[U-Boot] [PATCH] arm: mx6: Add Barco platinum-picon and platinum-titanium
This patch adds the new Barco platinum platform. It currently includes those two boards:
platinum-titanium ----------------- This is the same board as the titanium that is already supported in mainline U-Boot. But its now moved to this new platform to support multiple "flavors" of imx6 boards in one directory. Its also moved to support SPL booting. And with this we use the run-time DDR configuration of this SPL support. The board is equipped with the Micron MT41J128M16JT-125 DDR chips. We now can remove the DDR related registers tuples from the imximage.cfg file. As all this is done in the SPL at run-time.
platinum-picon -------------- This board is new and based on the MX6DL with 1GiB DDR using the Micron MT41K256M16HA DDR3 chips. Its also equipped with 2 NAND chips (each 512MiB).
Signed-off-by: Stefan Roese sr@denx.de Cc: Stefano Babic sbabic@denx.de Cc: Pieter Ronsijn pieter.ronsijn@barco.com --- arch/arm/Kconfig | 11 ++ board/barco/platinum/Kconfig | 37 ++++ board/barco/platinum/MAINTAINERS | 7 + board/barco/platinum/Makefile | 14 ++ board/barco/platinum/platinum.c | 217 +++++++++++++++++++++ board/barco/platinum/platinum.h | 88 +++++++++ board/barco/platinum/platinum_picon.c | 244 +++++++++++++++++++++++ board/barco/platinum/platinum_titanium.c | 209 ++++++++++++++++++++ board/barco/platinum/spl_picon.c | 182 ++++++++++++++++++ board/barco/platinum/spl_titanium.c | 185 ++++++++++++++++++ configs/platinum_picon_defconfig | 4 + configs/platinum_titanium_defconfig | 4 + include/configs/platinum.h | 319 +++++++++++++++++++++++++++++++ include/configs/platinum_picon.h | 31 +++ include/configs/platinum_titanium.h | 38 ++++ 15 files changed, 1590 insertions(+) create mode 100644 board/barco/platinum/Kconfig create mode 100644 board/barco/platinum/MAINTAINERS create mode 100644 board/barco/platinum/Makefile create mode 100644 board/barco/platinum/platinum.c create mode 100644 board/barco/platinum/platinum.h create mode 100644 board/barco/platinum/platinum_picon.c create mode 100644 board/barco/platinum/platinum_titanium.c create mode 100644 board/barco/platinum/spl_picon.c create mode 100644 board/barco/platinum/spl_titanium.c create mode 100644 configs/platinum_picon_defconfig create mode 100644 configs/platinum_titanium_defconfig create mode 100644 include/configs/platinum.h create mode 100644 include/configs/platinum_picon.h create mode 100644 include/configs/platinum_titanium.h
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 034ab33..6a45478 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -660,6 +660,16 @@ config TARGET_OT1200 bool "Bachmann OT1200" select CPU_V7
+config TARGET_PLATINUM_PICON + bool "Support platinum-picon" + select CPU_V7 + select SUPPORT_SPL + +config TARGET_PLATINUM_TITANIUM + bool "Support platinum-titanium" + select CPU_V7 + select SUPPORT_SPL + config OMAP34XX bool "OMAP34XX SoC" select CPU_V7 @@ -862,6 +872,7 @@ source "board/atmel/sama5d4_xplained/Kconfig" source "board/atmel/sama5d4ek/Kconfig" source "board/bachmann/ot1200/Kconfig" source "board/balloon3/Kconfig" +source "board/barco/platinum/Kconfig" source "board/barco/titanium/Kconfig" source "board/bluegiga/apx4devkit/Kconfig" source "board/bluewater/snapper9260/Kconfig" diff --git a/board/barco/platinum/Kconfig b/board/barco/platinum/Kconfig new file mode 100644 index 0000000..8bbad24 --- /dev/null +++ b/board/barco/platinum/Kconfig @@ -0,0 +1,37 @@ +if TARGET_PLATINUM_PICON + +config SYS_CPU + default "armv7" + +config SYS_VENDOR + default "barco" + +config SYS_SOC + default "mx6" + +config SYS_BOARD + default "platinum" + +config SYS_CONFIG_NAME + default "platinum_picon" + +endif + +if TARGET_PLATINUM_TITANIUM + +config SYS_CPU + default "armv7" + +config SYS_VENDOR + default "barco" + +config SYS_SOC + default "mx6" + +config SYS_BOARD + default "platinum" + +config SYS_CONFIG_NAME + default "platinum_titanium" + +endif diff --git a/board/barco/platinum/MAINTAINERS b/board/barco/platinum/MAINTAINERS new file mode 100644 index 0000000..a22584b --- /dev/null +++ b/board/barco/platinum/MAINTAINERS @@ -0,0 +1,7 @@ +PLATINUM BOARD +M: Stefan Roese sr@denx.de +S: Maintained +F: board/barco/platinum/ +F: include/configs/platinum.h +F: configs/platinum_picon_defconfig +F: configs/platinum_titanium_defconfig diff --git a/board/barco/platinum/Makefile b/board/barco/platinum/Makefile new file mode 100644 index 0000000..abc9419 --- /dev/null +++ b/board/barco/platinum/Makefile @@ -0,0 +1,14 @@ +# +# Copyright (C) 2014, Barco (www.barco.com) +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y := platinum.o +obj-$(CONFIG_TARGET_PLATINUM_PICON) += platinum_picon.o +obj-$(CONFIG_TARGET_PLATINUM_TITANIUM) += platinum_titanium.o + +ifneq ($(CONFIG_SPL_BUILD),) +obj-$(CONFIG_TARGET_PLATINUM_PICON) += spl_picon.o +obj-$(CONFIG_TARGET_PLATINUM_TITANIUM) += spl_titanium.o +endif diff --git a/board/barco/platinum/platinum.c b/board/barco/platinum/platinum.c new file mode 100644 index 0000000..1485a48 --- /dev/null +++ b/board/barco/platinum/platinum.c @@ -0,0 +1,217 @@ +/* + * Copyright (C) 2014, Barco (www.barco.com) + * Copyright (C) 2014 Stefan Roese sr@denx.de + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <mmc.h> +#include <fsl_esdhc.h> +#include <miiphy.h> +#include <netdev.h> +#include <asm/io.h> +#include <asm/arch/clock.h> +#include <asm/arch/imx-regs.h> +#include <asm/arch/iomux.h> +#include <asm/arch/mx6-pins.h> +#include <asm/arch/crm_regs.h> +#include <asm/arch/sys_proto.h> +#include <asm/gpio.h> +#include <asm/imx-common/iomux-v3.h> +#include <asm/imx-common/boot_mode.h> + +#include "platinum.h" + +DECLARE_GLOBAL_DATA_PTR; + +iomux_v3_cfg_t const usdhc3_pads[] = { + MX6_PAD_SD3_CLK__SD3_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD3_CMD__SD3_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD3_DAT0__SD3_DATA0 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD3_DAT1__SD3_DATA1 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD3_DAT2__SD3_DATA2 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD3_DAT3__SD3_DATA3 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD3_DAT5__GPIO7_IO00 | MUX_PAD_CTRL(NO_PAD_CTRL), /* CD */ +}; + +iomux_v3_cfg_t nfc_pads[] = { + MX6_PAD_NANDF_CLE__NAND_CLE | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_NANDF_ALE__NAND_ALE | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_NANDF_WP_B__NAND_WP_B | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_NANDF_RB0__NAND_READY_B | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_NANDF_CS0__NAND_CE0_B | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_NANDF_CS1__NAND_CE1_B | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_NANDF_CS2__NAND_CE2_B | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_NANDF_CS3__NAND_CE3_B | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_SD4_CMD__NAND_RE_B | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_SD4_CLK__NAND_WE_B | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_NANDF_D0__NAND_DATA00 | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_NANDF_D1__NAND_DATA01 | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_NANDF_D2__NAND_DATA02 | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_NANDF_D3__NAND_DATA03 | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_NANDF_D4__NAND_DATA04 | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_NANDF_D5__NAND_DATA05 | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_NANDF_D6__NAND_DATA06 | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_NANDF_D7__NAND_DATA07 | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_SD4_DAT0__NAND_DQS | MUX_PAD_CTRL(NO_PAD_CTRL), +}; + +struct fsl_esdhc_cfg usdhc_cfg[] = { + { USDHC3_BASE_ADDR }, +}; + +void setup_gpmi_nand(void) +{ + struct mxc_ccm_reg *mxc_ccm = (struct mxc_ccm_reg *)CCM_BASE_ADDR; + + /* config gpmi nand iomux */ + imx_iomux_v3_setup_multiple_pads(nfc_pads, ARRAY_SIZE(nfc_pads)); + + /* config gpmi and bch clock to 100 MHz */ + clrsetbits_le32(&mxc_ccm->cs2cdr, + MXC_CCM_CS2CDR_ENFC_CLK_PODF_MASK | + MXC_CCM_CS2CDR_ENFC_CLK_PRED_MASK | + MXC_CCM_CS2CDR_ENFC_CLK_SEL_MASK, + MXC_CCM_CS2CDR_ENFC_CLK_PODF(0) | + MXC_CCM_CS2CDR_ENFC_CLK_PRED(3) | + MXC_CCM_CS2CDR_ENFC_CLK_SEL(3)); + + /* enable gpmi and bch clock gating */ + setbits_le32(&mxc_ccm->CCGR4, + MXC_CCM_CCGR4_RAWNAND_U_BCH_INPUT_APB_MASK | + MXC_CCM_CCGR4_RAWNAND_U_GPMI_BCH_INPUT_BCH_MASK | + MXC_CCM_CCGR4_RAWNAND_U_GPMI_BCH_INPUT_GPMI_IO_MASK | + MXC_CCM_CCGR4_RAWNAND_U_GPMI_INPUT_APB_MASK | + MXC_CCM_CCGR4_PL301_MX6QPER1_BCH_OFFSET); + + /* enable apbh clock gating */ + setbits_le32(&mxc_ccm->CCGR0, MXC_CCM_CCGR0_APBHDMA_MASK); +} + +int dram_init(void) +{ + gd->ram_size = get_ram_size((void *)PHYS_SDRAM, PHYS_SDRAM_SIZE); + + return 0; +} + +int board_ehci_hcd_init(int port) +{ + return 0; +} + +int board_mmc_getcd(struct mmc *mmc) +{ + struct fsl_esdhc_cfg *cfg = (struct fsl_esdhc_cfg *)mmc->priv; + + if (cfg->esdhc_base == usdhc_cfg[0].esdhc_base) { + unsigned sd3_cd = IMX_GPIO_NR(7, 0); + gpio_direction_input(sd3_cd); + return !gpio_get_value(sd3_cd); + } + + return 0; +} + +int board_mmc_init(bd_t *bis) +{ + imx_iomux_v3_setup_multiple_pads(usdhc3_pads, ARRAY_SIZE(usdhc3_pads)); + usdhc_cfg[0].sdhc_clk = mxc_get_clock(MXC_ESDHC3_CLK); + + return fsl_esdhc_initialize(bis, &usdhc_cfg[0]); +} + +void board_init_gpio(void) +{ + platinum_init_gpio(); +} + +void board_init_gpmi_nand(void) +{ + setup_gpmi_nand(); +} + +void board_init_i2c(void) +{ + platinum_setup_i2c(); +} + +void board_init_spi(void) +{ + platinum_setup_spi(); +} + +void board_init_uart(void) +{ + platinum_setup_uart(); +} + +void board_init_usb(void) +{ + platinum_init_usb(); +} + +void board_init_finished(void) +{ + platinum_init_finished(); +} + +int board_phy_config(struct phy_device *phydev) +{ + return platinum_phy_config(phydev); +} + +int board_eth_init(bd_t *bis) +{ + return cpu_eth_init(bis); +} + +int board_early_init_f(void) +{ + board_init_uart(); + + return 0; +} + +int board_init(void) +{ + /* address of boot parameters */ + gd->bd->bi_boot_params = PHYS_SDRAM + 0x100; + + board_init_spi(); + + board_init_i2c(); + + board_init_gpmi_nand(); + + board_init_gpio(); + + board_init_usb(); + + board_init_finished(); + + return 0; +} + +int checkboard(void) +{ + puts("Board: " CONFIG_PLATINUM_BOARD "\n"); + return 0; +} + +static const struct boot_mode board_boot_modes[] = { + /* NAND */ + { "nand", MAKE_CFGVAL(0x80, 0x02, 0x00, 0x00) }, + /* 4 bit bus width */ + { "mmc0", MAKE_CFGVAL(0x40, 0x30, 0x00, 0x00) }, + { "mmc1", MAKE_CFGVAL(0x40, 0x38, 0x00, 0x00) }, + { NULL, 0 }, +}; + +int misc_init_r(void) +{ + add_board_boot_modes(board_boot_modes); + + return 0; +} diff --git a/board/barco/platinum/platinum.h b/board/barco/platinum/platinum.h new file mode 100644 index 0000000..8650d6d --- /dev/null +++ b/board/barco/platinum/platinum.h @@ -0,0 +1,88 @@ +/* + * Copyright (C) 2014 Stefan Roese sr@denx.de + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef _PLATINUM_H_ +#define _PLATINUM_H_ + +#include <miiphy.h> +#include <asm/arch/crm_regs.h> + +/* Defines */ + +#define ECSPI1_PAD_CLK (PAD_CTL_SRE_SLOW | PAD_CTL_PUS_100K_DOWN | \ + PAD_CTL_SPEED_LOW | PAD_CTL_DSE_40ohm | \ + PAD_CTL_HYS) +#define ECSPI2_PAD_CLK (PAD_CTL_SRE_FAST | PAD_CTL_PUS_100K_DOWN | \ + PAD_CTL_SPEED_MED | PAD_CTL_DSE_40ohm | \ + PAD_CTL_HYS) +#define ECSPI_PAD_MOSI (PAD_CTL_SRE_SLOW | PAD_CTL_PUS_100K_DOWN | \ + PAD_CTL_SPEED_LOW | PAD_CTL_DSE_120ohm | \ + PAD_CTL_HYS) +#define ECSPI_PAD_MISO (PAD_CTL_SRE_FAST | PAD_CTL_PUS_100K_DOWN | \ + PAD_CTL_SPEED_LOW | PAD_CTL_DSE_40ohm | \ + PAD_CTL_HYS) +#define ECSPI_PAD_SS (PAD_CTL_SRE_SLOW | PAD_CTL_PUS_100K_UP | \ + PAD_CTL_SPEED_LOW | PAD_CTL_DSE_120ohm | \ + PAD_CTL_HYS) + +#define ENET_PAD_CTRL (PAD_CTL_PUS_100K_UP | PAD_CTL_SPEED_MED | \ + PAD_CTL_DSE_40ohm | PAD_CTL_HYS) + +#define I2C_PAD_CTRL (PAD_CTL_PUS_100K_UP | PAD_CTL_SPEED_MED | \ + PAD_CTL_DSE_40ohm | PAD_CTL_HYS | \ + PAD_CTL_ODE | PAD_CTL_SRE_FAST) +#define I2C_PAD_CTRL_SCL (PAD_CTL_PUS_100K_UP | PAD_CTL_SPEED_LOW | \ + PAD_CTL_DSE_80ohm | PAD_CTL_HYS | \ + PAD_CTL_ODE | PAD_CTL_SRE_SLOW) + +#define UART_PAD_CTRL (PAD_CTL_PUS_100K_UP | PAD_CTL_SPEED_MED | \ + PAD_CTL_DSE_40ohm | PAD_CTL_SRE_FAST | \ + PAD_CTL_HYS) + +#define USDHC_PAD_CTRL (PAD_CTL_PUS_47K_UP | PAD_CTL_SPEED_LOW | \ + PAD_CTL_DSE_80ohm | PAD_CTL_SRE_FAST | \ + PAD_CTL_HYS) + + +#define PC MUX_PAD_CTRL(I2C_PAD_CTRL) +#define PC_SCL MUX_PAD_CTRL(I2C_PAD_CTRL_SCL) + +/* Prototypes */ + +int platinum_setup_enet(void); +int platinum_setup_i2c(void); +int platinum_setup_spi(void); +int platinum_setup_uart(void); +int platinum_phy_config(struct phy_device *phydev); +int platinum_init_gpio(void); +int platinum_init_usb(void); +int platinum_init_finished(void); + +static