[U-Boot] [PATCH v2 1/3] spl: mmc: Fix indentation in spl_mmc.c file
This fixes a wrongly indented block of code.
Signed-off-by: Mans Rullgard mans@mansr.com [lukma: Make the commit message more verbose] Signed-off-by: Lukasz Majewski lukma@denx.de
Changes in v2: None
common/spl/spl_mmc.c | 40 ++++++++++++++++++++-------------------- 1 file changed, 20 insertions(+), 20 deletions(-)
diff --git a/common/spl/spl_mmc.c b/common/spl/spl_mmc.c index b3619889f7..2caceb5186 100644 --- a/common/spl/spl_mmc.c +++ b/common/spl/spl_mmc.c @@ -334,28 +334,28 @@ int spl_mmc_load(struct spl_image_info *spl_image, err = -EINVAL; switch (boot_mode) { case MMCSD_MODE_EMMCBOOT: - /* - * We need to check what the partition is configured to. - * 1 and 2 match up to boot0 / boot1 and 7 is user data - * which is the first physical partition (0). - */ - part = (mmc->part_config >> 3) & PART_ACCESS_MASK; - - if (part == 7) - part = 0; - - if (CONFIG_IS_ENABLED(MMC_TINY)) - err = mmc_switch_part(mmc, part); - else - err = blk_dselect_hwpart(mmc_get_blk_desc(mmc), part); - - if (err) { + /* + * We need to check what the partition is configured to. + * 1 and 2 match up to boot0 / boot1 and 7 is user data + * which is the first physical partition (0). + */ + part = (mmc->part_config >> 3) & PART_ACCESS_MASK; + + if (part == 7) + part = 0; + + if (CONFIG_IS_ENABLED(MMC_TINY)) + err = mmc_switch_part(mmc, part); + else + err = blk_dselect_hwpart(mmc_get_blk_desc(mmc), part); + + if (err) { #ifdef CONFIG_SPL_LIBCOMMON_SUPPORT - puts("spl: mmc partition switch failed\n"); + puts("spl: mmc partition switch failed\n"); #endif - return err; - } - /* Fall through */ + return err; + } + /* Fall through */ case MMCSD_MODE_RAW: debug("spl: mmc boot mode: raw\n");
This change allows setting pre-defined eMMC boot partition for SPL eMMC booting. It is necessary in the case when one wants to boot (through falcon boot) from eMMC after loading SPL from other memory (like SPI-NOR).
Signed-off-by: Mans Rullgard mans@mansr.com [lukma: Edit the commit message] Signed-off-by: Lukasz Majewski lukma@denx.de
Changes in v2: None
common/spl/Kconfig | 6 ++++++ common/spl/spl_mmc.c | 4 ++++ 2 files changed, 10 insertions(+)
diff --git a/common/spl/Kconfig b/common/spl/Kconfig index 0a3877ec28..4fe4a1359c 100644 --- a/common/spl/Kconfig +++ b/common/spl/Kconfig @@ -293,6 +293,12 @@ config SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR Address on the MMC to load U-Boot from, when the MMC is being used in raw mode. Units: MMC sectors (1 sector = 512 bytes).
+config SYS_MMCSD_RAW_MODE_EMMC_BOOT_PARTITION + int "Number of the eMMC boot partition to use" + default 1 + help + eMMC boot partition number to use when the eMMC in raw mode. + config SYS_MMCSD_RAW_MODE_U_BOOT_USE_PARTITION bool "MMC Raw mode: by partition" help diff --git a/common/spl/spl_mmc.c b/common/spl/spl_mmc.c index 2caceb5186..a4d2e63b82 100644 --- a/common/spl/spl_mmc.c +++ b/common/spl/spl_mmc.c @@ -334,6 +334,9 @@ int spl_mmc_load(struct spl_image_info *spl_image, err = -EINVAL; switch (boot_mode) { case MMCSD_MODE_EMMCBOOT: +#ifdef CONFIG_SYS_MMCSD_RAW_MODE_EMMC_BOOT_PARTITION + part = CONFIG_SYS_MMCSD_RAW_MODE_EMMC_BOOT_PARTITION; +#else /* * We need to check what the partition is configured to. * 1 and 2 match up to boot0 / boot1 and 7 is user data @@ -343,6 +346,7 @@ int spl_mmc_load(struct spl_image_info *spl_image,
if (part == 7) part = 0; +#endif
if (CONFIG_IS_ENABLED(MMC_TINY)) err = mmc_switch_part(mmc, part);
Acked-by: Andreas Dannenberg dannenberg@ti.com
Regards, Andreas
Changes in v2: None
- int "Number of the eMMC boot partition to use"
- default 1
- help
-- 2.11.0
This patch introduces support for i.MX28 based XEA board.
This board supports DM/DTS in U-Boot proper as well as DM aware drivers in SPL (u-boot.sb). More detailed information regarding usage of it can be found in ./board/liebherr/xea/README file.
U-Boot SPL 2019.10-rc1-00233-g6aa549f05c (Aug 12 2019 - 09:23:36 +0200) Trying to boot from MMC1 MMC0: Command 8 timeout (status 0xf0344020) mmc_load_image_raw_sector: mmc block read error
U-Boot 2019.10-rc1-00233-g6aa549f05c (Aug 12 2019 - 09:23:36 +0200)
CPU: Freescale i.MX28 rev1.2 at 454 MHz BOOT: SSP SPI #3, master, 3V3 NOR Model: Liebherr (LWE) XEA i.MX28 Board DRAM: 128 MiB MMC: MXS MMC: 0 Loading Environment from SPI Flash... SF: Detected n25q128a13 with page size 256 Bytes, erase size 64 KiB, total 16 MiB OK In: serial Out: serial Err: serial Net: Warning: ethernet@800f0000 (eth0) using random MAC address - ce:e1:9e:46:f3:a2 eth0: ethernet@800f0000 Hit any key to stop autoboot: 0
Signed-off-by: Mans Rullgard mans@mansr.com Signed-off-by: Lukasz Majewski lukma@denx.de
