[RESEND PATCH 0/6] arm: dts: k3-am64 / k3-am62: Fix boot
(Apologies for resend as I missed the u-boot list the last time. Thanks Vignesh for catching this :) )
Since commit [1] A53 u-boot proper is broken. This is because nodes marked as 'bootph-pre-ram' are not availble at u-boot proper before relocation.
To fix this we mark all nodes in sk-u-boot.dtsi as 'bootph-all'.
Move cbass_mcu node to -r5-sk.dts as it is only required for R5 SPL.
[1] 9e644284ab812 ("dm: core: Report bootph-pre-ram/sram node as pre-reloc after relocation")
In addition to this we also fix some dts warnings related to CPSW nodes in R5 SPL DTBs.
cheers, -roger
Roger Quadros (6): arm: dts: k3-am64-evm: Fix boot arm: dts: k3-am64-evm: Mark dependent nodes for pre-relocation phase arm: dts: k3-am642-sk: Fix boot arm: dts: k3-am642-sk: Mark dependent nodes for pre-relocation phase arm: dts: k3-am625-sk: Fix boot arm: dts: k3-am625-sk: Mark dependent nodes for pre-relocation phase
arch/arm/dts/k3-am625-sk-u-boot.dtsi | 93 ++++++++++++++------- arch/arm/dts/k3-am642-evm-u-boot.dtsi | 104 ++++++++++++++++-------- arch/arm/dts/k3-am642-r5-evm.dts | 16 ++++ arch/arm/dts/k3-am642-r5-sk.dts | 4 + arch/arm/dts/k3-am642-sk-u-boot.dtsi | 112 +++++++++++++++++--------- 5 files changed, 230 insertions(+), 99 deletions(-)
base-commit: 90c81f407dd4a7747385b10f9b8f732202c45cde
Since commit [1] A53 u-boot proper is broken. This is because nodes marked as 'bootph-pre-ram' are not available at u-boot proper before relocation.
Move vtt_supply and cbass_mcu node to -r5-evm.dts as it is only required for R5 SPL.
Signed-off-by: Roger Quadros rogerq@kernel.org --- arch/arm/dts/k3-am642-evm-u-boot.dtsi | 56 ++++++++++++--------------- arch/arm/dts/k3-am642-r5-evm.dts | 8 ++++ 2 files changed, 32 insertions(+), 32 deletions(-)
diff --git a/arch/arm/dts/k3-am642-evm-u-boot.dtsi b/arch/arm/dts/k3-am642-evm-u-boot.dtsi index c85f57d40f..d06955dfbc 100644 --- a/arch/arm/dts/k3-am642-evm-u-boot.dtsi +++ b/arch/arm/dts/k3-am642-evm-u-boot.dtsi @@ -11,109 +11,101 @@ };
memory@80000000 { - bootph-pre-ram; + bootph-all; }; };
-&vtt_supply { - bootph-pre-ram; -}; - &cbass_main { - bootph-pre-ram; -}; - -&cbass_mcu { - bootph-pre-ram; + bootph-all; };
&main_timer0 { - bootph-pre-ram; + bootph-all; clock-frequency = <200000000>; };
&main_conf { - bootph-pre-ram; + bootph-all; chipid@14 { - bootph-pre-ram; + bootph-all; }; };
&main_pmx0 { - bootph-pre-ram; + bootph-all; };
&main_i2c0_pins_default { - bootph-pre-ram; + bootph-all; };
&main_i2c0 { - bootph-pre-ram; + bootph-all; };
&main_uart0_pins_default { - bootph-pre-ram; + bootph-all; };
&main_uart0 { - bootph-pre-ram; + bootph-all; };
&usb0 { dr_mode="peripheral"; - bootph-pre-ram; + bootph-all; };
&usbss0 { - bootph-pre-ram; + bootph-all; };
&main_mmc1_pins_default { - bootph-pre-ram; + bootph-all; };
&main_usb0_pins_default { - bootph-pre-ram; + bootph-all; };
&dmss { - bootph-pre-ram; + bootph-all; };
&secure_proxy_main { - bootph-pre-ram; + bootph-all; };
&dmsc { - bootph-pre-ram; + bootph-all; k3_sysreset: sysreset-controller { compatible = "ti,sci-sysreset"; - bootph-pre-ram; + bootph-all; }; };
&k3_pds { - bootph-pre-ram; + bootph-all; };
&k3_clks { - bootph-pre-ram; + bootph-all; };
&k3_reset { - bootph-pre-ram; + bootph-all; };
&sdhci0 { - bootph-pre-ram; + bootph-all; };
&sdhci1 { - bootph-pre-ram; + bootph-all; };
