[PATCH 1/2] net: rtl8169: add minimal support for 8125B variant
Add minimal support for 8125B version. Changes are based on the Linux driver. Tested on Radxa Rock 5B Rk3588 board.
Connection to a laptop worked fine in 100 Mbps mode. 1000 Mbps mode is not working at the moment.
Signed-off-by: Eugen Hristev eugen.hristev@collabora.com --- drivers/net/rtl8169.c | 52 ++++++++++++++++++++++++++++++------------- 1 file changed, 37 insertions(+), 15 deletions(-)
diff --git a/drivers/net/rtl8169.c b/drivers/net/rtl8169.c index c9c07a5a8ffe..2276a465e787 100644 --- a/drivers/net/rtl8169.c +++ b/drivers/net/rtl8169.c @@ -118,9 +118,9 @@ enum RTL8169_registers { FLASH = 0x30, ERSR = 0x36, ChipCmd = 0x37, - TxPoll = 0x38, - IntrMask = 0x3C, - IntrStatus = 0x3E, + TxPoll_8169 = 0x38, + IntrMask_8169 = 0x3C, + IntrStatus_8169 = 0x3E, TxConfig = 0x40, RxConfig = 0x44, RxMissed = 0x4C, @@ -148,6 +148,12 @@ enum RTL8169_registers { FuncForceEvent = 0xFC, };
+enum RTL8125_registers { + IntrMask_8125 = 0x38, + IntrStatus_8125 = 0x3C, + TxPoll_8125 = 0x90, +}; + enum RTL8169_register_content { /*InterruptStatusBits */ SYSErr = 0x8000, @@ -263,6 +269,7 @@ static struct { {"RTL-8101e", 0x34, 0xff7e1880,}, {"RTL-8100e", 0x32, 0xff7e1880,}, {"RTL-8168h/8111h", 0x54, 0xff7e1880,}, + {"RTL-8125B", 0x64, 0xff7e1880,}, };
enum _DescStatusBit { @@ -347,6 +354,7 @@ static struct pci_device_id supported[] = { { PCI_DEVICE(PCI_VENDOR_ID_REALTEK, 0x8167) }, { PCI_DEVICE(PCI_VENDOR_ID_REALTEK, 0x8168) }, { PCI_DEVICE(PCI_VENDOR_ID_REALTEK, 0x8169) }, + { PCI_DEVICE(PCI_VENDOR_ID_REALTEK, 0x8125) }, {} };
@@ -517,6 +525,7 @@ static int rtl_recv_common(struct udevice *dev, unsigned long dev_iobase, /* return true if there's an ethernet packet ready to read */ /* nic->packet should contain data on return */ /* nic->packetlen should contain length of data */ + struct pci_child_plat *pplat = dev_get_parent_plat(dev); int cur_rx; int length = 0;
@@ -558,6 +567,10 @@ static int rtl_recv_common(struct udevice *dev, unsigned long dev_iobase, return length;
} else { + u32 IntrStatus = IntrStatus_8169; + + if (pplat->device == 0x8125) + IntrStatus = IntrStatus_8125; ushort sts = RTL_R8(IntrStatus); RTL_W8(IntrStatus, sts & ~(TxErr | RxErr | SYSErr)); udelay(100); /* wait */ @@ -582,6 +595,7 @@ static int rtl_send_common(struct udevice *dev, unsigned long dev_iobase, { /* send the packet to destination */
+ struct pci_child_plat *pplat = dev_get_parent_plat(dev); u32 to; u8 *ptxb; int entry = tpc->cur_tx % NUM_TX_DESC; @@ -618,7 +632,10 @@ static int rtl_send_common(struct udevice *dev, unsigned long dev_iobase, ((len > ETH_ZLEN) ? len : ETH_ZLEN)); } rtl_flush_tx_desc(&tpc->TxDescArray[entry]); - RTL_W8(TxPoll, 0x40); /* set polling bit */ + if (pplat->device == 0x8125) + RTL_W8(TxPoll_8125, 0x1); /* set polling bit */ + else + RTL_W8(TxPoll_8169, 0x40); /* set polling bit */
tpc->cur_tx++; to = currticks() + TX_TIMEOUT; @@ -824,21 +841,26 @@ static int rtl8169_eth_start(struct udevice *dev) return 0; }
-static void rtl_halt_common(unsigned long dev_iobase) +static void rtl_halt_common(struct udevice *dev) { + struct rtl8169_private *priv = dev_get_priv(dev); + struct pci_child_plat *pplat = dev_get_parent_plat(dev); int i;
#ifdef DEBUG_RTL8169 printf ("%s\n", __FUNCTION__); #endif
- ioaddr = dev_iobase; + ioaddr = priv->iobase;
/* Stop the chip's Tx and Rx DMA processes. */ RTL_W8(ChipCmd, 0x00);
/* Disable interrupts by clearing the interrupt mask. */ - RTL_W16(IntrMask, 0x0000); + if (pplat->device == 0x8125) + RTL_W16(IntrMask_8125, 0x0000); + else + RTL_W16(IntrMask_8169, 0x0000);
