Re: [U-Boot-Users] [PATCH] MIPS time.c fix
11 Dec
2006
11 Dec
'06
11:03 a.m.
The above is not true for all MIPS. A lot (almost all) of older MIPS parts run the cpu CP0 counter at half the core clock rate.
Thanks for your feedback; I wasn't aware of this. I've encountered a couple of /2 constructions in some configurations, but I though that was just a quick fix that degrades the granularity of the timer by half in order to prevent overflows in net.c.
I would suggest changing CPU_CLOCK_RATE to CPU_CP0_COUNT_RATE since they are not always the same.
I have changed it to CFG_CP0_COUNT_RATE, if you don't mind. The IncaIP and Purple platform seem to have cores with half-speed COUNT registers so those have been fixed too. Behold the new patch ;-)
6723
Robert Deliën