&cpsw3g { - bootph-pre-ram; + bootph-all; };
&cpsw_port2 { diff --git a/arch/arm/dts/k3-am642-r5-evm.dts b/arch/arm/dts/k3-am642-r5-evm.dts index 73461f8f6c..696735d8e2 100644 --- a/arch/arm/dts/k3-am642-r5-evm.dts +++ b/arch/arm/dts/k3-am642-r5-evm.dts @@ -40,6 +40,10 @@ }; };
+&vtt_supply { + bootph-pre-ram; +}; + &cbass_main { sysctrler: sysctrler { compatible = "ti,am654-system-controller"; @@ -53,6 +57,10 @@ bootph-pre-ram; };
+&cbass_mcu { + bootph-pre-ram; +}; + &mcu_esm { bootph-pre-ram; };
memory@80000000 {
bootph-pre-ram;
};bootph-all;
-&vtt_supply {
- bootph-pre-ram;
&cbass_main {
- bootph-pre-ram;
-&cbass_mcu {
- bootph-pre-ram;
- bootph-all;
&main_timer0 {
- bootph-pre-ram;
- bootph-all; clock-frequency = <200000000>;
&main_conf {
- bootph-pre-ram;
- bootph-all; chipid@14 {
bootph-pre-ram;
};bootph-all;
&main_pmx0 {
- bootph-pre-ram;
- bootph-all;
- bootph-pre-ram;
- bootph-all;
&main_i2c0 {
- bootph-pre-ram;
- bootph-all;
- bootph-pre-ram;
- bootph-all;
&main_uart0 {
- bootph-pre-ram;
- bootph-all;
- bootph-pre-ram;
- bootph-all;
&usbss0 {
- bootph-pre-ram;
- bootph-all;
- bootph-pre-ram;
- bootph-all;
- bootph-pre-ram;
- bootph-all;
&dmss {
- bootph-pre-ram;
- bootph-all;
- bootph-pre-ram;
- bootph-all;
&dmsc {
- bootph-pre-ram;
- bootph-all; k3_sysreset: sysreset-controller { compatible = "ti,sci-sysreset";
bootph-pre-ram;
};bootph-all;
&k3_pds {
- bootph-pre-ram;
- bootph-all;
&k3_clks {
- bootph-pre-ram;
- bootph-all;
&k3_reset {
- bootph-pre-ram;
- bootph-all;
&sdhci0 {
- bootph-pre-ram;
- bootph-all;
&sdhci1 {
- bootph-pre-ram;
- bootph-all;
&cpsw3g {
- bootph-pre-ram;
- bootph-all;
+&vtt_supply {
- bootph-pre-ram;
+&cbass_mcu {
- bootph-pre-ram;
A bit superfluous, but ok - we just need this atm for esm.
&mcu_esm { bootph-pre-ram; }; -- 2.34.1
Reviewed-by: Nishanth Menon nm@ti.com
Nishanth,
memory@80000000 {
bootph-pre-ram;
};bootph-all;
-&vtt_supply {
- bootph-pre-ram;
&cbass_main {
- bootph-pre-ram;
-&cbass_mcu {
- bootph-pre-ram;
- bootph-all;
&main_timer0 {
- bootph-pre-ram;
&main_conf {
- bootph-pre-ram;
bootph-pre-ram;
};bootph-all;
&main_pmx0 {
- bootph-pre-ram;
- bootph-all;
- bootph-pre-ram;
- bootph-all;
&main_i2c0 {
- bootph-pre-ram;
- bootph-all;
- bootph-pre-ram;
- bootph-all;
&main_uart0 {
- bootph-pre-ram;
- bootph-all;
- bootph-pre-ram;
- bootph-all;
&usbss0 {
- bootph-pre-ram;
- bootph-all;
- bootph-pre-ram;
- bootph-all;
- bootph-pre-ram;
- bootph-all;
&dmss {
- bootph-pre-ram;
- bootph-all;
- bootph-pre-ram;
- bootph-all;
&dmsc {
- bootph-pre-ram;
bootph-pre-ram;
};bootph-all;
&k3_pds {
- bootph-pre-ram;
- bootph-all;
&k3_clks {
- bootph-pre-ram;
- bootph-all;
&k3_reset {
- bootph-pre-ram;
- bootph-all;
&sdhci0 {
- bootph-pre-ram;
- bootph-all;
&sdhci1 {
- bootph-pre-ram;
- bootph-all;
&cpsw3g {
- bootph-pre-ram;
- bootph-all;
+&vtt_supply {
- bootph-pre-ram;
+&cbass_mcu {
- bootph-pre-ram;
Just moved it from -uboot.dtsi to -r5-evm.dts.
Please see suggestion by Massimo here https://lore.kernel.org/all/CAC928HY2rZoz6L8za+L20GAsbJCBYOe+k75L_N3aE-78smn...
Do you agree we should change this series to use bootph-some-ram instead?
On 19:14-20231002, Roger Quadros wrote: [...]
Actually I dont like usage of bootph-some-ram as a hack. We dont have any DDR in the initial stages of R5 SPL. I'd rather stick with bootph-all and pre-ram which is accurate for the staged boot sequence we are following.
