[U-Boot] [PATCH 00/10] tbs2910 fixes and driver model conversion
DM_MMC activates BLK, so we have to convert dwc_ahsata to AHCI before.
Soeren Moch (10): board: tbs2910: Fix default environment board: tbs2910: Remove efi loader support in defconfig to reduce u-boot size board: tbs2910: Add device tree board: tbs2910: Add pinctrl driver and convert gpio to driver model board: tbs2910: Convert usb to driver model board: tbs2910: Convert i2c and rtc to driver model ata: dwc_ahsata: Fix sector reports for large disks ata: dwc_ahsata: Add ahci driver model support board: tbs2910: Convert sata to ahci driver model board: tbs2910: Convert mmc to driver model
arch/arm/dts/imx6q-tbs2910.dts | 394 +++++++++++++++++++++++++++++++++ board/tbs/tbs2910/MAINTAINERS | 1 + board/tbs/tbs2910/tbs2910.c | 184 +-------------- configs/cm_fx6_defconfig | 1 + configs/tbs2910_defconfig | 18 +- drivers/ata/Kconfig | 8 + drivers/ata/dwc_ahsata.c | 38 +++- include/configs/tbs2910.h | 38 +--- 8 files changed, 455 insertions(+), 227 deletions(-) create mode 100644 arch/arm/dts/imx6q-tbs2910.dts
-- 2.17.1
Especially fix usb keyboard support. Other changes are only for beautification.
Signed-off-by: Soeren Moch smoch@web.de --- Cc: Stefano Babic sbabic@denx.de Cc: u-boot@lists.denx.de --- include/configs/tbs2910.h | 12 ++++++------ 1 file changed, 6 insertions(+), 6 deletions(-)
diff --git a/include/configs/tbs2910.h b/include/configs/tbs2910.h index 2d4b9c9bfe..b06c90939c 100644 --- a/include/configs/tbs2910.h +++ b/include/configs/tbs2910.h @@ -94,7 +94,7 @@ "run set_con_hdmi; " \ "else " \ "run set_con_serial; " \ - "fi;" + "fi" #endif /* CONFIG_USB_KEYBOARD */ #endif /* CONFIG_CMD_USB */
@@ -142,12 +142,12 @@ "console=ttymxc0\0" \ "fan=gpio set 92\0" \ "set_con_serial=setenv stdout serial; " \ - "setenv stderr serial;\0" \ + "setenv stderr serial\0" \ "set_con_hdmi=setenv stdout serial,vga; " \ - "setenv stderr serial,vga;\0" \ - "stderr=serial,vga;\0" \ - "stdin=serial,usbkbd;\0" \ - "stdout=serial,vga;\0" + "setenv stderr serial,vga\0" \ + "stderr=serial,vga\0" \ + "stdin=serial,usbkbd\0" \ + "stdout=serial,vga\0"
#define CONFIG_BOOTCOMMAND \ "mmc rescan; " \ -- 2.17.1
Stefano,
apparently you decided to pull fixes for v2019.04 and DM conversions for v2019.07. Since this patch (1/10) is a fix, can you at least pull this now, and the rest of the series later (or for -next)?
Thanks, Soeren
Stefano,
That is right.
I pick up 1/10
Regards, Stefano
Signed-off-by: Soeren Moch smoch@web.de --- Cc: Stefano Babic sbabic@denx.de Cc: u-boot@lists.denx.de --- configs/tbs2910_defconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/configs/tbs2910_defconfig b/configs/tbs2910_defconfig index 78beb9a522..70a3e18e23 100644 --- a/configs/tbs2910_defconfig +++ b/configs/tbs2910_defconfig @@ -56,3 +56,4 @@ CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_VIDEO=y CONFIG_OF_LIBFDT=y +# CONFIG_EFI_LOADER is not set -- 2.17.1
Applied to u-boot-imx, -next, thanks !
Best regards, Stefano Babic
... as preparation for additional driver model coonversions.
We use CONFIG_OF_EMBED here to keep u-boot.imx as final binary name. So we maintain compatibility with the original TBS u-boot and available HOWTOs for u-boot updates.
Signed-off-by: Soeren Moch smoch@web.de --- Cc: Stefano Babic sbabic@denx.de Cc: u-boot@lists.denx.de --- arch/arm/dts/imx6q-tbs2910.dts | 394 +++++++++++++++++++++++++++++++++ board/tbs/tbs2910/MAINTAINERS | 1 + board/tbs/tbs2910/tbs2910.c | 6 - configs/tbs2910_defconfig | 4 +- 4 files changed, 398 insertions(+), 7 deletions(-) create mode 100644 arch/arm/dts/imx6q-tbs2910.dts
diff --git a/arch/arm/dts/imx6q-tbs2910.dts b/arch/arm/dts/imx6q-tbs2910.dts new file mode 100644 index 0000000000..21e62c0cab --- /dev/null +++ b/arch/arm/dts/imx6q-tbs2910.dts @@ -0,0 +1,394 @@ +// SPDX-License-Identifier: GPL-2.0+ OR MIT +// +// Copyright 2014-2019 Soeren Moch smoch@web.de + +/dts-v1/; + +#include "imx6q.dtsi" +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/input/input.h> + +/ { + model = "TBS2910 Matrix ARM mini PC"; + compatible = "tbs,imx6q-tbs2910", "fsl,imx6q"; + + chosen { + stdout-path = &uart1; + }; + + aliases { + mmc0 = &usdhc2; + mmc1 = &usdhc3; + mmc2 = &usdhc4; + usb0 = &usbotg; + }; + + memory@10000000 { + reg = <0x10000000 0x80000000>; + }; + + fan { + compatible = "gpio-fan"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_gpio_fan>; + gpios = <&gpio3 28 GPIO_ACTIVE_HIGH>; + gpio-fan,speed-map = <0 0 + 3000 1>; + }; + + ir_recv { + compatible = "gpio-ir-receiver"; + gpios = <&gpio3 18 GPIO_ACTIVE_LOW>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_ir>; + }; + + leds { + compatible = "gpio-leds"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_gpio_leds>; + + blue { + label = "blue_status_led"; + gpios = <&gpio1 2 GPIO_ACTIVE_HIGH>; + default-state = "keep"; + }; + }; + + reg_2p5v: regulator-2p5v { + compatible = "regulator-fixed"; + regulator-name = "2P5V"; + regulator-min-microvolt = <2500000>; + regulator-max-microvolt = <2500000>; + }; + + reg_3p3v: regulator-3p3v { + compatible = "regulator-fixed"; + regulator-name = "3P3V"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + }; + + reg_5p0v: regulator-5p0v { + compatible = "regulator-fixed"; + regulator-name = "5P0V"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + }; + + sound-sgtl5000 { + audio-codec = <&sgtl5000>; + audio-routing = + "MIC_IN", "Mic Jack", + "Mic Jack", "Mic Bias", + "Headphone Jack", "HP_OUT"; + compatible = "fsl,imx-audio-sgtl5000"; + model = "On-board Codec"; + mux-ext-port = <3>; + mux-int-port = <1>; + ssi-controller = <&ssi1>; + }; + + sound-spdif { + compatible = "fsl,imx-audio-spdif"; + model = "On-board SPDIF"; + spdif-controller = <&spdif>; + spdif-out; + }; +}; + +&audmux { + status = "okay"; +}; + +&fec { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_enet>; + phy-mode = "rgmii"; + phy-reset-gpios = <&gpio1 25 GPIO_ACTIVE_LOW>; + status = "okay"; +}; + +&hdmi { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_hdmi>; + ddc-i2c-bus = <&i2c2>; + status = "okay"; +}; + +&i2c1 { + clock-frequency = <100000>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c1>; + status = "okay"; + + sgtl5000: sgtl5000@a { + clocks = <&clks IMX6QDL_CLK_CKO>; + compatible = "fsl,sgtl5000"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_sgtl5000>; + reg = <0x0a>; + VDDA-supply = <®_2p5v>; + VDDIO-supply = <®_3p3v>; + }; +}; + +&i2c2 { + clock-frequency = <100000>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c2>; + status = "okay"; +}; + +&i2c3 { + clock-frequency = <100000>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c3>; + status = "okay"; + + rtc: ds1307@68 { + compatible = "dallas,ds1307"; + reg = <0x68>; + }; +}; + +&pcie { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_pcie>; + reset-gpio = <&gpio7 12 GPIO_ACTIVE_LOW>; + status = "okay"; +}; + +&sata { + fsl,transmit-level-mV = <1104>; + fsl,transmit-boost-mdB = <3330>; + fsl,transmit-atten-16ths = <16>; + fsl,receive-eq-mdB = <3000>; + status = "okay"; +}; + +&snvs_poweroff { + status = "okay"; +}; + +&spdif { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_spdif>; + status = "okay"; +}; + +&ssi1 { + status = "okay"; +}; + +&uart1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart1>; + status = "okay"; +}; + +&uart2 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart2>; + status = "okay"; +}; + +&usbh1 { + vbus-supply = <®_5p0v>; + status = "okay"; +}; + +&usbotg { + vbus-supply = <®_5p0v>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usbotg>; + disable-over-current; + status = "okay"; +}; + +&usdhc2 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usdhc2>; + bus-width = <4>; + cd-gpios = <&gpio2 2 GPIO_ACTIVE_LOW>; + vmmc-supply = <®_3p3v>; + vqmmc-supply = <®_3p3v>; + voltage-ranges = <3300 3300>; + no-1-8-v; + status = "okay"; +}; + +&usdhc3 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usdhc3>; + bus-width = <4>; + cd-gpios = <&gpio2 0 GPIO_ACTIVE_LOW>; + wp-gpios = <&gpio2 1 GPIO_ACTIVE_HIGH>; + vmmc-supply = <®_3p3v>; + vqmmc-supply = <®_3p3v>; + voltage-ranges = <3300 3300>; + no-1-8-v; + status = "okay"; +}; + +&usdhc4 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usdhc4>; + bus-width = <8>; + vmmc-supply = <®_3p3v>; + vqmmc-supply = <®_3p3v>; + voltage-ranges = <3300 3300>; + non-removable; + no-1-8-v; + status = "okay"; +}; + +&iomuxc { + pinctrl_enet: enetgrp { + fsl,pins = < + MX6QDL_PAD_ENET_MDIO__ENET_MDIO 0x1b0b0 + MX6QDL_PAD_ENET_MDC__ENET_MDC 0x1b0b0 + MX6QDL_PAD_RGMII_TXC__RGMII_TXC 0x1b030 + MX6QDL_PAD_RGMII_TD0__RGMII_TD0 0x1b030 + MX6QDL_PAD_RGMII_TD1__RGMII_TD1 0x1b030 + MX6QDL_PAD_RGMII_TD2__RGMII_TD2 0x1b030 + MX6QDL_PAD_RGMII_TD3__RGMII_TD3 0x1b030 + MX6QDL_PAD_RGMII_TX_CTL__RGMII_TX_CTL 0x1b030 + MX6QDL_PAD_ENET_REF_CLK__ENET_TX_CLK 0x1b0b0 + MX6QDL_PAD_RGMII_RXC__RGMII_RXC 0x1b030 + MX6QDL_PAD_RGMII_RD0__RGMII_RD0 0x1b030 + MX6QDL_PAD_RGMII_RD1__RGMII_RD1 0x1b030 + MX6QDL_PAD_RGMII_RD2__RGMII_RD2 0x1b030 + MX6QDL_PAD_RGMII_RD3__RGMII_RD3 0x1b030 + MX6QDL_PAD_RGMII_RX_CTL__RGMII_RX_CTL 0x1b030 + MX6QDL_PAD_GPIO_16__ENET_REF_CLK 0x4001b0a8 + MX6QDL_PAD_ENET_CRS_DV__GPIO1_IO25 0x1b059 + >; + }; + + pinctrl_gpio_fan: gpiofangrp { + fsl,pins = < + MX6QDL_PAD_EIM_D28__GPIO3_IO28 0x130b1 + >; + }; + + pinctrl_gpio_leds: gpioledsgrp { + fsl,pins = < + MX6QDL_PAD_GPIO_2__GPIO1_IO02 0x130b1 + >; + }; + + pinctrl_hdmi: hdmigrp { + fsl,pins = < + MX6QDL_PAD_KEY_ROW2__HDMI_TX_CEC_LINE 0x1f8b0 + >; + }; + + pinctrl_i2c1: i2c1grp { + fsl,pins = < + MX6QDL_PAD_CSI0_DAT9__I2C1_SCL 0x4001b8b1 + MX6QDL_PAD_CSI0_DAT8__I2C1_SDA 0x4001b8b1 + >; + }; + + pinctrl_i2c2: i2c2grp { + fsl,pins = < + MX6QDL_PAD_KEY_COL3__I2C2_SCL 0x4001b8b1 + MX6QDL_PAD_KEY_ROW3__I2C2_SDA 0x4001b8b1 + >; + }; + + pinctrl_i2c3: i2c3grp { + fsl,pins = < + MX6QDL_PAD_GPIO_3__I2C3_SCL 0x4001b8b1 + MX6QDL_PAD_GPIO_6__I2C3_SDA 0x4001b8b1 + >; + }; + + pinctrl_ir: irgrp { + fsl,pins = < + MX6QDL_PAD_EIM_D18__GPIO3_IO18 0x17059 + >; + }; + + pinctrl_pcie: pciegrp { + fsl,pins = < + MX6QDL_PAD_GPIO_17__GPIO7_IO12 0x17059 + >; + }; + + pinctrl_sgtl5000: sgtl5000grp { + fsl,pins = < + MX6QDL_PAD_CSI0_DAT7__AUD3_RXD 0x130b0 + MX6QDL_PAD_CSI0_DAT4__AUD3_TXC 0x130b0 + MX6QDL_PAD_CSI0_DAT5__AUD3_TXD 0x110b0 + MX6QDL_PAD_CSI0_DAT6__AUD3_TXFS 0x130b0 + MX6QDL_PAD_GPIO_0__CCM_CLKO1 0x130b0 + >; + }; + + pinctrl_spdif: spdifgrp { + fsl,pins = <MX6QDL_PAD_GPIO_19__SPDIF_OUT 0x13091 + >; + }; + + pinctrl_uart1: uart1grp { + fsl,pins = < + MX6QDL_PAD_CSI0_DAT10__UART1_TX_DATA 0x1b0b1 + MX6QDL_PAD_CSI0_DAT11__UART1_RX_DATA 0x1b0b1 + >; + }; + + pinctrl_uart2: uart2grp { + fsl,pins = < + MX6QDL_PAD_EIM_D26__UART2_TX_DATA 0x1b0b1 + MX6QDL_PAD_EIM_D27__UART2_RX_DATA 0x1b0b1 + >; + }; + + pinctrl_usbotg: usbotggrp { + fsl,pins = < + MX6QDL_PAD_ENET_RX_ER__USB_OTG_ID 0x17059 + >; + }; + + pinctrl_usdhc2: usdhc2grp { + fsl,pins = < + MX6QDL_PAD_SD2_CMD__SD2_CMD 0x17059 + MX6QDL_PAD_SD2_CLK__SD2_CLK 0x10059 + MX6QDL_PAD_SD2_DAT0__SD2_DATA0 0x17059 + MX6QDL_PAD_SD2_DAT1__SD2_DATA1 0x17059 + MX6QDL_PAD_SD2_DAT2__SD2_DATA2 0x17059 + MX6QDL_PAD_SD2_DAT3__SD2_DATA3 0x17059 + MX6QDL_PAD_NANDF_D2__GPIO2_IO02 0x17059 + >; + }; + + pinctrl_usdhc3: usdhc3grp { + fsl,pins = < + MX6QDL_PAD_SD3_CMD__SD3_CMD 0x17059 + MX6QDL_PAD_SD3_CLK__SD3_CLK 0x10059 + MX6QDL_PAD_SD3_DAT0__SD3_DATA0 0x17059 + MX6QDL_PAD_SD3_DAT1__SD3_DATA1 0x17059 + MX6QDL_PAD_SD3_DAT2__SD3_DATA2 0x17059 + MX6QDL_PAD_SD3_DAT3__SD3_DATA3 0x17059 + MX6QDL_PAD_NANDF_D0__GPIO2_IO00 0x17059 + MX6QDL_PAD_NANDF_D1__GPIO2_IO01 0x17059 + >; + }; + + pinctrl_usdhc4: usdhc4grp { + fsl,pins = < + MX6QDL_PAD_SD4_CMD__SD4_CMD 0x17059 + MX6QDL_PAD_SD4_CLK__SD4_CLK 0x10059 + MX6QDL_PAD_SD4_DAT0__SD4_DATA0 0x17059 + MX6QDL_PAD_SD4_DAT1__SD4_DATA1 0x17059 + MX6QDL_PAD_SD4_DAT2__SD4_DATA2 0x17059 + MX6QDL_PAD_SD4_DAT3__SD4_DATA3 0x17059 + MX6QDL_PAD_SD4_DAT4__SD4_DATA4 0x17059 + MX6QDL_PAD_SD4_DAT5__SD4_DATA5 0x17059 + MX6QDL_PAD_SD4_DAT6__SD4_DATA6 0x17059 + MX6QDL_PAD_SD4_DAT7__SD4_DATA7 0x17059 + >; + }; +}; diff --git a/board/tbs/tbs2910/MAINTAINERS b/board/tbs/tbs2910/MAINTAINERS index bf176553d2..a3ad2f712a 100644 --- a/board/tbs/tbs2910/MAINTAINERS +++ b/board/tbs/tbs2910/MAINTAINERS @@ -1,6 +1,7 @@ TBS2910 BOARD M: Soeren Moch smoch@web.de S: Maintained +F: arch/arm/dts/imx6q-tbs2910.dts F: board/tbs/tbs2910/ F: configs/tbs2910_defconfig F: include/configs/tbs2910.h diff --git a/board/tbs/tbs2910/tbs2910.c b/board/tbs/tbs2910/tbs2910.c index ecb45f208d..99b282ca6b 100644 --- a/board/tbs/tbs2910/tbs2910.c +++ b/board/tbs/tbs2910/tbs2910.c @@ -446,9 +446,3 @@ int board_init(void) #endif return 0; } - -int checkboard(void) -{ - puts("Board: TBS2910 Matrix ARM mini PC\n"); - return 0; -} diff --git a/configs/tbs2910_defconfig b/configs/tbs2910_defconfig index 70a3e18e23..3cc68eb922 100644 --- a/configs/tbs2910_defconfig +++ b/configs/tbs2910_defconfig @@ -36,6 +36,9 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_EFI_PARTITION=y +CONFIG_OF_CONTROL=y +CONFIG_OF_EMBED=y +CONFIG_DEFAULT_DEVICE_TREE="imx6q-tbs2910" CONFIG_ENV_IS_IN_MMC=y CONFIG_DM=y CONFIG_DWC_AHSATA=y @@ -55,5 +58,4 @@ CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_VIDEO=y -CONFIG_OF_LIBFDT=y # CONFIG_EFI_LOADER is not set -- 2.17.1
... as preparation for additional driver model coonversions. We use CONFIG_OF_EMBED here to keep u-boot.imx as final binary name. So we maintain compatibility with the original TBS u-boot and available HOWTOs for u-boot updates. Signed-off-by: Soeren Moch smoch@web.de
We need this for additional driver model conversions.