inline void ccgr_init(void) +{ + struct mxc_ccm_reg *ccm = (struct mxc_ccm_reg *)CCM_BASE_ADDR; + + writel(0x00C03F3F, &ccm->CCGR0); + writel(0x0030FC03, &ccm->CCGR1); + writel(0x0FFFC000, &ccm->CCGR2); + writel(0x3FF00000, &ccm->CCGR3); + writel(0xFFFFF300, &ccm->CCGR4); /* enable NAND/GPMI/BCH clks */ + writel(0x0F0000C3, &ccm->CCGR5); + writel(0x000003FF, &ccm->CCGR6); +} + +static inline void gpr_init(void) +{ + struct iomuxc *iomux = (struct iomuxc *)IOMUXC_BASE_ADDR; + + /* enable AXI cache for VDOA/VPU/IPU */ + writel(0xF00000CF, &iomux->gpr[4]); + /* set IPU AXI-id0 Qos=0xf(bypass) AXI-id1 Qos=0x7 */ + writel(0x007F007F, &iomux->gpr[6]); + writel(0x007F007F, &iomux->gpr[7]); +} + +#endif /* _PLATINUM_H_ */ diff --git a/board/barco/platinum/platinum_picon.c b/board/barco/platinum/platinum_picon.c new file mode 100644 index 0000000..b2eab76 --- /dev/null +++ b/board/barco/platinum/platinum_picon.c @@ -0,0 +1,244 @@ +/* + * Copyright (C) 2014, Barco (www.barco.com) + * Copyright (C) 2014 Stefan Roese sr@denx.de + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/gpio.h> +#include <asm/io.h> +#include <asm/arch/clock.h> +#include <asm/arch/iomux.h> +#include <asm/arch/mx6-pins.h> +#include <asm/imx-common/iomux-v3.h> +#include <asm/imx-common/mxc_i2c.h> +#include <i2c.h> +#include <miiphy.h> + +#include "platinum.h" + +#define GPIO_IP_NCONFIG IMX_GPIO_NR(5, 18) +#define GPIO_HK_NCONFIG IMX_GPIO_NR(7, 13) +#define GPIO_LS_NCONFIG IMX_GPIO_NR(5, 19) + +#define GPIO_I2C0_SEL0 IMX_GPIO_NR(5, 2) +#define GPIO_I2C0_SEL1 IMX_GPIO_NR(1, 11) +#define GPIO_I2C0_ENBN IMX_GPIO_NR(1, 13) + +#define GPIO_I2C2_SEL0 IMX_GPIO_NR(1, 17) +#define GPIO_I2C2_SEL1 IMX_GPIO_NR(1, 20) +#define GPIO_I2C2_ENBN IMX_GPIO_NR(1, 14) + +#define GPIO_USB_RESET IMX_GPIO_NR(1, 5) + +iomux_v3_cfg_t const ecspi1_pads[] = { + MX6_PAD_EIM_D16__ECSPI1_SCLK | MUX_PAD_CTRL(ECSPI1_PAD_CLK), + MX6_PAD_EIM_D17__ECSPI1_MISO | MUX_PAD_CTRL(ECSPI_PAD_MISO), + MX6_PAD_EIM_D18__ECSPI1_MOSI | MUX_PAD_CTRL(ECSPI_PAD_MOSI), + MX6_PAD_CSI0_DAT7__ECSPI1_SS0 | MUX_PAD_CTRL(ECSPI_PAD_SS), + MX6_PAD_EIM_D24__ECSPI1_SS2 | MUX_PAD_CTRL(ECSPI_PAD_SS), + MX6_PAD_EIM_D25__ECSPI1_SS3 | MUX_PAD_CTRL(ECSPI_PAD_SS), +}; + +iomux_v3_cfg_t const ecspi2_pads[] = { + MX6_PAD_EIM_CS0__ECSPI2_SCLK | MUX_PAD_CTRL(ECSPI2_PAD_CLK), + MX6_PAD_EIM_OE__ECSPI2_MISO | MUX_PAD_CTRL(ECSPI_PAD_MISO), + MX6_PAD_EIM_CS1__ECSPI2_MOSI | MUX_PAD_CTRL(ECSPI_PAD_MOSI), + MX6_PAD_EIM_RW__ECSPI2_SS0 | MUX_PAD_CTRL(ECSPI_PAD_SS), + MX6_PAD_EIM_LBA__ECSPI2_SS1 | MUX_PAD_CTRL(ECSPI_PAD_SS), +}; + +iomux_v3_cfg_t const enet_pads[] = { + MX6_PAD_ENET_MDIO__ENET_MDIO | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_ENET_MDC__ENET_MDC | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_ENET_CRS_DV__ENET_RX_EN | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_GPIO_16__ENET_REF_CLK | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_ENET_RX_ER__ENET_RX_ER | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_ENET_RXD0__ENET_RX_DATA0 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_ENET_RXD1__ENET_RX_DATA1 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_ENET_TX_EN__ENET_TX_EN | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_ENET_TXD0__ENET_TX_DATA0 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_ENET_TXD1__ENET_TX_DATA1 | MUX_PAD_CTRL(ENET_PAD_CTRL), +}; + +/* PHY nRESET */ +iomux_v3_cfg_t const phy_reset_pad = { + MX6_PAD_SD1_DAT2__GPIO1_IO19 | MUX_PAD_CTRL(NO_PAD_CTRL), +}; + +iomux_v3_cfg_t const uart1_pads[] = { + MX6_PAD_SD3_DAT6__UART1_RX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL), + MX6_PAD_SD3_DAT7__UART1_TX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL), +}; + +iomux_v3_cfg_t const uart4_pads[] = { + MX6_PAD_CSI0_DAT12__UART4_TX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL), + MX6_PAD_CSI0_DAT13__UART4_RX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL), + MX6_PAD_CSI0_DAT16__UART4_RTS_B | MUX_PAD_CTRL(UART_PAD_CTRL), + MX6_PAD_CSI0_DAT17__UART4_CTS_B | MUX_PAD_CTRL(UART_PAD_CTRL), +}; + +iomux_v3_cfg_t const uart5_pads[] = { + MX6_PAD_CSI0_DAT14__UART5_TX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL), + MX6_PAD_CSI0_DAT15__UART5_RX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL), + MX6_PAD_CSI0_DAT18__UART5_RTS_B | MUX_PAD_CTRL(UART_PAD_CTRL), + MX6_PAD_CSI0_DAT19__UART5_CTS_B | MUX_PAD_CTRL(UART_PAD_CTRL), +}; + +iomux_v3_cfg_t const i2c0_mux_pads[] = { + MX6_PAD_EIM_A25__GPIO5_IO02 | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_SD2_CMD__GPIO1_IO11 | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_SD2_DAT2__GPIO1_IO13 | MUX_PAD_CTRL(NO_PAD_CTRL), +}; + +iomux_v3_cfg_t const i2c2_mux_pads[] = { + MX6_PAD_SD1_DAT1__GPIO1_IO17 | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_SD1_CLK__GPIO1_IO20 | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_SD2_DAT1__GPIO1_IO14 | MUX_PAD_CTRL(NO_PAD_CTRL), +}; + +struct i2c_pads_info i2c_pad_info0 = { + .scl = { + .i2c_mode = MX6_PAD_CSI0_DAT9__I2C1_SCL | PC_SCL, + .gpio_mode = MX6_PAD_CSI0_DAT9__GPIO5_IO27 | PC_SCL, + .gp = IMX_GPIO_NR(5, 27) + }, + .sda = { + .i2c_mode = MX6_PAD_CSI0_DAT8__I2C1_SDA | PC, + .gpio_mode = MX6_PAD_CSI0_DAT8__GPIO5_IO26 | PC, + .gp = IMX_GPIO_NR(5, 26) + } +}; + +struct i2c_pads_info i2c_pad_info2 = { + .scl = { + .i2c_mode = MX6_PAD_GPIO_3__I2C3_SCL | PC_SCL, + .gpio_mode = MX6_PAD_GPIO_3__GPIO1_IO03 | PC_SCL, + .gp = IMX_GPIO_NR(1, 3) + }, + .sda = { + .i2c_mode = MX6_PAD_GPIO_6__I2C3_SDA | PC, + .gpio_mode = MX6_PAD_GPIO_6__GPIO1_IO06 | PC, + .gp = IMX_GPIO_NR(1, 6) + } +}; + +/* + * This enet related pin-muxing and GPIO handling is done + * in SPL U-Boot. For early initialization. And to give the + * PHY some time to come out of reset before the U-Boot + * ethernet driver tries to access its registers via MDIO. + */ +int platinum_setup_enet(void) +{ + struct iomuxc *iomux = (struct iomuxc *)IOMUXC_BASE_ADDR; + unsigned phy_reset = IMX_GPIO_NR(1, 19); + + /* First configure PHY reset GPIO pin */ + imx_iomux_v3_setup_pad(phy_reset_pad); + + /* Reconfigure enet muxing while PHY is in reset */ + gpio_direction_output(phy_reset, 0); + imx_iomux_v3_setup_multiple_pads(enet_pads, ARRAY_SIZE(enet_pads)); + mdelay(10); + gpio_set_value(phy_reset, 1); + udelay(100); + + /* set GPIO_16 as ENET_REF_CLK_OUT */ + setbits_le32(&iomux->gpr[1], IOMUXC_GPR1_ENET_CLK_SEL_MASK); + + return enable_fec_anatop_clock(ENET_50MHZ); +} + +int