Changes in v2: - Adjust config to match dependent patches - Increase malloc size to allow booting the board with GPIO DM/DTS support - Add support for GPIO driver in SPL (with DM + OF_PLATDATA) - Adjust spl_xea.c to support bootmode pins - Add patches to set in Kconfig default boot HW partition for eMMC
Dependencies: - The whole patch series (v2) (1-4) starting at: https://patchwork.ozlabs.org/cover/1146494/
- Fixes/conversion for i.MX28 spi, emmc and gpio (the whole series 1-9): https://patchwork.ozlabs.org/cover/1148900/
Applied on top of -master branch: SHA1: feb5a02f869d5678190dfc915ef6c2781b4f7a6c
Travis-CI: https://travis-ci.org/lmajewski/u-boot-dfu/builds/573538193 --- arch/arm/dts/Makefile | 3 + arch/arm/dts/imx28-xea-u-boot.dtsi | 46 ++++++ arch/arm/dts/imx28-xea.dts | 110 ++++++++++++++ arch/arm/mach-imx/mxs/Kconfig | 4 + board/liebherr/xea/Kconfig | 24 +++ board/liebherr/xea/MAINTAINERS | 6 + board/liebherr/xea/Makefile | 12 ++ board/liebherr/xea/README | 63 ++++++++ board/liebherr/xea/spl_xea.c | 303 +++++++++++++++++++++++++++++++++++++ board/liebherr/xea/xea.c | 152 +++++++++++++++++++ configs/imx28_xea_defconfig | 109 +++++++++++++ include/configs/xea.h | 196 ++++++++++++++++++++++++ 12 files changed, 1028 insertions(+) create mode 100644 arch/arm/dts/imx28-xea-u-boot.dtsi create mode 100644 arch/arm/dts/imx28-xea.dts create mode 100644 board/liebherr/xea/Kconfig create mode 100644 board/liebherr/xea/MAINTAINERS create mode 100644 board/liebherr/xea/Makefile create mode 100644 board/liebherr/xea/README create mode 100644 board/liebherr/xea/spl_xea.c create mode 100644 board/liebherr/xea/xea.c create mode 100644 configs/imx28_xea_defconfig create mode 100644 include/configs/xea.h
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 9e7d6d6490..555532b933 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -544,6 +544,9 @@ dtb-$(CONFIG_VF610) += vf500-colibri.dtb \ vf610-pcm052.dtb \ vf610-bk4r1.dtb
+dtb-$(CONFIG_MX28) += \ + imx28-xea.dtb + dtb-$(CONFIG_MX53) += imx53-cx9020.dtb \ imx53-kp.dtb \ imx53-m53menlo.dtb diff --git a/arch/arm/dts/imx28-xea-u-boot.dtsi b/arch/arm/dts/imx28-xea-u-boot.dtsi new file mode 100644 index 0000000000..cc2ced5d2d --- /dev/null +++ b/arch/arm/dts/imx28-xea-u-boot.dtsi @@ -0,0 +1,46 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2019 + * Lukasz Majewski, DENX Software Engineering, lukma@denx.de + * + * SPDX-License-Identifier: GPL-2.0+ or X11 + */ + +/* + * The minimal augmentation DTS U-Boot file to allow eMMC driver + * configuration in SPL for falcon boot. + */ +#include "imx28-u-boot.dtsi" +/ { + apb@80000000 { + u-boot,dm-spl; + + apbh@80000000 { + u-boot,dm-spl; + }; + + apbx@80040000 { + u-boot,dm-spl; + }; + }; +}; + +&clks { + u-boot,dm-spl; +}; + +&gpio0 { + u-boot,dm-spl; +}; + +&pinctrl { + u-boot,dm-spl; +}; + +&ssp0 { + u-boot,dm-spl; +}; + +&ssp3 { + u-boot,dm-spl; +}; diff --git a/arch/arm/dts/imx28-xea.dts b/arch/arm/dts/imx28-xea.dts new file mode 100644 index 0000000000..5de6774c5a --- /dev/null +++ b/arch/arm/dts/imx28-xea.dts @@ -0,0 +1,110 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2019 + * Lukasz Majewski, DENX Software Engineering, lukma@denx.de + * + * SPDX-License-Identifier: GPL-2.0+ or X11 + * + */ + +/dts-v1/; + +#include "imx28.dtsi" + +/ { + model = "Liebherr (LWE) XEA i.MX28 Board"; + compatible = "lwe,xea", "fsl,imx28"; + + aliases { + spi3 = &ssp3; + }; + + memory@40000000 { + device_type = "memory"; + reg = <0x40000000 0x10000000>; + }; + + reg_3p3v: regulator-3p3v { + compatible = "regulator-fixed"; + regulator-name = "3P3V"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + }; + + reg_fec_3v3: regulator-fec-3v3 { + compatible = "regulator-fixed"; + regulator-name = "fec-3v3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + gpio = <&gpio0 0 GPIO_ACTIVE_HIGH>; + }; +}; + +&mac0 { + phy-mode = "rmii"; + pinctrl-names = "default"; + pinctrl-0 = <&mac0_pins_a>; + phy-supply = <®_fec_3v3>; + phy-reset-gpios = <&gpio2 13 GPIO_ACTIVE_LOW>; + phy-reset-duration = <1>; + phy-reset-post-delay = <1>; + status = "okay"; + + fixed-link { + speed = <100>; + full-duplex; + }; +}; + +&ssp0 { + compatible = "fsl,imx28-mmc"; + pinctrl-names = "default"; + pinctrl-0 = <&mmc0_8bit_pins_a>; + bus-width = <8>; + vmmc-supply = <®_3p3v>; + non-removable; + status = "okay"; +}; + +&ssp3 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "fsl,imx28-spi"; + pinctrl-names = "default"; + pinctrl-0 = <&spi3_pins_b>; + status = "okay"; + spi-max-frequency = <40000000>; + num-cs = <2>; + + flash0: s25fl256s@0 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "jedec,spi-nor"; + spi-max-frequency = <40000000>; + reg = <0>; + + partition@0 { + label = "SPL (spi)"; + reg = <0x0 0x10000>; + read-only; + }; + partition@1 { + label = "u-boot (spi)"; + reg = <0x10000 0x70000>; + read-only; + }; + partition@2 { + label = "uboot-env (spi)"; + reg = <0x80000 0x20000>; + }; + partition@3 { + label = "kernel (spi)"; + reg = <0x100000 0x400000>; + }; + partition@4 { + label = "swupdate (spi)"; + reg = <0x50000 0x800000>; + }; + }; +}; diff --git a/arch/arm/mach-imx/mxs/Kconfig b/arch/arm/mach-imx/mxs/Kconfig index 68072d5a1f..b90d7b6e41 100644 --- a/arch/arm/mach-imx/mxs/Kconfig +++ b/arch/arm/mach-imx/mxs/Kconfig @@ -60,6 +60,9 @@ config TARGET_SC_SPS_1 config TARGET_TS4600 bool "Support TS4600"
