[PATCH v2 0/3] riscv: sophgo: milkv_duo: add support for Milk-V Duo board
The Milk-V Duo board is built upon Sophgo's CV1800B SoC, featuring two XuanTie C906 CPUs running at 1.0GHz and 700MHz, respectively.
This series introduces fundamental support for the Milk-V Duo board, encompassing UART, CPU, and PLIC support. This ensures that U-Boot can operate in serial console mode.
Changes in v2: - Fold the defconfig patch to first patch - Remove unnecessary environment settings of consoledev and baudrate in config
Kongyang Liu (3): riscv: sophgo: milkv_duo: initial support added riscv: dts: sophgo: Add basic device tree for Milk-V Duo board doc: sophgo: milkv_duo: document Milk-V Duo board
arch/riscv/Kconfig | 4 + arch/riscv/dts/Makefile | 1 + arch/riscv/dts/cv1800b-milkv-duo.dts | 38 +++++++++ arch/riscv/dts/cv1800b.dtsi | 123 +++++++++++++++++++++++++++ board/sophgo/milkv_duo/Kconfig | 28 ++++++ board/sophgo/milkv_duo/MAINTAINERS | 6 ++ board/sophgo/milkv_duo/Makefile | 5 ++ board/sophgo/milkv_duo/board.c | 9 ++ configs/milkv_duo_defconfig | 24 ++++++ doc/board/index.rst | 1 + doc/board/sophgo/index.rst | 8 ++ doc/board/sophgo/milkv_duo.rst | 50 +++++++++++ include/configs/milkv_duo.h | 12 +++ 13 files changed, 309 insertions(+) create mode 100644 arch/riscv/dts/cv1800b-milkv-duo.dts create mode 100644 arch/riscv/dts/cv1800b.dtsi create mode 100644 board/sophgo/milkv_duo/Kconfig create mode 100644 board/sophgo/milkv_duo/MAINTAINERS create mode 100644 board/sophgo/milkv_duo/Makefile create mode 100644 board/sophgo/milkv_duo/board.c create mode 100644 configs/milkv_duo_defconfig create mode 100644 doc/board/sophgo/index.rst create mode 100644 doc/board/sophgo/milkv_duo.rst create mode 100644 include/configs/milkv_duo.h
Add support for Sophgo's Milk-V Duo board, only minimal device tree and serial console are enabled, and it can boot via vendor first stage bootloader.
Signed-off-by: Kongyang Liu seashell11234455@gmail.com
arch/riscv/Kconfig | 4 ++++ board/sophgo/milkv_duo/Kconfig | 28 ++++++++++++++++++++++++++++ board/sophgo/milkv_duo/MAINTAINERS | 6 ++++++ board/sophgo/milkv_duo/Makefile | 5 +++++ board/sophgo/milkv_duo/board.c | 9 +++++++++ configs/milkv_duo_defconfig | 24 ++++++++++++++++++++++++ include/configs/milkv_duo.h | 12 ++++++++++++ 7 files changed, 88 insertions(+) create mode 100644 board/sophgo/milkv_duo/Kconfig create mode 100644 board/sophgo/milkv_duo/MAINTAINERS create mode 100644 board/sophgo/milkv_duo/Makefile create mode 100644 board/sophgo/milkv_duo/board.c create mode 100644 configs/milkv_duo_defconfig create mode 100644 include/configs/milkv_duo.h
diff --git a/arch/riscv/Kconfig b/arch/riscv/Kconfig index 6d0d812ddb..de99ce3a28 100644 --- a/arch/riscv/Kconfig +++ b/arch/riscv/Kconfig @@ -14,6 +14,9 @@ config TARGET_ANDES_AE350 config TARGET_MICROCHIP_ICICLE bool "Support Microchip PolarFire-SoC Icicle Board"
+config TARGET_MILKV_DUO + bool "Support Milk-v Duo Board" + config TARGET_OPENPITON_RISCV64 bool "Support RISC-V cores on OpenPiton SoC"
@@ -80,6 +83,7 @@ source "board/openpiton/riscv64/Kconfig" source "board/sifive/unleashed/Kconfig" source "board/sifive/unmatched/Kconfig" source "board/sipeed/maix/Kconfig" +source "board/sophgo/milkv_duo/Kconfig" source "board/starfive/visionfive2/Kconfig" source "board/thead/th1520_lpi4a/Kconfig"
