[U-Boot] [PATCH 0/3] ARM: atmel: add sama5d4ek board support
This patch series add sama5d4ek board support which supports following features: - Boot media support: NAND flash/SD card/SPI flash - Support LCD display - Support ethernet - Support USB mass storage
This patch series depends on the series [1]: ARM: atmel: use pcr to enable or disable peripheral clock.
[1] http://patchwork.ozlabs.org/patch/376960/
Bo Shen (2): net: macb: enable GMAC IP without GE feature support ARM: atmel: add sama5d4ek board support
Josh Wu (1): atmel_nand: if don't have gf table in rom code we will build it runtime
arch/arm/Kconfig | 4 + arch/arm/cpu/armv7/at91/timer.c | 3 +- arch/arm/include/asm/arch-at91/at91_pmc.h | 6 +- arch/arm/include/asm/arch-at91/clk.h | 29 +++ arch/arm/include/asm/arch-at91/hardware.h | 2 + arch/arm/include/asm/arch-at91/sama5d4.h | 199 ++++++++++++++++++ board/atmel/sama5d4ek/Kconfig | 18 ++ board/atmel/sama5d4ek/MAINTAINERS | 8 + board/atmel/sama5d4ek/Makefile | 15 ++ board/atmel/sama5d4ek/sama5d4ek.c | 322 ++++++++++++++++++++++++++++++ configs/sama5d4ek_mmc_defconfig | 3 + configs/sama5d4ek_nandflash_defconfig | 3 + configs/sama5d4ek_spiflash_defconfig | 3 + drivers/mtd/nand/atmel_nand.c | 127 +++++++++++- drivers/net/macb.c | 8 +- include/configs/sama5d4ek.h | 215 ++++++++++++++++++++ 16 files changed, 959 insertions(+), 6 deletions(-) create mode 100644 arch/arm/include/asm/arch-at91/sama5d4.h create mode 100644 board/atmel/sama5d4ek/Kconfig create mode 100644 board/atmel/sama5d4ek/MAINTAINERS create mode 100644 board/atmel/sama5d4ek/Makefile create mode 100644 board/atmel/sama5d4ek/sama5d4ek.c create mode 100644 configs/sama5d4ek_mmc_defconfig create mode 100644 configs/sama5d4ek_nandflash_defconfig create mode 100644 configs/sama5d4ek_spiflash_defconfig create mode 100644 include/configs/sama5d4ek.h
Add a macro NO_GALOIS_TABLE_IN_ROM. If it is defined we will build a runtime pmecc galois table.
Signed-off-by: Josh Wu josh.wu@atmel.com Signed-off-by: Bo Shen voice.shen@atmel.com ---
drivers/mtd/nand/atmel_nand.c | 127 +++++++++++++++++++++++++++++++++++++++++- 1 file changed, 126 insertions(+), 1 deletion(-)
diff --git a/drivers/mtd/nand/atmel_nand.c b/drivers/mtd/nand/atmel_nand.c index e73834d..7cf7b39 100644 --- a/drivers/mtd/nand/atmel_nand.c +++ b/drivers/mtd/nand/atmel_nand.c @@ -761,6 +761,108 @@ static int pmecc_choose_ecc(struct atmel_nand_host *host, } #endif
+#if defined(NO_GALOIS_TABLE_IN_ROM) +static uint16_t *pmecc_galois_table; +static int pmecc_build_galois_table(unsigned int mm, + int16_t *index_of, int16_t *alpha_to) +{ + unsigned int i, mask, nn; + unsigned int p[15]; + + nn = (1 << mm) - 1; + /* set default value */ + for (i = 1; i < mm; i++) + p[i] = 0; + + /* 1 + X^mm */ + p[0] = 1; + p[mm] = 1; + + /* others */ + switch (mm) { + case 3: + case 4: + case 6: + case 15: + p[1] = 1; + break; + case 5: + case 11: + p[2] = 1; + break; + case 7: + case 10: + p[3] = 1; + break; + case 8: + p[2] = 1; + p[3] = 1; + p[4] = 1; + break; + case 9: + p[4] = 1; + break; + case 12: + p[1] = 1; + p[4] = 1; + p[6] = 1; + break; + case 13: + p[1] = 1; + p[3] = 1; + p[4] = 1; + break; + case 14: + p[1] = 1; + p[6] = 1; + p[10] = 1; + break; + default: + /* Error */ + return -EINVAL; + } + + /* Build alpha ^ mm it will help to generate the field (primitiv) */ + alpha_to[mm] = 0; + for (i = 0; i < mm; i++) + if (p[i]) + alpha_to[mm] |= 1 << i; + + /* + * Then build elements from 0 to mm - 1. As degree is less than mm + * so it is just a logical shift. + */ + mask = 1; + for (i = 0; i < mm; i++) { + alpha_to[i] = mask; + index_of[alpha_to[i]] = i; + mask <<= 1; + } + + index_of[alpha_to[mm]] = mm; + + /* use a mask to select the MSB bit of the LFSR */ + mask >>= 1; + + /* then finish the building */ + for (i = mm + 1; i <= nn; i++) { + /* check if the msb bit of the lfsr is set */ + if (alpha_to[i - 1] & mask) + alpha_to[i] = alpha_to[mm] ^ + ((alpha_to[i - 1] ^ mask) << 1); + else + alpha_to[i] = alpha_to[i - 1] << 1; + + index_of[alpha_to[i]] = i % nn; + } + + /* index of 0 is undefined in a multiplicative field */ + index_of[0] = -1; + + return 0; +} +#endif + static int atmel_pmecc_nand_init_params(struct nand_chip *nand, struct mtd_info *mtd) { @@ -808,11 +910,18 @@ static int atmel_pmecc_nand_init_params(struct nand_chip *nand, sector_size = host->pmecc_sector_size;
/* TODO: need check whether cap & sector_size is validate */ - +#if defined(NO_GALOIS_TABLE_IN_ROM) + /* + * As pmecc_rom_base is the begin of the gallois field table, So the + * index offset just set as 0. + */ + host->pmecc_index_table_offset = 0; +#else if (host->pmecc_sector_size == 512) host->pmecc_index_table_offset = ATMEL_PMECC_INDEX_OFFSET_512; else host->pmecc_index_table_offset = ATMEL_PMECC_INDEX_OFFSET_1024; +#endif
MTDDEBUG(MTD_DEBUG_LEVEL1, "Initialize PMECC params, cap: %d, sector: %d\n", @@ -821,7 +930,23 @@ static int atmel_pmecc_nand_init_params(struct nand_chip *nand, host->pmecc = (struct pmecc_regs __iomem *) ATMEL_BASE_PMECC; host->pmerrloc = (struct pmecc_errloc_regs __iomem *) ATMEL_BASE_PMERRLOC; +#if defined(NO_GALOIS_TABLE_IN_ROM) + /* Set pmecc_rom_base as the begin of gf table */ + int size = host->pmecc_sector_size == 512 ? + PMECC_INDEX_TABLE_SIZE_512 : + PMECC_INDEX_TABLE_SIZE_1024; + pmecc_galois_table = malloc(2 * size * sizeof(uint16_t)); + if (!pmecc_galois_table) + return -ENOMEM; + + host->pmecc_rom_base = pmecc_galois_table; + pmecc_build_galois_table((sector_size == 512) ? PMECC_GF_DIMENSION_13 : + PMECC_GF_DIMENSION_14, + host->pmecc_rom_base, + host->pmecc_rom_base + (size * sizeof(int16_t))); +#else host->pmecc_rom_base = (void __iomem *) ATMEL_BASE_ROM; +#endif
/* ECC is calculated for the whole page (1 step) */ nand->ecc.size = mtd->writesize;
Hi Bo,
before diving into that code I have a question. What will be the boot mode for devices without integrated PMECC table? Can the first stage loader be read with PMECC mode? The question arises while thinking about this patch. We have generally two options here: a) pre-generated PMECC table included in u-boot b) runtime generated PMECC table in RAM (this solution)
While a) will bloat the u-boot binary b) will require some RAM to hold the table. If I understood correctly we will malloc at most 128 KiB for the PMECC table ... Ok option a) is not an option ;) Here my question arises, how can the ROM loader allocate 128 KiB? Do these devices have so many SRAM? Or am I wrong?
- unsigned int i, mask, nn;
- unsigned int p[15];
- nn = (1 << mm) - 1;
- /* set default value */
- for (i = 1; i < mm; i++)
p[i] = 0;
memset(p[1], 0, mm-1); // or even the whole field?
- /* 1 + X^mm */
- p[0] = 1;
- p[mm] = 1;
- /* others */
- switch (mm) {
- case 3:
- case 4:
- case 6:
- case 15:
p[1] = 1;
break;
- case 5:
- case 11:
p[2] = 1;
break;
- case 7:
- case 10:
p[3] = 1;
break;
- case 8:
p[2] = 1;
p[3] = 1;
p[4] = 1;
break;
- case 9:
p[4] = 1;
break;
- case 12:
p[1] = 1;
p[4] = 1;
p[6] = 1;
break;
- case 13:
p[1] = 1;
p[3] = 1;
p[4] = 1;
break;
- case 14:
p[1] = 1;
p[6] = 1;
p[10] = 1;
break;
- default:
/* Error */
return -EINVAL;
- /* Build alpha ^ mm it will help to generate the field (primitiv) */
- alpha_to[mm] = 0;
- for (i = 0; i < mm; i++)
if (p[i])
In fact p[] is a bit-field which is then copied to alpha_to[mm], why not use alpha_to[mm] in the switch-case and eliminate p[]?
