[U-Boot] [PATCH] hush shell: Avoid string write overflow when entering max cmd length
console_buffer array is defined to be CONFIG_SYS_CBSIZE + 1 long, whereas the_command array only CONFIG_SYS_CBSIZE long. Subsequent use of strcpy(the_command, console_buffer) will write final \0 terminating byte outside the_command array when entering a command of max length.
Signed-off-by: Kristian Otnes <kotnes <at> cisco <dot> com> --- common/hush.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/common/hush.c b/common/hush.c index df10267..5b43224 100644 --- a/common/hush.c +++ b/common/hush.c @@ -996,7 +996,7 @@ static void get_user_input(struct in_str *i) i->p = the_command; #else int n; - static char the_command[CONFIG_SYS_CBSIZE]; + static char the_command[CONFIG_SYS_CBSIZE + 1];
#ifdef CONFIG_BOOT_RETRY_TIME # ifndef CONFIG_RESET_TO_RETRY
Kristian Otnes
