[U-Boot] [PATCH] nios2: flush dcache after relocating code in start.S
If we relocate the code, the data cache must be flushed before we jump to the new code.
Signed-off-by: Thomas Chou thomas@wytron.com.tw --- cpu/nios2/start.S | 11 +++++++++++ 1 files changed, 11 insertions(+), 0 deletions(-)
diff --git a/cpu/nios2/start.S b/cpu/nios2/start.S index 4b4c560..b0a51a8 100644 --- a/cpu/nios2/start.S +++ b/cpu/nios2/start.S @@ -106,6 +106,17 @@ _cur: movhi r5, %hi(_cur - _start) bne r5, r6, 2b 3:
+ /* DCACHE FLUSH -- after relocating code and data + */ + movhi r4, %hi(CONFIG_SYS_DCACHELINE_SIZE) + ori r4, r4, %lo(CONFIG_SYS_DCACHELINE_SIZE) + movhi r5, %hi(CONFIG_SYS_DCACHE_SIZE) + ori r5, r5, %lo(CONFIG_SYS_DCACHE_SIZE) + mov r6, r0 +1: flushd 0(r6) + add r6, r6, r4 + bltu r6, r5, 1b + /* ZERO BSS/SBSS -- bss and sbss are assumed to be adjacent * and between __bss_start and _end. */
diff --git a/cpu/nios2/start.S b/cpu/nios2/start.S index 31cd5b0..61784d8 100644 --- a/cpu/nios2/start.S +++ b/cpu/nios2/start.S @@ -98,6 +98,17 @@ _cur: movhi r5, %hi(_cur - _start) stwio r7, 0(r5) addi r5, r5, 4 bne r5, r6, 2b + + /* DCACHE FLUSH -- after relocating code and data + */ + movhi r4, %hi(CONFIG_SYS_DCACHELINE_SIZE) + ori r4, r4, %lo(CONFIG_SYS_DCACHELINE_SIZE) + movhi r5, %hi(CONFIG_SYS_DCACHE_SIZE) + ori r5, r5, %lo(CONFIG_SYS_DCACHE_SIZE) + mov r6, r0 +1: flushd 0(r6) + add r6, r6, r4 + bltu r6, r5, 1b 3:
Hi Thomas,
Patch is reject.
The existing code uses stxio instructions, which by their very purpose, bypass the cache. So there's no need to flush the data cache.
One could argue that invalidating the _instruction_ cache may be necessary ... but I doubt it, given that first instructions after reset invalidate the entire instruction cache. It would be a defensive nevertheless.
Regards, --Scott
Scott McNutt
Thomas Chou