Signed-off-by: Soeren Moch smoch@web.de --- Cc: Stefano Babic sbabic@denx.de Cc: u-boot@lists.denx.de --- board/tbs/tbs2910/tbs2910.c | 3 +++ configs/tbs2910_defconfig | 3 +++ 2 files changed, 6 insertions(+)
diff --git a/board/tbs/tbs2910/tbs2910.c b/board/tbs/tbs2910/tbs2910.c index 99b282ca6b..175dd88a69 100644 --- a/board/tbs/tbs2910/tbs2910.c +++ b/board/tbs/tbs2910/tbs2910.c @@ -138,6 +138,7 @@ static void setup_iomux_enet(void) imx_iomux_v3_setup_multiple_pads(enet_pads, ARRAY_SIZE(enet_pads));
/* Reset AR8035 PHY */ + gpio_request(IMX_GPIO_NR(1, 25), "ETH_PHY_RESET"); gpio_direction_output(IMX_GPIO_NR(1, 25) , 0); udelay(500); gpio_set_value(IMX_GPIO_NR(1, 25), 1); @@ -230,12 +231,14 @@ int board_mmc_init(bd_t *bis) case 0: imx_iomux_v3_setup_multiple_pads( usdhc2_pads, ARRAY_SIZE(usdhc2_pads)); + gpio_request(USDHC2_CD_GPIO, "MMC0_CD"); gpio_direction_input(USDHC2_CD_GPIO); usdhc_cfg[0].sdhc_clk = mxc_get_clock(MXC_ESDHC2_CLK); break; case 1: imx_iomux_v3_setup_multiple_pads( usdhc3_pads, ARRAY_SIZE(usdhc3_pads)); + gpio_request(USDHC3_CD_GPIO, "MMC1_CD"); gpio_direction_input(USDHC3_CD_GPIO); usdhc_cfg[1].sdhc_clk = mxc_get_clock(MXC_ESDHC3_CLK); break; diff --git a/configs/tbs2910_defconfig b/configs/tbs2910_defconfig index 3cc68eb922..717cabfa3b 100644 --- a/configs/tbs2910_defconfig +++ b/configs/tbs2910_defconfig @@ -42,10 +42,13 @@ CONFIG_DEFAULT_DEVICE_TREE="imx6q-tbs2910" CONFIG_ENV_IS_IN_MMC=y CONFIG_DM=y CONFIG_DWC_AHSATA=y +CONFIG_DM_GPIO=y CONFIG_FSL_ESDHC=y CONFIG_PHYLIB=y CONFIG_MII=y CONFIG_PCI=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_IMX6=y CONFIG_DM_THERMAL=y CONFIG_USB=y CONFIG_USB_STORAGE=y -- 2.17.1
We need this for additional driver model conversions. Signed-off-by: Soeren Moch smoch@web.de
So we don't need to duplicate settings from the device tree in the board file.
Signed-off-by: Soeren Moch smoch@web.de --- Cc: Stefano Babic sbabic@denx.de Cc: u-boot@lists.denx.de --- board/tbs/tbs2910/tbs2910.c | 10 ---------- configs/tbs2910_defconfig | 2 ++ include/configs/tbs2910.h | 1 - 3 files changed, 2 insertions(+), 11 deletions(-)
diff --git a/board/tbs/tbs2910/tbs2910.c b/board/tbs/tbs2910/tbs2910.c index 175dd88a69..20c93778e1 100644 --- a/board/tbs/tbs2910/tbs2910.c +++ b/board/tbs/tbs2910/tbs2910.c @@ -418,12 +418,6 @@ static const struct boot_mode board_boot_modes[] = { }; #endif
-#ifdef CONFIG_USB_EHCI_MX6 -static iomux_v3_cfg_t const usb_otg_pads[] = { - MX6_PAD_ENET_RX_ER__USB_OTG_ID | MUX_PAD_CTRL(NO_PAD_CTRL), -}; -#endif - int board_init(void) { /* address of boot parameters */ @@ -442,10 +436,6 @@ int board_init(void) #endif #ifdef CONFIG_CMD_BMODE add_board_boot_modes(board_boot_modes); -#endif -#ifdef CONFIG_USB_EHCI_MX6 - imx_iomux_v3_setup_multiple_pads( - usb_otg_pads, ARRAY_SIZE(usb_otg_pads)); #endif return 0; } diff --git a/configs/tbs2910_defconfig b/configs/tbs2910_defconfig index 717cabfa3b..395275c6dd 100644 --- a/configs/tbs2910_defconfig +++ b/configs/tbs2910_defconfig @@ -43,6 +43,7 @@ CONFIG_ENV_IS_IN_MMC=y CONFIG_DM=y CONFIG_DWC_AHSATA=y CONFIG_DM_GPIO=y +CONFIG_DM_KEYBOARD=y CONFIG_FSL_ESDHC=y CONFIG_PHYLIB=y CONFIG_MII=y @@ -51,6 +52,7 @@ CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX6=y CONFIG_DM_THERMAL=y CONFIG_USB=y +CONFIG_DM_USB=y CONFIG_USB_STORAGE=y CONFIG_USB_KEYBOARD=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/include/configs/tbs2910.h b/include/configs/tbs2910.h index b06c90939c..93f75d72f3 100644 --- a/include/configs/tbs2910.h +++ b/include/configs/tbs2910.h @@ -81,7 +81,6 @@
/* USB */ #ifdef CONFIG_CMD_USB -#define CONFIG_USB_MAX_CONTROLLER_COUNT 2 #define CONFIG_EHCI_HCD_INIT_AFTER_RESET #define CONFIG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) #ifdef CONFIG_CMD_USB_MASS_STORAGE -- 2.17.1
So we don't need to duplicate settings from the device tree in the board file. Signed-off-by: Soeren Moch smoch@web.de
Signed-off-by: Soeren Moch smoch@web.de --- Cc: Stefano Babic sbabic@denx.de Cc: u-boot@lists.denx.de --- board/tbs/tbs2910/tbs2910.c | 57 ------------------------------------- configs/tbs2910_defconfig | 6 +++- include/configs/tbs2910.h | 17 ----------- 3 files changed, 5 insertions(+), 75 deletions(-)
