ata_taskfile *tf) +{ + struct ata_ioports *ioaddr = &ap->ioaddr; + unsigned int is_addr = tf->flags & ATA_TFLAG_ISADDR; + + if (tf->ctl != ap->last_ctl) { + if (ioaddr->ctl_addr) + writeb(tf->ctl, ioaddr->ctl_addr); + ap->last_ctl = tf->ctl; + ata_wait_idle(ap); + } + + if (is_addr && (tf->flags & ATA_TFLAG_LBA48)) { + writeb(tf->hob_feature, ioaddr->feature_addr); + writeb(tf->hob_nsect, ioaddr->nsect_addr); + writeb(tf->hob_lbal, ioaddr->lbal_addr); + writeb(tf->hob_lbam, ioaddr->lbam_addr); + writeb(tf->hob_lbah, ioaddr->lbah_addr); + } + + if (is_addr) { + writeb(tf->feature, ioaddr->feature_addr); + writeb(tf->nsect, ioaddr->nsect_addr); + writeb(tf->lbal, ioaddr->lbal_addr); + writeb(tf->lbam, ioaddr->lbam_addr); + writeb(tf->lbah, ioaddr->lbah_addr); + } + + if (tf->flags & ATA_TFLAG_DEVICE) + writeb(tf->device, ioaddr->device_addr); + + ata_wait_idle(ap); +} + +static void ata_exec_command(struct ata_port *ap, + const struct ata_taskfile *tf) +{ + writeb(tf->command, ap->ioaddr.command_addr); + + readb(ap->ioaddr.altstatus_addr); + + udelay(1); +} + +static void ata_pio_queue_task(struct ata_port *ap, + void *data,unsigned long delay) +{ + ap->port_task_data = data; +} + +static unsigned int ac_err_mask(u8 status) +{ + if (status & (ATA_BUSY | ATA_DRQ)) + return AC_ERR_HSM; + if (status & (ATA_ERR | ATA_DF)) + return AC_ERR_DEV; + return 0; +} + +static unsigned int __ac_err_mask(u8 status) +{ + unsigned int mask = ac_err_mask(status); + if (mask == 0) + return AC_ERR_OTHER; + return mask; +} + +static void ata_pio_task(struct ata_port *arg_ap) +{ + struct ata_port *ap = arg_ap; + struct ata_queued_cmd *qc = ap->port_task_data; + u8 status; + int poll_next; + +fsm_start: + /* + * This is purely heuristic. This is a fast path. + * Sometimes when we enter, BSY will be cleared in + * a chk-status or two. If not, the drive is probably seeking + * or something. Snooze for a couple msecs, then + * chk-status again. If still busy, queue delayed work. + */ + status = ata_busy_wait(ap, ATA_BUSY, 5); + if (status & ATA_BUSY) { + msleep(2); + status = ata_busy_wait(ap, ATA_BUSY, 10); + if (status & ATA_BUSY) { + ata_pio_queue_task(ap, qc, ATA_SHORT_PAUSE); + return; + } + } + + poll_next = ata_hsm_move(ap, qc, status, 1); + + /* another command or interrupt handler + * may be running at this point. + */ + if (poll_next) + goto fsm_start; +} + +static int ata_hsm_move(struct ata_port *ap, struct ata_queued_cmd *qc, + u8 status, int in_wq) +{ + int poll_next; + +fsm_start: + switch (ap->hsm_task_state) { + case HSM_ST_FIRST: + poll_next = (qc->tf.flags & ATA_TFLAG_POLLING); + + if ((status & ATA_DRQ) == 0) { + if (status & (ATA_ERR | ATA_DF)) { + qc->err_mask |= AC_ERR_DEV; + } else { + qc->err_mask |= AC_ERR_HSM; + } + ap->hsm_task_state = HSM_ST_ERR; + goto fsm_start; + } + + /* Device should not ask for data transfer (DRQ=1) + * when it finds something wrong. + * We ignore DRQ here and stop the HSM by + * changing hsm_task_state to HSM_ST_ERR and + * let the EH abort the command or reset the device. + */ + if (status & (ATA_ERR | ATA_DF)) { + if (!(qc->dev->horkage & ATA_HORKAGE_STUCK_ERR)) { + printf("DRQ=1 with device error, " + "dev_stat 0x%X\n", status); + qc->err_mask |= AC_ERR_HSM; + ap->hsm_task_state = HSM_ST_ERR; + goto fsm_start; + } + } + + if (qc->tf.protocol == ATA_PROT_PIO) { + /* PIO data out protocol. + * send first data block. + */ + /* ata_pio_sectors() might change the state + * to HSM_ST_LAST. so, the state is changed here + * before ata_pio_sectors(). + */ + ap->hsm_task_state = HSM_ST; + ata_pio_sectors(qc); + } else { + printf("protocol is not ATA_PROT_PIO \n"); + } + break; + + case HSM_ST: + if ((status & ATA_DRQ) == 0) { + if (status & (ATA_ERR | ATA_DF)) { + qc->err_mask |= AC_ERR_DEV; + } else { + /* HSM violation. Let EH handle this. + * Phantom devices also trigger this + * condition. Mark hint. + */ + qc->err_mask |= AC_ERR_HSM | AC_ERR_NODEV_HINT; + } + + ap->hsm_task_state = HSM_ST_ERR; + goto fsm_start; + } + /* For PIO reads, some devices may ask for + * data transfer (DRQ=1) alone with ERR=1. + * We respect DRQ here and transfer one + * block of junk data before changing the + * hsm_task_state to HSM_ST_ERR. + * + * For PIO writes, ERR=1 DRQ=1 doesn't make + * sense since the data block has been + * transferred to the device. + */ + if (status & (ATA_ERR | ATA_DF)) { + qc->err_mask |= AC_ERR_DEV; + + if (!