- mask = 1;
- for (i = 0; i < mm; i++) {
alpha_to[i] = mask;
mask <<= 1;
- index_of[alpha_to[mm]] = mm;
- /* use a mask to select the MSB bit of the LFSR */
- mask >>= 1;
- /* then finish the building */
- for (i = mm + 1; i <= nn; i++) {
else
- /* index of 0 is undefined in a multiplicative field */
- index_of[0] = -1;
The whole function is so longish and complicated ... I don't really like it. Maybe eliminating p[] makes it better?
+} +#endif
- host->pmecc_index_table_offset = 0;
- /* Set pmecc_rom_base as the begin of gf table */
- int size = host->pmecc_sector_size == 512 ?
- pmecc_galois_table = malloc(2 * size * sizeof(uint16_t));
I fear this will not work with current SPL implementation ...
- if (!pmecc_galois_table)
return -ENOMEM;
- host->pmecc_rom_base = pmecc_galois_table;
- pmecc_build_galois_table((sector_size == 512) ? PMECC_GF_DIMENSION_13 :
Best regards
Andreas Bießmann
Hi Andreas,
On 10/25/2014 06:22 AM, Andreas Bießmann wrote:
Hi Bo,
On SAMA5D4 SoC, the PMECC table is only seen by the ROM loader. So, for atbootstrap, we also need to generate the PMECC table and put it in DDR2 SDRAM. We can use the PMECC generate by atbootstrap, however we must to maintain the address where to put the PMECC table, it will easily cause issues, so we try to regenerate the PMECC table also in u-boot.
p[i] = 0;
OK. I will change it.
- /* 1 + X^mm */
- p[0] = 1;
- p[mm] = 1;
- /* others */
- switch (mm) {
- case 3:
- case 4:
- case 6:
- case 15:
p[1] = 1;
break;
- case 5:
- case 11:
p[2] = 1;
break;
- case 7:
- case 10:
p[3] = 1;
break;
- case 8:
p[2] = 1;
p[3] = 1;
p[4] = 1;
break;
- case 9:
p[4] = 1;
break;
- case 12:
p[1] = 1;
p[4] = 1;
p[6] = 1;
break;
- case 13:
p[1] = 1;
p[3] = 1;
p[4] = 1;
break;
- case 14:
p[1] = 1;
p[6] = 1;
p[10] = 1;
break;
- default:
/* Error */
return -EINVAL;
- alpha_to[mm] = 0;
if (p[i])
I will consider that.
- mask = 1;
alpha_to[i] = mask;
mask <<= 1;
- mask >>= 1;
else
- index_of[0] = -1;
I will try to check the table would be usable in BCH library code.
+} +#endif
- static int atmel_pmecc_nand_init_params(struct nand_chip *nand, struct mtd_info *mtd) {
I test with sama5d3xek board, it is OK. No problem found.
return -ENOMEM;
Best regards
Andreas Bießmann
Best Regards, Bo Shen
Hi, Andreas, Bo
On 10/27/2014 9:47 AM, Bo Shen wrote:
Hi Andreas,
Hi Bo,
Does your ROM loader means the ROM code? As the ROM code has a pre-generated PMECC table included. ROM code and the pre-generated PMECC table are both in the embedded readonly ROM. So that's not in the SRAM.
p[i] = 0;
- /* 1 + X^mm */
- p[0] = 1;
- p[mm] = 1;
- /* others */
- switch (mm) {
- case 3:
- case 4:
- case 6:
- case 15:
p[1] = 1;
break;
- case 5:
- case 11:
p[2] = 1;
break;
- case 7:
- case 10:
p[3] = 1;
break;
- case 8:
p[2] = 1;
p[3] = 1;
p[4] = 1;
break;
- case 9:
p[4] = 1;
break;
- case 12:
p[1] = 1;
p[4] = 1;
p[6] = 1;
break;
- case 13:
p[1] = 1;
p[3] = 1;
p[4] = 1;
break;
- case 14:
p[1] = 1;
p[6] = 1;
p[10] = 1;
break;
- default:
/* Error */
return -EINVAL;
(primitiv) */
- alpha_to[mm] = 0;
if (p[i])
- mask = 1;
alpha_to[i] = mask;
mask <<= 1;
- mask >>= 1;
else
- index_of[0] = -1;
I already submitted a patch to the kernel: http://patchwork.ozlabs.org/patch/398827/ In that patch, this function is rewritten according to BCH code. So I think maybe after that patch is accepted by kernel, then, we can resend new version patch to u-boot.
Best Regards, Josh Wu
Hi Andreas,
Yes, when I try to implement the SPL support for sama5d4ek board, I really meet this issue. I don't know what reason cause this issue. So, can you give me some hints about it? Thanks.
Hi Andreas,
On 10/28/2014 04:05 PM, Bo Shen wrote:
Hi Andreas,
I use the nand read.raw and nand write.raw command with wrong parameter.
It is OK for SPL with this kind of code on sama5d4ek.
Sorry for this noise.
Hi Bo,
On 28.10.14 10:27, Bo Shen wrote:
Hi Andreas,
Hi Andreas,
nice to hear, great!
Best regards
Andreas
The User Register in GMAC IP is used to select interface type. When with GE feature, it is used to select interface between RGMII and GMII. If without GE feature, it is used to select interface between MII and RMII.
drivers/net/macb.c | 8 +++++++- 1 file changed, 7 insertions(+), 1 deletion(-)
diff --git a/drivers/net/macb.c b/drivers/net/macb.c index 01a94a4..369d155 100644 --- a/drivers/net/macb.c +++ b/drivers/net/macb.c @@ -574,7 +574,13 @@ static int macb_init(struct eth_device *netdev, bd_t *bd) macb_writel(macb, TBQP, macb->tx_ring_dma);
if (macb_is_gem(macb)) { -#ifdef CONFIG_RGMII + /* + * When the GMAC IP with GE feature, this bit is used to + * select interface between RGMII and GMII. + * When the GMAC IP without GE feature, this bit is used + * to select interface between RMII and MII. + */ +#if defined(CONFIG_RGMII) || defined(CONFIG_RMII) gem_writel(macb, UR, GEM_BIT(RGMII)); #else gem_writel(macb, UR, 0);
Hi Bo,
looks good
Best regards
Andreas Bießmann
The code for this board supports following features: - Boot media support: NAND flash/SD card/SPI flash - Support LCD display - Support ethernet - Support USB mass storage
arch/arm/Kconfig | 4 + arch/arm/cpu/armv7/at91/timer.c | 3 +- arch/arm/include/asm/arch-at91/at91_pmc.h | 6 +- arch/arm/include/asm/arch-at91/clk.h | 29 +++ arch/arm/include/asm/arch-at91/hardware.h | 2 + arch/arm/include/asm/arch-at91/sama5d4.h | 199 ++++++++++++++++++ board/atmel/sama5d4ek/Kconfig | 18 ++ board/atmel/sama5d4ek/MAINTAINERS | 8 + board/atmel/sama5d4ek/Makefile | 15 ++ board/atmel/sama5d4ek/sama5d4ek.c | 322 ++++++++++++++++++++++++++++++ configs/sama5d4ek_mmc_defconfig | 3 + configs/sama5d4ek_nandflash_defconfig | 3 + configs/sama5d4ek_spiflash_defconfig | 3 + include/configs/sama5d4ek.h | 215 ++++++++++++++++++++ 14 files changed, 826 insertions(+), 4 deletions(-) create mode 100644 arch/arm/include/asm/arch-at91/sama5d4.h create mode 100644 board/atmel/sama5d4ek/Kconfig create mode 100644 board/atmel/sama5d4ek/MAINTAINERS create mode 100644 board/atmel/sama5d4ek/Makefile create mode 100644 board/atmel/sama5d4ek/sama5d4ek.c create mode 100644 configs/sama5d4ek_mmc_defconfig create mode 100644 configs/sama5d4ek_nandflash_defconfig create mode 100644 configs/sama5d4ek_spiflash_defconfig create mode 100644 include/configs/sama5d4ek.h
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index c8537bb..bbccd46 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -321,6 +321,9 @@ config TARGET_SAMA5D3_XPLAINED config TARGET_SAMA5D3XEK bool "Support sama5d3xek"