diff --git a/board/tbs/tbs2910/tbs2910.c b/board/tbs/tbs2910/tbs2910.c index 20c93778e1..2445efbde2 100644 --- a/board/tbs/tbs2910/tbs2910.c +++ b/board/tbs/tbs2910/tbs2910.c @@ -9,7 +9,6 @@ #include <asm/arch/mx6-pins.h> #include <linux/errno.h> #include <asm/gpio.h> -#include <asm/mach-imx/mxc_i2c.h> #include <asm/mach-imx/iomux-v3.h> #include <asm/mach-imx/sata.h> #include <asm/mach-imx/boot_mode.h> @@ -22,7 +21,6 @@ #include <asm/arch/crm_regs.h> #include <asm/io.h> #include <asm/arch/sys_proto.h> -#include <i2c.h> DECLARE_GLOBAL_DATA_PTR;
#define WEAK_PULLUP (PAD_CTL_PUS_47K_UP | \ @@ -40,56 +38,6 @@ DECLARE_GLOBAL_DATA_PTR; #define ENET_PAD_CTRL (PAD_CTL_PUS_100K_UP | \ PAD_CTL_SPEED_MED | PAD_CTL_DSE_40ohm | PAD_CTL_HYS)
-#define I2C_PAD_CTRL (PAD_CTL_PUS_100K_UP | \ - PAD_CTL_SPEED_MED | PAD_CTL_DSE_40ohm | PAD_CTL_HYS | \ - PAD_CTL_ODE | PAD_CTL_SRE_FAST) - -#define I2C_PAD MUX_PAD_CTRL(I2C_PAD_CTRL) - -#ifdef CONFIG_SYS_I2C -/* I2C1, SGTL5000 */ -static struct i2c_pads_info i2c_pad_info0 = { - .scl = { - .i2c_mode = MX6_PAD_CSI0_DAT9__I2C1_SCL | I2C_PAD, - .gpio_mode = MX6_PAD_CSI0_DAT9__GPIO5_IO27 | I2C_PAD, - .gp = IMX_GPIO_NR(5, 27) - }, - .sda = { - .i2c_mode = MX6_PAD_CSI0_DAT8__I2C1_SDA | I2C_PAD, - .gpio_mode = MX6_PAD_CSI0_DAT8__GPIO5_IO26 | I2C_PAD, - .gp = IMX_GPIO_NR(5, 26) - } -}; - -/* I2C2 HDMI */ -static struct i2c_pads_info i2c_pad_info1 = { - .scl = { - .i2c_mode = MX6_PAD_KEY_COL3__I2C2_SCL | I2C_PAD, - .gpio_mode = MX6_PAD_KEY_COL3__GPIO4_IO12 | I2C_PAD, - .gp = IMX_GPIO_NR(4, 12) - }, - .sda = { - .i2c_mode = MX6_PAD_KEY_ROW3__I2C2_SDA | I2C_PAD, - .gpio_mode = MX6_PAD_KEY_ROW3__GPIO4_IO13 | I2C_PAD, - .gp = IMX_GPIO_NR(4, 13) - } -}; - -/* I2C3, CON11, DS1307, PCIe_SMB */ -static struct i2c_pads_info i2c_pad_info2 = { - .scl = { - .i2c_mode = MX6_PAD_GPIO_3__I2C3_SCL | I2C_PAD, - .gpio_mode = MX6_PAD_GPIO_3__GPIO1_IO03 | I2C_PAD, - .gp = IMX_GPIO_NR(1, 3) - }, - .sda = { - .i2c_mode = MX6_PAD_GPIO_6__I2C3_SDA | I2C_PAD, - .gpio_mode = MX6_PAD_GPIO_6__GPIO1_IO06 | I2C_PAD, - .gp = IMX_GPIO_NR(1, 6) - } -}; -#endif /* CONFIG_SYS_I2C */ - static iomux_v3_cfg_t const uart1_pads[] = { MX6_PAD_CSI0_DAT10__UART1_TX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL), MX6_PAD_CSI0_DAT11__UART1_RX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL), @@ -426,11 +374,6 @@ int board_init(void) #ifdef CONFIG_VIDEO_IPUV3 setup_display(); #endif -#ifdef CONFIG_SYS_I2C - setup_i2c(0, CONFIG_SYS_I2C_SPEED, 0x7f, &i2c_pad_info0); - setup_i2c(1, CONFIG_SYS_I2C_SPEED, 0x7f, &i2c_pad_info1); - setup_i2c(2, CONFIG_SYS_I2C_SPEED, 0x7f, &i2c_pad_info2); -#endif #ifdef CONFIG_DWC_AHSATA setup_sata(); #endif diff --git a/configs/tbs2910_defconfig b/configs/tbs2910_defconfig index 395275c6dd..153f61d09d 100644 --- a/configs/tbs2910_defconfig +++ b/configs/tbs2910_defconfig @@ -28,7 +28,6 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y -CONFIG_CMD_DATE=y CONFIG_CMD_TIME=y CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y @@ -43,6 +42,8 @@ CONFIG_ENV_IS_IN_MMC=y CONFIG_DM=y CONFIG_DWC_AHSATA=y CONFIG_DM_GPIO=y +CONFIG_DM_I2C=y +CONFIG_SYS_I2C_MXC=y CONFIG_DM_KEYBOARD=y CONFIG_FSL_ESDHC=y CONFIG_PHYLIB=y @@ -50,6 +51,8 @@ CONFIG_MII=y CONFIG_PCI=y CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX6=y +CONFIG_DM_RTC=y +CONFIG_RTC_DS1307=y CONFIG_DM_THERMAL=y CONFIG_USB=y CONFIG_DM_USB=y @@ -62,5 +65,6 @@ CONFIG_USB_GADGET_VENDOR_NUM=0x0525 CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y +CONFIG_I2C_EDID=y CONFIG_VIDEO=y # CONFIG_EFI_LOADER is not set diff --git a/include/configs/tbs2910.h b/include/configs/tbs2910.h index 93f75d72f3..eff93eff4f 100644 --- a/include/configs/tbs2910.h +++ b/include/configs/tbs2910.h @@ -97,23 +97,6 @@ #endif /* CONFIG_USB_KEYBOARD */ #endif /* CONFIG_CMD_USB */
-/* RTC */ -#ifdef CONFIG_CMD_DATE -#define CONFIG_RTC_DS1307 -#define CONFIG_SYS_RTC_BUS_NUM 2 -#endif - -/* I2C */ -#ifdef CONFIG_CMD_I2C -#define CONFIG_SYS_I2C -#define CONFIG_SYS_I2C_MXC -#define CONFIG_SYS_I2C_MXC_I2C1 /* enable I2C bus 1 */ -#define CONFIG_SYS_I2C_MXC_I2C2 /* enable I2C bus 2 */ -#define CONFIG_SYS_I2C_MXC_I2C3 /* enable I2C bus 3 */ -#define CONFIG_SYS_I2C_SPEED 100000 -#define CONFIG_I2C_EDID -#endif - /* Environment organization */ #define CONFIG_SYS_MMC_ENV_DEV 2 /* overwritten on SD boot */ #define CONFIG_SYS_MMC_ENV_PART 1 /* overwritten on SD boot */ -- 2.17.1
Do not report negative sector numbers for disks > 1TB, do not limit sector numbers to 32 bit if CONFIG_SYS_64BIT_LBA is enabled.