(qc->tf.flags & ATA_TFLAG_WRITE)) { + ata_pio_sectors(qc); + status = ata_wait_idle(ap); + } + + if (status & (ATA_BUSY | ATA_DRQ)) + qc->err_mask |= AC_ERR_HSM; + + /* ata_pio_sectors() might change the + * state to HSM_ST_LAST. so, the state + * is changed after ata_pio_sectors(). + */ + ap->hsm_task_state = HSM_ST_ERR; + goto fsm_start; + } + + ata_pio_sectors(qc); + if (ap->hsm_task_state == HSM_ST_LAST && + (!(qc->tf.flags & ATA_TFLAG_WRITE))) { + status = ata_wait_idle(ap); + goto fsm_start; + } + + poll_next = 1; + break; + + case HSM_ST_LAST: + if (!ata_ok(status)) { + qc->err_mask |= __ac_err_mask(status); + ap->hsm_task_state = HSM_ST_ERR; + goto fsm_start; + } + + ap->hsm_task_state = HSM_ST_IDLE; + + ata_hsm_qc_complete(qc, in_wq); + + poll_next = 0; + break; + + case HSM_ST_ERR: + /* make sure qc->err_mask is available to + * know what's wrong and recover + */ + ap->hsm_task_state = HSM_ST_IDLE; + + ata_hsm_qc_complete(qc, in_wq); + + poll_next = 0; + break; + default: + poll_next = 0; + } + + return poll_next; +} + +static void ata_pio_sectors(struct ata_queued_cmd *qc) +{ + struct ata_port *ap; + ap = pap; + qc->pdata = ap->pdata; + + ata_pio_sector(qc); + + readb(qc->ap->ioaddr.altstatus_addr); + udelay(1); +} + +static void ata_pio_sector(struct ata_queued_cmd *qc) +{ + int do_write = (qc->tf.flags & ATA_TFLAG_WRITE); + struct ata_port *ap = qc->ap; + unsigned int offset; + unsigned char *buf; + char temp_data_buf[512]; + + if (qc->curbytes == qc->nbytes - qc->sect_size) + ap->hsm_task_state = HSM_ST_LAST; + + offset = qc->curbytes; + + switch (qc->tf.command) { + case ATA_CMD_ID_ATA: + buf = (unsigned char *)&ata_device.id[0]; + break; + case ATA_CMD_PIO_READ_EXT: + case ATA_CMD_PIO_READ: + case ATA_CMD_PIO_WRITE_EXT: + case ATA_CMD_PIO_WRITE: + buf = qc->pdata + offset; + break; + default: + buf = (unsigned char *)&temp_data_buf[0]; + } + + ata_mmio_data_xfer(qc->dev, buf, qc->sect_size, do_write); + + qc->curbytes += qc->sect_size; + +} + +static void ata_mmio_data_xfer(struct ata_device *dev, unsigned char *buf, + unsigned int buflen, int do_write) +{ + struct ata_port *ap = pap; + void __iomem *data_addr = ap->ioaddr.data_addr; + unsigned int words = buflen >> 1; + u16 *buf16 = (u16 *)buf; + unsigned int i = 0; + + udelay(100); + if (do_write) { + for (i = 0; i < words; i++) + writew(le16_to_cpu(buf16[i]), data_addr); + } else { + for (i = 0; i < words; i++) + buf16[i] = cpu_to_le16(readw(data_addr)); + } + + if (buflen & 0x01) { + __le16 align_buf[1] = { 0 }; + unsigned char *trailing_buf = buf + buflen - 1; + + if (do_write) { + memcpy(align_buf, trailing_buf, 1); + writew(le16_to_cpu(align_buf[0]), data_addr); + } else { + align_buf[0] = cpu_to_le16(readw(data_addr)); + memcpy(trailing_buf, align_buf, 1); + } + } +} + +static void ata_hsm_qc_complete(struct ata_queued_cmd *qc, int in_wq) +{ + struct ata_port *ap = qc->ap; + + if (in_wq) { + /* EH might have kicked in while host lock is + * released. + */ + qc = &ap->qcmd[qc->tag]; + if (qc) { + if (!(qc->err_mask & AC_ERR_HSM)) { + ata_irq_on(ap); + ata_qc_complete(qc); + } else { + ata_port_freeze(ap); + } + } + } else { + if (!(qc->err_mask & AC_ERR_HSM)) { + ata_qc_complete(qc); + } else { + ata_port_freeze(ap); + } + } +} + +static u8 ata_irq_on(struct ata_port *ap) +{ + struct ata_ioports *ioaddr = &ap->ioaddr; + u8 tmp; + + ap->ctl &= ~ATA_NIEN; + ap->last_ctl = ap->ctl; + + if (ioaddr->ctl_addr) + writeb(ap->ctl, ioaddr->ctl_addr); + + tmp = ata_wait_idle(ap); + + return tmp; +} + +static unsigned int ata_tag_internal(unsigned int tag) +{ + return tag == ATA_MAX_QUEUE - 1; +} + +static void ata_qc_complete(struct ata_queued_cmd *qc) +{ + struct ata_device *dev = qc->dev; + if (qc->err_mask) + qc->flags |= ATA_QCFLAG_FAILED; + + if (qc->flags & ATA_QCFLAG_FAILED) { + if (!ata_tag_internal(qc->tag)) { + fill_result_tf(qc); + return; + } + } + if (qc->flags & ATA_QCFLAG_RESULT_TF) + fill_result_tf(qc); + + /* Some commands need post-processing after successful + * completion. + */ + switch (qc->tf.command) { + case ATA_CMD_SET_FEATURES: + if (qc->tf.feature != SETFEATURES_WC_ON && + qc->tf.feature != SETFEATURES_WC_OFF) + break; + case ATA_CMD_INIT_DEV_PARAMS: + case ATA_CMD_SET_MULTI: + break; + + case