Further, boot-ph-all and pre-ram is already the direction we are moving in kernel dts to make syncs easier in the future. unless there is a strong reasoning on an alternate rationale, i'd rather not mess with the flow in play already.
Personally though, I am miffed at a breaking change of this form :(
Signed-off-by: Roger Quadros rogerq@kernel.org Reviewed-by: Nishanth Menon nm@ti.com
For the series, applied to u-boot/master, thanks!
CPSW node needs PHY, MDIO, pinmux, DMA and INTC nodes. USB and MMC nodes need pinmux.
Mark them as 'bootph-all' so they are available in all pre-relocation phases.
Fixes below dts warning:
<stdout>: Warning (dmas_property): /bus@f4000/ethernet@8000000:dmas: Could not get phandle node for (cell 0)
Signed-off-by: Roger Quadros rogerq@kernel.org --- arch/arm/dts/k3-am642-evm-u-boot.dtsi | 48 +++++++++++++++++++++++++++ arch/arm/dts/k3-am642-r5-evm.dts | 8 +++++ 2 files changed, 56 insertions(+)
diff --git a/arch/arm/dts/k3-am642-evm-u-boot.dtsi b/arch/arm/dts/k3-am642-evm-u-boot.dtsi index d06955dfbc..953bbe9aaf 100644 --- a/arch/arm/dts/k3-am642-evm-u-boot.dtsi +++ b/arch/arm/dts/k3-am642-evm-u-boot.dtsi @@ -51,6 +51,10 @@ bootph-all; };
+&main_usb0_pins_default { + bootph-all; +}; + &usb0 { dr_mode="peripheral"; bootph-all; @@ -100,12 +104,56 @@ bootph-all; };
+&main_mmc1_pins_default { + bootph-all; +}; + &sdhci1 { bootph-all; };
+&inta_main_dmss { + bootph-all; +}; + +&main_pktdma { + bootph-all; +}; + +&mdio1_pins_default { + bootph-all; +}; + +&cpsw3g_mdio { + bootph-all; +}; + +&cpsw3g_phy0 { + bootph-all; +}; + +&rgmii1_pins_default { + bootph-all; +}; + +&rgmii2_pins_default { + bootph-all; +}; + &cpsw3g { bootph-all; + + ethernet-ports { + bootph-all; + }; +}; + +&phy_gmii_sel { + bootph-all; +}; + +&cpsw_port1 { + bootph-all; };
&cpsw_port2 { diff --git a/arch/arm/dts/k3-am642-r5-evm.dts b/arch/arm/dts/k3-am642-r5-evm.dts index 696735d8e2..64b3c3af63 100644 --- a/arch/arm/dts/k3-am642-r5-evm.dts +++ b/arch/arm/dts/k3-am642-r5-evm.dts @@ -74,6 +74,14 @@ ti,secure-host; };
+&vtt_supply { + bootph-pre-ram; +}; + +&memorycontroller { + vtt-supply = <&vtt_supply>; +}; + &sdhci0 { clocks = <&clk_200mhz>; clock-names = "clk_xin";
- bootph-all;
- bootph-all;
+&inta_main_dmss {
- bootph-all;
+&main_pktdma {
- bootph-all;
- bootph-all;
+&cpsw3g_mdio {
- bootph-all;
+&cpsw3g_phy0 {
- bootph-all;
- bootph-all;
- bootph-all;
- ethernet-ports {
bootph-all;
+&phy_gmii_sel {
- bootph-all;
+&cpsw_port1 {
- bootph-all;
+&vtt_supply {
- bootph-pre-ram;
- vtt-supply = <&vtt_supply>;
&sdhci0 { clocks = <&clk_200mhz>; clock-names = "clk_xin"; -- 2.34.1
Signed-off-by: Roger Quadros rogerq@kernel.org --- arch/arm/dts/k3-am642-r5-sk.dts | 4 ++ arch/arm/dts/k3-am642-sk-u-boot.dtsi | 76 +++++++++++++--------------- 2 files changed, 40 insertions(+), 40 deletions(-)
