[U-Boot] [PATCH] PowerPC: phy: enable all phylib drivers when use phylib and tsec enet
<config_phylib_all_drivers.h> should be included when CONFIG_PHYLIB and CONFIG_TSEC_ENET are defined.
Fixes: 3146f0c017 ("Move PHYLIB to Kconfig") Signed-off-by: Zhao Qiang qiang.zhao@nxp.com --- arch/powerpc/include/asm/config.h | 4 +--- 1 files changed, 1 insertions(+), 3 deletions(-)
diff --git a/arch/powerpc/include/asm/config.h b/arch/powerpc/include/asm/config.h index 6aec815..8dd53f2 100644 --- a/arch/powerpc/include/asm/config.h +++ b/arch/powerpc/include/asm/config.h @@ -72,11 +72,9 @@ #endif
/* The TSEC driver uses the PHYLIB infrastructure */ -#ifndef CONFIG_PHYLIB -#if defined(CONFIG_TSEC_ENET) +#if defined(CONFIG_TSEC_ENET) && defined(CONFIG_PHYLIB) #include <config_phylib_all_drivers.h> #endif /* TSEC_ENET */ -#endif /* !CONFIG_PHYLIB */
/* The FMAN driver uses the PHYLIB infrastructure */
Applied to fsl-qoriq master, awaiting upstream. Thanks.
York
York Sun
Zhao Qiang