platinum_setup_i2c(void) +{ + imx_iomux_v3_setup_multiple_pads(i2c0_mux_pads, + ARRAY_SIZE(i2c0_mux_pads)); + imx_iomux_v3_setup_multiple_pads(i2c2_mux_pads, + ARRAY_SIZE(i2c2_mux_pads)); + + mdelay(10); + + /* Disable i2c mux 0 */ + gpio_direction_output(GPIO_I2C0_SEL0, 0); + gpio_direction_output(GPIO_I2C0_SEL1, 0); + gpio_direction_output(GPIO_I2C0_ENBN, 1); + + /* Disable i2c mux 1 */ + gpio_direction_output(GPIO_I2C2_SEL0, 0); + gpio_direction_output(GPIO_I2C2_SEL1, 0); + gpio_direction_output(GPIO_I2C2_ENBN, 1); + + udelay(10); + + setup_i2c(0, CONFIG_SYS_I2C_SPEED, 0x7f, &i2c_pad_info0); + setup_i2c(2, CONFIG_SYS_I2C_SPEED, 0x7f, &i2c_pad_info2); + + /* Disable all leds */ + i2c_set_bus_num(0); + i2c_reg_write(0x60, 0x05, 0x55); + + return 0; +} + +int platinum_setup_spi(void) +{ + imx_iomux_v3_setup_multiple_pads(ecspi1_pads, ARRAY_SIZE(ecspi1_pads)); + imx_iomux_v3_setup_multiple_pads(ecspi2_pads, ARRAY_SIZE(ecspi2_pads)); + + return 0; +} + +int platinum_setup_uart(void) +{ + imx_iomux_v3_setup_multiple_pads(uart1_pads, ARRAY_SIZE(uart1_pads)); + imx_iomux_v3_setup_multiple_pads(uart4_pads, ARRAY_SIZE(uart4_pads)); + imx_iomux_v3_setup_multiple_pads(uart5_pads, ARRAY_SIZE(uart5_pads)); + + return 0; +} + +int platinum_phy_config(struct phy_device *phydev) +{ + /* Use generic infrastructure, no specific setup */ + if (phydev->drv->config) + phydev->drv->config(phydev); + + return 0; +} + +int platinum_init_gpio(void) +{ + /* Reset FPGA's */ + gpio_direction_output(GPIO_IP_NCONFIG, 0); + gpio_direction_output(GPIO_HK_NCONFIG, 0); + gpio_direction_output(GPIO_LS_NCONFIG, 0); + udelay(3); + gpio_set_value(GPIO_IP_NCONFIG, 1); + gpio_set_value(GPIO_HK_NCONFIG, 1); + gpio_set_value(GPIO_LS_NCONFIG, 1); + + /* no dmd configuration yet */ + + return 0; +} + +int platinum_init_usb(void) +{ + /* Reset usb hub */ + gpio_direction_output(GPIO_USB_RESET, 0); + udelay(100); + gpio_set_value(GPIO_USB_RESET, 1); + + return 0; +} + +int platinum_init_finished(void) +{ + /* Enable led 0 */ + i2c_set_bus_num(0); + i2c_reg_write(0x60, 0x05, 0x54); + + return 0; +} diff --git a/board/barco/platinum/platinum_titanium.c b/board/barco/platinum/platinum_titanium.c new file mode 100644 index 0000000..73a955f --- /dev/null +++ b/board/barco/platinum/platinum_titanium.c @@ -0,0 +1,209 @@ +/* + * Copyright (C) 2014, Barco (www.barco.com) + * Copyright (C) 2014 Stefan Roese sr@denx.de + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/arch/iomux.h> +#include <asm/arch/mx6-pins.h> +#include <asm/gpio.h> +#include <asm/imx-common/iomux-v3.h> +#include <asm/imx-common/mxc_i2c.h> +#include <miiphy.h> +#include <micrel.h> + +#include "platinum.h" + +iomux_v3_cfg_t const ecspi1_pads[] = { + MX6_PAD_EIM_D16__ECSPI1_SCLK | MUX_PAD_CTRL(ECSPI1_PAD_CLK), + MX6_PAD_EIM_D17__ECSPI1_MISO | MUX_PAD_CTRL(ECSPI_PAD_MISO), + MX6_PAD_EIM_D18__ECSPI1_MOSI | MUX_PAD_CTRL(ECSPI_PAD_MOSI), + MX6_PAD_CSI0_DAT7__ECSPI1_SS0 | MUX_PAD_CTRL(ECSPI_PAD_SS), + /* non mounted spi nor flash for booting */ + MX6_PAD_EIM_D19__ECSPI1_SS1 | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_EIM_D24__ECSPI1_SS2 | MUX_PAD_CTRL(ECSPI_PAD_SS), + MX6_PAD_EIM_D25__ECSPI1_SS3 | MUX_PAD_CTRL(ECSPI_PAD_SS), +}; + +iomux_v3_cfg_t const ecspi2_pads[] = { + MX6_PAD_EIM_CS0__ECSPI2_SCLK | MUX_PAD_CTRL(ECSPI2_PAD_CLK), + MX6_PAD_EIM_OE__ECSPI2_MISO | MUX_PAD_CTRL(ECSPI_PAD_MISO), + MX6_PAD_EIM_CS1__ECSPI2_MOSI | MUX_PAD_CTRL(ECSPI_PAD_MOSI), + MX6_PAD_EIM_RW__ECSPI2_SS0 | MUX_PAD_CTRL(ECSPI_PAD_SS), +}; + +iomux_v3_cfg_t const enet_pads1[] = { + MX6_PAD_ENET_MDIO__ENET_MDIO | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_ENET_MDC__ENET_MDC | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_TXC__RGMII_TXC | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_TD0__RGMII_TD0 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_TD1__RGMII_TD1 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_TD2__RGMII_TD2 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_TD3__RGMII_TD3 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_TX_CTL__RGMII_TX_CTL | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_ENET_REF_CLK__ENET_TX_CLK | MUX_PAD_CTRL(ENET_PAD_CTRL), + /* pin 35 - 1 (PHY_AD2) on reset */ + MX6_PAD_RGMII_RXC__GPIO6_IO30 | MUX_PAD_CTRL(NO_PAD_CTRL), + /* pin 32 - 1 - (MODE0) all */ + MX6_PAD_RGMII_RD0__GPIO6_IO25 | MUX_PAD_CTRL(NO_PAD_CTRL), + /* pin 31 - 1 - (MODE1) all */ + MX6_PAD_RGMII_RD1__GPIO6_IO27 | MUX_PAD_CTRL(NO_PAD_CTRL), + /* pin 28 - 1 - (MODE2) all */ + MX6_PAD_RGMII_RD2__GPIO6_IO28 | MUX_PAD_CTRL(NO_PAD_CTRL), + /* pin 27 - 1 - (MODE3) all */ + MX6_PAD_RGMII_RD3__GPIO6_IO29 | MUX_PAD_CTRL(NO_PAD_CTRL), + /* pin 33 - 1 - (CLK125_EN) 125Mhz clockout enabled */ + MX6_PAD_RGMII_RX_CTL__GPIO6_IO24 | MUX_PAD_CTRL(NO_PAD_CTRL), + /* pin 42 PHY nRST */ + MX6_PAD_EIM_D23__GPIO3_IO23 | MUX_PAD_CTRL(NO_PAD_CTRL), +}; + +iomux_v3_cfg_t const enet_pads2[] = { + MX6_PAD_RGMII_RXC__RGMII_RXC | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_RD0__RGMII_RD0 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_RD1__RGMII_RD1 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_RD2__RGMII_RD2 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_RD3__RGMII_RD3 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_RX_CTL__RGMII_RX_CTL | MUX_PAD_CTRL(ENET_PAD_CTRL), +}; + +iomux_v3_cfg_t const uart1_pads[] = { + MX6_PAD_SD3_DAT6__UART1_RX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL), + MX6_PAD_SD3_DAT7__UART1_TX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL), +}; + +iomux_v3_cfg_t const uart2_pads[] = { + MX6_PAD_EIM_D26__UART2_TX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL), + MX6_PAD_EIM_D27__UART2_RX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL), + MX6_PAD_EIM_D28__UART2_DTE_CTS_B | MUX_PAD_CTRL(UART_PAD_CTRL), + MX6_PAD_EIM_D29__UART2_RTS_B | MUX_PAD_CTRL(UART_PAD_CTRL), +}; + +iomux_v3_cfg_t const uart4_pads[] = { + MX6_PAD_CSI0_DAT12__UART4_TX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL), + MX6_PAD_CSI0_DAT13__UART4_RX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL), + MX6_PAD_CSI0_DAT16__UART4_RTS_B | MUX_PAD_CTRL(UART_PAD_CTRL), + MX6_PAD_CSI0_DAT17__UART4_CTS_B | MUX_PAD_CTRL(UART_PAD_CTRL), +}; + +struct i2c_pads_info i2c_pad_info0 = { + .scl = { + .i2c_mode = MX6_PAD_CSI0_DAT9__I2C1_SCL | PC_SCL, + .gpio_mode = MX6_PAD_CSI0_DAT9__GPIO5_IO27 | PC_SCL, + .gp = IMX_GPIO_NR(5, 27) + }, + .sda = { + .i2c_mode = MX6_PAD_CSI0_DAT8__I2C1_SDA | PC, + .gpio_mode = MX6_PAD_CSI0_DAT8__GPIO5_IO26 | PC, + .gp = IMX_GPIO_NR(5, 26) + } +}; + +struct i2c_pads_info i2c_pad_info2 = { + .scl = { + .i2c_mode = MX6_PAD_GPIO_3__I2C3_SCL | PC_SCL, + .gpio_mode = MX6_PAD_GPIO_3__GPIO1_IO03 | PC_SCL, + .gp = IMX_GPIO_NR(1, 3) + }, + .sda = { + .i2c_mode = MX6_PAD_GPIO_6__I2C3_SDA | PC, + .gpio_mode = MX6_PAD_GPIO_16__GPIO7_IO11 | PC, + .gp = IMX_GPIO_NR(7, 11) + } +}; + +/* + * This enet related pin-muxing and GPIO handling is done + * in SPL U-Boot. For early initialization. And to give the + * PHY some time to come out of reset before the U-Boot + * ethernet driver tries to access its registers via MDIO. + */ +int platinum_setup_enet(void) +{ + gpio_direction_output(IMX_GPIO_NR(3, 23), 0); + gpio_direction_output(IMX_GPIO_NR(6, 30), 1); + gpio_direction_output(IMX_GPIO_NR(6, 25), 1); + gpio_direction_output(IMX_GPIO_NR(6, 27), 1); + gpio_direction_output(IMX_GPIO_NR(6, 28), 1); + gpio_direction_output(IMX_GPIO_NR(6, 29), 1); + imx_iomux_v3_setup_multiple_pads(enet_pads1, ARRAY_SIZE(enet_pads1)); + gpio_direction_output(IMX_GPIO_NR(6, 24), 1); + + /* Need delay 10ms according to KSZ9021 spec */ + mdelay(10); + gpio_set_value(IMX_GPIO_NR(3, 23), 1); + udelay(100); + + imx_iomux_v3_setup_multiple_pads(enet_pads2, ARRAY_SIZE(enet_pads2)); + + return 0; +} + +int platinum_setup_i2c(void) +{ + setup_i2c(0, CONFIG_SYS_I2C_SPEED, 0x7f, &i2c_pad_info0); + setup_i2c(2, CONFIG_SYS_I2C_SPEED, 0x7f, &i2c_pad_info2); + + return 0; +} + +int platinum_setup_spi(void) +{ + imx_iomux_v3_setup_multiple_pads(ecspi1_pads, ARRAY_SIZE(ecspi1_pads)); + imx_iomux_v3_setup_multiple_pads(ecspi2_pads, ARRAY_SIZE(ecspi2_pads)); + + return 0; +} + +int platinum_setup_uart(void) +{ + imx_iomux_v3_setup_multiple_pads(uart1_pads, ARRAY_SIZE(uart1_pads)); + imx_iomux_v3_setup_multiple_pads(uart2_pads, ARRAY_SIZE(uart2_pads)); + imx_iomux_v3_setup_multiple_pads(uart4_pads, ARRAY_SIZE(uart4_pads)); + + return 0; +} + +int platinum_phy_config(struct phy_device *phydev) +{ + /* min rx data delay */ + ksz9021_phy_extended_write(phydev, MII_KSZ9021_EXT_RGMII_RX_DATA_SKEW, + 0x0); + /* min tx data delay */ + ksz9021_phy_extended_write(phydev, MII_KSZ9021_EXT_RGMII_TX_DATA_SKEW, + 0x0); + /* max rx/tx clock delay, min rx/tx control */ + ksz9021_phy_extended_write(phydev, MII_KSZ9021_EXT_RGMII_CLOCK_SKEW, + 0xf0f0); + if (phydev->drv->config) + phydev->drv->config(phydev); + + return 0; +} + +int platinum_init_gpio(void) +{ + /* Default GPIO's */ + /* Toggle CONFIG_n to reset fpga on every boot */ + gpio_direction_output(IMX_GPIO_NR(5, 18), 0); + /* Need delay >=2uS */ + udelay(3); + gpio_set_value(IMX_GPIO_NR(5, 18), 1); + + /* Default pin 1,15 high - DLP_FLASH_WPZ */ + gpio_direction_output(IMX_GPIO_NR(1, 15), 1); + + return 0; +} + +int platinum_init_usb(void) +{ + return 0; +} + +int platinum_init_finished(void) +{ + return 0; +} diff --git a/board/barco/platinum/spl_picon.c b/board/barco/platinum/spl_picon.c new file mode 100644 index 0000000..f421c21 --- /dev/null +++ b/board/barco/platinum/spl_picon.c @@ -0,0 +1,182 @@ +/* + * Copyright (C) 2014 Stefan Roese sr@denx.de + * + * Based on: gw_ventana_spl.c which is: + * Copyright (C) 2014 Gateworks Corporation + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <i2c.h> +#include <asm/io.h> +#include <asm/arch/iomux.h> +#include <asm/arch/mx6-ddr.h> +#include <asm/arch/mx6-pins.h> +#include <asm/arch/sys_proto.h> +#include <asm/imx-common/boot_mode.h> +#include <asm/imx-common/iomux-v3.h> +#include <asm/imx-common/mxc_i2c.h> +#include <spl.h> + +#include "platinum.h" + +DECLARE_GLOBAL_DATA_PTR; + +#undef RTT_NOM_120OHM /* use 120ohm Rtt_nom vs 60ohm (lower power) */ + +/* Configure MX6Q/DUAL mmdc DDR io registers */ +struct mx6sdl_iomux_ddr_regs mx6sdl_ddr_ioregs = { + /* SDCLK[0:1], CAS, RAS, Reset: Differential input, 40ohm */ + .dram_sdclk_0 = 0x00020030, + .dram_sdclk_1 = 0x00020030, + .dram_cas = 0x00020030, + .dram_ras = 0x00020030, + .dram_reset = 0x00020030, + /* SDCKE[0:1]: 100k pull-up */ + .dram_sdcke0 = 0x00003000, + .dram_sdcke1 = 0x00003000, + /* SDBA2: pull-up disabled */ + .dram_sdba2 = 0x00000000, + /* SDODT[0:1]: 100k pull-up, 40 ohm */ + .dram_sdodt0 = 0x00003030, + .dram_sdodt1 = 0x00003030, + /* SDQS[0:7]: Differential input, 40 ohm */ + .dram_sdqs0 = 0x00000030, + .dram_sdqs1 = 0x00000030, + .dram_sdqs2 = 0x00000030, + .dram_sdqs3 = 0x00000030, + .dram_sdqs4 = 0x00000030, + .dram_sdqs5 = 0x00000030, + .dram_sdqs6 = 0x00000030, + .dram_sdqs7 = 0x00000030, + /* DQM[0:7]: Differential input, 40 ohm */ + .dram_dqm0 = 0x00020030, + .dram_dqm1 = 0x00020030, + .dram_dqm2 = 0x00020030, + .dram_dqm3 = 0x00020030, + .dram_dqm4 = 0x00020030, + .dram_dqm5 = 0x00020030, + .dram_dqm6 = 0x00020030, + .dram_dqm7 = 0x00020030, +}; + +/* Configure MX6Q/DUAL mmdc GRP io registers */ +struct mx6sdl_iomux_grp_regs mx6sdl_grp_ioregs = { + /* DDR3 */ + .grp_ddr_type = 0x000c0000, + .grp_ddrmode_ctl = 0x00020000, + /* disable DDR pullups */ + .grp_ddrpke = 0x00000000, + /* ADDR[00:16], SDBA[0:1]: 40 ohm */ + .grp_addds = 0x00000030, + /* CS0/CS1/SDBA2/CKE0/CKE1/SDWE: 40 ohm */ + .grp_ctlds = 0x00000030, + /* DATA[00:63]: Differential input, 40 ohm */ + .grp_ddrmode = 0x00020000, + .grp_b0ds = 0x00000030, + .grp_b1ds = 0x00000030, + .grp_b2ds = 0x00000030, + .grp_b3ds = 0x00000030, + .grp_b4ds = 0x00000030, + .grp_b5ds = 0x00000030, + .grp_b6ds = 0x00000030, + .grp_b7ds = 0x00000030, +}; + +/* MT41K256M16HA-125 */ +static struct mx6_ddr3_cfg mt41k256m16ha_125 = { + .mem_speed = 1600, + .density = 4, /* 4Gbit */ + .width = 16, + .banks = 8, + .rowaddr = 15, + .coladdr = 10, + .pagesz = 2, + .trcd = 1375, + .trcmin = 4875, + .trasmin = 3500, +}; + +/* + * Values from running the Freescale DDR stress tool via USB + */ +static struct mx6_mmdc_calibration mx6dq_mmdc_calib = { + /* write leveling calibration determine */ + .p0_mpwldectrl0 = 0x0044004E, + .p0_mpwldectrl1 = 0x001F0023, + /* Read DQS Gating calibration */ + .p0_mpdgctrl0 = 0x02480248, + .p0_mpdgctrl1 = 0x0210021C, + /* Read Calibration: DQS delay relative to DQ read access */ + .p0_mprddlctl = 0x42444444, + /* Write Calibration: DQ/DM delay relative to DQS write access */ + .p0_mpwrdlctl = 0x36322C32, +}; + +static void spl_dram_init(int width) +{ + struct mx6_ddr3_cfg *mem = &mt41k256m16ha_125; + struct mx6_ddr_sysinfo