ATA_CMD_SLEEP: + dev->flags |= ATA_DFLAG_SLEEPING; + break; + } + + __ata_qc_complete(qc); +} + +static void fill_result_tf(struct ata_queued_cmd *qc) +{ + struct ata_port *ap = qc->ap; + + qc->result_tf.flags = qc->tf.flags; + ata_tf_read(ap, &qc->result_tf); +} + +static void ata_tf_read(struct ata_port *ap, struct ata_taskfile *tf) +{ + struct ata_ioports *ioaddr = &ap->ioaddr; + + tf->command = ata_check_status(ap); + tf->feature = readb(ioaddr->error_addr); + tf->nsect = readb(ioaddr->nsect_addr); + tf->lbal = readb(ioaddr->lbal_addr); + tf->lbam = readb(ioaddr->lbam_addr); + tf->lbah = readb(ioaddr->lbah_addr); + tf->device = readb(ioaddr->device_addr); + + if (tf->flags & ATA_TFLAG_LBA48) { + if (ioaddr->ctl_addr) { + writeb(tf->ctl | ATA_HOB, ioaddr->ctl_addr); + + tf->hob_feature = readb(ioaddr->error_addr); + tf->hob_nsect = readb(ioaddr->nsect_addr); + tf->hob_lbal = readb(ioaddr->lbal_addr); + tf->hob_lbam = readb(ioaddr->lbam_addr); + tf->hob_lbah = readb(ioaddr->lbah_addr); + + writeb(tf->ctl, ioaddr->ctl_addr); + ap->last_ctl = tf->ctl; + } else { + printf("sata_dwc warnning register read.\n"); + } + } +} + +static void __ata_qc_complete(struct ata_queued_cmd *qc) +{ + struct ata_port *ap = qc->ap; + struct ata_link *link = qc->dev->link; + + link->active_tag = ATA_TAG_POISON; + ap->nr_active_links--; + + if (qc->flags & ATA_QCFLAG_CLEAR_EXCL && ap->excl_link == link) + ap->excl_link = NULL; + + qc->flags &= ~ATA_QCFLAG_ACTIVE; + ap->qc_active &= ~(1 << qc->tag); +} + +static void ata_qc_free(struct ata_queued_cmd *qc) +{ + struct ata_port *ap = qc->ap; + unsigned int tag; + qc->flags = 0; + tag = qc->tag; + if (tag < ATA_MAX_QUEUE) { + qc->tag = ATA_TAG_POISON; + clear_bit(tag, &ap->qc_allocated); + } +} + +static int check_sata_dev_state(void) +{ + unsigned long datalen; + unsigned char *pdata; + int ret = 0; + int i = 0; + char temp_data_buf[512]; + + while (1) { + udelay (10000); + + pdata = (unsigned char*)&temp_data_buf[0]; + datalen = 512; + + ret = ata_dev_read_sectors(pdata, datalen, 0, 1); + + if (ret == TRUE) + break; + + i++; + if (i > (ATA_RESET_TIME * 100)) { + printf("** TimeOUT **\n"); + dev_state = SATA_NODEVICE; + return FALSE; + } + + if ((i >= 100) && ((i % 100) == 0)) + printf("."); + } + + dev_state = SATA_READY; + + return TRUE; +} + +static unsigned int ata_dev_set_feature(struct ata_device *dev, + u8 enable, u8 feature) +{ + struct ata_taskfile tf; + struct ata_port *ap; + ap = pap; + unsigned int err_mask; + + memset(&tf, 0, sizeof(tf)); + tf.ctl = ap->ctl; + + tf.device = ATA_DEVICE_OBS; + tf.command = ATA_CMD_SET_FEATURES; + tf.feature = enable; + tf.flags |= ATA_TFLAG_ISADDR | ATA_TFLAG_DEVICE; + tf.protocol = ATA_PROT_NODATA; + tf.nsect = feature; + + err_mask = ata_exec_internal(dev, &tf, NULL, DMA_NONE, 0, 0); + + return err_mask; +} + +static unsigned int ata_dev_init_params(struct ata_device *dev, + u16 heads, u16 sectors) +{ + struct ata_taskfile tf; + struct ata_port *ap; + ap = pap; + unsigned int err_mask; + + if (sectors < 1 || sectors > 255 || heads < 1 || heads > 16) + return AC_ERR_INVALID; + + memset(&tf, 0, sizeof(tf)); + tf.ctl = ap->ctl; + tf.device = ATA_DEVICE_OBS; + tf.command = ATA_CMD_INIT_DEV_PARAMS; + tf.flags |= ATA_TFLAG_ISADDR | ATA_TFLAG_DEVICE; + tf.protocol = ATA_PROT_NODATA; + tf.nsect = sectors; + tf.device |= (heads - 1) & 0x0f; + + err_mask = ata_exec_internal(dev, &tf, NULL, DMA_NONE, 0, 0); + + if (err_mask == AC_ERR_DEV && (tf.feature & ATA_ABORTED)) + err_mask = 0; + + return err_mask; +} + +#if defined(CONFIG_SATA_DWC) && !defined(CONFIG_LBA48) +#define SATA_MAX_READ_BLK 0xFF +#else +#define SATA_MAX_READ_BLK 0xFFFF +#endif + +ulong sata_read(int device, ulong blknr, lbaint_t blkcnt, void *buffer) +{ + ulong start,blks, buf_addr; + unsigned short smallblks; + unsigned long datalen; + unsigned char *pdata; + device &= 0xff; + + u32 block = 0; + u32 n_block = 0; + + if (dev_state != SATA_READY) + return 0; + + buf_addr = (unsigned long)buffer; + start = blknr; + blks = blkcnt; + do { + pdata = (unsigned char *)buf_addr; + if (blks > SATA_MAX_READ_BLK) { + datalen = sata_dev_desc[device].blksz * SATA_MAX_READ_BLK; + smallblks = SATA_MAX_READ_BLK; + + block = (u32)start; + n_block = (u32)smallblks; + + start += SATA_MAX_READ_BLK; + blks -= SATA_MAX_READ_BLK; + } else { + datalen = sata_dev_desc[device].blksz * SATA_MAX_READ_BLK; + datalen = sata_dev_desc[device].blksz * blks; + smallblks = (unsigned short)blks; + + block = (u32)start; + n_block = (u32)smallblks; + + start += blks; + blks = 0; + } + + if (ata_dev_read_sectors(pdata, datalen, block, n_block) != TRUE) { + printf("sata_dwc : Hard disk read error.