+config TARGET_XEA + bool "Support XEA" + endchoice
config SYS_SOC @@ -67,6 +70,7 @@ config SYS_SOC
source "board/bluegiga/apx4devkit/Kconfig" source "board/freescale/mx28evk/Kconfig" +source "board/liebherr/xea/Kconfig" source "board/ppcag/bg0900/Kconfig" source "board/schulercontrol/sc_sps_1/Kconfig" source "board/technologic/ts4600/Kconfig" diff --git a/board/liebherr/xea/Kconfig b/board/liebherr/xea/Kconfig new file mode 100644 index 0000000000..5428de4646 --- /dev/null +++ b/board/liebherr/xea/Kconfig @@ -0,0 +1,24 @@ +if TARGET_XEA + +config SYS_BOARD + default "xea" + +config SYS_VENDOR + default "liebherr" + +config SYS_SOC + default "mxs" + +config SYS_CONFIG_NAME + default "xea" + +config ENV_SIZE + default 0x2000 + +config ENV_SECT_SIZE + default 0x10000 if ENV_IS_IN_SPI_FLASH + +config ENV_OFFSET + default 0x80000 if ENV_IS_IN_SPI_FLASH + +endif diff --git a/board/liebherr/xea/MAINTAINERS b/board/liebherr/xea/MAINTAINERS new file mode 100644 index 0000000000..623184d0f8 --- /dev/null +++ b/board/liebherr/xea/MAINTAINERS @@ -0,0 +1,6 @@ +XEA BOARD +M: Lukasz Majewski lukma@denx.de +S: Maintained +F: board/liebherr/xea/ +F: include/configs/xea.h +F: configs/imx28_xea_defconfig diff --git a/board/liebherr/xea/Makefile b/board/liebherr/xea/Makefile new file mode 100644 index 0000000000..abf500857f --- /dev/null +++ b/board/liebherr/xea/Makefile @@ -0,0 +1,12 @@ +# +# (C) Copyright 2019 +# Lukasz Majewski, DENX Software Engineering, lukma@denx.de. +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y := xea.o + +ifdef CONFIG_SPL_BUILD +obj-y += spl_xea.o +endif diff --git a/board/liebherr/xea/README b/board/liebherr/xea/README new file mode 100644 index 0000000000..3e55d3ea43 --- /dev/null +++ b/board/liebherr/xea/README @@ -0,0 +1,63 @@ +Building SPL/U-Boot for xea board +================================= + +Setup environment, configure and build, e.g. by: + + $ make imx28_xea_defconfig + $ make -j4 u-boot.sb u-boot.img + +Now you should see u-boot.sb and u-boot.img files in the build directory. + + +Booting +======= + +The boot ROM loads SPL from SPI NOR flash into SRAM. SPL configures +DRAM and loads either a Linux kernel (falcon mode) or, if the rescue +pin is asserted, the main U-Boot. Both kernel and U-Boot reside in +eMMC boot partition 0. For redundancy, a copy of U-Boot is also +stored in SPI flash. If a valid kernel image is not found, U-Boot is +loaded from eMMC or, if this fails, SPI flash. + +Boot area layout +---------------- + +SPI NOR +Offset Function File +------------------------------------------ +0x00000000 SPL u-boot.sb +0x00010000 U-Boot u-boot.img +0x00080000 Environment + +eMMC +Offset Function File +------------------------------------------ +0x00000000 U-Boot u-boot.img +0x00080000 Devicetree imx28-bttc.dtb +0x00100000 Kernel uImage + + +Falcon mode +=========== + +In falcon mode, the default, SPL loads the kernel and devicetree +directly. For this to work, the stored devicetree must include +correct "memory" and "chosen" nodes as these are not updated by SPL +before booting the kernel. + + +Updating from U-Boot +==================== + +The default U-Boot environment includes command sequences to update +SPL, U-Boot, and kernel over TFTP. These are as follows: + +- update_spl: writes u-boot.sb to SPI NOR +- update_uboot: writes u-boot.img to eMMC and SPI NOR +- update_kernel: writes kernel and devicetree to eMMC + +They can be invoked at the U-Boot prompt using the "run" command, +e.g. "run update_spl" to update the SPL. + +These update commands download the above-named files from the +${hostname} directory on the server provided by DHCP. diff --git a/board/liebherr/xea/spl_xea.c b/board/liebherr/xea/spl_xea.c new file mode 100644 index 0000000000..d88b75bb3a --- /dev/null +++ b/board/liebherr/xea/spl_xea.c @@ -0,0 +1,303 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * DENX M28 Boot setup + * + * Copyright (C) 2019 DENX Software Engineering + * Lukasz Majewski, DENX Software Engineering, lukma@denx.de + * + * Copyright (C) 2018 DENX Software Engineering + * Måns Rullgård, DENX Software Engineering, mans@mansr.com + * + * Copyright (C) 2011 Marek Vasut marek.vasut@gmail.com + * on behalf of DENX Software Engineering GmbH + */ + +#include <common.h> +#include <config.h> +#include <asm/io.h> +#include <asm/arch/iomux-mx28.h> +#include <asm/arch/imx-regs.h> +#include <asm/arch/sys_proto.h> + +#define MUX_CONFIG_LCD (MXS_PAD_3V3 | MXS_PAD_4MA | MXS_PAD_NOPULL) +#define MUX_CONFIG_BOOT (MXS_PAD_3V3 | MXS_PAD_PULLUP) +#define MUX_CONFIG_TSC (MXS_PAD_3V3 | MXS_PAD_8MA | MXS_PAD_PULLUP) +#define MUX_CONFIG_SSP0 (MXS_PAD_3V3 | MXS_PAD_12MA | MXS_PAD_PULLUP) +#define MUX_CONFIG_SSP2 (MXS_PAD_3V3 | MXS_PAD_4MA | MXS_PAD_PULLUP) +#define MUX_CONFIG_ENET (MXS_PAD_3V3 | MXS_PAD_8MA | MXS_PAD_NOPULL) +#define MUX_CONFIG_EMI (MXS_PAD_3V3 | MXS_PAD_12MA | MXS_PAD_NOPULL) + +const iomux_cfg_t iomux_setup[] = { + /* AUART0 IRDA */ + MX28_PAD_AUART0_RX__AUART0_RX, + MX28_PAD_AUART0_TX__AUART0_TX, + + /* AUART 4 RS422 */ + MX28_PAD_AUART0_CTS__AUART4_RX, + MX28_PAD_AUART0_RTS__AUART4_TX, + + /* USB0 */ + MX28_PAD_AUART1_CTS__USB0_OVERCURRENT, + MX28_PAD_AUART1_RTS__USB0_ID, + MX28_PAD_LCD_VSYNC__GPIO_1_28, /* PRW_On */ + + /* USB1 */ + MX28_PAD_PWM2__USB1_OVERCURRENT, + + /* eMMC */ + MX28_PAD_SSP0_CMD__SSP0_CMD | MUX_CONFIG_SSP0, + MX28_PAD_SSP0_DATA0__SSP0_D0 | MUX_CONFIG_SSP0, + MX28_PAD_SSP0_DATA1__SSP0_D1 | MUX_CONFIG_SSP0, + MX28_PAD_SSP0_DATA2__SSP0_D2 | MUX_CONFIG_SSP0, + MX28_PAD_SSP0_DATA3__SSP0_D3 | MUX_CONFIG_SSP0, + MX28_PAD_SSP0_DATA4__SSP0_D4 | MUX_CONFIG_SSP0, + MX28_PAD_SSP0_DATA5__SSP0_D5 | MUX_CONFIG_SSP0, + MX28_PAD_SSP0_DATA6__SSP0_D6 | MUX_CONFIG_SSP0, + MX28_PAD_SSP0_DATA7__SSP0_D7 | MUX_CONFIG_SSP0, + MX28_PAD_SSP0_DETECT__GPIO_2_9, /* Reset for eMMC */ + MX28_PAD_SSP0_SCK__SSP0_SCK | MUX_CONFIG_SSP0, + + /* DIG Keys */ + MX28_PAD_GPMI_D00__GPIO_0_0, + MX28_PAD_GPMI_D01__GPIO_0_1, + MX28_PAD_GPMI_D02__GPIO_0_2, + MX28_PAD_GPMI_D03__GPIO_0_3, + MX28_PAD_GPMI_D04__GPIO_0_4, + MX28_PAD_GPMI_D05__GPIO_0_5, + MX28_PAD_GPMI_D06__GPIO_0_6, + MX28_PAD_GPMI_D07__GPIO_0_7, + + /* ADR_0-2 */ + MX28_PAD_GPMI_CE1N__GPIO_0_17, + MX28_PAD_GPMI_CE2N__GPIO_0_18, + MX28_PAD_GPMI_CE3N__GPIO_0_19, + + /* Read Keys */ + MX28_PAD_GPMI_RDY0__GPIO_0_20, + + /* LATCH_EN */ + MX28_PAD_GPMI_RDY1__GPIO_0_21, + + /* Power off */ + MX28_PAD_GPMI_RDN__GPIO_0_24, + + /* I2C1 Touch */ + MX28_PAD_AUART2_CTS__GPIO_3_10, + MX28_PAD_AUART2_RTS__GPIO_3_11, + MX28_PAD_GPMI_RDY2__GPIO_0_22, /* Touch Reset */ + + /* TIVA */ + MX28_PAD_AUART1_RX__SSP2_CARD_DETECT, + MX28_PAD_SSP2_MISO__SSP2_D0, + MX28_PAD_SSP2_MOSI__SSP2_CMD, + MX28_PAD_SSP2_SCK__SSP2_SCK, + MX28_PAD_SSP2_SS0__SSP2_D3, + MX28_PAD_SSP2_SS1__GPIO_2_20, + MX28_PAD_SSP2_SS2__GPIO_2_21, + + /* SPI3 NOR-Flash */ + MX28_PAD_AUART1_TX__SSP3_CARD_DETECT, + MX28_PAD_AUART2_RX__SSP3_D1, + MX28_PAD_AUART2_TX__SSP3_D2, + MX28_PAD_SSP3_MISO__SSP3_D0, + MX28_PAD_SSP3_MOSI__SSP3_CMD, + MX28_PAD_SSP3_SCK__SSP3_SCK, + MX28_PAD_SSP3_SS0__SSP3_D3, + + /* NOR-Flash CMD */ + MX28_PAD_LCD_RS__GPIO_1_26, /* Hold */ + MX28_PAD_LCD_WR_RWN__GPIO_1_25, /* write protect */ + + /* I2C0 Codec */ + MX28_PAD_I2C0_SCL__I2C0_SCL, + MX28_PAD_I2C0_SDA__I2C0_SDA, + + /* I2S Codec */ + MX28_PAD_SAIF0_BITCLK__SAIF0_BITCLK, + MX28_PAD_SAIF0_LRCLK__SAIF0_LRCLK, + MX28_PAD_SAIF0_MCLK__SAIF0_MCLK, + MX28_PAD_SAIF0_SDATA0__SAIF0_SDATA0, + MX28_PAD_SAIF1_SDATA0__SAIF1_SDATA0, + + /* PWR-Hold */ + MX28_PAD_SPDIF__GPIO_3_27, + + /* EMI */ + MX28_PAD_EMI_D00__EMI_DATA0 | MUX_CONFIG_EMI, + MX28_PAD_EMI_D01__EMI_DATA1 | MUX_CONFIG_EMI, + MX28_PAD_EMI_D02__EMI_DATA2 | MUX_CONFIG_EMI, + MX28_PAD_EMI_D03__EMI_DATA3 | MUX_CONFIG_EMI, + MX28_PAD_EMI_D04__EMI_DATA4 | MUX_CONFIG_EMI, + MX28_PAD_EMI_D05__EMI_DATA5 | MUX_CONFIG_EMI, + MX28_PAD_EMI_D06__EMI_DATA6 | MUX_CONFIG_EMI, + MX28_PAD_EMI_D07__EMI_DATA7 | MUX_CONFIG_EMI, + MX28_PAD_EMI_D08__EMI_DATA8 | MUX_CONFIG_EMI, + MX28_PAD_EMI_D09__EMI_DATA9 | MUX_CONFIG_EMI, + MX28_PAD_EMI_D10__EMI_DATA10 | MUX_CONFIG_EMI, + MX28_PAD_EMI_D11__EMI_DATA11 | MUX_CONFIG_EMI, + MX28_PAD_EMI_D12__EMI_DATA12 | MUX_CONFIG_EMI, + MX28_PAD_EMI_D13__EMI_DATA13 | MUX_CONFIG_EMI, + MX28_PAD_EMI_D14__EMI_DATA14 | MUX_CONFIG_EMI, + MX28_PAD_EMI_D15__EMI_DATA15 | MUX_CONFIG_EMI, + MX28_PAD_EMI_ODT0__EMI_ODT0 | MUX_CONFIG_EMI, + MX28_PAD_EMI_DQM0__EMI_DQM0 | MUX_CONFIG_EMI, + MX28_PAD_EMI_ODT1__EMI_ODT1 | MUX_CONFIG_EMI, + MX28_PAD_EMI_DQM1__EMI_DQM1 | MUX_CONFIG_EMI, + MX28_PAD_EMI_DDR_OPEN_FB__EMI_DDR_OPEN_FEEDBACK | MUX_CONFIG_EMI, + MX28_PAD_EMI_CLK__EMI_CLK | MUX_CONFIG_EMI, + MX28_PAD_EMI_DQS0__EMI_DQS0 | MUX_CONFIG_EMI, + MX28_PAD_EMI_DQS1__EMI_DQS1 | MUX_CONFIG_EMI, + MX28_PAD_EMI_DDR_OPEN__EMI_DDR_OPEN | MUX_CONFIG_EMI, + + MX28_PAD_EMI_A00__EMI_ADDR0 | MUX_CONFIG_EMI, + MX28_PAD_EMI_A01__EMI_ADDR1 | MUX_CONFIG_EMI, + MX28_PAD_EMI_A02__EMI_ADDR2 | MUX_CONFIG_EMI, + MX28_PAD_EMI_A03__EMI_ADDR3 | MUX_CONFIG_EMI, + MX28_PAD_EMI_A04__EMI_ADDR4 | MUX_CONFIG_EMI, + MX28_PAD_EMI_A05__EMI_ADDR5 | MUX_CONFIG_EMI, + MX28_PAD_EMI_A06__EMI_ADDR6 | MUX_CONFIG_EMI, + MX28_PAD_EMI_A07__EMI_ADDR7 | MUX_CONFIG_EMI, + MX28_PAD_EMI_A08__EMI_ADDR8 | MUX_CONFIG_EMI, + MX28_PAD_EMI_A09__EMI_ADDR9 | MUX_CONFIG_EMI, + MX28_PAD_EMI_A10__EMI_ADDR10 | MUX_CONFIG_EMI, + MX28_PAD_EMI_A11__EMI_ADDR11 | MUX_CONFIG_EMI, + MX28_PAD_EMI_A12__EMI_ADDR12 | MUX_CONFIG_EMI, + MX28_PAD_EMI_A13__EMI_ADDR13 | MUX_CONFIG_EMI, + MX28_PAD_EMI_A14__EMI_ADDR14 | MUX_CONFIG_EMI, + MX28_PAD_EMI_BA0__EMI_BA0 | MUX_CONFIG_EMI, + MX28_PAD_EMI_BA1__EMI_BA1 | MUX_CONFIG_EMI, + MX28_PAD_EMI_BA2__EMI_BA2 | MUX_CONFIG_EMI, + MX28_PAD_EMI_CASN__EMI_CASN | MUX_CONFIG_EMI, + MX28_PAD_EMI_RASN__EMI_RASN | MUX_CONFIG_EMI, + MX28_PAD_EMI_WEN__EMI_WEN | MUX_CONFIG_EMI, + MX28_PAD_EMI_CE0N__EMI_CE0N | MUX_CONFIG_EMI, + MX28_PAD_EMI_CE1N__EMI_CE1N | MUX_CONFIG_EMI, + MX28_PAD_EMI_CKE__EMI_CKE | MUX_CONFIG_EMI, + + /* Uart3 Bluetooth-Interface */ + MX28_PAD_AUART3_CTS__AUART3_CTS, + MX28_PAD_AUART3_RTS__AUART3_RTS, + MX28_PAD_AUART3_RX__AUART3_RX, + MX28_PAD_AUART3_TX__AUART3_TX, + + /* framebuffer */ + MX28_PAD_LCD_CS__LCD_CS | MUX_CONFIG_LCD, + MX28_PAD_LCD_D00__LCD_D0 | MUX_CONFIG_LCD, + MX28_PAD_LCD_D01__LCD_D1 | MUX_CONFIG_LCD, + MX28_PAD_LCD_D02__LCD_D2 | MUX_CONFIG_LCD, + MX28_PAD_LCD_D03__LCD_D3 | MUX_CONFIG_LCD, + MX28_PAD_LCD_D04__LCD_D4 | MUX_CONFIG_LCD, + MX28_PAD_LCD_D05__LCD_D5 | MUX_CONFIG_LCD, + MX28_PAD_LCD_D06__LCD_D6 | MUX_CONFIG_LCD, + MX28_PAD_LCD_D07__LCD_D7 | MUX_CONFIG_LCD, + MX28_PAD_LCD_D08__LCD_D8 | MUX_CONFIG_LCD, + MX28_PAD_LCD_D09__LCD_D9 | MUX_CONFIG_LCD, + MX28_PAD_LCD_D10__LCD_D10 | MUX_CONFIG_LCD, + MX28_PAD_LCD_D11__LCD_D11 | MUX_CONFIG_LCD, + MX28_PAD_LCD_D12__LCD_D12 | MUX_CONFIG_LCD, + MX28_PAD_LCD_D13__LCD_D13 | MUX_CONFIG_LCD, + MX28_PAD_LCD_D14__LCD_D14 | MUX_CONFIG_LCD, + MX28_PAD_LCD_D15__LCD_D15 | MUX_CONFIG_LCD, + MX28_PAD_LCD_D16__LCD_D16 | MUX_CONFIG_LCD, + MX28_PAD_LCD_D17__LCD_D17 | MUX_CONFIG_LCD, + MX28_PAD_LCD_D18__LCD_D18 | MUX_CONFIG_LCD, + MX28_PAD_LCD_D19__LCD_D19 | MUX_CONFIG_LCD, + MX28_PAD_LCD_D20__LCD_D20 | MUX_CONFIG_LCD, + MX28_PAD_LCD_D21__LCD_D21 | MUX_CONFIG_LCD, + MX28_PAD_LCD_D22__LCD_D22 | MUX_CONFIG_LCD, + MX28_PAD_LCD_D23__LCD_D23 | MUX_CONFIG_LCD, + MX28_PAD_LCD_DOTCLK__LCD_DOTCLK | MUX_CONFIG_LCD, + MX28_PAD_LCD_ENABLE__LCD_ENABLE | MUX_CONFIG_LCD, + MX28_PAD_LCD_HSYNC__LCD_HSYNC | MUX_CONFIG_LCD, + MX28_PAD_LCD_RD_E__LCD_VSYNC | MUX_CONFIG_LCD, + MX28_PAD_LCD_RESET__LCD_RESET | MUX_CONFIG_LCD, + + /* DUART RS232 */ + MX28_PAD_PWM0__DUART_RX, + MX28_PAD_PWM1__DUART_TX, + + /* FEC Ethernet */ + MX28_PAD_ENET_CLK__CLKCTRL_ENET | MUX_CONFIG_ENET, + MX28_PAD_ENET0_COL__ENET1_TX_EN | MUX_CONFIG_ENET, + MX28_PAD_ENET0_CRS__ENET1_RX_EN | MUX_CONFIG_ENET, + MX28_PAD_ENET0_MDC__ENET0_MDC | MUX_CONFIG_ENET, + MX28_PAD_ENET0_MDIO__ENET0_MDIO | MUX_CONFIG_ENET, + MX28_PAD_ENET0_RX_CLK__GPIO_4_13, /* Phy Interrupt */ + MX28_PAD_ENET0_RX_EN__ENET0_RX_EN | MUX_CONFIG_ENET, + MX28_PAD_ENET0_RXD0__ENET0_RXD0 | MUX_CONFIG_ENET, + MX28_PAD_ENET0_RXD1__ENET0_RXD1 | MUX_CONFIG_ENET, + MX28_PAD_ENET0_RXD3__ENET1_RXD1 | MUX_CONFIG_ENET, + MX28_PAD_ENET0_TX_CLK__GPIO_4_5, /* n.c. */ + MX28_PAD_ENET0_TX_EN__ENET0_TX_EN | MUX_CONFIG_ENET, + MX28_PAD_ENET0_TXD0__ENET0_TXD0 | MUX_CONFIG_ENET, + MX28_PAD_ENET0_TXD1__ENET0_TXD1 | MUX_CONFIG_ENET, + MX28_PAD_ENET0_TXD3__ENET1_TXD1 | MUX_CONFIG_ENET, + MX28_PAD_SSP1_CMD__GPIO_2_13, /* PHY reset */ + + /* TIVA boot control */ + MX28_PAD_GPMI_RDY3__GPIO_0_23 | MUX_CONFIG_BOOT, /* TIVA0 */ + MX28_PAD_GPMI_WRN__GPIO_0_25 | MUX_CONFIG_BOOT, /* TIVA1 */ +}; + +u32 mxs_dram_vals[] = { + 0x00000000, 0x00000000, 0x00000000, 0x00000000, + 0x00000000, 0x00000000, 0x00000000, 0x00000000, + 0x00000000, 0x00000000, 0x00000000, 0x00000000, + 0x00000000, 0x00000000, 0x00000000, 0x00000000, + 0x00000000, 0x00000100, 0x00000000, 0x00000000, + 0x00000000, 0x00000000, 0x00000000, 0x00000000, + 0x00000000, 0x00000000, 0x00010101, 0x01010101, + 0x000f0f01, 0x0f02010a, 0x00000000, 0x00010101, + 0x00000100, 0x00000100, 0x00000000, 0x00000002, + 0x01010000, 0x07080403, 0x07005303, 0x0b0000c8, + 0x0200a0c1, 0x0002040c, 0x0038430a, 0x04290322, + 0x02040203, 0x00c8002b, 0x00000000, 0x00000000, + 0x00012100, 0xffff0303, 0x00012100, 0xffff0303, + 0x00012100, 0xffff0303, 0x00012100, 0xffff0303, + 0x00000003, 0x00000000, 0x00000000, 0x00000000, + 0x00000000, 0x00000000, 0x00000000, 0x00000000, + 0x00000000, 0x00000000, 0x00000612, 0x01000102, + 0x06120612, 0x00000200, 0x00020007, 0xf4004a27, + 0xf4004a27, 0xf4004a27, 0xf4004a27, 0x07400300, + 0x07400300, 0x07400300, 0x07400300, 0x00000005, + 0x00000000, 0x00000000, 0x01000000, 0x00000000, + 0x00000001, 0x000f1133, 0x00000000, 0x00001f04, + 0x00001f04, 0x00001f04, 0x00001f04, 0x00001f04, + 0x00001f04, 0x00001f04, 0x00001f04, 