sysinfo = { + /* width of data bus:0=16,1=32,2=64 */ + .dsize = width / 32, + /* config for full 4GB range so that get_mem_size() works */ + .cs_density = 32, /* 32Gb per CS */ + /* single chip select */ + .ncs = 1, + .cs1_mirror = 1, + .rtt_wr = 1 /*DDR3_RTT_60_OHM*/, /* RTT_Wr = RZQ/4 */ +#ifdef RTT_NOM_120OHM + .rtt_nom = 2 /*DDR3_RTT_120_OHM*/, /* RTT_Nom = RZQ/2 */ +#else + .rtt_nom = 1 /*DDR3_RTT_60_OHM*/, /* RTT_Nom = RZQ/4 */ +#endif + .walat = 0, /* Write additional latency */ + .ralat = 5, /* Read additional latency */ + .mif3_mode = 3, /* Command prediction working mode */ + .bi_on = 1, /* Bank interleaving enabled */ + .sde_to_rst = 0x10, /* 14 cycles, 200us (JEDEC default) */ + .rst_to_cke = 0x23, /* 33 cycles, 500us (JEDEC default) */ + }; + + mx6sdl_dram_iocfg(width, &mx6sdl_ddr_ioregs, &mx6sdl_grp_ioregs); + mx6_dram_cfg(&sysinfo, &mx6dq_mmdc_calib, mem); +} + +/* + * Called from C runtime startup code (arch/arm/lib/crt0.S:_main) + * - we have a stack and a place to store GD, both in SRAM + * - no variable global data is available + */ +void board_init_f(ulong dummy) +{ + /* Setup AIPS and disable watchdog */ + arch_cpu_init(); + + ccgr_init(); + gpr_init(); + + /* UART iomux */ + board_early_init_f(); + + /* Setup GP timer */ + timer_init(); + + /* UART clocks enabled and gd valid - init serial console */ + preloader_console_init(); + + /* Init DDR with 32bit width */ + spl_dram_init(32); + + /* Clear the BSS */ + memset(__bss_start, 0, __bss_end - __bss_start); + + /* + * Setup enet related MUXing early to give the PHY + * some time to wake-up from reset + */ + platinum_setup_enet(); + + /* load/boot image from boot device */ + board_init_r(NULL, 0); +} diff --git a/board/barco/platinum/spl_titanium.c b/board/barco/platinum/spl_titanium.c new file mode 100644 index 0000000..26fe26b --- /dev/null +++ b/board/barco/platinum/spl_titanium.c @@ -0,0 +1,185 @@ +/* + * Copyright (C) 2014 Stefan Roese sr@denx.de + * + * Based on: gw_ventana_spl.c which is: + * Copyright (C) 2014 Gateworks Corporation + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <i2c.h> +#include <asm/io.h> +#include <asm/arch/iomux.h> +#include <asm/arch/mx6-ddr.h> +#include <asm/arch/mx6-pins.h> +#include <asm/arch/sys_proto.h> +#include <asm/imx-common/boot_mode.h> +#include <asm/imx-common/iomux-v3.h> +#include <asm/imx-common/mxc_i2c.h> +#include <spl.h> + +#include "platinum.h" + +DECLARE_GLOBAL_DATA_PTR; + +#undef RTT_NOM_120OHM /* use 120ohm Rtt_nom vs 60ohm (lower power) */ + +/* Configure MX6Q/DUAL mmdc DDR io registers */ +struct mx6dq_iomux_ddr_regs mx6dq_ddr_ioregs = { + /* SDCLK[0:1], CAS, RAS, Reset: Differential input, 40ohm */ + .dram_sdclk_0 = 0x00020030, + .dram_sdclk_1 = 0x00020030, + .dram_cas = 0x00020030, + .dram_ras = 0x00020030, + .dram_reset = 0x00020030, + /* SDCKE[0:1]: 100k pull-up */ + .dram_sdcke0 = 0x00003000, + .dram_sdcke1 = 0x00003000, + /* SDBA2: pull-up disabled */ + .dram_sdba2 = 0x00000000, + /* SDODT[0:1]: 100k pull-up, 40 ohm */ + .dram_sdodt0 = 0x00003030, + .dram_sdodt1 = 0x00003030, + /* SDQS[0:7]: Differential input, 40 ohm */ + .dram_sdqs0 = 0x00000030, + .dram_sdqs1 = 0x00000030, + .dram_sdqs2 = 0x00000030, + .dram_sdqs3 = 0x00000030, + .dram_sdqs4 = 0x00000030, + .dram_sdqs5 = 0x00000030, + .dram_sdqs6 = 0x00000030, + .dram_sdqs7 = 0x00000030, + /* DQM[0:7]: Differential input, 40 ohm */ + .dram_dqm0 = 0x00020030, + .dram_dqm1 = 0x00020030, + .dram_dqm2 = 0x00020030, + .dram_dqm3 = 0x00020030, + .dram_dqm4 = 0x00020030, + .dram_dqm5 = 0x00020030, + .dram_dqm6 = 0x00020030, + .dram_dqm7 = 0x00020030, +}; + +/* Configure MX6Q/DUAL mmdc GRP io registers */ +struct mx6dq_iomux_grp_regs mx6dq_grp_ioregs = { + /* DDR3 */ + .grp_ddr_type = 0x000c0000, + .grp_ddrmode_ctl = 0x00020000, + /* disable DDR pullups */ + .grp_ddrpke = 0x00000000, + /* ADDR[00:16], SDBA[0:1]: 40 ohm */ + .grp_addds = 0x00000030, + /* CS0/CS1/SDBA2/CKE0/CKE1/SDWE: 40 ohm */ + .grp_ctlds = 0x00000030, + /* DATA[00:63]: Differential input, 40 ohm */ + .grp_ddrmode = 0x00020000, + .grp_b0ds = 0x00000030, + .grp_b1ds = 0x00000030, + .grp_b2ds = 0x00000030, + .grp_b3ds = 0x00000030, + .grp_b4ds = 0x00000030, + .grp_b5ds = 0x00000030, + .grp_b6ds = 0x00000030, + .grp_b7ds = 0x00000030, +}; + +/* MT41J128M16JT-125 */ +static struct mx6_ddr3_cfg mt41j128m16jt_125 = { + .mem_speed = 1600, + .density = 2, + .width = 16, + .banks = 8, + .rowaddr = 14, + .coladdr = 10, + .pagesz = 2, + .trcd = 1375, + .trcmin = 4875, + .trasmin = 3500, +}; + +static struct mx6_mmdc_calibration mx6dq_mmdc_calib = { + /* Write leveling calibration determine */ + .p0_mpwldectrl0 = 0x001f001f, + .p0_mpwldectrl1 = 0x001f001f, + .p1_mpwldectrl0 = 0x00440044, + .p1_mpwldectrl1 = 0x00440044, + /* Read DQS Gating calibration */ + .p0_mpdgctrl0 = 0x434b0350, + .p0_mpdgctrl1 = 0x034c0359, + .p1_mpdgctrl0 = 0x434b0350, + .p1_mpdgctrl1 = 0x03650348, + /* Read Calibration: DQS delay relative to DQ read access */ + .p0_mprddlctl = 0x4436383b, + .p1_mprddlctl = 0x39393341, + /* Write Calibration: DQ/DM delay relative to DQS write access */ + .p0_mpwrdlctl = 0x35373933, + .p1_mpwrdlctl = 0x48254a36, +}; + +static void spl_dram_init(int width) +{ + struct mx6_ddr3_cfg *mem = &mt41j128m16jt_125; + struct mx6_ddr_sysinfo sysinfo = { + /* width of data bus:0=16,1=32,2=64 */ + .dsize = width / 32, + /* config for full 4GB range so that get_mem_size() works */ + .cs_density = 32, /* 32Gb per CS */ + /* single chip select */ + .ncs = 1, + .cs1_mirror = 1, + .rtt_wr = 1 /*DDR3_RTT_60_OHM*/, /* RTT_Wr = RZQ/4 */ +#ifdef RTT_NOM_120OHM + .rtt_nom = 2 /*DDR3_RTT_120_OHM*/, /* RTT_Nom = RZQ/2 */ +#else + .rtt_nom = 1 /*DDR3_RTT_60_OHM*/, /* RTT_Nom = RZQ/4 */ +#endif + .walat = 0, /* Write additional latency */ + .ralat = 5, /* Read additional latency */ + .mif3_mode = 3, /* Command prediction working mode */ + .bi_on = 1, /* Bank interleaving enabled */ + .sde_to_rst = 0x10, /* 14 cycles, 200us (JEDEC default) */ + .rst_to_cke = 0x23, /* 33 cycles, 500us (JEDEC default) */ + }; + + mx6dq_dram_iocfg(width, &mx6dq_ddr_ioregs, &mx6dq_grp_ioregs); + mx6_dram_cfg(&sysinfo, &mx6dq_mmdc_calib, mem); +} + +/* + * Called from C runtime startup code (arch/arm/lib/crt0.S:_main) + * - we have a stack and a place to store GD, both in SRAM + * - no variable global data is available + */ +void board_init_f(ulong dummy) +{ + /* Setup AIPS and disable watchdog */ + arch_cpu_init(); + + ccgr_init(); + gpr_init(); + + /* UART iomux */ + board_early_init_f(); + + /* Setup GP timer */ + timer_init(); + + /* UART clocks enabled and gd valid - init serial console */ + preloader_console_init(); + + /* Init DDR with 32bit width */ + spl_dram_init(32); + + /* Clear the BSS */ + memset(__bss_start, 0, __bss_end - __bss_start); + + /* + * Setup enet related MUXing early to give the PHY + * some time to wake-up from reset + */ + platinum_setup_enet(); + + /* load/boot image from boot device */ + board_init_r(NULL, 0); +} diff --git a/configs/platinum_picon_defconfig b/configs/platinum_picon_defconfig new file mode 100644 index 0000000..c3ca040 --- /dev/null +++ b/configs/platinum_picon_defconfig @@ -0,0 +1,4 @@ +CONFIG_SPL=y +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,MX6DL" ++S:CONFIG_ARM=y ++S:CONFIG_TARGET_PLATINUM_PICON=y diff --git a/configs/platinum_titanium_defconfig b/configs/platinum_titanium_defconfig new file mode 100644 index 0000000..db8cef9 --- /dev/null +++ b/configs/platinum_titanium_defconfig @@ -0,0 +1,4 @@ +CONFIG_SPL=y +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,MX6Q" ++S:CONFIG_ARM=y ++S:CONFIG_TARGET_PLATINUM_TITANIUM=y diff --git a/include/configs/platinum.h b/include/configs/platinum.h new file mode 100644 index 0000000..134bb45 --- /dev/null +++ b/include/configs/platinum.h @@ -0,0 +1,319 @@ +/* + * Copyright (C) 2014, Barco (www.barco.com) + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __PLATINUM_CONFIG_H__ +#define __PLATINUM_CONFIG_H__ + +#define CONFIG_SYS_GENERIC_BOARD + +/* SPL */ +#define CONFIG_SPL_NAND_SUPPORT +#define CONFIG_SPL_MMC_SUPPORT + +/* Location in NAND to read U-Boot from */ +#define CONFIG_SYS_NAND_U_BOOT_OFFS (14 * 1024 * 1024) + +#include "imx6_spl.h" /* common IMX6 SPL configuration */ +#include "mx6_common.h" +#include <asm/arch/imx-regs.h> +#include <asm/imx-common/gpio.h> + +/* + * Console configuration + */ + +#include <config_cmd_default.h> +#define CONFIG_CMD_BMODE +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_EXT2 +#define CONFIG_CMD_FAT +#define CONFIG_CMD_FUSE +#define CONFIG_CMD_GPIO +#define CONFIG_CMD_I2C +#undef CONFIG_CMD_IMLS +#define CONFIG_CMD_MII +#define CONFIG_CMD_MMC +#define CONFIG_CMD_MTDPARTS +#define CONFIG_CMD_NAND +#define CONFIG_CMD_NAND_TRIMFFS +#define CONFIG_CMD_NET +#define CONFIG_CMD_PING +#define CONFIG_CMD_TIME +#define CONFIG_CMD_UBI +#define CONFIG_CMD_UBIFS +#define CONFIG_CMD_USB + +/* + * Hardware configuration + */ + +/* GPIO config */ +#define CONFIG_MXC_GPIO + +/* UART config */ +#define CONFIG_MXC_UART +#define CONFIG_MXC_UART_BASE UART1_BASE +#define CONFIG_BAUDRATE 115200 +#define CONFIG_CONS_INDEX 1 + +/* I2C config */ +#define CONFIG_SYS_I2C +#define CONFIG_SYS_I2C_MXC +#define CONFIG_SYS_I2C_SPEED 100000 + +/* MMC config */ +#define CONFIG_FSL_ESDHC +#define CONFIG_FSL_USDHC +#define CONFIG_SYS_FSL_ESDHC_ADDR 0 +#define CONFIG_SYS_FSL_USDHC_NUM 1 +#define CONFIG_MMC +#define CONFIG_GENERIC_MMC +#define CONFIG_BOUNCE_BUFFER +#define CONFIG_DOS_PARTITION + +/* Ethernet config */ +#define CONFIG_FEC_MXC +#define CONFIG_MII +#define IMX_FEC_BASE ENET_BASE_ADDR + +#define CONFIG_PHYLIB + +/* USB config */ +#define CONFIG_USB_EHCI +#define CONFIG_USB_EHCI_MX6 +#define CONFIG_USB_STORAGE +#define CONFIG_MXC_USB_PORT 1 +#define CONFIG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) +#define CONFIG_MXC_USB_FLAGS 0 + +/* Memory config */ +#define CONFIG_NR_DRAM_BANKS 1 +#define PHYS_SDRAM MMDC0_ARB_BASE_ADDR +#ifndef PHYS_SDRAM_SIZE +#define PHYS_SDRAM_SIZE (1024 << 20) +#endif + +#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM +#define CONFIG_SYS_INIT_RAM_ADDR IRAM_BASE_ADDR +#define CONFIG_SYS_INIT_RAM_SIZE IRAM_SIZE + +#define CONFIG_SYS_INIT_SP_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - \ + GENERATED_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_INIT_RAM_ADDR + \ + CONFIG_SYS_INIT_SP_OFFSET) + +#define CONFIG_SYS_MALLOC_LEN (16 * 1024 * 1024) + +/* FLASH and environment organization */ +#define CONFIG_SYS_NO_FLASH + +#ifdef CONFIG_CMD_NAND + +/* NAND config */ +#define CONFIG_NAND_MXS +#ifndef CONFIG_SYS_NAND_MAX_CHIPS +#define CONFIG_SYS_NAND_MAX_CHIPS 2 +#endif +#define CONFIG_SYS_MAX_NAND_DEVICE 1 +#define CONFIG_SYS_NAND_BASE 0x40000000 +#define CONFIG_SYS_NAND_5_ADDR_CYCLE +#define CONFIG_SYS_NAND_ONFI_DETECTION + +/* DMA config, needed for GPMI/MXS NAND support */ +#define CONFIG_APBH_DMA +#define CONFIG_APBH_DMA_BURST +#define CONFIG_APBH_DMA_BURST8 + +/* Fuse support */ +#define CONFIG_MXC_OCOTP + +/* Environment in NAND */ +#define CONFIG_ENV_IS_IN_NAND +#define CONFIG_ENV_OFFSET (16 << 20) +#define CONFIG_ENV_SECT_SIZE (128 << 10) +#define CONFIG_ENV_SIZE CONFIG_ENV_SECT_SIZE +#define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + (512 << 10)) +#define CONFIG_ENV_SIZE_REDUND CONFIG_ENV_SIZE + +#else /* CONFIG_CMD_NAND */ + +/* Environment in MMC */ +#define CONFIG_ENV_SIZE (8 << 10) +#define CONFIG_ENV_IS_IN_MMC +#define CONFIG_ENV_OFFSET (6 * 64 * 1024) +#define CONFIG_SYS_MMC_ENV_DEV 0 + +#endif /* CONFIG_CMD_NAND */ + +/* + * U-Boot configuration + */ + +/* Console boot messages */ +#define CONFIG_DISPLAY_CPUINFO +#define CONFIG_DISPLAY_BOARDINFO + +/* Tag config */ +#define CONFIG_CMDLINE_TAG +#define CONFIG_SETUP_MEMORY_TAGS +#define CONFIG_INITRD_TAG +#define CONFIG_REVISION_TAG + +/* Board startup config */ +#define CONFIG_BOARD_EARLY_INIT_F +#define CONFIG_MISC_INIT_R + +/* allow to overwrite serial and ethaddr */ +#define CONFIG_ENV_OVERWRITE + +/* Device tree support */ +#define CONFIG_OF_LIBFDT + +#define CONFIG_LOADADDR 0x12000000 +#define CONFIG_SYS_TEXT_BASE 0x17800000 + +#define CONFIG_SYS_MEMTEST_START PHYS_SDRAM +#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START + \ + PHYS_SDRAM_SIZE - (12 << 20)) + +#define CONFIG_BOOTDELAY 3 +#define CONFIG_BOOTCOMMAND "run bootubi_scr" + +/* Miscellaneous configurable options */ +#define CONFIG_SYS_LONGHELP +#define CONFIG_SYS_HUSH_PARSER + +#define CONFIG_AUTO_COMPLETE +#define CONFIG_CMDLINE_EDITING +#define CONFIG_PREBOOT + +#define CONFIG_SYS_CBSIZE 256 + +/* Print Buffer Size */ +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ + sizeof(CONFIG_SYS_PROMPT) + 16) +#define CONFIG_SYS_MAXARGS 16 +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE + +#define CONFIG_SYS_LOAD_ADDR CONFIG_LOADADDR + +/* MTD/UBI/UBIFS config */ +#define CONFIG_LZO +#define CONFIG_MTD_DEVICE +#define CONFIG_MTD_PARTITIONS +#define CONFIG_RBTREE + +#if (CONFIG_SYS_NAND_MAX_CHIPS == 1) +#define MTDIDS_DEFAULT "nand0=gpmi-nand" +#define MTDPARTS_DEFAULT "mtdparts=gpmi-nand:14M(spl),2M(uboot)," \ + "512k(env1),512k(env2),-(ubi)" +#elif (CONFIG_SYS_NAND_MAX_CHIPS == 2) +#define MTDIDS_DEFAULT "nand0=gpmi-nand" +#define MTDPARTS_DEFAULT "mtdparts=gpmi-nand:14M(spl),2M(uboot)," \ + "512k(env1),512k(env2),495M(ubi0)," \ + "14M(res0),2M(res1)," \ + "512k(res2),512k(res3),-(ubi1)" +#endif + +#ifndef CONFIG_SYS_DCACHE_OFF +#define CONFIG_CMD_CACHE +#endif + +/* + * Environment configuration + */ + +#if (CONFIG_SYS_NAND_MAX_CHIPS == 1) +#define CONFIG_COMMON_ENV_UBI \ + "setubipartition=env set ubipartition ubi\0" \ + "setubirfs=env set ubirfs $ubipartition:rootfs$boot_vol\0" +#elif (CONFIG_SYS_NAND_MAX_CHIPS == 2) +#define CONFIG_COMMON_ENV_UBI \ + "setubipartition=env set ubipartition ubi$boot_vol\0" \ + "setubirfs=env set ubirfs ubi0:rootfs\0" +#endif + +#define CONFIG_COMMON_ENV_MISC \ + "user=user\0" \ + "project="CONFIG_PLATINUM_PROJECT"\0" \ + "uimage=uImage\0" \ + "dtb="CONFIG_PLATINUM_CPU"-platinum-"CONFIG_PLATINUM_PROJECT".dtb\0" \ + "serverip=serverip\0" \ + "memaddrlinux=0x10800000\0" \ + "memaddrsrc=0x11000000\0" \ + "memaddrdtb=0x12000000\0" \ + "console=ttymxc0\0" \ + "baudrate=115200\0" \ + "boot_scr=boot.uboot\0" \ + "boot_vol=0\0" \ + "mtdids="MTDIDS_DEFAULT"\0" \ + "mtdparts="MTDPARTS_DEFAULT"\0" \ + "mmcfs=ext2\0" \ + "mmcrootpart=1\0" \ + \ + "setnfspath=env set nfspath /home/nfs/$user/$project/root\0" \ + "settftpfilelinux=env set tftpfilelinux $user/$project/$uimage\0" \ + "settftpfiledtb=env set tftpfiledtb $user/$project/$dtb\0" \ + "setubifilelinux=env set ubifilelinux boot/$uimage\0" \ + "setubipfiledtb=env set ubifiledtb boot/$dtb\0" \ + "setmmcrootdev=env set mmcrootdev /dev/mmcblk0p$mmcrootpart\0" \ + "setmmcfilelinux=env set mmcfilelinux /boot/$uimage\0" \ + "setmmcfiledtb=env set mmcfiledtb /boot/$dtb\0" \ + \ + "loadtftpkernel=dhcp $memaddrlinux $tftpfilelinux\0" \ + "loadtftpdtb=dhcp $memaddrdtb $tftpfiledtb\0" \ + "loadubikernel=ubifsload $memaddrlinux $ubifilelinux\0" \ + "loadubidtb=ubifsload $memaddrdtb $ubifiledtb\0" \ + "loadmmckernel=${mmcfs}load mmc 0:$mmcrootpart $memaddrlinux " \ + "$mmcfilelinux\0" \ + "loadmmcdtb=${mmcfs}load mmc 0:$mmcrootpart $memaddrdtb " \ + "$mmcfiledtb\0" \ + \ + "ubipart=ubi part $ubipartition\0" \ + "ubimount=ubifsmount $ubirfs\0" \ + \ + "setbootargscommon=env set bootargs $bootargs " \ + "console=$console,$baudrate enable_wait_mode=off\0" \ + "setbootargsmtd=env set bootargs $bootargs $mtdparts\0" \ + "setbootargsdhcp=env set bootargs $bootargs ip=dhcp\0" \ + "setbootargsubirfs=env set bootargs $bootargs " \ + "ubi.mtd=$ubipartition root=$ubirfs rootfstype=ubifs\0" \ + "setbootargsnfsrfs=env set bootargs $bootargs root=/dev/nfs " \ + "nfsroot=$serverip:$nfspath,v3,tcp\0" \ + "setbootargsmmcrfs=env set bootargs $bootargs " \ + "root=$mmcrootdev rootwait rw\0" \ + \ + "bootnet=run settftpfilelinux settftpfiledtb setnfspath " \ + "setbootargscommon setbootargsmtd setbootargsdhcp " \ + "setbootargsnfsrfs;" \ + "run loadtftpkernel loadtftpdtb;" \ + "bootm $memaddrlinux - $memaddrdtb\0" \ + "bootnet_ubirfs=run settftpfilelinux settftpfiledtb;" \ + "run setubipartition setubirfs;" \ + "run setbootargscommon setbootargsmtd " \ + "setbootargsubirfs;" \ + "run loadtftpkernel loadtftpdtb;" \ + "bootm $memaddrlinux - $memaddrdtb\0" \ + "bootubi=run setubipartition setubirfs setubifilelinux " \ + "setubipfiledtb;" \ + "run setbootargscommon setbootargsmtd " \ + "setbootargsubirfs;" \ + "run ubipart ubimount loadubikernel loadubidtb;" \ + "bootm $memaddrlinux - $memaddrdtb\0" \ + "bootubi_scr=run setubipartition setubirfs;" \ + "run ubipart ubimount;" \ + "if ubifsload ${memaddrsrc} boot/${boot_scr}; " \ + "then source ${memaddrsrc}; else run bootubi; fi\0" \ + "bootmmc=run setmmcrootdev setmmcfilelinux setmmcfiledtb " \ + "setbootargscommon setbootargsmmcrfs;" \ + "run loadmmckernel loadmmcdtb;" \ + "bootm $memaddrlinux - $memaddrdtb\0" \ + \ + "bootcmd="CONFIG_BOOTCOMMAND"\0" + +#define CONFIG_COMMON_ENV_SETTINGS CONFIG_COMMON_ENV_MISC \ + CONFIG_COMMON_ENV_UBI +#endif /* __PLATINUM_CONFIG_H__ */ diff --git a/include/configs/platinum_picon.h b/include/configs/platinum_picon.h new file mode 100644 index 0000000..4590df5 --- /dev/null +++ b/include/configs/platinum_picon.h @@ -0,0 +1,31 @@ +/* + * Copyright (C) 2014, Barco (www.barco.com) + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __PLATINUM_PICON_CONFIG_H__ +#define __PLATINUM_PICON_CONFIG_H__ + +#define CONFIG_PLATINUM_PICON +#define CONFIG_PLATINUM_BOARD "Barco Picon" +#define CONFIG_PLATINUM_PROJECT "picon" +#define CONFIG_PLATINUM_CPU "imx6dl" + +#define CONFIG_MX6 + +#include <configs/platinum.h> + +#define CONFIG_FEC_XCV_TYPE RMII +#define CONFIG_FEC_MXC_PHYADDR 0 + +#define CONFIG_HOSTNAME picon + +#define CONFIG_SYS_PROMPT "picon > " + +#define CONFIG_PLATFORM_ENV_SETTINGS "\0" + +#define CONFIG_EXTRA_ENV_SETTINGS CONFIG_COMMON_ENV_SETTINGS \ + CONFIG_PLATFORM_ENV_SETTINGS + +#endif /* __PLATINUM_PICON_CONFIG_H__ */ diff --git a/include/configs/platinum_titanium.h b/include/configs/platinum_titanium.h new file mode 100644 index 0000000..6789655 --- /dev/null +++ b/include/configs/platinum_titanium.h @@ -0,0 +1,38 @@ +/* + * Copyright (C) 2014, Barco (www.barco.com) + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __PLATINUM_TITANIUM_CONFIG_H__ +#define __PLATINUM_TITANIUM_CONFIG_H__ + +#define CONFIG_PLATINUM_TITANIUM +#define CONFIG_PLATINUM_BOARD "Barco Titanium" +#define CONFIG_PLATINUM_PROJECT "titanium" +#define CONFIG_PLATINUM_CPU "imx6q" + +#define CONFIG_MX6 + +#define PHYS_SDRAM_SIZE (512 << 20) +#define CONFIG_SYS_NAND_MAX_CHIPS 1 + +#include <configs/platinum.h> + +#define CONFIG_FEC_XCV_TYPE RGMII +#define CONFIG_FEC_MXC_PHYADDR 4 + +#define CONFIG_PHY_MICREL +#define CONFIG_PHY_MICREL_KSZ9021 +#define CONFIG_PHY_RESET_DELAY 1000 + +#define CONFIG_HOSTNAME titanium + +#define CONFIG_SYS_PROMPT "titanium > " + +#define CONFIG_PLATFORM_ENV_SETTINGS "\0" + +#define CONFIG_EXTRA_ENV_SETTINGS CONFIG_COMMON_ENV_SETTINGS \ + CONFIG_PLATFORM_ENV_SETTINGS + +#endif /* __PLATINUM_TITANIUM_CONFIG_H__ */
platinum-titanium
platinum-picon
Applied to -u-boot-imx, thanks !
Best regards, Stefano Babic
Stefan Roese
Stefano Babic