\n"); + blkcnt -= blks; + break; + } + buf_addr += datalen; + } while (blks != 0); + + return (blkcnt); +} + +static int ata_dev_read_sectors(unsigned char *pdata, unsigned long datalen, + u32 block, u32 n_block) +{ + struct ata_port *ap = pap; + struct ata_device *dev = &ata_device; + struct ata_taskfile tf; + unsigned int class = ATA_DEV_ATA; + unsigned int err_mask = 0; + const char *reason; + int may_fallback = 1; + int rc; + + if (dev_state == SATA_ERROR) + return FALSE; + + ata_dev_select(ap, dev->devno, 1, 1); + +retry: + memset(&tf, 0, sizeof(tf)); + tf.ctl = ap->ctl; + ap->print_id = 1; + ap->flags &= ~ATA_FLAG_DISABLED; + + ap->pdata = pdata; + + tf.device = ATA_DEVICE_OBS; + + temp_n_block = n_block; + +#ifdef CONFIG_LBA48 + tf.command = ATA_CMD_PIO_READ_EXT; + tf.flags |= ATA_TFLAG_LBA | ATA_TFLAG_LBA48; + + tf.hob_feature = 31; + tf.feature = 31; + tf.hob_nsect = (n_block >> 8) & 0xff; + tf.nsect = n_block & 0xff; + + tf.hob_lbah = 0x0; + tf.hob_lbam = 0x0; + tf.hob_lbal = (block >> 24) & 0xff; + tf.lbah = (block >> 16) & 0xff; + tf.lbam = (block >> 8) & 0xff; + tf.lbal = block & 0xff; + + tf.device = 1 << 6; + if (tf.flags & ATA_TFLAG_FUA) + tf.device |= 1 << 7; +#else + tf.command = ATA_CMD_PIO_READ; + tf.flags |= ATA_TFLAG_LBA ; + + tf.feature = 31; + tf.nsect = n_block & 0xff; + + tf.lbah = (block >> 16) & 0xff; + tf.lbam = (block >> 8) & 0xff; + tf.lbal = block & 0xff; + + tf.device = (block >> 24) & 0xf; + + tf.device |= 1 << 6; + if (tf.flags & ATA_TFLAG_FUA) + tf.device |= 1 << 7; + +#endif + + tf.protocol = ATA_PROT_PIO; + + /* Some devices choke if TF registers contain garbage. Make + * sure those are properly initialized. + */ + tf.flags |= ATA_TFLAG_ISADDR | ATA_TFLAG_DEVICE; + tf.flags |= ATA_TFLAG_POLLING; + + err_mask = ata_exec_internal(dev, &tf, NULL, DMA_FROM_DEVICE,0, 0); + + if (err_mask) { + if (err_mask & AC_ERR_NODEV_HINT) { + printf("READ_SECTORS NODEV after polling detection\n"); + return -ENOENT; + } + + if ((err_mask == AC_ERR_DEV) && (tf.feature & ATA_ABORTED)) { + /* Device or controller might have reported + * the wrong device class. Give a shot at the + * other IDENTIFY if the current one is + * aborted by the device. + */ + if (may_fallback) { + may_fallback = 0; + + if (class == ATA_DEV_ATA) { + class = ATA_DEV_ATAPI; + } else { + class = ATA_DEV_ATA; + } + goto retry; + } + /* Control reaches here iff the device aborted + * both flavors of IDENTIFYs which happens + * sometimes with phantom devices. + */ + printf("both IDENTIFYs aborted, assuming NODEV\n"); + return -ENOENT; + } + + rc = -EIO; + reason = "I/O error"; + goto err_out; + } + + /* Falling back doesn't make sense if ID data was read + * successfully at least once. + */ + may_fallback = 0; + + rc = -EINVAL; + reason = "device reports invalid type"; + + return TRUE; + +err_out: + printf("failed to READ SECTORS (%s, err_mask=0x%x)\n", reason, err_mask); + return FALSE; +} + +#if defined(CONFIG_SATA_DWC) && !defined(CONFIG_LBA48) +#define SATA_MAX_WRITE_BLK 0xFF +#else +#define SATA_MAX_WRITE_BLK 0xFFFF +#endif + +ulong sata_write(int device, ulong blknr, lbaint_t blkcnt, void *buffer) +{ + ulong start,blks, buf_addr; + unsigned short smallblks; + unsigned long datalen; + unsigned char *pdata; + device &= 0xff; + + + u32 block = 0; + u32 n_block = 0; + + if (dev_state != SATA_READY) + return 0; + + buf_addr = (unsigned long)buffer; + start = blknr; + blks = blkcnt; + do { + pdata = (unsigned char *)buf_addr; + if (blks > SATA_MAX_WRITE_BLK) { + datalen = sata_dev_desc[device].blksz * SATA_MAX_WRITE_BLK; + smallblks = SATA_MAX_WRITE_BLK; + + block = (u32)start; + n_block = (u32)smallblks; + + start += SATA_MAX_WRITE_BLK; + blks -= SATA_MAX_WRITE_BLK; + } else { + datalen = sata_dev_desc[device].blksz * blks; + smallblks = (unsigned short)blks; + + block = (u32)start; + n_block = (u32)smallblks; + + start += blks; + blks = 0; + } + + if (ata_dev_write_sectors(pdata, datalen, block, n_block) != TRUE) { + printf("sata_dwc : Hard disk read error.