+config TARGET_SAMA5D4EK + bool "Support sama5d4ek" + config TARGET_BCM28155_AP bool "Support bcm28155_ap"
@@ -569,6 +572,7 @@ source "board/atmel/at91sam9rlek/Kconfig" source "board/atmel/at91sam9x5ek/Kconfig" source "board/atmel/sama5d3_xplained/Kconfig" source "board/atmel/sama5d3xek/Kconfig" +source "board/atmel/sama5d4ek/Kconfig" source "board/balloon3/Kconfig" source "board/barco/titanium/Kconfig" source "board/bluegiga/apx4devkit/Kconfig" diff --git a/arch/arm/cpu/armv7/at91/timer.c b/arch/arm/cpu/armv7/at91/timer.c index e3ebfe0..19bf80b 100644 --- a/arch/arm/cpu/armv7/at91/timer.c +++ b/arch/arm/cpu/armv7/at91/timer.c @@ -65,7 +65,8 @@ int timer_init(void) /* Enable PITC */ writel(TIMER_LOAD_VAL | AT91_PIT_MR_EN , &pit->mr);
- gd->arch.timer_rate_hz = gd->arch.mck_rate_hz / 16; + gd->arch.timer_rate_hz = get_pit_clk_rate() / 16; + gd->arch.tbu = 0; gd->arch.tbl = 0;
diff --git a/arch/arm/include/asm/arch-at91/at91_pmc.h b/arch/arm/include/asm/arch-at91/at91_pmc.h index 27331ff..e81ece9 100644 --- a/arch/arm/include/asm/arch-at91/at91_pmc.h +++ b/arch/arm/include/asm/arch-at91/at91_pmc.h @@ -78,7 +78,7 @@ typedef struct at91_pmc { #define AT91_PMC_PLLXR_DIV(x) (x & 0xFF) #define AT91_PMC_PLLXR_PLLCOUNT(x) ((x & 0x3F) << 8) #define AT91_PMC_PLLXR_OUT(x) ((x & 0x03) << 14) -#ifdef CONFIG_SAMA5D3 +#if defined(CONFIG_SAMA5D3) || defined(CONFIG_SAMA5D4) #define AT91_PMC_PLLXR_MUL(x) ((x & 0x7F) << 18) #else #define AT91_PMC_PLLXR_MUL(x) ((x & 0x7FF) << 16) @@ -97,7 +97,7 @@ typedef struct at91_pmc { #define AT91_PMC_MCKR_CSS_PLLB 0x00000003 #define AT91_PMC_MCKR_CSS_MASK 0x00000003
-#ifdef CONFIG_SAMA5D3 +#if defined(CONFIG_SAMA5D3) || defined(CONFIG_SAMA5D4) #define AT91_PMC_MCKR_PRES_1 0x00000000 #define AT91_PMC_MCKR_PRES_2 0x00000010 #define AT91_PMC_MCKR_PRES_4 0x00000020 @@ -126,7 +126,7 @@ typedef struct at91_pmc { #else #define AT91_PMC_MCKR_MDIV_1 0x00000000 #define AT91_PMC_MCKR_MDIV_2 0x00000100 -#ifdef CONFIG_SAMA5D3 +#if defined(CONFIG_SAMA5D3) || defined(CONFIG_SAMA5D4) #define AT91_PMC_MCKR_MDIV_3 0x00000300 #endif #define AT91_PMC_MCKR_MDIV_4 0x00000200 diff --git a/arch/arm/include/asm/arch-at91/clk.h b/arch/arm/include/asm/arch-at91/clk.h index 4076a78..7615018 100644 --- a/arch/arm/include/asm/arch-at91/clk.h +++ b/arch/arm/include/asm/arch-at91/clk.h @@ -50,12 +50,20 @@ static inline u32 get_pllb_init(void)
static inline unsigned long get_macb_pclk_rate(unsigned int dev_id) { +#ifdef CPU_HAS_H32MXDIV + return get_mck_clk_rate() / H32MXDIV; +#else return get_mck_clk_rate(); +#endif }
static inline unsigned long get_usart_clk_rate(unsigned int dev_id) { +#ifdef CPU_HAS_H32MXDIV + return get_mck_clk_rate() / H32MXDIV; +#else return get_mck_clk_rate(); +#endif }
static inline unsigned long get_lcdc_clk_rate(unsigned int dev_id) @@ -65,17 +73,38 @@ static inline unsigned long get_lcdc_clk_rate(unsigned int dev_id)
static inline unsigned long get_spi_clk_rate(unsigned int dev_id) { +#ifdef CPU_HAS_H32MXDIV + return get_mck_clk_rate() / H32MXDIV; +#else return get_mck_clk_rate(); +#endif }
static inline unsigned long get_twi_clk_rate(unsigned int dev_id) { +#ifdef CPU_HAS_H32MXDIV + return get_mck_clk_rate() / H32MXDIV; +#else return get_mck_clk_rate(); +#endif }
static inline unsigned long get_mci_clk_rate(void) { +#ifdef CPU_HAS_H32MXDIV + return get_mck_clk_rate() / H32MXDIV; +#else return get_mck_clk_rate(); +#endif +} + +static inline unsigned long get_pit_clk_rate(void) +{ +#ifdef CPU_HAS_H32MXDIV + return get_mck_clk_rate() / H32MXDIV; +#else + return get_mck_clk_rate(); +#endif }
int at91_clock_init(unsigned long main_clock); diff --git a/arch/arm/include/asm/arch-at91/hardware.h b/arch/arm/include/asm/arch-at91/hardware.h index d712a0d..bf0a1bd 100644 --- a/arch/arm/include/asm/arch-at91/hardware.h +++ b/arch/arm/include/asm/arch-at91/hardware.h @@ -27,6 +27,8 @@ # include <asm/arch/at91cap9.h> #elif defined(CONFIG_SAMA5D3) # include <asm/arch/sama5d3.h> +#elif defined(CONFIG_SAMA5D4) +# include <asm/arch/sama5d4.h> #else # error "Unsupported AT91 processor" #endif diff --git a/arch/arm/include/asm/arch-at91/sama5d4.h b/arch/arm/include/asm/arch-at91/sama5d4.h new file mode 100644 index 0000000..12a6646 --- /dev/null +++ b/arch/arm/include/asm/arch-at91/sama5d4.h @@ -0,0 +1,199 @@ +/* + * Chip-specific header file for the SAMA5D4 SoC + * + * Copyright (C) 2014 Atmel + * Bo Shen voice.shen@atmel.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __SAMA5D4_H +#define __SAMA5D4_H + +/* + * defines to be used in other places + */ +#define CONFIG_ARMV7 /* ARM Cortex-A5 Core */ +#define CONFIG_AT91FAMILY /* It's a member of AT91 */ + +/* + * Peripheral identifiers/interrupts. + */ +#define ATMEL_ID_FIQ 0 /* FIQ Interrupt */ +#define ATMEL_ID_SYS 1 /* System Controller */ +#define ATMEL_ID_ARM 2 /* Performance Monitor Unit */ +#define ATMEL_ID_PIT 3 /* Periodic Interval Timer */ +#define ATMEL_ID_WDT 4 /* Watchdog timer */ +#define ATMEL_ID_PIOD 5 /* Parallel I/O Controller D */ +#define ATMEL_ID_USART0 6 /* USART 0 */ +#define ATMEL_ID_USART1 7 /* USART 1 */ +#define ATMEL_ID_DMA0 8 /* DMA Controller 0 */ +#define ATMEL_ID_ICM 9 /* Integrity Check Monitor */ +#define ATMEL_ID_PKCC 10 /* Public Key Crypto Controller */ +#define ATMEL_ID_AES 12 /* Advanced Encryption Standard */ +#define ATMEL_ID_AESB 13 /* AES Bridge*/ +#define ATMEL_ID_TDES 14 /* Triple Data Encryption Standard */ +#define ATMEL_ID_SHA 15 /* SHA Signature */ +#define ATMEL_ID_MPDDRC 16 /* MPDDR controller */ +#define ATMEL_ID_MATRIX1 17 /* H32MX, 32-bit AHB Matrix */ +#define ATMEL_ID_MATRIX0 18 /* H64MX, 64-bit AHB Matrix */ +#define ATMEL_ID_VDEC 19 /* Video Decoder */ +#define ATMEL_ID_SBM 20 /* Secure Box Module */ +#define ATMEL_ID_SMC 22 /* Multi-bit ECC interrupt */ +#define ATMEL_ID_PIOA 23 /* Parallel I/O Controller A */ +#define ATMEL_ID_PIOB 24 /* Parallel I/O Controller B */ +#define ATMEL_ID_PIOC 25 /* Parallel I/O Controller C */ +#define ATMEL_ID_PIOE 26 /* Parallel I/O Controller E */ +#define ATMEL_ID_UART0 27 /* UART 0 */ +#define ATMEL_ID_UART1 28 /* UART 1 */ +#define ATMEL_ID_USART2 29 /* USART 2 */ +#define ATMEL_ID_USART3 30 /* USART 3 */ +#define ATMEL_ID_USART4 31 /* USART 4 */ +#define ATMEL_ID_TWI0 32 /* Two-Wire Interface 0 */ +#define ATMEL_ID_TWI1 33 /* Two-Wire Interface 1 */ +#define ATMEL_ID_TWI2 34 /* Two-Wire Interface 2 */ +#define ATMEL_ID_MCI0 35 /* High Speed Multimedia Card Interface 0 */ +#define ATMEL_ID_MCI1 36 /* High Speed Multimedia Card Interface 1 */ +#define ATMEL_ID_SPI0 37 /* Serial