diff --git a/board/sophgo/milkv_duo/Kconfig b/board/sophgo/milkv_duo/Kconfig new file mode 100644 index 0000000000..2a458f291c --- /dev/null +++ b/board/sophgo/milkv_duo/Kconfig @@ -0,0 +1,28 @@ +if TARGET_MILKV_DUO + +config SYS_BOARD + default "milkv_duo" + +config SYS_VENDOR + default "sophgo" + +config SYS_CPU + default "generic" + +config SYS_CONFIG_NAME + default "milkv_duo" + +config TEXT_BASE + default 0x80200000 + +config ENV_SIZE + default 0x20000 + +config ENV_SECT_SIZE + default 0x40000 + +config BOARD_SPECIFIC_OPTIONS + def_bool y + select GENERIC_RISCV + +endif diff --git a/board/sophgo/milkv_duo/MAINTAINERS b/board/sophgo/milkv_duo/MAINTAINERS new file mode 100644 index 0000000000..651a0592f7 --- /dev/null +++ b/board/sophgo/milkv_duo/MAINTAINERS @@ -0,0 +1,6 @@ +Milk-V Duo +M: Kongyang Liu seashell11234455@gmail.com +S: Maintained +F: board/sophgo/milkv_duo/ +F: configs/milkv_duo_defconfig +F: doc/board/sophgo/milkv_duo.rst diff --git a/board/sophgo/milkv_duo/Makefile b/board/sophgo/milkv_duo/Makefile new file mode 100644 index 0000000000..a087013f5c --- /dev/null +++ b/board/sophgo/milkv_duo/Makefile @@ -0,0 +1,5 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# Copyright (c) 2024, Kongyang Liu seashell11234455@gmail.com + +obj-y := board.o diff --git a/board/sophgo/milkv_duo/board.c b/board/sophgo/milkv_duo/board.c new file mode 100644 index 0000000000..eaa47be173 --- /dev/null +++ b/board/sophgo/milkv_duo/board.c @@ -0,0 +1,9 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (c) 2024, Kongyang Liu seashell11234455@gmail.com + */ + +int board_init(void) +{ + return 0; +} diff --git a/configs/milkv_duo_defconfig b/configs/milkv_duo_defconfig new file mode 100644 index 0000000000..c4782639ef --- /dev/null +++ b/configs/milkv_duo_defconfig @@ -0,0 +1,24 @@ +CONFIG_RISCV=y +CONFIG_SYS_MALLOC_LEN=0x820000 +CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_NR_DRAM_BANKS=1 +CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y +CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x82300000 +CONFIG_DEFAULT_DEVICE_TREE="cv1800b-milkv-duo" +CONFIG_IDENT_STRING="milkv_duo" +CONFIG_SYS_LOAD_ADDR=0x80080000 +CONFIG_TARGET_MILKV_DUO=y +CONFIG_ARCH_RV64I=y +CONFIG_RISCV_SMODE=y +CONFIG_FIT=y +CONFIG_SUPPORT_RAW_INITRD=y +CONFIG_HUSH_PARSER=y +CONFIG_SYS_PROMPT="milkv_duo# " +CONFIG_SYS_MAXARGS=64 +CONFIG_SYS_CBSIZE=512 +CONFIG_SYS_PBSIZE=544 +CONFIG_SYS_BOOTM_LEN=0x4000000 +CONFIG_ENV_OVERWRITE=y +CONFIG_SYS_NS16550=y +CONFIG_SYS_NS16550_MEM32=y +# CONFIG_EFI_LOADER is not set diff --git a/include/configs/milkv_duo.h b/include/configs/milkv_duo.h new file mode 100644 index 0000000000..0b4109dc1f --- /dev/null +++ b/include/configs/milkv_duo.h @@ -0,0 +1,12 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (c) 2024, Kongyang Liu seashell11234455@gmail.com + * + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +#define CFG_SYS_SDRAM_BASE 0x80000000 + +#endif /* __CONFIG_H */
The sequence of patches seems to be wrong.
We expect that after each single patch building succeeds. But the device-tree is neither in this patch nor in a preceding patch. Please, swap patch 1 and 2.
make[2]: *** No rule to make target 'arch/riscv/dts/cv1800b-milkv-duo.dtb', needed by 'dtbs'.