diff --git a/arch/arm/dts/k3-am642-r5-sk.dts b/arch/arm/dts/k3-am642-r5-sk.dts index def4622ff1..daa483a781 100644 --- a/arch/arm/dts/k3-am642-r5-sk.dts +++ b/arch/arm/dts/k3-am642-r5-sk.dts @@ -53,6 +53,10 @@ bootph-pre-ram; };
+&cbass_mcu { + bootph-pre-ram; +}; + &mcu_esm { bootph-pre-ram; }; diff --git a/arch/arm/dts/k3-am642-sk-u-boot.dtsi b/arch/arm/dts/k3-am642-sk-u-boot.dtsi index c277ef8aba..5599977f6c 100644 --- a/arch/arm/dts/k3-am642-sk-u-boot.dtsi +++ b/arch/arm/dts/k3-am642-sk-u-boot.dtsi @@ -11,129 +11,125 @@ };
&cbass_main{ - bootph-pre-ram; -}; - -&cbass_mcu { - bootph-pre-ram; + bootph-all; };
&sdhci0 { status = "disabled"; - bootph-pre-ram; + bootph-all; };
ethernet-ports { - bootph-pre-ram; + bootph-all; }; };
&cpsw_port2 { - bootph-pre-ram; + bootph-all; };
&main_bcdma { - bootph-pre-ram; + bootph-all; };
&main_pktdma { - bootph-pre-ram; + bootph-all; };
&rgmii1_pins_default { - bootph-pre-ram; + bootph-all; };
&rgmii2_pins_default { - bootph-pre-ram; + bootph-all; };
&mdio1_pins_default { - bootph-pre-ram; + bootph-all; };
&cpsw3g_phy1 { - bootph-pre-ram; + bootph-all; };
&serdes_ln_ctrl { @@ -141,25 +137,25 @@ };
&usb0 { - bootph-pre-ram; + bootph-all; };
&serdes_wiz0 { - bootph-pre-ram; + bootph-all; };
&serdes0_usb_link { - bootph-pre-ram; + bootph-all; };
&serdes0 { - bootph-pre-ram; + bootph-all; };
&serdes_refclk { - bootph-pre-ram; + bootph-all; };
+&cbass_mcu {
- bootph-pre-ram;
memory@80000000 {
bootph-pre-ram;
};bootph-all;
&cbass_main{
- bootph-pre-ram;
-&cbass_mcu {
- bootph-pre-ram;
- bootph-all;
&main_timer0 {
- bootph-pre-ram;
&main_conf {
- bootph-pre-ram;
bootph-pre-ram;
};bootph-all;
&main_pmx0 {
- bootph-pre-ram;
- bootph-all;
- bootph-pre-ram;
- bootph-all;
&main_i2c0 {
- bootph-pre-ram;
- bootph-all;
- bootph-pre-ram;
- bootph-all;
&main_uart0 {
- bootph-pre-ram;
- bootph-all;
&dmss {
- bootph-pre-ram;
- bootph-all;
- bootph-pre-ram;
- bootph-all;
&dmsc {
- bootph-pre-ram;
bootph-pre-ram;
};bootph-all;
&k3_pds {
- bootph-pre-ram;
- bootph-all;
&k3_clks {
- bootph-pre-ram;
- bootph-all;
&k3_reset {
- bootph-pre-ram;
- bootph-all;
- bootph-pre-ram;
- bootph-all;
&sdhci1 {
- bootph-pre-ram;
- bootph-all;
- bootph-pre-ram;
- bootph-all;
&cpsw3g {
- bootph-pre-ram;
bootph-all;
ethernet-ports {
bootph-pre-ram;
};bootph-all;
&cpsw_port2 {
- bootph-pre-ram;
- bootph-all;
&main_bcdma {
- bootph-pre-ram;
- bootph-all;
&main_pktdma {
- bootph-pre-ram;
- bootph-all;
- bootph-pre-ram;
- bootph-all;
- bootph-pre-ram;
- bootph-all;
- bootph-pre-ram;
- bootph-all;
&cpsw3g_phy1 {
- bootph-pre-ram;
- bootph-all;
- bootph-pre-ram;
- bootph-all;
&usbss0 {
- bootph-pre-ram;
- bootph-all;
&usb0 {
- bootph-pre-ram;
- bootph-all;
&serdes_wiz0 {
- bootph-pre-ram;
- bootph-all;
&serdes0_usb_link {
- bootph-pre-ram;
- bootph-all;
&serdes0 {
- bootph-pre-ram;
- bootph-all;
&serdes_refclk {
- bootph-pre-ram;
- bootph-all;
2.34.1
CPSW node needs PHY, MDIO, pinmux, DMA and INTC nodes. Mark them as 'bootph-all' so they are available in all pre-relocation phases.
