[PATCH v1] arm: dts: rockchip: rk3288: move dma-controller nodes
In order to better compare the Linux rk3288.dtsi version with the u-boot version move the dma-controller nodes to the DT root.
Signed-off-by: Johan Jonker jbx6244@gmail.com --- arch/arm/dts/rk3288.dtsi | 76 ++++++++++++++++++---------------------- 1 file changed, 35 insertions(+), 41 deletions(-)
diff --git a/arch/arm/dts/rk3288.dtsi b/arch/arm/dts/rk3288.dtsi index 469df94e..53ee760b 100644 --- a/arch/arm/dts/rk3288.dtsi +++ b/arch/arm/dts/rk3288.dtsi @@ -86,47 +86,6 @@ }; };
- amba { - compatible = "arm,amba-bus"; - #address-cells = <1>; - #size-cells = <1>; - ranges; - - dmac_peri: dma-controller@ff250000 { - compatible = "arm,pl330", "arm,primecell"; - broken-no-flushp; - reg = <0xff250000 0x4000>; - interrupts = <GIC_SPI 2 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 3 IRQ_TYPE_LEVEL_HIGH>; - #dma-cells = <1>; - clocks = <&cru ACLK_DMAC2>; - clock-names = "apb_pclk"; - }; - - dmac_bus_ns: dma-controller@ff600000 { - compatible = "arm,pl330", "arm,primecell"; - broken-no-flushp; - reg = <0xff600000 0x4000>; - interrupts = <GIC_SPI 0 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 1 IRQ_TYPE_LEVEL_HIGH>; - #dma-cells = <1>; - clocks = <&cru ACLK_DMAC1>; - clock-names = "apb_pclk"; - status = "disabled"; - }; - - dmac_bus_s: dma-controller@ffb20000 { - compatible = "arm,pl330", "arm,primecell"; - broken-no-flushp; - reg = <0xffb20000 0x4000>; - interrupts = <GIC_SPI 0 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 1 IRQ_TYPE_LEVEL_HIGH>; - #dma-cells = <1>; - clocks = <&cru ACLK_DMAC1>; - clock-names = "apb_pclk"; - }; - }; - xin24m: oscillator { compatible = "fixed-clock"; clock-frequency = <24000000>; @@ -367,6 +326,18 @@ pinctrl-0 = <&uart4_xfer>; status = "disabled"; }; + + dmac_peri: dma-controller@ff250000 { + compatible = "arm,pl330", "arm,primecell"; + reg = <0xff250000 0x4000>; + interrupts = <GIC_SPI 2 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 3 IRQ_TYPE_LEVEL_HIGH>; + #dma-cells = <1>; + broken-no-flushp; + clocks = <&cru ACLK_DMAC2>; + clock-names = "apb_pclk"; + }; + thermal: thermal-zones { #include "rk3288-thermal.dtsi" }; @@ -458,6 +429,18 @@ status = "disabled"; };
+ dmac_bus_ns: dma-controller@ff600000 { + compatible = "arm,pl330", "arm,primecell"; + reg = <0xff600000 0x4000>; + interrupts = <GIC_SPI 0 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 1 IRQ_TYPE_LEVEL_HIGH>; + #dma-cells = <1>; + broken-no-flushp; + clocks = <&cru ACLK_DMAC1>; + clock-names = "apb_pclk"; + status = "disabled"; + }; + i2c0: i2c@ff650000 { compatible = "rockchip,rk3288-i2c"; reg = <0xff650000 0x1000>; @@ -870,6 +853,17 @@ status = "disabled"; };
+ dmac_bus_s: dma-controller@ffb20000 { + compatible = "arm,pl330", "arm,primecell"; + reg = <0xffb20000 0x4000>; + interrupts = <GIC_SPI 0 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 1 IRQ_TYPE_LEVEL_HIGH>; + #dma-cells = <1>; + broken-no-flushp; + clocks = <&cru ACLK_DMAC1>; + clock-names = "apb_pclk"; + }; + efuse: efuse@ffb40000 { compatible = "rockchip,rk3288-efuse"; reg = <0xffb40000 0x10000>;
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
- amba {
#size-cells = <1>;
ranges;
broken-no-flushp;
#dma-cells = <1>;
broken-no-flushp;
#dma-cells = <1>;
broken-no-flushp;
#dma-cells = <1>;
#dma-cells = <1>;
broken-no-flushp;
- thermal: thermal-zones { #include "rk3288-thermal.dtsi" };
#dma-cells = <1>;
broken-no-flushp;
- i2c0: i2c@ff650000 { compatible = "rockchip,rk3288-i2c"; reg = <0xff650000 0x1000>;
#dma-cells = <1>;
broken-no-flushp;
- efuse: efuse@ffb40000 { compatible = "rockchip,rk3288-efuse"; reg = <0xffb40000 0x10000>;
Johan Jonker
Kever Yang
