ARM: mvebu: enable SPI for helios4 and sata and uart images for clearfog
In an effort to build SPI images for clearfog and helios4 I needed to make some minor changes to the dts and Kconfig for the helios4 and set some variables for UART and SATA images for ClearFog.
Version 2 dropped changes for db-mv784mp-gp as the board turns out to be currently broken, the serial port is not available and the system bails after loading the SPL the dts changes for the helios4 have been shrunk back to remove everything not needed or valid
Dennis
mirror the clearfog setup to enable SPI to work
Signed-off-by: Dennis Gilmore dennis@ausil.us --- arch/arm/mach-mvebu/Kconfig | 1 + board/kobol/helios4/Kconfig | 24 ++++++++++++++++++++++++ configs/helios4_defconfig | 2 -- 3 files changed, 25 insertions(+), 2 deletions(-) create mode 100644 board/kobol/helios4/Kconfig
diff --git a/arch/arm/mach-mvebu/Kconfig b/arch/arm/mach-mvebu/Kconfig index 0d8e0922a2..66fd771dff 100644 --- a/arch/arm/mach-mvebu/Kconfig +++ b/arch/arm/mach-mvebu/Kconfig @@ -293,5 +293,6 @@ config SECURED_MODE_CSK_INDEX depends on SECURED_MODE_IMAGE
source "board/solidrun/clearfog/Kconfig" +source "board/kobol/helios4/Kconfig"
endif diff --git a/board/kobol/helios4/Kconfig b/board/kobol/helios4/Kconfig new file mode 100644 index 0000000000..cad51c1cf0 --- /dev/null +++ b/board/kobol/helios4/Kconfig @@ -0,0 +1,24 @@ +menu "Helios4 configuration" + depends on TARGET_HELIOS4 + +config ENV_SIZE + hex "Environment Size" + default 0x10000 + +config ENV_OFFSET + hex "Environment offset" + default 0xF0000 + +config ENV_SECT_SIZE + hex "Environment Sector-Size" + # Use SPI or SATA flash erase block size of 4 KiB + default 0x1000 if MVEBU_SPL_BOOT_DEVICE_SPI || MVEBU_SPL_BOOT_DEVICE_SATA + # Use optimistic 64 KiB erase block, will vary between actual media + default 0x10000 if MVEBU_SPL_BOOT_DEVICE_MMC || MVEBU_SPL_BOOT_DEVICE_UART + +config SYS_SPI_U_BOOT_OFFS + hex "address of u-boot payload in SPI flash" + default 0x20000 + depends on MVEBU_SPL_BOOT_DEVICE_SPI + +endmenu diff --git a/configs/helios4_defconfig b/configs/helios4_defconfig index eceb85f082..bdc6f43554 100644 --- a/configs/helios4_defconfig +++ b/configs/helios4_defconfig @@ -9,8 +9,6 @@ CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_NR_DRAM_BANKS=2 CONFIG_TARGET_HELIOS4=y CONFIG_MVEBU_SPL_BOOT_DEVICE_MMC=y -CONFIG_ENV_SIZE=0x2000 -CONFIG_ENV_OFFSET=0xFE000 CONFIG_DM_GPIO=y CONFIG_SPL_TEXT_BASE=0x40000030 CONFIG_SPL_SERIAL_SUPPORT=y
Move all aliases defintions into the main dts file Add u-boot definiton to i2c0 based on clearfog set spi1 status to okay
Signed-off-by: Dennis Gilmore dennis@ausil.us --- arch/arm/dts/armada-388-helios4-u-boot.dtsi | 23 ++++++++++++--------- arch/arm/dts/armada-388-helios4.dts | 14 ++++++++++++- 2 files changed, 26 insertions(+), 11 deletions(-)
diff --git a/arch/arm/dts/armada-388-helios4-u-boot.dtsi b/arch/arm/dts/armada-388-helios4-u-boot.dtsi index 0753889854..1047c1af23 100644 --- a/arch/arm/dts/armada-388-helios4-u-boot.dtsi +++ b/arch/arm/dts/armada-388-helios4-u-boot.dtsi @@ -1,13 +1,5 @@ // SPDX-License-Identifier: GPL-2.0+
-/ { - aliases { - i2c0 = &i2c0; - i2c1 = &i2c1; - spi1 = &spi1; - }; -}; - ð0 { phy-reset-gpios = <&gpio0 19 GPIO_ACTIVE_LOW>; }; @@ -20,7 +12,6 @@ };
&w25q32 { - status = "okay"; u-boot,dm-spl; };
