[U-Boot] [PATCH] nds32: Support serial DM.
Add device tree source file and enable DM and DM_SERIAL ag101p board can run ns16550 serial DM flow.
Signed-off-by: rick rick@andestech.com Cc: Andes uboot@andestech.com --- arch/Kconfig | 1 + arch/nds32/cpu/n1213/start.S | 13 +++++---- arch/nds32/dts/Makefile | 14 +++++++++ arch/nds32/dts/ag101p.dts | 61 +++++++++++++++++++++++++++++++++++++++ arch/nds32/include/asm/config.h | 1 + configs/adp-ag101p_defconfig | 5 ++++ include/configs/adp-ag101p.h | 8 +++-- 7 files changed, 96 insertions(+), 7 deletions(-) create mode 100644 arch/nds32/dts/Makefile create mode 100644 arch/nds32/dts/ag101p.dts
diff --git a/arch/Kconfig b/arch/Kconfig index d718a68..4c5e4cd 100644 --- a/arch/Kconfig +++ b/arch/Kconfig @@ -42,6 +42,7 @@ config MIPS
config NDS32 bool "NDS32 architecture" + select SUPPORT_OF_CONTROL
config NIOS2 bool "Nios II architecture" diff --git a/arch/nds32/cpu/n1213/start.S b/arch/nds32/cpu/n1213/start.S index 7b2b637..e51bb2b 100644 --- a/arch/nds32/cpu/n1213/start.S +++ b/arch/nds32/cpu/n1213/start.S @@ -179,11 +179,14 @@ update_gp: */ call_board_init_f: li $sp, CONFIG_SYS_INIT_SP_ADDR - li $r10, GD_SIZE /* get GD size */ - sub $sp, $sp, $r10 /* GD start addr */ - move $r10, $sp - li $r0, 0x00000000 - + move $r0, $sp + bal board_init_f_alloc_reserve + move $sp, $r0 + bal board_init_f_init_reserve +#ifdef CONFIG_DEBUG_UART + bal debug_uart_init +#endif + li $r0, 0x00000000 #ifdef __PIC__ #ifdef __NDS32_N1213_43U1H__ /* __NDS32_N1213_43U1H__ implies NDS32 V0 ISA */ diff --git a/arch/nds32/dts/Makefile b/arch/nds32/dts/Makefile new file mode 100644 index 0000000..2d8480b --- /dev/null +++ b/arch/nds32/dts/Makefile @@ -0,0 +1,14 @@ +# +# SPDX-License-Identifier: GPL-2.0+ +# + +dtb-$(CONFIG_TARGET_ADP_AG101P) += ag101p.dtb +targets += $(dtb-y) + +DTC_FLAGS += -R 4 -p 0x1000 + +PHONY += dtbs +dtbs: $(addprefix $(obj)/, $(dtb-y)) + @: + +clean-files := *.dtb diff --git a/arch/nds32/dts/ag101p.dts b/arch/nds32/dts/ag101p.dts new file mode 100644 index 0000000..07f7c98 --- /dev/null +++ b/arch/nds32/dts/ag101p.dts @@ -0,0 +1,61 @@ +/dts-v1/; +/ { + compatible = "nds32 ag101p"; + #address-cells = <1>; + #size-cells = <1>; + interrupt-parent = <&intc>; + + aliases { + uart0 = &serial0; + } ; + + chosen { + /* bootargs = "console=ttyS0,38400n8 earlyprintk=uart8250-32bit,0x99600000 debug bootmem_debug memblock=debug loglevel=7"; */ + bootargs = "console=ttyS0,38400n8 earlyprintk=uart8250-32bit,0x99600000 debug loglevel=7"; + stdout-path = "uart0:38400n8"; + }; + + memory@0 { + device_type = "memory"; + reg = <0x00000000 0x40000000>; + }; + + cpus { + #address-cells = <1>; + #size-cells = <0>; + cpu@0 { + compatible = "andestech,n13"; + reg = <0>; + /* FIXME: to fill correct frqeuency */ + clock-frequency = <60000000>; + }; + }; + + intc: interrupt-controller { + compatible = "andestech,atnointc010"; + #interrupt-cells = <1>; + interrupt-controller; + }; + + serial0: serial@99600000 { + compatible = "andestech,uart16550", "ns16550a"; + reg = <0x99600000 0x1000>; + interrupts = <7 4>; + clock-frequency = <14745600>; + reg-shift = <2>; + no-loopback-test = <1>; + }; + + timer0: timer@98400000 { + compatible = "andestech,attmr010"; + reg = <0x98400000 0x1000>; + interrupts = <19 4>; + clock-frequency = <15000000>; + }; + + mac0: mac@90900000 { + compatible = "andestech,atmac100"; + reg = <0x90900000 0x1000>; + interrupts = <25 4>; + }; +}; diff --git a/arch/nds32/include/asm/config.h b/arch/nds32/include/asm/config.h index 054cc48..7289217 100644 --- a/arch/nds32/include/asm/config.h +++ b/arch/nds32/include/asm/config.h @@ -8,5 +8,6 @@
#ifndef _ASM_CONFIG_H_ #define _ASM_CONFIG_H_ +#define CONFIG_LMB
#endif diff --git a/configs/adp-ag101p_defconfig b/configs/adp-ag101p_defconfig index 0def407..eb46e3f 100644 --- a/configs/adp-ag101p_defconfig +++ b/configs/adp-ag101p_defconfig @@ -1,5 +1,7 @@ CONFIG_NDS32=y CONFIG_TARGET_ADP_AG101P=y +CONFIG_DEFAULT_DEVICE_TREE="ag101p" +CONFIG_FIT=y CONFIG_BOOTDELAY=3 CONFIG_SYS_PROMPT="NDS32 # " CONFIG_CMD_MMC=y @@ -8,4 +10,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_OF_CONTROL=y +CONFIG_DM=y +CONFIG_DM_SERIAL=y CONFIG_SYS_NS16550=y diff --git a/include/configs/adp-ag101p.h b/include/configs/adp-ag101p.h index 5cb79f1..eb8b2d3 100644 --- a/include/configs/adp-ag101p.h +++ b/include/configs/adp-ag101p.h @@ -20,8 +20,6 @@
#define CONFIG_SKIP_LOWLEVEL_INIT
-#define CONFIG_SYS_GENERIC_GLOBAL_DATA - /* * Definitions related to passing arguments to kernel. */ @@ -35,6 +33,10 @@
#ifdef CONFIG_SKIP_LOWLEVEL_INIT #define CONFIG_SYS_TEXT_BASE 0x00500000 +#ifdef CONFIG_OF_CONTROL +#undef CONFIG_OF_SEPARATE +#define CONFIG_OF_EMBED +#endif #else #ifdef CONFIG_MEM_REMAP #define CONFIG_SYS_TEXT_BASE 0x80000000 @@ -88,7 +90,9 @@ #define CONFIG_CONS_INDEX 1 #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_COM1 CONFIG_FTUART010_02_BASE +#ifndef CONFIG_DM_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE -4 +#endif #define CONFIG_SYS_NS16550_CLK ((18432000 * 20) / 25) /* AG101P */
Andes