\n"); + blkcnt -= blks; + break; + } + buf_addr += datalen; + } while (blks != 0); + + return (blkcnt); +} + +static int ata_dev_write_sectors(unsigned char* pdata, unsigned long datalen, + u32 block, u32 n_block) +{ + struct ata_port *ap = pap; + struct ata_device *dev = &ata_device; + struct ata_taskfile tf; + unsigned int class = ATA_DEV_ATA; + unsigned int err_mask = 0; + const char *reason; + int may_fallback = 1; + int rc; + + if (dev_state == SATA_ERROR) + return FALSE; + + ata_dev_select(ap, dev->devno, 1, 1); + +retry: + memset(&tf, 0, sizeof(tf)); + tf.ctl = ap->ctl; + ap->print_id = 1; + ap->flags &= ~ATA_FLAG_DISABLED; + + ap->pdata = pdata; + + tf.device = ATA_DEVICE_OBS; + + temp_n_block = n_block; + + +#ifdef CONFIG_LBA48 + tf.command = ATA_CMD_PIO_WRITE_EXT; + tf.flags |= ATA_TFLAG_LBA | ATA_TFLAG_LBA48 | ATA_TFLAG_WRITE; + + tf.hob_feature = 31; + tf.feature = 31; + tf.hob_nsect = (n_block >> 8) & 0xff; + tf.nsect = n_block & 0xff; + + tf.hob_lbah = 0x0; + tf.hob_lbam = 0x0; + tf.hob_lbal = (block >> 24) & 0xff; + tf.lbah = (block >> 16) & 0xff; + tf.lbam = (block >> 8) & 0xff; + tf.lbal = block & 0xff; + + tf.device = 1 << 6; + if (tf.flags & ATA_TFLAG_FUA) + tf.device |= 1 << 7; +#else + tf.command = ATA_CMD_PIO_WRITE; + tf.flags |= ATA_TFLAG_LBA | ATA_TFLAG_WRITE; + + tf.feature = 31; + tf.nsect = n_block & 0xff; + + tf.lbah = (block >> 16) & 0xff; + tf.lbam = (block >> 8) & 0xff; + tf.lbal = block & 0xff; + + tf.device = (block >> 24) & 0xf; + + tf.device |= 1 << 6; + if (tf.flags & ATA_TFLAG_FUA) + tf.device |= 1 << 7; + +#endif + + tf.protocol = ATA_PROT_PIO; + + /* Some devices choke if TF registers contain garbage. Make + * sure those are properly initialized. + */ + tf.flags |= ATA_TFLAG_ISADDR | ATA_TFLAG_DEVICE; + tf.flags |= ATA_TFLAG_POLLING; + + err_mask = ata_exec_internal(dev, &tf, NULL, DMA_FROM_DEVICE,0, 0); + + if (err_mask) { + if (err_mask & AC_ERR_NODEV_HINT) { + printf("READ_SECTORS NODEV after polling detection\n"); + return -ENOENT; + } + + if ((err_mask == AC_ERR_DEV) && (tf.feature & ATA_ABORTED)) { + /* Device or controller might have reported + * the wrong device class. Give a shot at the + * other IDENTIFY if the current one is + * aborted by the device. + */ + if (may_fallback) { + may_fallback = 0; + + if (class == ATA_DEV_ATA) { + class = ATA_DEV_ATAPI; + } else { + class = ATA_DEV_ATA; + } + goto retry; + } + /* Control reaches here iff the device aborted + * both flavors of IDENTIFYs which happens + * sometimes with phantom devices. + */ + printf("both IDENTIFYs aborted, assuming NODEV\n"); + return -ENOENT; + } + + rc = -EIO; + reason = "I/O error"; + goto err_out; + } + + /* Falling back doesn't make sense if ID data was read + * successfully at least once. + */ + may_fallback = 0; + + rc = -EINVAL; + reason = "device reports invalid type"; + + return TRUE; + +err_out: + printf("failed to WRITE SECTORS (%s, err_mask=0x%x)\n", reason, err_mask); + return FALSE; +} diff -uprN u-boot-0512/drivers/block/sata_dwc.h u-boot-sata/drivers/block/sata_dwc.h --- u-boot-0512/drivers/block/sata_dwc.h 1970-01-01 09:00:00.000000000 +0900 +++ u-boot-sata/drivers/block/sata_dwc.h 2009-05-07 09:37:57.000000000 +0900 @@ -0,0 +1,463 @@ +/* + * sata_dwc.h + * + * Synopsys DesignWare Cores (DWC) SATA host driver + * + * Author: Mark Miesfeld mmiesfeld@amcc.com + * + * Ported from 2.6.19.2 to 2.6.25/26 by Stefan Roese sr@denx.de + * Copyright 2008 DENX Software Engineering + * + * Based on versions provided by AMCC and Synopsys which are: + * Copyright 2006 Applied Micro Circuits Corporation + * COPYRIGHT (C) 2005 SYNOPSYS, INC. ALL RIGHTS RESERVED + * + * This program is free software; you can redistribute + * it and/or modify it under the terms of the GNU + * General Public License as published by the + * Free Software Foundation; either version 2 of the License, + * or (at your option) any later version. + * + */ +/* + * SATA support based on the chip canyonlands. + * + * 04-17-2009 + * The local version of this driver for the canyonlands board + * does not use interrupts but polls the chip instead. + */ + + +#ifndef _SATA_DWC_H_ +#define _SATA_DWC_H_ + +#define HZ 100 + +#define READ 0 +#define WRITE 1 + +enum { + ATA_READID_POSTRESET = (1 << 0), + + ATA_DNXFER_PIO = 0, + ATA_DNXFER_DMA = 1, + ATA_DNXFER_40C = 2, + ATA_DNXFER_FORCE_PIO = 3, + ATA_DNXFER_FORCE_PIO0 = 4, + + ATA_DNXFER_QUIET = (1 << 31), +}; + +enum hsm_task_states { + HSM_ST_IDLE, + HSM_ST_FIRST, + HSM_ST, + HSM_ST_LAST, + HSM_ST_ERR, +}; + +#define ATA_SHORT_PAUSE ((HZ >> 6) + 1) + +struct ata_queued_cmd { + struct ata_port *ap; + struct ata_device *dev; + + struct ata_taskfile tf; + u8 cdb[ATAPI_CDB_LEN]; + + unsigned long flags; + unsigned int tag; + unsigned int n_elem; + + int dma_dir; + + unsigned int sect_size; + + unsigned int nbytes; + unsigned int extrabytes; + unsigned int curbytes; + + unsigned int err_mask; + struct ata_taskfile result_tf; + + void *private_data; + void *lldd_task; + unsigned char *pdata; +}; + +typedef void (*ata_qc_cb_t) (struct ata_queued_cmd *qc); + +#define ATA_TAG_POISON 0xfafbfcfdU + +enum { + LIBATA_MAX_PRD = ATA_MAX_PRD / 2, + LIBATA_DUMB_MAX_PRD = ATA_MAX_PRD / 4, + ATA_MAX_PORTS = 8, + ATA_DEF_QUEUE = 1, + ATA_MAX_QUEUE = 32, + ATA_TAG_INTERNAL = ATA_MAX_QUEUE - 1, + ATA_MAX_BUS = 2, + ATA_DEF_BUSY_WAIT = 10000, + + ATAPI_MAX_DRAIN = 16 << 10, + + ATA_SHT_EMULATED = 1, + ATA_SHT_CMD_PER_LUN = 1, + ATA_SHT_THIS_ID = -1, + ATA_SHT_USE_CLUSTERING = 1, + + ATA_DFLAG_LBA = (1 << 0), + ATA_DFLAG_LBA48 = (1 << 1), + ATA_DFLAG_CDB_INTR = (1 << 2), + ATA_DFLAG_NCQ = (1 << 3), + ATA_DFLAG_FLUSH_EXT = (1 << 4), + ATA_DFLAG_ACPI_PENDING = (1 << 5), + ATA_DFLAG_ACPI_FAILED = (1 << 6), + ATA_DFLAG_AN = (1 << 7), + ATA_DFLAG_HIPM = (1 << 8), + ATA_DFLAG_DIPM = (1 << 9), + ATA_DFLAG_DMADIR = (1 << 10), + ATA_DFLAG_CFG_MASK = (1 << 12) - 1, + + ATA_DFLAG_PIO = (1 << 12), + ATA_DFLAG_NCQ_OFF = (1 << 13), + ATA_DFLAG_SPUNDOWN = (1 << 14), + ATA_DFLAG_SLEEPING = (1 << 15), + ATA_DFLAG_DUBIOUS_XFER = (1 << 16), + ATA_DFLAG_INIT_MASK = (1 << 24) - 1, + + ATA_DFLAG_DETACH = (1 << 24), + ATA_DFLAG_DETACHED = (1 << 25), + + ATA_LFLAG_HRST_TO_RESUME = (1 << 0), + ATA_LFLAG_SKIP_D2H_BSY = (1 << 1), + ATA_LFLAG_NO_SRST = (1 << 2), + ATA_LFLAG_ASSUME_ATA = (1 << 3), + ATA_LFLAG_ASSUME_SEMB = (1 << 4), + ATA_LFLAG_ASSUME_CLASS = ATA_LFLAG_ASSUME_ATA | ATA_LFLAG_ASSUME_SEMB, + ATA_LFLAG_NO_RETRY = (1 << 5), + ATA_LFLAG_DISABLED = (1 << 6), + + ATA_FLAG_SLAVE_POSS = (1 << 0), + ATA_FLAG_SATA = (1 << 1), + ATA_FLAG_NO_LEGACY = (1 << 2), + ATA_FLAG_MMIO = (1 << 3), + ATA_FLAG_SRST = (1 << 4), + ATA_FLAG_SATA_RESET = (1 << 5), + ATA_FLAG_NO_ATAPI = (1 << 6), + ATA_FLAG_PIO_DMA = (1 << 7), + ATA_FLAG_PIO_LBA48 = (1 << 8), + ATA_FLAG_PIO_POLLING = (1 << 9), + ATA_FLAG_NCQ = (1 << 10), + ATA_FLAG_DEBUGMSG = (1 << 13), + ATA_FLAG_IGN_SIMPLEX = (1 << 15), + ATA_FLAG_NO_IORDY = (1 << 16), + ATA_FLAG_ACPI_SATA = (1 << 17), + ATA_FLAG_AN = (1 << 18), + ATA_FLAG_PMP = (1 << 19), + ATA_FLAG_IPM = (1 << 20), + + ATA_FLAG_DISABLED = (1 << 23), + + ATA_PFLAG_EH_PENDING = (1 << 0), + ATA_PFLAG_EH_IN_PROGRESS = (1 << 1), + ATA_PFLAG_FROZEN = (1 << 2), + ATA_PFLAG_RECOVERED = (1 << 3), + ATA_PFLAG_LOADING = (1 << 4), + ATA_PFLAG_UNLOADING = (1 << 5), + ATA_PFLAG_SCSI_HOTPLUG = (1 << 6), + ATA_PFLAG_INITIALIZING = (1 << 7), + ATA_PFLAG_RESETTING = (1 << 8), + ATA_PFLAG_SUSPENDED = (1 << 17), + ATA_PFLAG_PM_PENDING = (1 << 18), + + ATA_QCFLAG_ACTIVE = (1 << 0), + ATA_QCFLAG_DMAMAP = (1 << 1), + ATA_QCFLAG_IO = (1 << 3), + ATA_QCFLAG_RESULT_TF = (1 << 4), + ATA_QCFLAG_CLEAR_EXCL = (1 << 5), + ATA_QCFLAG_QUIET = (1 << 6), + + ATA_QCFLAG_FAILED = (1 << 16), + ATA_QCFLAG_SENSE_VALID = (1 << 17), + ATA_QCFLAG_EH_SCHEDULED = (1 << 18), + + ATA_HOST_SIMPLEX = (1 << 0), + ATA_HOST_STARTED = (1 << 1), + + ATA_TMOUT_BOOT = 30 * 100, + ATA_TMOUT_BOOT_QUICK = 7 * 100, + ATA_TMOUT_INTERNAL = 30 * 100, + ATA_TMOUT_INTERNAL_QUICK = 5 * 100, + + /* FIXME: GoVault needs 2s but we can't afford that without + * parallel probing. 