0x00000000, + 0x00000000, 0x00000000, 0x00000000, 0x00000000, + 0x00000000, 0x00000000, 0x00000000, 0x00000000, + 0x00000000, 0x00000000, 0x00000000, 0x00000000, + 0x00000000, 0x00000000, 0x00000000, 0x00000000, + 0x00000000, 0x00000000, 0x00000000, 0x00000000, + 0x00000000, 0x00000000, 0x00000000, 0x00000000, + 0x00000000, 0x00000000, 0x00000000, 0x00000000, + 0x00000000, 0x00000000, 0x00000000, 0x00000000, + 0x00000000, 0x00000000, 0x00000000, 0x00000000, + 0x00000000, 0x00000000, 0x00000000, 0x00000000, + 0x00000000, 0x00000000, 0x00000000, 0x00000000, + 0x00000000, 0x00000000, 0x00000000, 0x00000000, + 0x00000000, 0x00000000, 0x00000000, 0x00000000, + 0x00000000, 0x00000000, 0x00000000, 0x00000000, + 0x00000000, 0x00000000, 0x00000000, 0x00000000, + 0x00000000, 0x00000000, 0x00000000, 0x00000000, + 0x00000000, 0x00000000, 0x00010000, 0x00030404, + 0x00000002, 0x00000000, 0x00000000, 0x00000000, + 0x00000000, 0x00000000, 0x00000000, 0x01010000, + 0x01000000, 0x03030000, 0x00010303, 0x01020202, + 0x00000000, 0x02040101, 0x21002103, 0x00061200, + 0x06120612, 0x00000642, 0x00000000, 0x00000004, + 0x00000000, 0x00000080, 0x00000000, 0x00000000, + 0x00000000, 0xffffffff +}; + +void lowlevel_init(void) +{ + struct mxs_pinctrl_regs *pinctrl_regs = + (struct mxs_pinctrl_regs *)MXS_PINCTRL_BASE; + + /* Set EMI drive strength */ + writel(0x00003fff, &pinctrl_regs->hw_pinctrl_emi_ds_ctrl_clr); + writel(0x00002aaa, &pinctrl_regs->hw_pinctrl_emi_ds_ctrl_set); + + mxs_common_spl_init(0, NULL, iomux_setup, ARRAY_SIZE(iomux_setup)); +} diff --git a/board/liebherr/xea/xea.c b/board/liebherr/xea/xea.c new file mode 100644 index 0000000000..7291313e95 --- /dev/null +++ b/board/liebherr/xea/xea.c @@ -0,0 +1,152 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * XEA iMX28 board + * + * Copyright (C) 2019 DENX Software Engineering + * Lukasz Majewski, DENX Software Engineering, lukma@denx.de + * + * Copyright (C) 2018 DENX Software Engineering + * Måns Rullgård, DENX Software Engineering, mans@mansr.com + * + * Copyright (C) 2011 Marek Vasut marek.vasut@gmail.com + * on behalf of DENX Software Engineering GmbH + * + */ + +#include <common.h> +#include <asm/gpio.h> +#include <asm/io.h> +#include <asm/arch/imx-regs.h> +#include <asm/arch/iomux-mx28.h> +#include <asm/arch/clock.h> +#include <asm/arch/sys_proto.h> +#include <linux/mii.h> +#include <miiphy.h> +#include <netdev.h> +#include <errno.h> +#include <usb.h> + +#ifdef CONFIG_SPL_BUILD +#include <spl.h> +#endif + +DECLARE_GLOBAL_DATA_PTR; + +/* + * Functions + */ + +static void init_clocks(void) +{ + /* IO0 clock at 480MHz */ + mxs_set_ioclk(MXC_IOCLK0, 480000); + /* IO1 clock at 480MHz */ + mxs_set_ioclk(MXC_IOCLK1, 480000); + + /* SSP0 clock at 96MHz */ + mxs_set_sspclk(MXC_SSPCLK0, 96000, 0); + /* SSP2 clock at 160MHz */ + mxs_set_sspclk(MXC_SSPCLK2, 160000, 0); + /* SSP3 clock at 96MHz */ + mxs_set_sspclk(MXC_SSPCLK3, 96000, 0); +} + +#ifdef CONFIG_SPL_BUILD +void board_init_f(ulong arg) +{ + init_clocks(); + preloader_console_init(); +} + +static int boot_tiva0, boot_tiva1; + +/* Check if TIVAs request booting via U-Boot proper */ +void spl_board_init(void) +{ + struct gpio_desc btiva0, btiva1; + int ret; + + ret = dm_gpio_lookup_name("GPIO0_23", &btiva0); + if (ret) + printf("Cannot get GPIO0_23\n"); + + ret = dm_gpio_lookup_name("GPIO0_25", &btiva1); + if (ret) + printf("Cannot get GPIO0_25\n"); + + ret = dm_gpio_request(&btiva0, "boot-tiva0"); + if (ret) + printf("Cannot request GPIO0_23\n"); + + ret = dm_gpio_request(&btiva1, "boot-tiva1"); + if (ret) + printf("Cannot request GPIO0_25\n"); + + dm_gpio_set_dir_flags(&btiva0, GPIOD_IS_IN); + dm_gpio_set_dir_flags(&btiva1, GPIOD_IS_IN); + + udelay(1000); + + boot_tiva0 = dm_gpio_get_value(&btiva0); + boot_tiva1 = dm_gpio_get_value(&btiva1); +} + +void board_boot_order(u32 *spl_boot_list) +{ + spl_boot_list[0] = BOOT_DEVICE_MMC1; + spl_boot_list[1] = BOOT_DEVICE_SPI; +} + +int spl_start_uboot(void) +{ + /* break into full u-boot on 'c' */ + if (serial_tstc() && serial_getc() == 'c') + return 1; + + debug("%s: btiva0: %d btiva1: %d\n", __func__, boot_tiva0, boot_tiva1); + return !boot_tiva0 || !boot_tiva1; +} +#else + +int board_early_init_f(void) +{ + init_clocks(); + + return 0; +} + +int board_init(void) +{ + struct gpio_desc phy_rst; + int ret; + + /* Address of boot parameters */ + gd->bd->bi_boot_params = PHYS_SDRAM_1 + 0x100; + + cpu_eth_init(NULL); + + /* PHY INT#/PWDN# */ + ret = dm_gpio_lookup_name("GPIO4_13", &phy_rst); + if (ret) { + printf("Cannot get GPIO4_13\n"); + return ret; + } + + ret = dm_gpio_request(&phy_rst, "phy-rst"); + if (ret) { + printf("Cannot request GPIO4_13\n"); + return ret; + } + + dm_gpio_set_dir_flags(&phy_rst, GPIOD_IS_IN); + udelay(1000); + + return 