Fixes below dts warnings:
<stdout>: Warning (reg_format): /bus@f4000/ethernet@8000000/mdio@f00/ethernet-phy@1:reg: property has invalid length (4 bytes) (#address-cells == 2, #size-cells == 1) <stdout>: Warning (unit_address_vs_reg): /bus@f4000/ethernet@8000000/mdio@f00: node has a unit name, but no reg or ranges property <stdout>: Warning (pci_device_reg): Failed prerequisite 'reg_format' <stdout>: Warning (pci_device_bus_num): Failed prerequisite 'reg_format' <stdout>: Warning (simple_bus_reg): Failed prerequisite 'reg_format' <stdout>: Warning (i2c_bus_reg): Failed prerequisite 'reg_format' <stdout>: Warning (spi_bus_reg): Failed prerequisite 'reg_format' <stdout>: Warning (avoid_default_addr_size): /bus@f4000/ethernet@8000000/mdio@f00/ethernet-phy@1: Relying on default #address-cells value <stdout>: Warning (avoid_default_addr_size): /bus@f4000/ethernet@8000000/mdio@f00/ethernet-phy@1: Relying on default #size-cells value <stdout>: Warning (avoid_unnecessary_addr_size): Failed prerequisite 'avoid_default_addr_size' <stdout>: Warning (unique_unit_address): Failed prerequisite 'avoid_default_addr_size' <stdout>: Warning (msi_parent_property): /bus@f4000/bus@48000000/dma-controller@485c0100:msi-parent: Could not get phandle node for (cell 0) <stdout>: Warning (msi_parent_property): /bus@f4000/bus@48000000/dma-controller@485c0000:msi-parent: Could not get phandle node for (cell 0) <stdout>: Warning (phys_property): /bus@f4000/ethernet@8000000/ethernet-ports/port@2:phys: Could not get phandle node for (cell 0)
Signed-off-by: Roger Quadros rogerq@kernel.org --- arch/arm/dts/k3-am642-sk-u-boot.dtsi | 36 ++++++++++++++++++++++++++++ 1 file changed, 36 insertions(+)
diff --git a/arch/arm/dts/k3-am642-sk-u-boot.dtsi b/arch/arm/dts/k3-am642-sk-u-boot.dtsi index 5599977f6c..40a53df0b0 100644 --- a/arch/arm/dts/k3-am642-sk-u-boot.dtsi +++ b/arch/arm/dts/k3-am642-sk-u-boot.dtsi @@ -92,6 +92,38 @@ bootph-all; };
+&inta_main_dmss { + bootph-all; +}; + +&main_pktdma { + bootph-all; +}; + +&mdio1_pins_default { + bootph-all; +}; + +&cpsw3g_mdio { + bootph-all; +}; + +&cpsw3g_phy0 { + bootph-all; +}; + +&cpsw3g_phy1 { + bootph-all; +}; + +&rgmii1_pins_default { + bootph-all; +}; + +&rgmii2_pins_default { + bootph-all; +}; + &cpsw3g { bootph-all;
@@ -100,6 +132,10 @@ }; };
+&phy_gmii_sel { + bootph-all; +}; + &cpsw_port2 { bootph-all; };
+&inta_main_dmss {
- bootph-all;
+&main_pktdma {
- bootph-all;
- bootph-all;
+&cpsw3g_mdio {
- bootph-all;
+&cpsw3g_phy0 {
- bootph-all;
+&cpsw3g_phy1 {
- bootph-all;
- bootph-all;
- bootph-all;
+&phy_gmii_sel {
- bootph-all;
&cpsw_port2 { bootph-all; }; -- 2.34.1
Signed-off-by: Roger Quadros rogerq@kernel.org --- arch/arm/dts/k3-am625-sk-u-boot.dtsi | 54 ++++++++++++++-------------- 1 file changed, 27 insertions(+), 27 deletions(-)
diff --git a/arch/arm/dts/k3-am625-sk-u-boot.dtsi b/arch/arm/dts/k3-am625-sk-u-boot.dtsi index c1685bc9ca..c658506256 100644 --- a/arch/arm/dts/k3-am625-sk-u-boot.dtsi +++ b/arch/arm/dts/k3-am625-sk-u-boot.dtsi @@ -17,113 +17,113 @@ };
&cbass_main { - bootph-pre-ram; + bootph-all; };
&main_timer0 { clock-frequency = <25000000>; - bootph-pre-ram; + bootph-all; };
&dmsc { - bootph-pre-ram; + bootph-all; };
&wkup_conf { - bootph-pre-ram; + bootph-all; };
&chipid { - bootph-pre-ram; + bootph-all; };
&cbass_wakeup { - bootph-pre-ram; + bootph-all; };
&mcu_pmx0 { - bootph-pre-ram; + bootph-all; };
&fss { - bootph-pre-ram; + bootph-all; };
&ospi0_pins_default { - bootph-pre-ram; + bootph-all; };
&ospi0 { - bootph-pre-ram; + bootph-all;
flash@0 { - bootph-pre-ram; + bootph-all;
partitions { - bootph-pre-ram; + bootph-all;
partition@3fc0000 { - bootph-pre-ram; + bootph-all; }; }; }; };
&cpsw_port1 { - bootph-pre-ram; + bootph-all; };
&cpsw_port2 {
memory@80000000 {
bootph-pre-ram;
};bootph-all;
&cbass_main {
- bootph-pre-ram;
- bootph-all;
- bootph-pre-ram;
- bootph-all;
&dmss {
- bootph-pre-ram;
- bootph-all;
- bootph-pre-ram;
- bootph-all;
&dmsc {
- bootph-pre-ram;
- bootph-all;
&k3_pds {
- bootph-pre-ram;
- bootph-all;
&k3_clks {
- bootph-pre-ram;
- bootph-all;
&k3_reset {
- bootph-pre-ram;
- bootph-all;
&wkup_conf {
- bootph-pre-ram;
- bootph-all;
&chipid {
- bootph-pre-ram;
- bootph-all;
&main_pmx0 {
- bootph-pre-ram;
- bootph-all;
&main_uart0 {
- bootph-pre-ram;
- bootph-all;
- bootph-pre-ram;
- bootph-all;
&cbass_mcu {
- bootph-pre-ram;
- bootph-all;
&cbass_wakeup {
- bootph-pre-ram;
- bootph-all;
&mcu_pmx0 {
- bootph-pre-ram;
- bootph-all;
&sdhci1 {
- bootph-pre-ram;
- bootph-all;
- bootph-pre-ram;
- bootph-all;
&fss {
- bootph-pre-ram;
- bootph-all;
- bootph-pre-ram;
- bootph-all;
&ospi0 {
- bootph-pre-ram;
bootph-all;
flash@0 {
bootph-pre-ram;
bootph-all;
partitions {
bootph-pre-ram;
bootph-all; partition@3fc0000 {
bootph-pre-ram;
}; };bootph-all; };
&cpsw3g {
- bootph-pre-ram;
- bootph-all;
&cpsw_port1 {
- bootph-pre-ram;
- bootph-all;
&cpsw_port2 {
2.34.1
CPSW node needs PHY, MDIO, pinmux, DMA and INTC nodes. main_conf is required for phy_gmii_sel. Mark them as 'bootph-all' so they are available in all pre-relocation phases.
