[U-Boot] [PATCH] dfu: Disable default calculation of CRC32
Patch (SHA1: bd694244db7bc969954) dfu: Introduction of the "dfu_hash_algo" env variable for checksum method setting
already introduced more generic handling of the crc32 calculation. Up till now the CRC32 of received data was calculated unconditionally. This patch changes this and from now - by default the crc32 is NOT calculated anymore.
Signed-off-by: Lukasz Majewski l.majewski@samsung.com Cc: Marek Vasut marex@denx.de --- drivers/dfu/dfu.c | 20 +++++++------------- 1 file changed, 7 insertions(+), 13 deletions(-)
diff --git a/drivers/dfu/dfu.c b/drivers/dfu/dfu.c index 5878f99..dc09ff6 100644 --- a/drivers/dfu/dfu.c +++ b/drivers/dfu/dfu.c @@ -106,21 +106,15 @@ static char *dfu_get_hash_algo(void) char *s;
s = getenv("dfu_hash_algo"); - /* - * By default the legacy behaviour to calculate the crc32 hash - * value is preserved. - * - * To disable calculation of the hash algorithm for received data - * specify the "dfu_hash_algo = disabled" at your board envs. - */ - debug("%s: DFU hash method: %s\n", __func__, s ? s : "not specified"); - - if (!s || !strcmp(s, "crc32")) - return "crc32"; - - if (!strcmp(s, "disabled")) + if (!s) return NULL;
+ if (!strcmp(s, "crc32")) { + debug("%s: DFU hash method: %s\n", __func__, s); + return s; + } + + error("DFU hash method: %s not supported!\n", s); return NULL; }
Applied, thanks.
Best regards, Marek Vasut
Lukasz Majewski