0; +} + +int dram_init(void) +{ + return mxs_dram_init(); +} + +#endif /* CONFIG_SPL_BUILD */ diff --git a/configs/imx28_xea_defconfig b/configs/imx28_xea_defconfig new file mode 100644 index 0000000000..d216d8a320 --- /dev/null +++ b/configs/imx28_xea_defconfig @@ -0,0 +1,109 @@ +CONFIG_ARM=y +CONFIG_SPL_SYS_THUMB_BUILD=y +CONFIG_ARCH_MX28=y +CONFIG_SYS_TEXT_BASE=0x40002000 +CONFIG_SPL_GPIO_SUPPORT=y +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_SYS_MALLOC_F_LEN=0x800 +CONFIG_TARGET_XEA=y +CONFIG_SPL_MMC_SUPPORT=y +CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_SPL_SYS_MALLOC_F_LEN=0x1000 +CONFIG_NR_DRAM_BANKS=1 +CONFIG_SPL=y +CONFIG_SPL_SPI_FLASH_SUPPORT=y +CONFIG_SPL_SPI_SUPPORT=y +CONFIG_TPL_SYS_MALLOC_F_LEN=0x400 +CONFIG_FIT=y +CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_SPL_TEXT_BASE=0x1000 +CONFIG_SPL_BOARD_INIT=y +# CONFIG_SPL_RAW_IMAGE_SUPPORT is not set +CONFIG_SPL_SYS_MALLOC_SIMPLE=y +CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y +CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0 +CONFIG_SPL_DMA_SUPPORT=y +CONFIG_SPL_DM_GPIO=y +CONFIG_SPL_MMC_TINY=y +CONFIG_SPL_DM_SPI=y +CONFIG_SPL_DM_SPI_FLASH=y +CONFIG_SPL_OS_BOOT=y +CONFIG_SPL_PAYLOAD="u-boot.img" +CONFIG_SPL_SPI_LOAD=y +CONFIG_HUSH_PARSER=y +CONFIG_CMD_SPL=y +CONFIG_CMD_ASKENV=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_DM=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_MMC=y +CONFIG_CMD_MTD=y +# CONFIG_CMD_PINMUX is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y +CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_REGULATOR=y +CONFIG_CMD_FS_GENERIC=y +CONFIG_CMD_MTDPARTS=y +CONFIG_MTDIDS_DEFAULT="nor0=spi3.0" +CONFIG_MTDPARTS_DEFAULT="spi3.0:64k(SPL),448k(uboot),128k(envs),384k(unused1),4096k(kernel),8192k(swupdate),-(unused2)" +CONFIG_DOS_PARTITION=y +CONFIG_OF_CONTROL=y +CONFIG_SPL_OF_CONTROL=y +CONFIG_DEFAULT_DEVICE_TREE="imx28-xea" +CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent interrupts" +CONFIG_SPL_OF_PLATDATA=y +CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_USE_ENV_SPI_BUS=y +CONFIG_ENV_SPI_BUS=3 +CONFIG_USE_ENV_SPI_CS=y +CONFIG_ENV_SPI_CS=0 +CONFIG_USE_ENV_SPI_MAX_HZ=y +CONFIG_ENV_SPI_MAX_HZ=40000000 +CONFIG_USE_ENV_SPI_MODE=y +CONFIG_ENV_SPI_MODE=0x0 +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_DM=y +CONFIG_SPL_DM=y +CONFIG_DEVRES=y +CONFIG_DM_GPIO=y +CONFIG_MXS_GPIO=y +CONFIG_DM_MMC=y +CONFIG_SUPPORT_EMMC_BOOT=y +CONFIG_MMC_MXS=y +CONFIG_MTD=y +CONFIG_MTD_DEVICE=y +CONFIG_DM_SPI_FLASH=y +CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_BUS=3 +CONFIG_SF_DEFAULT_MODE=0x0 +CONFIG_SF_DEFAULT_SPEED=40000000 +CONFIG_SPI_FLASH_SFDP_SUPPORT=y +CONFIG_SPI_FLASH_ISSI=y +CONFIG_SPI_FLASH_SPANSION=y +CONFIG_SPI_FLASH_STMICRO=y +# CONFIG_SPI_FLASH_USE_4K_SECTORS is not set +CONFIG_SPI_FLASH_MTD=y +CONFIG_PHYLIB=y +CONFIG_PHY_ADDR_ENABLE=y +CONFIG_PHY_ADDR=1 +CONFIG_PHY_FIXED=y +CONFIG_DM_ETH=y +CONFIG_FEC_MXC=y +CONFIG_MII=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_MXS=y +CONFIG_DM_REGULATOR=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_REGULATOR_GPIO=y +CONFIG_CONS_INDEX=0 +CONFIG_SPI=y +CONFIG_DM_SPI=y +CONFIG_MXS_SPI=y +CONFIG_FS_FAT=y +# CONFIG_SPL_OF_LIBFDT is not set +# CONFIG_EFI_LOADER is not set diff --git a/include/configs/xea.h b/include/configs/xea.h new file mode 100644 index 0000000000..f60d2694bf --- /dev/null +++ b/include/configs/xea.h @@ -0,0 +1,196 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2019 DENX Software Engineering + * Lukasz Majewski, DENX Software Engineering, lukma@denx.de + * + * Copyright (C) 2018 DENX Software Engineering + * Måns Rullgård, DENX Software Engineering, mans@mansr.com + * + * Copyright (C) 2011 Marek Vasut marek.vasut@gmail.com + * on behalf of DENX Software Engineering GmbH + */ +#ifndef __CONFIGS_XEA_H__ +#define __CONFIGS_XEA_H__ + +#include <linux/sizes.h> + +#define CONFIG_TIMESTAMP /* Print image info with timestamp */ + +/* SPL */ +#define CONFIG_SPL_STACK 0x20000 + +#define CONFIG_SYS_SPL_ARGS_ADDR 0x44000000 + +#define CONFIG_SYS_SPI_U_BOOT_OFFS SZ_64K +#define CONFIG_SYS_SPI_KERNEL_OFFS SZ_1M +#define CONFIG_SYS_SPI_ARGS_OFFS SZ_512K +#define CONFIG_SYS_SPI_ARGS_SIZE SZ_32K + +#define CONFIG_SYS_MMCSD_RAW_MODE_ARGS_SECTOR (SZ_512K / 0x200) +#define CONFIG_SYS_MMCSD_RAW_MODE_ARGS_SECTORS (SZ_32K / 0x200) +#define CONFIG_SYS_MMCSD_RAW_MODE_KERNEL_SECTOR (SZ_1M / 0x200) + +/* U-Boot Commands */ +#define CONFIG_FS_EXT4 + +/* Memory configuration */ +#define PHYS_SDRAM_1 0x40000000 /* Base address */ +#define PHYS_SDRAM_1_SIZE 0x10000000 /* Max 256 MB RAM */ +#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1 + +/* Environment */ +#define CONFIG_ENV_OVERWRITE + +/* Booting Linux */ +#define CONFIG_BOOTFILE "uImage" +#define