RTL_W32(RxMissed, 0);
@@ -849,9 +871,7 @@ static void rtl_halt_common(unsigned long dev_iobase)
void rtl8169_eth_stop(struct udevice *dev) { - struct rtl8169_private *priv = dev_get_priv(dev); - - rtl_halt_common(priv->iobase); + rtl_halt_common(dev); }
static int rtl8169_write_hwaddr(struct udevice *dev) @@ -1025,23 +1045,25 @@ static int rtl8169_eth_probe(struct udevice *dev) struct pci_child_plat *pplat = dev_get_parent_plat(dev); struct rtl8169_private *priv = dev_get_priv(dev); struct eth_pdata *plat = dev_get_plat(dev); - u32 iobase; int region; int ret;
- debug("rtl8169: REALTEK RTL8169 @0x%x\n", iobase); switch (pplat->device) { case 0x8168: + case 0x8125: region = 2; break; default: region = 1; break; } - dm_pci_read_config32(dev, PCI_BASE_ADDRESS_0 + region * 4, &iobase); - iobase &= ~0xf; - priv->iobase = (int)dm_pci_mem_to_phys(dev, iobase);
+ priv->iobase = (ulong)dm_pci_map_bar(dev, + PCI_BASE_ADDRESS_0 + region * 4, + 0, 0, + PCI_REGION_TYPE, PCI_REGION_MEM); + + debug("rtl8169: REALTEK RTL8169 @0x%lx\n", priv->iobase); ret = rtl_init(priv->iobase, dev->name, plat->enetaddr); if (ret < 0) { printf(pr_fmt("failed to initialize card: %d\n"), ret);
Add the rtl8169 driver, which supports the rtl8125b device, which is connected on the pciE bus on this board. Enable also CONFIG_SYS_HAS_NONCACHED_MEMORY to have the descriptors stored.
Signed-off-by: Eugen Hristev eugen.hristev@collabora.com --- configs/rock5b-rk3588_defconfig | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/configs/rock5b-rk3588_defconfig b/configs/rock5b-rk3588_defconfig index a14fcd2ee924..bfa48227aee2 100644 --- a/configs/rock5b-rk3588_defconfig +++ b/configs/rock5b-rk3588_defconfig @@ -1,5 +1,6 @@ CONFIG_ARM=y CONFIG_SKIP_LOWLEVEL_INIT=y +CONFIG_SYS_HAS_NONCACHED_MEMORY=y CONFIG_COUNTER_FREQUENCY=24000000 CONFIG_ARCH_ROCKCHIP=y CONFIG_TEXT_BASE=0x00a00000 @@ -71,6 +72,7 @@ CONFIG_MMC_SDHCI_SDMA=y CONFIG_MMC_SDHCI_ROCKCHIP=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_ETH_DESIGNWARE=y +CONFIG_RTL8169=y CONFIG_GMAC_ROCKCHIP=y CONFIG_PCI=y CONFIG_PCIE_DW_ROCKCHIP=y
Does this depend on some series I missed where PCI is enabled on this config?
Hi Tom,
the network device is connected on PCI express, that is right. I have a separate series for that. However, the network driver itself and the enabling of the network driver is somewhat independent, so I sent it as a separate series (this one ) I think the config patch can go through rockchip custodian tree.
Thanks, Eugen
Hi Tom,
With 1/2 now applied this results in failure to build due to DM_PCI not being enabled.
Hi Tom,
This is most strange. 1/2 are just changes in the driver. How does that cause a build failure ? The driver is not even selected for this config in 2/2, before the actual patch. Do you have the log of the failure so I can have a look ?
Hi Tom,
I don't have the log handy right now, please re-test the config changes on top of master and repost.
Hi Tom,
Hi Tom,
I figured out the issue. My patch is indeed based on another patch that selects CONFIG_PCI.
However, the rtl8169 driver depends on PCI, even if it does not have 'depends on PCI' in the Kconfig. So selecting it without PCI, well, the error.
So I sent another patch :
https://patchwork.ozlabs.org/project/uboot/patch/20230517104124.111075-1-eug...
... that should have the rtl8169 depend on PCI now.
That being said, this current patch can be applied on kever's rockchip master branch on top of PCI series, but if it's to be applied on master, it should work on top of the 'rtl8169 depends on PCI' patch now.