Fixes the below dts warnings:
<stdout>: Warning (reg_format): /bus@f0000/syscon@100000/phy@4044:reg: property has invalid length (8 bytes) (#address-cells == 2, #size-cells == 1) <stdout>: Warning (reg_format): /bus@f0000/ethernet@8000000/ethernet-ports/port@1:reg: property has invalid length (4 bytes) (#address-cells == 2, #size-cells == 1) <stdout>: Warning (unit_address_vs_reg): /bus@f0000/syscon@100000: node has a unit name, but no reg or ranges property <stdout>: Warning (pci_device_reg): Failed prerequisite 'reg_format' <stdout>: Warning (pci_device_bus_num): Failed prerequisite 'reg_format' <stdout>: Warning (simple_bus_reg): Failed prerequisite 'reg_format' <stdout>: Warning (i2c_bus_reg): Failed prerequisite 'reg_format' <stdout>: Warning (spi_bus_reg): Failed prerequisite 'reg_format' <stdout>: Warning (avoid_default_addr_size): /bus@f0000/syscon@100000/phy@4044: Relying on default #address-cells value <stdout>: Warning (avoid_default_addr_size): /bus@f0000/syscon@100000/phy@4044: Relying on default #size-cells value <stdout>: Warning (avoid_default_addr_size): /bus@f0000/ethernet@8000000/ethernet-ports/port@1: Relying on default #address-cells value <stdout>: Warning (avoid_default_addr_size): /bus@f0000/ethernet@8000000/ethernet-ports/port@1: Relying on default #size-cells value <stdout>: Warning (avoid_unnecessary_addr_size): Failed prerequisite 'avoid_default_addr_size' <stdout>: Warning (unique_unit_address): Failed prerequisite 'avoid_default_addr_size'
Signed-off-by: Roger Quadros rogerq@kernel.org --- arch/arm/dts/k3-am625-sk-u-boot.dtsi | 39 ++++++++++++++++++++++++++++ 1 file changed, 39 insertions(+)
diff --git a/arch/arm/dts/k3-am625-sk-u-boot.dtsi b/arch/arm/dts/k3-am625-sk-u-boot.dtsi index c658506256..b78d34b459 100644 --- a/arch/arm/dts/k3-am625-sk-u-boot.dtsi +++ b/arch/arm/dts/k3-am625-sk-u-boot.dtsi @@ -21,6 +21,10 @@ }; };
+&main_conf { + bootph-all; +}; + &cbass_main { bootph-all; }; @@ -118,8 +122,43 @@ }; };
+&inta_main_dmss { + bootph-all; +}; + +&main_pktdma { + bootph-all; +}; + +&cpsw3g_mdio { + bootph-all; +}; + +&cpsw3g_phy0 { + bootph-all; +}; + +&cpsw3g_phy1 { + bootph-all; +}; + +&main_rgmii1_pins_default { + bootph-all; +}; + +&main_rgmii2_pins_default { + bootph-all; +}; + +&phy_gmii_sel { + bootph-all; +}; + &cpsw3g { bootph-all; + ethernet-ports { + bootph-all; + }; };
&cpsw_port1 {
+&main_conf {
- bootph-all;
+&inta_main_dmss {
- bootph-all;
+&main_pktdma {
- bootph-all;
+&cpsw3g_mdio {
- bootph-all;
+&cpsw3g_phy0 {
- bootph-all;
+&cpsw3g_phy1 {
- bootph-all;
- bootph-all;
- bootph-all;
+&phy_gmii_sel {
- bootph-all;
- ethernet-ports {
bootph-all;
&cpsw_port1 {
2.34.1
To fix this we mark all nodes as 'bootph-all'.