@@ -37,5 +28,17 @@ };
&sdhci { - u-boot,dm-spl; + u-boot,dm-spl; +}; + +&i2c0 { + u-boot,dm-spl; + + eeprom@52 { + u-boot,dm-spl; + }; + + eeprom@53 { + u-boot,dm-spl; + }; }; diff --git a/arch/arm/dts/armada-388-helios4.dts b/arch/arm/dts/armada-388-helios4.dts index fb49df2a3b..cbc296a46c 100644 --- a/arch/arm/dts/armada-388-helios4.dts +++ b/arch/arm/dts/armada-388-helios4.dts @@ -22,10 +22,14 @@ };
aliases { - /* So that mvebu u-boot can update the MAC addresses */ + /* So that mvebu u-boot can update the MAC address */ ethernet1 = ð0; + spi1 = &spi1; + i2c0 = &i2c0; + i2c1 = &i2c1; };
+ chosen { stdout-path = "serial0:115200n8"; }; @@ -306,3 +310,11 @@ }; }; }; + +&w25q32 { + status = "okay"; +}; + +&spi1 { + status = "okay"; +};
could I please get someone to review this patch
Dennis
aliases {
i2c0 = &i2c0;
i2c1 = &i2c1;
spi1 = &spi1;
&w25q32 {
&sdhci {
u-boot,dm-spl;
u-boot,dm-spl;
+&i2c0 {
u-boot,dm-spl;
eeprom@52 {
u-boot,dm-spl;
eeprom@53 {
u-boot,dm-spl;
aliases {
spi1 = &spi1;
i2c0 = &i2c0;
i2c1 = &i2c1; };
+&w25q32 {
status = "okay";
+&spi1 {
status = "okay";
2.28.0
Do the changes in armada-388-helios4.dts bring us more in sync with the Linux kernel side? Thanks.
Hi Dennis,
Dennis
It's already included in mainline. I pulled it in a few days ago. Please check if something else is missing.
Thanks, Stefan
aliases {
i2c0 = &i2c0;
i2c1 = &i2c1;
spi1 = &spi1;
&w25q32 {
};status = "okay"; u-boot,dm-spl;
&sdhci {
u-boot,dm-spl;
u-boot,dm-spl;
+&i2c0 {
u-boot,dm-spl;
eeprom@52 {
u-boot,dm-spl;
eeprom@53 {
u-boot,dm-spl;
aliases {
spi1 = &spi1;
i2c0 = &i2c0;
i2c1 = &i2c1; };
+&w25q32 {
status = "okay";
+&spi1 {
status = "okay";
2.28.0
Viele Grüße, Stefan
SATA and UART ClearFog imaages are not buildable as ENV_SECT_SIZE is not defined set values for both possible targets
Signed-off-by: Dennis Gilmore dennis@ausil.us --- board/solidrun/clearfog/Kconfig | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/board/solidrun/clearfog/Kconfig b/board/solidrun/clearfog/Kconfig index e8c3f53d84..cf95258090 100644 --- a/board/solidrun/clearfog/Kconfig +++ b/board/solidrun/clearfog/Kconfig @@ -50,9 +50,9 @@ config ENV_OFFSET config ENV_SECT_SIZE hex "Environment Sector-Size" # Use SPI flash erase block size of 4 KiB - default 0x1000 if MVEBU_SPL_BOOT_DEVICE_SPI + default 0x1000 if MVEBU_SPL_BOOT_DEVICE_SPI || MVEBU_SPL_BOOT_DEVICE_SATA # Use optimistic 64 KiB erase block, will vary between actual media - default 0x10000 if MVEBU_SPL_BOOT_DEVICE_MMC + default 0x10000 if MVEBU_SPL_BOOT_DEVICE_MMC || MVEBU_SPL_BOOT_DEVICE_UART
config SYS_SPI_U_BOOT_OFFS hex "address of u-boot payload in SPI flash"
Hi Dennis,
Could you please test this small patch on the db-mv784mp-gp and report back, if this works:
diff --git a/arch/arm/dts/armada-xp-gp.dts b/arch/arm/dts/armada-xp-gp.dts index 1139e9469a..57abbbba58 100644 --- a/arch/arm/dts/armada-xp-gp.dts +++ b/arch/arm/dts/armada-xp-gp.dts @@ -93,6 +93,7 @@ internal-regs { serial@12000 { status = "okay"; + u-boot,dm-pre-reloc; }; serial@12100 { status = "okay";
Thanks, Stefan
On Wed, Dec 9, 2020 at 7:57 AM Stefan Roese sr@denx.de wrote:
Hi Dennis,
with this dts change the serial port is registered correctly
Dennis
Thanks, Stefan
participants (5)
Dennis Gilmore
Dennis Gilmore
dgilmore@redhat.com
Stefan Roese
