[PATCH] efi_loader: Add a locality event on the eventlog
We are currently not adding any events on the eventlog apart from the SpecID event. The locality event is mandatory and must be logged before extending PCR[0].
The spec description is "The Startup Locality event should be placed in the log before any event which extends PCR[0]. This allows software which needs to parse the TCG Event Log to initialize its internal PCR[0] state correctly".
So let's add a locality even during the EventLog creation, right after our SpecID event.
Signed-off-by: Ilias Apalodimas ilias.apalodimas@linaro.org --- lib/efi_loader/efi_tcg2.c | 50 +++++++++++++++++++++++++++++---------- 1 file changed, 37 insertions(+), 13 deletions(-)
diff --git a/lib/efi_loader/efi_tcg2.c b/lib/efi_loader/efi_tcg2.c index 797d6eb134f6..a89dadcb22e9 100644 --- a/lib/efi_loader/efi_tcg2.c +++ b/lib/efi_loader/efi_tcg2.c @@ -513,7 +513,7 @@ static efi_status_t tcg2_create_digest(const u8 *input, u32 length, sha1_context ctx; sha256_context ctx_256; sha512_context ctx_512; - u8 final[TPM2_ALG_SHA512]; + u8 final[TPM2_ALG_SHA512] = { 0 }; efi_status_t ret; u32 active; int i; @@ -530,27 +530,35 @@ static efi_status_t tcg2_create_digest(const u8 *input, u32 length, continue; switch (hash_alg) { case TPM2_ALG_SHA1: - sha1_starts(&ctx); - sha1_update(&ctx, input, length); - sha1_finish(&ctx, final); + if (input) { + sha1_starts(&ctx); + sha1_update(&ctx, input, length); + sha1_finish(&ctx, final); + } digest_list->count++; break; case TPM2_ALG_SHA256: - sha256_starts(&ctx_256); - sha256_update(&ctx_256, input, length); - sha256_finish(&ctx_256, final); + if (input) { + sha256_starts(&ctx_256); + sha256_update(&ctx_256, input, length); + sha256_finish(&ctx_256, final); + } digest_list->count++; break; case TPM2_ALG_SHA384: - sha384_starts(&ctx_512); - sha384_update(&ctx_512, input, length); - sha384_finish(&ctx_512, final); + if (input) { + sha384_starts(&ctx_512); + sha384_update(&ctx_512, input, length); + sha384_finish(&ctx_512, final); + } digest_list->count++; break; case TPM2_ALG_SHA512: - sha512_starts(&ctx_512); - sha512_update(&ctx_512, input, length); - sha512_finish(&ctx_512, final); + if (input) { + sha512_starts(&ctx_512); + sha512_update(&ctx_512, input, length); + sha512_finish(&ctx_512, final); + } digest_list->count++; break; default: @@ -1004,6 +1012,8 @@ static efi_status_t efi_init_event_log(void) struct udevice *dev; size_t spec_event_size; efi_status_t ret; + struct tcg_efi_startup_locality_event locality_event; + struct tpml_digest_values digest_list;
ret = platform_get_tpm2_device(&dev); if (ret != EFI_SUCCESS) @@ -1040,6 +1050,20 @@ static efi_status_t efi_init_event_log(void) event_log.pos = spec_event_size + sizeof(*event_header); event_log.last_event_size = event_log.pos;
+ /* Add a locality event before PCR[0] changes */ + memcpy(locality_event.signature, TCG_EFI_STARTUP_LOCALITY_SIGNATURE, + sizeof(locality_event.signature)); + /* + * Locality 0 is designated as the default Locality. This is usually + * the platform’s boot firmware, OS and applications. + */ + locality_event.startup_locality = 0; + ret = tcg2_create_digest(NULL, 0, &digest_list); + ret = tcg2_agile_log_append(0, EV_NO_ACTION, &digest_list, + sizeof(locality_event), (u8 *)&locality_event); + if (ret != EFI_SUCCESS) + goto out; + ret = create_final_event();
out:
Ilias Apalodimas