Signed-off-by: Jan Kiszka jan.kiszka@siemens.com ---
This may overshoot, but at least the board boots again. Could it be that [1] broke even more boards?
arch/arm/dts/k3-am625-beagleplay-u-boot.dtsi | 70 ++++++++++---------- arch/arm/dts/k3-am625-r5-beagleplay.dts | 12 ++-- 2 files changed, 41 insertions(+), 41 deletions(-)
diff --git a/arch/arm/dts/k3-am625-beagleplay-u-boot.dtsi b/arch/arm/dts/k3-am625-beagleplay-u-boot.dtsi index f8c04e8a300..d6c6baa5518 100644 --- a/arch/arm/dts/k3-am625-beagleplay-u-boot.dtsi +++ b/arch/arm/dts/k3-am625-beagleplay-u-boot.dtsi @@ -14,143 +14,143 @@ }; memory@80000000 { - bootph-pre-ram; + bootph-all; }; /* Keep the LEDs on by default to indicate life */ leds { - bootph-pre-ram; + bootph-all; led-0 { default-state = "on"; - bootph-pre-ram; + bootph-all; }; led-1 { default-state = "on"; - bootph-pre-ram; + bootph-all; }; led-2 { default-state = "on"; - bootph-pre-ram; + bootph-all; }; led-3 { default-state = "on"; - bootph-pre-ram; + bootph-all; }; led-4 { default-state = "on"; - bootph-pre-ram; + bootph-all; }; }; }; &cbass_main { - bootph-pre-ram; + bootph-all; }; &main_timer0 { clock-frequency = <25000000>; - bootph-pre-ram; + bootph-all; }; &dmss { - bootph-pre-ram; + bootph-all; }; &secure_proxy_main { - bootph-pre-ram; + bootph-all; }; &dmsc { - bootph-pre-ram; + bootph-all; }; &k3_pds { - bootph-pre-ram; + bootph-all; }; &k3_clks { - bootph-pre-ram; + bootph-all; }; &k3_reset { - bootph-pre-ram; + bootph-all; }; &dmsc { - bootph-pre-ram; + bootph-all; k3_sysreset: sysreset-controller { compatible = "ti,sci-sysreset"; - bootph-pre-ram; + bootph-all; }; }; &wkup_conf { - bootph-pre-ram; + bootph-all; }; &chipid { - bootph-pre-ram; + bootph-all; }; &main_pmx0 { - bootph-pre-ram; + bootph-all; }; &main_uart0 { - bootph-pre-ram; + bootph-all; }; &console_pins_default { - bootph-pre-ram; + bootph-all; }; &cbass_mcu { - bootph-pre-ram; + bootph-all; }; &cbass_wakeup { - bootph-pre-ram; + bootph-all; }; &mcu_pmx0 { - bootph-pre-ram; + bootph-all; }; &main_i2c0 { - bootph-pre-ram; + bootph-all; }; &local_i2c_pins_default { - bootph-pre-ram; + bootph-all; }; &gpio0_pins_default { - bootph-pre-ram; + bootph-all; }; &main_gpio0 { - bootph-pre-ram; + bootph-all; }; &main_gpio1 { - bootph-pre-ram; + bootph-all; }; &sdhci0 { /* EMMC */ - bootph-pre-ram; + bootph-all; }; &emmc_pins_default { - bootph-pre-ram; + bootph-all; }; &sd_pins_default { - bootph-pre-ram; + bootph-all; /* Force to use SDCD card detect pin */ pinctrl-single,pins = < AM62X_IOPAD(0x023c, PIN_INPUT, 0) /* (A21) MMC1_CMD */ @@ -164,11 +164,11 @@ }; &tps65219 { - bootph-pre-ram; + bootph-all; }; &sdhci1 { - bootph-pre-ram; + bootph-all; }; #ifdef CONFIG_TARGET_AM625_A53_EVM diff --git a/arch/arm/dts/k3-am625-r5-beagleplay.dts b/arch/arm/dts/k3-am625-r5-beagleplay.dts index 9c9d0570592..ac5461a32c0 100644 --- a/arch/arm/dts/k3-am625-r5-beagleplay.dts +++ b/arch/arm/dts/k3-am625-r5-beagleplay.dts @@ -31,7 +31,7 @@ ti,sci = <&dmsc>; ti,sci-proc-id = <32>; ti,sci-host-id = <10>; - bootph-pre-ram; + bootph-all; }; dm_tifs: dm-tifs { @@ -41,7 +41,7 @@ mbox-names = "rx", "tx"; mboxes= <&secure_proxy_main 22>, <&secure_proxy_main 23>; - bootph-pre-ram; + bootph-all; }; }; @@ -55,11 +55,11 @@ }; &mcu_esm { - bootph-pre-ram; + bootph-all; }; &secure_proxy_sa3 { - bootph-pre-ram; + bootph-all; /* We require this for boot handshake */ status = "okay"; }; @@ -69,12 +69,12 @@ compatible = "ti,am654-system-controller"; mboxes= <&secure_proxy_main 1>, <&secure_proxy_main 0>, <&secure_proxy_sa3 0>; mbox-names = "tx", "rx", "boot_notify"; - bootph-pre-ram; + bootph-all; }; }; &main_esm { - bootph-pre-ram; + bootph-all; }; &main_pktdma {
