[U-Boot] [PATCH v3] sun50i: a64: Add Olimex A64-Teres-I board initial support
Olimex A64-Teres-I board is a mainboard (the only one so far) for Olimex Teres-I DIY laptop kit.
Key features: - Allwinner A64 Cortex-A53 - Mali-400MP2 GPU - AXP803 PMIC - 2GB DDR3 RAM - MicroSD Slot - 16GB eMMC Flash - eDP LCD display - HDMI - USB Host - Battery management - 5V DC power supply - Certified Open Source Hardware (OSHW)
Works: - i2C - MMC/SD - PWM backlight
Known broken: - USB
Company page: https://linux-sunxi.org/Olimex_Teres-A64 Community page: https://linux-sunxi.org/Olimex_Teres-A64 hardware sources: https://github.com/OLIMEX/DIY-LAPTOP/tree/master/HARDWARE/A64-TERES/TERES-PC...
This patch enables support for the A64-Teres-I board to u-boot, including enabling screen backlight (lacking from Linux device-tree).
Linux commit details about the sun50i-a64-teres-i.dts sync: "arm64: dts: allwinner: a64: Rename uart0_pins_a label to uart0_pb_pins" (sha1: d91ebb95b96c8840932dc3a10c9f243712555467)
Cosmetic warnings regarding whitespace and placement of SPDX notice for dts file was ignored.
config and .dtsi file are adapted from pinebook files.
Tested-by: Jonas Smedegaard dr@jones.dk Signed-off-by: Jonas Smedegaard dr@jones.dk ---
Changes for v2: * List Icenowy and Jonas as MAINTAINERS * Add commit hash in linux tree for sun50i-a64-teres-i.dts * Drop superfluous and unsupported Author: tag
Changes for v3: * Use tags sun50i a64 (not sunxi) * List key, working, and known broken features * Reference upstream pages. * Reference linux commit
--- MAINTAINERS | 8 + arch/arm/dts/Makefile | 3 +- arch/arm/dts/sun50i-a64-teres-i-u-boot.dtsi | 41 +++ arch/arm/dts/sun50i-a64-teres-i.dts | 270 ++++++++++++++++++++ configs/teres_i_defconfig | 21 ++ 5 files changed, 342 insertions(+), 1 deletion(-) create mode 100644 arch/arm/dts/sun50i-a64-teres-i-u-boot.dtsi create mode 100644 arch/arm/dts/sun50i-a64-teres-i.dts create mode 100644 configs/teres_i_defconfig
diff --git a/MAINTAINERS b/MAINTAINERS index c77abba1e5..d6ba87a0ba 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -319,6 +319,14 @@ F: arch/arm/include/asm/arch-sunxi/ F: arch/arm/mach-sunxi/ F: board/sunxi/
+ARM SUNXI OLIMEX TERES-I +M: Jonas Smedegaard dr@jones.dk +M: Icenowy Zheng icenowy@aosc.io +S: Maintained +T: git https://salsa.debian.org/js/u-boot +F: arch/arm/dts/sun50i-a64-teres-i* +F: configs/teres_i_defconfig + ARM TEGRA M: Tom Warren twarren@nvidia.com S: Maintained diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 0aee8dfde0..eabe9e1ae3 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -483,7 +483,8 @@ dtb-$(CONFIG_MACH_SUN50I) += \ sun50i-a64-pine64-plus.dtb \ sun50i-a64-pine64.dtb \ sun50i-a64-pinebook.dtb \ - sun50i-a64-sopine-baseboard.dtb + sun50i-a64-sopine-baseboard.dtb \ + sun50i-a64-teres-i.dtb dtb-$(CONFIG_MACH_SUN9I) += \ sun9i-a80-optimus.dtb \ sun9i-a80-cubieboard4.dtb \ diff --git a/arch/arm/dts/sun50i-a64-teres-i-u-boot.dtsi b/arch/arm/dts/sun50i-a64-teres-i-u-boot.dtsi new file mode 100644 index 0000000000..1a64b7d09c --- /dev/null +++ b/arch/arm/dts/sun50i-a64-teres-i-u-boot.dtsi @@ -0,0 +1,41 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (C) 2019 Vasily Khoruzhick anarsoul@gmail.com + * + */ + +#include "sunxi-u-boot.dtsi" + +/ { + vdd_bl: regulator@0 { + compatible = "regulator-fixed"; + regulator-name = "bl-3v3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + gpio = <&pio 7 6 GPIO_ACTIVE_HIGH>; /* PH6 */ + enable-active-high; + }; + + backlight: backlight { + compatible = "pwm-backlight"; + pwms = <&pwm 0 50000 0>; + brightness-levels = <0 5 10 15 20 30 40 55 70 85 100>; + default-brightness-level = <2>; + enable-gpios = <&pio 3 23 GPIO_ACTIVE_HIGH>; /* PD23 */ + power-supply = <&vdd_bl>; + }; +}; + +/* The ANX6345 eDP-bridge is on i2c */ +&i2c0 { + anx6345: edp-bridge@38 { + compatible = "analogix,anx6345"; + reg = <0x38>; + reset-gpios = <&pio 3 24 GPIO_ACTIVE_LOW>; /* PD24 */ + status = "okay"; + }; +}; + +&pwm { + status = "okay"; +}; diff --git a/arch/arm/dts/sun50i-a64-teres-i.dts b/arch/arm/dts/sun50i-a64-teres-i.dts new file mode 100644 index 0000000000..c455b24dd0 --- /dev/null +++ b/arch/arm/dts/sun50i-a64-teres-i.dts @@ -0,0 +1,270 @@ +/* + * Copyright (C) Harald Geyer harald@ccbib.org + * based on sun50i-a64-olinuxino.dts by Jagan Teki jteki@openedev.com + * + * SPDX-License-Identifier: (GPL-2.0 OR MIT) + */ + +/dts-v1/; + +#include "sun50i-a64.dtsi" + +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/input/input.h> +#include <dt-bindings/pwm/pwm.h> + +/ { + model = "Olimex A64 Teres-I"; + compatible = "olimex,a64-teres-i", "allwinner,sun50i-a64"; + + aliases { + serial0 = &uart0; + }; + + chosen { + stdout-path = "serial0:115200n8"; + + framebuffer-lcd { + eDP25-supply = <®_dldo2>; + eDP12-supply = <®_dldo3>; + }; + }; + + gpio-keys { + compatible = "gpio-keys"; + + lid-switch { + label = "Lid Switch"; + gpios = <&r_pio 0 8 GPIO_ACTIVE_LOW>; /* PL8 */ + linux,input-type = <EV_SW>; + linux,code = <SW_LID>; + wakeup-source; + }; + }; + + leds { + compatible = "gpio-leds"; + + capslock { + label = "teres-i:green:capslock"; + gpios = <&pio 2 7 GPIO_ACTIVE_HIGH>; /* PC7 */ + }; + + numlock { + label = "teres-i:green:numlock"; + gpios = <&pio 2 4 GPIO_ACTIVE_HIGH>; /* PC4 */ + }; + }; + + reg_usb1_vbus: usb1-vbus { + compatible = "regulator-fixed"; + regulator-name = "usb1-vbus"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + enable-active-high; + gpio = <&r_pio 0 7 GPIO_ACTIVE_HIGH>; /* PL7 */ + status = "okay"; + }; + + wifi_pwrseq: wifi_pwrseq { + compatible = "mmc-pwrseq-simple"; + reset-gpios = <&r_pio 0 2 GPIO_ACTIVE_LOW>; /* PL2 */ + }; +}; + +&ehci1 { + status = "okay"; +}; + + +/* The ANX6345 eDP-bridge is on i2c0. There is no linux (mainline) + * driver for this chip at the moment, the bootloader initializes it. + * However it can be accessed with the i2c-dev driver from user space. + */ +&i2c0 { + clock-frequency = <100000>; + pinctrl-names = "default"; + pinctrl-0 = <&i2c0_pins>; + status = "okay"; +}; + +&mmc0 { + pinctrl-names = "default"; + pinctrl-0 = <&mmc0_pins>; + vmmc-supply = <®_dcdc1>; + cd-gpios = <&pio 5 6 GPIO_ACTIVE_LOW>; + disable-wp; + bus-width = <4>; + status = "okay"; +}; + +&mmc1 { + pinctrl-names = "default"; + pinctrl-0 = <&mmc1_pins>; + vmmc-supply = <®_aldo2>; + vqmmc-supply = <®_dldo4>; + mmc-pwrseq = <&wifi_pwrseq>; + bus-width = <4>; + non-removable; + status = "okay"; + + rtl8723bs: wifi@1 { + reg = <1>; + interrupt-parent = <&r_pio>; + interrupts = <0 3 IRQ_TYPE_LEVEL_LOW>; /* PL3 */ + interrupt-names = "host-wake"; + }; +}; + +&mmc2 { + pinctrl-names = "default"; + pinctrl-0 = <&mmc2_pins>; + vmmc-supply = <®_dcdc1>; + vqmmc-supply = <®_dcdc1>; + bus-width = <8>; + non-removable; + cap-mmc-hw-reset; + status = "okay"; +}; + +&ohci1 { + status = "okay"; +}; + +&r_rsb { + status = "okay"; + + axp803: pmic@3a3 { + compatible = "x-powers,axp803"; + reg = <0x3a3>; + interrupt-parent = <&r_intc>; + interrupts = <0 IRQ_TYPE_LEVEL_LOW>; + wakeup-source; + }; +}; + +#include "axp803.dtsi" + +®_aldo1 { + regulator-always-on; + regulator-min-microvolt = <2800000>; + regulator-max-microvolt = <2800000>; + regulator-name = "vcc-pe"; +}; + +®_aldo2 { + regulator-always-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vcc-pl"; +}; + +®_aldo3 { + regulator-always-on; + regulator-min-microvolt = <3000000>; + regulator-max-microvolt = <3000000>; + regulator-name = "vcc-pll-avcc"; +}; + +®_dcdc1 { + regulator-always-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vcc-3v3"; +}; + +®_dcdc2 { + regulator-always-on; + regulator-min-microvolt = <1040000>; + regulator-max-microvolt = <1300000>; + regulator-name = "vdd-cpux"; +}; + +/* DCDC3 is polyphased with DCDC2 */ + +®_dcdc5 { + regulator-always-on; + regulator-min-microvolt = <1500000>; + regulator-max-microvolt = <1500000>; + regulator-name = "vcc-ddr3"; +}; + +®_dcdc6 { + regulator-always-on; + regulator-min-microvolt = <1100000>; + regulator-max-microvolt = <1100000>; + regulator-name = "vdd-sys"; +}; + +®_dldo1 { + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vcc-hdmi"; +}; + +®_dldo2 { + regulator-min-microvolt = <2500000>; + regulator-max-microvolt = <2500000>; + regulator-name = "vcc-pd"; +}; + +®_dldo3 { + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <1200000>; + regulator-name = "vdd-edp"; +}; + +®_dldo4 { + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vcc-wifi-io"; +}; + +®_eldo1 { + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-name = "cpvdd"; +}; + +®_eldo2 { + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-name = "vcc-dvdd-csi"; +}; + +®_fldo1 { + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <1200000>; + regulator-name = "vcc-1v2-hsic"; +}; + +/* + * The A64 chip cannot work without this regulator off, although + * it seems to be only driving the AR100 core. + * Maybe we don't still know well about CPUs domain. + */ +®_fldo2 { + regulator-always-on; + regulator-min-microvolt = <1100000>; + regulator-max-microvolt = <1100000>; + regulator-name = "vdd-cpus"; +}; + +®_rtc_ldo { + regulator-name = "vcc-rtc"; +}; + +&simplefb_hdmi { + vcc-hdmi-supply = <®_dldo1>; +}; + +&uart0 { + pinctrl-names = "default"; + pinctrl-0 = <&uart0_pb_pins>; + status = "okay"; +}; + +&usbphy { + usb1_vbus-supply = <®_usb1_vbus>; + status = "okay"; +}; diff --git a/configs/teres_i_defconfig b/configs/teres_i_defconfig new file mode 100644 index 0000000000..939dc24408 --- /dev/null +++ b/configs/teres_i_defconfig @@ -0,0 +1,21 @@ +CONFIG_ARM=y +CONFIG_ARCH_SUNXI=y +CONFIG_SPL=y +CONFIG_MACH_SUN50I=y +CONFIG_DRAM_CLK=552 +CONFIG_DRAM_ZQ=3881949 +CONFIG_MMC_SUNXI_SLOT_EXTRA=2 +CONFIG_I2C0_ENABLE=y +# CONFIG_CMD_FLASH is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set +CONFIG_DEFAULT_DEVICE_TREE="sun50i-a64-teres-i" +CONFIG_DM_REGULATOR=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_PWM=y +CONFIG_PWM_SUNXI=y +CONFIG_USB_EHCI_HCD=y +CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y +# CONFIG_USB_GADGET is not set +CONFIG_VIDEO_BRIDGE=y +CONFIG_VIDEO_BRIDGE_ANALOGIX_ANX6345=y
Key features:
- Mali-400MP2 GPU
- AXP803 PMIC
- 2GB DDR3 RAM
- MicroSD Slot
- 16GB eMMC Flash
- eDP LCD display
- HDMI
- USB Host
Works:
- i2C
- MMC/SD
- PWM backlight
Known broken:
- USB
what is broken? any information?
I usually won't prefer these links in commit message.
Changes for v2:
- List Icenowy and Jonas as MAINTAINERS
- Add commit hash in linux tree for sun50i-a64-teres-i.dts
- Drop superfluous and unsupported Author: tag
Changes for v3:
- Use tags sun50i a64 (not sunxi)
- List key, working, and known broken features
- Reference upstream pages.
- Reference linux commit
Is there any relation to this tree to Mainline. usually the git tree which are preparing PR's can list like this otherwise no need.
Quoting Jagan Teki (2019-04-18 18:57:59)
Known broken:
- USB
Below is the console output - neither builtin USB1 keyboard nor an external USB USB2 hub with a USB1 keyboard attached are detected:
U-Boot 2019.04-00502-g3a85a96182-dirty (Apr 18 2019 - 17:12:25 +0200) Allwinner Technology
CPU: Allwinner A64 (SUN50I) Model: Olimex A64 Teres-I DRAM: 2 GiB MMC: Device 'mmc@1c11000': seq 1 is in use by 'mmc@1c10000' mmc@1c0f000: 0, mmc@1c10000: 2, mmc@1c11000: 1 Loading Environment from FAT... OK In: serial Out: vidconsole Err: vidconsole Net: No ethernet found. starting USB... Bus usb@1c1b000: USB EHCI 1.00 scanning bus usb@1c1b000 for devices... 1 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found Hit any key to stop autoboot: 0 => usb tree USB device tree: 1 Hub (480 Mb/s, 0mA) u-boot EHCI Host Controller
Ok, I'll remove those.
Ok. Probably best I remove that line, then.
- Jonas
Quoting Jonas Smedegaard (2019-04-18 20:22:28)
Known broken:
- USB
...and "dm tree" contains this:
[...] regulator 0 [ ] fixed regulator |-- usb1-vbus regulator 1 [ + ] fixed regulator |-- regulator@0 [...]
Also, if I enable CONFIG_USB_OHCI_HCD (noticing that was done generally for a64 boards recently in commit 29d280c88a), then u-boot hangs just after the "Bus usb@1c1b000: USB EHCI 1.00".
General question: Is it appropriate to cc this many individuals (resolved by the patman script), or if not which are appropriate?
- Jonas
Jagan Teki
Jonas Smedegaard