Changes in v2:
config
- bool "Support Milk-v Duo Board"
- config TARGET_OPENPITON_RISCV64 bool "Support RISC-V cores on OpenPiton SoC"
error: patch failed: arch/riscv/Kconfig:80
Please, rebase.
+config SYS_BOARD
- default "milkv_duo"
+config SYS_VENDOR
- default "sophgo"
+config SYS_CPU
- default "generic"
+config TEXT_BASE
- default 0x80200000
+config ENV_SIZE
- default 0x20000
- default 0x40000
- def_bool y
- select GENERIC_RISCV
- Copyright (c) 2024, Kongyang Liu seashell11234455@gmail.com
Is there a limitation on the size of the binary or why are you excluding this option?
With the loady command you should be able to load an EFI binary via the UART and then launch it. U-Boot comes with some EFI test applications that you could run like smbiosdump.efi.
Best regards
Heinrich
Heinrich Schuchardt xypron.glpk@gmx.de 于2024年1月15日周一 05:57写道:
I forgot defconfig relies on dts files, I will swap patch 1 and 2.
Changes in v2:
config
Please, rebase.
I will rebase it.
+config SYS_BOARD
default "milkv_duo"
+config SYS_VENDOR
default "sophgo"
+config SYS_CPU
default "generic"
default "milkv_duo"
+config TEXT_BASE
default 0x80200000
+config ENV_SIZE
default 0x20000
default 0x40000
def_bool y
In my memory, enabling the CONFIG_EFI_LOADER option resulted in some errors on this board, but I forgot what those errors were. I will verify it, and if there are no issues, I will enable this option.
Best regards Kongyang Liu
Best regards
Heinrich
Import device tree from Linux kernel to add basic support for CPU, PLIC, UART and Timer. The name cv1800b in the filename represent the chip used on Milk-V Duo board.
Signed-off-by: Kongyang Liu seashell11234455@gmail.com ---
(no changes since v1)
arch/riscv/dts/Makefile | 1 + arch/riscv/dts/cv1800b-milkv-duo.dts | 38 +++++++++ arch/riscv/dts/cv1800b.dtsi | 123 +++++++++++++++++++++++++++ 3 files changed, 162 insertions(+) create mode 100644 arch/riscv/dts/cv1800b-milkv-duo.dts create mode 100644 arch/riscv/dts/cv1800b.dtsi
diff --git a/arch/riscv/dts/Makefile b/arch/riscv/dts/Makefile index be6c8a4227..b9e1678676 100644 --- a/arch/riscv/dts/Makefile +++ b/arch/riscv/dts/Makefile @@ -2,6 +2,7 @@
dtb-$(CONFIG_TARGET_ANDES_AE350) += ae350_32.dtb ae350_64.dtb dtb-$(CONFIG_TARGET_MICROCHIP_ICICLE) += mpfs-icicle-kit.dtb +dtb-$(CONFIG_TARGET_MILKV_DUO) += cv1800b-milkv-duo.dtb dtb-$(CONFIG_TARGET_QEMU_VIRT) += qemu-virt32.dtb qemu-virt64.dtb dtb-$(CONFIG_TARGET_OPENPITON_RISCV64) += openpiton-riscv64.dtb dtb-$(CONFIG_TARGET_SIFIVE_UNLEASHED) += hifive-unleashed-a00.dtb diff --git a/arch/riscv/dts/cv1800b-milkv-duo.dts b/arch/riscv/dts/cv1800b-milkv-duo.dts new file mode 100644 index 0000000000..3af9e34b3b --- /dev/null +++ b/arch/riscv/dts/cv1800b-milkv-duo.dts @@ -0,0 +1,38 @@ +// SPDX-License-Identifier: (GPL-2.0 OR MIT) +/* + * Copyright (C) 2023 Jisheng Zhang jszhang@kernel.org + */ + +/dts-v1/; + +#include "cv1800b.dtsi" + +/ { + model = "Milk-V Duo"; + compatible = "milkv,duo", "sophgo,cv1800b"; + + aliases { + serial0 = &uart0; + serial1 = &uart1; + serial2 = &uart2; + serial3 = &uart3; + serial4 = &uart4; + }; + + chosen { + stdout-path = "serial0:115200n8"; + }; + + memory@80000000 { + device_type = "memory"; + reg = <0x80000000 