800ms is enough for iVDR disk + * HHD424020F7SV00. Increase to 2secs when parallel probing + * is in place. + */ + ATA_TMOUT_FF_WAIT = 4 * 100 / 5, + + BUS_UNKNOWN = 0, + BUS_DMA = 1, + BUS_IDLE = 2, + BUS_NOINTR = 3, + BUS_NODATA = 4, + BUS_TIMER = 5, + BUS_PIO = 6, + BUS_EDD = 7, + BUS_IDENTIFY = 8, + BUS_PACKET = 9, + + PORT_UNKNOWN = 0, + PORT_ENABLED = 1, + PORT_DISABLED = 2, + + /* encoding various smaller bitmaps into a single + * unsigned long bitmap + */ + ATA_NR_PIO_MODES = 7, + ATA_NR_MWDMA_MODES = 5, + ATA_NR_UDMA_MODES = 8, + + ATA_SHIFT_PIO = 0, + ATA_SHIFT_MWDMA = ATA_SHIFT_PIO + ATA_NR_PIO_MODES, + ATA_SHIFT_UDMA = ATA_SHIFT_MWDMA + ATA_NR_MWDMA_MODES, + + ATA_DMA_PAD_SZ = 4, + + ATA_ERING_SIZE = 32, + + ATA_DEFER_LINK = 1, + ATA_DEFER_PORT = 2, + + ATA_EH_DESC_LEN = 80, + + ATA_EH_REVALIDATE = (1 << 0), + ATA_EH_SOFTRESET = (1 << 1), + ATA_EH_HARDRESET = (1 << 2), + ATA_EH_ENABLE_LINK = (1 << 3), + ATA_EH_LPM = (1 << 4), + + ATA_EH_RESET_MASK = ATA_EH_SOFTRESET | ATA_EH_HARDRESET, + ATA_EH_PERDEV_MASK = ATA_EH_REVALIDATE, + + ATA_EHI_HOTPLUGGED = (1 << 0), + ATA_EHI_RESUME_LINK = (1 << 1), + ATA_EHI_NO_AUTOPSY = (1 << 2), + ATA_EHI_QUIET = (1 << 3), + + ATA_EHI_DID_SOFTRESET = (1 << 16), + ATA_EHI_DID_HARDRESET = (1 << 17), + ATA_EHI_PRINTINFO = (1 << 18), + ATA_EHI_SETMODE = (1 << 19), + ATA_EHI_POST_SETMODE = (1 << 20), + + ATA_EHI_DID_RESET = ATA_EHI_DID_SOFTRESET | ATA_EHI_DID_HARDRESET, + ATA_EHI_RESET_MODIFIER_MASK = ATA_EHI_RESUME_LINK, + + ATA_EH_MAX_TRIES = 5, + + ATA_PROBE_MAX_TRIES = 3, + ATA_EH_DEV_TRIES = 3, + ATA_EH_PMP_TRIES = 5, + ATA_EH_PMP_LINK_TRIES = 3, + + SATA_PMP_SCR_TIMEOUT = 250, + + /* Horkage types. May be set by libata or controller on drives + (some horkage may be drive/controller pair dependant */ + + ATA_HORKAGE_DIAGNOSTIC = (1 << 0), + ATA_HORKAGE_NODMA = (1 << 1), + ATA_HORKAGE_NONCQ = (1 << 2), + ATA_HORKAGE_MAX_SEC_128 = (1 << 3), + ATA_HORKAGE_BROKEN_HPA = (1 << 4), + ATA_HORKAGE_SKIP_PM = (1 << 5), + ATA_HORKAGE_HPA_SIZE = (1 << 6), + ATA_HORKAGE_IPM = (1 << 7), + ATA_HORKAGE_IVB = (1 << 8), + ATA_HORKAGE_STUCK_ERR = (1 << 9), + + ATA_DMA_MASK_ATA = (1 << 0), + ATA_DMA_MASK_ATAPI = (1 << 1), + ATA_DMA_MASK_CFA = (1 << 2), + + ATAPI_READ = 0, + ATAPI_WRITE = 1, + ATAPI_READ_CD = 2, + ATAPI_PASS_THRU = 3, + ATAPI_MISC = 4, +}; + +enum ata_completion_errors { + AC_ERR_DEV = (1 << 0), + AC_ERR_HSM = (1 << 1), + AC_ERR_TIMEOUT = (1 << 2), + AC_ERR_MEDIA = (1 << 3), + AC_ERR_ATA_BUS = (1 << 4), + AC_ERR_HOST_BUS = (1 << 5), + AC_ERR_SYSTEM = (1 << 6), + AC_ERR_INVALID = (1 << 7), + AC_ERR_OTHER = (1 << 8), + AC_ERR_NODEV_HINT = (1 << 9), + AC_ERR_NCQ = (1 << 10), +}; + +enum ata_xfer_mask { + ATA_MASK_PIO = ((1LU << ATA_NR_PIO_MODES) - 1) << ATA_SHIFT_PIO, + ATA_MASK_MWDMA = ((1LU << ATA_NR_MWDMA_MODES) - 1) << ATA_SHIFT_MWDMA, + ATA_MASK_UDMA = ((1LU << ATA_NR_UDMA_MODES) - 1) << ATA_SHIFT_UDMA, +}; + +struct ata_port_info { + struct scsi_host_template *sht; + unsigned long flags; + unsigned long link_flags; + unsigned long pio_mask; + unsigned long mwdma_mask; + unsigned long udma_mask; + const struct ata_port_operations *port_ops; + void *private_data; +}; + +struct ata_ioports { + void __iomem *cmd_addr; + void __iomem *data_addr; + void __iomem *error_addr; + void __iomem *feature_addr; + void __iomem *nsect_addr; + void __iomem *lbal_addr; + void __iomem *lbam_addr; + void __iomem *lbah_addr; + void __iomem *device_addr; + void __iomem *status_addr; + void __iomem *command_addr; + void __iomem *altstatus_addr; + void __iomem *ctl_addr; + void __iomem *bmdma_addr; + void __iomem *scr_addr; +}; + +struct ata_host { + void __iomem * const *iomap; + unsigned int n_ports; + void *private_data; + const struct ata_port_operations *ops; + unsigned long flags; + struct ata_port *simplex_claimed; + struct ata_port *ports[0]; +}; + +struct ata_port_stats { + unsigned long unhandled_irq; + unsigned long idle_irq; + unsigned long rw_reqbuf; +}; + +struct ata_device { + struct ata_link *link; + unsigned int devno; + unsigned long flags; + unsigned int horkage; + struct scsi_device *sdev; +#ifdef CONFIG_ATA_ACPI + acpi_handle acpi_handle; + union acpi_object *gtf_cache; +#endif + u64 n_sectors; + unsigned int class; + + union { + u16 id[ATA_ID_WORDS]; + u32 gscr[SATA_PMP_GSCR_DWORDS]; + }; + + u8 pio_mode; + u8 dma_mode; + u8 xfer_mode; + unsigned int xfer_shift; + + unsigned int multi_count; + unsigned int max_sectors; + unsigned int cdb_len; + + unsigned long pio_mask; + unsigned long mwdma_mask; + unsigned long udma_mask; + + u16 cylinders; + u16 heads; + u16 sectors; + + int spdn_cnt; +}; + +enum dma_data_direction { + DMA_BIDIRECTIONAL = 0, + DMA_TO_DEVICE = 1, + DMA_FROM_DEVICE = 2, + DMA_NONE = 3, +}; + +struct ata_link { + struct ata_port *ap; + int pmp; + unsigned int active_tag; + u32 sactive; + + unsigned int flags; + + unsigned int hw_sata_spd_limit; + unsigned int sata_spd_limit; + unsigned int