CONFIG_BOOTARGS "console=ttyAMA0,115200n8 " +#define CONFIG_BOOTCOMMAND "run ${bootpri} ; run ${bootsec}" +#define CONFIG_LOADADDR 0x42000000 +#define CONFIG_SYS_LOAD_ADDR CONFIG_LOADADDR + +/* Extra Environment */ +#define CONFIG_PREBOOT "run prebootcmd" +#define CONFIG_HOSTNAME "xea" + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "bootmode=update\0" \ + "bootpri=mmc_mmc\0" \ + "bootsec=sf_swu\0" \ + "consdev=ttyAMA0\0" \ + "baudrate=115200\0" \ + "dtbaddr=0x44000000\0" \ + "dtbfile=imx28-xea.dtb\0" \ + "rootdev=/dev/mmcblk0p2\0" \ + "netdev=eth0\0" \ + "rdaddr=0x43000000\0" \ + "swufile=swupdate.img\0" \ + "sf_kernel_offset=0x100000\0" \ + "sf_kernel_size=0x400000\0" \ + "sf_swu_offset=0x500000\0" \ + "sf_swu_size=0x800000\0" \ + "rootpath=/opt/eldk-5.5/armv5te/rootfs-qte-sdk\0" \ + "do_update_mmc=" \ + "if mmc rescan ; then " \ + "mmc dev 0 ${update_mmc_part} ; " \ + "if dhcp ${hostname}/${update_filename} ; then " \ + "setexpr fw_sz ${filesize} / 0x200 ; " /* SD block size */ \ + "setexpr fw_sz ${fw_sz} + 1 ; " \ + "mmc write ${loadaddr} ${update_offset} ${fw_sz} ; " \ + "fi ; " \ + "fi\0" \ + "do_update_sf=" \ + "if sf probe ; then " \ + "if dhcp ${hostname}/${update_filename} ; then " \ + "sf erase ${update_offset} +${filesize} ; " \ + "sf write ${loadaddr} ${update_offset} ${filesize} ; " \ + "fi ; " \ + "fi\0" \ + "update_spl_filename=u-boot.sb\0" \ + "update_spl=" \ + "setenv update_filename ${update_spl_filename} ; " \ + "setenv update_offset 0 ; " \ + "run do_update_sf\0" \ + "update_uboot_filename=u-boot.img\0" \ + "update_uboot=" \ + "setenv update_filename ${update_uboot_filename} ; " \ + "setenv update_offset 0x10000 ; " \ + "run do_update_sf ; " \ + "setenv update_mmc_part 1 ; " \ + "setenv update_offset 0 ; " \ + "run do_update_mmc\0" \ + "update_kernel_filename=uImage\0" \ + "update_kernel=" \ + "setenv update_mmc_part 1 ; " \ + "setenv update_filename ${update_kernel_filename} ; " \ + "setenv update_offset 0x800 ; " \ + "run do_update_mmc ; " \ + "setenv update_filename ${dtbfile} ; " \ + "setenv update_offset 0x400 ; " \ + "run do_update_mmc\0" \ + "update_sfkernel=" \ + "setenv update_filename fitImage ; " \ + "setenv update_offset ${sf_kernel_offset} ; " \ + "run do_update_sf\0" \ + "update_swu=" \ + "setenv update_filename ${swufile} ; " \ + "setenv update_offset ${sf_swu_offset} ; " \ + "run do_update_sf\0" \ + "addcons=" \ + "setenv bootargs ${bootargs} " \ + "console=${consdev},${baudrate}\0" \ + "addip=" \ + "setenv bootargs ${bootargs} " \ + "ip=${ipaddr}:${serverip}:${gatewayip}:" \ + "${netmask}:${hostname}:${netdev}:off\0" \ + "addmisc=" \ + "setenv bootargs ${bootargs} ${miscargs}\0" \ + "addargs=run addcons addmisc\0" \ + "mmcload=" \ + "mmc rescan ; " \ + "mmc dev 0 1 ; " \ + "mmc read ${loadaddr} 0x800 0x2000 ; " \ + "mmc read ${dtbaddr} 0x400 0x80\0" \ + "netload=" \ + "dhcp ${loadaddr} ${hostname}/${bootfile} ; " \ + "tftp ${dtbaddr} ${hostname}/${dtbfile}\0" \ + "sfload=" \ + "sf probe ; " \ + "sf read ${loadaddr} ${sf_kernel_offset} ${sf_kernel_size}\0" \ + "usbload=" \ + "usb start ; " \ + "load usb 0:1 ${loadaddr} ${bootfile}\0" \ + "miscargs=panic=1\0" \ + "mmcargs=setenv bootargs root=${rootdev} rw rootwait\0" \ + "nfsargs=" \ + "setenv bootargs root=/dev/nfs rw " \ + "nfsroot=${serverip}:${rootpath},v3,tcp\0" \ + "mmc_mmc=" \ + "if run mmcload mmcargs addargs ; then " \ + "bootm ${loadaddr} - ${dtbaddr} ; " \ + "fi\0" \ + "mmc_nfs=" \ + "if run mmcload nfsargs addip addargs ; then " \ + "bootm ${loadaddr} - ${dtbaddr} ; " \ + "fi\0" \ + "sf_mmc=" \ + "if run sfload mmcargs addargs ; then " \ + "bootm ${loadaddr} - ${dtbaddr} ; " \ + "fi\0" \ + "sf_swu=" \ + "if run sfload ; then " \ + "sf read ${rdaddr} ${sf_swu_offset} ${sf_swu_size} ; " \ + "setenv bootargs root=/dev/ram0 rw ; " \ + "run addargs ; " \ + "bootm ${loadaddr} ${rdaddr} ; " \ + "fi\0" \ + "net_mmc=" \ + "if run netload mmcargs addargs ; then " \ + "bootm ${loadaddr} - ${dtbaddr} ; " \ + "fi\0" \ + "net_nfs=" \ + "if run netload nfsargs addip addargs ; then " \ + "bootm ${loadaddr} - ${dtbaddr} ; " \ + "fi\0" \ + "prebootcmd=" \ + "if test "${envsaved}" != y ; then ; " \ + "setenv envsaved y ; " \ + "saveenv ; " \ + "fi ; " \ + "if test "${bootmode}" = normal ; then " \ + "setenv bootdelay 0 ; " \ + "setenv bootpri mmc_mmc ; " \ + "elif test "${bootmode}" = devel ; then " \ + "setenv bootdelay 3 ; " \ + "setenv bootpri net_mmc ; " \ + "else " \ + "if test "${bootmode}" != update ; then " \ + "echo Warning: unknown bootmode "${bootmode}" ; " \ + "fi ; " \ + "setenv bootdelay 1 ; " \ + "setenv bootpri sf_swu ; " \ + "fi\0" + +/* The rest of the configuration is shared */ +#include <configs/mxs.h> + +#endif /* __CONFIGS_XEA_H__ */
Andreas Dannenberg
Lukasz Majewski