Peripheral Interface 0 */ +#define ATMEL_ID_SPI1 38 /* Serial Peripheral Interface 1 */ +#define ATMEL_ID_SPI2 39 /* Serial Peripheral Interface 2 */ +#define ATMEL_ID_TC0 40 /* Timer Counter 0 (ch. 0, 1, 2) */ +#define ATMEL_ID_TC1 41 /* Timer Counter 1 (ch. 3, 4, 5) */ +#define ATMEL_ID_TC2 42 /* Timer Counter 2 (ch. 6, 7, 8) */ +#define ATMEL_ID_PWMC 43 /* Pulse Width Modulation Controller */ +#define ATMEL_ID_ADC 44 /* Touch Screen ADC Controller */ +#define ATMEL_ID_DBGU 45 /* Debug Unit Interrupt */ +#define ATMEL_ID_UHPHS 46 /* USB Host High Speed */ +#define ATMEL_ID_UDPHS 47 /* USB Device High Speed */ +#define ATMEL_ID_SSC0 48 /* Synchronous Serial Controller 0 */ +#define ATMEL_ID_SSC1 49 /* Synchronous Serial Controller 1 */ +#define ATMEL_ID_XDMAC1 50 /* DMA Controller 1 */ +#define ATMEL_ID_LCDC 51 /* LCD Controller */ +#define ATMEL_ID_ISI 52 /* Image Sensor Interface */ +#define ATMEL_ID_TRNG 53 /* True Random Number Generator */ +#define ATMEL_ID_GMAC0 54 /* Ethernet MAC 0 */ +#define ATMEL_ID_GMAC1 55 /* Ethernet MAC 1 */ +#define ATMEL_ID_IRQ 56 /* IRQ Interrupt ID */ +#define ATMEL_ID_SFC 57 /* Fuse Controller */ +#define ATMEL_ID_SECURAM 59 /* Secured RAM */ +#define ATMEL_ID_SMD 61 /* SMD Soft Modem */ +#define ATMEL_ID_TWI3 62 /* Two-Wire Interface 3 */ +#define ATMEL_ID_CATB 63 /* Capacitive Touch Controller */ +#define ATMEL_ID_SFR 64 /* Special Funcion Register */ +#define ATMEL_ID_AIC 65 /* Advanced Interrupt Controller */ +#define ATMEL_ID_SAIC 66 /* Secured Advanced Interrupt Controller */ +#define ATMEL_ID_L2CC 67 /* L2 Cache Controller */ + +/* + * User Peripherals physical base addresses. + */ +#define ATMEL_BASE_LCDC 0xf0000000 +#define ATMEL_BASE_DMAC1 0xf0004000 +#define ATMEL_BASE_ISI 0xf0008000 +#define ATMEL_BASE_PKCC 0xf000C000 +#define ATMEL_BASE_MPDDRC 0xf0010000 +#define ATMEL_BASE_DMAC0 0xf0014000 +#define ATMEL_BASE_PMC 0xf0018000 +#define ATMEL_BASE_MATRIX0 0xf001c000 +#define ATMEL_BASE_AESB 0xf0020000 +/* Reserved: 0xf0024000 - 0xf8000000 */ +#define ATMEL_BASE_MCI0 0xf8000000 +#define ATMEL_BASE_UART0 0xf8004000 +#define ATMEL_BASE_SSC0 0xf8008000 +#define ATMEL_BASE_PWMC 0xf800c000 +#define ATMEL_BASE_SPI0 0xf8010000 +#define ATMEL_BASE_TWI0 0xf8014000 +#define ATMEL_BASE_TWI1 0xf8018000 +#define ATMEL_BASE_TC0 0xf801c000 +#define ATMEL_BASE_GMAC0 0xf8020000 +#define ATMEL_BASE_TWI2 0xf8024000 +#define ATMEL_BASE_SFR 0xf8028000 +#define ATMEL_BASE_USART0 0xf802c000 +#define ATMEL_BASE_USART1 0xf8030000 +/* Reserved: 0xf8034000 - 0xfc000000 */ +#define ATMEL_BASE_MCI1 0xfc000000 +#define ATMEL_BASE_UART1 0xfc004000 +#define ATMEL_BASE_USART2 0xfc008000 +#define ATMEL_BASE_USART3 0xfc00c000 +#define ATMEL_BASE_USART4 0xfc010000 +#define ATMEL_BASE_SSC1 0xfc014000 +#define ATMEL_BASE_SPI1 0xfc018000 +#define ATMEL_BASE_SPI2 0xfc01c000 +#define ATMEL_BASE_TC1 0xfc020000 +#define ATMEL_BASE_TC2 0xfc024000 +#define ATMEL_BASE_GMAC1 0xfc028000 +#define ATMEL_BASE_UDPHS 0xfc02c000 +#define ATMEL_BASE_TRNG 0xfc030000 +#define ATMEL_BASE_ADC 0xfc034000 +#define ATMEL_BASE_TWI3 0xfc038000 + +#define ATMEL_BASE_SMC 0xfc05c000 +#define ATMEL_BASE_PMECC (ATMEL_BASE_SMC + 0x070) +#define ATMEL_BASE_PMERRLOC (ATMEL_BASE_SMC + 0x500) + +#define ATMEL_BASE_PIOD 0xfc068000 +#define ATMEL_BASE_RSTC 0xfc068600 +#define ATMEL_BASE_PIT 0xfc068630 +#define ATMEL_BASE_WDT 0xfc068640 + +#define ATMEL_BASE_DBGU 0xfc069000 +#define ATMEL_BASE_PIOA 0xfc06a000 +#define ATMEL_BASE_PIOB 0xfc06b000 +#define ATMEL_BASE_PIOC 0xfc06c000 +#define ATMEL_BASE_PIOE 0xfc06d000 +#define ATMEL_BASE_AIC 0xfc06e000 + +/* + * Internal Memory. + */ +#define ATMEL_BASE_ROM 0x00000000 /* Internal ROM base address */ +#define ATMEL_BASE_NFC 0x00100000 /* NFC SRAM */ +#define ATMEL_BASE_SRAM 0x00200000 /* Internal ROM base address */ +#define ATMEL_BASE_VDEC 0x00300000 /* Video Decoder Controller */ +#define ATMEL_BASE_UDPHS_FIFO 0x00400000 /* USB Device HS controller */ +#define ATMEL_BASE_OHCI 0x00500000 /* USB Host controller (OHCI) */ +#define ATMEL_BASE_EHCI 0x00600000 /* USB Host controller (EHCI) */ +#define ATMEL_BASE_AXI 0x00700000 +#define ATMEL_BASE_DAP 0x00800000 +#define ATMEL_BASE_SMD 0x00900000 + +/* + * External memory + */ +#define ATMEL_BASE_CS0 0x10000000 +#define ATMEL_BASE_DDRCS 0x20000000 +#define ATMEL_BASE_CS1 0x60000000 +#define ATMEL_BASE_CS2 0x70000000 +#define ATMEL_BASE_CS3 0x80000000 + +/* + * Other misc defines + */ +#define ATMEL_PIO_PORTS 5 +#define CPU_HAS_PIO3 +#define PIO_SCDR_DIV 0x3fff +#define CPU_HAS_PCR +#define CPU_HAS_H32MXDIV + +/* + * The clock of peripheral connect to H32MX is decided by H32MXDIV + * bit in MCKR, if this bit is set, the peripheral only work at half + * of MCK, the MCKR address is 0xf0018030, and H32MXDIV is bit 24. + */ +#define H32MXDIV (readl(0xF0018030) & (1 << 24) ? 2 : 1) + +/* + * No PMECC Galois table in ROM + */ +#define NO_GALOIS_TABLE_IN_ROM + +#ifndef __ASSEMBLY__ +unsigned int get_chip_id(void); +unsigned int get_extension_chip_id(void); +unsigned int has_emac(void); +unsigned int has_gmac(void); +unsigned int has_lcdc(void); +char *get_cpu_name(void); +#endif + +#endif diff --git a/board/atmel/sama5d4ek/Kconfig b/board/atmel/sama5d4ek/Kconfig new file mode 100644 index 0000000..a889895 --- /dev/null +++ b/board/atmel/sama5d4ek/Kconfig @@ -0,0 +1,18 @@ +if TARGET_SAMA5D4EK + +config SYS_CPU + default "armv7" + +config SYS_BOARD + default "sama5d4ek" + +config SYS_VENDOR + default "atmel" + +config SYS_SOC + default "at91" + +config SYS_CONFIG_NAME + default "sama5d4ek" + +endif diff --git a/board/atmel/sama5d4ek/MAINTAINERS b/board/atmel/sama5d4ek/MAINTAINERS new file mode 100644 index 0000000..afe88dd --- /dev/null +++ b/board/atmel/sama5d4ek/MAINTAINERS @@ -0,0 +1,8 @@ +SAMA5D4EK BOARD +M: Bo Shen voice.shen@atmel.com +S: Maintained +F: board/atmel/sama5d4ek/ +F: include/configs/sama5d4ek.h +F: configs/sama5d4ek_mmc_defconfig +F: configs/sama5d4ek_nandflash_defconfig +F: configs/sama5d4ek_spiflash_defconfig diff --git a/board/atmel/sama5d4ek/Makefile b/board/atmel/sama5d4ek/Makefile new file mode 100644 index 0000000..d91525c --- /dev/null +++ b/board/atmel/sama5d4ek/Makefile @@ -0,0 +1,15 @@ +# +# (C) Copyright 2003-2008 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# (C) Copyright 2008 +# Stelian Pop stelian@popies.net +# Lead Tech Design <www.leadtechdesign.com> +# +# (C) Copyright 2014 +# Bo Shen voice.shen@atmel.com +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y += sama5d4ek.o diff --git a/board/atmel/sama5d4ek/sama5d4ek.c b/board/atmel/sama5d4ek/sama5d4ek.c new file mode 100644 index 0000000..099b924 --- /dev/null +++ b/board/atmel/sama5d4ek/sama5d4ek.c @@ -0,0 +1,322 @@ +/* + * Copyright (C) 2014 Atmel + * Bo Shen voice.shen@atmel.