[U-Boot] [PATCH] cm4008, cm41xx: fix build warnings
Fix these: cm4008.c: In function 'board_eth_init': cm4008.c:79: warning: implicit declaration of function 'ks8695_eth_initialize'
cm41xx.c: In function 'board_eth_init': cm41xx.c:79: warning: implicit declaration of function 'ks8695_eth_initialize'
While we are at it, sort include list in netdev.h
Signed-off-by: Wolfgang Denk wd@denx.de Cc: Greg Ungerer greg.ungerer@opengear.com --- board/cm4008/cm4008.c | 1 + board/cm41xx/cm41xx.c | 1 + include/netdev.h | 18 +++++++++--------- 3 files changed, 11 insertions(+), 9 deletions(-)
diff --git a/board/cm4008/cm4008.c b/board/cm4008/cm4008.c index 2e8d948..ed493a8 100644 --- a/board/cm4008/cm4008.c +++ b/board/cm4008/cm4008.c @@ -30,6 +30,7 @@
#include <common.h> #include <asm/arch/platform.h> +#include <netdev.h>
DECLARE_GLOBAL_DATA_PTR;
diff --git a/board/cm41xx/cm41xx.c b/board/cm41xx/cm41xx.c index 72fd64d..d9dff4e 100644 --- a/board/cm41xx/cm41xx.c +++ b/board/cm41xx/cm41xx.c @@ -30,6 +30,7 @@
diff --git a/include/netdev.h b/include/netdev.h index 83d7886..96c7b9b 100644 --- a/include/netdev.h +++ b/include/netdev.h @@ -43,30 +43,32 @@ int cpu_eth_init(bd_t *bis); /* Driver initialization prototypes */ int altera_tse_initialize(u8 dev_num, int mac_base, int sgdma_rx_base, int sgdma_tx_base); -int ax88180_initialize(bd_t *bis); -int au1x00_enet_initialize(bd_t*); int at91emac_register(bd_t *bis, unsigned long iobase); +int au1x00_enet_initialize(bd_t*); +int ax88180_initialize(bd_t *bis); int bfin_EMAC_initialize(bd_t *bis); int cs8900_initialize(u8 dev_num, int base_addr); -int dc21x4x_initialize(bd_t *bis); int davinci_emac_initialize(void); +int dc21x4x_initialize(bd_t *bis); int designware_initialize(u32 id, ulong base_addr, u32 phy_addr); +int dm9000_initialize(bd_t *bis); int dnet_eth_initialize(int id, void *regs, unsigned int phy_addr); int e1000_initialize(bd_t *bis); int eepro100_initialize(bd_t *bis); int enc28j60_initialize(unsigned int bus, unsigned int cs, unsigned int max_hz, unsigned int mode); int ep93xx_eth_initialize(u8 dev_num, int base_addr); -int ethoc_initialize(u8 dev_num, int base_addr); int eth_3com_initialize (bd_t * bis); +int ethoc_initialize(u8 dev_num, int base_addr); int fec_initialize (bd_t *bis); int fecmxc_initialize (bd_t *bis); +int fecmxc_initialize(bd_t *bis); int ftgmac100_initialize(bd_t *bits); int ftmac100_initialize(bd_t *bits); int greth_initialize(bd_t *bis); void gt6426x_eth_initialize(bd_t *bis); int inca_switch_initialize(bd_t *bis); -int ks8695_eth_initialize(bd_t *bis); +int ks8695_eth_initialize(void); int lan91c96_initialize(u8 dev_num, int base_addr); int macb_eth_initialize(int id, void *regs, unsigned int phy_addr); int mcdmafec_initialize(bd_t *bis); @@ -85,16 +87,14 @@ int ppc_4xx_eth_initialize (bd_t *bis); int rtl8139_initialize(bd_t *bis); int rtl8169_initialize(bd_t *bis); int scc_initialize(bd_t *bis); +int sh_eth_initialize(bd_t *bis); int skge_initialize(bd_t *bis); -int smc911x_initialize(u8 dev_num, int base_addr); int smc91111_initialize(u8 dev_num, int base_addr); +int smc911x_initialize(u8 dev_num, int base_addr); int tsi108_eth_initialize(bd_t *bis); int uec_standard_init(bd_t *bis); int uli526x_initialize(bd_t *bis); int xilinx_emaclite_initialize (bd_t *bis, int base_addr); -int sh_eth_initialize(bd_t *bis); -int dm9000_initialize(bd_t *bis); -int fecmxc_initialize(bd_t *bis);
/* Boards with PCI network controllers can call this from their board_eth_init() * function to initialize whatever's on board.
Dear Wolfgang Denk,
Applied, thanks.
