[U-Boot] [PATCH v2] Fix cache misalignment after network load operations
After any operation that downloads a file (e.g., pxe get, or dhcp), the buffer containing the downloaded data is flushed. This patch rounds up the flushed size to a cacheline boundary, preventing a cache misalignment message from u-boot.
Signed-off-by: Peter Chubb peter.chubb@data61.csiro.au --- cmd/net.c | 3 --- 1 file changed, 3 deletions(-)
Index: u-boot/cmd/net.c =================================================================== --- u-boot.orig/cmd/net.c 2016-09-07 13:50:46.616156851 +1000 +++ u-boot/cmd/net.c 2016-09-07 19:18:18.962450874 +1000 @@ -243,9 +243,6 @@ static int netboot_common(enum proto_t p return CMD_RET_SUCCESS; }
- /* flush cache */ - flush_cache(load_addr, size); - bootstage_mark(BOOTSTAGE_ID_NET_LOADED);
rcode = bootm_maybe_autostart(cmdtp, argv[0]);
Looks like you missed to update the commit log for v2 as you are no longer flushing the cache :-)
Also, in the Subject line it is always good practice to start with the subsystem name, so something like: net: Remove flush_cache() operation
"Fabio" == Fabio Estevam festevam@gmail.com writes:
Fabio> On Tue, Sep 13, 2016 at 10:30 PM, Peter.Chubb@data61.csiro.au Fabio> wrote:
Fabio> Looks like you missed to update the commit log for v2 as you Fabio> are no longer flushing the cache :-)
Arrgh. Thanks for this -- will respin and resubmit.
Fabio> Also, in the Subject line it is always good practice to start Fabio> with the subsystem name, so something like: net: Remove Fabio> flush_cache() operation
Will do.
Peter C
Fabio Estevam