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/at91_common.h> +#include <asm/arch/at91_pmc.h> +#include <asm/arch/at91_rstc.h> +#include <asm/arch/gpio.h> +#include <asm/arch/clk.h> +#include <asm/arch/sama5d3_smc.h> +#include <asm/arch/sama5d4.h> +#include <atmel_lcdc.h> +#include <atmel_mci.h> +#include <lcd.h> +#include <mmc.h> +#include <net.h> +#include <netdev.h> +#include <nand.h> +#include <spi.h> + +DECLARE_GLOBAL_DATA_PTR; + +#ifdef CONFIG_ATMEL_SPI +int spi_cs_is_valid(unsigned int bus, unsigned int cs) +{ + return bus == 0 && cs == 0; +} + +void spi_cs_activate(struct spi_slave *slave) +{ + at91_set_pio_output(AT91_PIO_PORTC, 3, 0); +} + +void spi_cs_deactivate(struct spi_slave *slave) +{ + at91_set_pio_output(AT91_PIO_PORTC, 3, 1); +} + +static void sama5d4ek_spi0_hw_init(void) +{ + at91_set_a_periph(AT91_PIO_PORTC, 0, 0); /* SPI0_MISO */ + at91_set_a_periph(AT91_PIO_PORTC, 1, 0); /* SPI0_MOSI */ + at91_set_a_periph(AT91_PIO_PORTC, 2, 0); /* SPI0_SPCK */ + + at91_set_pio_output(AT91_PIO_PORTC, 3, 1); /* SPI0_CS0 */ + + /* Enable clock */ + at91_periph_clk_enable(ATMEL_ID_SPI0); +} +#endif /* CONFIG_ATMEL_SPI */ + +#ifdef CONFIG_NAND_ATMEL +static void sama5d4ek_nand_hw_init(void) +{ + struct at91_smc *smc = (struct at91_smc *)ATMEL_BASE_SMC; + + at91_periph_clk_enable(ATMEL_ID_SMC); + + /* Configure SMC CS3 for NAND */ + writel(AT91_SMC_SETUP_NWE(1) | AT91_SMC_SETUP_NCS_WR(1) | + AT91_SMC_SETUP_NRD(1) | AT91_SMC_SETUP_NCS_RD(1), + &smc->cs[3].setup); + writel(AT91_SMC_PULSE_NWE(2) | AT91_SMC_PULSE_NCS_WR(3) | + AT91_SMC_PULSE_NRD(2) | AT91_SMC_PULSE_NCS_RD(3), + &smc->cs[3].pulse); + writel(AT91_SMC_CYCLE_NWE(5) | AT91_SMC_CYCLE_NRD(5), + &smc->cs[3].cycle); + writel(AT91_SMC_TIMINGS_TCLR(2) | AT91_SMC_TIMINGS_TADL(7) | + AT91_SMC_TIMINGS_TAR(2) | AT91_SMC_TIMINGS_TRR(3) | + AT91_SMC_TIMINGS_TWB(7) | AT91_SMC_TIMINGS_RBNSEL(3)| + AT91_SMC_TIMINGS_NFSEL(1), &smc->cs[3].timings); + writel(AT91_SMC_MODE_RM_NRD | AT91_SMC_MODE_WM_NWE | + AT91_SMC_MODE_EXNW_DISABLE | + AT91_SMC_MODE_DBW_8 | + AT91_SMC_MODE_TDF_CYCLE(3), + &smc->cs[3].mode); + + at91_set_a_periph(AT91_PIO_PORTC, 5, 0); /* D0 */ + at91_set_a_periph(AT91_PIO_PORTC, 6, 0); /* D1 */ + at91_set_a_periph(AT91_PIO_PORTC, 7, 0); /* D2 */ + at91_set_a_periph(AT91_PIO_PORTC, 8, 0); /* D3 */ + at91_set_a_periph(AT91_PIO_PORTC, 9, 0); /* D4 */ + at91_set_a_periph(AT91_PIO_PORTC, 10, 0); /* D5 */ + at91_set_a_periph(AT91_PIO_PORTC, 11, 0); /* D6 */ + at91_set_a_periph(AT91_PIO_PORTC, 12, 0); /* D7 */ + at91_set_a_periph(AT91_PIO_PORTC, 13, 0); /* RE */ + at91_set_a_periph(AT91_PIO_PORTC, 14, 0); /* WE */ + at91_set_a_periph(AT91_PIO_PORTC, 15, 1); /* NCS */ + at91_set_a_periph(AT91_PIO_PORTC, 16, 1); /* RDY */ + at91_set_a_periph(AT91_PIO_PORTC, 17, 1); /* ALE */ + at91_set_a_periph(AT91_PIO_PORTC, 18, 1); /* CLE */ +} +#endif + +#ifdef CONFIG_CMD_USB +static void sama5d4ek_usb_hw_init(void) +{ + at91_set_pio_output(AT91_PIO_PORTE, 11, 0); + at91_set_pio_output(AT91_PIO_PORTE, 12, 0); + at91_set_pio_output(AT91_PIO_PORTE, 10, 0); +} +#endif + +#ifdef CONFIG_LCD +vidinfo_t panel_info = { + .vl_col = 800, + .vl_row = 480, + .vl_clk = 33260000, + .vl_sync = ATMEL_LCDC_INVLINE_NORMAL | ATMEL_LCDC_INVFRAME_NORMAL, + .vl_bpix = LCD_BPP, + .vl_tft = 1, + .vl_hsync_len = 5, + .vl_left_margin = 128, + .vl_right_margin = 0, + .vl_vsync_len = 5, + .vl_upper_margin = 23, + .vl_lower_margin = 22, + .mmio = ATMEL_BASE_LCDC, +}; + +/* No power up/down pin for the LCD pannel */ +void lcd_enable(void) { /* Empty! */ } +void lcd_disable(void) { /* Empty! */ } + +unsigned int has_lcdc(void) +{ + return 1; +} + +static void sama5d4ek_lcd_hw_init(void) +{ + at91_set_a_periph(AT91_PIO_PORTA, 24, 0); /* LCDPWM */ + at91_set_a_periph(AT91_PIO_PORTA, 25, 0); /* LCDDISP */ + at91_set_a_periph(AT91_PIO_PORTA, 26, 0); /* LCDVSYNC */ + at91_set_a_periph(AT91_PIO_PORTA, 27, 0); /* LCDHSYNC */ + at91_set_a_periph(AT91_PIO_PORTA, 28, 0); /* LCDDOTCK */ + at91_set_a_periph(AT91_PIO_PORTA, 29, 0); /* LCDDEN */ + + at91_set_a_periph(AT91_PIO_PORTA, 2, 0); /* LCDD2 */ + at91_set_a_periph(AT91_PIO_PORTA, 3, 0); /* LCDD3 */ + at91_set_a_periph(AT91_PIO_PORTA, 4, 0); /* LCDD4 */ + at91_set_a_periph(AT91_PIO_PORTA, 5, 0); /* LCDD5 */ + at91_set_a_periph(AT91_PIO_PORTA, 6, 0); /* LCDD6 */ + at91_set_a_periph(AT91_PIO_PORTA, 7, 0); /* LCDD7 */ + + at91_set_a_periph(AT91_PIO_PORTA, 10, 0); /* LCDD10 */ + at91_set_a_periph(AT91_PIO_PORTA, 11, 0); /* LCDD11 */ + at91_set_a_periph(AT91_PIO_PORTA, 12, 0); /* LCDD12 */ + at91_set_a_periph(AT91_PIO_PORTA, 13, 0); /* LCDD13 */ + at91_set_a_periph(AT91_PIO_PORTA, 14, 0); /* LCDD14 */ + at91_set_a_periph(AT91_PIO_PORTA, 15, 0); /* LCDD15 */ + + at91_set_a_periph(AT91_PIO_PORTA, 18, 0); /* LCDD18 */ + at91_set_a_periph(AT91_PIO_PORTA, 19, 0); /* LCDD19 */ + at91_set_a_periph(AT91_PIO_PORTA, 20, 0); /* LCDD20 */ + at91_set_a_periph(AT91_PIO_PORTA, 21, 0); /* LCDD21 */ + at91_set_a_periph(AT91_PIO_PORTA, 22, 0); /* LCDD22 */ + at91_set_a_periph(AT91_PIO_PORTA, 23, 0); /* LCDD23 */ + + /* Enable clock */ + at91_periph_clk_enable(ATMEL_ID_LCDC); +} + +#ifdef CONFIG_LCD_INFO +void lcd_show_board_info(void) +{ + ulong dram_size, nand_size; + int i; + char temp[32]; + + lcd_printf("2014 ATMEL Corp\n"); + lcd_printf("at91@atmel.com\n"); + lcd_printf("%s CPU at %s MHz\n", get_cpu_name(), + strmhz(temp, get_cpu_clk_rate())); + + dram_size = 0; + for (i = 0; i < CONFIG_NR_DRAM_BANKS; i++) + dram_size += gd->bd->bi_dram[i].size; + + nand_size = 0; +#ifdef CONFIG_NAND_ATMEL + for (i = 0; i < CONFIG_SYS_MAX_NAND_DEVICE; i++) + nand_size += nand_info[i].size; +#endif + lcd_printf("%ld MB SDRAM, %ld MB NAND\n", + dram_size >> 20, nand_size >> 20); +} +#endif /* CONFIG_LCD_INFO */ + +#endif /* CONFIG_LCD */ + +#ifdef CONFIG_GENERIC_ATMEL_MCI +void sama5d4ek_mci1_hw_init(void) +{ + at91_set_c_periph(AT91_PIO_PORTE, 19, 1); /* MCI1 CDA */ + at91_set_c_periph(AT91_PIO_PORTE, 20, 1); /* MCI1 DA0 */ + at91_set_c_periph(AT91_PIO_PORTE, 21, 1); /* MCI1 DA1 */ + at91_set_c_periph(AT91_PIO_PORTE, 22, 1); /* MCI1 DA2 */ + at91_set_c_periph(AT91_PIO_PORTE, 23, 1); /* MCI1 DA3 */ + at91_set_c_periph(AT91_PIO_PORTE, 18, 0); /* MCI1 CLK */ + + /* + * As the mci io internal pull down is too strong, so if the io