Hi Jan,
Nishanth already send a fix earlier https://lore.kernel.org/all/20231002150053.2930710-1-nm@ti.com/
Jan: https://lore.kernel.org/all/b1c62a7d-a90e-4212-8972-9b622e147975@kernel.org/
I got boot without r5-beagleplay.dts modified. and it is in line with the changes in linux-next commit 944adefc7f88 ("arm64: dts: ti: k3-am625-beagleplay: Add boot phase tags marking")
bootph-pre-ram;
}; /* Keep the LEDs on by default to indicate life */ leds {bootph-all;
bootph-pre-ram;
led-0 { default-state = "on";bootph-all;
bootph-pre-ram;
}; led-1 { default-state = "on";bootph-all;
bootph-pre-ram;
}; led-2 { default-state = "on";bootph-all;
bootph-pre-ram;
}; led-3 { default-state = "on";bootph-all;
bootph-pre-ram;
}; led-4 { default-state = "on";bootph-all;
bootph-pre-ram;
}; };bootph-all;
}; &cbass_main {
- bootph-pre-ram;
- bootph-all;
- bootph-pre-ram;
- bootph-all;
}; &dmss {
- bootph-pre-ram;
- bootph-all;
- bootph-pre-ram;
- bootph-all;
}; &dmsc {
- bootph-pre-ram;
- bootph-all;
}; &k3_pds {
- bootph-pre-ram;
- bootph-all;
}; &k3_clks {
- bootph-pre-ram;
- bootph-all;
}; &k3_reset {
- bootph-pre-ram;
- bootph-all;
}; &dmsc {
- bootph-pre-ram;
bootph-pre-ram;
};bootph-all;
}; &wkup_conf {
- bootph-pre-ram;
- bootph-all;
}; &chipid {
- bootph-pre-ram;
- bootph-all;
}; &main_pmx0 {
- bootph-pre-ram;
- bootph-all;
}; &main_uart0 {
- bootph-pre-ram;
- bootph-all;
- bootph-pre-ram;
- bootph-all;
}; &cbass_mcu {
- bootph-pre-ram;
- bootph-all;
}; &cbass_wakeup {
- bootph-pre-ram;
- bootph-all;
}; &mcu_pmx0 {
- bootph-pre-ram;
- bootph-all;
}; &main_i2c0 {
- bootph-pre-ram;
- bootph-all;
- bootph-pre-ram;
- bootph-all;
- bootph-pre-ram;
- bootph-all;
}; &main_gpio0 {
- bootph-pre-ram;
- bootph-all;
}; &main_gpio1 {
- bootph-pre-ram;
- bootph-all;
- bootph-pre-ram;
- bootph-all;
- bootph-pre-ram;
- bootph-all;
- bootph-pre-ram;
- bootph-all; /* Force to use SDCD card detect pin */ pinctrl-single,pins = < AM62X_IOPAD(0x023c, PIN_INPUT, 0) /* (A21) MMC1_CMD */
- bootph-pre-ram;
- bootph-all;
}; &sdhci1 {
- bootph-pre-ram;
- bootph-all;
bootph-pre-ram;
}; dm_tifs: dm-tifs {bootph-all;
bootph-pre-ram;
};bootph-all;
- bootph-pre-ram;
- bootph-all;
- bootph-pre-ram;
- bootph-all; /* We require this for boot handshake */ status = "okay";
bootph-pre-ram;
};bootph-all;
}; &main_esm {
- bootph-pre-ram;
- bootph-all;
}; &main_pktdma { -- 2.35.3
Yeah, no problem, missed that.
Meanwhile, I can fix our IOT2050 because I was unfortunatenly right: more havoc in sight. Did anyone tried to look at the fallouts systematically already? Is it only affecting the TI family?
Jan
I know all of TI K3 platforms are broken, but I don't think (based on discussions on the list so far), anyone actually went around non-TI platforms to identify the ones that are broken.
Well, I'm pretty confused right now. The visible breakage has been traced back to a commit that was in -next and is fine on my J721E EVM and is fine on my AM65x EVM. I can't figure out where my Beagleplay ended up, so I can't check that one as easily. But given how the breakage is described, mine too should be failing. But they aren't. In both cases, I have the GP versions of the chips, and am booting the unsigned files.
OK, I think I might have solved my own unexpected success here in that it seems like I had the wrong files being copied to the device and so that somehow ended up working. I have replicated failure finally.
-- Tom
Jan Kiszka
Nishanth Menon
Roger Quadros
