[U-Boot] [PATCH v2 1/4] imx: Remove unneeded/repititive definitions from imx headers
Remove gpio related unused/repititive definitions from imx headers.
Signed-off-by: Vikram Narayanan vikram186@gmail.com --- arch/arm/include/asm/arch-mx35/mx35_pins.h | 2 -- arch/arm/include/asm/arch-mx5/mx5x_pins.h | 2 -- arch/arm/include/asm/arch-mx6/imx-regs.h | 2 -- 3 files changed, 0 insertions(+), 6 deletions(-)
diff --git a/arch/arm/include/asm/arch-mx35/mx35_pins.h b/arch/arm/include/asm/arch-mx35/mx35_pins.h index 3676e33..8c38139 100644 --- a/arch/arm/include/asm/arch-mx35/mx35_pins.h +++ b/arch/arm/include/asm/arch-mx35/mx35_pins.h @@ -84,8 +84,6 @@ GPIO_NUM_PIN) + ((pin >> MUX_IO_I) &\ ((1 << (MUX_IO_P - MUX_IO_I)) - 1))) #define IOMUX_TO_IRQ(pin) (MXC_GPIO_INT_BASE + IOMUX_TO_GPIO(pin)) -#define GPIO_TO_PORT(n) (n / GPIO_NUM_PIN) -#define GPIO_TO_INDEX(n) (n % GPIO_NUM_PIN)
#define NON_GPIO_I 0x7 #define PIN_TO_MUX_MASK ((1<<(PAD_I - MUX_I)) - 1) diff --git a/arch/arm/include/asm/arch-mx5/mx5x_pins.h b/arch/arm/include/asm/arch-mx5/mx5x_pins.h index 4e3a31b..122fbee 100644 --- a/arch/arm/include/asm/arch-mx5/mx5x_pins.h +++ b/arch/arm/include/asm/arch-mx5/mx5x_pins.h @@ -78,8 +78,6 @@ GPIO_NUM_PIN) + ((pin >> MUX_IO_I) &\ ((1 << (MUX_IO_P - MUX_IO_I)) - 1))) #define IOMUX_TO_IRQ(pin) (MXC_GPIO_INT_BASE + IOMUX_TO_GPIO(pin)) -#define GPIO_TO_PORT(n) (n / GPIO_NUM_PIN) -#define GPIO_TO_INDEX(n) (n % GPIO_NUM_PIN)
#define NON_GPIO_PORT 0x7 #define PIN_TO_MUX_MASK ((1 << (PAD_I - MUX_I)) - 1) diff --git a/arch/arm/include/asm/arch-mx6/imx-regs.h b/arch/arm/include/asm/arch-mx6/imx-regs.h index cad957a..27ecb75 100644 --- a/arch/arm/include/asm/arch-mx6/imx-regs.h +++ b/arch/arm/include/asm/arch-mx6/imx-regs.h @@ -168,8 +168,6 @@ #define FEC_QUIRK_ENET_MAC
#define GPIO_NUMBER(port, index) ((((port)-1)*32)+((index)&31)) -#define GPIO_TO_PORT(number) (((number)/32)+1) -#define GPIO_TO_INDEX(number) ((number)&31)
#if !(defined(__KERNEL_STRICT_NAMES) || defined(__ASSEMBLY__)) #include <asm/types.h>
Acked-by: Stefano Babic sbabic@denx.de
Best regards, Stefano Babic
Applied to u-boot-imx (fix), thanks.
Stefano Babic
Vikram Narayanan