needs + * external pull up, the pull up resistor will be very small, if so + * the power consumption will increase, so disable the interanl pull + * down to save the power. + */ + at91_set_pio_pulldown(AT91_PIO_PORTE, 18, 0); + at91_set_pio_pulldown(AT91_PIO_PORTE, 19, 0); + at91_set_pio_pulldown(AT91_PIO_PORTE, 20, 0); + at91_set_pio_pulldown(AT91_PIO_PORTE, 21, 0); + at91_set_pio_pulldown(AT91_PIO_PORTE, 22, 0); + at91_set_pio_pulldown(AT91_PIO_PORTE, 23, 0); + + /* Enable clock */ + at91_periph_clk_enable(ATMEL_ID_MCI1); +} + +int board_mmc_init(bd_t *bis) +{ + /* Enable power for MCI1 interface */ + at91_set_pio_output(AT91_PIO_PORTE, 15, 0); + + return atmel_mci_init((void *)ATMEL_BASE_MCI1); +} +#endif /* CONFIG_GENERIC_ATMEL_MCI */ + +#ifdef CONFIG_MACB +void sama5d4ek_macb0_hw_init(void) +{ + at91_set_a_periph(AT91_PIO_PORTB, 0, 0); /* ETXCK_EREFCK */ + at91_set_a_periph(AT91_PIO_PORTB, 6, 0); /* ERXDV */ + at91_set_a_periph(AT91_PIO_PORTB, 8, 0); /* ERX0 */ + at91_set_a_periph(AT91_PIO_PORTB, 9, 0); /* ERX1 */ + at91_set_a_periph(AT91_PIO_PORTB, 7, 0); /* ERXER */ + at91_set_a_periph(AT91_PIO_PORTB, 2, 0); /* ETXEN */ + at91_set_a_periph(AT91_PIO_PORTB, 12, 0); /* ETX0 */ + at91_set_a_periph(AT91_PIO_PORTB, 13, 0); /* ETX1 */ + at91_set_a_periph(AT91_PIO_PORTB, 17, 0); /* EMDIO */ + at91_set_a_periph(AT91_PIO_PORTB, 16, 0); /* EMDC */ + + /* Enable clock */ + at91_periph_clk_enable(ATMEL_ID_GMAC0); +} +#endif + +char *get_cpu_name() +{ + return "SAMA5D4"; +} + +static void sama5d4ek_serial3_hw_init(void) +{ + at91_set_b_periph(AT91_PIO_PORTE, 17, 1); /* TXD3 */ + at91_set_b_periph(AT91_PIO_PORTE, 16, 0); /* RXD3 */ + + /* Enable clock */ + at91_periph_clk_enable(ATMEL_ID_USART3); +} + +int board_early_init_f(void) +{ + at91_periph_clk_enable(ATMEL_ID_PIOA); + at91_periph_clk_enable(ATMEL_ID_PIOB); + at91_periph_clk_enable(ATMEL_ID_PIOC); + at91_periph_clk_enable(ATMEL_ID_PIOD); + at91_periph_clk_enable(ATMEL_ID_PIOE); + + sama5d4ek_serial3_hw_init(); + + return 0; +} + +int board_init(void) +{ + /* adress of boot parameters */ + gd->bd->bi_boot_params = CONFIG_SYS_SDRAM_BASE + 0x100; + +#ifdef CONFIG_ATMEL_SPI + sama5d4ek_spi0_hw_init(); +#endif +#ifdef CONFIG_NAND_ATMEL + sama5d4ek_nand_hw_init(); +#endif +#ifdef CONFIG_GENERIC_ATMEL_MCI + sama5d4ek_mci1_hw_init(); +#endif +#ifdef CONFIG_MACB + sama5d4ek_macb0_hw_init(); +#endif +#ifdef CONFIG_LCD + sama5d4ek_lcd_hw_init(); +#endif +#ifdef CONFIG_CMD_USB + sama5d4ek_usb_hw_init(); +#endif + + return 0; +} + +int dram_init(void) +{ + gd->ram_size = get_ram_size((void *)CONFIG_SYS_SDRAM_BASE, + CONFIG_SYS_SDRAM_SIZE); + return 0; +} + +int board_eth_init(bd_t *bis) +{ + int rc = 0; + +#ifdef CONFIG_MACB + rc = macb_eth_initialize(0, (void *)ATMEL_BASE_GMAC0, 0x00); +#endif + + return rc; +} diff --git a/configs/sama5d4ek_mmc_defconfig b/configs/sama5d4ek_mmc_defconfig new file mode 100644 index 0000000..16a5ed7 --- /dev/null +++ b/configs/sama5d4ek_mmc_defconfig @@ -0,0 +1,3 @@ +CONFIG_SYS_EXTRA_OPTIONS="SAMA5D4,SYS_USE_MMC" ++S:CONFIG_ARM=y ++S:CONFIG_TARGET_SAMA5D4EK=y diff --git a/configs/sama5d4ek_nandflash_defconfig b/configs/sama5d4ek_nandflash_defconfig new file mode 100644 index 0000000..8b7fbc3 --- /dev/null +++ b/configs/sama5d4ek_nandflash_defconfig @@ -0,0 +1,3 @@ +CONFIG_SYS_EXTRA_OPTIONS="SAMA5D4,SYS_USE_NANDFLASH" ++S:CONFIG_ARM=y ++S:CONFIG_TARGET_SAMA5D4EK=y diff --git a/configs/sama5d4ek_spiflash_defconfig b/configs/sama5d4ek_spiflash_defconfig new file mode 100644 index 0000000..63e9b6c --- /dev/null +++ b/configs/sama5d4ek_spiflash_defconfig @@ -0,0 +1,3 @@ +CONFIG_SYS_EXTRA_OPTIONS="SAMA5D4,SYS_USE_SERIALFLASH" ++S:CONFIG_ARM=y ++S:CONFIG_TARGET_SAMA5D4EK=y diff --git a/include/configs/sama5d4ek.h b/include/configs/sama5d4ek.h new file mode 100644 index 0000000..d50897e --- /dev/null +++ b/include/configs/sama5d4ek.h @@ -0,0 +1,215 @@ +/* + * Configuration settings for the SAMA5D4EK board. + * + * Copyright (C) 2014 Atmel + * Bo Shen voice.shen@atmel.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +#include <asm/hardware.h> + +#define CONFIG_SYS_TEXT_BASE 0x26f00000 + +/* ARM asynchronous clock */ +#define CONFIG_SYS_AT91_SLOW_CLOCK 32768 +#define CONFIG_SYS_AT91_MAIN_CLOCK 12000000 /* from 12 MHz crystal */ +#define CONFIG_SYS_HZ 1000 + +#define CONFIG_ARCH_CPU_INIT + +#define CONFIG_SKIP_LOWLEVEL_INIT +#define CONFIG_BOARD_EARLY_INIT_F +#define CONFIG_DISPLAY_CPUINFO + +#define CONFIG_CMD_BOOTZ +#define CONFIG_OF_LIBFDT /* Device Tree support */ + +#define CONFIG_SYS_GENERIC_BOARD + +/* general purpose I/O */ +#define CONFIG_AT91_GPIO + +/* serial console */ +#define CONFIG_ATMEL_USART +#define CONFIG_USART_BASE ATMEL_BASE_USART3 +#define CONFIG_USART_ID ATMEL_ID_USART3 + +#define CONFIG_BOOTDELAY 3 + +/* + * BOOTP options + */ +#define CONFIG_BOOTP_BOOTFILESIZE +#define CONFIG_BOOTP_BOOTPATH +#define CONFIG_BOOTP_GATEWAY +#define CONFIG_BOOTP_HOSTNAME + +/* No NOR flash */ +#define CONFIG_SYS_NO_FLASH + +/* + * Command line configuration. + */ +#include <config_cmd_default.h> +#undef CONFIG_CMD_FPGA +#undef CONFIG_CMD_IMI +#undef CONFIG_CMD_LOADS +#define CONFIG_CMD_PING +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_SETEXPR + +/* SDRAM */ +#define CONFIG_NR_DRAM_BANKS 1 +#define CONFIG_SYS_SDRAM_BASE ATMEL_BASE_DDRCS +#define CONFIG_SYS_SDRAM_SIZE 0x20000000 + +#define CONFIG_SYS_INIT_SP_ADDR \ + (CONFIG_SYS_SDRAM_BASE + 4 * 1024 - GENERATED_GBL_DATA_SIZE) + +#define CONFIG_SYS_LOAD_ADDR 0x22000000 /* load address */ + +/* SerialFlash */ +#define CONFIG_CMD_SF + +#ifdef CONFIG_CMD_SF +#define CONFIG_ATMEL_SPI +#define CONFIG_ATMEL_SPI0 +#define CONFIG_SPI_FLASH +#define CONFIG_SPI_FLASH_ATMEL +#define CONFIG_SF_DEFAULT_BUS 0 +#define CONFIG_SF_DEFAULT_CS 0 +#define CONFIG_SF_DEFAULT_SPEED 30000000 +#endif + +/* NAND flash */ +#define CONFIG_CMD_NAND + +#ifdef CONFIG_CMD_NAND +#define CONFIG_NAND_ATMEL +#define CONFIG_SYS_MAX_NAND_DEVICE 1 +#define CONFIG_SYS_NAND_BASE ATMEL_BASE_CS3 +/* our ALE is AD21 */ +#define CONFIG_SYS_NAND_MASK_ALE (1 << 21) +/* our CLE is AD22 */ +#define CONFIG_SYS_NAND_MASK_CLE (1 << 22) +#define CONFIG_SYS_NAND_ONFI_DETECTION +/* PMECC & PMERRLOC */ +#define CONFIG_ATMEL_NAND_HWECC +#define CONFIG_ATMEL_NAND_HW_PMECC +#endif + +/* MMC */ +#define CONFIG_CMD_MMC + +#ifdef CONFIG_CMD_MMC +#define CONFIG_MMC +#define CONFIG_GENERIC_MMC +#define CONFIG_GENERIC_ATMEL_MCI +#define ATMEL_BASE_MMCI ATMEL_BASE_MCI1 +#endif + +/* USB */ +#define CONFIG_CMD_USB + +#ifdef