[U-Boot] [PATCH] pmic: ltc3676: add regulator config function
Add a convenience function for configuring the most common characteristics of an LTC3676 buck regulator.
Signed-off-by: Tim Harvey tharvey@gateworks.com --- drivers/power/pmic/pmic_ltc3676.c | 16 ++++++++++++++++ include/power/ltc3676_pmic.h | 40 +++++++++++++++++++++++++++++++++++++++ 2 files changed, 56 insertions(+)
diff --git a/drivers/power/pmic/pmic_ltc3676.c b/drivers/power/pmic/pmic_ltc3676.c index 9b874cb..af795ea 100644 --- a/drivers/power/pmic/pmic_ltc3676.c +++ b/drivers/power/pmic/pmic_ltc3676.c @@ -30,3 +30,19 @@ int power_ltc3676_init(unsigned char bus)
return 0; } + +void power_ltc3676_swconfig(struct pmic *p, enum ltc3676_sw sw, + enum ltc3676_mode mode, enum ltc3676_phase phase, + enum ltc3676_freq freq) +{ + u32 reg; + + pmic_reg_read(p, LTC3676_BUCK1 + sw, ®); + reg &= ~LTC3676_MODE_MASK; + reg |= (mode << LTC3676_MODE); + reg &= ~(1 << LTC3676_PHASE); + reg |= (phase << LTC3676_PHASE); + reg &= ~(1 << LTC3676_FREQ); + reg |= (freq << LTC3676_FREQ); + pmic_reg_write(p, LTC3676_BUCK1 + sw, reg); +} diff --git a/include/power/ltc3676_pmic.h b/include/power/ltc3676_pmic.h index dcaa985..f5b0f3c 100644 --- a/include/power/ltc3676_pmic.h +++ b/include/power/ltc3676_pmic.h @@ -42,10 +42,50 @@ enum { * SW Configuration */
+/* DVB<x> registers */ #define LTC3676_DVB_MASK 0x1f #define LTC3676_PGOOD_MASK (1<<5) #define LTC3676_REF_SELA (0<<5) #define LTC3676_REF_SELB (1<<5)
+/* BUCK<x> registers */ +#define LTC3676_MODE_MASK 0x60 +#define LTC3676_MODE 5 +#define LTC3676_STARTUP 4 +#define LTC3676_PHASE 3 +#define LTC3676_FREQ 2 +#define LTC3676_KEEPALIVE 1 +#define LTC3676_RATE 0 + +enum ltc3676_sw { + SW1 = 0, + SW2 = 1, + SW3 = 2, + SW4 = 3 +}; + +enum ltc3676_mode { + PFM = 0, /* pulse-skipping */ + APF = 1, /* burst - auto switches */ + PWM = 2, /* forced continuous */ +}; + +enum ltc3676_phase { + PHASE1 = 0, + PHASE2 = 1, +}; + +enum ltc3676_freq { + F2250KHZ = 0, + F1125KHZ = 1, +}; + +enum ltc3676_rate { + SLOW = 0, + FAST = 1, +}; + int power_ltc3676_init(unsigned char bus); +void power_ltc3676_swconfig(struct pmic *, enum ltc3676_sw, enum ltc3676_mode, + enum ltc3676_phase, enum ltc3676_freq); #endif
I didn't know where this is used.
return 0; }
As i mentioned above, this function doesn't call anywhere.. Well, if i missed some your patches, let me know, plz.
- u32 reg;
- pmic_reg_read(p, LTC3676_BUCK1 + sw, ®);
- reg &= ~LTC3676_MODE_MASK;
- reg |= (mode << LTC3676_MODE);
- reg &= ~(1 << LTC3676_PHASE);
For clearing bit, use the macro..
- reg |= (phase << LTC3676_PHASE);
- reg &= ~(1 << LTC3676_FREQ);
- reg |= (freq << LTC3676_FREQ);
- pmic_reg_write(p, LTC3676_BUCK1 + sw, reg);
- SW Configuration
Use the bit API.. #define LTC3676_MODE BIT(5) #define LTC3676_STARTUP BIT(4) ...
Then you can change the code in power_ltc3676_swconfig().
Best Regards, Jaehoon Chung
+enum ltc3676_sw {
- SW1 = 0,
- SW2 = 1,
- SW3 = 2,
- SW4 = 3
- PFM = 0, /* pulse-skipping */
- APF = 1, /* burst - auto switches */
- PWM = 2, /* forced continuous */
- PHASE1 = 0,
- PHASE2 = 1,
- F2250KHZ = 0,
- F1125KHZ = 1,
- SLOW = 0,
- FAST = 1,
#endif
Hi Jaehoon,
I'm going to use it for the IMX6 based Gateworks Ventana boards to put the switching regulators in continuous PWM mode. So no users yet... as soon as its acceptable I'll send a board-support patch that uses it though:
diff --git a/board/gateworks/gw_ventana/common.c b/board/gateworks/gw_ventana/common.c index 56a7b3e..8061c29 100644 --- a/board/gateworks/gw_ventana/common.c +++ b/board/gateworks/gw_ventana/common.c @@ -1350,6 +1350,12 @@ void setup_pmic(void) /* set SW3 (VDD_ARM) */ pmic_reg_write(p, LTC3676_DVB3A, 0x1f); } + + /* Use continuous PWM mode, 1Mhz on all regulators */ + power_ltc3676_swconfig(p, SW1, PWM, PHASE1, F1125KHZ); + power_ltc3676_swconfig(p, SW2, PWM, PHASE1, F1125KHZ); + power_ltc3676_swconfig(p, SW3, PWM, PHASE1, F1125KHZ); + power_ltc3676_swconfig(p, SW4, PWM, PHASE1, F1125KHZ); } }
u32 reg;
- SW Configuration
ok - I will submit a v2
Thanks,
Tim
Jaehoon Chung
Tim Harvey