0x3f40000>; + }; +}; + +&osc { + clock-frequency = <25000000>; +}; + +&uart0 { + status = "okay"; +}; diff --git a/arch/riscv/dts/cv1800b.dtsi b/arch/riscv/dts/cv1800b.dtsi new file mode 100644 index 0000000000..df40e87ee0 --- /dev/null +++ b/arch/riscv/dts/cv1800b.dtsi @@ -0,0 +1,123 @@ +// SPDX-License-Identifier: (GPL-2.0 OR MIT) +/* + * Copyright (C) 2023 Jisheng Zhang jszhang@kernel.org + */ + +#include <dt-bindings/interrupt-controller/irq.h> + +/ { + compatible = "sophgo,cv1800b"; + #address-cells = <1>; + #size-cells = <1>; + + cpus: cpus { + #address-cells = <1>; + #size-cells = <0>; + timebase-frequency = <25000000>; + + cpu0: cpu@0 { + compatible = "thead,c906", "riscv"; + device_type = "cpu"; + reg = <0>; + d-cache-block-size = <64>; + d-cache-sets = <512>; + d-cache-size = <65536>; + i-cache-block-size = <64>; + i-cache-sets = <128>; + i-cache-size = <32768>; + mmu-type = "riscv,sv39"; + riscv,isa = "rv64imafdc"; + riscv,isa-base = "rv64i"; + riscv,isa-extensions = "i", "m", "a", "f", "d", "c", "zicntr", "zicsr", + "zifencei", "zihpm"; + + cpu0_intc: interrupt-controller { + compatible = "riscv,cpu-intc"; + interrupt-controller; + #address-cells = <0>; + #interrupt-cells = <1>; + }; + }; + }; + + osc: oscillator { + compatible = "fixed-clock"; + clock-output-names = "osc_25m"; + #clock-cells = <0>; + }; + + soc { + compatible = "simple-bus"; + interrupt-parent = <&plic>; + #address-cells = <1>; + #size-cells = <1>; + dma-noncoherent; + ranges; + + uart0: serial@4140000 { + compatible = "snps,dw-apb-uart"; + reg = <0x04140000 0x100>; + interrupts = <44 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&osc>; + reg-shift = <2>; + reg-io-width = <4>; + status = "disabled"; + }; + + uart1: serial@4150000 { + compatible = "snps,dw-apb-uart"; + reg = <0x04150000 0x100>; + interrupts = <45 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&osc>; + reg-shift = <2>; + reg-io-width = <4>; + status = "disabled"; + }; + + uart2: serial@4160000 { + compatible = "snps,dw-apb-uart"; + reg = <0x04160000 0x100>; + interrupts = <46 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&osc>; + reg-shift = <2>; + reg-io-width = <4>; + status = "disabled"; + }; + + uart3: serial@4170000 { + compatible = "snps,dw-apb-uart"; + reg = <0x04170000 0x100>; + interrupts = <47 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&osc>; + reg-shift = <2>; + reg-io-width = <4>; + status = "disabled"; + }; + + uart4: serial@41c0000 { + compatible = "snps,dw-apb-uart"; + reg = <0x041c0000 0x100>; + interrupts = <48 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&osc>; + reg-shift = <2>; + reg-io-width = <4>; + status = "disabled"; + }; + + plic: interrupt-controller@70000000 { + compatible = "sophgo,cv1800b-plic", "thead,c900-plic"; + reg = <0x70000000 0x4000000>; + interrupts-extended = <&cpu0_intc 11>, <&cpu0_intc 9>; + interrupt-controller; + #address-cells = <0>; + #interrupt-cells = <2>; + riscv,ndev = <101>; + }; + + clint: timer@74000000 { + compatible = "sophgo,cv1800b-clint", "thead,c900-clint"; + reg = <0x74000000 0x10000>; + interrupts-extended = <&cpu0_intc 3>, <&cpu0_intc 7>; + }; + }; +};
Add document for Milk-V Duo board which based on Sophgo's CV1800B SoC.