I hope it makes sense. Thanks
On Tue, Apr 25, 2023 at 04:06:59PM +0300, Eugen Hristev wrote: > Add the rtl8169 driver, which supports the rtl8125b device, which is > connected on the pciE bus on this board. > Enable also CONFIG_SYS_HAS_NONCACHED_MEMORY to have the > descriptors stored. > > Signed-off-by: Eugen Hristev eugen.hristev@collabora.com > --- > configs/rock5b-rk3588_defconfig | 2 ++ > 1 file changed, 2 insertions(+) > > diff --git a/configs/rock5b-rk3588_defconfig > b/configs/rock5b-rk3588_defconfig > index a14fcd2ee924..bfa48227aee2 100644 > --- a/configs/rock5b-rk3588_defconfig > +++ b/configs/rock5b-rk3588_defconfig > @@ -1,5 +1,6 @@ > CONFIG_ARM=y > CONFIG_SKIP_LOWLEVEL_INIT=y > +CONFIG_SYS_HAS_NONCACHED_MEMORY=y > CONFIG_COUNTER_FREQUENCY=24000000 > CONFIG_ARCH_ROCKCHIP=y > CONFIG_TEXT_BASE=0x00a00000 > @@ -71,6 +72,7 @@ CONFIG_MMC_SDHCI_SDMA=y > CONFIG_MMC_SDHCI_ROCKCHIP=y > CONFIG_SPI_FLASH_MACRONIX=y > CONFIG_ETH_DESIGNWARE=y > +CONFIG_RTL8169=y > CONFIG_GMAC_ROCKCHIP=y > CONFIG_PCI=y > CONFIG_PCIE_DW_ROCKCHIP=y
Hi Tom,
Hi Tom,
Hi Kever,
Maybe you somehow missed this patch ? The prerequisites(PCI series, driver, and PCI dependency for the driver are already in tree)
Thanks, Eugen
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
The one thing that impacts all the rtl chips is the way the pci BAR is now mapped. I could not test this on another platform so help on this matter is appreciated.
Thanks! Eugen
- TxPoll = 0x38,
- IntrMask = 0x3C,
- TxPoll_8169 = 0x38,
- IntrMask_8169 = 0x3C,
- IntrStatus_8169 = 0x3E, TxConfig = 0x40, RxConfig = 0x44, RxMissed = 0x4C,
- IntrMask_8125 = 0x38,
- IntrStatus_8125 = 0x3C,
- TxPoll_8125 = 0x90,
- enum RTL8169_register_content { /*InterruptStatusBits */ SYSErr = 0x8000,
- { PCI_DEVICE(PCI_VENDOR_ID_REALTEK, 0x8125) }, {} };
- struct pci_child_plat *pplat = dev_get_parent_plat(dev); int cur_rx; int length = 0;
} else {
ushort sts = RTL_R8(IntrStatus); RTL_W8(IntrStatus, sts & ~(TxErr | RxErr | SYSErr)); udelay(100); /* wait */IntrStatus = IntrStatus_8125;
- struct pci_child_plat *pplat = dev_get_parent_plat(dev); u32 to; u8 *ptxb; int entry = tpc->cur_tx % NUM_TX_DESC;
else
else
- case 0x8125: region = 2; break; default: region = 1; break; }
- iobase &= ~0xf;
- priv->iobase = (ulong)dm_pci_map_bar(dev,
0, 0,
- debug("rtl8169: REALTEK RTL8169 @0x%lx\n", priv->iobase); ret = rtl_init(priv->iobase, dev->name, plat->enetaddr); if (ret < 0) { printf(pr_fmt("failed to initialize card: %d\n"), ret);
On Tue, Apr 25, 2023 at 4:17 PM Eugen Hristev eugen.hristev@collabora.com wrote:
Thanks! Eugen
Let's wait a bit to see if someone can test it. why did you change the mapping of the BAR ?
Thanks! Eugen
It did not work with the old code. It provided a bad address, to some area which did not have the right registers. I looked into similar drivers and they were using this call, which works perfectly for 8125b device
Eugen
On Tue, Apr 25, 2023 at 10:47 PM Eugen Hristev eugen.hristev@collabora.com wrote:
Thanks! Eugen
Eugen
Ok. Hopefully nothing breaks. Reviewed-by: Ramon Fried rfried.dev@gmail.com
Thanks! Eugen
Eugen
Hello Ramon,
I have a question if you don't mind, maybe you are better suited to answer this :
In the case of rtl8169 which is a pci express device, the probing is done on demand (pci enum) or with MISC_INIT_R, anyway, the probing is done *after* the board init is done, and in case of rockchip, the board init will check if there is any 'ethaddr' set, and if not, set the ethaddr by generating an unique cpuid-based MAC. This happens, no ethaddr is set, and the MAC is generated. However, when the rtl8169 probes, it has ofcourse a different hardware written MAC, but the uboot subsystem will deny it, and claim ethaddr is already set, and it will call the 8169 driver to rewrite its MAC. This then happens, and Uboot will use the initial ethaddr (the one generated) for any kind of packets. While this is not a problem at first glance, when Linux boots, it will read the MAC from rtl8169 ROM (even if uboot attempted to rewrite its MAC, being a ROM, it will not be written), and Linux will use a different MAC now. Do you have any idea on how to solve this problem ? I would like that once rtl8169 driver probes, the initial ethaddr would be overwritten.
Thanks !
Signed-off-by: Eugen Hristev eugen.hristev@collabora.com Reviewed-by: Ramon Fried rfried.dev@gmail.com
Eugen Hristev
Kever Yang
Ramon Fried