Signed-off-by: Soeren Moch smoch@web.de --- Cc: Stefano Babic sbabic@denx.de Cc: u-boot@lists.denx.de --- drivers/ata/dwc_ahsata.c | 14 +++----------- 1 file changed, 3 insertions(+), 11 deletions(-)
diff --git a/drivers/ata/dwc_ahsata.c b/drivers/ata/dwc_ahsata.c index 4c5b98482f..6fe5641dd9 100644 --- a/drivers/ata/dwc_ahsata.c +++ b/drivers/ata/dwc_ahsata.c @@ -511,15 +511,9 @@ static int ahci_port_start(struct ahci_uc_priv *uc_priv, u8 port) static void dwc_ahsata_print_info(struct blk_desc *pdev) { printf("SATA Device Info:\n\r"); -#ifdef CONFIG_SYS_64BIT_LBA printf("S/N: %s\n\rProduct model number: %s\n\r" - "Firmware version: %s\n\rCapacity: %lld sectors\n\r", + "Firmware version: %s\n\rCapacity: " LBAFU " sectors\n\r", pdev->product, pdev->vendor, pdev->revision, pdev->lba); -#else - printf("S/N: %s\n\rProduct model number: %s\n\r" - "Firmware version: %s\n\rCapacity: %ld sectors\n\r", - pdev->product, pdev->vendor, pdev->revision, pdev->lba); -#endif }
static void dwc_ahsata_identify(struct ahci_uc_priv *uc_priv, u16 *id) @@ -754,7 +748,6 @@ static int dwc_ahsata_scan_common(struct ahci_uc_priv *uc_priv, u8 serial[ATA_ID_SERNO_LEN + 1] = { 0 }; u8 firmware[ATA_ID_FW_REV_LEN + 1] = { 0 }; u8 product[ATA_ID_PROD_LEN + 1] = { 0 }; - u64 n_sectors; u8 port = uc_priv->hard_port_no; ALLOC_CACHE_ALIGN_BUFFER(u16, id, ATA_ID_WORDS);
@@ -773,9 +766,8 @@ static int dwc_ahsata_scan_common(struct ahci_uc_priv *uc_priv, ata_id_c_string(id, product, ATA_ID_PROD, sizeof(product)); memcpy(pdev->vendor, product, sizeof(product));
- /* Totoal sectors */ - n_sectors = ata_id_n_sectors(id); - pdev->lba = (u32)n_sectors; + /* Total sectors */ + pdev->lba = ata_id_n_sectors(id);
pdev->type = DEV_TYPE_HARDDISK; pdev->blksz = ATA_SECT_SIZE; -- 2.17.1
Do not report negative sector numbers for disks > 1TB, do not limit sector numbers to 32 bit if CONFIG_SYS_64BIT_LBA is enabled. Signed-off-by: Soeren Moch smoch@web.de
Disable this support for cm_fx6 to avoid breakage.
Signed-off-by: Soeren Moch smoch@web.de --- It would be easy to add weak board_ahci_enable/disable functions which can be overwritten (e.g. in the cm_fx6 board file) to handle power enable/ disable on driver probe/remove. But I have no idea why this board needs these repeated probe/remove calls for the same sata device. In my tests on a tbs2910 board a sata harddisk is always recognized by a 'sata init' command, also without this probe loop. If this can be ironed out, we can remove the DWC_AHSATA_AHCI config option.
Cc: Nikita Kiryanov nikita@compulab.co.il Cc: Stefano Babic sbabic@denx.de Cc: Fabio Estevam festevam@gmail.com Cc: Marcel Ziswiler marcel@ziswiler.com Cc: Stefan Roese sr@denx.de Cc: Simon Glass sjg@chromium.org Cc: u-boot@lists.denx.de --- configs/cm_fx6_defconfig | 1 + drivers/ata/Kconfig | 8 ++++++++ drivers/ata/dwc_ahsata.c | 24 ++++++++++++++++++++++++ 3 files changed, 33 insertions(+)
diff --git a/configs/cm_fx6_defconfig b/configs/cm_fx6_defconfig index c8d1e83111..1623357132 100644 --- a/configs/cm_fx6_defconfig +++ b/configs/cm_fx6_defconfig @@ -51,6 +51,7 @@ CONFIG_DEFAULT_DEVICE_TREE="imx6q-cm-fx6" CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_DWC_AHSATA=y +# CONFIG_DWC_AHSATA_AHCI is not set CONFIG_DM_KEYBOARD=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y diff --git a/drivers/ata/Kconfig b/drivers/ata/Kconfig index 49a056e941..d7818c2d68 100644 --- a/drivers/ata/Kconfig +++ b/drivers/ata/Kconfig @@ -66,6 +66,14 @@ config DWC_AHSATA Enable this driver to support the DWC AHSATA SATA controller found in i.MX5 and i.MX6 SoCs.