doc/board/index.rst | 1 + doc/board/sophgo/index.rst | 8 ++++++ doc/board/sophgo/milkv_duo.rst | 50 ++++++++++++++++++++++++++++++++++ 3 files changed, 59 insertions(+) create mode 100644 doc/board/sophgo/index.rst create mode 100644 doc/board/sophgo/milkv_duo.rst
diff --git a/doc/board/index.rst b/doc/board/index.rst index 531e547e7e..a0bd534742 100644 --- a/doc/board/index.rst +++ b/doc/board/index.rst @@ -45,6 +45,7 @@ Board-specific doc sifive/index sipeed/index socionext/index + sophgo/index st/index starfive/index ste/index diff --git a/doc/board/sophgo/index.rst b/doc/board/sophgo/index.rst new file mode 100644 index 0000000000..e097afdac6 --- /dev/null +++ b/doc/board/sophgo/index.rst @@ -0,0 +1,8 @@ +.. SPDX-License-Identifier: GPL-2.0+ + +Sophgo +====== +.. toctree:: + :maxdepth: 1 + + milkv_duo diff --git a/doc/board/sophgo/milkv_duo.rst b/doc/board/sophgo/milkv_duo.rst new file mode 100644 index 0000000000..b63304b510 --- /dev/null +++ b/doc/board/sophgo/milkv_duo.rst @@ -0,0 +1,50 @@ +.. SPDX-License-Identifier: GPL-2.0+ + +Milk-V Duo +========== + +CV1800B RISC-V SoC +------------------ +The CV1800B is a high-performance, low-power 1+1 64-bit RISC-V SoC from Sophgo. + +Mainline support +---------------- +The support for following drivers are already enabled: +1. ns16550 UART Driver. + +Building +~~~~~~~~ +1. Add the RISC-V toolchain to your PATH. +2. Setup ARCH & cross compilation environment variable: + +.. code-block:: console + + export CROSS_COMPILE=<riscv64 toolchain prefix> + cd <U-Boot-dir> + make milkv_duo_defconfig + make + +This will generate u-boot-dtb.bin + +Booting +~~~~~~~ +Currently, we rely on vendor FSBL(First Stage Boot Loader) to initialize the +clock and load the u-boot image, then bootup from it. + +Sample boot log from Milk-V Duo board +~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ +.. code-block:: none + + U-Boot 2024.01-rc5-00010-g51965baa36 (Dec 28 2023 - 13:15:53 +0800)milkv_duo + + DRAM: 63.3 MiB + Core: 10 devices, 8 uclasses, devicetree: separate + Loading Environment from nowhere... OK + In: serial@4140000 + Out: serial@4140000 + Err: serial@4140000 + Net: No ethernet found. + milkv_duo# cpu detail + 0: cpu@0 rv64imafdc + ID = 0, freq = 0 Hz: L1 cache, MMU + milkv_duo#
- sophgo/index st/index starfive/index ste/index
- :maxdepth: 1
- milkv_duo
- export CROSS_COMPILE=<riscv64 toolchain prefix>
- cd <U-Boot-dir>
- make milkv_duo_defconfig
- make
Thank you for providing documentation for the board.
Could you please, additionally describe the procedure to run u-boot-dtb.bin on top of FSBL.
Best regards
Heinrich
- U-Boot 2024.01-rc5-00010-g51965baa36 (Dec 28 2023 - 13:15:53 +0800)milkv_duo
- DRAM: 63.3 MiB
- Core: 10 devices, 8 uclasses, devicetree: separate
- Loading Environment from nowhere... OK
- In: serial@4140000
- Out: serial@4140000
- Err: serial@4140000
- Net: No ethernet found.
- milkv_duo# cpu detail
0: cpu@0 rv64imafdc
- milkv_duo#
Heinrich Schuchardt xypron.glpk@gmx.de 于2024年1月15日周一 05:27写道:
- :maxdepth: 1
- milkv_duo
- cd <U-Boot-dir>
- make
I'd like to clarify your request for describing the procedure to run u-boot-dtb.bin on top of FSBL. Are you looking for a detailed, step-by-step guide to replicate the process and successfully run u-boot-dtb.bin, or would you prefer a more concise overview?
Best regards
Heinrich
- DRAM: 63.3 MiB
0: cpu@0 rv64imafdc
- milkv_duo#
Kongyang Liu