CONFIG_CMD_USB +#define CONFIG_USB_EHCI +#define CONFIG_USB_EHCI_ATMEL +#define CONFIG_SYS_USB_EHCI_MAX_ROOT_PORTS 3 +#define CONFIG_USB_STORAGE +#endif + +#if defined(CONFIG_CMD_USB) || defined(CONFIG_CMD_MMC) +#define CONFIG_CMD_FAT +#define CONFIG_DOS_PARTITION +#endif + +/* Ethernet Hardware */ +#define CONFIG_MACB +#define CONFIG_RMII +#define CONFIG_NET_RETRY_COUNT 20 +#define CONFIG_MACB_SEARCH_PHY + +/* LCD */ +#define CONFIG_LCD +#define LCD_BPP LCD_COLOR16 +#define LCD_OUTPUT_BPP 18 +#define CONFIG_LCD_LOGO +#define CONFIG_LCD_INFO +#define CONFIG_LCD_INFO_BELOW_LOGO +#define CONFIG_SYS_WHITE_ON_BLACK +#define CONFIG_ATMEL_HLCD +#define CONFIG_ATMEL_LCD_RGB565 +#define CONFIG_SYS_CONSOLE_IS_IN_ENV + +#ifdef CONFIG_SYS_USE_SERIALFLASH +/* bootstrap + u-boot + env + linux in serial flash */ +#define CONFIG_ENV_IS_IN_SPI_FLASH +#define CONFIG_ENV_SPI_BUS CONFIG_SF_DEFAULT_BUS +#define CONFIG_ENV_SPI_CS CONFIG_SF_DEFAULT_CS +#define CONFIG_ENV_OFFSET 0x10000 +#define CONFIG_ENV_SIZE 0x10000 +#define CONFIG_ENV_SECT_SIZE 0x1000 +#define CONFIG_BOOTCOMMAND "sf probe 0; " \ + "sf read 0x21000000 0xa0000 0x60000; " \ + "sf read 0x22000000 0x100000 0x300000; " \ + "bootz 0x22000000 - 0x21000000" +#elif CONFIG_SYS_USE_NANDFLASH +/* bootstrap + u-boot + env in nandflash */ +#define CONFIG_ENV_IS_IN_NAND +#define CONFIG_ENV_OFFSET 0xc0000 +#define CONFIG_ENV_OFFSET_REDUND 0x100000 +#define CONFIG_ENV_SIZE 0x20000 +#define CONFIG_BOOTCOMMAND "nand read 0x21000000 0x180000 0x80000;" \ + "nand read 0x22000000 0x200000 0x600000;" \ + "bootz 0x22000000 - 0x21000000" +#elif CONFIG_SYS_USE_MMC +/* bootstrap + u-boot + env in sd card */ +#define CONFIG_ENV_IS_IN_FAT +#define CONFIG_FAT_WRITE +#define FAT_ENV_INTERFACE "mmc" +/* + * We don't specify the part number, if device 0 has partition table, it means + * the first partition; it no partition table, then take whole device as a + * FAT file system. + */ +#define FAT_ENV_DEVICE_AND_PART "0" +#define FAT_ENV_FILE "uboot.env" +#define CONFIG_ENV_SIZE 0x4000 +#define CONFIG_BOOTCOMMAND "fatload mmc 0:1 0x21000000 sama5d4ek.dtb; " \ + "fatload mmc 0:1 0x22000000 zImage; " \ + "bootz 0x22000000 - 0x21000000" +#endif + +#ifdef CONFIG_SYS_USE_MMC +#define CONFIG_BOOTARGS \ + "console=ttyS0,115200 earlyprintk " \ + "root=/dev/mmcblk0p2 rw rootwait" +#else +#define CONFIG_BOOTARGS \ + "console=ttyS0,115200 earlyprintk " \ + "mtdparts=atmel_nand:256k(bootstrap)ro,512k(uboot)ro," \ + "256K(env),256k(evn_redundent),256k(spare)," \ + "512k(dtb),6M(kernel)ro,-(rootfs) " \ + "rootfstype=ubifs ubi.mtd=7 root=ubi0:rootfs" +#endif + +#define CONFIG_BAUDRATE 115200 + +#define CONFIG_SYS_PROMPT "U-Boot> " +#define CONFIG_SYS_CBSIZE 256 +#define CONFIG_SYS_MAXARGS 16 +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ + sizeof(CONFIG_SYS_PROMPT) + 16) +#define CONFIG_SYS_LONGHELP +#define CONFIG_CMDLINE_EDITING +#define CONFIG_AUTO_COMPLETE +#define CONFIG_SYS_HUSH_PARSER + +/* Size of malloc() pool */ +#define CONFIG_SYS_MALLOC_LEN (4 * 1024 * 1024) + +#endif
Hi Bo,
- Support ethernet
- bool "Support sama5d4ek"
- gd->arch.timer_rate_hz = get_pit_clk_rate() / 16;
is this part related to sama5d4ek or is it a generic fix? Could yopu please send as an extra patch if it's the latter?
- return get_mck_clk_rate() / H32MXDIV;
+#else
I wonder if we should introduce H32MXDIV for all atmel SoC and remove the CPU_HAS_H32MXDIV here. A division by 1 should be optimized away if it is a constant. After all this piece of code would be more readable.
+#else
- return get_mck_clk_rate();
+#endif }
- Chip-specific header file for the SAMA5D4 SoC
- Copyright (C) 2014 Atmel
Bo Shen <voice.shen@atmel.com>
- defines to be used in other places
We should start moving these defines into Kconfig ... someday
- Peripheral identifiers/interrupts.
- User Peripherals physical base addresses.
- Internal Memory.
- External memory
- Other misc defines
- The clock of peripheral connect to H32MX is decided by H32MXDIV
- bit in MCKR, if this bit is set, the peripheral only work at half
- of MCK, the MCKR address is 0xf0018030, and H32MXDIV is bit 24.
Could we use ATMEL_BASE_PMC + <some new define> here?
- No PMECC Galois table in ROM
+config SYS_CPU
- default "armv7"
+config SYS_BOARD
- default "sama5d4ek"
+config SYS_VENDOR
- default "atmel"
+config SYS_SOC
- default "at91"
- return bus == 0 && cs == 0;
- at91_set_pio_output(AT91_PIO_PORTC, 3, 0);
- at91_set_pio_output(AT91_PIO_PORTC, 3, 1);
- at91_set_a_periph(AT91_PIO_PORTC, 0, 0); /* SPI0_MISO */
- at91_set_a_periph(AT91_PIO_PORTC, 1, 0); /* SPI0_MOSI */
- at91_set_a_periph(AT91_PIO_PORTC, 2, 0); /* SPI0_SPCK */
- at91_set_pio_output(AT91_PIO_PORTC, 3, 1); /* SPI0_CS0 */
- /* Enable clock */
- at91_periph_clk_enable(ATMEL_ID_SPI0);
- struct at91_smc *smc = (struct at91_smc *)ATMEL_BASE_SMC;
- at91_periph_clk_enable(ATMEL_ID_SMC);
- /* Configure SMC CS3 for NAND */
- writel(AT91_SMC_SETUP_NWE(1) | AT91_SMC_SETUP_NCS_WR(1) |
&smc->cs[3].setup);
- writel(AT91_SMC_PULSE_NWE(2) | AT91_SMC_PULSE_NCS_WR(3) |
&smc->cs[3].pulse);
- writel(AT91_SMC_CYCLE_NWE(5) | AT91_SMC_CYCLE_NRD(5),
&smc->cs[3].cycle);
- writel(AT91_SMC_TIMINGS_TCLR(2) | AT91_SMC_TIMINGS_TADL(7) |
- writel(AT91_SMC_MODE_RM_NRD | AT91_SMC_MODE_WM_NWE |
&smc->cs[3].mode);
- at91_set_a_periph(AT91_PIO_PORTC, 5, 0); /* D0 */
- at91_set_a_periph(AT91_PIO_PORTC, 6, 0); /* D1 */
- at91_set_a_periph(AT91_PIO_PORTC, 7, 0); /* D2 */
- at91_set_a_periph(AT91_PIO_PORTC, 8, 0); /* D3 */
- at91_set_a_periph(AT91_PIO_PORTC, 9, 0); /* D4 */
- at91_set_a_periph(AT91_PIO_PORTC, 10, 0); /* D5 */
- at91_set_a_periph(AT91_PIO_PORTC, 11, 0); /* D6 */
- at91_set_a_periph(AT91_PIO_PORTC, 12, 0); /* D7 */
- at91_set_a_periph(AT91_PIO_PORTC, 13, 0); /* RE */
- at91_set_a_periph(AT91_PIO_PORTC, 14, 0); /* WE */
- at91_set_a_periph(AT91_PIO_PORTC, 15, 1); /* NCS */
- at91_set_a_periph(AT91_PIO_PORTC, 16, 1); /* RDY */
- at91_set_a_periph(AT91_PIO_PORTC, 17, 1); /* ALE */
- at91_set_a_periph(AT91_PIO_PORTC, 18, 1); /* CLE */
+} +#endif
- at91_set_pio_output(AT91_PIO_PORTE, 11, 0);
- at91_set_pio_output(AT91_PIO_PORTE, 12, 0);
- at91_set_pio_output(AT91_PIO_PORTE, 10, 0);
+} +#endif
- .vl_col = 800,
- .vl_row = 480,
- .vl_clk = 33260000,
- .vl_sync = ATMEL_LCDC_INVLINE_NORMAL | ATMEL_LCDC_INVFRAME_NORMAL,
- .vl_bpix = LCD_BPP,
- .vl_tft = 1,
- .vl_hsync_len = 5,
- .vl_left_margin = 128,
- .vl_right_margin = 0,
- .vl_vsync_len = 5,
- .vl_upper_margin = 23,
- .vl_lower_margin = 22,
- .mmio = ATMEL_BASE_LCDC,
- return 1;