+config DWC_AHSATA_AHCI + bool "Enable DWC AHSATA AHCI driver support" + depends on DWC_AHSATA + depends on AHCI + default y + help + Enable this option unless you need your private ahci implementation + config FSL_SATA bool "Enable Freescale SATA controller driver support" select LIBATA diff --git a/drivers/ata/dwc_ahsata.c b/drivers/ata/dwc_ahsata.c index 6fe5641dd9..afced8e7e3 100644 --- a/drivers/ata/dwc_ahsata.c +++ b/drivers/ata/dwc_ahsata.c @@ -16,6 +16,7 @@ #include <asm/io.h> #include <asm/arch/clock.h> #include <asm/arch/sys_proto.h> +#include <asm/mach-imx/sata.h> #include <linux/bitops.h> #include <linux/ctype.h> #include <linux/errno.h> @@ -1020,6 +1021,9 @@ int dwc_ahsata_probe(struct udevice *dev) struct ahci_uc_priv *uc_priv = dev_get_uclass_priv(dev); int ret;
+#if defined(CONFIG_MX6) + setup_sata(); +#endif uc_priv->host_flags = ATA_FLAG_SATA | ATA_FLAG_NO_LEGACY | ATA_FLAG_MMIO | ATA_FLAG_PIO_DMA | ATA_FLAG_NO_ATAPI; uc_priv->mmio_base = (void __iomem *)dev_read_addr(dev); @@ -1067,4 +1071,24 @@ U_BOOT_DRIVER(dwc_ahsata_blk) = { .ops = &dwc_ahsata_blk_ops, };
+#if CONFIG_IS_ENABLED(DWC_AHSATA_AHCI) +struct ahci_ops dwc_ahsata_ahci_ops = { + .port_status = dwc_ahsata_port_status, + .reset = dwc_ahsata_bus_reset, + .scan = dwc_ahsata_scan, +}; + +static const struct udevice_id dwc_ahsata_ahci_ids[] = { + { .compatible = "fsl,imx6q-ahci" }, + { } +}; + +U_BOOT_DRIVER(dwc_ahsata_ahci) = { + .name = "dwc_ahsata_ahci", + .id = UCLASS_AHCI, + .of_match = dwc_ahsata_ahci_ids, + .ops = &dwc_ahsata_ahci_ops, + .probe = dwc_ahsata_probe, +}; +#endif #endif -- 2.17.1
After rebasing this patch series from v2019.04-rc2 to -rc3, I get this:
Matrix U-Boot> sata init
AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl SATA mode
flags: ncq stag pm led clo only pmp pio slum part
Can not start port 0
data abort
pc : [<8ffab37c>] lr : [<8ffab595>]
reloc pc : [<1781837c>] lr : [<17818595>]
sp : 87f909c8 ip : 87f90cd4 fp : 00000004
r10: 6c41202e r9 : 87f90ea0 r8 : 00000000
r7 : 87f90a80 r6 : 00000200 r5 : 00000000 r4 : 87f90a80
r3 : 00000070 r2 : 87f90cc0 r1 : 87f90cc0 r0 : 00000000
Flags: nzcv IRQs off FIQs off Mode SVC_32
Code: fb03231c f8d3030b 9001a00c 9e0c4611 (3038f8da)
Resetting CPU ...
Any idea what got broken here?
Thanks, Soeren
data abort
Resetting CPU ...
This was caused by a bad power supply. So this patch series still works fine on top of v2019.04-rc3.
Sorry for the noise, Soeren
Disable this support for cm_fx6 to avoid breakage. Signed-off-by: Soeren Moch smoch@web.de
While at it, also configure 64-bit LBA support.
Signed-off-by: Soeren Moch smoch@web.de --- Cc: Stefano Babic sbabic@denx.de Cc: Nikita Kiryanov nikita@compulab.co.il Cc: Marcel Ziswiler marcel@ziswiler.com Cc: u-boot@lists.denx.de --- board/tbs/tbs2910/tbs2910.c | 4 ---- configs/tbs2910_defconfig | 1 + include/configs/tbs2910.h | 1 + 3 files changed, 2 insertions(+), 4 deletions(-)
diff --git a/board/tbs/tbs2910/tbs2910.c b/board/tbs/tbs2910/tbs2910.c index 2445efbde2..84c813e29f 100644 --- a/board/tbs/tbs2910/tbs2910.c +++ b/board/tbs/tbs2910/tbs2910.c @@ -10,7 +10,6 @@ #include <linux/errno.h> #include <asm/gpio.h> #include <asm/mach-imx/iomux-v3.h> -#include <asm/mach-imx/sata.h> #include <asm/mach-imx/boot_mode.h> #include <asm/mach-imx/video.h> #include <mmc.h> @@ -374,9 +373,6 @@ int board_init(void) #ifdef CONFIG_VIDEO_IPUV3 setup_display(); #endif -#ifdef CONFIG_DWC_AHSATA - setup_sata(); -#endif #ifdef CONFIG_CMD_BMODE add_board_boot_modes(board_boot_modes); #endif diff --git a/configs/tbs2910_defconfig b/configs/tbs2910_defconfig index 153f61d09d..54e34df6aa 100644 --- a/configs/tbs2910_defconfig +++ b/configs/tbs2910_defconfig @@ -4,6 +4,7 @@ CONFIG_ARCH_MX6=y CONFIG_SYS_TEXT_BASE=0x17800000 CONFIG_TARGET_TBS2910=y CONFIG_CMD_HDMIDETECT=y +CONFIG_AHCI=y CONFIG_NR_DRAM_BANKS=1 CONFIG_BOOTDELAY=3 CONFIG_PRE_CONSOLE_BUFFER=y diff --git a/include/configs/tbs2910.h b/include/configs/tbs2910.h index eff93eff4f..a211b9d611 100644 --- a/include/configs/tbs2910.h +++ b/include/configs/tbs2910.h @@ -77,6 +77,7 @@ #define CONFIG_DWC_AHSATA_PORT_ID 0 #define CONFIG_DWC_AHSATA_BASE_ADDR SATA_ARB_BASE_ADDR #define CONFIG_LBA48 +#define CONFIG_SYS_64BIT_LBA #endif
/* USB */ -- 2.17.1
While at it, also configure 64-bit LBA support. Signed-off-by: Soeren Moch smoch@web.de
Signed-off-by: Soeren Moch smoch@web.de --- Cc: Stefano Babic sbabic@denx.de Cc: u-boot@lists.denx.de --- board/tbs/tbs2910/tbs2910.c | 108 ------------------------------------ configs/tbs2910_defconfig | 1 + include/configs/tbs2910.h | 7 --- 3 files changed, 1 insertion(+), 115 deletions(-)
diff --git a/board/tbs/tbs2910/tbs2910.c b/board/tbs/tbs2910/tbs2910.c index 84c813e29f..fb0e773afc 100644 --- a/board/tbs/tbs2910/tbs2910.c +++ b/board/tbs/tbs2910/tbs2910.c @@ -30,10 +30,6 @@ DECLARE_GLOBAL_DATA_PTR; PAD_CTL_SPEED_MED | PAD_CTL_DSE_40ohm | \ PAD_CTL_SRE_FAST | PAD_CTL_HYS)