sata_spd; + + struct ata_device device[2]; +}; + +struct ata_port { + unsigned long flags; + unsigned int pflags; + unsigned int print_id; + unsigned int port_no; + + struct ata_ioports ioaddr; + + u8 ctl; + u8 last_ctl; + unsigned int pio_mask; + unsigned int mwdma_mask; + unsigned int udma_mask; + unsigned int cbl; + + struct ata_queued_cmd qcmd[ATA_MAX_QUEUE]; + unsigned long qc_allocated; + unsigned int qc_active; + int nr_active_links; + + struct ata_link link; + + int nr_pmp_links; + struct ata_link *pmp_link; + struct ata_link *excl_link; + + struct ata_port_stats stats; + struct ata_host *host; + + struct device *dev; + void *port_task_data; + + unsigned int hsm_task_state; + + u32 msg_enable; + void *private_data; + unsigned char *pdata; +}; + +#ifndef TRUE +#define TRUE 1 +#endif +#ifndef FALSE +#define FALSE 0 +#endif + +#endif diff -uprN u-boot-0512/include/configs/canyonlands.h u-boot-sata/include/configs/canyonlands.h --- u-boot-0512/include/configs/canyonlands.h 2009-05-12 12:48:40.000000000 +0900 +++ u-boot-sata/include/configs/canyonlands.h 2009-05-13 16:24:03.000000000 +0900 @@ -451,6 +451,7 @@ #define CONFIG_CMD_FAT #define CONFIG_CMD_NAND #define CONFIG_CMD_PCI +#define CONFIG_CMD_SATA #define CONFIG_CMD_SDRAM #define CONFIG_CMD_SNTP #define CONFIG_CMD_USB @@ -516,6 +517,19 @@ #endif /* CONFIG_ARCHES */ #endif /* CONFIG_460GT */
+/* + * S-ATA driver setup + */ +#ifdef CONFIG_CMD_SATA +#define CONFIG_SATA_DWC +#define CONFIG_LIBATA +#define SATA_BASE_ADDR 0xe20d1000 /* PPC460EX SATA Base Address */ +#define SATA_DMA_REG_ADDR 0xe20d0800 /* PPC460EX SATA Base Address */ +#define CONFIG_SYS_SATA_MAX_DEVICE 1 /* SATA MAX DEVICE */ +/* Convert sectorsize to wordsize */ +#define ATA_SECTOR_WORDS (ATA_SECT_SIZE/2) +#endif + /*----------------------------------------------------------------------- * External Bus Controller (EBC) Setup *----------------------------------------------------------------------*/
On Wednesday 13 May 2009 10:56:00 Kazuaki Ichinohe wrote:
This patch adds a SATA harddisk driver for the canyonlands. This patch is kernel driver's porting. This pach corresponded to not cmd_scsi but cmd_sata.
[environment variable, boot script] setenv bootargs root=/dev/sda7 rw setenv bootargs ${bootargs} console=ttyS0,115200 ext2load sata 0:2 0x400000 /canyonlands/uImage ext2load sata 0:2 0x800000 /canyonlands/canyonlands.dtb fdt addr 0x800000 0x4000 bootm 0x400000 - 0x800000
If you drive SATA-2 disk on Canyonlands, you must change parts from PI2PCIE212 to PI2PCIE2212 on U25. We confirmed to boot by using following disk.
1.Vender: Fujitsu Type: MHW2040BS 2.Vender: Fujitsu Type: MHW2060BK 3.Vendor: HAGIWARA SYS-COM:HFD25S-032GT 4.Vender: WesternDigital Type: WD3200BJKT (CONFIG_LBA48 required) 5.Vender: WesternDigital Type: WD3200BEVT (CONFIG_LBA48 required) 6.Vender: hitachi Type: HTS543232L9A300 (CONFIG_LBA48 required) 7.Vender: Seagate Type: ST31000333AS (CONFIG_LBA48 required) 8.Vender: Transcend Type: TS32GSSD25S-M 9.Vender: MTRON Type: MSD-SATA1525-016
Signed-off-by: Kazuaki Ichinohe <kazuichi at fsi.co.jp>
This finally looks good. :)
Some comments below.
+++ u-boot-sata/drivers/block/sata_dwc.c 2009-05-07 09:37:53.000000000 +0900 @@ -0,0 +1,2110 @@ +/*
- sata_dwc.c
<snip>
- if ((nsect == 0x55) && (lbal == 0xaa)) {
printf("Device found\n");
- } else {
printf("No device found\n");
return FALSE;
- tmp = ATA_DEVICE_OBS;
- writeb(tmp,ioaddr->device_addr);
Add a space after the ",".
- writeb(ap->ctl,ioaddr->ctl_addr);
Here again...
- udelay(200);
- writeb(ap->ctl | ATA_SRST, ioaddr->ctl_addr);
- udelay(200);
And here again. I won't mention this again. Please check the whole source for such missing spaces.
<snip>
Please remove the space before "(". Use a consistent coding style in this file. So check for other occurrences too.
- int i;
- int rc;
- u8 status;
- const u16 *id;
- struct ata_device *ata_dev = &ata_device;
- unsigned long pio_mask, mwdma_mask, udma_mask;
- unsigned long xfer_mask;
- char revbuf[7];
- u16 iobuf[ATA_SECTOR_WORDS];
- memset ( iobuf, 0, sizeof(iobuf));
memset(iobuf, 0, sizeof(iobuf));
- if (dev_state == SATA_NODEVICE)
return 1;
- printf("waitng for device ready.");
printf("Waiting for device...");
There are two places where "waiting" is misspelled. Please fix both.
Thanks.
Best regards, Stefan
Kazuaki Ichinohe
Stefan Roese