- at91_set_a_periph(AT91_PIO_PORTA, 24, 0); /* LCDPWM */
- at91_set_a_periph(AT91_PIO_PORTA, 25, 0); /* LCDDISP */
- at91_set_a_periph(AT91_PIO_PORTA, 26, 0); /* LCDVSYNC */
- at91_set_a_periph(AT91_PIO_PORTA, 27, 0); /* LCDHSYNC */
- at91_set_a_periph(AT91_PIO_PORTA, 28, 0); /* LCDDOTCK */
- at91_set_a_periph(AT91_PIO_PORTA, 29, 0); /* LCDDEN */
- at91_set_a_periph(AT91_PIO_PORTA, 2, 0); /* LCDD2 */
- at91_set_a_periph(AT91_PIO_PORTA, 3, 0); /* LCDD3 */
- at91_set_a_periph(AT91_PIO_PORTA, 4, 0); /* LCDD4 */
- at91_set_a_periph(AT91_PIO_PORTA, 5, 0); /* LCDD5 */
- at91_set_a_periph(AT91_PIO_PORTA, 6, 0); /* LCDD6 */
- at91_set_a_periph(AT91_PIO_PORTA, 7, 0); /* LCDD7 */
- at91_set_a_periph(AT91_PIO_PORTA, 10, 0); /* LCDD10 */
- at91_set_a_periph(AT91_PIO_PORTA, 11, 0); /* LCDD11 */
- at91_set_a_periph(AT91_PIO_PORTA, 12, 0); /* LCDD12 */
- at91_set_a_periph(AT91_PIO_PORTA, 13, 0); /* LCDD13 */
- at91_set_a_periph(AT91_PIO_PORTA, 14, 0); /* LCDD14 */
- at91_set_a_periph(AT91_PIO_PORTA, 15, 0); /* LCDD15 */
- at91_set_a_periph(AT91_PIO_PORTA, 18, 0); /* LCDD18 */
- at91_set_a_periph(AT91_PIO_PORTA, 19, 0); /* LCDD19 */
- at91_set_a_periph(AT91_PIO_PORTA, 20, 0); /* LCDD20 */
- at91_set_a_periph(AT91_PIO_PORTA, 21, 0); /* LCDD21 */
- at91_set_a_periph(AT91_PIO_PORTA, 22, 0); /* LCDD22 */
- at91_set_a_periph(AT91_PIO_PORTA, 23, 0); /* LCDD23 */
- at91_periph_clk_enable(ATMEL_ID_LCDC);
- ulong dram_size, nand_size;
- int i;
- char temp[32];
- lcd_printf("2014 ATMEL Corp\n");
- lcd_printf("at91@atmel.com\n");
- lcd_printf("%s CPU at %s MHz\n", get_cpu_name(),
- dram_size = 0;
- for (i = 0; i < CONFIG_NR_DRAM_BANKS; i++)
- nand_size = 0;
- for (i = 0; i < CONFIG_SYS_MAX_NAND_DEVICE; i++)
- lcd_printf("%ld MB SDRAM, %ld MB NAND\n",
- at91_set_c_periph(AT91_PIO_PORTE, 19, 1); /* MCI1 CDA */
- at91_set_c_periph(AT91_PIO_PORTE, 20, 1); /* MCI1 DA0 */
- at91_set_c_periph(AT91_PIO_PORTE, 21, 1); /* MCI1 DA1 */
- at91_set_c_periph(AT91_PIO_PORTE, 22, 1); /* MCI1 DA2 */
- at91_set_c_periph(AT91_PIO_PORTE, 23, 1); /* MCI1 DA3 */
- at91_set_c_periph(AT91_PIO_PORTE, 18, 0); /* MCI1 CLK */
- at91_set_pio_pulldown(AT91_PIO_PORTE, 18, 0);
- at91_set_pio_pulldown(AT91_PIO_PORTE, 19, 0);
- at91_set_pio_pulldown(AT91_PIO_PORTE, 20, 0);
- at91_set_pio_pulldown(AT91_PIO_PORTE, 21, 0);
- at91_set_pio_pulldown(AT91_PIO_PORTE, 22, 0);
- at91_set_pio_pulldown(AT91_PIO_PORTE, 23, 0);
- at91_periph_clk_enable(ATMEL_ID_MCI1);
- /* Enable power for MCI1 interface */
- at91_set_pio_output(AT91_PIO_PORTE, 15, 0);
- return atmel_mci_init((void *)ATMEL_BASE_MCI1);
- at91_set_a_periph(AT91_PIO_PORTB, 0, 0); /* ETXCK_EREFCK */
- at91_set_a_periph(AT91_PIO_PORTB, 6, 0); /* ERXDV */
- at91_set_a_periph(AT91_PIO_PORTB, 8, 0); /* ERX0 */
- at91_set_a_periph(AT91_PIO_PORTB, 9, 0); /* ERX1 */
- at91_set_a_periph(AT91_PIO_PORTB, 7, 0); /* ERXER */
- at91_set_a_periph(AT91_PIO_PORTB, 2, 0); /* ETXEN */
- at91_set_a_periph(AT91_PIO_PORTB, 12, 0); /* ETX0 */
- at91_set_a_periph(AT91_PIO_PORTB, 13, 0); /* ETX1 */
- at91_set_a_periph(AT91_PIO_PORTB, 17, 0); /* EMDIO */
- at91_set_a_periph(AT91_PIO_PORTB, 16, 0); /* EMDC */
- at91_periph_clk_enable(ATMEL_ID_GMAC0);
+} +#endif
- return "SAMA5D4";
Since when is the get_cpu_name() a board function? This should be placed in some SoC file. Generally I'm missing a sama5d4_devices.c There should be placed some of the functions here in the board code.
- at91_set_b_periph(AT91_PIO_PORTE, 17, 1); /* TXD3 */
- at91_set_b_periph(AT91_PIO_PORTE, 16, 0); /* RXD3 */
- at91_periph_clk_enable(ATMEL_ID_USART3);
- at91_periph_clk_enable(ATMEL_ID_PIOA);
- at91_periph_clk_enable(ATMEL_ID_PIOB);
- at91_periph_clk_enable(ATMEL_ID_PIOC);
- at91_periph_clk_enable(ATMEL_ID_PIOD);
- at91_periph_clk_enable(ATMEL_ID_PIOE);
- sama5d4ek_serial3_hw_init();
- /* adress of boot parameters */
- gd->bd->bi_boot_params = CONFIG_SYS_SDRAM_BASE + 0x100;
- sama5d4ek_spi0_hw_init();
- sama5d4ek_nand_hw_init();
- sama5d4ek_mci1_hw_init();
- sama5d4ek_macb0_hw_init();
- sama5d4ek_lcd_hw_init();
- sama5d4ek_usb_hw_init();
- gd->ram_size = get_ram_size((void *)CONFIG_SYS_SDRAM_BASE,
- int rc = 0;
+#ifdef CONFIG_MACB
- rc = macb_eth_initialize(0, (void *)ATMEL_BASE_GMAC0, 0x00);
- return rc;
- Configuration settings for the SAMA5D4EK board.
- BOOTP options
- Command line configuration.
- (CONFIG_SYS_SDRAM_BASE + 4 * 1024 - GENERATED_GBL_DATA_SIZE)
- We don't specify the part number, if device 0 has partition table, it means
- the first partition; it no partition table, then take whole device as a
- FAT file system.
- "console=ttyS0,115200 earlyprintk " \
- "root=/dev/mmcblk0p2 rw rootwait"
- "mtdparts=atmel_nand:256k(bootstrap)ro,512k(uboot)ro," \
- "256K(env),256k(evn_redundent),256k(spare)," \
- "512k(dtb),6M(kernel)ro,-(rootfs) " \
- "rootfstype=ubifs ubi.mtd=7 root=ubi0:rootfs"
Best Regards
Andreas Bießmann
Hi Andreas,
On 10/25/2014 08:26 AM, Andreas Bießmann wrote:
Hi Bo,
- Support ethernet
- config TARGET_BCM28155_AP bool "Support bcm28155_ap"
This is part related to sama5d4ek, as we introduce the H32MXDIV.
+#else
I don't think that a good idea, as the H32MXDIV is only appear in SAMA5D4 SoC, it is a bit in Master Clock Register (MCKR) and whether the H32MXDIV is set according to the master clock frequency. If H32MXDIV is set, then div2, or else div 1. Maybe a better way is: --->8--- #ifdef CPU_HAS_H32MXDIV if (H32MXDIV) return get_mck_clk_rate() / 2; else return get_mck_clk_rate(); #else ... ---8<---
+#else
+#endif }
That's a good idea.
- Internal Memory.
- External memory
Yes. I will add it.
+config SYS_CPU
- default "armv7"
+config SYS_BOARD
+config SYS_VENDOR
- default "atmel"
+config SYS_SOC
- default "at91"
&smc->cs[3].setup);
&smc->cs[3].pulse);
&smc->cs[3].cycle);
&smc->cs[3].mode);
+} +#endif
+} +#endif
- .vl_col = 800,
- .vl_row = 480,
- .vl_tft = 1,
- return 1;
- int i;
- char temp[32];
- dram_size = 0;
- nand_size = 0;
+} +#endif
- return "SAMA5D4";
This should be a SoC function and in SoC file.
As the SoC before SAMA5D4 which has pins can not be mux, so we put this part of code in SoC file (<soc_name>_device.c), however on SAMA5D4 SoC, almost can not find the pin can not be mux, so, I don't keep the sama5d4_device.c file.
- int rc = 0;
+#ifdef CONFIG_MACB
- return rc;
- BOOTP options
- FAT file system.
Best Regards
Andreas Bießmann
On 16/09/2014 09:57, Bo Shen :
- Support ethernet
For the whole series:
Acked-by: Nicolas Ferre nicolas.ferre@atmel.com
Thanks, best regards,
Andreas Bießmann
Bo Shen
Josh Wu
Nicolas Ferre