-#define USDHC_PAD_CTRL (PAD_CTL_PUS_47K_UP | \ - PAD_CTL_SPEED_LOW | PAD_CTL_DSE_80ohm | \ - PAD_CTL_SRE_FAST | PAD_CTL_HYS) - #define ENET_PAD_CTRL (PAD_CTL_PUS_100K_UP | \ PAD_CTL_SPEED_MED | PAD_CTL_DSE_40ohm | PAD_CTL_HYS)
@@ -103,110 +99,6 @@ static void setup_iomux_uart(void) }
#ifdef CONFIG_FSL_ESDHC -static iomux_v3_cfg_t const usdhc2_pads[] = { - MX6_PAD_SD2_CLK__SD2_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD2_CMD__SD2_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD2_DAT0__SD2_DATA0 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD2_DAT1__SD2_DATA1 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD2_DAT2__SD2_DATA2 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD2_DAT3__SD2_DATA3 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_NANDF_D2__GPIO2_IO02 | MUX_PAD_CTRL(NO_PAD_CTRL), /* CD */ -}; - -static iomux_v3_cfg_t const usdhc3_pads[] = { - MX6_PAD_SD3_CLK__SD3_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD3_CMD__SD3_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD3_DAT0__SD3_DATA0 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD3_DAT1__SD3_DATA1 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD3_DAT2__SD3_DATA2 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD3_DAT3__SD3_DATA3 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_NANDF_D0__GPIO2_IO00 | MUX_PAD_CTRL(NO_PAD_CTRL), /* CD */ -}; - -static iomux_v3_cfg_t const usdhc4_pads[] = { - MX6_PAD_SD4_CLK__SD4_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD4_CMD__SD4_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD4_DAT0__SD4_DATA0 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD4_DAT1__SD4_DATA1 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD4_DAT2__SD4_DATA2 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD4_DAT3__SD4_DATA3 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD4_DAT4__SD4_DATA4 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD4_DAT5__SD4_DATA5 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD4_DAT6__SD4_DATA6 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD4_DAT7__SD4_DATA7 | MUX_PAD_CTRL(USDHC_PAD_CTRL), -}; - -static struct fsl_esdhc_cfg usdhc_cfg[3] = { - {USDHC2_BASE_ADDR}, - {USDHC3_BASE_ADDR}, - {USDHC4_BASE_ADDR}, -}; - -#define USDHC2_CD_GPIO IMX_GPIO_NR(2, 2) -#define USDHC3_CD_GPIO IMX_GPIO_NR(2, 0) - -int board_mmc_getcd(struct mmc *mmc) -{ - struct fsl_esdhc_cfg *cfg = (struct fsl_esdhc_cfg *)mmc->priv; - int ret = 0; - - switch (cfg->esdhc_base) { - case USDHC2_BASE_ADDR: - ret = !gpio_get_value(USDHC2_CD_GPIO); - break; - case USDHC3_BASE_ADDR: - ret = !gpio_get_value(USDHC3_CD_GPIO); - break; - case USDHC4_BASE_ADDR: - ret = 1; /* eMMC/uSDHC4 is always present */ - break; - } - return ret; -} - -int board_mmc_init(bd_t *bis) -{ - /* - * (U-Boot device node) (Physical Port) - * mmc0 SD2 - * mmc1 SD3 - * mmc2 eMMC - */ - int i, ret; - for (i = 0; i < CONFIG_SYS_FSL_USDHC_NUM; i++) { - switch (i) { - case 0: - imx_iomux_v3_setup_multiple_pads( - usdhc2_pads, ARRAY_SIZE(usdhc2_pads)); - gpio_request(USDHC2_CD_GPIO, "MMC0_CD"); - gpio_direction_input(USDHC2_CD_GPIO); - usdhc_cfg[0].sdhc_clk = mxc_get_clock(MXC_ESDHC2_CLK); - break; - case 1: - imx_iomux_v3_setup_multiple_pads( - usdhc3_pads, ARRAY_SIZE(usdhc3_pads)); - gpio_request(USDHC3_CD_GPIO, "MMC1_CD"); - gpio_direction_input(USDHC3_CD_GPIO); - usdhc_cfg[1].sdhc_clk = mxc_get_clock(MXC_ESDHC3_CLK); - break; - case 2: - imx_iomux_v3_setup_multiple_pads( - usdhc4_pads, ARRAY_SIZE(usdhc4_pads)); - usdhc_cfg[2].sdhc_clk = mxc_get_clock(MXC_ESDHC4_CLK); - break; - default: - printf("Warning: you configured more USDHC controllers" - "(%d) then supported by the board (%d)\n", - i + 1, CONFIG_SYS_FSL_USDHC_NUM); - return -EINVAL; - } - ret = fsl_esdhc_initialize(bis, &usdhc_cfg[i]); - if (ret) - return ret; - } - return 0; -} - /* set environment device to boot device when booting from SD */ int board_mmc_get_env_dev(int devno) { diff --git a/configs/tbs2910_defconfig b/configs/tbs2910_defconfig index 54e34df6aa..4d755c88c3 100644 --- a/configs/tbs2910_defconfig +++ b/configs/tbs2910_defconfig @@ -46,6 +46,7 @@ CONFIG_DM_GPIO=y CONFIG_DM_I2C=y CONFIG_SYS_I2C_MXC=y CONFIG_DM_KEYBOARD=y +CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y CONFIG_PHYLIB=y CONFIG_MII=y diff --git a/include/configs/tbs2910.h b/include/configs/tbs2910.h index a211b9d611..f31cadd951 100644 --- a/include/configs/tbs2910.h +++ b/include/configs/tbs2910.h @@ -40,13 +40,6 @@ #define CONFIG_MXC_UART #define CONFIG_MXC_UART_BASE UART1_BASE /* select UART1/UART2 */
-/* Filesystems / image support */ - -/* MMC */ -#define CONFIG_SYS_FSL_USDHC_NUM 3 -#define CONFIG_SYS_FSL_ESDHC_ADDR USDHC4_BASE_ADDR -#define CONFIG_SUPPORT_EMMC_BOOT - /* Ethernet */ #define CONFIG_FEC_MXC #define CONFIG_FEC_MXC -- 2.17.1
sbabic@denx.de
Soeren Moch
Stefano Babic
